[U-Boot] [PATCH 1/6] powerpc/mpc8xxx: Add immap for topology and rcpm registers
Signed-off-by: Kumar Gala galak@kernel.crashing.org Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/include/asm/immap_85xx.h | 88 ++++++++++++++++++++++++++++++++- 1 files changed, 87 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 5a20a52..163f08d 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1848,7 +1848,13 @@ typedef struct ccsr_gur { u8 res31[184]; u32 sriopstecr; /* SRIO prescaler timer enable control */ u32 dcsrcr; /* DCSR Control register */ - u8 res32[1784]; + u8 res31a[56]; + u32 tp_ityp[64]; /* Topology Initiator Type Register */ + struct { + u32 upper; + u32 lower; + } tp_cluster[16]; /* Core Cluster n Topology Register */ + u8 res32[1344]; u32 pmuxcr; /* Pin multiplexing control */ u8 res33[60]; u32 iovselsr; /* I/O voltage selection status */ @@ -1861,6 +1867,18 @@ typedef struct ccsr_gur { u8 res37[380]; } ccsr_gur_t;
+#define TP_ITYP_AV 0x00000001 /* Initiator available */ +#define TP_ITYP_TYPE(x) (((x) & 0x6) >> 1) /* Initiator Type */ +#define TP_ITYP_TYPE_OTHER 0x0 +#define TP_ITYP_TYPE_PPC 0x1 /* PowerPC */ +#define TP_ITYP_TYPE_SC 0x2 /* StarCore DSP */ +#define TP_ITYP_TYPE_HA 0x3 /* HW Accelerator */ +#define TP_ITYP_THDS(x) (((x) & 0x18) >> 3) /* # threads */ +#define TP_ITYP_VER(x) (((x) & 0xe0) >> 5) /* Initiator Version */ + +#define TP_CLUSTER_EOC 0x80000000 /* end of clusters */ +#define TP_CLUSTER_INIT_MASK 0x0000003f /* initiator mask */ + #define FSL_CORENET_DCSR_SZ_MASK 0x00000003 #define FSL_CORENET_DCSR_SZ_4M 0x0 #define FSL_CORENET_DCSR_SZ_1G 0x3 @@ -1902,6 +1920,73 @@ typedef struct ccsr_clk { u8 res15[0x3dc]; } ccsr_clk_t;
+#ifdef CONFIG_SYS_FSL_QORIQ_CHASSIS2 +typedef struct ccsr_rcpm { + u8 res_00[12]; + u32 tph10sr0; /* Thread PH10 Status Register */ + u8 res_10[12]; + u32 tph10setr0; /* Thread PH10 Set Control Register */ + u8 res_20[12]; + u32 tph10clrr0; /* Thread PH10 Clear Control Register */ + u8 res_30[12]; + u32 tph10psr0; /* Thread PH10 Previous Status Register */ + u8 res_40[12]; + u32 twaitsr0; /* Thread Wait Status Register */ + u8 res_50[96]; + u32 pcph15sr; /* Physical Core PH15 Status Register */ + u32 pcph15setr; /* Physical Core PH15 Set Control Register */ + u32 pcph15clrr; /* Physical Core PH15 Clear Control Register */ + u32 pcph15psr; /* Physical Core PH15 Prev Status Register */ + u8 res_c0[16]; + u32 pcph20sr; /* Physical Core PH20 Status Register */ + u32 pcph20setr; /* Physical Core PH20 Set Control Register */ + u32 pcph20clrr; /* Physical Core PH20 Clear Control Register */ + u32 pcph20psr; /* Physical Core PH20 Prev Status Register */ + u32 pcpw20sr; /* Physical Core PW20 Status Register */ + u8 res_e0[12]; + u32 pcph30sr; /* Physical Core PH30 Status Register */ + u32 pcph30setr; /* Physical Core PH30 Set Control Register */ + u32 pcph30clrr; /* Physical Core PH30 Clear Control Register */ + u32 pcph30psr; /* Physical Core PH30 Prev Status Register */ + u8 res_100[32]; + u32 ippwrgatecr; /* IP Power Gating Control Register */ + u8 res_124[12]; + u32 powmgtcsr; /* Power Management Control & Status Reg */ + u8 res_134[12]; + u32 ippdexpcr[4]; /* IP Powerdown Exception Control Reg */ + u8 res_150[12]; + u32 tpmimr0; /* Thread PM Interrupt Mask Reg */ + u8 res_160[12]; + u32 tpmcimr0; /* Thread PM Crit Interrupt Mask Reg */ + u8 res_170[12]; + u32 tpmmcmr0; /* Thread PM Machine Check Interrupt Mask Reg */ + u8 res_180[12]; + u32 tpmnmimr0; /* Thread PM NMI Mask Reg */ + u8 res_190[12]; + u32 tmcpmaskcr0; /* Thread Machine Check Mask Control Reg */ + u32 pctbenr; /* Physical Core Time Base Enable Reg */ + u32 pctbclkselr; /* Physical Core Time Base Clock Select */ + u32 tbclkdivr; /* Time Base Clock Divider Register */ + u8 res_1ac[4]; + u32 ttbhltcr[4]; /* Thread Time Base Halt Control Register */ + u32 clpcl10sr; /* Cluster PCL10 Status Register */ + u32 clpcl10setr; /* Cluster PCL30 Set Control Register */ + u32 clpcl10clrr; /* Cluster PCL30 Clear Control Register */ + u32 clpcl10psr; /* Cluster PCL30 Prev Status Register */ + u32 cddslpsetr; /* Core Domain Deep Sleep Set Register */ + u32 cddslpclrr; /* Core Domain Deep Sleep Clear Register */ + u32 cdpwroksetr; /* Core Domain Power OK Set Register */ + u32 cdpwrokclrr; /* Core Domain Power OK Clear Register */ + u32 cdpwrensr; /* Core Domain Power Enable Status Register */ + u32 cddslsr; /* Core Domain Deep Sleep Status Register */ + u8 res_1e8[8]; + u32 dslpcntcr[8]; /* Deep Sleep Counter Cfg Register */ + u8 res_300[3568]; +} ccsr_rcpm_t; + +#define ctbenrl pctbenr + +#else typedef struct ccsr_rcpm { u8 res1[4]; u32 cdozsrl; /* Core Doze Status */ @@ -1938,6 +2023,7 @@ typedef struct ccsr_rcpm { u32 ctbhltcrl; /* Core Time Base Halt Control */ u8 res18[0xf68]; } ccsr_rcpm_t; +#endif /* CONFIG_SYS_FSL_QORIQ_CHASSIS2 */
#else typedef struct ccsr_gur {
We have actual topology infomation to find out exactly which core is present. Calculate the number of cores if not specified.
Signed-off-by: Kumar Gala galak@kernel.crashing.org Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc8xxx/cpu.c | 65 +++++++++++++++++++++++++++++----- arch/powerpc/include/asm/processor.h | 1 + arch/powerpc/lib/board.c | 13 +++++++ 3 files changed, 70 insertions(+), 9 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/cpu.c b/arch/powerpc/cpu/mpc8xxx/cpu.c index bb50f68..7821423 100644 --- a/arch/powerpc/cpu/mpc8xxx/cpu.c +++ b/arch/powerpc/cpu/mpc8xxx/cpu.c @@ -85,7 +85,39 @@ struct cpu_type cpu_type_list [] = { #endif };
-struct cpu_type cpu_type_unknown = CPU_TYPE_ENTRY(Unknown, Unknown, 1); +#ifdef CONFIG_SYS_FSL_QORIQ_CHASSIS2 +u32 compute_ppc_cpumask(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + int i = 0, count = 0; + u32 cluster, mask = 0; + + do { + int j; + cluster = in_be32(&gur->tp_cluster[i++].lower); + for (j = 0; j < 4; j++) { + u32 idx = (cluster >> (j*8)) & TP_CLUSTER_INIT_MASK; + u32 type = in_be32(&gur->tp_ityp[idx]); + + if (type & TP_ITYP_AV) { + if (TP_ITYP_TYPE(type) == TP_ITYP_TYPE_PPC) + mask |= 1 << count; + } + count++; + } + } while ((cluster & TP_CLUSTER_EOC) != TP_CLUSTER_EOC); + + return mask; +} +#else /* CONFIG_SYS_FSL_QORIQ_CHASSIS2 */ +/* + * Before chassis genenration 2, the cpumask should be hard-coded. + * In case of cpu type unknown or cpumask unset, use 1 as fail save. + */ +#define compute_ppc_cpumask() 1 +#endif /* CONFIG_SYS_FSL_QORIQ_CHASSIS2 */ + +struct cpu_type cpu_type_unknown = CPU_TYPE_ENTRY(Unknown, Unknown, 0);
struct cpu_type *identify_cpu(u32 ver) { @@ -113,6 +145,9 @@ u32 cpu_mask() return ((in_be32(&pic->frr) & MPC8xxx_PICFRR_NCPU_MASK) >> MPC8xxx_PICFRR_NCPU_SHIFT) + 1;
+ if (cpu->num_cores == 0) + return compute_ppc_cpumask(); + return cpu->mask; }
@@ -120,13 +155,14 @@ u32 cpu_mask() * Return the number of cores on this SOC. */ int cpu_numcores() { - ccsr_pic_t __iomem *pic = (void *)CONFIG_SYS_MPC8xxx_PIC_ADDR; struct cpu_type *cpu = gd->cpu;
- /* better to query feature reporting register than just assume 1 */ - if (cpu == &cpu_type_unknown) - return ((in_be32(&pic->frr) & MPC8xxx_PICFRR_NCPU_MASK) >> - MPC8xxx_PICFRR_NCPU_SHIFT) + 1; + /* + * Report # of cores in terms of the cpu_mask if we haven't + * figured out how many there are yet + */ + if (cpu->num_cores == 0) + return hweight32(cpu_mask());
return cpu->num_cores; } @@ -138,9 +174,7 @@ int cpu_numcores() { */ int is_core_valid(unsigned int core) { - struct cpu_type *cpu = gd->cpu; - - return !!((1 << core) & cpu->mask); + return !!((1 << core) & cpu_mask()); }
int probecpu (void) @@ -156,6 +190,19 @@ int probecpu (void) return 0; }
+/* Once in memory, compute mask & # cores once and save them off */ +int fixup_cpu(void) +{ + struct cpu_type *cpu = gd->cpu; + + if (cpu->num_cores == 0) { + cpu->mask = cpu_mask(); + cpu->num_cores = cpu_numcores(); + } + + return 0; +} + /* * Initializes on-chip ethernet controllers. * to override, implement board_eth_init() diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index 20dc2ee..5e68b1d 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -1161,6 +1161,7 @@ struct cpu_type { };
struct cpu_type *identify_cpu(u32 ver); +int fixup_cpu(void);
#if defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) #define CPU_TYPE_ENTRY(n, v, nc) \ diff --git a/arch/powerpc/lib/board.c b/arch/powerpc/lib/board.c index fea310e..e9b33c2 100644 --- a/arch/powerpc/lib/board.c +++ b/arch/powerpc/lib/board.c @@ -345,6 +345,13 @@ ulong get_effective_memsize(void) #endif }
+int __fixup_cpu(void) +{ + return 0; +} + +int fixup_cpu(void) __attribute__((weak, alias("__fixup_cpu"))); + /* * This is the first part of the initialization sequence that is * implemented in C, but still running from ROM. @@ -647,6 +654,12 @@ void board_init_r(gd_t *id, ulong dest_addr) * We need to update it to point to the same CPU entry in RAM. */ gd->cpu += dest_addr - CONFIG_SYS_MONITOR_BASE; + + /* + * If we didn't know the cpu mask & # cores, we can save them of + * now rather than 'computing' them constantly + */ + fixup_cpu(); #endif
#ifdef CONFIG_SYS_EXTRA_ENV_RELOC
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc85xx/cpu.c | 3 +++ arch/powerpc/include/asm/processor.h | 1 + 2 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu.c b/arch/powerpc/cpu/mpc85xx/cpu.c index d71878b..6faa984 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu.c +++ b/arch/powerpc/cpu/mpc85xx/cpu.c @@ -117,6 +117,9 @@ int checkcpu (void) case PVR_VER_E5500: puts("E5500"); break; + case PVR_VER_E6500: + puts("E6500"); + break; default: puts("Unknown"); break; diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index 5e68b1d..7fdfda9 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -951,6 +951,7 @@ #define PVR_VER_E500_V2 0x8021 #define PVR_VER_E500MC 0x8023 #define PVR_VER_E5500 0x8024 +#define PVR_VER_E6500 0x8040
#define PVR_86xx 0x80040000
Signed-off-by: Kumar Gala galak@kernel.crashing.org Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/include/asm/immap_85xx.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 163f08d..63bcfda 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -2749,6 +2749,7 @@ typedef struct ccsr_snvs_regs { #define CONFIG_SYS_MPC85xx_ESPI_OFFSET 0x110000 #define CONFIG_SYS_MPC85xx_ESDHC_OFFSET 0x114000 #define CONFIG_SYS_MPC85xx_LBC_OFFSET 0x124000 +#define CONFIG_SYS_MPC85xx_IFC_OFFSET 0x124000 #define CONFIG_SYS_MPC85xx_GPIO_OFFSET 0x130000 #define CONFIG_SYS_FSL_CORENET_RMAN_OFFSET 0x1e0000 #define CONFIG_SYS_MPC85xx_PCIE1_OFFSET 0x200000
In case more than 32 bit address is used, the EXT bit should be set. Need to fix up address map for IFC #CS for 4, also need to move # of IFC banks into config_mpc85xx.h
Signed-off-by: Kumar Gala galak@kernel.crashing.org Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc8xxx/fsl_ifc.c | 12 ++++++++++++ arch/powerpc/include/asm/fsl_ifc.h | 18 ++++++++++++------ 2 files changed, 24 insertions(+), 6 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/fsl_ifc.c b/arch/powerpc/cpu/mpc8xxx/fsl_ifc.c index 6682496..56b319f 100644 --- a/arch/powerpc/cpu/mpc8xxx/fsl_ifc.c +++ b/arch/powerpc/cpu/mpc8xxx/fsl_ifc.c @@ -44,12 +44,18 @@ void init_early_memctl_regs(void) set_ifc_ftim(IFC_CS0, IFC_FTIM3, CONFIG_SYS_CS0_FTIM3);
#if !defined(CONFIG_SYS_FSL_ERRATUM_IFC_A003399) || defined(CONFIG_SYS_RAMBOOT) +#ifdef CONFIG_SYS_CSPR0_EXT + set_ifc_cspr_ext(IFC_CS0, CONFIG_SYS_CSPR0_EXT); +#endif set_ifc_cspr(IFC_CS0, CONFIG_SYS_CSPR0); set_ifc_amask(IFC_CS0, CONFIG_SYS_AMASK0); set_ifc_csor(IFC_CS0, CONFIG_SYS_CSOR0); #endif #endif
+#ifdef CONFIG_SYS_CSPR1_EXT + set_ifc_cspr_ext(IFC_CS1, CONFIG_SYS_CSPR1_EXT); +#endif #if defined(CONFIG_SYS_CSPR1) && defined(CONFIG_SYS_CSOR1) set_ifc_ftim(IFC_CS1, IFC_FTIM0, CONFIG_SYS_CS1_FTIM0); set_ifc_ftim(IFC_CS1, IFC_FTIM1, CONFIG_SYS_CS1_FTIM1); @@ -61,6 +67,9 @@ void init_early_memctl_regs(void) set_ifc_cspr(IFC_CS1, CONFIG_SYS_CSPR1); #endif
+#ifdef CONFIG_SYS_CSPR2_EXT + set_ifc_cspr_ext(IFC_CS2, CONFIG_SYS_CSPR2_EXT); +#endif #if defined(CONFIG_SYS_CSPR2) && defined(CONFIG_SYS_CSOR2) set_ifc_ftim(IFC_CS2, IFC_FTIM0, CONFIG_SYS_CS2_FTIM0); set_ifc_ftim(IFC_CS2, IFC_FTIM1, CONFIG_SYS_CS2_FTIM1); @@ -72,6 +81,9 @@ void init_early_memctl_regs(void) set_ifc_cspr(IFC_CS2, CONFIG_SYS_CSPR2); #endif
+#ifdef CONFIG_SYS_CSPR3_EXT + set_ifc_cspr_ext(IFC_CS3, CONFIG_SYS_CSPR3_EXT); +#endif #if defined(CONFIG_SYS_CSPR3) && defined(CONFIG_SYS_CSOR3) set_ifc_ftim(IFC_CS3, IFC_FTIM0, CONFIG_SYS_CS3_FTIM0); set_ifc_ftim(IFC_CS3, IFC_FTIM1, CONFIG_SYS_CS3_FTIM1); diff --git a/arch/powerpc/include/asm/fsl_ifc.h b/arch/powerpc/include/asm/fsl_ifc.h index 7d95eb4..ba41b73 100644 --- a/arch/powerpc/include/asm/fsl_ifc.h +++ b/arch/powerpc/include/asm/fsl_ifc.h @@ -783,12 +783,16 @@ extern void init_early_memctl_regs(void);
#define IFC_BASE_ADDR ((struct fsl_ifc *)CONFIG_SYS_IFC_ADDR)
+#define get_ifc_cspr_ext(i) (in_be32(&(IFC_BASE_ADDR)->cspr_cs[i].cspr_ext)) #define get_ifc_cspr(i) (in_be32(&(IFC_BASE_ADDR)->cspr_cs[i].cspr)) +#define get_ifc_csor_ext(i) (in_be32(&(IFC_BASE_ADDR)->csor_cs[i].csor_ext)) #define get_ifc_csor(i) (in_be32(&(IFC_BASE_ADDR)->csor_cs[i].csor)) #define get_ifc_amask(i) (in_be32(&(IFC_BASE_ADDR)->amask_cs[i].amask)) #define get_ifc_ftim(i, j) (in_be32(&(IFC_BASE_ADDR)->ftim_cs[i].ftim[j]))
+#define set_ifc_cspr_ext(i, v) (out_be32(&(IFC_BASE_ADDR)->cspr_cs[i].cspr_ext, v)) #define set_ifc_cspr(i, v) (out_be32(&(IFC_BASE_ADDR)->cspr_cs[i].cspr, v)) +#define set_ifc_csor_ext(i, v) (out_be32(&(IFC_BASE_ADDR)->csor_cs[i].csor_ext, v)) #define set_ifc_csor(i, v) (out_be32(&(IFC_BASE_ADDR)->csor_cs[i].csor, v)) #define set_ifc_amask(i, v) (out_be32(&(IFC_BASE_ADDR)->amask_cs[i].amask, v)) #define set_ifc_ftim(i, j, v) \ @@ -909,22 +913,24 @@ struct fsl_ifc_gpcm { */ struct fsl_ifc { u32 ifc_rev; - u32 res1[0x3]; + u32 res1[0x2]; struct { + u32 cspr_ext; u32 cspr; - u32 res2[0x2]; + u32 res2; } cspr_cs[FSL_IFC_BANK_COUNT]; - u32 res3[0x18]; + u32 res3[0x19]; struct { u32 amask; u32 res4[0x2]; } amask_cs[FSL_IFC_BANK_COUNT]; - u32 res5[0x18]; + u32 res5[0x17]; struct { + u32 csor_ext; u32 csor; - u32 res6[0x2]; + u32 res6; } csor_cs[FSL_IFC_BANK_COUNT]; - u32 res7[0x18]; + u32 res7[0x19]; struct { u32 ftim[4]; u32 res8[0x8];
For the cores with multiple threads, we need to figure out which physical core a thread belongs. To match the core ids, update PIR registers and spin tables.
Signed-off-by: York Sun yorksun@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- arch/powerpc/cpu/mpc85xx/fdt.c | 5 ++- arch/powerpc/cpu/mpc85xx/release.S | 45 +++++++++++++++++++++++++++++++++-- arch/powerpc/cpu/mpc8xxx/fdt.c | 3 +- arch/powerpc/include/asm/mp.h | 6 ++++ 4 files changed, 53 insertions(+), 6 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index 21c3ad4..40df01c 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -57,8 +57,9 @@ void ft_fixup_cpu(void *blob, u64 memory_limit) u32 *reg = (u32 *)fdt_getprop(blob, off, "reg", 0);
if (reg) { - u64 val = *reg * SIZE_BOOT_ENTRY + spin_tbl_addr; - val = cpu_to_fdt32(val); + u32 phys_cpu_id = thread_to_core(*reg); + u64 val = phys_cpu_id * SIZE_BOOT_ENTRY + spin_tbl_addr; + val = cpu_to_fdt64(val); if (*reg == id) { fdt_setprop_string(blob, off, "status", "okay"); diff --git a/arch/powerpc/cpu/mpc85xx/release.S b/arch/powerpc/cpu/mpc85xx/release.S index 043d0ff..22e73e0 100644 --- a/arch/powerpc/cpu/mpc85xx/release.S +++ b/arch/powerpc/cpu/mpc85xx/release.S @@ -1,5 +1,5 @@ /* - * Copyright 2008-2011 Freescale Semiconductor, Inc. + * Copyright 2008-2012 Freescale Semiconductor, Inc. * Kumar Gala kumar.gala@freescale.com * * See file CREDITS for list of people who contributed to this @@ -155,7 +155,27 @@ __secondary_start_page:
/* r10 has the base address for the entry */ mfspr r0,SPRN_PIR -#ifdef CONFIG_E500MC +#if defined(CONFIG_E6500) +/* + * PIR definition for E6500 + * 0-17 Reserved (logic 0s) + * 8-19 CHIP_ID, 2’b00 - SoC 1 + * all others - reserved + * 20-24 CLUSTER_ID 5’b00000 - CCM 1 + * all others - reserved + * 25-26 CORE_CLUSTER_ID 2’b00 - cluster 1 + * 2’b01 - cluster 2 + * 2’b10 - cluster 3 + * 2’b11 - cluster 4 + * 27-28 CORE_ID 2’b00 - core 0 + * 2’b01 - core 1 + * 2’b10 - core 2 + * 2’b11 - core 3 + * 29-31 THREAD_ID 3’b000 - thread 0 + * 3’b001 - thread 1 + */ + rlwinm r4,r0,29,25,31 +#elif defined(CONFIG_E500MC) rlwinm r4,r0,27,27,31 #else mr r4,r0 @@ -170,6 +190,25 @@ __secondary_start_page: mtspr L1CSR2,r8 #endif
+#ifdef CONFIG_E6500 + mfspr r0,SPRN_PIR + /* + * core 0 thread 0: pir reset value 0x00, new pir 0 + * core 0 thread 1: pir reset value 0x01, new pir 1 + * core 1 thread 0: pir reset value 0x08, new pir 2 + * core 1 thread 1: pir reset value 0x09, new pir 3 + * core 2 thread 0: pir reset value 0x10, new pir 4 + * core 2 thread 1: pir reset value 0x11, new pir 5 + * etc. + * + * Only thread 0 of each core will be running, updating PIR doesn't + * need to deal with the thread bits. + */ + rlwinm r4,r0,30,24,30 +#endif + + mtspr SPRN_PIR,r4 /* write to PIR register */ + #if defined(CONFIG_SYS_P4080_ERRATUM_CPU22) || \ defined(CONFIG_SYS_FSL_ERRATUM_NMG_CPU_A011) /* @@ -253,7 +292,7 @@ __secondary_start_page: /* setup the entry */ li r3,0 li r8,1 - stw r0,ENTRY_PIR(r10) + stw r4,ENTRY_PIR(r10) stw r3,ENTRY_ADDR_UPPER(r10) stw r8,ENTRY_ADDR_LOWER(r10) stw r3,ENTRY_R3_UPPER(r10) diff --git a/arch/powerpc/cpu/mpc8xxx/fdt.c b/arch/powerpc/cpu/mpc8xxx/fdt.c index 09810be..32ab050 100644 --- a/arch/powerpc/cpu/mpc8xxx/fdt.c +++ b/arch/powerpc/cpu/mpc8xxx/fdt.c @@ -62,8 +62,9 @@ void ft_fixup_num_cores(void *blob) { off = fdt_node_offset_by_prop_value(blob, -1, "device_type", "cpu", 4); while (off != -FDT_ERR_NOTFOUND) { u32 *reg = (u32 *)fdt_getprop(blob, off, "reg", 0); + u32 phys_cpu_id = thread_to_core(*reg);
- if (!is_core_valid(*reg) || is_core_disabled(*reg)) { + if (!is_core_valid(phys_cpu_id) || is_core_disabled(phys_cpu_id)) { int ph = fdt_get_phandle(blob, off);
/* Delete the cpu node once there are no cpu handles */ diff --git a/arch/powerpc/include/asm/mp.h b/arch/powerpc/include/asm/mp.h index 3ffa30b..fe490ba 100644 --- a/arch/powerpc/include/asm/mp.h +++ b/arch/powerpc/include/asm/mp.h @@ -28,4 +28,10 @@ void cpu_mp_lmb_reserve(struct lmb *lmb); u32 determine_mp_bootpg(void); int is_core_disabled(int nr);
+#ifdef CONFIG_E6500 +#define thread_to_core(x) (x >> 1) +#else +#define thread_to_core(x) (x) +#endif + #endif
On Fri, Aug 17, 2012 at 1:20 PM, York Sun yorksun@freescale.com wrote:
- 8-19 CHIP_ID, 2’b00 - SoC 1
- 20-24 CLUSTER_ID 5’b00000 - CCM 1
- 25-26 CORE_CLUSTER_ID 2’b00 - cluster 1
2’b01 - cluster 2
2’b10 - cluster 3
2’b11 - cluster 4
- 27-28 CORE_ID 2’b00 - core 0
2’b01 - core 1
2’b10 - core 2
2’b11 - core 3
- 29-31 THREAD_ID 3’b000 - thread 0
3’b001 - thread 1
It's too bad no one noticed the Unicode characters in this comment before the patch was applied.
http://www.fileformat.info/info/unicode/char/2019/index.htm
Tabi Timur-B04825
York Sun
