[PATCH 00/43] test: Improvements to ut command and test-suite running
The current method of running unit tests relies on subcommands of the ut command. Only the code in each subcommand knows how to find the tests related to that subcomand.
This is not ideal and we now have quite a few subcommands which do nothing but locate the relevant tests in a linker list, then call a common function to run them.
This series adds a list of test suites, so that these subcommands can be removed.
An issue with 'ut all' is that it doesn't record how many tests failed overall, so it is necessary to examine copious amounts of output to look for failures. This series adds a new 'total' feature allow recording the total number of failed tests.
To help with 'ut all' a new pytest is created which runs it (as well as 'ut info') and makes sure that all is well. Due to the 'ut all' failures this does not pass, so the test is disabled for now. It is here because it provides security against misnaming a test suite and causing it not to run.
Future work may: - get 'ut all' passing - enable test_suite() in CL, to ensure that 'ut all' keeps passing - record duration of each suite - allow running the tests in random order to tease out dependencies - tweak the output to remove common prefixes - getting rid of bootstd, optee and seame 'ut' subcommands
Simon Glass (43): test: Drop unused suite prototypes test: Rename test_get_state() to ut_get_state() test: Add functions to init and uninit the test state test: Pass the test-state into ut_run_list() Improve support for linker lists in data structures test: Add newlines to hush-test messages test: Rename test suites to match their linker-list name test: Update ut info to show suites test/py: Add a test which runs all unit tests test: Drop the _test suffix on linker lists test: Introduce a better array of test suites test: Drop the function for running bdinfo tests test: Drop the function for running cmd tests test: Drop the function for running common tests test: Drop the function for running dm tests test: Drop the function for running env tests test: Drop the function for running exit tests test: Drop the function for running fdt tests test: Drop the function for running font tests test: Drop the function for running lib tests test: Drop the function for running log tests test: Drop the function for running mbr tests test: Drop the function for running mem tests test: Drop the function for running setexpr tests test: Drop the function for running measurement tests test: Drop the function for running bloblist tests test: Drop the function for running bootm tests test: Drop the function for running addrmap tests test: Drop the function for running hush tests test: Drop the function for running loadm tests test: Drop the function for running pci_mps tests test: Drop the function for running seama tests test: Drop the function for running upl tests test: Drop the info test from the list test: Drop conditional compilation for suites test: Pass the test state to cmd_ut_category() test: Move stats into a struct test: Keep a track of the numbers of tests run test: Move stat-printing into its own function test: Record and show the totals for all test runs test: Sort the test suites test: Disable test_suite test: Move help into the suite declaration
arch/sandbox/cpu/spl.c | 6 +- include/dm/test.h | 2 +- include/linker_lists.h | 51 +++++ include/test/cmd.h | 2 +- include/test/common.h | 2 +- include/test/env.h | 2 +- include/test/hush.h | 2 +- include/test/lib.h | 2 +- include/test/log.h | 4 +- include/test/optee.h | 2 +- include/test/overlay.h | 2 +- include/test/suites.h | 53 ++--- include/test/test.h | 23 ++- include/test/ut.h | 45 ++++- test/boot/bootm.c | 11 +- test/boot/bootstd_common.c | 9 +- test/boot/bootstd_common.h | 3 +- test/boot/measurement.c | 12 +- test/boot/upl.c | 11 +- test/cmd/Makefile | 4 +- test/cmd/addrmap.c | 11 +- test/cmd/bdinfo.c | 10 +- test/cmd/cmd_ut_cmd.c | 20 -- test/cmd/exit.c | 11 +- test/cmd/fdt.c | 10 +- test/cmd/font.c | 10 +- test/cmd/loadm.c | 11 +- test/cmd/mbr.c | 10 +- test/cmd/mem.c | 19 -- test/cmd/mem_copy.c | 2 +- test/cmd/mem_search.c | 2 +- test/cmd/pci_mps.c | 12 +- test/cmd/seama.c | 11 +- test/cmd/setexpr.c | 11 +- test/cmd_ut.c | 361 +++++++++++++++++++++------------- test/common/Makefile | 1 - test/common/bloblist.c | 12 +- test/common/cmd_ut_common.c | 21 -- test/dm/Makefile | 2 - test/dm/test-dm.c | 16 -- test/dm/test-driver.c | 10 +- test/dm/test-uclass.c | 8 +- test/env/cmd_ut_env.c | 10 - test/hush/Makefile | 1 - test/hush/cmd_ut_hush.c | 19 -- test/hush/dollar.c | 7 +- test/hush/loop.c | 4 +- test/lib/Makefile | 1 - test/lib/cmd_ut_lib.c | 19 -- test/log/Makefile | 2 - test/log/log_ut.c | 20 -- test/optee/cmd_ut_optee.c | 4 +- test/overlay/cmd_ut_overlay.c | 14 +- test/py/conftest.py | 7 +- test/py/tests/test_spl.py | 2 +- test/py/tests/test_suite.py | 182 +++++++++++++++++ test/py/tests/test_upl.py | 2 +- test/py/tests/test_ut.py | 2 +- test/py/tests/test_vbe.py | 2 +- test/py/tests/test_vpl.py | 2 +- test/test-main.c | 104 ++++++---- test/ut.c | 4 +- 62 files changed, 657 insertions(+), 580 deletions(-) delete mode 100644 test/cmd/cmd_ut_cmd.c delete mode 100644 test/cmd/mem.c delete mode 100644 test/common/cmd_ut_common.c delete mode 100644 test/dm/test-dm.c delete mode 100644 test/hush/cmd_ut_hush.c delete mode 100644 test/lib/cmd_ut_lib.c delete mode 100644 test/log/log_ut.c create mode 100644 test/py/tests/test_suite.py
Drop some the prototypes for functions which were removed in earlier series.
include/test/suites.h | 7 ------- 1 file changed, 7 deletions(-)
diff --git a/include/test/suites.h b/include/test/suites.h index 2ceef577f7f..e40ad634702 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -36,8 +36,6 @@ int do_ut_bloblist(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_cmd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_common(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_compression(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]); int do_ut_dm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_env(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_exit(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); @@ -55,14 +53,9 @@ int do_ut_overlay(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_pci_mps(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_print(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_seama(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_setexpr(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_str(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_time(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_unicode(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]); int do_ut_upl(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]);
#endif /* __TEST_SUITES_H__ */
Rename this function and test_set_state() so use the same ut_ prefix as other functions in ut.h
include/test/ut.h | 8 ++++---- test/dm/test-driver.c | 10 +++++----- test/dm/test-uclass.c | 8 ++++---- test/test-main.c | 8 ++++---- 4 files changed, 17 insertions(+), 17 deletions(-)
diff --git a/include/test/ut.h b/include/test/ut.h index c8838dad096..2e4d8edf826 100644 --- a/include/test/ut.h +++ b/include/test/ut.h @@ -466,18 +466,18 @@ void ut_unsilence_console(struct unit_test_state *uts); void ut_set_skip_delays(struct unit_test_state *uts, bool skip_delays);
/** - * test_get_state() - Get the active test state + * ut_state_get() - Get the active test state * * Return: the currently active test state, or NULL if none */ -struct unit_test_state *test_get_state(void); +struct unit_test_state *ut_get_state(void);
/** - * test_set_state() - Set the active test state + * ut_set_state() - Set the active test state * * @uts: Test state to use as currently active test state, or NULL if none */ -void test_set_state(struct unit_test_state *uts); +void ut_set_state(struct unit_test_state *uts);
/** * ut_run_tests() - Run a set of tests diff --git a/test/dm/test-driver.c b/test/dm/test-driver.c index 851177c3018..759de3a5f77 100644 --- a/test/dm/test-driver.c +++ b/test/dm/test-driver.c @@ -35,7 +35,7 @@ static const struct test_ops test_ops = {
static int test_bind(struct udevice *dev) { - struct unit_test_state *uts = test_get_state(); + struct unit_test_state *uts = ut_get_state();
/* Private data should not be allocated */ ut_assert(!dev_get_priv(dev)); @@ -46,7 +46,7 @@ static int test_bind(struct udevice *dev)
static int test_probe(struct udevice *dev) { - struct unit_test_state *uts = test_get_state(); + struct unit_test_state *uts = ut_get_state(); struct dm_test_priv *priv = dev_get_priv(dev);
/* Private data should be allocated */ @@ -59,7 +59,7 @@ static int test_probe(struct udevice *dev)
static int test_remove(struct udevice *dev) { - struct unit_test_state *uts = test_get_state(); + struct unit_test_state *uts = ut_get_state();
/* Private data should still be allocated */ ut_assert(dev_get_priv(dev)); @@ -70,7 +70,7 @@ static int test_remove(struct udevice *dev)
static int test_unbind(struct udevice *dev) { - struct unit_test_state *uts = test_get_state(); + struct unit_test_state *uts = ut_get_state();
/* Private data should not be allocated */ ut_assert(!dev_get_priv(dev)); @@ -121,7 +121,7 @@ static int test_manual_bind(struct udevice *dev)
static int test_manual_probe(struct udevice *dev) { - struct unit_test_state *uts = test_get_state(); + struct unit_test_state *uts = ut_get_state();
dm_testdrv_op_count[DM_TEST_OP_PROBE]++; if (!uts->force_fail_alloc) diff --git a/test/dm/test-uclass.c b/test/dm/test-uclass.c index 9a80cc63667..be4108bbecb 100644 --- a/test/dm/test-uclass.c +++ b/test/dm/test-uclass.c @@ -28,7 +28,7 @@ int test_ping(struct udevice *dev, int pingval, int *pingret)
static int test_post_bind(struct udevice *dev) { - struct unit_test_state *uts = test_get_state(); + struct unit_test_state *uts = ut_get_state(); struct dm_test_perdev_uc_pdata *uc_pdata;
dm_testdrv_op_count[DM_TEST_OP_POST_BIND]++; @@ -54,7 +54,7 @@ static int test_pre_unbind(struct udevice *dev) static int test_pre_probe(struct udevice *dev) { struct dm_test_uclass_perdev_priv *priv = dev_get_uclass_priv(dev); - struct unit_test_state *uts = test_get_state(); + struct unit_test_state *uts = ut_get_state();
dm_testdrv_op_count[DM_TEST_OP_PRE_PROBE]++; ut_assert(priv); @@ -65,7 +65,7 @@ static int test_pre_probe(struct udevice *dev)
static int test_post_probe(struct udevice *dev) { - struct unit_test_state *uts = test_get_state(); + struct unit_test_state *uts = ut_get_state(); struct udevice *prev = list_entry(dev->uclass_node.prev, struct udevice, uclass_node);
@@ -100,7 +100,7 @@ static int test_pre_remove(struct udevice *dev)
static int test_init(struct uclass *uc) { - struct unit_test_state *uts = test_get_state(); + struct unit_test_state *uts = ut_get_state();
dm_testdrv_op_count[DM_TEST_OP_INIT]++; ut_assert(uclass_get_priv(uc)); diff --git a/test/test-main.c b/test/test-main.c index 8d764892fa6..cfb3504941d 100644 --- a/test/test-main.c +++ b/test/test-main.c @@ -63,12 +63,12 @@ static enum fdtchk_t fdt_action(void) /* This is valid when a test is running, NULL otherwise */ static struct unit_test_state *cur_test_state;
-struct unit_test_state *test_get_state(void) +struct unit_test_state *ut_get_state(void) { return cur_test_state; }
-void test_set_state(struct unit_test_state *uts) +void ut_set_state(struct unit_test_state *uts) { cur_test_state = uts; } @@ -466,7 +466,7 @@ static int ut_run_test(struct unit_test_state *uts, struct unit_test *test, printf("Test: %s: %s%s\n", test_name, fname, note);
/* Allow access to test state from drivers */ - test_set_state(uts); + ut_set_state(uts);
ret = test_pre_run(uts, test); if (ret == -EAGAIN) @@ -482,7 +482,7 @@ static int ut_run_test(struct unit_test_state *uts, struct unit_test *test, if (ret) return ret;
- test_set_state( NULL); + ut_set_state(NULL);
return 0; }
Move these operations into separate functions so that it is clearer what is needed. These functions can also be called from somewhere other than ut_run_list().
test/test-main.c | 21 ++++++++++++++++----- 1 file changed, 16 insertions(+), 5 deletions(-)
diff --git a/test/test-main.c b/test/test-main.c index cfb3504941d..871fc1f22b4 100644 --- a/test/test-main.c +++ b/test/test-main.c @@ -73,6 +73,19 @@ void ut_set_state(struct unit_test_state *uts) cur_test_state = uts; }
+void ut_init_state(struct unit_test_state *uts) +{ + memset(uts, '\0', sizeof(*uts)); +} + +void ut_uninit_state(struct unit_test_state *uts) +{ + if (IS_ENABLED(CONFIG_SANDBOX)) { + os_free(uts->fdt_copy); + os_free(uts->other_fdt); + } +} + /** * dm_test_pre_run() - Get ready to run a driver model test * @@ -664,10 +677,11 @@ int ut_run_list(const char *category, const char *prefix, struct unit_test *tests, int count, const char *select_name, int runs_per_test, bool force_run, const char *test_insert) { - struct unit_test_state uts = { .fail_count = 0 }; + struct unit_test_state uts; bool has_dm_tests = false; int ret;
+ ut_init_state(&uts); if (!CONFIG_IS_ENABLED(OF_PLATDATA) && ut_list_has_dm_tests(tests, count, prefix, select_name)) { has_dm_tests = true; @@ -703,10 +717,6 @@ int ut_run_list(const char *category, const char *prefix, /* Best efforts only...ignore errors */ if (has_dm_tests) dm_test_restore(uts.of_root); - if (IS_ENABLED(CONFIG_SANDBOX)) { - os_free(uts.fdt_copy); - os_free(uts.other_fdt); - }
if (uts.skip_count) printf("Skipped: %d, ", uts.skip_count); @@ -714,6 +724,7 @@ int ut_run_list(const char *category, const char *prefix, printf("Test '%s' not found\n", select_name); else printf("Failures: %d\n", uts.fail_count); + ut_uninit_state(&uts);
return ret; }
Pass this into the function so that callers can inspect the state afterwards.
arch/sandbox/cpu/spl.c | 5 ++++- include/test/ut.h | 29 ++++++++++++++++++++++++++--- test/cmd_ut.c | 5 ++++- test/test-main.c | 35 +++++++++++++++++------------------ 4 files changed, 51 insertions(+), 23 deletions(-)
diff --git a/arch/sandbox/cpu/spl.c b/arch/sandbox/cpu/spl.c index 7056cfd0180..0ad23e4ba95 100644 --- a/arch/sandbox/cpu/spl.c +++ b/arch/sandbox/cpu/spl.c @@ -147,10 +147,13 @@ void spl_board_init(void) if (state->run_unittests) { struct unit_test *tests = UNIT_TEST_ALL_START(); const int count = UNIT_TEST_ALL_COUNT(); + struct unit_test_state uts; int ret;
- ret = ut_run_list("spl", NULL, tests, count, + ut_init_state(&uts); + ret = ut_run_list(&uts, "spl", NULL, tests, count, state->select_unittests, 1, false, NULL); + ut_uninit_state(&uts); /* continue execution into U-Boot */ } } diff --git a/include/test/ut.h b/include/test/ut.h index 2e4d8edf826..a51defc3b90 100644 --- a/include/test/ut.h +++ b/include/test/ut.h @@ -479,12 +479,34 @@ struct unit_test_state *ut_get_state(void); */ void ut_set_state(struct unit_test_state *uts);
+/** + * ut_init_state() - Set up a new test state + * + * This must be called before using the test state with ut_run_tests() + * + * @uts: Test state to init + */ +void ut_init_state(struct unit_test_state *uts); + +/** + * ut_uninit_state() - Free memory used by test state + * + * This must be called before after the test state with ut_run_tests(). To later + * reuse the test state to run more tests, call test_state_init() first + * + * @uts: Test state to uninit + */ +void ut_uninit_state(struct unit_test_state *uts); + /** * ut_run_tests() - Run a set of tests * * This runs the test, handling any preparation and clean-up needed. It prints * the name of each test before running it. * + * @uts: Unit-test state, which must be ready for use, i.e. ut_init_state() + * has been called. The caller is responsible for calling + * ut_uninit_state() after this function returns * @category: Category of these tests. This is a string printed at the start to * announce the the number of tests * @prefix: String prefix for the tests. Any tests that have this prefix will be @@ -503,8 +525,9 @@ void ut_set_state(struct unit_test_state *uts); * Pass NULL to disable this * Return: 0 if all tests passed, -1 if any failed */ -int ut_run_list(const char *name, const char *prefix, struct unit_test *tests, - int count, const char *select_name, int runs_per_test, - bool force_run, const char *test_insert); +int ut_run_list(struct unit_test_state *uts, const char *category, + const char *prefix, struct unit_test *tests, int count, + const char *select_name, int runs_per_test, bool force_run, + const char *test_insert);
#endif diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 195b7ea50ac..d25c2c37e7a 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -21,6 +21,7 @@ int cmd_ut_category(const char *name, const char *prefix, struct unit_test *tests, int n_ents, int argc, char *const argv[]) { + struct unit_test_state uts; const char *test_insert = NULL; int runs_per_text = 1; bool force_run = false; @@ -44,9 +45,11 @@ int cmd_ut_category(const char *name, const char *prefix, argc--; }
- ret = ut_run_list(name, prefix, tests, n_ents, + ut_init_state(&uts); + ret = ut_run_list(&uts, name, prefix, tests, n_ents, cmd_arg1(argc, argv), runs_per_text, force_run, test_insert); + ut_uninit_state(&uts);
return ret ? CMD_RET_FAILURE : 0; } diff --git a/test/test-main.c b/test/test-main.c index 871fc1f22b4..e12c5a95e45 100644 --- a/test/test-main.c +++ b/test/test-main.c @@ -673,15 +673,15 @@ static int ut_run_tests(struct unit_test_state *uts, const char *prefix, return uts->fail_count ? -EBADF : 0; }
-int ut_run_list(const char *category, const char *prefix, - struct unit_test *tests, int count, const char *select_name, - int runs_per_test, bool force_run, const char *test_insert) +int ut_run_list(struct unit_test_state *uts, const char *category, + const char *prefix, struct unit_test *tests, int count, + const char *select_name, int runs_per_test, bool force_run, + const char *test_insert) { - struct unit_test_state uts; + ; bool has_dm_tests = false; int ret;
- ut_init_state(&uts); if (!CONFIG_IS_ENABLED(OF_PLATDATA) && ut_list_has_dm_tests(tests, count, prefix, select_name)) { has_dm_tests = true; @@ -699,32 +699,31 @@ int ut_run_list(const char *category, const char *prefix, if (!select_name) printf("Running %d %s tests\n", count, category);
- uts.of_root = gd_of_root(); - uts.runs_per_test = runs_per_test; + uts->of_root = gd_of_root(); + uts->runs_per_test = runs_per_test; if (fdt_action() == FDTCHK_COPY && gd->fdt_blob) { - uts.fdt_size = fdt_totalsize(gd->fdt_blob); - uts.fdt_copy = os_malloc(uts.fdt_size); - if (!uts.fdt_copy) { + uts->fdt_size = fdt_totalsize(gd->fdt_blob); + uts->fdt_copy = os_malloc(uts->fdt_size); + if (!uts->fdt_copy) { printf("Out of memory for device tree copy\n"); return -ENOMEM; } - memcpy(uts.fdt_copy, gd->fdt_blob, uts.fdt_size); + memcpy(uts->fdt_copy, gd->fdt_blob, uts->fdt_size); } - uts.force_run = force_run; - ret = ut_run_tests(&uts, prefix, tests, count, select_name, + uts->force_run = force_run; + ret = ut_run_tests(uts, prefix, tests, count, select_name, test_insert);
/* Best efforts only...ignore errors */ if (has_dm_tests) - dm_test_restore(uts.of_root); + dm_test_restore(uts->of_root);
- if (uts.skip_count) - printf("Skipped: %d, ", uts.skip_count); + if (uts->skip_count) + printf("Skipped: %d, ", uts->skip_count); if (ret == -ENOENT) printf("Test '%s' not found\n", select_name); else - printf("Failures: %d\n", uts.fail_count); - ut_uninit_state(&uts); + printf("Failures: %d\n", uts->fail_count);
return ret; }
A limitation of most linker_list macros is that they cannot easily be used in data structures. This is because they include code inside their expressions.
Provide a way to support this, with new ll_start_decl() and ll_end_decl() macros.
include/linker_lists.h | 51 ++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 51 insertions(+)
diff --git a/include/linker_lists.h b/include/linker_lists.h index f9a2ee0c762..c05b99c886f 100644 --- a/include/linker_lists.h +++ b/include/linker_lists.h @@ -186,6 +186,57 @@ _ll_result; \ })
+/** + * Declares a symbol that points to the start/end of the list. The name of the + * (new) symbol is arbitrary and can be anything that is not already declared in + * the file where it appears. It is provided in _sym and can then be used (later + * in the same file) within a data structure. + * + * The _type and _list arguments must match those passed to ll_entry_start/end() + * + * Example: + * + * :: + * Here we want to record the start of each sub-command in a list. We have two + * sub-commands, 'bob' and 'mary'. + * + * In bob.c: + * ll_entry_declare(struct my_sub_cmd, bob_cmd, cmd_sub) = {...} + * + * In mary.c: + * ll_entry_declare(struct my_sub_cmd, mary_cmd, cmd_sub) = {...} + * + * In a different file where we want a list the start of all sub-commands. + * It is not possible to use ll_entry_start() in a data structure, due to its + * use of code inside expressions - ({ ... }) - so this fails to compile: + * + * In sub_cmds.c: + * struct cmd_sub *my_list[] = { + * ll_entry_start(cmd_sub, bob), + * ll_entry_start(cmd_sub, bob), + * } + * + * Instead, we can use: + * + * ll_start_decl(bob, struct my_sub_cmd, cmd_sub); + * ll_start_decl(mary, struct my_sub_cmd, cmd_sub); + * + * struct cmd_sub *my_list[] = { + * bob, + * mary, + * } + * + * So 'bob' is declared as symbol, a struct my_list * which points to the + * start of the bob sub-commands. It is then used in my_list[] + */ +#define ll_start_decl(_sym, _type, _list) \ + static _type _sym[0] __aligned(CONFIG_LINKER_LIST_ALIGN) \ + __maybe_unused __section("__u_boot_list_2_" #_list "_1") + +#define ll_end_decl(_sym, _type, _list) \ + static _type _sym[0] __aligned(CONFIG_LINKER_LIST_ALIGN) \ + __maybe_unused __section("__u_boot_list_2_" #_list "_3") + /** * ll_entry_get() - Retrieve entry from linker-generated array by name * @_type: Data type of the entry
A few messages lack a newline so the test output shows the next test-name on the same line. For example:
Beware: this test sets local variable dollar_bar and dollar_quux and they cannot be unset!Test: hush_test_env_dollar: dollar.c
This is confusing, so fix it.
test/hush/dollar.c | 7 ++++--- test/hush/loop.c | 4 ++-- 2 files changed, 6 insertions(+), 5 deletions(-)
diff --git a/test/hush/dollar.c b/test/hush/dollar.c index 077dcd62c0e..820110799a2 100644 --- a/test/hush/dollar.c +++ b/test/hush/dollar.c @@ -108,7 +108,7 @@ static int hush_test_simple_dollar(struct unit_test_state *uts) /* Reset local variable. */ ut_assertok(run_command("dollar_foo=", 0)); } else if (gd->flags & GD_FLG_HUSH_OLD_PARSER) { - puts("Beware: this test set local variable dollar_foo and it cannot be unset!"); + puts("Beware: this test set local variable dollar_foo and it cannot be unset!\n"); }
return 0; @@ -140,7 +140,7 @@ static int hush_test_env_dollar(struct unit_test_state *uts) /* Reset local variable. */ ut_assertok(run_command("env_foo=", 0)); } else if (gd->flags & GD_FLG_HUSH_OLD_PARSER) { - puts("Beware: this test set local variable env_foo and it cannot be unset!"); + puts("Beware: this test set local variable env_foo and it cannot be unset!\n"); }
return 0; @@ -206,7 +206,8 @@ static int hush_test_command_dollar(struct unit_test_state *uts) ut_assertok(run_command("dollar_bar=", 0)); ut_assertok(run_command("dollar_quux=", 0)); } else if (gd->flags & GD_FLG_HUSH_OLD_PARSER) { - puts("Beware: this test sets local variable dollar_bar and dollar_quux and they cannot be unset!"); + puts("Beware: this test sets local variable dollar_bar and " + "dollar_quux and they cannot be unset!\n"); }
return 0; diff --git a/test/hush/loop.c b/test/hush/loop.c index a9b6a8edf24..7154b9bc0ae 100644 --- a/test/hush/loop.c +++ b/test/hush/loop.c @@ -25,7 +25,7 @@ static int hush_test_for(struct unit_test_state *uts) /* Reset local variable. */ ut_assertok(run_command("loop_i=", 0)); } else if (gd->flags & GD_FLG_HUSH_OLD_PARSER) { - puts("Beware: this test set local variable loop_i and it cannot be unset!"); + puts("Beware: this test set local variable loop_i and it cannot be unset!\n"); }
return 0; @@ -56,7 +56,7 @@ static int hush_test_while(struct unit_test_state *uts) /* Reset local variable. */ ut_assertok(run_command("loop_foo=", 0)); } else if (gd->flags & GD_FLG_HUSH_OLD_PARSER) { - puts("Beware: this test set local variable loop_foo and it cannot be unset!"); + puts("Beware: this test set local variable loop_foo and it cannot be unset!\n"); }
Some suites have a different name from that used in the linker list. That makes it hard to programmatically match the name printed when the suite runs to the linker-list name it has.
Update the names so they are the same.
include/test/cmd.h | 2 +- test/boot/upl.c | 3 +-- test/cmd/addrmap.c | 2 +- test/cmd/cmd_ut_cmd.c | 4 ++-- test/cmd/exit.c | 2 +- test/cmd/mem.c | 2 +- test/cmd/pci_mps.c | 2 +- test/cmd/setexpr.c | 2 +- test/dm/test-dm.c | 3 +-- test/env/cmd_ut_env.c | 3 +-- 10 files changed, 11 insertions(+), 14 deletions(-)
diff --git a/include/test/cmd.h b/include/test/cmd.h index c200570e423..3d1e3e3bddb 100644 --- a/include/test/cmd.h +++ b/include/test/cmd.h @@ -10,6 +10,6 @@ #include <test/test.h>
/* Declare a new command test */ -#define CMD_TEST(_name, _flags) UNIT_TEST(_name, _flags, cmd_test) +#define CMD_TEST(_name, _flags) UNIT_TEST(_name, _flags, cmd)
#endif /* __TEST_CMD_H__ */ diff --git a/test/boot/upl.c b/test/boot/upl.c index 99f02b7951b..ef65cf34055 100644 --- a/test/boot/upl.c +++ b/test/boot/upl.c @@ -432,6 +432,5 @@ int do_ut_upl(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) struct unit_test *tests = UNIT_TEST_SUITE_START(upl_test); const int n_ents = UNIT_TEST_SUITE_COUNT(upl_test);
- return cmd_ut_category("cmd_upl", "cmd_upl_", tests, n_ents, argc, - argv); + return cmd_ut_category("upl", "cmd_upl_", tests, n_ents, argc, argv); } diff --git a/test/cmd/addrmap.c b/test/cmd/addrmap.c index b34be895f5d..43897615aa9 100644 --- a/test/cmd/addrmap.c +++ b/test/cmd/addrmap.c @@ -30,6 +30,6 @@ int do_ut_addrmap(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) struct unit_test *tests = UNIT_TEST_SUITE_START(addrmap_test); const int n_ents = UNIT_TEST_SUITE_COUNT(addrmap_test);
- return cmd_ut_category("cmd_addrmap", "cmd_addrmap_", tests, n_ents, + return cmd_ut_category("addrmap", "cmd_addrmap_", tests, n_ents, argc, argv); } diff --git a/test/cmd/cmd_ut_cmd.c b/test/cmd/cmd_ut_cmd.c index e77fa1c7f01..ad192563c5a 100644 --- a/test/cmd/cmd_ut_cmd.c +++ b/test/cmd/cmd_ut_cmd.c @@ -13,8 +13,8 @@
int do_ut_cmd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(cmd_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(cmd_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(cmd); + const int n_ents = UNIT_TEST_SUITE_COUNT(cmd);
return cmd_ut_category("cmd", "cmd_test_", tests, n_ents, argc, argv); } diff --git a/test/cmd/exit.c b/test/cmd/exit.c index af58a57fca7..cf65c05e283 100644 --- a/test/cmd/exit.c +++ b/test/cmd/exit.c @@ -116,6 +116,6 @@ int do_ut_exit(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) struct unit_test *tests = UNIT_TEST_SUITE_START(exit_test); const int n_ents = UNIT_TEST_SUITE_COUNT(exit_test);
- return cmd_ut_category("cmd_exit", "exit_test_", tests, n_ents, + return cmd_ut_category("exit", "exit_test_", tests, n_ents, argc, argv); } diff --git a/test/cmd/mem.c b/test/cmd/mem.c index f1bbab6055b..d6f2544a4e9 100644 --- a/test/cmd/mem.c +++ b/test/cmd/mem.c @@ -14,6 +14,6 @@ int do_ut_mem(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) struct unit_test *tests = UNIT_TEST_SUITE_START(mem_test); const int n_ents = UNIT_TEST_SUITE_COUNT(mem_test);
- return cmd_ut_category("cmd_mem", "mem_test_", tests, n_ents, argc, + return cmd_ut_category("mem", "mem_test_", tests, n_ents, argc, argv); } diff --git a/test/cmd/pci_mps.c b/test/cmd/pci_mps.c index a265105600c..0c57d15d636 100644 --- a/test/cmd/pci_mps.c +++ b/test/cmd/pci_mps.c @@ -35,6 +35,6 @@ int do_ut_pci_mps(struct cmd_tbl *cmdtp, int flag, int argc, struct unit_test *tests = UNIT_TEST_SUITE_START(pci_mps_test); const int n = UNIT_TEST_SUITE_COUNT(pci_mps_test);
- return cmd_ut_category("cmd_pci_mps", "pci_mps_test_", tests, n, + return cmd_ut_category("pci_mps", "pci_mps_test_", tests, n, argc, argv); } diff --git a/test/cmd/setexpr.c b/test/cmd/setexpr.c index 21a3268bd81..9b3277f2ad9 100644 --- a/test/cmd/setexpr.c +++ b/test/cmd/setexpr.c @@ -485,6 +485,6 @@ int do_ut_setexpr(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) struct unit_test *tests = UNIT_TEST_SUITE_START(setexpr_test); const int n_ents = UNIT_TEST_SUITE_COUNT(setexpr_test);
- return cmd_ut_category("cmd_setexpr", "setexpr_test_", tests, n_ents, + return cmd_ut_category("setexpr", "setexpr_test_", tests, n_ents, argc, argv); } diff --git a/test/dm/test-dm.c b/test/dm/test-dm.c index 4bc2c45db61..7cfbefe02da 100644 --- a/test/dm/test-dm.c +++ b/test/dm/test-dm.c @@ -11,6 +11,5 @@ int do_ut_dm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) struct unit_test *tests = UNIT_TEST_SUITE_START(dm_test); const int n_ents = UNIT_TEST_SUITE_COUNT(dm_test);
- return cmd_ut_category("driver model", "dm_test_", tests, n_ents, argc, - argv); + return cmd_ut_category("dm", "dm_test_", tests, n_ents, argc, argv); } diff --git a/test/env/cmd_ut_env.c b/test/env/cmd_ut_env.c index 9f16a978f2a..494b5db395b 100644 --- a/test/env/cmd_ut_env.c +++ b/test/env/cmd_ut_env.c @@ -80,6 +80,5 @@ int do_ut_env(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) struct unit_test *tests = UNIT_TEST_SUITE_START(env_test); const int n_ents = UNIT_TEST_SUITE_COUNT(env_test);
- return cmd_ut_category("environment", "env_test_", - tests, n_ents, argc, argv); + return cmd_ut_category("env", "env_test_", tests, n_ents, argc, argv); }
It is helpful to see a list of available suites. At present this is handled by the longhelp for the 'ut' command, but this is not in a format which can be easily parsed by python tests.
Add a -s option to show this. At present it is not possible to show the number of tests in each suite, but future work will address this. For now, show a ?
test/cmd_ut.c | 14 +++++++++++++- 1 file changed, 13 insertions(+), 1 deletion(-)
diff --git a/test/cmd_ut.c b/test/cmd_ut.c index d25c2c37e7a..b6ceeb94a30 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -151,9 +151,21 @@ static int do_ut_all(struct cmd_tbl *cmdtp, int flag, int argc, static int do_ut_info(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { + const char *flags; + printf("Test suites: %d\n", (int)ARRAY_SIZE(cmd_ut_sub)); printf("Total tests: %d\n", (int)UNIT_TEST_ALL_COUNT());
+ flags = cmd_arg1(argc, argv); + if (flags && !strcmp("-s", flags)) { + int i; + + puts("\nTests Suite\n"); + puts("----- -----\n"); + for (i = 1; i < ARRAY_SIZE(cmd_ut_sub); i++) + printf("%5s %s\n", "?", cmd_ut_sub[i].name); + } + return 0; }
@@ -184,7 +196,7 @@ U_BOOT_LONGHELP(ut, "\n" "\nOptions for <suite>:" "\nall - execute all enabled tests" - "\ninfo - show info about tests" + "\ninfo [-s] - show info about tests [and suites]" #ifdef CONFIG_CMD_ADDRMAP "\naddrmap - very basic test of addrmap command" #endif
Add a Python test which runs 'ut all' and then checks that the expected suites are present and all tests in each suite are run.
This can help to check that nothing is missing.
Update 'ut info' to ignore the 'all' suite when counting the number of suites, since that is really just a combination of all the other suites.
Adjust the message for skipped tests so that appears even if no particular test was selected. This helps the new 'test_suite' test see what is going on.
test/cmd_ut.c | 2 +- test/py/tests/test_suite.py | 175 ++++++++++++++++++++++++++++++++++++ test/test-main.c | 6 +- 3 files changed, 178 insertions(+), 5 deletions(-) create mode 100644 test/py/tests/test_suite.py
diff --git a/test/cmd_ut.c b/test/cmd_ut.c index b6ceeb94a30..b81708b3e57 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -153,7 +153,7 @@ static int do_ut_info(struct cmd_tbl *cmdtp, int flag, int argc, { const char *flags;
- printf("Test suites: %d\n", (int)ARRAY_SIZE(cmd_ut_sub)); + printf("Test suites: %d\n", (int)ARRAY_SIZE(cmd_ut_sub) - 1); printf("Total tests: %d\n", (int)UNIT_TEST_ALL_COUNT());
flags = cmd_arg1(argc, argv); diff --git a/test/py/tests/test_suite.py b/test/py/tests/test_suite.py new file mode 100644 index 00000000000..ed636bbde74 --- /dev/null +++ b/test/py/tests/test_suite.py @@ -0,0 +1,175 @@ +# SPDX-License-Identifier: GPL-2.0 +# Copyright 2024 Google LLC + +import pytest +import re + +# List of test suites we expect to find with 'ut info' and 'ut all' +EXPECTED_SUITES = [ + 'addrmap', 'bdinfo', 'bloblist', 'bootm', 'bootstd', + 'cmd', 'common', 'dm', 'env', 'exit', + 'fdt', 'font', 'hush', 'info', 'lib', + 'loadm', 'log', 'mbr', 'measurement', 'mem', + 'overlay', 'pci_mps', 'setexpr', 'upl', + ] + + +# Set this to True to aid debugging of tests +DEBUG_ME = True + + +def collect_info(cons, output): + """Run all unit tests and check the resulting output + + Args: + cons: U-Boot console object + output: Output from running 'ut all' + + Returns: + tuple: + set: suite names that were found in output + set: test names that were found in output + dict: test count for each suite: + key: suite name + value: number of tests for the suite found in output + set: missing suites (compared to EXPECTED_SUITES) + set: extra suites (compared to EXPECTED_SUITES) + """ + suites = set() + tests = set() + cur_suite = None + test_count = None + exp_test_count = {} + + # Collect suites{} + for line in output.splitlines(): + m = re.search('----Running ([^ ]*) tests----', line) + if m: + if DEBUG_ME and cur_suite and cur_suite != 'info': + cons.log.info(f'suite: {cur_suite} expected {exp_test_count[cur_suite]} found {test_count}') + + cur_suite = m.group(1) + if DEBUG_ME: + cons.log.info(f'cur_suite: {cur_suite}') + suites.add(cur_suite) + + test_count = 0 + m = re.match(rf'Running (\d+) {cur_suite} tests', line) + if m: + exp_test_count[cur_suite] = int(m.group(1)) + m = re.search(r'Test: (\w*): ([-a-z0-9_]*.c)?( .*)?', line) + if m: + test_name = m.group(1) + msg = m.group(3) + if DEBUG_ME: + cons.log.info(f"test_name {test_name} msg '{msg}'") + if msg == ' (flat tree)' and test_name not in tests: + tests.add(test_name) + test_count += 1 + if not msg or 'skipped as it is manual' in msg: + tests.add(test_name) + test_count += 1 + if DEBUG_ME: + cons.log.info(f'suite: {cur_suite} expected {exp_test_count[cur_suite]} found {test_count}') + cons.log.info(f"Tests: {' '.join(sorted(list(tests)))}") + + # Figure out what is missing, or extra + missing = set() + extra = set(suites) + for suite in EXPECTED_SUITES: + if suite in extra: + extra.remove(suite) + else: + missing.add(suite) + + return suites, tests, exp_test_count, missing, extra + + +def process_ut_info(cons, output): + """Process the output of the 'ut info' command + + Args: + cons: U-Boot console object + output: Output from running 'ut all' + + Returns: + tuple: + int: Number of suites reported + int: Number of tests reported + dict: test count for each suite: + key: suite name + value: number of tests reported for the suite + + """ + suite_count = None + total_test_count = None + test_count = {} + for line in output.splitlines(): + if DEBUG_ME: + cons.log.info(f'line: {line}') + m = re.match(r'Test suites: (.*)', line) + if m: + suite_count = int(m.group(1)) + m = re.match(r'Total tests: (.*)', line) + if m: + total_test_count = int(m.group(1)) + m = re.match(r' *([0-9?]*) (\w*)', line) + if m: + test_count[m.group(2)] = m.group(1) + return suite_count, total_test_count, test_count + + +@pytest.mark.buildconfigspec('sandbox') +@pytest.mark.notbuildconfigspec('sandbox_spl') +@pytest.mark.notbuildconfigspec('sandbox64') +def test_suite(u_boot_console): + """Perform various checks on the unit tests, including: + + - The number of suites matches that reported by the 'ut info' + - Where available, the number of tests is each suite matches that + reported by 'ut info -s' + - The total number of tests adds up to the total that are actually run + with 'ut all' + - All suites are run with 'ut all' + - The expected set of suites is run (the list is hard-coded in this test) + + """ + cons = u_boot_console + with cons.log.section('Run all unit tests'): + # ut hush hush_test_simple_dollar prints "Unknown command" on purpose. + with u_boot_console.disable_check('unknown_command'): + output = cons.run_command('ut all') + + # Process the output from the run + with cons.log.section('Check output'): + suites, all_tests, exp_test_count, missing, extra = collect_info(cons, + output) + + # Make sure we got a test count for each suite (ignore 'info' since it isn't + # a real suite + assert suites - exp_test_count.keys() == {'info'} + + # Run 'ut info' and compare with the log results + with cons.log.section('Check suite test-counts'): + output = cons.run_command('ut info -s') + + suite_count, total_test_count, test_count = process_ut_info(cons, + output) + + if missing or extra: + cons.log.info(f"suites: {' '.join(sorted(list(suites)))}") + cons.log.error(f'missing: {sorted(list(missing))}') + cons.log.error(f'extra: {sorted(list(extra))}') + + assert not missing + assert not extra + + cons.log.info(str(exp_test_count)) + for suite in EXPECTED_SUITES: + # 'info' is not really a suite, just a subcommand of 'ut' + if suite != 'info': + assert test_count[suite] in ['?', str(exp_test_count[suite])],\ + f'suite {suite} expected {exp_test_count[suite]}' + + assert suite_count == len(EXPECTED_SUITES) + assert total_test_count == len(all_tests) diff --git a/test/test-main.c b/test/test-main.c index e12c5a95e45..391d4e7bb0e 100644 --- a/test/test-main.c +++ b/test/test-main.c @@ -636,10 +636,8 @@ static int ut_run_tests(struct unit_test_state *uts, const char *prefix, return -EBADF; } if (!uts->force_run) { - if (select_name) { - printf("Test '%s' skipped as it is manual (use -f to run it)\n", - test_name); - } + printf("Test: %s: skipped as it is manual (use -f to run it)\n", + test_name); continue; } }
Most test suites have a _test suffix. This is not necessary as there is also a ut_ prefix.
Drop the suffix so that (with future work) the suite name can be used as the linker-list name.
Remove the suffix from the pytest regex as well, moving it to the top of the file, as it is a constant.
include/dm/test.h | 2 +- include/test/common.h | 2 +- include/test/env.h | 2 +- include/test/hush.h | 2 +- include/test/lib.h | 2 +- include/test/log.h | 4 ++-- include/test/optee.h | 2 +- include/test/overlay.h | 2 +- test/boot/bootm.c | 6 +++--- test/boot/bootstd_common.c | 8 ++++---- test/boot/bootstd_common.h | 3 +-- test/boot/measurement.c | 6 +++--- test/boot/upl.c | 6 +++--- test/cmd/addrmap.c | 6 +++--- test/cmd/bdinfo.c | 6 +++--- test/cmd/exit.c | 6 +++--- test/cmd/fdt.c | 6 +++--- test/cmd/font.c | 6 +++--- test/cmd/loadm.c | 6 +++--- test/cmd/mbr.c | 6 +++--- test/cmd/mem.c | 4 ++-- test/cmd/mem_copy.c | 2 +- test/cmd/mem_search.c | 2 +- test/cmd/pci_mps.c | 6 +++--- test/cmd/seama.c | 6 +++--- test/cmd/setexpr.c | 6 +++--- test/common/bloblist.c | 6 +++--- test/common/cmd_ut_common.c | 4 ++-- test/dm/test-dm.c | 4 ++-- test/env/cmd_ut_env.c | 4 ++-- test/hush/cmd_ut_hush.c | 4 ++-- test/lib/cmd_ut_lib.c | 4 ++-- test/log/log_ut.c | 4 ++-- test/optee/cmd_ut_optee.c | 4 ++-- test/overlay/cmd_ut_overlay.c | 4 ++-- test/py/conftest.py | 7 +++++-- 36 files changed, 81 insertions(+), 79 deletions(-)
diff --git a/include/dm/test.h b/include/dm/test.h index 3cbf2c740d4..4aabb4603b9 100644 --- a/include/dm/test.h +++ b/include/dm/test.h @@ -143,7 +143,7 @@ extern struct unit_test_state global_dm_test_state;
/* Declare a new driver model test */ #define DM_TEST(_name, _flags) \ - UNIT_TEST(_name, UTF_DM | UTF_CONSOLE | (_flags), dm_test) + UNIT_TEST(_name, UTF_DM | UTF_CONSOLE | (_flags), dm)
/* * struct sandbox_sdl_plat - Platform data for the SDL video driver diff --git a/include/test/common.h b/include/test/common.h index 81260d06ad6..d5a65d5b50b 100644 --- a/include/test/common.h +++ b/include/test/common.h @@ -10,6 +10,6 @@ #include <test/test.h>
/* Declare a new common function test */ -#define COMMON_TEST(_name, _flags) UNIT_TEST(_name, _flags, common_test) +#define COMMON_TEST(_name, _flags) UNIT_TEST(_name, _flags, common)
#endif /* __TEST_COMMON_H__ */ diff --git a/include/test/env.h b/include/test/env.h index f45e33d71a4..6a63cc972e9 100644 --- a/include/test/env.h +++ b/include/test/env.h @@ -10,6 +10,6 @@ #include <test/test.h>
/* Declare a new environment test */ -#define ENV_TEST(_name, _flags) UNIT_TEST(_name, _flags, env_test) +#define ENV_TEST(_name, _flags) UNIT_TEST(_name, _flags, env)
#endif /* __TEST_ENV_H__ */ diff --git a/include/test/hush.h b/include/test/hush.h index cca66544a06..e57bf13ea61 100644 --- a/include/test/hush.h +++ b/include/test/hush.h @@ -10,6 +10,6 @@ #include <test/test.h>
/* Declare a new environment test */ -#define HUSH_TEST(_name, _flags) UNIT_TEST(_name, _flags, hush_test) +#define HUSH_TEST(_name, _flags) UNIT_TEST(_name, _flags, hush)
#endif /* __TEST_HUSH_H__ */ diff --git a/include/test/lib.h b/include/test/lib.h index 04b6241e54a..b19eb863a33 100644 --- a/include/test/lib.h +++ b/include/test/lib.h @@ -9,6 +9,6 @@ #include <test/test.h>
/* Declare a new library function test */ -#define LIB_TEST(_name, _flags) UNIT_TEST(_name, _flags, lib_test) +#define LIB_TEST(_name, _flags) UNIT_TEST(_name, _flags, lib)
#endif /* __TEST_LIB_H__ */ diff --git a/include/test/log.h b/include/test/log.h index e3362b85e99..0921c0c1cbc 100644 --- a/include/test/log.h +++ b/include/test/log.h @@ -13,8 +13,8 @@ #define LOGF_TEST (BIT(LOGF_FUNC) | BIT(LOGF_MSG))
/* Declare a new logging test */ -#define LOG_TEST(_name) UNIT_TEST(_name, UTF_CONSOLE, log_test) +#define LOG_TEST(_name) UNIT_TEST(_name, UTF_CONSOLE, log) #define LOG_TEST_FLAGS(_name, _flags) \ - UNIT_TEST(_name, _flags | UTF_CONSOLE, log_test) + UNIT_TEST(_name, _flags | UTF_CONSOLE, log)
#endif /* __TEST_LOG_H__ */ diff --git a/include/test/optee.h b/include/test/optee.h index a8c6e6395f5..f4255b39ee3 100644 --- a/include/test/optee.h +++ b/include/test/optee.h @@ -9,6 +9,6 @@ #include <test/test.h>
/* Declare a new environment test */ -#define OPTEE_TEST(_name, _flags) UNIT_TEST(_name, _flags, optee_test) +#define OPTEE_TEST(_name, _flags) UNIT_TEST(_name, _flags, optee)
#endif /* __TEST_OPTEE_H__ */ diff --git a/include/test/overlay.h b/include/test/overlay.h index c13f4d66e09..5dc98399ce7 100644 --- a/include/test/overlay.h +++ b/include/test/overlay.h @@ -10,6 +10,6 @@ #include <test/test.h>
/* Declare a new environment test */ -#define OVERLAY_TEST(_name, _flags) UNIT_TEST(_name, _flags, overlay_test) +#define OVERLAY_TEST(_name, _flags) UNIT_TEST(_name, _flags, overlay)
#endif /* __TEST_OVERLAY_H__ */ diff --git a/test/boot/bootm.c b/test/boot/bootm.c index 0dd8bc2979f..c8e32023acb 100644 --- a/test/boot/bootm.c +++ b/test/boot/bootm.c @@ -13,7 +13,7 @@
DECLARE_GLOBAL_DATA_PTR;
-#define BOOTM_TEST(_name, _flags) UNIT_TEST(_name, _flags, bootm_test) +#define BOOTM_TEST(_name, _flags) UNIT_TEST(_name, _flags, bootm)
enum { BUF_SIZE = 1024, @@ -259,8 +259,8 @@ BOOTM_TEST(bootm_test_subst_both, 0);
int do_ut_bootm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(bootm_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(bootm_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(bootm); + const int n_ents = UNIT_TEST_SUITE_COUNT(bootm);
return cmd_ut_category("bootm", "bootm_test_", tests, n_ents, argc, argv); diff --git a/test/boot/bootstd_common.c b/test/boot/bootstd_common.c index ff8ed2303b3..6bd9bb65a40 100644 --- a/test/boot/bootstd_common.c +++ b/test/boot/bootstd_common.c @@ -96,8 +96,8 @@ void bootstd_reset_usb(void)
int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(bootstd_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(bootstd_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(bootstd); + const int n_ents = UNIT_TEST_SUITE_COUNT(bootstd); int ret;
ret = bootstd_setup_for_tests(); @@ -106,6 +106,6 @@ int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) return CMD_RET_FAILURE; }
- return cmd_ut_category("bootstd", "bootstd_test_", - tests, n_ents, argc, argv); + return cmd_ut_category("bootstd", "bootstd_", tests, n_ents, + argc, argv); } diff --git a/test/boot/bootstd_common.h b/test/boot/bootstd_common.h index e29036c897c..ea3ecd1166c 100644 --- a/test/boot/bootstd_common.h +++ b/test/boot/bootstd_common.h @@ -12,8 +12,7 @@ #include <version_string.h>
/* Declare a new bootdev test */ -#define BOOTSTD_TEST(_name, _flags) \ - UNIT_TEST(_name, _flags, bootstd_test) +#define BOOTSTD_TEST(_name, _flags) UNIT_TEST(_name, _flags, bootstd)
#define NVDATA_START_BLK ((0x400 + 0x400) / MMC_MAX_BLOCK_LEN) #define VERSION_START_BLK ((0x400 + 0x800) / MMC_MAX_BLOCK_LEN) diff --git a/test/boot/measurement.c b/test/boot/measurement.c index 29be495412d..018e8af45f0 100644 --- a/test/boot/measurement.c +++ b/test/boot/measurement.c @@ -14,7 +14,7 @@ #include <asm/io.h>
#define MEASUREMENT_TEST(_name, _flags) \ - UNIT_TEST(_name, _flags, measurement_test) + UNIT_TEST(_name, _flags, measurement)
static int measure(struct unit_test_state *uts) { @@ -57,8 +57,8 @@ MEASUREMENT_TEST(measure, 0); int do_ut_measurement(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(measurement_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(measurement_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(measurement); + const int n_ents = UNIT_TEST_SUITE_COUNT(measurement);
return cmd_ut_category("measurement", "measurement_test_", tests, n_ents, argc, argv); diff --git a/test/boot/upl.c b/test/boot/upl.c index ef65cf34055..2c9b8bc8bc0 100644 --- a/test/boot/upl.c +++ b/test/boot/upl.c @@ -16,7 +16,7 @@ #include "bootstd_common.h"
/* Declare a new upl test */ -#define UPL_TEST(_name, _flags) UNIT_TEST(_name, _flags, upl_test) +#define UPL_TEST(_name, _flags) UNIT_TEST(_name, _flags, upl)
static int add_region(struct unit_test_state *uts, struct alist *lst, ulong base, ulong size) @@ -429,8 +429,8 @@ UPL_TEST(upl_test_info_norun, UTF_CONSOLE | UTF_MANUAL);
int do_ut_upl(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(upl_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(upl_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(upl); + const int n_ents = UNIT_TEST_SUITE_COUNT(upl);
return cmd_ut_category("upl", "cmd_upl_", tests, n_ents, argc, argv); } diff --git a/test/cmd/addrmap.c b/test/cmd/addrmap.c index 43897615aa9..fd0117102e2 100644 --- a/test/cmd/addrmap.c +++ b/test/cmd/addrmap.c @@ -10,7 +10,7 @@ #include <test/ut.h>
/* Declare a new addrmap test */ -#define ADDRMAP_TEST(_name, _flags) UNIT_TEST(_name, _flags, addrmap_test) +#define ADDRMAP_TEST(_name, _flags) UNIT_TEST(_name, _flags, addrmap)
/* Test 'addrmap' command output */ static int addrmap_test_basic(struct unit_test_state *uts) @@ -27,8 +27,8 @@ ADDRMAP_TEST(addrmap_test_basic, UTF_CONSOLE);
int do_ut_addrmap(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(addrmap_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(addrmap_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(addrmap); + const int n_ents = UNIT_TEST_SUITE_COUNT(addrmap);
return cmd_ut_category("addrmap", "cmd_addrmap_", tests, n_ents, argc, argv); diff --git a/test/cmd/bdinfo.c b/test/cmd/bdinfo.c index bb419ab2394..46482b1f56b 100644 --- a/test/cmd/bdinfo.c +++ b/test/cmd/bdinfo.c @@ -26,7 +26,7 @@ DECLARE_GLOBAL_DATA_PTR;
/* Declare a new bdinfo test */ -#define BDINFO_TEST(_name, _flags) UNIT_TEST(_name, _flags, bdinfo_test) +#define BDINFO_TEST(_name, _flags) UNIT_TEST(_name, _flags, bdinfo)
static int test_num_l(struct unit_test_state *uts, const char *name, ulong value) @@ -285,8 +285,8 @@ BDINFO_TEST(bdinfo_test_eth, UTF_CONSOLE);
int do_ut_bdinfo(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(bdinfo_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(bdinfo_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(bdinfo); + const int n_ents = UNIT_TEST_SUITE_COUNT(bdinfo);
return cmd_ut_category("bdinfo", "bdinfo_test_", tests, n_ents, argc, argv); } diff --git a/test/cmd/exit.c b/test/cmd/exit.c index cf65c05e283..d1eacdc36c2 100644 --- a/test/cmd/exit.c +++ b/test/cmd/exit.c @@ -14,7 +14,7 @@ DECLARE_GLOBAL_DATA_PTR;
/* Declare a new exit test */ -#define EXIT_TEST(_name, _flags) UNIT_TEST(_name, _flags, exit_test) +#define EXIT_TEST(_name, _flags) UNIT_TEST(_name, _flags, exit)
/* Test 'exit addr' getting/setting address */ static int cmd_exit_test(struct unit_test_state *uts) @@ -113,8 +113,8 @@ EXIT_TEST(cmd_exit_test, UTF_CONSOLE);
int do_ut_exit(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(exit_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(exit_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(exit); + const int n_ents = UNIT_TEST_SUITE_COUNT(exit);
return cmd_ut_category("exit", "exit_test_", tests, n_ents, argc, argv); diff --git a/test/cmd/fdt.c b/test/cmd/fdt.c index e64785101cd..74fd603bb02 100644 --- a/test/cmd/fdt.c +++ b/test/cmd/fdt.c @@ -23,7 +23,7 @@ DECLARE_GLOBAL_DATA_PTR; */
/* Declare a new fdt test */ -#define FDT_TEST(_name, _flags) UNIT_TEST(_name, _flags, fdt_test) +#define FDT_TEST(_name, _flags) UNIT_TEST(_name, _flags, fdt)
/** * make_test_fdt() - Create an FDT with just a root node @@ -1465,8 +1465,8 @@ FDT_TEST(fdt_test_apply, UTF_CONSOLE);
int do_ut_fdt(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(fdt_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(fdt_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(fdt); + const int n_ents = UNIT_TEST_SUITE_COUNT(fdt);
return cmd_ut_category("fdt", "fdt_test_", tests, n_ents, argc, argv); } diff --git a/test/cmd/font.c b/test/cmd/font.c index 3335dd65bea..d860efe8ce5 100644 --- a/test/cmd/font.c +++ b/test/cmd/font.c @@ -12,7 +12,7 @@ #include <test/ut.h>
/* Declare a new fdt test */ -#define FONT_TEST(_name, _flags) UNIT_TEST(_name, _flags, font_test) +#define FONT_TEST(_name, _flags) UNIT_TEST(_name, _flags, font)
/* Test 'fdt addr' resizing an fdt */ static int font_test_base(struct unit_test_state *uts) @@ -88,8 +88,8 @@ FONT_TEST(font_test_base, UTF_SCAN_PDATA | UTF_SCAN_FDT | UTF_CONSOLE |
int do_ut_font(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(font_Test); - const int n_ents = UNIT_TEST_SUITE_COUNT(font_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(font); + const int n_ents = UNIT_TEST_SUITE_COUNT(font);
return cmd_ut_category("font", "font_test_", tests, n_ents, argc, argv); } diff --git a/test/cmd/loadm.c b/test/cmd/loadm.c index dedb4f7683e..78bb12ce88c 100644 --- a/test/cmd/loadm.c +++ b/test/cmd/loadm.c @@ -19,7 +19,7 @@
#define BUF_SIZE 0x100
-#define LOADM_TEST(_name, _flags) UNIT_TEST(_name, _flags, loadm_test) +#define LOADM_TEST(_name, _flags) UNIT_TEST(_name, _flags, loadm)
static int loadm_test_params(struct unit_test_state *uts) { @@ -61,8 +61,8 @@ LOADM_TEST(loadm_test_load, UTF_CONSOLE);
int do_ut_loadm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(loadm_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(loadm_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(loadm); + const int n_ents = UNIT_TEST_SUITE_COUNT(loadm);
return cmd_ut_category("loadm", "loadm_test_", tests, n_ents, argc, argv); diff --git a/test/cmd/mbr.c b/test/cmd/mbr.c index d137378a3be..ad859921ce5 100644 --- a/test/cmd/mbr.c +++ b/test/cmd/mbr.c @@ -470,12 +470,12 @@ static int mbr_test_run(struct unit_test_state *uts) }
/* Declare mbr test */ -UNIT_TEST(mbr_test_run, UTF_CONSOLE, mbr_test); +UNIT_TEST(mbr_test_run, UTF_CONSOLE, mbr);
int do_ut_mbr(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(mbr_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(mbr_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(mbr); + const int n_ents = UNIT_TEST_SUITE_COUNT(mbr);
return cmd_ut_category("mbr", "mbr_test_", tests, n_ents, argc, argv); } diff --git a/test/cmd/mem.c b/test/cmd/mem.c index d6f2544a4e9..2b78e421a9c 100644 --- a/test/cmd/mem.c +++ b/test/cmd/mem.c @@ -11,8 +11,8 @@
int do_ut_mem(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(mem_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(mem_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(mem); + const int n_ents = UNIT_TEST_SUITE_COUNT(mem);
return cmd_ut_category("mem", "mem_test_", tests, n_ents, argc, argv); diff --git a/test/cmd/mem_copy.c b/test/cmd/mem_copy.c index 67eca328777..3e904fc4e4b 100644 --- a/test/cmd/mem_copy.c +++ b/test/cmd/mem_copy.c @@ -12,7 +12,7 @@ #define BUF_SIZE 256
/* Declare a new mem test */ -#define MEM_TEST(_name) UNIT_TEST(_name, 0, mem_test) +#define MEM_TEST(_name) UNIT_TEST(_name, 0, mem)
struct param { int d, s, count; diff --git a/test/cmd/mem_search.c b/test/cmd/mem_search.c index 3a031eed7ed..df8938bdb6c 100644 --- a/test/cmd/mem_search.c +++ b/test/cmd/mem_search.c @@ -14,7 +14,7 @@ #define BUF_SIZE 0x100
/* Declare a new mem test */ -#define MEM_TEST(_name, _flags) UNIT_TEST(_name, _flags, mem_test) +#define MEM_TEST(_name, _flags) UNIT_TEST(_name, _flags, mem)
/* Test 'ms' command with bytes */ static int mem_test_ms_b(struct unit_test_state *uts) diff --git a/test/cmd/pci_mps.c b/test/cmd/pci_mps.c index 0c57d15d636..2595ea103ff 100644 --- a/test/cmd/pci_mps.c +++ b/test/cmd/pci_mps.c @@ -11,7 +11,7 @@ #include <test/suites.h> #include <test/ut.h>
-#define PCI_MPS_TEST(_name, _flags) UNIT_TEST(_name, _flags, pci_mps_test) +#define PCI_MPS_TEST(_name, _flags) UNIT_TEST(_name, _flags, pci_mps)
/* Test "pci_mps" command in safe "s" mode */ static int test_pci_mps_safe(struct unit_test_state *uts) @@ -32,8 +32,8 @@ PCI_MPS_TEST(test_pci_mps_safe, UTF_CONSOLE); int do_ut_pci_mps(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(pci_mps_test); - const int n = UNIT_TEST_SUITE_COUNT(pci_mps_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(pci_mps); + const int n = UNIT_TEST_SUITE_COUNT(pci_mps);
return cmd_ut_category("pci_mps", "pci_mps_test_", tests, n, argc, argv); diff --git a/test/cmd/seama.c b/test/cmd/seama.c index 28d6b9ab517..39590d162ac 100644 --- a/test/cmd/seama.c +++ b/test/cmd/seama.c @@ -11,7 +11,7 @@ #include <test/test.h> #include <test/ut.h>
-#define SEAMA_TEST(_name, _flags) UNIT_TEST(_name, _flags, seama_test) +#define SEAMA_TEST(_name, _flags) UNIT_TEST(_name, _flags, seama)
static int seama_test_noargs(struct unit_test_state *uts) { @@ -59,8 +59,8 @@ SEAMA_TEST(seama_test_index, UTF_CONSOLE);
int do_ut_seama(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(seama_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(seama_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(seama); + const int n_ents = UNIT_TEST_SUITE_COUNT(seama);
return cmd_ut_category("seama", "seama_test_", tests, n_ents, argc, argv); diff --git a/test/cmd/setexpr.c b/test/cmd/setexpr.c index 9b3277f2ad9..49eac5890aa 100644 --- a/test/cmd/setexpr.c +++ b/test/cmd/setexpr.c @@ -15,7 +15,7 @@ #define BUF_SIZE 0x100
/* Declare a new setexpr test */ -#define SETEXPR_TEST(_name, _flags) UNIT_TEST(_name, _flags, setexpr_test) +#define SETEXPR_TEST(_name, _flags) UNIT_TEST(_name, _flags, setexpr)
/* Test 'setexpr' command with simply setting integers */ static int setexpr_test_int(struct unit_test_state *uts) @@ -482,8 +482,8 @@ SETEXPR_TEST(setexpr_test_fmt, UTF_CONSOLE);
int do_ut_setexpr(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(setexpr_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(setexpr_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(setexpr); + const int n_ents = UNIT_TEST_SUITE_COUNT(setexpr);
return cmd_ut_category("setexpr", "setexpr_test_", tests, n_ents, argc, argv); diff --git a/test/common/bloblist.c b/test/common/bloblist.c index 4bca62110a5..f5d98774862 100644 --- a/test/common/bloblist.c +++ b/test/common/bloblist.c @@ -12,7 +12,7 @@
/* Declare a new bloblist test */ #define BLOBLIST_TEST(_name, _flags) \ - UNIT_TEST(_name, _flags, bloblist_test) + UNIT_TEST(_name, _flags, bloblist)
enum { TEST_TAG = BLOBLISTT_U_BOOT_SPL_HANDOFF, @@ -606,8 +606,8 @@ BLOBLIST_TEST(bloblist_test_blob_maxsize, UFT_BLOBLIST); int do_ut_bloblist(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(bloblist_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(bloblist_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(bloblist); + const int n_ents = UNIT_TEST_SUITE_COUNT(bloblist);
return cmd_ut_category("bloblist", "bloblist_test_", tests, n_ents, argc, argv); diff --git a/test/common/cmd_ut_common.c b/test/common/cmd_ut_common.c index 2f03a58af47..0724c9361b8 100644 --- a/test/common/cmd_ut_common.c +++ b/test/common/cmd_ut_common.c @@ -13,8 +13,8 @@
int do_ut_common(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(common_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(common_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(common); + const int n_ents = UNIT_TEST_SUITE_COUNT(common);
return cmd_ut_category("common", "common_test_", tests, n_ents, argc, argv); diff --git a/test/dm/test-dm.c b/test/dm/test-dm.c index 7cfbefe02da..8f83110163a 100644 --- a/test/dm/test-dm.c +++ b/test/dm/test-dm.c @@ -8,8 +8,8 @@
int do_ut_dm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(dm_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(dm_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(dm); + const int n_ents = UNIT_TEST_SUITE_COUNT(dm);
return cmd_ut_category("dm", "dm_test_", tests, n_ents, argc, argv); } diff --git a/test/env/cmd_ut_env.c b/test/env/cmd_ut_env.c index 494b5db395b..332139bb803 100644 --- a/test/env/cmd_ut_env.c +++ b/test/env/cmd_ut_env.c @@ -77,8 +77,8 @@ ENV_TEST(env_test_env_cmd, UTF_CONSOLE);
int do_ut_env(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(env_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(env_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(env); + const int n_ents = UNIT_TEST_SUITE_COUNT(env);
return cmd_ut_category("env", "env_test_", tests, n_ents, argc, argv); } diff --git a/test/hush/cmd_ut_hush.c b/test/hush/cmd_ut_hush.c index abad44f3216..141203d766b 100644 --- a/test/hush/cmd_ut_hush.c +++ b/test/hush/cmd_ut_hush.c @@ -11,8 +11,8 @@
int do_ut_hush(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(hush_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(hush_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(hush); + const int n_ents = UNIT_TEST_SUITE_COUNT(hush);
return cmd_ut_category("hush", "hush_test_", tests, n_ents, argc, argv); diff --git a/test/lib/cmd_ut_lib.c b/test/lib/cmd_ut_lib.c index f98cb9b3c57..90a8c0728b7 100644 --- a/test/lib/cmd_ut_lib.c +++ b/test/lib/cmd_ut_lib.c @@ -12,8 +12,8 @@
int do_ut_lib(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(lib_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(lib_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(lib); + const int n_ents = UNIT_TEST_SUITE_COUNT(lib);
return cmd_ut_category("lib", "lib_test_", tests, n_ents, argc, argv); } diff --git a/test/log/log_ut.c b/test/log/log_ut.c index 6617ed8b152..2aa3afe286a 100644 --- a/test/log/log_ut.c +++ b/test/log/log_ut.c @@ -12,8 +12,8 @@
int do_ut_log(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(log_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(log_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(log); + const int n_ents = UNIT_TEST_SUITE_COUNT(log);
return cmd_ut_category("log", "log_test_", tests, n_ents, argc, argv); diff --git a/test/optee/cmd_ut_optee.c b/test/optee/cmd_ut_optee.c index c6f50e0995a..fc6674764f9 100644 --- a/test/optee/cmd_ut_optee.c +++ b/test/optee/cmd_ut_optee.c @@ -93,8 +93,8 @@ OPTEE_TEST(optee_fdt_protected_memory, 0);
int do_ut_optee(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(optee_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(optee_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(optee); + const int n_ents = UNIT_TEST_SUITE_COUNT(optee); struct unit_test_state *uts; void *fdt_optee = &__dtb_test_optee_optee_begin; void *fdt_no_optee = &__dtb_test_optee_no_optee_begin; diff --git a/test/overlay/cmd_ut_overlay.c b/test/overlay/cmd_ut_overlay.c index 256afd115d2..e0483afc31d 100644 --- a/test/overlay/cmd_ut_overlay.c +++ b/test/overlay/cmd_ut_overlay.c @@ -212,8 +212,8 @@ OVERLAY_TEST(fdt_overlay_stacked, 0);
int do_ut_overlay(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct unit_test *tests = UNIT_TEST_SUITE_START(overlay_test); - const int n_ents = UNIT_TEST_SUITE_COUNT(overlay_test); + struct unit_test *tests = UNIT_TEST_SUITE_START(overlay); + const int n_ents = UNIT_TEST_SUITE_COUNT(overlay); struct unit_test_state *uts; void *fdt_base = &__dtb_test_fdt_base_begin; void *fdt_overlay = &__dtbo_test_fdt_overlay_begin; diff --git a/test/py/conftest.py b/test/py/conftest.py index d4127dd0a93..3bd333bfd24 100644 --- a/test/py/conftest.py +++ b/test/py/conftest.py @@ -33,6 +33,9 @@ console = None
TEST_PY_DIR = os.path.dirname(os.path.abspath(__file__))
+# Regex for test-function symbols +RE_UT_TEST_LIST = re.compile(r'[^a-zA-Z0-9_]_u_boot_list_2_ut_(.*)_2_(.*)\s*$') + def mkdir_p(path): """Create a directory path.
@@ -341,7 +344,7 @@ def pytest_configure(config): import u_boot_console_exec_attach console = u_boot_console_exec_attach.ConsoleExecAttach(log, ubconfig)
-re_ut_test_list = re.compile(r'[^a-zA-Z0-9_]_u_boot_list_2_ut_(.*)_test_2_(.*)\s*$') + def generate_ut_subtest(metafunc, fixture_name, sym_path): """Provide parametrization for a ut_subtest fixture.
@@ -368,7 +371,7 @@ def generate_ut_subtest(metafunc, fixture_name, sym_path):
vals = [] for l in lines: - m = re_ut_test_list.search(l) + m = RE_UT_TEST_LIST.search(l) if not m: continue suite, name = m.groups()
The current cmd_ut_sub[] array was fine when there were only a few test suites. But is quite unwieldy now:
- it requires a separate do_ut_xxx for each suite, even though the code for most is almost identical - running more than one suite requires running multiple commands, and there is no record of which suites passed or failed - 'ut all' runs all suites but reports their results individually - we need lots of #ifdefs in the array, mirroring those in the makefile but maintained in a separate place
In fact the tests are all in the same linker list. The suites are grouped, so it is possible to access the information without a command.
Introduce a 'suite' array, which holds the cmd_ut_...() function to call, but can also support running a suite without that function. This means that the array of struct cmd_tbl is transformed into an array of 'struct suite'.
This will allow removal of many of the functions, particularly those without test-specific init.
include/test/suites.h | 4 + test/cmd_ut.c | 205 +++++++++++++++++++++++++++++++++--------- 2 files changed, 166 insertions(+), 43 deletions(-)
diff --git a/include/test/suites.h b/include/test/suites.h index e40ad634702..c1119e44999 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -10,6 +10,10 @@ struct cmd_tbl; struct unit_test;
+/* 'command' functions normally called do_xxx where xxx is the command name */ +typedef int (*ut_cmd_func)(struct cmd_tbl *cmd, int flags, int argc, + char *const argv[]); + /** * cmd_ut_category() - Run a category of unit tests * diff --git a/test/cmd_ut.c b/test/cmd_ut.c index b81708b3e57..10557be6d6d 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -11,6 +11,24 @@ #include <test/test.h> #include <test/ut.h>
+/** + * struct suite - A set of tests for a certain topic + * + * All tests end up in a single 'struct unit_test' linker-list array, in order + * of the suite they are in + * + * @name: Name of suite + * @start: First test in suite + * end: End test in suite (points to the first test in the next suite + * cmd: Command to use to run the suite + */ +struct suite { + const char *name; + struct unit_test *start; + struct unit_test *end; + ut_cmd_func cmd; +}; + static int do_ut_all(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]);
@@ -54,83 +72,147 @@ int cmd_ut_category(const char *name, const char *prefix, return ret ? CMD_RET_FAILURE : 0; }
-static struct cmd_tbl cmd_ut_sub[] = { - U_BOOT_CMD_MKENT(all, CONFIG_SYS_MAXARGS, 1, do_ut_all, "", ""), - U_BOOT_CMD_MKENT(info, 1, 1, do_ut_info, "", ""), +/* declare linker-list symbols for the start and end of a suite */ +#define SUITE_DECL(_name) \ + ll_start_decl(suite_start_ ## _name, struct unit_test, ut_ ## _name); \ + ll_end_decl(suite_end_ ## _name, struct unit_test, ut_ ## _name) + +/* declare a test suite which uses a subcommand to run */ +#define SUITE_CMD(_name, _cmd_func) { \ + #_name, \ + suite_start_ ## _name, \ + suite_end_ ## _name, \ + _cmd_func, \ + } + +/* declare a test suite which can be run directly without a subcommand */ +#define SUITE(_name) { \ + #_name, \ + suite_start_ ## _name, \ + suite_end_ ## _name, \ + NULL, \ + } + +SUITE_DECL(info); +SUITE_DECL(bdinfo); +SUITE_DECL(bootstd); +SUITE_DECL(cmd); +SUITE_DECL(common); +SUITE_DECL(dm); +SUITE_DECL(env); +SUITE_DECL(exit); +SUITE_DECL(fdt); +SUITE_DECL(font); +SUITE_DECL(optee); +SUITE_DECL(overlay); +SUITE_DECL(lib); +SUITE_DECL(log); +SUITE_DECL(mbr); +SUITE_DECL(mem); +SUITE_DECL(setexpr); +SUITE_DECL(measurement); +SUITE_DECL(bloblist); +SUITE_DECL(bootm); +SUITE_DECL(addrmap); +SUITE_DECL(hush); +SUITE_DECL(loadm); +SUITE_DECL(pci_mps); +SUITE_DECL(seama); +SUITE_DECL(upl); + +static struct suite suites[] = { + SUITE_CMD(info, do_ut_info), #ifdef CONFIG_CMD_BDI - U_BOOT_CMD_MKENT(bdinfo, CONFIG_SYS_MAXARGS, 1, do_ut_bdinfo, "", ""), + SUITE_CMD(bdinfo, do_ut_bdinfo), #endif #ifdef CONFIG_UT_BOOTSTD - U_BOOT_CMD_MKENT(bootstd, CONFIG_SYS_MAXARGS, 1, do_ut_bootstd, - "", ""), + SUITE_CMD(bootstd, do_ut_bootstd), #endif #ifdef CONFIG_CMDLINE - U_BOOT_CMD_MKENT(cmd, CONFIG_SYS_MAXARGS, 1, do_ut_cmd, "", ""), + SUITE_CMD(cmd, do_ut_cmd), #endif - U_BOOT_CMD_MKENT(common, CONFIG_SYS_MAXARGS, 1, do_ut_common, "", ""), + SUITE_CMD(common, do_ut_common), #if defined(CONFIG_UT_DM) - U_BOOT_CMD_MKENT(dm, CONFIG_SYS_MAXARGS, 1, do_ut_dm, "", ""), + SUITE_CMD(dm, do_ut_dm), #endif #if defined(CONFIG_UT_ENV) - U_BOOT_CMD_MKENT(env, CONFIG_SYS_MAXARGS, 1, do_ut_env, "", ""), + SUITE_CMD(env, do_ut_env), #endif - U_BOOT_CMD_MKENT(exit, CONFIG_SYS_MAXARGS, 1, do_ut_exit, "", ""), + SUITE_CMD(exit, do_ut_exit), #ifdef CONFIG_CMD_FDT - U_BOOT_CMD_MKENT(fdt, CONFIG_SYS_MAXARGS, 1, do_ut_fdt, "", ""), + SUITE_CMD(fdt, do_ut_fdt), #endif #ifdef CONFIG_CONSOLE_TRUETYPE - U_BOOT_CMD_MKENT(font, CONFIG_SYS_MAXARGS, 1, do_ut_font, "", ""), + SUITE_CMD(font, do_ut_font), #endif #ifdef CONFIG_UT_OPTEE - U_BOOT_CMD_MKENT(optee, CONFIG_SYS_MAXARGS, 1, do_ut_optee, "", ""), + SUITE_CMD(optee, do_ut_optee), #endif #ifdef CONFIG_UT_OVERLAY - U_BOOT_CMD_MKENT(overlay, CONFIG_SYS_MAXARGS, 1, do_ut_overlay, "", ""), + SUITE_CMD(overlay, do_ut_overlay), #endif #ifdef CONFIG_UT_LIB - U_BOOT_CMD_MKENT(lib, CONFIG_SYS_MAXARGS, 1, do_ut_lib, "", ""), + SUITE_CMD(lib, do_ut_lib), #endif #ifdef CONFIG_UT_LOG - U_BOOT_CMD_MKENT(log, CONFIG_SYS_MAXARGS, 1, do_ut_log, "", ""), + SUITE_CMD(log, do_ut_log), #endif #if defined(CONFIG_SANDBOX) && defined(CONFIG_CMD_MBR) && defined(CONFIG_CMD_MMC) \ && defined(CONFIG_MMC_SANDBOX) && defined(CONFIG_MMC_WRITE) - U_BOOT_CMD_MKENT(mbr, CONFIG_SYS_MAXARGS, 1, do_ut_mbr, "", ""), + SUITE_CMD(mbr, do_ut_mbr), #endif - U_BOOT_CMD_MKENT(mem, CONFIG_SYS_MAXARGS, 1, do_ut_mem, "", ""), + SUITE_CMD(mem, do_ut_mem), #if defined(CONFIG_SANDBOX) && defined(CONFIG_CMD_SETEXPR) - U_BOOT_CMD_MKENT(setexpr, CONFIG_SYS_MAXARGS, 1, do_ut_setexpr, "", - ""), + SUITE_CMD(setexpr, do_ut_setexpr), #endif #ifdef CONFIG_MEASURED_BOOT - U_BOOT_CMD_MKENT(measurement, CONFIG_SYS_MAXARGS, 1, do_ut_measurement, - "", ""), + SUITE_CMD(measurement, do_ut_measurement), #endif #ifdef CONFIG_SANDBOX - U_BOOT_CMD_MKENT(bloblist, CONFIG_SYS_MAXARGS, 1, do_ut_bloblist, - "", ""), - U_BOOT_CMD_MKENT(bootm, CONFIG_SYS_MAXARGS, 1, do_ut_bootm, "", ""), + SUITE_CMD(bloblist, do_ut_bloblist), + SUITE_CMD(bootm, do_ut_bootm), #endif #ifdef CONFIG_CMD_ADDRMAP - U_BOOT_CMD_MKENT(addrmap, CONFIG_SYS_MAXARGS, 1, do_ut_addrmap, "", ""), + SUITE_CMD(addrmap, do_ut_addrmap), #endif #if CONFIG_IS_ENABLED(HUSH_PARSER) - U_BOOT_CMD_MKENT(hush, CONFIG_SYS_MAXARGS, 1, do_ut_hush, "", ""), + SUITE_CMD(hush, do_ut_hush), #endif #ifdef CONFIG_CMD_LOADM - U_BOOT_CMD_MKENT(loadm, CONFIG_SYS_MAXARGS, 1, do_ut_loadm, "", ""), + SUITE_CMD(loadm, do_ut_loadm), #endif #ifdef CONFIG_CMD_PCI_MPS - U_BOOT_CMD_MKENT(pci_mps, CONFIG_SYS_MAXARGS, 1, do_ut_pci_mps, "", ""), + SUITE_CMD(pci_mps, do_ut_pci_mps), #endif #ifdef CONFIG_CMD_SEAMA - U_BOOT_CMD_MKENT(seama, CONFIG_SYS_MAXARGS, 1, do_ut_seama, "", ""), + SUITE_CMD(seama, do_ut_seama), #endif #ifdef CONFIG_CMD_UPL - U_BOOT_CMD_MKENT(upl, CONFIG_SYS_MAXARGS, 1, do_ut_upl, "", ""), + SUITE_CMD(upl, do_ut_upl), #endif };
+/** run_suite() - Run a suite of tests */ +static int run_suite(struct suite *ste, struct cmd_tbl *cmdtp, int flag, + int argc, char *const argv[]) +{ + int ret; + + if (ste->cmd) { + ret = ste->cmd(cmdtp, flag, argc, argv); + } else { + int n_ents = ste->end - ste->start; + char prefix[30]; + + /* use a standard prefix */ + snprintf(prefix, sizeof(prefix), "%s_test", ste->name); + ret = cmd_ut_category(ste->name, prefix, ste->start, n_ents, + argc, argv); + } + + return ret; +} + static int do_ut_all(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { @@ -138,9 +220,12 @@ static int do_ut_all(struct cmd_tbl *cmdtp, int flag, int argc, int retval; int any_fail = 0;
- for (i = 1; i < ARRAY_SIZE(cmd_ut_sub); i++) { - printf("----Running %s tests----\n", cmd_ut_sub[i].name); - retval = cmd_ut_sub[i].cmd(cmdtp, flag, 1, &cmd_ut_sub[i].name); + for (i = 0; i < ARRAY_SIZE(suites); i++) { + struct suite *ste = &suites[i]; + char *const argv[] = {(char *)ste->name, NULL}; + + printf("----Running %s tests----\n", ste->name); + retval = run_suite(ste, cmdtp, flag, 1, argv); if (!any_fail) any_fail = retval; } @@ -153,7 +238,7 @@ static int do_ut_info(struct cmd_tbl *cmdtp, int flag, int argc, { const char *flags;
- printf("Test suites: %d\n", (int)ARRAY_SIZE(cmd_ut_sub) - 1); + printf("Test suites: %d\n", (int)ARRAY_SIZE(suites)); printf("Total tests: %d\n", (int)UNIT_TEST_ALL_COUNT());
flags = cmd_arg1(argc, argv); @@ -162,16 +247,38 @@ static int do_ut_info(struct cmd_tbl *cmdtp, int flag, int argc,
puts("\nTests Suite\n"); puts("----- -----\n"); - for (i = 1; i < ARRAY_SIZE(cmd_ut_sub); i++) - printf("%5s %s\n", "?", cmd_ut_sub[i].name); + for (i = 1; i < ARRAY_SIZE(suites); i++) { + struct suite *ste = &suites[i]; + long n_ent = ste->end - ste->start; + + if (n_ent) + printf("%5ld %s\n", n_ent, ste->name); + else + printf("%5s %s\n", "?", ste->name); + } }
return 0; }
+static struct suite *find_suite(const char *name) +{ + struct suite *ste; + int i; + + for (i = 0, ste = suites; i < ARRAY_SIZE(suites); i++, ste++) { + if (!strcmp(ste->name, name)) + return ste; + } + + return NULL; +} + static int do_ut(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { - struct cmd_tbl *cp; + struct suite *ste; + const char *name; + int ret;
if (argc < 2) return CMD_RET_USAGE; @@ -180,12 +287,24 @@ static int do_ut(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) argc--; argv++;
- cp = find_cmd_tbl(argv[0], cmd_ut_sub, ARRAY_SIZE(cmd_ut_sub)); + name = argv[0]; + if (!strcmp(name, "all")) { + ret = do_ut_all(cmdtp, flag, argc, argv); + } else if (!strcmp(name, "info")) { + ret = do_ut_info(cmdtp, flag, argc, argv); + } else { + ste = find_suite(argv[0]); + if (!ste) { + printf("Suite '%s' not found\n", argv[0]); + return CMD_RET_FAILURE; + }
- if (cp) - return cp->cmd(cmdtp, flag, argc, argv); + ret = run_suite(ste, cmdtp, flag, argc, argv); + } + if (ret) + return ret;
- return CMD_RET_USAGE; + return 0; }
U_BOOT_LONGHELP(ut,
Use the new suite-runner to run these tests instead.
include/test/suites.h | 1 - test/cmd/bdinfo.c | 8 -------- test/cmd_ut.c | 2 +- 3 files changed, 1 insertion(+), 10 deletions(-)
diff --git a/include/test/suites.h b/include/test/suites.h index c1119e44999..b6af9295424 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -32,7 +32,6 @@ int cmd_ut_category(const char *name, const char *prefix,
int do_ut_addrmap(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_bdinfo(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_bootm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); diff --git a/test/cmd/bdinfo.c b/test/cmd/bdinfo.c index 46482b1f56b..11f717bf43e 100644 --- a/test/cmd/bdinfo.c +++ b/test/cmd/bdinfo.c @@ -282,11 +282,3 @@ static int bdinfo_test_eth(struct unit_test_state *uts) return 0; } BDINFO_TEST(bdinfo_test_eth, UTF_CONSOLE); - -int do_ut_bdinfo(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(bdinfo); - const int n_ents = UNIT_TEST_SUITE_COUNT(bdinfo); - - return cmd_ut_category("bdinfo", "bdinfo_test_", tests, n_ents, argc, argv); -} diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 10557be6d6d..2ee9b589b52 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -123,7 +123,7 @@ SUITE_DECL(upl); static struct suite suites[] = { SUITE_CMD(info, do_ut_info), #ifdef CONFIG_CMD_BDI - SUITE_CMD(bdinfo, do_ut_bdinfo), + SUITE(bdinfo), #endif #ifdef CONFIG_UT_BOOTSTD SUITE_CMD(bootstd, do_ut_bootstd),
include/test/suites.h | 1 - test/cmd/Makefile | 2 -- test/cmd/cmd_ut_cmd.c | 20 -------------------- test/cmd_ut.c | 2 +- 4 files changed, 1 insertion(+), 24 deletions(-) delete mode 100644 test/cmd/cmd_ut_cmd.c
diff --git a/include/test/suites.h b/include/test/suites.h index b6af9295424..21158692e9b 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -37,7 +37,6 @@ int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_bloblist(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_cmd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_common(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_dm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_env(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); diff --git a/test/cmd/Makefile b/test/cmd/Makefile index 583e7c2eec4..f83c53696d0 100644 --- a/test/cmd/Makefile +++ b/test/cmd/Makefile @@ -3,8 +3,6 @@ # Copyright (c) 2013 Google, Inc # Copyright 2022-2023 Arm Limited and/or its affiliates open-source-office@arm.com
-obj-y += cmd_ut_cmd.o - obj-$(CONFIG_$(XPL_)CMDLINE) += command.o ifdef CONFIG_HUSH_PARSER obj-$(CONFIG_CONSOLE_RECORD) += test_echo.o diff --git a/test/cmd/cmd_ut_cmd.c b/test/cmd/cmd_ut_cmd.c deleted file mode 100644 index ad192563c5a..00000000000 --- a/test/cmd/cmd_ut_cmd.c +++ /dev/null @@ -1,20 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Copyright 2023 Google LLC - * Written by Simon Glass sjg@chromium.org - * - * Unit tests for command functions - */ - -#include <command.h> -#include <test/cmd.h> -#include <test/suites.h> -#include <test/ut.h> - -int do_ut_cmd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(cmd); - const int n_ents = UNIT_TEST_SUITE_COUNT(cmd); - - return cmd_ut_category("cmd", "cmd_test_", tests, n_ents, argc, argv); -} diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 2ee9b589b52..761556cc763 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -129,7 +129,7 @@ static struct suite suites[] = { SUITE_CMD(bootstd, do_ut_bootstd), #endif #ifdef CONFIG_CMDLINE - SUITE_CMD(cmd, do_ut_cmd), + SUITE(cmd), #endif SUITE_CMD(common, do_ut_common), #if defined(CONFIG_UT_DM)
include/test/suites.h | 1 - test/cmd_ut.c | 2 +- test/common/Makefile | 1 - test/common/cmd_ut_common.c | 21 --------------------- 4 files changed, 1 insertion(+), 24 deletions(-) delete mode 100644 test/common/cmd_ut_common.c
diff --git a/include/test/suites.h b/include/test/suites.h index 21158692e9b..d6c0061ff87 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -37,7 +37,6 @@ int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_bloblist(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_common(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_dm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_env(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_exit(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 761556cc763..4b529cbd699 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -131,7 +131,7 @@ static struct suite suites[] = { #ifdef CONFIG_CMDLINE SUITE(cmd), #endif - SUITE_CMD(common, do_ut_common), + SUITE(common), #if defined(CONFIG_UT_DM) SUITE_CMD(dm, do_ut_dm), #endif diff --git a/test/common/Makefile b/test/common/Makefile index 53c4f16164d..9cfb5585d78 100644 --- a/test/common/Makefile +++ b/test/common/Makefile @@ -1,5 +1,4 @@ # SPDX-License-Identifier: GPL-2.0+ -obj-y += cmd_ut_common.o obj-$(CONFIG_AUTOBOOT) += test_autoboot.o ifneq ($(CONFIG_$(XPL_)BLOBLIST),) obj-$(CONFIG_$(XPL_)CMDLINE) += bloblist.o diff --git a/test/common/cmd_ut_common.c b/test/common/cmd_ut_common.c deleted file mode 100644 index 0724c9361b8..00000000000 --- a/test/common/cmd_ut_common.c +++ /dev/null @@ -1,21 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Copyright (c) 2019 Heinrich Schuchardt xypron.glpk@gmx.de - * Copyright (c) 2021 Steffen Jaeckel jaeckel-floss@eyet-services.de - * - * Unit tests for common functions - */ - -#include <command.h> -#include <test/common.h> -#include <test/suites.h> -#include <test/ut.h> - -int do_ut_common(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(common); - const int n_ents = UNIT_TEST_SUITE_COUNT(common); - - return cmd_ut_category("common", "common_test_", tests, n_ents, argc, - argv); -}
include/test/suites.h | 1 - test/cmd_ut.c | 2 +- test/dm/Makefile | 2 -- test/dm/test-dm.c | 15 --------------- 4 files changed, 1 insertion(+), 19 deletions(-) delete mode 100644 test/dm/test-dm.c
diff --git a/include/test/suites.h b/include/test/suites.h index d6c0061ff87..414613c593e 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -37,7 +37,6 @@ int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_bloblist(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_dm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_env(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_exit(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_fdt(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 4b529cbd699..a3dcbef1740 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -133,7 +133,7 @@ static struct suite suites[] = { #endif SUITE(common), #if defined(CONFIG_UT_DM) - SUITE_CMD(dm, do_ut_dm), + SUITE(dm), #endif #if defined(CONFIG_UT_ENV) SUITE_CMD(env, do_ut_env), diff --git a/test/dm/Makefile b/test/dm/Makefile index bcb52ef1067..e44f3d89e77 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -3,8 +3,6 @@ # Copyright (c) 2013 Google, Inc # Copyright 2022-2023 Arm Limited and/or its affiliates open-source-office@arm.com
-obj-$(CONFIG_UT_DM) += test-dm.o - # Tests for particular subsystems - when enabling driver model for a new # subsystem you must add sandbox tests here. ifeq ($(CONFIG_XPL_BUILD),y) diff --git a/test/dm/test-dm.c b/test/dm/test-dm.c deleted file mode 100644 index 8f83110163a..00000000000 --- a/test/dm/test-dm.c +++ /dev/null @@ -1,15 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (c) 2013 Google, Inc - */ - -#include <test/suites.h> -#include <test/test.h> - -int do_ut_dm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(dm); - const int n_ents = UNIT_TEST_SUITE_COUNT(dm); - - return cmd_ut_category("dm", "dm_test_", tests, n_ents, argc, argv); -}
include/test/suites.h | 1 - test/cmd_ut.c | 2 +- test/env/cmd_ut_env.c | 9 --------- 3 files changed, 1 insertion(+), 11 deletions(-)
diff --git a/include/test/suites.h b/include/test/suites.h index 414613c593e..b78436fe2b2 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -37,7 +37,6 @@ int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_bloblist(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_env(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_exit(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_fdt(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_font(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); diff --git a/test/cmd_ut.c b/test/cmd_ut.c index a3dcbef1740..a34998605cc 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -136,7 +136,7 @@ static struct suite suites[] = { SUITE(dm), #endif #if defined(CONFIG_UT_ENV) - SUITE_CMD(env, do_ut_env), + SUITE(env), #endif SUITE_CMD(exit, do_ut_exit), #ifdef CONFIG_CMD_FDT diff --git a/test/env/cmd_ut_env.c b/test/env/cmd_ut_env.c index 332139bb803..81d1bb2f80d 100644 --- a/test/env/cmd_ut_env.c +++ b/test/env/cmd_ut_env.c @@ -4,7 +4,6 @@ * Joe Hershberger, National Instruments, joe.hershberger@ni.com */
-#include <command.h> #include <test/env.h> #include <test/suites.h> #include <test/ut.h> @@ -74,11 +73,3 @@ static int env_test_env_cmd(struct unit_test_state *uts) return 0; } ENV_TEST(env_test_env_cmd, UTF_CONSOLE); - -int do_ut_env(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(env); - const int n_ents = UNIT_TEST_SUITE_COUNT(env); - - return cmd_ut_category("env", "env_test_", tests, n_ents, argc, argv); -}
include/test/suites.h | 1 - test/cmd/exit.c | 9 --------- test/cmd_ut.c | 2 +- 3 files changed, 1 insertion(+), 11 deletions(-)
diff --git a/include/test/suites.h b/include/test/suites.h index b78436fe2b2..70b9af1fd05 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -37,7 +37,6 @@ int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_bloblist(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_exit(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_fdt(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_font(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_hush(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); diff --git a/test/cmd/exit.c b/test/cmd/exit.c index d1eacdc36c2..71c37edcdf6 100644 --- a/test/cmd/exit.c +++ b/test/cmd/exit.c @@ -110,12 +110,3 @@ static int cmd_exit_test(struct unit_test_state *uts) return 0; } EXIT_TEST(cmd_exit_test, UTF_CONSOLE); - -int do_ut_exit(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(exit); - const int n_ents = UNIT_TEST_SUITE_COUNT(exit); - - return cmd_ut_category("exit", "exit_test_", tests, n_ents, - argc, argv); -} diff --git a/test/cmd_ut.c b/test/cmd_ut.c index a34998605cc..88a32129f0a 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -138,7 +138,7 @@ static struct suite suites[] = { #if defined(CONFIG_UT_ENV) SUITE(env), #endif - SUITE_CMD(exit, do_ut_exit), + SUITE(exit), #ifdef CONFIG_CMD_FDT SUITE_CMD(fdt, do_ut_fdt), #endif
include/test/suites.h | 1 - test/cmd/fdt.c | 8 -------- test/cmd_ut.c | 2 +- 3 files changed, 1 insertion(+), 10 deletions(-)
diff --git a/include/test/suites.h b/include/test/suites.h index 70b9af1fd05..bf3a9851322 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -37,7 +37,6 @@ int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_bloblist(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_fdt(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_font(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_hush(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_lib(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); diff --git a/test/cmd/fdt.c b/test/cmd/fdt.c index 74fd603bb02..ab6dbd45e54 100644 --- a/test/cmd/fdt.c +++ b/test/cmd/fdt.c @@ -1462,11 +1462,3 @@ static int fdt_test_apply(struct unit_test_state *uts) return 0; } FDT_TEST(fdt_test_apply, UTF_CONSOLE); - -int do_ut_fdt(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(fdt); - const int n_ents = UNIT_TEST_SUITE_COUNT(fdt); - - return cmd_ut_category("fdt", "fdt_test_", tests, n_ents, argc, argv); -} diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 88a32129f0a..f6c28c73981 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -140,7 +140,7 @@ static struct suite suites[] = { #endif SUITE(exit), #ifdef CONFIG_CMD_FDT - SUITE_CMD(fdt, do_ut_fdt), + SUITE(fdt), #endif #ifdef CONFIG_CONSOLE_TRUETYPE SUITE_CMD(font, do_ut_font),
include/test/suites.h | 1 - test/cmd/font.c | 8 -------- test/cmd_ut.c | 2 +- 3 files changed, 1 insertion(+), 10 deletions(-)
diff --git a/include/test/suites.h b/include/test/suites.h index bf3a9851322..587d6a5b473 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -37,7 +37,6 @@ int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_bloblist(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_font(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_hush(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_lib(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_loadm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); diff --git a/test/cmd/font.c b/test/cmd/font.c index d860efe8ce5..af88d1b5459 100644 --- a/test/cmd/font.c +++ b/test/cmd/font.c @@ -85,11 +85,3 @@ static int font_test_base(struct unit_test_state *uts) } FONT_TEST(font_test_base, UTF_SCAN_PDATA | UTF_SCAN_FDT | UTF_CONSOLE | UTF_DM); - -int do_ut_font(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(font); - const int n_ents = UNIT_TEST_SUITE_COUNT(font); - - return cmd_ut_category("font", "font_test_", tests, n_ents, argc, argv); -} diff --git a/test/cmd_ut.c b/test/cmd_ut.c index f6c28c73981..f9cf7b93412 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -143,7 +143,7 @@ static struct suite suites[] = { SUITE(fdt), #endif #ifdef CONFIG_CONSOLE_TRUETYPE - SUITE_CMD(font, do_ut_font), + SUITE(font), #endif #ifdef CONFIG_UT_OPTEE SUITE_CMD(optee, do_ut_optee),
include/test/suites.h | 1 - test/cmd_ut.c | 2 +- test/lib/Makefile | 1 - test/lib/cmd_ut_lib.c | 19 ------------------- 4 files changed, 1 insertion(+), 22 deletions(-) delete mode 100644 test/lib/cmd_ut_lib.c
diff --git a/include/test/suites.h b/include/test/suites.h index 587d6a5b473..08b35b276be 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -38,7 +38,6 @@ int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, int do_ut_bloblist(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_hush(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_lib(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_loadm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_log(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv[]); int do_ut_mbr(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); diff --git a/test/cmd_ut.c b/test/cmd_ut.c index f9cf7b93412..ba101a48b98 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -152,7 +152,7 @@ static struct suite suites[] = { SUITE_CMD(overlay, do_ut_overlay), #endif #ifdef CONFIG_UT_LIB - SUITE_CMD(lib, do_ut_lib), + SUITE(lib), #endif #ifdef CONFIG_UT_LOG SUITE_CMD(log, do_ut_log), diff --git a/test/lib/Makefile b/test/lib/Makefile index 3556c4d199c..f38f4947157 100644 --- a/test/lib/Makefile +++ b/test/lib/Makefile @@ -6,7 +6,6 @@ obj-$(CONFIG_$(XPL_)UT_COMPRESSION) += compression.o
ifeq ($(CONFIG_XPL_BUILD),) -obj-y += cmd_ut_lib.o obj-y += abuf.o obj-y += alist.o obj-$(CONFIG_EFI_LOADER) += efi_device_path.o diff --git a/test/lib/cmd_ut_lib.c b/test/lib/cmd_ut_lib.c deleted file mode 100644 index 90a8c0728b7..00000000000 --- a/test/lib/cmd_ut_lib.c +++ /dev/null @@ -1,19 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Copyright (c) 2019 Heinrich Schuchardt xypron.glpk@gmx.de - * - * Unit tests for library functions - */ - -#include <command.h> -#include <test/lib.h> -#include <test/suites.h> -#include <test/ut.h> - -int do_ut_lib(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(lib); - const int n_ents = UNIT_TEST_SUITE_COUNT(lib); - - return cmd_ut_category("lib", "lib_test_", tests, n_ents, argc, argv); -}
include/test/suites.h | 1 - test/cmd_ut.c | 2 +- test/log/Makefile | 2 -- test/log/log_ut.c | 20 -------------------- 4 files changed, 1 insertion(+), 24 deletions(-) delete mode 100644 test/log/log_ut.c
diff --git a/include/test/suites.h b/include/test/suites.h index 08b35b276be..72f98eb3558 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -39,7 +39,6 @@ int do_ut_bloblist(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_hush(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_loadm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_log(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv[]); int do_ut_mbr(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_measurement(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv[]); int do_ut_mem(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); diff --git a/test/cmd_ut.c b/test/cmd_ut.c index ba101a48b98..c490498b4c5 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -155,7 +155,7 @@ static struct suite suites[] = { SUITE(lib), #endif #ifdef CONFIG_UT_LOG - SUITE_CMD(log, do_ut_log), + SUITE(log), #endif #if defined(CONFIG_SANDBOX) && defined(CONFIG_CMD_MBR) && defined(CONFIG_CMD_MMC) \ && defined(CONFIG_MMC_SANDBOX) && defined(CONFIG_MMC_WRITE) diff --git a/test/log/Makefile b/test/log/Makefile index 08eea70e344..24b7c46786d 100644 --- a/test/log/Makefile +++ b/test/log/Makefile @@ -7,8 +7,6 @@ obj-$(CONFIG_CMD_LOG) += log_filter.o
ifdef CONFIG_UT_LOG
-obj-y += log_ut.o - ifdef CONFIG_SANDBOX obj-$(CONFIG_LOG_SYSLOG) += syslog_test.o obj-$(CONFIG_LOG_SYSLOG) += syslog_test_ndebug.o diff --git a/test/log/log_ut.c b/test/log/log_ut.c deleted file mode 100644 index 2aa3afe286a..00000000000 --- a/test/log/log_ut.c +++ /dev/null @@ -1,20 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (c) 2020, Heinrich Schuchardt xypron.glpk@gmx.de - * - * Logging function tests. - */ - -#include <console.h> -#include <log.h> -#include <test/log.h> -#include <test/suites.h> - -int do_ut_log(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(log); - const int n_ents = UNIT_TEST_SUITE_COUNT(log); - - return cmd_ut_category("log", "log_test_", - tests, n_ents, argc, argv); -}
include/test/suites.h | 1 - test/cmd/mbr.c | 8 -------- test/cmd_ut.c | 2 +- 3 files changed, 1 insertion(+), 10 deletions(-)
diff --git a/include/test/suites.h b/include/test/suites.h index 72f98eb3558..612167fe053 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -39,7 +39,6 @@ int do_ut_bloblist(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_hush(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_loadm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_mbr(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_measurement(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv[]); int do_ut_mem(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_optee(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); diff --git a/test/cmd/mbr.c b/test/cmd/mbr.c index ad859921ce5..45bab04923a 100644 --- a/test/cmd/mbr.c +++ b/test/cmd/mbr.c @@ -471,11 +471,3 @@ static int mbr_test_run(struct unit_test_state *uts)
/* Declare mbr test */ UNIT_TEST(mbr_test_run, UTF_CONSOLE, mbr); - -int do_ut_mbr(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(mbr); - const int n_ents = UNIT_TEST_SUITE_COUNT(mbr); - - return cmd_ut_category("mbr", "mbr_test_", tests, n_ents, argc, argv); -} diff --git a/test/cmd_ut.c b/test/cmd_ut.c index c490498b4c5..f5fbcf0d686 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -159,7 +159,7 @@ static struct suite suites[] = { #endif #if defined(CONFIG_SANDBOX) && defined(CONFIG_CMD_MBR) && defined(CONFIG_CMD_MMC) \ && defined(CONFIG_MMC_SANDBOX) && defined(CONFIG_MMC_WRITE) - SUITE_CMD(mbr, do_ut_mbr), + SUITE(mbr), #endif SUITE_CMD(mem, do_ut_mem), #if defined(CONFIG_SANDBOX) && defined(CONFIG_CMD_SETEXPR)
include/test/suites.h | 1 - test/cmd/Makefile | 2 +- test/cmd/mem.c | 19 ------------------- test/cmd_ut.c | 2 +- 4 files changed, 2 insertions(+), 22 deletions(-) delete mode 100644 test/cmd/mem.c
diff --git a/include/test/suites.h b/include/test/suites.h index 612167fe053..cb6b6fba240 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -40,7 +40,6 @@ int do_ut_bloblist(struct cmd_tbl *cmdtp, int flag, int argc, int do_ut_hush(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_loadm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_measurement(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv[]); -int do_ut_mem(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_optee(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_overlay(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); diff --git a/test/cmd/Makefile b/test/cmd/Makefile index f83c53696d0..d8a5e77402d 100644 --- a/test/cmd/Makefile +++ b/test/cmd/Makefile @@ -10,7 +10,7 @@ endif ifdef CONFIG_CONSOLE_RECORD obj-$(CONFIG_CMD_PAUSE) += test_pause.o endif -obj-y += exit.o mem.o +obj-y += exit.o obj-$(CONFIG_X86) += cpuid.o msr.o obj-$(CONFIG_CMD_ADDRMAP) += addrmap.o obj-$(CONFIG_CMD_BDI) += bdinfo.o diff --git a/test/cmd/mem.c b/test/cmd/mem.c deleted file mode 100644 index 2b78e421a9c..00000000000 --- a/test/cmd/mem.c +++ /dev/null @@ -1,19 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Executes tests for memory-related commands - * - * Copyright 2020 Google LLC - */ - -#include <command.h> -#include <test/suites.h> -#include <test/test.h> - -int do_ut_mem(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(mem); - const int n_ents = UNIT_TEST_SUITE_COUNT(mem); - - return cmd_ut_category("mem", "mem_test_", tests, n_ents, argc, - argv); -} diff --git a/test/cmd_ut.c b/test/cmd_ut.c index f5fbcf0d686..4e57fcf0005 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -161,7 +161,7 @@ static struct suite suites[] = { && defined(CONFIG_MMC_SANDBOX) && defined(CONFIG_MMC_WRITE) SUITE(mbr), #endif - SUITE_CMD(mem, do_ut_mem), + SUITE(mem), #if defined(CONFIG_SANDBOX) && defined(CONFIG_CMD_SETEXPR) SUITE_CMD(setexpr, do_ut_setexpr), #endif
include/test/suites.h | 2 -- test/cmd/setexpr.c | 9 --------- test/cmd_ut.c | 2 +- 3 files changed, 1 insertion(+), 12 deletions(-)
diff --git a/include/test/suites.h b/include/test/suites.h index cb6b6fba240..775b0a5a131 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -46,8 +46,6 @@ int do_ut_overlay(struct cmd_tbl *cmdtp, int flag, int argc, int do_ut_pci_mps(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_seama(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_setexpr(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]); int do_ut_upl(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]);
#endif /* __TEST_SUITES_H__ */ diff --git a/test/cmd/setexpr.c b/test/cmd/setexpr.c index 49eac5890aa..7f318a42ead 100644 --- a/test/cmd/setexpr.c +++ b/test/cmd/setexpr.c @@ -479,12 +479,3 @@ static int setexpr_test_fmt(struct unit_test_state *uts) } SETEXPR_TEST(setexpr_test_fmt, UTF_CONSOLE); #endif - -int do_ut_setexpr(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(setexpr); - const int n_ents = UNIT_TEST_SUITE_COUNT(setexpr); - - return cmd_ut_category("setexpr", "setexpr_test_", tests, n_ents, - argc, argv); -} diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 4e57fcf0005..c53b24bfde9 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -163,7 +163,7 @@ static struct suite suites[] = { #endif SUITE(mem), #if defined(CONFIG_SANDBOX) && defined(CONFIG_CMD_SETEXPR) - SUITE_CMD(setexpr, do_ut_setexpr), + SUITE(setexpr), #endif #ifdef CONFIG_MEASURED_BOOT SUITE_CMD(measurement, do_ut_measurement),
include/test/suites.h | 1 - test/boot/measurement.c | 10 ---------- test/cmd_ut.c | 2 +- 3 files changed, 1 insertion(+), 12 deletions(-)
diff --git a/include/test/suites.h b/include/test/suites.h index 775b0a5a131..1a40af6599a 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -39,7 +39,6 @@ int do_ut_bloblist(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_hush(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_loadm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_measurement(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv[]); int do_ut_optee(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_overlay(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); diff --git a/test/boot/measurement.c b/test/boot/measurement.c index 018e8af45f0..5a49c7a6b23 100644 --- a/test/boot/measurement.c +++ b/test/boot/measurement.c @@ -53,13 +53,3 @@ static int measure(struct unit_test_state *uts) return 0; } MEASUREMENT_TEST(measure, 0); - -int do_ut_measurement(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(measurement); - const int n_ents = UNIT_TEST_SUITE_COUNT(measurement); - - return cmd_ut_category("measurement", "measurement_test_", tests, - n_ents, argc, argv); -} diff --git a/test/cmd_ut.c b/test/cmd_ut.c index c53b24bfde9..6f5aa7e4924 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -166,7 +166,7 @@ static struct suite suites[] = { SUITE(setexpr), #endif #ifdef CONFIG_MEASURED_BOOT - SUITE_CMD(measurement, do_ut_measurement), + SUITE(measurement), #endif #ifdef CONFIG_SANDBOX SUITE_CMD(bloblist, do_ut_bloblist),
include/test/suites.h | 2 -- test/cmd_ut.c | 2 +- test/common/bloblist.c | 10 ---------- 3 files changed, 1 insertion(+), 13 deletions(-)
diff --git a/include/test/suites.h b/include/test/suites.h index 1a40af6599a..32b7e8e3d5a 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -35,8 +35,6 @@ int do_ut_addrmap(struct cmd_tbl *cmdtp, int flag, int argc, int do_ut_bootm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_bloblist(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]); int do_ut_hush(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_loadm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_optee(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 6f5aa7e4924..e0e01510016 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -169,7 +169,7 @@ static struct suite suites[] = { SUITE(measurement), #endif #ifdef CONFIG_SANDBOX - SUITE_CMD(bloblist, do_ut_bloblist), + SUITE(bloblist), SUITE_CMD(bootm, do_ut_bootm), #endif #ifdef CONFIG_CMD_ADDRMAP diff --git a/test/common/bloblist.c b/test/common/bloblist.c index f5d98774862..9467abfa8e1 100644 --- a/test/common/bloblist.c +++ b/test/common/bloblist.c @@ -602,13 +602,3 @@ static int bloblist_test_blob_maxsize(struct unit_test_state *uts) return 0; } BLOBLIST_TEST(bloblist_test_blob_maxsize, UFT_BLOBLIST); - -int do_ut_bloblist(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(bloblist); - const int n_ents = UNIT_TEST_SUITE_COUNT(bloblist); - - return cmd_ut_category("bloblist", "bloblist_test_", - tests, n_ents, argc, argv); -}
include/test/suites.h | 1 - test/boot/bootm.c | 9 --------- test/cmd_ut.c | 2 +- 3 files changed, 1 insertion(+), 11 deletions(-)
diff --git a/include/test/suites.h b/include/test/suites.h index 32b7e8e3d5a..77af692be3c 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -32,7 +32,6 @@ int cmd_ut_category(const char *name, const char *prefix,
int do_ut_addrmap(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_bootm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_hush(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); diff --git a/test/boot/bootm.c b/test/boot/bootm.c index c8e32023acb..1ce5c3cd6bf 100644 --- a/test/boot/bootm.c +++ b/test/boot/bootm.c @@ -256,12 +256,3 @@ static int bootm_test_subst_both(struct unit_test_state *uts) return 0; } BOOTM_TEST(bootm_test_subst_both, 0); - -int do_ut_bootm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(bootm); - const int n_ents = UNIT_TEST_SUITE_COUNT(bootm); - - return cmd_ut_category("bootm", "bootm_test_", tests, n_ents, - argc, argv); -} diff --git a/test/cmd_ut.c b/test/cmd_ut.c index e0e01510016..eb5ef099cb8 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -170,7 +170,7 @@ static struct suite suites[] = { #endif #ifdef CONFIG_SANDBOX SUITE(bloblist), - SUITE_CMD(bootm, do_ut_bootm), + SUITE(bootm), #endif #ifdef CONFIG_CMD_ADDRMAP SUITE_CMD(addrmap, do_ut_addrmap),
include/test/suites.h | 2 -- test/cmd/addrmap.c | 9 --------- test/cmd_ut.c | 2 +- 3 files changed, 1 insertion(+), 12 deletions(-)
diff --git a/include/test/suites.h b/include/test/suites.h index 77af692be3c..54fddaa6bac 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -30,8 +30,6 @@ int cmd_ut_category(const char *name, const char *prefix, struct unit_test *tests, int n_ents, int argc, char *const argv[]);
-int do_ut_addrmap(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]); int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_hush(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); diff --git a/test/cmd/addrmap.c b/test/cmd/addrmap.c index fd0117102e2..1f2deb15052 100644 --- a/test/cmd/addrmap.c +++ b/test/cmd/addrmap.c @@ -24,12 +24,3 @@ static int addrmap_test_basic(struct unit_test_state *uts) return 0; } ADDRMAP_TEST(addrmap_test_basic, UTF_CONSOLE); - -int do_ut_addrmap(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(addrmap); - const int n_ents = UNIT_TEST_SUITE_COUNT(addrmap); - - return cmd_ut_category("addrmap", "cmd_addrmap_", tests, n_ents, - argc, argv); -} diff --git a/test/cmd_ut.c b/test/cmd_ut.c index eb5ef099cb8..f68da4dcf76 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -173,7 +173,7 @@ static struct suite suites[] = { SUITE(bootm), #endif #ifdef CONFIG_CMD_ADDRMAP - SUITE_CMD(addrmap, do_ut_addrmap), + SUITE(addrmap), #endif #if CONFIG_IS_ENABLED(HUSH_PARSER) SUITE_CMD(hush, do_ut_hush),
include/test/suites.h | 1 - test/cmd_ut.c | 2 +- test/hush/Makefile | 1 - test/hush/cmd_ut_hush.c | 19 ------------------- 4 files changed, 1 insertion(+), 22 deletions(-) delete mode 100644 test/hush/cmd_ut_hush.c
diff --git a/include/test/suites.h b/include/test/suites.h index 54fddaa6bac..b96a78f7129 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -32,7 +32,6 @@ int cmd_ut_category(const char *name, const char *prefix,
int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_hush(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_loadm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_optee(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_overlay(struct cmd_tbl *cmdtp, int flag, int argc, diff --git a/test/cmd_ut.c b/test/cmd_ut.c index f68da4dcf76..39489ba0811 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -176,7 +176,7 @@ static struct suite suites[] = { SUITE(addrmap), #endif #if CONFIG_IS_ENABLED(HUSH_PARSER) - SUITE_CMD(hush, do_ut_hush), + SUITE(hush), #endif #ifdef CONFIG_CMD_LOADM SUITE_CMD(loadm, do_ut_loadm), diff --git a/test/hush/Makefile b/test/hush/Makefile index 4c3a0be857a..febdc82e8aa 100644 --- a/test/hush/Makefile +++ b/test/hush/Makefile @@ -3,7 +3,6 @@ # (C) Copyright 2021 # Francis Laniel, Amarula Solutions, francis.laniel@amarulasolutions.com
-obj-y += cmd_ut_hush.o obj-y += if.o ifdef CONFIG_CONSOLE_RECORD obj-y += dollar.o diff --git a/test/hush/cmd_ut_hush.c b/test/hush/cmd_ut_hush.c deleted file mode 100644 index 141203d766b..00000000000 --- a/test/hush/cmd_ut_hush.c +++ /dev/null @@ -1,19 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * (C) Copyright 2021 - * Francis Laniel, Amarula Solutions, francis.laniel@amarulasolutions.com - */ - -#include <command.h> -#include <test/hush.h> -#include <test/suites.h> -#include <test/ut.h> - -int do_ut_hush(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(hush); - const int n_ents = UNIT_TEST_SUITE_COUNT(hush); - - return cmd_ut_category("hush", "hush_test_", - tests, n_ents, argc, argv); -}
include/test/suites.h | 1 - test/cmd/loadm.c | 9 --------- test/cmd_ut.c | 2 +- 3 files changed, 1 insertion(+), 11 deletions(-)
diff --git a/include/test/suites.h b/include/test/suites.h index b96a78f7129..f6b33da5a28 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -32,7 +32,6 @@ int cmd_ut_category(const char *name, const char *prefix,
int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_loadm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_optee(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_overlay(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); diff --git a/test/cmd/loadm.c b/test/cmd/loadm.c index 78bb12ce88c..3c623aa655f 100644 --- a/test/cmd/loadm.c +++ b/test/cmd/loadm.c @@ -58,12 +58,3 @@ static int loadm_test_load (struct unit_test_state *uts) return 0; } LOADM_TEST(loadm_test_load, UTF_CONSOLE); - -int do_ut_loadm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(loadm); - const int n_ents = UNIT_TEST_SUITE_COUNT(loadm); - - return cmd_ut_category("loadm", "loadm_test_", tests, n_ents, argc, - argv); -} diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 39489ba0811..0a6284e4962 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -179,7 +179,7 @@ static struct suite suites[] = { SUITE(hush), #endif #ifdef CONFIG_CMD_LOADM - SUITE_CMD(loadm, do_ut_loadm), + SUITE(loadm), #endif #ifdef CONFIG_CMD_PCI_MPS SUITE_CMD(pci_mps, do_ut_pci_mps),
include/test/suites.h | 2 -- test/cmd/pci_mps.c | 10 ---------- test/cmd_ut.c | 2 +- 3 files changed, 1 insertion(+), 13 deletions(-)
diff --git a/include/test/suites.h b/include/test/suites.h index f6b33da5a28..49c18ebf456 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -35,8 +35,6 @@ int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, int do_ut_optee(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_overlay(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_pci_mps(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]); int do_ut_seama(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_upl(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]);
diff --git a/test/cmd/pci_mps.c b/test/cmd/pci_mps.c index 2595ea103ff..8b3ea4a6134 100644 --- a/test/cmd/pci_mps.c +++ b/test/cmd/pci_mps.c @@ -28,13 +28,3 @@ static int test_pci_mps_safe(struct unit_test_state *uts) return 0; } PCI_MPS_TEST(test_pci_mps_safe, UTF_CONSOLE); - -int do_ut_pci_mps(struct cmd_tbl *cmdtp, int flag, int argc, - char * const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(pci_mps); - const int n = UNIT_TEST_SUITE_COUNT(pci_mps); - - return cmd_ut_category("pci_mps", "pci_mps_test_", tests, n, - argc, argv); -} diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 0a6284e4962..7caf41da096 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -182,7 +182,7 @@ static struct suite suites[] = { SUITE(loadm), #endif #ifdef CONFIG_CMD_PCI_MPS - SUITE_CMD(pci_mps, do_ut_pci_mps), + SUITE(pci_mps), #endif #ifdef CONFIG_CMD_SEAMA SUITE_CMD(seama, do_ut_seama),
It is not clear that these actually work, since they are not enabled on sandbox for some reason.
include/test/suites.h | 1 - test/cmd/seama.c | 9 --------- test/cmd_ut.c | 2 +- 3 files changed, 1 insertion(+), 11 deletions(-)
diff --git a/include/test/suites.h b/include/test/suites.h index 49c18ebf456..cd758b8c464 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -35,7 +35,6 @@ int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, int do_ut_optee(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_overlay(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_seama(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_upl(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]);
#endif /* __TEST_SUITES_H__ */ diff --git a/test/cmd/seama.c b/test/cmd/seama.c index 39590d162ac..1edc3fcac5a 100644 --- a/test/cmd/seama.c +++ b/test/cmd/seama.c @@ -56,12 +56,3 @@ static int seama_test_index(struct unit_test_state *uts) return 0; } SEAMA_TEST(seama_test_index, UTF_CONSOLE); - -int do_ut_seama(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(seama); - const int n_ents = UNIT_TEST_SUITE_COUNT(seama); - - return cmd_ut_category("seama", "seama_test_", tests, n_ents, argc, - argv); -} diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 7caf41da096..c6b7ccdedbd 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -185,7 +185,7 @@ static struct suite suites[] = { SUITE(pci_mps), #endif #ifdef CONFIG_CMD_SEAMA - SUITE_CMD(seama, do_ut_seama), + SUITE(seama), #endif #ifdef CONFIG_CMD_UPL SUITE_CMD(upl, do_ut_upl),
include/test/suites.h | 1 - test/boot/upl.c | 8 -------- test/cmd_ut.c | 2 +- 3 files changed, 1 insertion(+), 10 deletions(-)
diff --git a/include/test/suites.h b/include/test/suites.h index cd758b8c464..20e6a2a113b 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -35,6 +35,5 @@ int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, int do_ut_optee(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_ut_overlay(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_upl(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]);
#endif /* __TEST_SUITES_H__ */ diff --git a/test/boot/upl.c b/test/boot/upl.c index 2c9b8bc8bc0..aa58cdf083b 100644 --- a/test/boot/upl.c +++ b/test/boot/upl.c @@ -426,11 +426,3 @@ static int upl_test_info_norun(struct unit_test_state *uts) return 0; } UPL_TEST(upl_test_info_norun, UTF_CONSOLE | UTF_MANUAL); - -int do_ut_upl(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) -{ - struct unit_test *tests = UNIT_TEST_SUITE_START(upl); - const int n_ents = UNIT_TEST_SUITE_COUNT(upl); - - return cmd_ut_category("upl", "cmd_upl_", tests, n_ents, argc, argv); -} diff --git a/test/cmd_ut.c b/test/cmd_ut.c index c6b7ccdedbd..0d055119ce3 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -188,7 +188,7 @@ static struct suite suites[] = { SUITE(seama), #endif #ifdef CONFIG_CMD_UPL - SUITE_CMD(upl, do_ut_upl), + SUITE(upl), #endif };
The 'info' test is not a real test. With the new suite array we can drop this and the associated special-case code.
test/cmd_ut.c | 4 +--- test/py/tests/test_suite.py | 13 +++++-------- 2 files changed, 6 insertions(+), 11 deletions(-)
diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 0d055119ce3..798710972e5 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -93,7 +93,6 @@ int cmd_ut_category(const char *name, const char *prefix, NULL, \ }
-SUITE_DECL(info); SUITE_DECL(bdinfo); SUITE_DECL(bootstd); SUITE_DECL(cmd); @@ -121,7 +120,6 @@ SUITE_DECL(seama); SUITE_DECL(upl);
static struct suite suites[] = { - SUITE_CMD(info, do_ut_info), #ifdef CONFIG_CMD_BDI SUITE(bdinfo), #endif @@ -247,7 +245,7 @@ static int do_ut_info(struct cmd_tbl *cmdtp, int flag, int argc,
puts("\nTests Suite\n"); puts("----- -----\n"); - for (i = 1; i < ARRAY_SIZE(suites); i++) { + for (i = 0; i < ARRAY_SIZE(suites); i++) { struct suite *ste = &suites[i]; long n_ent = ste->end - ste->start;
diff --git a/test/py/tests/test_suite.py b/test/py/tests/test_suite.py index ed636bbde74..938dfb468f6 100644 --- a/test/py/tests/test_suite.py +++ b/test/py/tests/test_suite.py @@ -8,7 +8,7 @@ import re EXPECTED_SUITES = [ 'addrmap', 'bdinfo', 'bloblist', 'bootm', 'bootstd', 'cmd', 'common', 'dm', 'env', 'exit', - 'fdt', 'font', 'hush', 'info', 'lib', + 'fdt', 'font', 'hush', 'lib', 'loadm', 'log', 'mbr', 'measurement', 'mem', 'overlay', 'pci_mps', 'setexpr', 'upl', ] @@ -145,9 +145,8 @@ def test_suite(u_boot_console): suites, all_tests, exp_test_count, missing, extra = collect_info(cons, output)
- # Make sure we got a test count for each suite (ignore 'info' since it isn't - # a real suite - assert suites - exp_test_count.keys() == {'info'} + # Make sure we got a test count for each suite + assert suites - exp_test_count.keys() == set()
# Run 'ut info' and compare with the log results with cons.log.section('Check suite test-counts'): @@ -166,10 +165,8 @@ def test_suite(u_boot_console):
cons.log.info(str(exp_test_count)) for suite in EXPECTED_SUITES: - # 'info' is not really a suite, just a subcommand of 'ut' - if suite != 'info': - assert test_count[suite] in ['?', str(exp_test_count[suite])],\ - f'suite {suite} expected {exp_test_count[suite]}' + assert test_count[suite] in ['?', str(exp_test_count[suite])], \ + f'suite {suite} expected {exp_test_count[suite]}'
assert suite_count == len(EXPECTED_SUITES) assert total_test_count == len(all_tests)
This is not needed anymore. If a test suite is not built, then it will have no linker-list entries. So we can just check for that and know that the suite is not present.
This allows removal of the #ifdefs and the need to keep them in sync with the associated Makefile rules, which has actually failed, since the help does not match what commands are actually present.
test/cmd_ut.c | 75 ++++++++++++++++--------------------- test/py/tests/test_suite.py | 19 +++++++--- 2 files changed, 46 insertions(+), 48 deletions(-)
diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 798710972e5..2ba99a26c63 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -120,76 +120,55 @@ SUITE_DECL(seama); SUITE_DECL(upl);
static struct suite suites[] = { -#ifdef CONFIG_CMD_BDI SUITE(bdinfo), -#endif #ifdef CONFIG_UT_BOOTSTD SUITE_CMD(bootstd, do_ut_bootstd), #endif -#ifdef CONFIG_CMDLINE SUITE(cmd), -#endif SUITE(common), -#if defined(CONFIG_UT_DM) SUITE(dm), -#endif -#if defined(CONFIG_UT_ENV) SUITE(env), -#endif SUITE(exit), -#ifdef CONFIG_CMD_FDT SUITE(fdt), -#endif -#ifdef CONFIG_CONSOLE_TRUETYPE SUITE(font), -#endif #ifdef CONFIG_UT_OPTEE SUITE_CMD(optee, do_ut_optee), #endif #ifdef CONFIG_UT_OVERLAY SUITE_CMD(overlay, do_ut_overlay), #endif -#ifdef CONFIG_UT_LIB SUITE(lib), -#endif -#ifdef CONFIG_UT_LOG SUITE(log), -#endif -#if defined(CONFIG_SANDBOX) && defined(CONFIG_CMD_MBR) && defined(CONFIG_CMD_MMC) \ - && defined(CONFIG_MMC_SANDBOX) && defined(CONFIG_MMC_WRITE) SUITE(mbr), -#endif SUITE(mem), -#if defined(CONFIG_SANDBOX) && defined(CONFIG_CMD_SETEXPR) SUITE(setexpr), -#endif -#ifdef CONFIG_MEASURED_BOOT SUITE(measurement), -#endif -#ifdef CONFIG_SANDBOX SUITE(bloblist), SUITE(bootm), -#endif -#ifdef CONFIG_CMD_ADDRMAP SUITE(addrmap), -#endif -#if CONFIG_IS_ENABLED(HUSH_PARSER) SUITE(hush), -#endif -#ifdef CONFIG_CMD_LOADM SUITE(loadm), -#endif -#ifdef CONFIG_CMD_PCI_MPS SUITE(pci_mps), -#endif -#ifdef CONFIG_CMD_SEAMA SUITE(seama), -#endif -#ifdef CONFIG_CMD_UPL SUITE(upl), -#endif };
+/** + * has_tests() - Check if a suite has tests, i.e. is supported in this build + * + * If the suite is run using a command, we have to assume that tests may be + * present, since we have no visibility + * + * @ste: Suite to check + * Return: true if supported, false if not + */ +static bool has_tests(struct suite *ste) +{ + int n_ents = ste->end - ste->start; + + return n_ents || ste->cmd; +} + /** run_suite() - Run a suite of tests */ static int run_suite(struct suite *ste, struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) @@ -222,10 +201,12 @@ static int do_ut_all(struct cmd_tbl *cmdtp, int flag, int argc, struct suite *ste = &suites[i]; char *const argv[] = {(char *)ste->name, NULL};
- printf("----Running %s tests----\n", ste->name); - retval = run_suite(ste, cmdtp, flag, 1, argv); - if (!any_fail) - any_fail = retval; + if (has_tests(ste)) { + printf("----Running %s tests----\n", ste->name); + retval = run_suite(ste, cmdtp, flag, 1, argv); + if (!any_fail) + any_fail = retval; + } }
return any_fail; @@ -234,9 +215,17 @@ static int do_ut_all(struct cmd_tbl *cmdtp, int flag, int argc, static int do_ut_info(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { + int suite_count, i; const char *flags;
- printf("Test suites: %d\n", (int)ARRAY_SIZE(suites)); + for (suite_count = 0, i = 0; i < ARRAY_SIZE(suites); i++) { + struct suite *ste = &suites[i]; + + if (has_tests(ste)) + suite_count++; + } + + printf("Test suites: %d\n", suite_count); printf("Total tests: %d\n", (int)UNIT_TEST_ALL_COUNT());
flags = cmd_arg1(argc, argv); @@ -251,7 +240,7 @@ static int do_ut_info(struct cmd_tbl *cmdtp, int flag, int argc,
if (n_ent) printf("%5ld %s\n", n_ent, ste->name); - else + else if (ste->cmd) printf("%5s %s\n", "?", ste->name); } } diff --git a/test/py/tests/test_suite.py b/test/py/tests/test_suite.py index 938dfb468f6..1c248602199 100644 --- a/test/py/tests/test_suite.py +++ b/test/py/tests/test_suite.py @@ -106,7 +106,7 @@ def process_ut_info(cons, output): test_count = {} for line in output.splitlines(): if DEBUG_ME: - cons.log.info(f'line: {line}') + cons.log.info(f'line: {line.rstrip()}') m = re.match(r'Test suites: (.*)', line) if m: suite_count = int(m.group(1)) @@ -122,7 +122,7 @@ def process_ut_info(cons, output): @pytest.mark.buildconfigspec('sandbox') @pytest.mark.notbuildconfigspec('sandbox_spl') @pytest.mark.notbuildconfigspec('sandbox64') -def test_suite(u_boot_console): +def test_suite(u_boot_console, u_boot_config): """Perform various checks on the unit tests, including:
- The number of suites matches that reported by the 'ut info' @@ -135,6 +135,7 @@ def test_suite(u_boot_console):
""" cons = u_boot_console + buildconfig = u_boot_config.buildconfig with cons.log.section('Run all unit tests'): # ut hush hush_test_simple_dollar prints "Unknown command" on purpose. with u_boot_console.disable_check('unknown_command'): @@ -144,9 +145,17 @@ def test_suite(u_boot_console): with cons.log.section('Check output'): suites, all_tests, exp_test_count, missing, extra = collect_info(cons, output) + cons.log.info(f'missing {missing}') + cons.log.info(f'extra {extra}')
# Make sure we got a test count for each suite - assert suites - exp_test_count.keys() == set() + assert not (suites - exp_test_count.keys()) + + # Deal with missing suites + with cons.log.section('Check missing suites'): + if 'config_cmd_seama' not in buildconfig: + cons.log.info("CMD_SEAMA not enabled: Ignoring suite 'seama'") + missing.discard('seama')
# Run 'ut info' and compare with the log results with cons.log.section('Check suite test-counts'): @@ -160,8 +169,8 @@ def test_suite(u_boot_console): cons.log.error(f'missing: {sorted(list(missing))}') cons.log.error(f'extra: {sorted(list(extra))}')
- assert not missing - assert not extra + assert not missing, f'Missing suites {missing}' + assert not extra, f'Extra suites {extra}'
Update this function to access a unit-test state, so that the caller can collect results from running multiple suites.
include/test/suites.h | 20 +++++++++++-------- test/boot/bootstd_common.c | 7 ++++--- test/cmd_ut.c | 37 ++++++++++++++++++----------------- test/overlay/cmd_ut_overlay.c | 10 +++------- 4 files changed, 38 insertions(+), 36 deletions(-)
diff --git a/include/test/suites.h b/include/test/suites.h index 20e6a2a113b..774dd893378 100644 --- a/include/test/suites.h +++ b/include/test/suites.h @@ -9,14 +9,18 @@
struct cmd_tbl; struct unit_test; +struct unit_test_state;
/* 'command' functions normally called do_xxx where xxx is the command name */ -typedef int (*ut_cmd_func)(struct cmd_tbl *cmd, int flags, int argc, - char *const argv[]); +typedef int (*ut_cmd_func)(struct unit_test_state *uts, struct cmd_tbl *cmd, + int flags, int argc, char *const argv[]);
/** * cmd_ut_category() - Run a category of unit tests * + * @uts: Unit-test state, which must be ready for use, i.e. ut_init_state() + * has been called. The caller is responsible for calling + * ut_uninit_state() after this function returns * @name: Category name * @prefix: Prefix of test name * @tests: List of tests to run @@ -26,14 +30,14 @@ typedef int (*ut_cmd_func)(struct cmd_tbl *cmd, int flags, int argc, * @argv: Arguments: argv[1] is the test to run (if @argc >= 2) * Return: 0 if OK, CMD_RET_FAILURE on failure */ -int cmd_ut_category(const char *name, const char *prefix, - struct unit_test *tests, int n_ents, +int cmd_ut_category(struct unit_test_state *uts, const char *name, + const char *prefix, struct unit_test *tests, int n_ents, int argc, char *const argv[]);
-int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]); +int do_ut_bootstd(struct unit_test_state *uts, struct cmd_tbl *cmdtp, int flag, + int argc, char *const argv[]); int do_ut_optee(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); -int do_ut_overlay(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]); +int do_ut_overlay(struct unit_test_state *uts, struct cmd_tbl *cmdtp, int flag, + int argc, char *const argv[]);
#endif /* __TEST_SUITES_H__ */ diff --git a/test/boot/bootstd_common.c b/test/boot/bootstd_common.c index 6bd9bb65a40..724e3d9bdd2 100644 --- a/test/boot/bootstd_common.c +++ b/test/boot/bootstd_common.c @@ -94,7 +94,8 @@ void bootstd_reset_usb(void) usb_started = false; }
-int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +int do_ut_bootstd(struct unit_test_state *uts, struct cmd_tbl *cmdtp, int flag, + int argc, char *const argv[]) { struct unit_test *tests = UNIT_TEST_SUITE_START(bootstd); const int n_ents = UNIT_TEST_SUITE_COUNT(bootstd); @@ -106,6 +107,6 @@ int do_ut_bootstd(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) return CMD_RET_FAILURE; }
- return cmd_ut_category("bootstd", "bootstd_", tests, n_ents, - argc, argv); + return cmd_ut_category(uts, "bootstd", "bootstd_", + tests, n_ents, argc, argv); } diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 2ba99a26c63..f315c442abf 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -29,17 +29,16 @@ struct suite { ut_cmd_func cmd; };
-static int do_ut_all(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]); +static int do_ut_all(struct unit_test_state *uts, struct cmd_tbl *cmdtp, + int flag, int argc, char *const argv[]);
static int do_ut_info(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]);
-int cmd_ut_category(const char *name, const char *prefix, - struct unit_test *tests, int n_ents, +int cmd_ut_category(struct unit_test_state *uts, const char *name, + const char *prefix, struct unit_test *tests, int n_ents, int argc, char *const argv[]) { - struct unit_test_state uts; const char *test_insert = NULL; int runs_per_text = 1; bool force_run = false; @@ -63,11 +62,9 @@ int cmd_ut_category(const char *name, const char *prefix, argc--; }
- ut_init_state(&uts); - ret = ut_run_list(&uts, name, prefix, tests, n_ents, + ret = ut_run_list(uts, name, prefix, tests, n_ents, cmd_arg1(argc, argv), runs_per_text, force_run, test_insert); - ut_uninit_state(&uts);
return ret ? CMD_RET_FAILURE : 0; } @@ -170,28 +167,29 @@ static bool has_tests(struct suite *ste) }
/** run_suite() - Run a suite of tests */ -static int run_suite(struct suite *ste, struct cmd_tbl *cmdtp, int flag, - int argc, char *const argv[]) +static int run_suite(struct unit_test_state *uts, struct suite *ste, + struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) { int ret;
if (ste->cmd) { - ret = ste->cmd(cmdtp, flag, argc, argv); + ret = ste->cmd(uts, cmdtp, flag, argc, argv); } else { int n_ents = ste->end - ste->start; char prefix[30];
/* use a standard prefix */ snprintf(prefix, sizeof(prefix), "%s_test", ste->name); - ret = cmd_ut_category(ste->name, prefix, ste->start, n_ents, - argc, argv); + ret = cmd_ut_category(uts, ste->name, prefix, ste->start, + n_ents, argc, argv); }
return ret; }
-static int do_ut_all(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]) +static int do_ut_all(struct unit_test_state *uts, struct cmd_tbl *cmdtp, + int flag, int argc, char *const argv[]) { int i; int retval; @@ -203,7 +201,7 @@ static int do_ut_all(struct cmd_tbl *cmdtp, int flag, int argc,
if (has_tests(ste)) { printf("----Running %s tests----\n", ste->name); - retval = run_suite(ste, cmdtp, flag, 1, argv); + retval = run_suite(uts, ste, cmdtp, flag, 1, argv); if (!any_fail) any_fail = retval; } @@ -263,6 +261,7 @@ static struct suite *find_suite(const char *name)
static int do_ut(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { + struct unit_test_state uts; struct suite *ste; const char *name; int ret; @@ -274,9 +273,10 @@ static int do_ut(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) argc--; argv++;
+ ut_init_state(&uts); name = argv[0]; if (!strcmp(name, "all")) { - ret = do_ut_all(cmdtp, flag, argc, argv); + ret = do_ut_all(&uts, cmdtp, flag, argc, argv); } else if (!strcmp(name, "info")) { ret = do_ut_info(cmdtp, flag, argc, argv); } else { @@ -286,10 +286,11 @@ static int do_ut(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) return CMD_RET_FAILURE; }
- ret = run_suite(ste, cmdtp, flag, argc, argv); + ret = run_suite(&uts, ste, cmdtp, flag, argc, argv); } if (ret) return ret; + ut_uninit_state(&uts);
return 0; } diff --git a/test/overlay/cmd_ut_overlay.c b/test/overlay/cmd_ut_overlay.c index e0483afc31d..aefa147ec04 100644 --- a/test/overlay/cmd_ut_overlay.c +++ b/test/overlay/cmd_ut_overlay.c @@ -210,21 +210,17 @@ static int fdt_overlay_stacked(struct unit_test_state *uts) } OVERLAY_TEST(fdt_overlay_stacked, 0);
-int do_ut_overlay(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +int do_ut_overlay(struct unit_test_state *uts, struct cmd_tbl *cmdtp, int flag, + int argc, char *const argv[]) { struct unit_test *tests = UNIT_TEST_SUITE_START(overlay); const int n_ents = UNIT_TEST_SUITE_COUNT(overlay); - struct unit_test_state *uts; void *fdt_base = &__dtb_test_fdt_base_begin; void *fdt_overlay = &__dtbo_test_fdt_overlay_begin; void *fdt_overlay_stacked = &__dtbo_test_fdt_overlay_stacked_begin; void *fdt_overlay_copy, *fdt_overlay_stacked_copy; int ret = -ENOMEM;
- uts = calloc(1, sizeof(*uts)); - if (!uts) - return -ENOMEM; - ut_assertok(fdt_check_header(fdt_base)); ut_assertok(fdt_check_header(fdt_overlay));
@@ -272,7 +268,7 @@ int do_ut_overlay(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) /* Apply the stacked overlay */ ut_assertok(fdt_overlay_apply(fdt, fdt_overlay_stacked_copy));
- ret = cmd_ut_category("overlay", "", tests, n_ents, argc, argv); + ret = cmd_ut_category(uts, "overlay", "", tests, n_ents, argc, argv);
free(fdt_overlay_stacked_copy); err3:
Use a struct to hold the stats, since we also want to have the same stats for all runs as we have for each suite.
include/test/test.h | 17 +++++++++++++---- test/test-main.c | 29 +++++++++++++++-------------- test/ut.c | 4 ++-- 3 files changed, 30 insertions(+), 20 deletions(-)
diff --git a/include/test/test.h b/include/test/test.h index 21c0478befe..bc8f0bbe501 100644 --- a/include/test/test.h +++ b/include/test/test.h @@ -9,11 +9,21 @@ #include <malloc.h> #include <linux/bitops.h>
-/* - * struct unit_test_state - Entire state of test system +/** + * struct ut_stats - Statistics about tests run * * @fail_count: Number of tests that failed * @skip_count: Number of tests that were skipped + */ +struct ut_stats { + int fail_count; + int skip_count; +}; + +/* + * struct unit_test_state - Entire state of test system + * + * @cur: Statistics for the current run * @start: Store the starting mallinfo when doing leak test * @of_live: true to use livetree if available, false to use flattree * @of_root: Record of the livetree root node (used for setting up tests) @@ -34,8 +44,7 @@ * @actual_str: Temporary string used to hold actual string value */ struct unit_test_state { - int fail_count; - int skip_count; + struct ut_stats cur; struct mallinfo start; struct device_node *of_root; bool of_live; diff --git a/test/test-main.c b/test/test-main.c index 391d4e7bb0e..e8aecd267c7 100644 --- a/test/test-main.c +++ b/test/test-main.c @@ -448,7 +448,7 @@ static int test_post_run(struct unit_test_state *uts, struct unit_test *test) */ static int skip_test(struct unit_test_state *uts) { - uts->skip_count++; + uts->cur.skip_count++;
return -EAGAIN; } @@ -460,7 +460,7 @@ static int skip_test(struct unit_test_state *uts) * the name of each test before running it. * * @uts: Test state to update. The caller should ensure that this is zeroed for - * the first call to this function. On exit, @uts->fail_count is + * the first call to this function. On exit, @uts->cur.fail_count is * incremented by the number of failures (0, one hopes) * @test_name: Test to run * @name: Name of test, possibly skipping a prefix that should not be displayed @@ -510,7 +510,7 @@ static int ut_run_test(struct unit_test_state *uts, struct unit_test *test, * SPL. * * @uts: Test state to update. The caller should ensure that this is zeroed for - * the first call to this function. On exit, @uts->fail_count is + * the first call to this function. On exit, @uts->cur.fail_count is * incremented by the number of failures (0, one hopes) * @test: Test to run * Return: 0 if all tests passed, -EAGAIN if the test should be skipped, -1 if @@ -574,7 +574,7 @@ static int ut_run_test_live_flat(struct unit_test_state *uts, * the name of each test before running it. * * @uts: Test state to update. The caller should ensure that this is zeroed for - * the first call to this function. On exit, @uts->fail_count is + * the first call to this function. On exit, @uts->cur.fail_count is * incremented by the number of failures (0, one hopes) * @prefix: String prefix for the tests. Any tests that have this prefix will be * printed without the prefix, so that it is easier to see the unique part @@ -632,7 +632,7 @@ static int ut_run_tests(struct unit_test_state *uts, const char *prefix, if (len < 6 || strcmp(test_name + len - 6, "_norun")) { printf("Test '%s' is manual so must have a name ending in _norun\n", test_name); - uts->fail_count++; + uts->cur.fail_count++; return -EBADF; } if (!uts->force_run) { @@ -641,23 +641,24 @@ static int ut_run_tests(struct unit_test_state *uts, const char *prefix, continue; } } - old_fail_count = uts->fail_count; + old_fail_count = uts->cur.fail_count;
if (one && upto == pos) { ret = ut_run_test_live_flat(uts, one); - if (uts->fail_count != old_fail_count) { + if (uts->cur.fail_count != old_fail_count) { printf("Test '%s' failed %d times (position %d)\n", one->name, - uts->fail_count - old_fail_count, pos); + uts->cur.fail_count - old_fail_count, + pos); } return -EBADF; }
for (i = 0; i < uts->runs_per_test; i++) ret = ut_run_test_live_flat(uts, test); - if (uts->fail_count != old_fail_count) { + if (uts->cur.fail_count != old_fail_count) { printf("Test '%s' failed %d times\n", test_name, - uts->fail_count - old_fail_count); + uts->cur.fail_count - old_fail_count); } found++; if (ret == -EAGAIN) @@ -668,7 +669,7 @@ static int ut_run_tests(struct unit_test_state *uts, const char *prefix, if (select_name && !found) return -ENOENT;
- return uts->fail_count ? -EBADF : 0; + return uts->cur.fail_count ? -EBADF : 0; }
int ut_run_list(struct unit_test_state *uts, const char *category, @@ -716,12 +717,12 @@ int ut_run_list(struct unit_test_state *uts, const char *category, if (has_dm_tests) dm_test_restore(uts->of_root);
- if (uts->skip_count) - printf("Skipped: %d, ", uts->skip_count); + if (uts->cur.skip_count) + printf("Skipped: %d, ", uts->cur.skip_count); if (ret == -ENOENT) printf("Test '%s' not found\n", select_name); else - printf("Failures: %d\n", uts->fail_count); + printf("Failures: %d\n", uts->cur.fail_count);
return ret; } diff --git a/test/ut.c b/test/ut.c index 7454da3e001..a16fdfb3a93 100644 --- a/test/ut.c +++ b/test/ut.c @@ -21,7 +21,7 @@ void ut_fail(struct unit_test_state *uts, const char *fname, int line, { gd->flags &= ~(GD_FLG_SILENT | GD_FLG_RECORD); printf("%s:%d, %s(): %s\n", fname, line, func, cond); - uts->fail_count++; + uts->cur.fail_count++; }
void ut_failf(struct unit_test_state *uts, const char *fname, int line, @@ -35,7 +35,7 @@ void ut_failf(struct unit_test_state *uts, const char *fname, int line, vprintf(fmt, args); va_end(args); putc('\n'); - uts->fail_count++; + uts->cur.fail_count++; }
ulong ut_check_free(void)
This is useful information and is not always the same as the 'count' arg to ut_run_list() so add it as a separate stat.
include/test/test.h | 3 +++ test/test-main.c | 2 ++ 2 files changed, 5 insertions(+)
diff --git a/include/test/test.h b/include/test/test.h index bc8f0bbe501..f7087ab4eea 100644 --- a/include/test/test.h +++ b/include/test/test.h @@ -14,10 +14,13 @@ * * @fail_count: Number of tests that failed * @skip_count: Number of tests that were skipped + * @test_count: Number of tests run. If a test is run muiltiple times, only one + * is counted */ struct ut_stats { int fail_count; int skip_count; + int test_count; };
/* diff --git a/test/test-main.c b/test/test-main.c index e8aecd267c7..e36bc37d29e 100644 --- a/test/test-main.c +++ b/test/test-main.c @@ -643,6 +643,7 @@ static int ut_run_tests(struct unit_test_state *uts, const char *prefix, } old_fail_count = uts->cur.fail_count;
+ uts->cur.test_count++; if (one && upto == pos) { ret = ut_run_test_live_flat(uts, one); if (uts->cur.fail_count != old_fail_count) { @@ -717,6 +718,7 @@ int ut_run_list(struct unit_test_state *uts, const char *category, if (has_dm_tests) dm_test_restore(uts->of_root);
+ printf("Tests run: %d, ", uts->cur.test_count); if (uts->cur.skip_count) printf("Skipped: %d, ", uts->cur.skip_count); if (ret == -ENOENT)
Add a function to show the stats, so we can decide when to print it.
This slightly adjusts the output, so that any 'test not found' message appears on its own line after all other output.
The 'failures' message now appears in lower case so update pytest accordingly.
arch/sandbox/cpu/spl.c | 1 + include/test/ut.h | 8 ++++++++ test/py/tests/test_spl.py | 2 +- test/py/tests/test_upl.py | 2 +- test/py/tests/test_ut.py | 2 +- test/py/tests/test_vbe.py | 2 +- test/py/tests/test_vpl.py | 2 +- test/test-main.c | 14 +++++++++----- 8 files changed, 23 insertions(+), 10 deletions(-)
diff --git a/arch/sandbox/cpu/spl.c b/arch/sandbox/cpu/spl.c index 0ad23e4ba95..544ea8717eb 100644 --- a/arch/sandbox/cpu/spl.c +++ b/arch/sandbox/cpu/spl.c @@ -153,6 +153,7 @@ void spl_board_init(void) ut_init_state(&uts); ret = ut_run_list(&uts, "spl", NULL, tests, count, state->select_unittests, 1, false, NULL); + ut_report(&uts.cur, "Tests"); ut_uninit_state(&uts); /* continue execution into U-Boot */ } diff --git a/include/test/ut.h b/include/test/ut.h index a51defc3b90..55bb5aa2092 100644 --- a/include/test/ut.h +++ b/include/test/ut.h @@ -530,4 +530,12 @@ int ut_run_list(struct unit_test_state *uts, const char *category, const char *select_name, int runs_per_test, bool force_run, const char *test_insert);
+/** + * ut_report() - Report stats on a test run + * + * @stats: Stats to show + * @prefix: Name of this run type, e.g. "Tests" or "Total tests" + */ +void ut_report(struct ut_stats *stats, const char *prefix); + #endif diff --git a/test/py/tests/test_spl.py b/test/py/tests/test_spl.py index 42e4c4342b2..474f430a344 100644 --- a/test/py/tests/test_spl.py +++ b/test/py/tests/test_spl.py @@ -36,7 +36,7 @@ def test_spl(u_boot_console, ut_spl_subtest): cons = u_boot_console cons.restart_uboot_with_flags(['-u', '-k', ut_spl_subtest.split()[1]]) output = cons.get_spawn_output().replace('\r', '') - assert 'Failures: 0' in output + assert 'failures: 0' in output finally: # Restart afterward in case a non-SPL test is run next. This should not # happen since SPL tests are run in their own invocation of test.py, but diff --git a/test/py/tests/test_upl.py b/test/py/tests/test_upl.py index 3164bda6b71..d94359d8b9b 100644 --- a/test/py/tests/test_upl.py +++ b/test/py/tests/test_upl.py @@ -35,4 +35,4 @@ def test_upl_handoff(u_boot_console):
# Check the FIT offsets look correct output = cons.run_command('ut upl -f upl_test_info_norun') - assert 'Failures: 0' in output + assert 'failures: 0' in output diff --git a/test/py/tests/test_ut.py b/test/py/tests/test_ut.py index cacf11f7c0a..d2d8ce10755 100644 --- a/test/py/tests/test_ut.py +++ b/test/py/tests/test_ut.py @@ -607,4 +607,4 @@ def test_ut(u_boot_console, ut_subtest): assert 'Unknown command 'quux' - try 'help'' in output else: output = u_boot_console.run_command('ut ' + ut_subtest) - assert output.endswith('Failures: 0') + assert output.endswith('failures: 0') diff --git a/test/py/tests/test_vbe.py b/test/py/tests/test_vbe.py index 50b6c1cd911..861df3f8266 100644 --- a/test/py/tests/test_vbe.py +++ b/test/py/tests/test_vbe.py @@ -117,4 +117,4 @@ def test_vbe(u_boot_console): with cons.log.section('Kernel load'): output = cons.run_command_list(cmd.splitlines())
- assert 'Failures: 0' in output[-1] + assert 'failures: 0' in output[-1] diff --git a/test/py/tests/test_vpl.py b/test/py/tests/test_vpl.py index 4af578b9173..8c472ca7a92 100644 --- a/test/py/tests/test_vpl.py +++ b/test/py/tests/test_vpl.py @@ -26,7 +26,7 @@ def test_vpl(u_boot_console, ut_vpl_subtest): cons = u_boot_console cons.restart_uboot_with_flags(['-u', '-k', ut_vpl_subtest.split()[1]]) output = cons.get_spawn_output().replace('\r', '') - assert 'Failures: 0' in output + assert 'failures: 0' in output finally: # Restart afterward in case a non-VPL test is run next. This should not # happen since VPL tests are run in their own invocation of test.py, but diff --git a/test/test-main.c b/test/test-main.c index e36bc37d29e..a0a3f6086ef 100644 --- a/test/test-main.c +++ b/test/test-main.c @@ -673,6 +673,14 @@ static int ut_run_tests(struct unit_test_state *uts, const char *prefix, return uts->cur.fail_count ? -EBADF : 0; }
+void ut_report(struct ut_stats *stats, const char *prefix) +{ + printf("%s run: %d, ", prefix, stats->test_count); + if (stats->skip_count) + printf("skipped: %d, ", stats->skip_count); + printf("failures: %d\n", stats->fail_count); +} + int ut_run_list(struct unit_test_state *uts, const char *category, const char *prefix, struct unit_test *tests, int count, const char *select_name, int runs_per_test, bool force_run, @@ -718,13 +726,9 @@ int ut_run_list(struct unit_test_state *uts, const char *category, if (has_dm_tests) dm_test_restore(uts->of_root);
- printf("Tests run: %d, ", uts->cur.test_count); - if (uts->cur.skip_count) - printf("Skipped: %d, ", uts->cur.skip_count); + ut_report(&uts->cur, "Tests"); if (ret == -ENOENT) printf("Test '%s' not found\n", select_name); - else - printf("Failures: %d\n", uts->cur.fail_count);
return ret; }
With 'ut all' multiple test suites are run. Add a way to collect totals and show them at the end.
include/test/test.h | 3 +++ test/cmd_ut.c | 2 ++ test/test-main.c | 9 +++++++-- 3 files changed, 12 insertions(+), 2 deletions(-)
diff --git a/include/test/test.h b/include/test/test.h index f7087ab4eea..58023f6eafb 100644 --- a/include/test/test.h +++ b/include/test/test.h @@ -27,6 +27,7 @@ struct ut_stats { * struct unit_test_state - Entire state of test system * * @cur: Statistics for the current run + * @run_count: Number of times ut_run_list() has been called * @start: Store the starting mallinfo when doing leak test * @of_live: true to use livetree if available, false to use flattree * @of_root: Record of the livetree root node (used for setting up tests) @@ -48,6 +49,8 @@ struct ut_stats { */ struct unit_test_state { struct ut_stats cur; + struct ut_stats total; + int run_count; struct mallinfo start; struct device_node *of_root; bool of_live; diff --git a/test/cmd_ut.c b/test/cmd_ut.c index f315c442abf..f33918ddd00 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -206,6 +206,8 @@ static int do_ut_all(struct unit_test_state *uts, struct cmd_tbl *cmdtp, any_fail = retval; } } + if (uts->run_count > 1) + ut_report(&uts->total, "Total tests");
return any_fail; } diff --git a/test/test-main.c b/test/test-main.c index a0a3f6086ef..6010c24207c 100644 --- a/test/test-main.c +++ b/test/test-main.c @@ -690,6 +690,8 @@ int ut_run_list(struct unit_test_state *uts, const char *category, bool has_dm_tests = false; int ret;
+ memset(&uts->cur, '\0', sizeof(struct ut_stats)); + if (!CONFIG_IS_ENABLED(OF_PLATDATA) && ut_list_has_dm_tests(tests, count, prefix, select_name)) { has_dm_tests = true; @@ -727,8 +729,11 @@ int ut_run_list(struct unit_test_state *uts, const char *category, dm_test_restore(uts->of_root);
ut_report(&uts->cur, "Tests"); - if (ret == -ENOENT) - printf("Test '%s' not found\n", select_name); + + uts->total.skip_count += uts->cur.skip_count; + uts->total.fail_count += uts->cur.fail_count; + uts->total.test_count += uts->cur.test_count; + uts->run_count++;
return ret; }
Put the suites in order by name, for easier code-maintenance. This also helps find test results for a particular swuit in the 'ut all' output.
test/cmd_ut.c | 40 ++++++++++++++++++++-------------------- 1 file changed, 20 insertions(+), 20 deletions(-)
diff --git a/test/cmd_ut.c b/test/cmd_ut.c index f33918ddd00..3afab422e4a 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -90,7 +90,10 @@ int cmd_ut_category(struct unit_test_state *uts, const char *name, NULL, \ }
+SUITE_DECL(addrmap); SUITE_DECL(bdinfo); +SUITE_DECL(bloblist); +SUITE_DECL(bootm); SUITE_DECL(bootstd); SUITE_DECL(cmd); SUITE_DECL(common); @@ -99,25 +102,25 @@ SUITE_DECL(env); SUITE_DECL(exit); SUITE_DECL(fdt); SUITE_DECL(font); -SUITE_DECL(optee); -SUITE_DECL(overlay); +SUITE_DECL(hush); SUITE_DECL(lib); +SUITE_DECL(loadm); SUITE_DECL(log); SUITE_DECL(mbr); -SUITE_DECL(mem); -SUITE_DECL(setexpr); SUITE_DECL(measurement); -SUITE_DECL(bloblist); -SUITE_DECL(bootm); -SUITE_DECL(addrmap); -SUITE_DECL(hush); -SUITE_DECL(loadm); +SUITE_DECL(mem); +SUITE_DECL(optee); +SUITE_DECL(overlay); SUITE_DECL(pci_mps); SUITE_DECL(seama); +SUITE_DECL(setexpr); SUITE_DECL(upl);
static struct suite suites[] = { + SUITE(addrmap), SUITE(bdinfo), + SUITE(bloblist), + SUITE(bootm), #ifdef CONFIG_UT_BOOTSTD SUITE_CMD(bootstd, do_ut_bootstd), #endif @@ -128,25 +131,22 @@ static struct suite suites[] = { SUITE(exit), SUITE(fdt), SUITE(font), + SUITE(hush), + SUITE(lib), + SUITE(loadm), + SUITE(log), + SUITE(mbr), + SUITE(measurement), + SUITE(mem), #ifdef CONFIG_UT_OPTEE SUITE_CMD(optee, do_ut_optee), #endif #ifdef CONFIG_UT_OVERLAY SUITE_CMD(overlay, do_ut_overlay), #endif - SUITE(lib), - SUITE(log), - SUITE(mbr), - SUITE(mem), - SUITE(setexpr), - SUITE(measurement), - SUITE(bloblist), - SUITE(bootm), - SUITE(addrmap), - SUITE(hush), - SUITE(loadm), SUITE(pci_mps), SUITE(seama), + SUITE(setexpr), SUITE(upl), };
This fails at present, so disable it until it can pass.
test/py/tests/test_suite.py | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/test/py/tests/test_suite.py b/test/py/tests/test_suite.py index 1c248602199..d5d68502167 100644 --- a/test/py/tests/test_suite.py +++ b/test/py/tests/test_suite.py @@ -122,7 +122,8 @@ def process_ut_info(cons, output): @pytest.mark.buildconfigspec('sandbox') @pytest.mark.notbuildconfigspec('sandbox_spl') @pytest.mark.notbuildconfigspec('sandbox64') -def test_suite(u_boot_console, u_boot_config): +# This test is disabled since it fails; remove the leading 'x' to try it +def xtest_suite(u_boot_console, u_boot_config): """Perform various checks on the unit tests, including:
Rather than having the help in the longhelp, put it in the suite info so 'ut info -s' can show it. This is tidier, particular due to the removal of #ifdefs
This means that the help text is present in the image (although not displayed with 'ut info -s') so the image-size increases. But with UNIT_TEST enabled, we expect large images so this doesn't seem important.
test/cmd_ut.c | 127 ++++++++++++++++---------------------------------- 1 file changed, 40 insertions(+), 87 deletions(-)
diff --git a/test/cmd_ut.c b/test/cmd_ut.c index 3afab422e4a..76f481f509b 100644 --- a/test/cmd_ut.c +++ b/test/cmd_ut.c @@ -19,14 +19,16 @@ * * @name: Name of suite * @start: First test in suite - * end: End test in suite (points to the first test in the next suite - * cmd: Command to use to run the suite + * @end: End test in suite (points to the first test in the next suite + * @cmd: Command to use to run the suite + * @help: Help-string to show for this suite */ struct suite { const char *name; struct unit_test *start; struct unit_test *end; ut_cmd_func cmd; + const char *help; };
static int do_ut_all(struct unit_test_state *uts, struct cmd_tbl *cmdtp, @@ -75,19 +77,21 @@ int cmd_ut_category(struct unit_test_state *uts, const char *name, ll_end_decl(suite_end_ ## _name, struct unit_test, ut_ ## _name)
/* declare a test suite which uses a subcommand to run */ -#define SUITE_CMD(_name, _cmd_func) { \ +#define SUITE_CMD(_name, _cmd_func, _help) { \ #_name, \ suite_start_ ## _name, \ suite_end_ ## _name, \ _cmd_func, \ + _help, \ }
/* declare a test suite which can be run directly without a subcommand */ -#define SUITE(_name) { \ +#define SUITE(_name, _help) { \ #_name, \ suite_start_ ## _name, \ suite_end_ ## _name, \ NULL, \ + _help, \ }
SUITE_DECL(addrmap); @@ -117,37 +121,37 @@ SUITE_DECL(setexpr); SUITE_DECL(upl);
static struct suite suites[] = { - SUITE(addrmap), - SUITE(bdinfo), - SUITE(bloblist), - SUITE(bootm), + SUITE(addrmap, "very basic test of addrmap command"), + SUITE(bdinfo, "bdinfo (board info) command"), + SUITE(bloblist, "bloblist implementation"), + SUITE(bootm, "bootm command"), #ifdef CONFIG_UT_BOOTSTD - SUITE_CMD(bootstd, do_ut_bootstd), + SUITE_CMD(bootstd, do_ut_bootstd, "standard boot implementation"), #endif - SUITE(cmd), - SUITE(common), - SUITE(dm), - SUITE(env), - SUITE(exit), - SUITE(fdt), - SUITE(font), - SUITE(hush), - SUITE(lib), - SUITE(loadm), - SUITE(log), - SUITE(mbr), - SUITE(measurement), - SUITE(mem), + SUITE(cmd, "various commands"), + SUITE(common, "tests for common/ directory"), + SUITE(dm, "driver model"), + SUITE(env, "environment"), + SUITE(exit, "shell exit and variables"), + SUITE(fdt, "fdt command"), + SUITE(font, "font command"), + SUITE(hush, "hush behaviour"), + SUITE(lib, "library functions"), + SUITE(loadm, "loadm command parameters and loading memory blob"), + SUITE(log, "logging functions"), + SUITE(mbr, "mbr command"), + SUITE(measurement, "TPM-based measured boot"), + SUITE(mem, "memory-related commands"), #ifdef CONFIG_UT_OPTEE - SUITE_CMD(optee, do_ut_optee), + SUITE_CMD(optee, do_ut_optee, "OP-TEE"), #endif #ifdef CONFIG_UT_OVERLAY - SUITE_CMD(overlay, do_ut_overlay), + SUITE_CMD(overlay, do_ut_overlay, "device tree overlays"), #endif - SUITE(pci_mps), - SUITE(seama), - SUITE(setexpr), - SUITE(upl), + SUITE(pci_mps, "PCI Express Maximum Payload Size"), + SUITE(seama, "seama command parameters loading and decoding"), + SUITE(setexpr, "setexpr command"), + SUITE(upl, "Universal payload support"), };
/** @@ -232,16 +236,19 @@ static int do_ut_info(struct cmd_tbl *cmdtp, int flag, int argc, if (flags && !strcmp("-s", flags)) { int i;
- puts("\nTests Suite\n"); - puts("----- -----\n"); + puts("\nTests Suite Purpose"); + puts("\n----- ------------ -------------------------\n"); for (i = 0; i < ARRAY_SIZE(suites); i++) { struct suite *ste = &suites[i]; long n_ent = ste->end - ste->start;
if (n_ent) - printf("%5ld %s\n", n_ent, ste->name); + printf("%5ld", n_ent); else if (ste->cmd) - printf("%5s %s\n", "?", ste->name); + printf("%5s", "?"); + else /* suite is not present */ + continue; + printf(" %-13.13s %s\n", ste->name, ste->help); } }
@@ -306,60 +313,6 @@ U_BOOT_LONGHELP(ut, "\nOptions for <suite>:" "\nall - execute all enabled tests" "\ninfo [-s] - show info about tests [and suites]" -#ifdef CONFIG_CMD_ADDRMAP - "\naddrmap - very basic test of addrmap command" -#endif -#ifdef CONFIG_CMD_BDI - "\nbdinfo - bdinfo command" -#endif -#ifdef CONFIG_SANDBOX - "\nbloblist - bloblist implementation" -#endif -#ifdef CONFIG_BOOTSTD - "\nbootstd - standard boot implementation" -#endif -#ifdef CONFIG_CMDLINE - "\ncmd - test various commands" -#endif - "\ncommon - tests for common/ directory" -#ifdef CONFIG_UT_DM - "\ndm - driver model" -#endif -#ifdef CONFIG_UT_ENV - "\nenv - environment" -#endif -#ifdef CONFIG_CMD_FDT - "\nfdt - fdt command" -#endif -#ifdef CONFIG_CONSOLE_TRUETYPE - "\nfont - font command" -#endif -#if CONFIG_IS_ENABLED(HUSH_PARSER) - "\nhush - Test hush behavior" -#endif -#ifdef CONFIG_CMD_LOADM - "\nloadm - loadm command parameters and loading memory blob" -#endif -#ifdef CONFIG_UT_LIB - "\nlib - library functions" -#endif -#ifdef CONFIG_UT_LOG - "\nlog - logging functions" -#endif - "\nmem - memory-related commands" -#ifdef CONFIG_UT_OPTEE - "\noptee - test OP-TEE" -#endif -#ifdef CONFIG_UT_OVERLAY - "\noverlay - device tree overlays" -#endif -#ifdef CONFIG_CMD_PCI_MPS - "\npci_mps - PCI Express Maximum Payload Size" -#endif - "\nsetexpr - setexpr command" -#ifdef CONFIG_CMD_SEAMA - "\nseama - seama command parameters loading and decoding" -#endif );
U_BOOT_CMD(
On 15.01.25 14:30, Simon Glass wrote:
The current method of running unit tests relies on subcommands of the ut command. Only the code in each subcommand knows how to find the tests related to that subcomand.
This is not ideal and we now have quite a few subcommands which do nothing but locate the relevant tests in a linker list, then call a common function to run them.
This series adds a list of test suites, so that these subcommands can be removed.
An issue with 'ut all' is that it doesn't record how many tests failed overall, so it is necessary to examine copious amounts of output to look for failures. This series adds a new 'total' feature allow recording the total number of failed tests.
To help with 'ut all' a new pytest is created which runs it (as well as 'ut info') and makes sure that all is well. Due to the 'ut all' failures this does not pass, so the test is disabled for now. It is here because it provides security against misnaming a test suite and causing it not to run.
Future work may:
- get 'ut all' passing
- enable test_suite() in CL, to ensure that 'ut all' keeps passing
- record duration of each suite
- allow running the tests in random order to tease out dependencies
- tweak the output to remove common prefixes
- getting rid of bootstd, optee and seame 'ut' subcommands
Am I missing a patch for doc/ or will the usage of the ut command remain unchanged?
How would you specify a test suite like 'lib' in future? How would you specify running all tests in future?
Best regards
Heinrich
Simon Glass (43): test: Drop unused suite prototypes test: Rename test_get_state() to ut_get_state() test: Add functions to init and uninit the test state test: Pass the test-state into ut_run_list() Improve support for linker lists in data structures test: Add newlines to hush-test messages test: Rename test suites to match their linker-list name test: Update ut info to show suites test/py: Add a test which runs all unit tests test: Drop the _test suffix on linker lists test: Introduce a better array of test suites test: Drop the function for running bdinfo tests test: Drop the function for running cmd tests test: Drop the function for running common tests test: Drop the function for running dm tests test: Drop the function for running env tests test: Drop the function for running exit tests test: Drop the function for running fdt tests test: Drop the function for running font tests test: Drop the function for running lib tests test: Drop the function for running log tests test: Drop the function for running mbr tests test: Drop the function for running mem tests test: Drop the function for running setexpr tests test: Drop the function for running measurement tests test: Drop the function for running bloblist tests test: Drop the function for running bootm tests test: Drop the function for running addrmap tests test: Drop the function for running hush tests test: Drop the function for running loadm tests test: Drop the function for running pci_mps tests test: Drop the function for running seama tests test: Drop the function for running upl tests test: Drop the info test from the list test: Drop conditional compilation for suites test: Pass the test state to cmd_ut_category() test: Move stats into a struct test: Keep a track of the numbers of tests run test: Move stat-printing into its own function test: Record and show the totals for all test runs test: Sort the test suites test: Disable test_suite test: Move help into the suite declaration
arch/sandbox/cpu/spl.c | 6 +- include/dm/test.h | 2 +- include/linker_lists.h | 51 +++++ include/test/cmd.h | 2 +- include/test/common.h | 2 +- include/test/env.h | 2 +- include/test/hush.h | 2 +- include/test/lib.h | 2 +- include/test/log.h | 4 +- include/test/optee.h | 2 +- include/test/overlay.h | 2 +- include/test/suites.h | 53 ++--- include/test/test.h | 23 ++- include/test/ut.h | 45 ++++- test/boot/bootm.c | 11 +- test/boot/bootstd_common.c | 9 +- test/boot/bootstd_common.h | 3 +- test/boot/measurement.c | 12 +- test/boot/upl.c | 11 +- test/cmd/Makefile | 4 +- test/cmd/addrmap.c | 11 +- test/cmd/bdinfo.c | 10 +- test/cmd/cmd_ut_cmd.c | 20 -- test/cmd/exit.c | 11 +- test/cmd/fdt.c | 10 +- test/cmd/font.c | 10 +- test/cmd/loadm.c | 11 +- test/cmd/mbr.c | 10 +- test/cmd/mem.c | 19 -- test/cmd/mem_copy.c | 2 +- test/cmd/mem_search.c | 2 +- test/cmd/pci_mps.c | 12 +- test/cmd/seama.c | 11 +- test/cmd/setexpr.c | 11 +- test/cmd_ut.c | 361 +++++++++++++++++++++------------- test/common/Makefile | 1 - test/common/bloblist.c | 12 +- test/common/cmd_ut_common.c | 21 -- test/dm/Makefile | 2 - test/dm/test-dm.c | 16 -- test/dm/test-driver.c | 10 +- test/dm/test-uclass.c | 8 +- test/env/cmd_ut_env.c | 10 - test/hush/Makefile | 1 - test/hush/cmd_ut_hush.c | 19 -- test/hush/dollar.c | 7 +- test/hush/loop.c | 4 +- test/lib/Makefile | 1 - test/lib/cmd_ut_lib.c | 19 -- test/log/Makefile | 2 - test/log/log_ut.c | 20 -- test/optee/cmd_ut_optee.c | 4 +- test/overlay/cmd_ut_overlay.c | 14 +- test/py/conftest.py | 7 +- test/py/tests/test_spl.py | 2 +- test/py/tests/test_suite.py | 182 +++++++++++++++++ test/py/tests/test_upl.py | 2 +- test/py/tests/test_ut.py | 2 +- test/py/tests/test_vbe.py | 2 +- test/py/tests/test_vpl.py | 2 +- test/test-main.c | 104 ++++++---- test/ut.c | 4 +- 62 files changed, 657 insertions(+), 580 deletions(-) delete mode 100644 test/cmd/cmd_ut_cmd.c delete mode 100644 test/cmd/mem.c delete mode 100644 test/common/cmd_ut_common.c delete mode 100644 test/dm/test-dm.c delete mode 100644 test/hush/cmd_ut_hush.c delete mode 100644 test/lib/cmd_ut_lib.c delete mode 100644 test/log/log_ut.c create mode 100644 test/py/tests/test_suite.py
Hi Heinrich,
Future work may:
No change to the command, but the output changes, so I can add an update to the 'examples' section.
LIB_TEST(...)
If you want to create a new one, you need to add it to the list in cmd_ut.c as now. But it is now in a new format which is easier to maintain.
'ut -a' as now
Hi Simon,
Thank you for the series.
I wanted to test this, but it seems it does not apply on both master or next:
With master: 178f6ecb21fe ("Merge patch series "bootstd: Support recording images"") With next: d6da3dbaef57 ("Merge patch series "cmd: Add support for optee commands."")
When running: $ b4 shazam -s -l --check 20250115133114.590375-1-sjg@chromium.org
I see:
""" [...] snip
Total patches: 43 --- Applying: test: Drop unused suite prototypes Applying: test: Rename test_get_state() to ut_get_state() Applying: test: Add functions to init and uninit the test state Applying: test: Pass the test-state into ut_run_list() Applying: Improve support for linker lists in data structures Applying: test: Add newlines to hush-test messages Applying: test: Rename test suites to match their linker-list name Applying: test: Update ut info to show suites Applying: test/py: Add a test which runs all unit tests Applying: test: Drop the _test suffix on linker lists Applying: test: Introduce a better array of test suites Patch failed at 0011 test: Introduce a better array of test suites error: sha1 information is lacking or useless (test/cmd_ut.c). error: could not build fake ancestor hint: Use 'git am --show-current-patch=diff' to see the failed patch hint: When you have resolved this problem, run "git am --continue". hint: If you prefer to skip this patch, run "git am --skip" instead. hint: To restore the original branch and stop patching, run "git am --abort". """
On what base should this be applied if we want to test this? Sorry if this is a sily question, usually I get dependencies from the cover letter but I could not find any here.
Future work may:
-- 2.34.1
Hi Mattijs,
On Thu, 16 Jan 2025 at 02:47, Mattijs Korpershoek mkorpershoek@baylibre.com wrote:
Hi Simon,
I see:
""" [...] snip
Total patches: 43
Yes, it is supposed to be based on -next but there are two patches in -next but not in the tree I used:
90856d695f2 test: sandbox: fix link error with do_ut_bootm if BLOBLIST=n 6970eeb7885 test: sandbox: fix link error with do_ut_bloblist if BLOBLIST=n
The series is available at sjg.u-boot.org/u-boot/u-boot/-/tree/tes?ref_type=heads
I'll sort this out when I send v2, but will wait for some more feedback.
Regards, SImon
Mattijs Korpershoek
