[U-Boot] [PATCH] nios2: export fdt_blob to the environment variable
Export fdt_blob to the environment variable. So that we may use it to boot Linux.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- arch/nios2/lib/Makefile | 1 + arch/nios2/lib/misc.c | 16 ++++++++++++++++ include/configs/nios2-generic.h | 1 + 3 files changed, 18 insertions(+) create mode 100644 arch/nios2/lib/misc.c
diff --git a/arch/nios2/lib/Makefile b/arch/nios2/lib/Makefile index e35d2e9..05deea4 100644 --- a/arch/nios2/lib/Makefile +++ b/arch/nios2/lib/Makefile @@ -8,3 +8,4 @@ obj-y += cache.o obj-$(CONFIG_CMD_BOOTM) += bootm.o obj-y += libgcc.o +obj-y += misc.o diff --git a/arch/nios2/lib/misc.c b/arch/nios2/lib/misc.c new file mode 100644 index 0000000..2cf8574 --- /dev/null +++ b/arch/nios2/lib/misc.c @@ -0,0 +1,16 @@ +/* + * Copyright (C) 2015 Thomas Chou thomas@wytron.com.tw + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> + +DECLARE_GLOBAL_DATA_PTR; + +int misc_init_r(void) +{ + setenv_addr("fdt_blob", gd->fdt_blob); + + return 0; +} diff --git a/include/configs/nios2-generic.h b/include/configs/nios2-generic.h index e4b5abb..14ab37f 100644 --- a/include/configs/nios2-generic.h +++ b/include/configs/nios2-generic.h @@ -15,6 +15,7 @@ #include "../board/altera/nios2-generic/custom_fpga.h" /* fpga parameters */ #define CONFIG_BOARD_NAME "nios2-generic" /* custom board name */ #define CONFIG_BOARD_EARLY_INIT_F /* enable early board-spec. init */ +#define CONFIG_MISC_INIT_R #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO_LATE #define CONFIG_SYS_NIOS_SYSID_BASE CONFIG_SYS_SYSID_BASE
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- v2 move the code to per board, nios2-generic.c.
board/altera/nios2-generic/nios2-generic.c | 9 +++++++++ include/configs/nios2-generic.h | 1 + 2 files changed, 10 insertions(+)
diff --git a/board/altera/nios2-generic/nios2-generic.c b/board/altera/nios2-generic/nios2-generic.c index e7fecd2..f508c00 100644 --- a/board/altera/nios2-generic/nios2-generic.c +++ b/board/altera/nios2-generic/nios2-generic.c @@ -14,6 +14,8 @@ #include <asm/io.h> #include <asm/gpio.h>
+DECLARE_GLOBAL_DATA_PTR; + #if defined(CONFIG_ENV_IS_IN_FLASH) && defined(CONFIG_ENV_ADDR) && \ defined(CONFIG_CFI_FLASH_MTD) static void __early_flash_cmd_reset(void) @@ -35,6 +37,13 @@ int board_early_init_f(void) return 0; }
+int misc_init_r(void) +{ + setenv_addr("fdt_blob", gd->fdt_blob); + + return 0; +} + int checkboard(void) { #ifdef CONFIG_ALTERA_SYSID diff --git a/include/configs/nios2-generic.h b/include/configs/nios2-generic.h index e4b5abb..14ab37f 100644 --- a/include/configs/nios2-generic.h +++ b/include/configs/nios2-generic.h @@ -15,6 +15,7 @@ #include "../board/altera/nios2-generic/custom_fpga.h" /* fpga parameters */ #define CONFIG_BOARD_NAME "nios2-generic" /* custom board name */ #define CONFIG_BOARD_EARLY_INIT_F /* enable early board-spec. init */ +#define CONFIG_MISC_INIT_R #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO_LATE #define CONFIG_SYS_NIOS_SYSID_BASE CONFIG_SYS_SYSID_BASE
- setenv_addr("fdt_blob", gd->fdt_blob);
Shouldn't this go into generic code ?
Best regards, Marek Vasut
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- v2 move the code to per board, nios2-generic.c. v3 move the code to generic, board_r.c.
common/board_r.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/common/board_r.c b/common/board_r.c index a4facf8..6f10a31 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -449,6 +449,7 @@ static int initr_env(void) env_relocate(); else set_default_env(NULL); + setenv_addr("fdt_blob", gd->fdt_blob);
/* Initialize from environment */ load_addr = getenv_ulong("loadaddr", 16, load_addr);
setenv_addr("fdt_blob", gd->fdt_blob); /* Initialize from environment */ load_addr = getenv_ulong("loadaddr", 16, load_addr);
-- 2.1.4
We already have fdtcontroladdr, so how about using that instead?
Also please can you add docs to README.fdt-control? Also note that it is read-only and cannot be changed. In fact changing it will be ignored.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- v2 move the code to per board, nios2-generic.c. v3 move the code to generic, board_r.c. v4 use fdtcontroladdr as Simon suggested.
common/board_r.c | 3 +++ doc/README.fdt-control | 5 ++++- 2 files changed, 7 insertions(+), 1 deletion(-)
diff --git a/common/board_r.c b/common/board_r.c index a4facf8..d722081 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -449,6 +449,9 @@ static int initr_env(void) env_relocate(); else set_default_env(NULL); +#ifdef CONFIG_OF_CONTROL + setenv_addr("fdtcontroladdr", gd->fdt_blob); +#endif
/* Initialize from environment */ load_addr = getenv_ulong("loadaddr", 16, load_addr); diff --git a/doc/README.fdt-control b/doc/README.fdt-control index e6d5ed0..29fd56a 100644 --- a/doc/README.fdt-control +++ b/doc/README.fdt-control @@ -156,7 +156,10 @@ address of the fdt binary blob, and will override either of the options. Be aware that this environment variable is checked prior to relocation, when only the compiled-in environment is available. Therefore it is not possible to define this variable in the saved SPI/NAND flash -environment, for example (it will be ignored). +environment, for example (it will be ignored). After relocation, this +variable will be set to the address of the newly relocated fdt blob. +It is read-only and cannot be changed. It can optionally be used to +control the boot process of Linux with bootm/bootz commands.
To use this, put something like this in your board header file:
Applied to u-boot-dm, thanks!
Thomas Chou
