[PATCH v3 2/2] boot: build arch/*/lib/bootm.c if support boot linux
arch/*/lib/bootm.c is for the boot Linux commands, not just for bootm command.
This commit makes CONFIG_BOOTM_LINUX selected by the boot Linux commands and arch/*/lib/bootm.c will be built if enabled CONFIG_BOOTM_LINUX.
Signed-off-by: Rover Mo myzmzz@126.com --- arch/arc/lib/Makefile | 2 +- arch/arm/lib/Makefile | 6 +++--- arch/m68k/lib/Makefile | 2 +- arch/microblaze/lib/Makefile | 2 +- arch/mips/lib/Makefile | 2 +- arch/nios2/lib/Makefile | 2 +- arch/powerpc/lib/Makefile | 2 +- arch/riscv/lib/Makefile | 4 ++-- arch/sandbox/lib/Makefile | 3 +-- arch/sh/lib/Makefile | 2 +- arch/x86/lib/Makefile | 2 +- arch/xtensa/lib/Makefile | 2 +- cmd/Kconfig | 3 +++ 13 files changed, 18 insertions(+), 16 deletions(-)
diff --git a/arch/arc/lib/Makefile b/arch/arc/lib/Makefile index 0eb44bcf33..777380b36d 100644 --- a/arch/arc/lib/Makefile +++ b/arch/arc/lib/Makefile @@ -12,6 +12,6 @@ obj-y += reset.o obj-y += ints_low.o obj-y += init_helpers.o
-obj-$(CONFIG_CMD_BOOTM) += bootm.o +obj-$(CONFIG_BOOTM_LINUX) += bootm.o
lib-$(CONFIG_USE_PRIVATE_LIBGCC) += _millicodethunk.o libgcc2.o diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index c603fe61bc..c446219b4b 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -30,9 +30,9 @@ endif
obj-$(CONFIG_CPU_V7M) += cmd_boot.o obj-$(CONFIG_OF_LIBFDT) += bootm-fdt.o -obj-$(CONFIG_CMD_BOOTI) += bootm.o image.o -obj-$(CONFIG_CMD_BOOTM) += bootm.o -obj-$(CONFIG_CMD_BOOTZ) += bootm.o zimage.o +obj-$(CONFIG_CMD_BOOTI) += image.o +obj-$(CONFIG_CMD_BOOTZ) += zimage.o +obj-$(CONFIG_BOOTM_LINUX) += bootm.o obj-$(CONFIG_SYS_L2_PL310) += cache-pl310.o else obj-$(CONFIG_$(SPL_TPL_)FRAMEWORK) += spl.o diff --git a/arch/m68k/lib/Makefile b/arch/m68k/lib/Makefile index b66d66afd2..7fdedf6ad8 100644 --- a/arch/m68k/lib/Makefile +++ b/arch/m68k/lib/Makefile @@ -8,7 +8,7 @@ lib-$(CONFIG_USE_PRIVATE_LIBGCC) += lshrdi3.o muldi3.o ashldi3.o
obj-y += bdinfo.o -obj-$(CONFIG_CMD_BOOTM) += bootm.o +obj-$(CONFIG_BOOTM_LINUX) += bootm.o obj-y += cache.o obj-y += interrupts.o obj-y += time.o diff --git a/arch/microblaze/lib/Makefile b/arch/microblaze/lib/Makefile index 05f447abba..b523d18a78 100644 --- a/arch/microblaze/lib/Makefile +++ b/arch/microblaze/lib/Makefile @@ -3,5 +3,5 @@ # (C) Copyright 2003-2006 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-obj-$(CONFIG_CMD_BOOTM) += bootm.o +obj-$(CONFIG_BOOTM_LINUX) += bootm.o obj-y += muldi3.o diff --git a/arch/mips/lib/Makefile b/arch/mips/lib/Makefile index 9ee1fcb5c7..0fc66f1c49 100644 --- a/arch/mips/lib/Makefile +++ b/arch/mips/lib/Makefile @@ -10,7 +10,7 @@ obj-y += reloc.o obj-y += stack.o obj-y += traps.o
-obj-$(CONFIG_CMD_BOOTM) += bootm.o +obj-$(CONFIG_BOOTM_LINUX) += bootm.o obj-$(CONFIG_CMD_GO) += boot.o obj-$(CONFIG_SPL_BUILD) += spl.o
diff --git a/arch/nios2/lib/Makefile b/arch/nios2/lib/Makefile index a9f3c7100e..fdd671a3b8 100644 --- a/arch/nios2/lib/Makefile +++ b/arch/nios2/lib/Makefile @@ -4,5 +4,5 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
obj-y += cache.o -obj-$(CONFIG_CMD_BOOTM) += bootm.o +obj-$(CONFIG_BOOTM_LINUX) += bootm.o obj-y += libgcc.o diff --git a/arch/powerpc/lib/Makefile b/arch/powerpc/lib/Makefile index 2782740bf5..16374e33fb 100644 --- a/arch/powerpc/lib/Makefile +++ b/arch/powerpc/lib/Makefile @@ -33,7 +33,7 @@ endif obj-y += reloc.o
obj-$(CONFIG_BAT_RW) += bat_rw.o -obj-$(CONFIG_CMD_BOOTM) += bootm.o +obj-$(CONFIG_BOOTM_LINUX) += bootm.o obj-y += cache.o obj-y += extable.o obj-y += interrupts.o diff --git a/arch/riscv/lib/Makefile b/arch/riscv/lib/Makefile index 06020fcc2a..48d6366136 100644 --- a/arch/riscv/lib/Makefile +++ b/arch/riscv/lib/Makefile @@ -6,8 +6,8 @@ # Copyright (C) 2017 Andes Technology Corporation # Rick Chen, Andes Technology Corporation rick@andestech.com
-obj-$(CONFIG_CMD_BOOTM) += bootm.o -obj-$(CONFIG_CMD_BOOTI) += bootm.o image.o +obj-$(CONFIG_BOOTM_LINUX) += bootm.o +obj-$(CONFIG_CMD_BOOTI) += image.o obj-$(CONFIG_CMD_GO) += boot.o obj-y += cache.o obj-$(CONFIG_SIFIVE_CACHE) += sifive_cache.o diff --git a/arch/sandbox/lib/Makefile b/arch/sandbox/lib/Makefile index a2bc5a7ee6..a0eedf0273 100644 --- a/arch/sandbox/lib/Makefile +++ b/arch/sandbox/lib/Makefile @@ -7,5 +7,4 @@
obj-y += fdt_fixup.o interrupts.o sections.o obj-$(CONFIG_PCI) += pci_io.o -obj-$(CONFIG_CMD_BOOTM) += bootm.o -obj-$(CONFIG_CMD_BOOTZ) += bootm.o +obj-$(CONFIG_BOOTM_LINUX) += bootm.o diff --git a/arch/sh/lib/Makefile b/arch/sh/lib/Makefile index e7520a328d..840edf2942 100644 --- a/arch/sh/lib/Makefile +++ b/arch/sh/lib/Makefile @@ -6,7 +6,7 @@ extra-y += start.o
obj-y += board.o -obj-$(CONFIG_CMD_BOOTM) += bootm.o +obj-$(CONFIG_BOOTM_LINUX) += bootm.o obj-y += time.o obj-$(CONFIG_CMD_SH_ZIMAGEBOOT) += zimageboot.o
diff --git a/arch/x86/lib/Makefile b/arch/x86/lib/Makefile index a6f2244147..9f99b78679 100644 --- a/arch/x86/lib/Makefile +++ b/arch/x86/lib/Makefile @@ -13,7 +13,7 @@ endif obj-y += string.o endif ifndef CONFIG_SPL_BUILD -obj-$(CONFIG_CMD_BOOTM) += bootm.o +obj-$(CONFIG_BOOTM_LINUX) += bootm.o endif obj-y += cmd_boot.o obj-$(CONFIG_$(SPL_)COREBOOT_SYSINFO) += coreboot/ diff --git a/arch/xtensa/lib/Makefile b/arch/xtensa/lib/Makefile index ad4fe32cb6..4c54b845e2 100644 --- a/arch/xtensa/lib/Makefile +++ b/arch/xtensa/lib/Makefile @@ -3,6 +3,6 @@ # (C) Copyright 2007 - 2013 Tensilica Inc. # (C) Copyright 2014 - 2016 Cadence Design Systems Inc.
obj-y += cache.o misc.o relocate.o time.o diff --git a/cmd/Kconfig b/cmd/Kconfig index 6baa85bfdd..46291b3b07 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -197,6 +197,7 @@ config CMD_BOOTD
config CMD_BOOTM bool "bootm" + select BOOTM_LINUX default y help Boot an application image from the memory. @@ -259,6 +260,7 @@ config BOOTM_EFI
config CMD_BOOTZ bool "bootz" + select BOOTM_LINUX default y if !FIT_SIGNATURE && !EFI_SECURE_BOOT help Boot the Linux zImage @@ -268,6 +270,7 @@ config CMD_BOOTZ
config CMD_BOOTI bool "booti" + select BOOTM_LINUX depends on ARM64 || RISCV default y if !FIT_SIGNATURE && !EFI_SECURE_BOOT help
NAK.
bootm is also used for booting VxWorks.
Regards, Bin
Bin Meng
Rover Mo
