[PATCH 1/1] efi_loader: use correct printf codes
For printing u32 use %u not %d.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_esrt.c | 14 +++++++------- 1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/lib/efi_loader/efi_esrt.c b/lib/efi_loader/efi_esrt.c index 8815e56e15..a750164bc4 100644 --- a/lib/efi_loader/efi_esrt.c +++ b/lib/efi_loader/efi_esrt.c @@ -120,8 +120,8 @@ efi_status_t efi_esrt_allocate_install(u32 num_entries) (void **)&new_esrt);
if (ret != EFI_SUCCESS) { - EFI_PRINT("ESRT cannot allocate memory for %d entries (%d bytes)\n", - num_entries, efi_esrt_entries_to_size(num_entries)); + EFI_PRINT("ESRT cannot allocate memory for %u entries (%u bytes)\n", + num_entries, size);
return ret; } @@ -180,7 +180,7 @@ struct efi_system_resource_entry *esrt_find_entry(efi_guid_t *img_fw_class) /* Check if the image with img_fw_class is already in the ESRT. */ for (u32 idx = 0; idx < filled_entries; idx++) { if (!guidcmp(&entry[idx].fw_class, img_fw_class)) { - EFI_PRINT("ESRT found entry for image %pUl at index %d\n", + EFI_PRINT("ESRT found entry for image %pUl at index %u\n", img_fw_class, idx); return &entry[idx]; } @@ -202,7 +202,7 @@ struct efi_system_resource_entry *esrt_find_entry(efi_guid_t *img_fw_class) */ esrt->fw_resource_count++; entry[filled_entries].fw_class = *img_fw_class; - EFI_PRINT("ESRT allocated new entry for image %pUl at index %d\n", + EFI_PRINT("ESRT allocated new entry for image %pUl at index %u\n", img_fw_class, filled_entries);
return &entry[filled_entries]; @@ -363,7 +363,7 @@ efi_status_t efi_esrt_populate(void) &handler);
if (ret != EFI_SUCCESS) { - EFI_PRINT("ESRT Unable to find FMP handle (%d)\n", + EFI_PRINT("ESRT Unable to find FMP handle (%u)\n", idx); goto out; } @@ -414,7 +414,7 @@ efi_status_t efi_esrt_populate(void) EFI_CALL(efi_free_pool(img_info)); }
- EFI_PRINT("ESRT create table with %d entries\n", num_entries); + EFI_PRINT("ESRT create table with %u entries\n", num_entries); /* * Allocate an ESRT with the sufficient number of entries to accommodate * all the FMPs in the system. @@ -435,7 +435,7 @@ efi_status_t efi_esrt_populate(void) &handler));
if (ret != EFI_SUCCESS) { - EFI_PRINT("ESRT unable to find FMP handle (%d)\n", + EFI_PRINT("ESRT unable to find FMP handle (%u)\n", idx); break; } -- 2.30.2
