[PATCH 1/2] MAINTAINERS, cortina: add common feature and platform enablement flag
Add a CONFIG which allows Cortina Access (CA) drivers to be configured in both ARM and MIPS based SoC platforms.
Additionally, Cortina Access specific common board features will be enabled/disabled via a Cortina specific KConfig.
Signed-off-by: Alex Nemirovsky alex.nemirovsky@cortina-access.com
MAINTAINERS | 2 ++ board/cortina/common/Kconfig | 5 +++++ 2 files changed, 7 insertions(+) create mode 100644 board/cortina/common/Kconfig
diff --git a/MAINTAINERS b/MAINTAINERS index c40e9ee..394a089 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -177,6 +177,7 @@ ARM CORTINA ACCESS CAxxxx M: Alex Nemirovsky alex.nemirovsky@cortina-access.com S: Supported F: board/cortina/common/* +F: board/cortina/common/Kconfig F: board/cortina/common/armv8/*
ARM/CZ.NIC TURRIS MOX SUPPORT @@ -657,6 +658,7 @@ MIPS CORTINA ACCESS CAxxxx M: Alex Nemirovsky alex.nemirovsky@cortina-access.com S: Supported F: board/cortina/common/* +F: board/cortina/common/Kconfig F: board/cortina/common/mips/*
MIPS MSCC diff --git a/board/cortina/common/Kconfig b/board/cortina/common/Kconfig new file mode 100644 index 0000000..a3d361e --- /dev/null +++ b/board/cortina/common/Kconfig @@ -0,0 +1,5 @@ +config CORTINA_PLATFORM + bool "Cortina-Access Platform" + default y + help + Select this option for Cortina-Access platform.
Cortina Access ARMv8 boards share common custom ARMV8 init routines.
Add common board init code for Cortina Access SoC ARMv8 based SoCs
Signed-off-by: Alex Nemirovsky alex.nemirovsky@cortina-access.com ---
MAINTAINERS | 2 +- board/cortina/common/armv8/lowlevel_init.S | 87 ++++++++++++++++++++++++++++++ 2 files changed, 88 insertions(+), 1 deletion(-) create mode 100644 board/cortina/common/armv8/lowlevel_init.S
diff --git a/MAINTAINERS b/MAINTAINERS index 394a089..02b2e11 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -178,7 +178,7 @@ M: Alex Nemirovsky alex.nemirovsky@cortina-access.com S: Supported F: board/cortina/common/* F: board/cortina/common/Kconfig -F: board/cortina/common/armv8/* +F: board/cortina/common/armv8/lowlevel_init.S
ARM/CZ.NIC TURRIS MOX SUPPORT M: Marek Behun marek.behun@nic.cz diff --git a/board/cortina/common/armv8/lowlevel_init.S b/board/cortina/common/armv8/lowlevel_init.S new file mode 100644 index 0000000..702611b --- /dev/null +++ b/board/cortina/common/armv8/lowlevel_init.S @@ -0,0 +1,87 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020 Cortina-Access + * + */ + + +#include <asm-offsets.h> +#include <config.h> +#include <linux/linkage.h> +#include <asm/macro.h> +#include <asm/armv8/mmu.h> + + .globl lowlevel_init +lowlevel_init: + mov x29, lr /* Save LR */ + +#if defined(CONFIG_CA77XX) + /* Enable SMPEN in CPUECTLR */ + mrs x0, s3_1_c15_c2_1 + tst x0, #0x40 + b.ne skip_smp_setup + orr x0, x0, #0x40 + msr s3_1_c15_c2_1, x0 +skip_smp_setup: +#endif + +#if defined(CONFIG_CA8277B) + /* Enable CPU Timer */ + ldr x0, =CONFIG_SYS_TIMER_BASE + mov x1, #1 + str w1, [x0] +#endif + +#if defined(CONFIG_GICV2) || defined(CONFIG_GICV3) + branch_if_slave x0, 1f +#ifndef CONFIG_TARGET_VENUS + ldr x0, =GICD_BASE + bl gic_init_secure +#endif +1: +#if defined(CONFIG_GICV3) + ldr x0, =GICR_BASE + bl gic_init_secure_percpu +#elif defined(CONFIG_GICV2) + ldr x0, =GICD_BASE + ldr x1, =GICC_BASE + bl gic_init_secure_percpu +#endif +#endif + +#ifdef CONFIG_ARMV8_MULTIENTRY + branch_if_master x0, x1, 2f + + /* + * Slave should wait for master clearing spin table. + * This sync prevent salves observing incorrect + * value of spin table and jumping to wrong place. + */ +#if defined(CONFIG_GICV2) || defined(CONFIG_GICV3) +#ifdef CONFIG_GICV2 + ldr x0, =GICC_BASE +#endif + bl gic_wait_for_interrupt +#endif + + /* + * All slaves will enter EL2 and optionally EL1. + */ + adr x4, lowlevel_in_el2 + ldr x5, =ES_TO_AARCH64 + bl armv8_switch_to_el2 + +lowlevel_in_el2: +#ifdef CONFIG_ARMV8_SWITCH_TO_EL1 + adr x4, lowlevel_in_el1 + ldr x5, =ES_TO_AARCH64 + bl armv8_switch_to_el1 + +lowlevel_in_el1: +#endif + +#endif /* CONFIG_ARMV8_MULTIENTRY */ + +2: + mov lr, x29 /* Restore LR */ + ret
Alex Nemirovsky
