[PATCH v2 1/2] usb: host: ehci-generic: Make usage of clock/reset bulk() API
Make usage of clock and reset bulk API in order to simplify the code
Signed-off-by: Patrice Chotard patrice.chotard@foss.st.com ---
Changes in v2: - add the error code in all dev_err() output.
drivers/usb/host/ehci-generic.c | 103 ++++++++++---------------------- 1 file changed, 32 insertions(+), 71 deletions(-)
diff --git a/drivers/usb/host/ehci-generic.c b/drivers/usb/host/ehci-generic.c index 4c28a69b98..8760169035 100644 --- a/drivers/usb/host/ehci-generic.c +++ b/drivers/usb/host/ehci-generic.c @@ -23,14 +23,12 @@ */ struct generic_ehci { struct ehci_ctrl ctrl; - struct clk *clocks; - struct reset_ctl *resets; + struct clk_bulk clocks; + struct reset_ctl_bulk resets; struct phy phy; #ifdef CONFIG_DM_REGULATOR struct udevice *vbus_supply; #endif - int clock_count; - int reset_count; };
#ifdef CONFIG_DM_REGULATOR @@ -47,7 +45,7 @@ static int ehci_enable_vbus_supply(struct udevice *dev) if (priv->vbus_supply) { ret = regulator_set_enable(priv->vbus_supply, true); if (ret) { - dev_err(dev, "Error enabling VBUS supply\n"); + dev_err(dev, "Error enabling VBUS supply (ret=%d)\n", ret); return ret; } } else { @@ -81,68 +79,31 @@ static int ehci_usb_probe(struct udevice *dev) struct generic_ehci *priv = dev_get_priv(dev); struct ehci_hccr *hccr; struct ehci_hcor *hcor; - int i, err, ret, clock_nb, reset_nb; + int err, ret;
err = 0; - priv->clock_count = 0; - clock_nb = ofnode_count_phandle_with_args(dev_ofnode(dev), "clocks", - "#clock-cells", 0); - if (clock_nb > 0) { - priv->clocks = devm_kcalloc(dev, clock_nb, sizeof(struct clk), - GFP_KERNEL); - if (!priv->clocks) - return -ENOMEM; - - for (i = 0; i < clock_nb; i++) { - err = clk_get_by_index(dev, i, &priv->clocks[i]); - - if (err < 0) - break; - err = clk_enable(&priv->clocks[i]); - if (err && err != -ENOSYS) { - dev_err(dev, "failed to enable clock %d\n", i); - clk_free(&priv->clocks[i]); - goto clk_err; - } - priv->clock_count++; - } - } else { - if (clock_nb != -ENOENT) { - dev_err(dev, "failed to get clock phandle(%d)\n", - clock_nb); - return clock_nb; - } + ret = clk_get_bulk(dev, &priv->clocks); + if (ret) { + dev_err(dev, "Failed to get clocks (ret=%d)\n", ret); + return ret; }
- priv->reset_count = 0; - reset_nb = ofnode_count_phandle_with_args(dev_ofnode(dev), "resets", - "#reset-cells", 0); - if (reset_nb > 0) { - priv->resets = devm_kcalloc(dev, reset_nb, - sizeof(struct reset_ctl), - GFP_KERNEL); - if (!priv->resets) - return -ENOMEM; - - for (i = 0; i < reset_nb; i++) { - err = reset_get_by_index(dev, i, &priv->resets[i]); - if (err < 0) - break; - - if (reset_deassert(&priv->resets[i])) { - dev_err(dev, "failed to deassert reset %d\n", - i); - reset_free(&priv->resets[i]); - goto reset_err; - } - priv->reset_count++; - } - } else { - if (reset_nb != -ENOENT) { - dev_err(dev, "failed to get reset phandle(%d)\n", - reset_nb); - goto clk_err; - } + err = clk_enable_bulk(&priv->clocks); + if (err) { + dev_err(dev, "Failed to enable clocks (err=%d)\n", err); + goto clk_err; + } + + err = reset_get_bulk(dev, &priv->resets); + if (err) { + dev_err(dev, "Failed to get resets (err=%d)\n", err); + goto clk_err; + } + + err = reset_deassert_bulk(&priv->resets); + if (err) { + dev_err(dev, "Failed to get deassert resets (err=%d)\n", err); + goto reset_err; }
err = ehci_enable_vbus_supply(dev); @@ -166,21 +127,21 @@ static int ehci_usb_probe(struct udevice *dev) phy_err: ret = ehci_shutdown_phy(dev, &priv->phy); if (ret) - dev_err(dev, "failed to shutdown usb phy\n"); + dev_err(dev, "failed to shutdown usb phy (ret=%d)\n", ret);
regulator_err: ret = ehci_disable_vbus_supply(priv); if (ret) - dev_err(dev, "failed to disable VBUS supply\n"); + dev_err(dev, "failed to disable VBUS supply (ret=%d)\n", ret);
reset_err: - ret = reset_release_all(priv->resets, priv->reset_count); + ret = reset_release_bulk(&priv->resets); if (ret) - dev_err(dev, "failed to assert all resets\n"); + dev_err(dev, "failed to release resets (ret=%d)\n", ret); clk_err: - ret = clk_release_all(priv->clocks, priv->clock_count); + ret = clk_release_bulk(&priv->clocks); if (ret) - dev_err(dev, "failed to disable all clocks\n"); + dev_err(dev, "failed to release clocks (ret=%d)\n", ret);
return err; } @@ -202,11 +163,11 @@ static int ehci_usb_remove(struct udevice *dev) if (ret) return ret;
- ret = reset_release_all(priv->resets, priv->reset_count); + ret = reset_release_bulk(&priv->resets); if (ret) return ret;
- return clk_release_all(priv->clocks, priv->clock_count); + return clk_release_bulk(&priv->clocks); }
static const struct udevice_id ehci_usb_ids[] = {
Since commit 16cc5ad0b439 ("power: regulator: add dummy helper") regulator dummy helper are always available even if DM_REGULATOR is not set. DM_REGULATOR flag is no more needed to protect no DM core, remove it.
Changes in v2: - update commit message
drivers/usb/host/ehci-generic.c | 14 -------------- 1 file changed, 14 deletions(-)
diff --git a/drivers/usb/host/ehci-generic.c b/drivers/usb/host/ehci-generic.c index 8760169035..4734af0396 100644 --- a/drivers/usb/host/ehci-generic.c +++ b/drivers/usb/host/ehci-generic.c @@ -26,12 +26,9 @@ struct generic_ehci { struct clk_bulk clocks; struct reset_ctl_bulk resets; struct phy phy; -#ifdef CONFIG_DM_REGULATOR struct udevice *vbus_supply; -#endif };
-#ifdef CONFIG_DM_REGULATOR static int ehci_enable_vbus_supply(struct udevice *dev) { struct generic_ehci *priv = dev_get_priv(dev); @@ -62,17 +59,6 @@ static int ehci_disable_vbus_supply(struct generic_ehci *priv) else return 0; } -#else -static int ehci_enable_vbus_supply(struct udevice *dev) -{ - return 0; -} - -static int ehci_disable_vbus_supply(struct generic_ehci *priv) -{ - return 0; -} -#endif
static int ehci_usb_probe(struct udevice *dev) {
Changes in v2:
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Thanks Patrick
Changes in v2:
Thanks Patrick
Patrice Chotard
Patrick DELAUNAY
