[U-Boot] [PATCH] new tool mkenvimage: generates an env image from an arbitrary config file
This tool takes a key=value configuration file (same as would a `printenv' show) and generates the corresponding environnment image, ready to be flashed.
Signed-off-by: David Wagner david.wagner@free-electrons.com --- tools/Makefile | 5 ++ tools/mkenvimage.c | 157 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 162 insertions(+), 0 deletions(-) create mode 100644 tools/mkenvimage.c
diff --git a/tools/Makefile b/tools/Makefile index e813e1d..db8522f 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -69,6 +69,7 @@ BIN_FILES-$(CONFIG_XWAY_SWAP_BYTES) += xway-swap-bytes$(SFX) BIN_FILES-y += mkimage$(SFX) BIN_FILES-$(CONFIG_NETCONSOLE) += ncb$(SFX) BIN_FILES-$(CONFIG_SHA1_CHECK_UB_IMG) += ubsha1$(SFX) +BIN_FILES-y += mkenvimage$(SFX)
# Source files which exist outside the tools directory EXT_OBJ_FILES-$(CONFIG_BUILD_ENVCRC) += common/env_embedded.o @@ -93,6 +94,7 @@ OBJ_FILES-$(CONFIG_NETCONSOLE) += ncb.o NOPED_OBJ_FILES-y += os_support.o OBJ_FILES-$(CONFIG_SHA1_CHECK_UB_IMG) += ubsha1.o NOPED_OBJ_FILES-y += ublimage.o +NOPED_OBJ_FILES-y += mkenvimage.o
# Don't build by default #ifeq ($(ARCH),ppc) @@ -171,6 +173,9 @@ $(obj)bmp_logo$(SFX): $(obj)bmp_logo.o $(obj)envcrc$(SFX): $(obj)crc32.o $(obj)env_embedded.o $(obj)envcrc.o $(obj)sha1.o $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^
+$(obj)mkenvimage$(SFX): $(obj)crc32.o $(obj)mkenvimage.o + $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ + $(obj)gen_eth_addr$(SFX): $(obj)gen_eth_addr.o $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ $(HOSTSTRIP) $@ diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c new file mode 100644 index 0000000..3fba5ea --- /dev/null +++ b/tools/mkenvimage.c @@ -0,0 +1,157 @@ +/* + * (C) Copyright 2011 Free Electrons + * David Wagner david.wagner@free-electrons.com + * + * Inspired from envcrc.c: + * (C) Copyright 2001 + * Paolo Scaffardi, AIRVENT SAM s.p.a - RIMINI(ITALY), arsenio@tin.it + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <errno.h> +#include <stdio.h> +#include <stdint.h> +#include <stdlib.h> +#include <string.h> +#include <unistd.h> +#include <endian.h> + +extern uint32_t crc32 (uint32_t, const unsigned char *, unsigned int); + +#define CRC_SIZE sizeof(uint32_t) + +static void usage(void) +{ + printf("envcrc [-h] [-r] [-b] -s <envrionnment partition size> -o <output> " + "<input file>\n" + "\n" + "\tThe input file is in format:\n" + "\t\tkey1=value1\n" + "\t\tkey2=value2\n" + "\t\t...\n" + "\t-r : the environnment is redundand\n" + "\t-b : the target is big endian (default is little endian)\n"); + +} + +static int make_binary_config(FILE* txt_file, unsigned char *envptr, int envsize) +{ + int i; + int ret; + + ret = fread(envptr, envsize, 1, txt_file); + for (i = 0 ; i < envsize ; i++) + if (envptr[i] == '\n') + envptr[i] = '\0'; + + return 0; +} + +int main(int argc, char **argv) +{ + uint32_t crc; + char *txt_filename = NULL, *bin_filename = NULL; + FILE *txt_file, *bin_file; + unsigned char *dataptr, *envptr; + unsigned int envsize, datasize = 0; + int bigendian = 0; + int redundant = 0; + + int option; + int ret = EXIT_SUCCESS; + + opterr = 0; + + + /* Parse the cmdline */ + while ((option = getopt(argc, argv, "s:o:rbh")) != -1) + switch (option) + { + case 's': + datasize = atoi(optarg); + break; + case 'o': + bin_filename = strdup(optarg); + if (!bin_filename) + return ENOMEM; + break; + case 'r': + redundant = 1; + break; + case 'b': + bigendian = 1; + break; + case 'h': + usage(); + return EXIT_SUCCESS; + default: + if (bin_filename) + free(bin_filename); + fprintf(stderr, "Wrong option\n"); + usage(); + return EXIT_FAILURE; + } + + if (datasize == 0) { + printf("Please specify the size of the envrionnment partition.\n"); + usage(); + ret = EXIT_FAILURE; + goto out; + } + + + txt_filename = strdup(argv[optind]); + if (!txt_filename) { + ret = ENOMEM; + goto out; + } + + txt_file = fopen(txt_filename, "r"); + if (!txt_file) + goto out; + /* Read the raw configuration file and transform it */ + dataptr = calloc(datasize, 1); + if (!dataptr) + goto out; + + envsize = datasize - (CRC_SIZE + redundant); + envptr = dataptr + CRC_SIZE + redundant; + + ret = make_binary_config(txt_file, envptr, envsize); + ret = fclose(txt_file); + + crc = crc32(0, envptr, envsize); + printf("crc: 0x%08X\n", crc); + + *((uint32_t*) dataptr) = bigendian ? htobe32(crc) : htole32(crc); + + bin_file = fopen(bin_filename, "w"); + if (fwrite(dataptr, 1, datasize, bin_file) != datasize) + fprintf(stderr, "fwrite() failed: %s\n", strerror(errno)); + + ret = fclose(bin_file); + +out: + if (txt_filename) + free(txt_filename); + if (bin_filename) + free(bin_filename); + return ret; +}
Hello,
Le Fri, 5 Aug 2011 16:49:58 +0200, David Wagner david.wagner@free-electrons.com a écrit :
Nice tool. I'm currently using a crappy shell-based equivalent of this, but it'd be a lot better to have a clean and nice version integrated in U-Boot. However, see some comments below:
"the environment has two copies in flash" might be clearer that this "redundand" word maybe.
- int i;
- int ret;
- ret = fread(envptr, envsize, 1, txt_file);
- for (i = 0 ; i < envsize ; i++)
envptr[i] = '\0';
The name of the function sounds a bit strange, and the function's job is really small. Maybe it should just be merged into the main function.
- uint32_t crc;
- char *txt_filename = NULL, *bin_filename = NULL;
- FILE *txt_file, *bin_file;
- unsigned char *dataptr, *envptr;
- unsigned int envsize, datasize = 0;
- int bigendian = 0;
- int redundant = 0;
- int option;
- int ret = EXIT_SUCCESS;
- opterr = 0;
- /* Parse the cmdline */
- while ((option = getopt(argc, argv, "s:o:rbh")) != -1)
I'd prefer to have an opening brace here, even if there is technically a single statement inside the while() loop.
switch (option)
case 's':
break;
It'd be nicer if sizes could be given in decimal *or* hexadecimal formats. 0x20000 is much easier to type than 131072.
default:
if (bin_filename)
free(bin_filename);
Don't try to do needless cleanup, and let the operating system do it for you. It's a short-lived program, I don't think it's worth worrying about cleaning-up things.
usage();
- if (datasize == 0) {
^^^^^ typo The message should probably be printed to stderr:
fprintf(stderr, "blabla\n");
usage();
ret = EXIT_FAILURE;
goto out;
just return EXIT_FAILURE, not need to clean up.
- txt_filename = strdup(argv[optind]);
- if (!txt_filename) {
ret = ENOMEM;
goto out;
no need to clean up.
- txt_file = fopen(txt_filename, "r");
- if (!txt_file)
goto out;
You should check whether the size of the environment given in the file doesn't exceed the size of the environment passed on the command line.
- /* Read the raw configuration file and transform it */
- dataptr = calloc(datasize, 1);
- if (!dataptr)
goto out;
No need to clean up.
- envsize = datasize - (CRC_SIZE + redundant);
- envptr = dataptr + CRC_SIZE + redundant;
- ret = make_binary_config(txt_file, envptr, envsize);
- ret = fclose(txt_file);
- crc = crc32(0, envptr, envsize);
- printf("crc: 0x%08X\n", crc);
I don't think printing the CRC is useful, just drop.
- *((uint32_t*) dataptr) = bigendian ? htobe32(crc) : htole32(crc);
I think it'd be better to have :
struct env_normal { uint32_t crc; char data[0]; }
struct env_redund { uint32_t crc; char flags; char data[0]; }
rather than this cast.
- bin_file = fopen(bin_filename, "w");
- if (fwrite(dataptr, 1, datasize, bin_file) != datasize)
Missing exit with error here.
- ret = fclose(bin_file);
+out:
- if (txt_filename)
free(txt_filename);
- if (bin_filename)
free(bin_filename);
- return ret;
No need to do useless clean up.
Regards,
Thomas
Hi Thomas,
This second version addresses all your comments except - as we discussed - the cast vs. struct part.
tools/Makefile | 5 ++ tools/mkenvimage.c | 187 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 192 insertions(+), 0 deletions(-) create mode 100644 tools/mkenvimage.c
+$(obj)mkenvimage$(SFX): $(obj)crc32.o $(obj)mkenvimage.o + $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ + $(obj)gen_eth_addr$(SFX): $(obj)gen_eth_addr.o $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ $(HOSTSTRIP) $@ diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c new file mode 100644 index 0000000..175126a --- /dev/null +++ b/tools/mkenvimage.c @@ -0,0 +1,187 @@ +/* + * (C) Copyright 2011 Free Electrons + * David Wagner david.wagner@free-electrons.com + * + * Inspired from envcrc.c: + * (C) Copyright 2001 + * Paolo Scaffardi, AIRVENT SAM s.p.a - RIMINI(ITALY), arsenio@tin.it + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <errno.h> +#include <stdio.h> +#include <stdint.h> +#include <stdlib.h> +#include <string.h> +#include <unistd.h> +#include <endian.h> +#include <sys/types.h> +#include <sys/stat.h> + +extern uint32_t crc32 (uint32_t, const unsigned char *, unsigned int); + +#define CRC_SIZE sizeof(uint32_t) + +static void usage(void) +{ + printf("envcrc [-h] [-r] [-b] -s <envrionnment partition size> -o <output> " + "<input file>\n" + "\n" + "\tThe input file is in format:\n" + "\t\tkey1=value1\n" + "\t\tkey2=value2\n" + "\t\t...\n" + "\t-r : the environment has two copies in flash\n" + "\t-b : the target is big endian (default is little endian)\n"); + +} + +int main(int argc, char **argv) +{ + uint32_t crc; + char *txt_filename = NULL, *bin_filename = NULL; + FILE *txt_file, *bin_file; + unsigned char *dataptr, *envptr; + unsigned int envsize, datasize = 0; + int bigendian = 0; + int redundant = 0; + + int option; + int ret = EXIT_SUCCESS; + + struct stat txt_file_stat; + + int i; + + opterr = 0; + + + /* Parse the cmdline */ + while ((option = getopt(argc, argv, "s:o:rbh")) != -1) { + switch (option) + { + case 's': + datasize = strtol(optarg, NULL, 0); + break; + case 'o': + bin_filename = strdup(optarg); + if (!bin_filename) { + fprintf(stderr, "Can't strdup() the output filename\n"); + return EXIT_FAILURE; + } + break; + case 'r': + redundant = 1; + break; + case 'b': + bigendian = 1; + break; + case 'h': + usage(); + return EXIT_SUCCESS; + default: + fprintf(stderr, "Wrong option -%c\n", option); + usage(); + return EXIT_FAILURE; + } + } + + + /* Check datasize and allocate the data */ + if (datasize == 0) { + fprintf(stderr, + "Please specify the size of the envrionnment partition.\n"); + usage(); + return EXIT_FAILURE; + } + + dataptr = calloc(datasize, 1); + if (!dataptr) { + fprintf(stderr, "Can't alloc dataptr.\n"); + return EXIT_FAILURE; + } + + /* envptr points to the beginning of the actual environment (after the + * crc and possible `redundant' bit */ + envsize = datasize - (CRC_SIZE + redundant); + envptr = dataptr + CRC_SIZE + redundant; + + + /* Check the configuration file ...*/ + txt_filename = strdup(argv[optind]); + if (!txt_filename) { + fprintf(stderr, "Can't strdup() the configuration filename\n"); + return EXIT_FAILURE; + } + ret = stat(txt_filename, &txt_file_stat); + if (ret == -1) { + fprintf(stderr, "Can't stat() on configuration file: %s", + strerror(errno)); + return EXIT_FAILURE; + } + if (txt_file_stat.st_size > envsize) { + fprintf(stderr, "The configuration file is larger than the " + "envrionnment partition size\n"); + return EXIT_FAILURE; + } + + /* ... and open it. */ + txt_file = fopen(txt_filename, "r"); + if (!txt_file) { + fprintf(stderr, "Can't open configuration file: %s", strerror(errno)); + return EXIT_FAILURE; + } + + + /* Read the raw configuration file and transform it */ + ret = fread(envptr, txt_file_stat.st_size, 1, txt_file); + if (ret != 1) { + fprintf(stderr, "Can't read the whole configuration file\n"); + return EXIT_FAILURE; + } + + for (i = 0 ; i < envsize ; i++) + if (envptr[i] == '\n') + envptr[i] = '\0'; + + ret = fclose(txt_file); + + + /* Computes the CRC and put it at the beginning of the data */ + crc = crc32(0, envptr, envsize); + + *((uint32_t*) dataptr) = bigendian ? htobe32(crc) : htole32(crc); + + bin_file = fopen(bin_filename, "w"); + if (!bin_file) { + fprintf(stderr, "Can't open output file: %s", strerror(errno)); + return EXIT_FAILURE; + } + + if (fwrite(dataptr, 1, datasize, bin_file) != datasize) { + fprintf(stderr, "fwrite() failed: %s\n", strerror(errno)); + return EXIT_FAILURE; + } + + ret = fclose(bin_file); + + + return ret; +}
this is not portable. include compiler.h and use the already existing uswap/cpu_to/to_cpu/etc... helpers.
- printf("envcrc [-h] [-r] [-b] -s <envrionnment partition size> -o <output> "
funny, "envcrc" isnt what the filename actually is ...
typo with "environment"
seems like this should also take a padding byte so people can use a more sensible 0xff rather than 0x00
- "\t-b : the target is big endian (default is little endian)\n");
kill useless newline before brace
- opterr = 0;
unnecessary ... punt it
- switch (option)
cuddle the brace up
- /* Check the configuration file ...*/
no need to strdup this. argv isnt going anywhere.
- ret = stat(txt_filename, &txt_file_stat);
- if (ret == -1) {
- fprintf(stderr, "Can't stat() on configuration file: %s",
- strerror(errno));
- return EXIT_FAILURE;
- if (txt_file_stat.st_size > envsize) {
- fprintf(stderr, "The configuration file is larger than the "
- "envrionnment partition size\n");
- /* ... and open it. */
fopen() it, then fstat() the fileno(txt_file) to avoid possible race conditions. also, use "rb".
- ret = fread(envptr, txt_file_stat.st_size, 1, txt_file);
you've swapped size and nemb args
- if (envptr[i] == '\n')
- envptr[i] = '\0';
you could use memchr() and a while loop instead ... but probably not worth the effort
you could fclose() before the envptr conversion since you're done with the file at that point
create a local uint32_t variable to set, then use memcpy to copy it over to dataptr
"wb"
- if (fwrite(dataptr, 1, datasize, bin_file) != datasize) {
funny enough, you got the size/nemb args in the right order here ;) -mike
size> -o <output> "
ah, yes, it began as an attempt to extend envcrc but ended up fairly different.
Thomas told me that when padding with 0xff, his environment image wouldn't be taken into account anymore. I'll add the option anyway, but do you know what could be happening ?
Also, I guess this makes necessary making sure there is a \0 after the last configuration line.
I wasn't sure whether the proper way of doing it was "read/write 1 byte, N times" or "read/write the size of the file, 1 time". I probably changed my mine in between.
Thanks for reviewing ; David.
Hi David,
printf("envcrc [-h] [-r] [-b] -s<envrionnment partition
size> -o<output> "
Maybe passing argv[0] to usage() would help deal with the current name of the executable?
Amicalement,
On 08/08/2011 10:46 AM, Albert ARIBAUD wrote:
Hi David,
size> -o<output> "
Amicalement,
Indeed, merci.
sorry, but i dont know what you're referring to. perhaps you wrote out the padding before calculating the crc ? ive been using `tools/envcrc --binary` for a while now and it pads things with 0xff.
two to be exact ... one for the config opt, and one to tell u-boot that it's the end of the env.
dont think of it in terms of bytes. in fact, forget about that completely. think of it in terms of "elements". in this case, the element is a "char" which means you want to read a bunch of "char" elements and the size of each is 1.
you could also do: fwrite(dataptr, sizeof(*dataptr), datasize, bin_file); then you dont need to think "how many bytes is one element". -mike
Hi Mike,
This 3rd version should address what you pointed out.
I had troubles testing it on my IGEP board: I couldn't compile from the official git (I think it's because of my toolchain ... a more recent toolchain might be able to compile but won't compile IGEP's uboot version ... weird stuff above my head involved). And the IGEP uboot seems broken wrt environnment in onenand: when computing the CRC, it only takes the 4092 (4096 minus the header) bytes of the environment into account ...
So, someone else should probably test it.
David.
tools/Makefile | 5 ++ tools/mkenvimage.c | 205 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 210 insertions(+), 0 deletions(-) create mode 100644 tools/mkenvimage.c
+$(obj)mkenvimage$(SFX): $(obj)crc32.o $(obj)mkenvimage.o + $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ + $(obj)gen_eth_addr$(SFX): $(obj)gen_eth_addr.o $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ $(HOSTSTRIP) $@ diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c new file mode 100644 index 0000000..fe91bc4 --- /dev/null +++ b/tools/mkenvimage.c @@ -0,0 +1,205 @@ +/* + * (C) Copyright 2011 Free Electrons + * David Wagner david.wagner@free-electrons.com + * + * Inspired from envcrc.c: + * (C) Copyright 2001 + * Paolo Scaffardi, AIRVENT SAM s.p.a - RIMINI(ITALY), arsenio@tin.it + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <errno.h> +#include <stdio.h> +#include <stdint.h> +#include <stdlib.h> +#include <string.h> +#include <unistd.h> +#include <compiler.h> +#include <sys/types.h> +#include <sys/stat.h> + +extern uint32_t crc32 (uint32_t, const unsigned char *, unsigned int); + +#define CRC_SIZE sizeof(uint32_t) + +static void usage(char *exec_name) +{ + printf("%s [-h] [-r] [-b] [-p <byte>] " + "-s <envrionment partition size> -o <output> <input file>\n" + "\n" + "\tThe input file is in format:\n" + "\t\tkey1=value1\n" + "\t\tkey2=value2\n" + "\t\t...\n" + "\t-r : the environment has two copies in flash\n" + "\t-b : the target is big endian (default is little endian)\n" + "\t-p <byte> : fill the image with <byte> bytes instead of 0xff bytes\n", + exec_name); +} + +int main(int argc, char **argv) +{ + uint32_t crc, targetendian_crc; + char *txt_filename = NULL, *bin_filename = NULL; + FILE *txt_file, *bin_file; + unsigned char *dataptr, *envptr; + unsigned int envsize, datasize = 0; + int bigendian = 0; + int redundant = 0; + unsigned char padbyte = 0xff; + + int option; + int ret = EXIT_SUCCESS; + + struct stat txt_file_stat; + + int i; + + + /* Parse the cmdline */ + while ((option = getopt(argc, argv, "s:o:rbp:h")) != -1) { + switch (option) { + case 's': + datasize = strtol(optarg, NULL, 0); + break; + case 'o': + bin_filename = strdup(optarg); + if (!bin_filename) { + fprintf(stderr, "Can't strdup() the output filename\n"); + return EXIT_FAILURE; + } + break; + case 'r': + redundant = 1; + break; + case 'b': + bigendian = 1; + break; + case 'p': + padbyte = strtol(optarg, NULL, 0); + break; + case 'h': + usage(argv[0]); + return EXIT_SUCCESS; + default: + fprintf(stderr, "Wrong option -%c\n", option); + usage(argv[0]); + return EXIT_FAILURE; + } + } + + + /* Check datasize and allocate the data */ + if (datasize == 0) { + fprintf(stderr, + "Please specify the size of the envrionnment partition.\n"); + usage(argv[0]); + return EXIT_FAILURE; + } + + dataptr = calloc(datasize, sizeof(*dataptr)); + if (!dataptr) { + fprintf(stderr, "Can't alloc dataptr.\n"); + return EXIT_FAILURE; + } + + /* envptr points to the beginning of the actual environment (after the + * crc and possible `redundant' bit */ + envsize = datasize - (CRC_SIZE + redundant); + envptr = dataptr + CRC_SIZE + redundant; + + /* Pad the environnment with the padding byte */ + memset(envptr, padbyte, envsize); + + /* Open the configuration file ... */ + txt_filename = argv[optind]; + if (!txt_filename) { + fprintf(stderr, "Can't strdup() the configuration filename\n"); + return EXIT_FAILURE; + } + txt_file = fopen(txt_filename, "rb"); + if (!txt_file) { + fprintf(stderr, "Can't open configuration file: %s\n", strerror(errno)); + return EXIT_FAILURE; + } + /* ... and check it */ + ret = fstat(fileno(txt_file), &txt_file_stat); + if (ret == -1) { + fprintf(stderr, "Can't stat() on configuration file: %s\n", + strerror(errno)); + return EXIT_FAILURE; + } + if (txt_file_stat.st_size > envsize) { + fprintf(stderr, "The configuration file is larger than the " + "envrionnment partition size\n"); + return EXIT_FAILURE; + } + + + /* Read the raw configuration file and transform it */ + ret = fread(envptr, sizeof(*envptr), txt_file_stat.st_size, txt_file); + if (ret != txt_file_stat.st_size) { + fprintf(stderr, "Can't read the whole configuration file\n"); + return EXIT_FAILURE; + } + ret = fclose(txt_file); + + for (i = 0 ; i < txt_file_stat.st_size ; i++) + if (envptr[i] == '\n') + envptr[i] = '\0'; + /* + * Make sure there is a final '\0' (necessary if the padding byte isn't + * 0x00 or if there wasn't a newline at the end of the configuration + * file) Also, don't add it if the configuration file size is exactly + * the size of the environnment. + * + * And do it again on the next byte to mark the end of the environment. + */ + if (i < envsize && envptr[i-1] != '\0') { + envptr[i] = '\0'; + i++; + envptr[i] = '\0'; + } else if (i < envsize) { + envptr[i] = '\0'; + } + + + /* Computes the CRC and put it at the beginning of the data */ + crc = crc32(0, envptr, envsize); + targetendian_crc = bigendian ? cpu_to_be32(crc) : cpu_to_le32(crc); + + memcpy((uint32_t*) dataptr, &targetendian_crc, sizeof(uint32_t)); + + bin_file = fopen(bin_filename, "wb"); + if (!bin_file) { + fprintf(stderr, "Can't open output file: %s\n", strerror(errno)); + return EXIT_FAILURE; + } + + if (fwrite(dataptr, sizeof(*dataptr), datasize, bin_file) != datasize) { + fprintf(stderr, "fwrite() failed: %s\n", strerror(errno)); + return EXIT_FAILURE; + } + + ret = fclose(bin_file); + + + return ret; +}
does including u-boot/crc.h work ?
const char *exec_name
mark them both const ?
- dataptr = calloc(datasize, sizeof(*dataptr));
you zero-ed it out here ...
- /* Pad the environnment with the padding byte */
- memset(envptr, padbyte, envsize);
... then manually filled it with a byte. just use malloc() instead of calloc() and avoid that zero.
- memcpy((uint32_t*) dataptr, &targetendian_crc, sizeof(uint32_t));
i dont think that cast is necessary. just punt it. -mike
Dear David Wagner,
In message 1312885889-20222-1-git-send-email-david.wagner@free-electrons.com you wrote:
s/nnm/nm/
Hi Mike,
If this is v3, then why don't you say so in the Subject: ???
Could you please explain which usage scenarios you have in mind for this tool? I would probably rather just load the text file you use as input, and run "env import -t" on it.
Checkpatch says:
total: 4 errors, 5 warnings, 228 lines checked
Please fix these.
In addition:
default:
usage(argv[0]);
- /* Check datasize and allocate the data */
Please only one blank line in cases like this.
- /* envptr points to the beginning of the actual environment (after the
inforrect multiline comment style.
- /* Open the configuration file ... */
- txt_filename = argv[optind];
Where is there any strdup() involved ?
- txt_file = fopen(txt_filename, "rb");
- if (!txt_file) {
It would probably be very useful to also print the file name.
- /* ... and check it */
- ret = fstat(fileno(txt_file), &txt_file_stat);
Why don't you simply use mmap() ?
- for (i = 0 ; i < txt_file_stat.st_size ; i++)
envptr[i] = '\0';
This is actually wrong. Envrionment variables can have embedded newlines.
You did not take this into account in your file size check above, it seems.
The double '\0' termination is _always_ needed.
This tool takes a key=value configuration file (same as would a `printenv' show) and generates the corresponding environment image, ready to be flashed.
For now, it doesn't work properly if environment variables have embedded newlines.
changes since v3 ~~~~~~~~~~~~~~~~
* cosmetic changes (checkpatch, spelling, blank lines)
* fail with an error message if it's impossible to have two ending '\0'
@Wolgang: What is the advantage of using mmap() here ? the file is read entirely and sequentially ; does it make much of a difference compared to fread() ?
PS: Until a proper way is found for replacing only newlines that separate two environment variables (and not the ones inside a variable), let's just warn that it isn't supported.
tools/Makefile | 5 + tools/mkenvimage.c | 219 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 224 insertions(+), 0 deletions(-) create mode 100644 tools/mkenvimage.c
diff --git a/tools/Makefile b/tools/Makefile index fc741d3..8e7e85e 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -69,6 +69,7 @@ BIN_FILES-$(CONFIG_XWAY_SWAP_BYTES) += xway-swap-bytes$(SFX) BIN_FILES-y += mkimage$(SFX) BIN_FILES-$(CONFIG_NETCONSOLE) += ncb$(SFX) BIN_FILES-$(CONFIG_SHA1_CHECK_UB_IMG) += ubsha1$(SFX) +BIN_FILES-y += mkenvimage$(SFX)
# Source files which exist outside the tools directory EXT_OBJ_FILES-$(CONFIG_BUILD_ENVCRC) += common/env_embedded.o @@ -94,6 +95,7 @@ OBJ_FILES-$(CONFIG_NETCONSOLE) += ncb.o NOPED_OBJ_FILES-y += os_support.o OBJ_FILES-$(CONFIG_SHA1_CHECK_UB_IMG) += ubsha1.o NOPED_OBJ_FILES-y += ublimage.o +NOPED_OBJ_FILES-y += mkenvimage.o
# Don't build by default #ifeq ($(ARCH),ppc) @@ -172,6 +174,9 @@ $(obj)bmp_logo$(SFX): $(obj)bmp_logo.o $(obj)envcrc$(SFX): $(obj)crc32.o $(obj)env_embedded.o $(obj)envcrc.o $(obj)sha1.o $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^
+$(obj)mkenvimage$(SFX): $(obj)crc32.o $(obj)mkenvimage.o + $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ + $(obj)gen_eth_addr$(SFX): $(obj)gen_eth_addr.o $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ $(HOSTSTRIP) $@ diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c new file mode 100644 index 0000000..9c06e1e --- /dev/null +++ b/tools/mkenvimage.c @@ -0,0 +1,219 @@ +/* + * (C) Copyright 2011 Free Electrons + * David Wagner david.wagner@free-electrons.com + * + * Inspired from envcrc.c: + * (C) Copyright 2001 + * Paolo Scaffardi, AIRVENT SAM s.p.a - RIMINI(ITALY), arsenio@tin.it + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <errno.h> +#include <stdio.h> +#include <stdint.h> +#include <stdlib.h> +#include <string.h> +#include <unistd.h> +#include <compiler.h> +#include <sys/types.h> +#include <sys/stat.h> + +#include <u-boot/crc.h> + +#define CRC_SIZE sizeof(uint32_t) + +static void usage(const char *exec_name) +{ + printf("%s [-h] [-r] [-b] [-p <byte>] " + "-s <envrionment partition size> -o <output> <input file>\n" + "\n" + "\tThe input file is in format:\n" + "\t\tkey1=value1\n" + "\t\tkey2=value2\n" + "\t\t...\n" + "\t-r : the environment has two copies in flash\n" + "\t-b : the target is big endian (default is little endian)\n" + "\t-p <byte> : fill the image with <byte> bytes instead of 0xff " + "bytes\n", + exec_name); +} + +int main(int argc, char **argv) +{ + uint32_t crc, targetendian_crc; + const char *txt_filename = NULL, *bin_filename = NULL; + FILE *txt_file, *bin_file; + unsigned char *dataptr, *envptr; + unsigned int envsize, datasize = 0; + int bigendian = 0; + int redundant = 0; + unsigned char padbyte = 0xff; + + int option; + int ret = EXIT_SUCCESS; + + struct stat txt_file_stat; + + int i; + + /* Parse the cmdline */ + while ((option = getopt(argc, argv, "s:o:rbp:h")) != -1) { + switch (option) { + case 's': + datasize = strtol(optarg, NULL, 0); + break; + case 'o': + bin_filename = strdup(optarg); + if (!bin_filename) { + fprintf(stderr, "Can't strdup() the output " + "filename\n"); + return EXIT_FAILURE; + } + break; + case 'r': + redundant = 1; + break; + case 'b': + bigendian = 1; + break; + case 'p': + padbyte = strtol(optarg, NULL, 0); + break; + case 'h': + usage(argv[0]); + return EXIT_SUCCESS; + default: + fprintf(stderr, "Wrong option -%c\n", option); + usage(argv[0]); + return EXIT_FAILURE; + } + } + + /* Check datasize and allocate the data */ + if (datasize == 0) { + fprintf(stderr, + "Please specify the size of the envrionnment " + "partition.\n"); + usage(argv[0]); + return EXIT_FAILURE; + } + + dataptr = malloc(datasize * sizeof(*dataptr)); + if (!dataptr) { + fprintf(stderr, "Can't alloc dataptr.\n"); + return EXIT_FAILURE; + } + + /* + * envptr points to the beginning of the actual environment (after the + * crc and possible `redundant' bit + */ + envsize = datasize - (CRC_SIZE + redundant); + envptr = dataptr + CRC_SIZE + redundant; + + /* Pad the environnment with the padding byte */ + memset(envptr, padbyte, envsize); + + /* Open the configuration file ... */ + if (optind >= argc) { + fprintf(stderr, "Please specify a configuration filename\n"); + return EXIT_FAILURE; + } + + txt_filename = argv[optind]; + txt_file = fopen(txt_filename, "rb"); + if (!txt_file) { + fprintf(stderr, "Can't open configuration file "%s": %s\n", + txt_filename, strerror(errno)); + return EXIT_FAILURE; + } + /* ... and check it */ + ret = fstat(fileno(txt_file), &txt_file_stat); + if (ret == -1) { + fprintf(stderr, "Can't stat() on configuration file "%s": " + " %s\n", txt_filename, strerror(errno)); + return EXIT_FAILURE; + } + /* + * The right test to do is "=>" (not ">") because of the additionnal + * ending \0. See below. + */ + if (txt_file_stat.st_size >= envsize) { + fprintf(stderr, "The configuration file is larger than the " + "envrionnment partition size\n"); + return EXIT_FAILURE; + } + + /* Read the raw configuration file and transform it */ + ret = fread(envptr, sizeof(*envptr), txt_file_stat.st_size, txt_file); + if (ret != txt_file_stat.st_size) { + fprintf(stderr, "Can't read the whole configuration file\n"); + return EXIT_FAILURE; + } + ret = fclose(txt_file); + + for (i = 0 ; i < txt_file_stat.st_size ; i++) + if (envptr[i] == '\n') + envptr[i] = '\0'; + /* + * Make sure there is a final '\0' (necessary if the padding byte isn't + * 0x00 or if there wasn't a newline at the end of the configuration + * file) + * + * And do it again on the next byte to mark the end of the environment. + */ + if (i < envsize && envptr[i-1] != '\0') { + envptr[i++] = '\0'; + /* + * The text file doesn't have an ending newline. We need to + * check the env size again to make sure we have room for two \0 + */ + if (i >= envsize) { + fprintf(stderr, "The configuration is too large for the" + " target environment storage\n"); + return EXIT_FAILURE; + } + envptr[i] = '\0'; + } else if (i < envsize) { + envptr[i] = '\0'; + } + + /* Computes the CRC and put it at the beginning of the data */ + crc = crc32(0, envptr, envsize); + targetendian_crc = bigendian ? cpu_to_be32(crc) : cpu_to_le32(crc); + + memcpy(dataptr, &targetendian_crc, sizeof(uint32_t)); + + bin_file = fopen(bin_filename, "wb"); + if (!bin_file) { + fprintf(stderr, "Can't open output file "%s": %s\n", + bin_filename, strerror(errno)); + return EXIT_FAILURE; + } + + if (fwrite(dataptr, sizeof(*dataptr), datasize, bin_file) != datasize) { + fprintf(stderr, "fwrite() failed: %s\n", strerror(errno)); + return EXIT_FAILURE; + } + + ret = fclose(bin_file); + + return ret; +}
this one line desc is pretty succulent. i'd suggest adding it to the usage() so that people who run `./tools/mkenvimage -h` get the idea immediately.
the rest looks pretty straightforward without actually compiling/testing :). thanks ! -mike
Dear David Wagner,
In message 1314619606-1172-1-git-send-email-david.wagner@free-electrons.com you wrote:
I think this should be added for compatibility with both the printenv output and the result of "env export -t"
It's easier to go back in the stream without allocating buffers that are at least as big as the file.
What do you mean by "Until a proper way is found"? There is nothing to be found. Just have a look at the "env import" code which does exactly that. Alternatively, as you are only dealing with text format anyway, look if the character immediately preceeding the newline is a backslash:
=> setenv x 'line 1 > line 2' => printenv ... x=line 1\ line 2
Please keep list sorted.
Ditto.
- $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^
Ditto.
- printf("%s [-h] [-r] [-b] [-p <byte>] "
"\n"
"\t\tkey1=value1\n"
"\t\tkey2=value2\n"
"\t\t...\n"
Please s/two/multiple/ or s/two/more than one/ - especially on NAND we can have more than just 2 copies.
fprintf(stderr,
s/envrionnment/environment/
Please fix globally (same error further down below).
- if (optind >= argc) {
Why don;t you allow reading from stdin? It is good old Unix tradition that all commands can be used in pipes. Also, input file name '-' should select stdin.
Um... and why do you call it "configuration file"? It's not configuration data, it's plain input data, so rather call it "input file"
- if (!txt_file) {
fprintf(stderr, "Can't open configuration file \"%s\": %s\n",
Here it's even better to omit the "configuration file " part completely.
- if (ret == -1) {
fprintf(stderr, "Can't stat() on configuration file \"%s\": "
Same here.
- if (txt_file_stat.st_size >= envsize) {
See note above.
envptr[i] = '\0';
This needs braces.
* file)
The double '\0' termination is _always_ necessary. Please avoid constructing special cases where there aren't any.
- if (i < envsize && envptr[i-1] != '\0') {
envptr[i++] = '\0';
if (i >= envsize) {
If you test this here, you can remove the test above.
- bin_file = fopen(bin_filename, "wb");
- if (!bin_file) {
fprintf(stderr, "Can't open output file \"%s\": %s\n",
- if (fwrite(dataptr, sizeof(*dataptr), datasize, bin_file) != datasize) {
Is there any good reason for using stdio functions (fopen(), fread(), fwrite(), fclose()) instead of plain system calls (open(), read(), write(), close()) ?
use case: flash the environment with an external tool
changes since v4 ~~~~~~~~~~~~~~~~
- keep the Makefiles somewhat sorted (I'm not sure how it is sorted but since "mkenvimage" is alphabetically before "mkimage", I put the former just before the latter).
- replace f{open, read, write, ...} with {open, read, write, ...} and remove the now unused stdlib.h include
- tweak usage()
- typos
- properly handle embedded newlines, comments and empty lines at the beginning of the input file. This introduced a second buffer ('filebuf') (see the big for loop): When we encouter a newline after a backslash, without this buffer, we would have needed to shift all envptr one byte backward to overwrite the preceeding backslash. Introducing this second buffer looked like a simpler alternative.
- correct the way how 2 \0 are put at the end of the environment (@Wolfgang: the second "ep >= envsize" check is there to handle the corner case where the env target partition would be, say, 32 bytes long and the input file is 31 byte long but doesn't have an ending newline)
PS: as the input file is probably always pretty small and we read the file sequentially, we don't go back in the stream, we didn't find much advantage over read()
tools/Makefile | 5 + tools/mkenvimage.c | 263 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 268 insertions(+), 0 deletions(-) create mode 100644 tools/mkenvimage.c
diff --git a/tools/Makefile b/tools/Makefile index fc741d3..da7caf0 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -66,6 +66,7 @@ BIN_FILES-$(CONFIG_BUILD_ENVCRC) += envcrc$(SFX) BIN_FILES-$(CONFIG_CMD_NET) += gen_eth_addr$(SFX) BIN_FILES-$(CONFIG_CMD_LOADS) += img2srec$(SFX) BIN_FILES-$(CONFIG_XWAY_SWAP_BYTES) += xway-swap-bytes$(SFX) +BIN_FILES-y += mkenvimage$(SFX) BIN_FILES-y += mkimage$(SFX) BIN_FILES-$(CONFIG_NETCONSOLE) += ncb$(SFX) BIN_FILES-$(CONFIG_SHA1_CHECK_UB_IMG) += ubsha1$(SFX) @@ -89,6 +90,7 @@ OBJ_FILES-$(CONFIG_XWAY_SWAP_BYTES) += xway-swap-bytes.o NOPED_OBJ_FILES-y += kwbimage.o NOPED_OBJ_FILES-y += imximage.o NOPED_OBJ_FILES-y += omapimage.o +NOPED_OBJ_FILES-y += mkenvimage.o NOPED_OBJ_FILES-y += mkimage.o OBJ_FILES-$(CONFIG_NETCONSOLE) += ncb.o NOPED_OBJ_FILES-y += os_support.o @@ -184,6 +186,9 @@ $(obj)xway-swap-bytes$(SFX): $(obj)xway-swap-bytes.o $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ $(HOSTSTRIP) $@
+$(obj)mkenvimage$(SFX): $(obj)crc32.o $(obj)mkenvimage.o + $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ + $(obj)mkimage$(SFX): $(obj)crc32.o \ $(obj)default_image.o \ $(obj)fit_image.o \ diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c new file mode 100644 index 0000000..8aaa5ce --- /dev/null +++ b/tools/mkenvimage.c @@ -0,0 +1,263 @@ +/* + * (C) Copyright 2011 Free Electrons + * David Wagner david.wagner@free-electrons.com + * + * Inspired from envcrc.c: + * (C) Copyright 2001 + * Paolo Scaffardi, AIRVENT SAM s.p.a - RIMINI(ITALY), arsenio@tin.it + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <errno.h> +#include <fcntl.h> +#include <stdio.h> +#include <stdint.h> +#include <string.h> +#include <unistd.h> +#include <compiler.h> +#include <sys/types.h> +#include <sys/stat.h> + +#include <u-boot/crc.h> + +#define CRC_SIZE sizeof(uint32_t) + +static void usage(const char *exec_name) +{ + fprintf(stderr, "%s [-h] [-r] [-b] [-p <byte>] " + "-s <envrionment partition size> -o <output> <input file>\n" + "\n" + "This tool takes a key=value input file (same as would a " + "`printenv' show) and generates the corresponding environment " + "image, ready to be flashed.\n" + "\n" + "\tThe input file is in format:\n" + "\t\tkey1=value1\n" + "\t\tkey2=value2\n" + "\t\t...\n" + "\t-r : the environment has multiple copies in flash\n" + "\t-b : the target is big endian (default is little endian)\n" + "\t-p <byte> : fill the image with <byte> bytes instead of " + "0xff bytes\n" + "\n" + "If the input file is "-", data is read from standard input\n", + exec_name); +} + +int main(int argc, char **argv) +{ + uint32_t crc, targetendian_crc; + const char *txt_filename = NULL, *bin_filename = NULL; + int txt_fd, bin_fd; + unsigned char *dataptr, *envptr; + unsigned char *filebuf; + unsigned int envsize, datasize = 0; + int bigendian = 0; + int redundant = 0; + unsigned char padbyte = 0xff; + + int option; + int ret = EXIT_SUCCESS; + + struct stat txt_file_stat; + + int fp, ep; + + /* Parse the cmdline */ + while ((option = getopt(argc, argv, "s:o:rbp:h")) != -1) { + switch (option) { + case 's': + datasize = strtol(optarg, NULL, 0); + break; + case 'o': + bin_filename = strdup(optarg); + if (!bin_filename) { + fprintf(stderr, "Can't strdup() the output " + "filename\n"); + return EXIT_FAILURE; + } + break; + case 'r': + redundant = 1; + break; + case 'b': + bigendian = 1; + break; + case 'p': + padbyte = strtol(optarg, NULL, 0); + break; + case 'h': + usage(argv[0]); + return EXIT_SUCCESS; + default: + fprintf(stderr, "Wrong option -%c\n", option); + usage(argv[0]); + return EXIT_FAILURE; + } + } + + /* Check datasize and allocate the data */ + if (datasize == 0) { + fprintf(stderr, + "Please specify the size of the envrionnment " + "partition.\n"); + usage(argv[0]); + return EXIT_FAILURE; + } + + dataptr = malloc(datasize * sizeof(*dataptr)); + if (!dataptr) { + fprintf(stderr, "Can't alloc dataptr.\n"); + return EXIT_FAILURE; + } + + /* + * envptr points to the beginning of the actual environment (after the + * crc and possible `redundant' bit + */ + envsize = datasize - (CRC_SIZE + redundant); + envptr = dataptr + CRC_SIZE + redundant; + + /* Pad the environment with the padding byte */ + memset(envptr, padbyte, envsize); + + /* Open the input file ... */ + if (optind >= argc) { + fprintf(stderr, "Please specify an input filename\n"); + return EXIT_FAILURE; + } + + txt_filename = argv[optind]; + if (strcmp(txt_filename, "-") == 0) { + txt_fd = STDIN_FILENO; + } else { + txt_fd = open(txt_filename, O_RDONLY); + if (txt_fd == -1) { + fprintf(stderr, "Can't open "%s": %s\n", + txt_filename, strerror(errno)); + return EXIT_FAILURE; + } + } + /* ... and check it */ + ret = fstat(txt_fd, &txt_file_stat); + if (ret == -1) { + fprintf(stderr, "Can't stat() on "%s": " + "%s\n", txt_filename, strerror(errno)); + return EXIT_FAILURE; + } + /* + * The right test to do is "=>" (not ">") because of the additionnal + * ending \0. See below. + */ + if (txt_file_stat.st_size >= envsize) { + fprintf(stderr, "The input file is larger than the " + "envrionnment partition size\n"); + return EXIT_FAILURE; + } + + /* Read the raw input file and transform it */ + filebuf = malloc(sizeof(*envptr) * txt_file_stat.st_size); + ret = read(txt_fd, filebuf, sizeof(*envptr) * txt_file_stat.st_size); + if (ret != txt_file_stat.st_size) { + fprintf(stderr, "Can't read the whole input file\n"); + return EXIT_FAILURE; + } + ret = close(txt_fd); + + /* Replace newlines separating variables with \0 */ + for (fp = 0, ep = 0 ; fp < txt_file_stat.st_size ; fp++) { + /* TODO: what happens if we find a \n at the beginning of the + * file ? + */ + if (filebuf[fp] == '\n') { + if (fp == 0) { + /* + * Newline at the beggining of the file ? + * Ignore it. + */ + continue; + } else if (filebuf[fp-1] == '\') { + /* + * Embedded newline in a variable. + * + * The backslash was added to the envptr ; + * rewind and replace it with a newline + */ + ep--; + envptr[ep++] = '\n'; + } else { + /* End of a variable */ + envptr[ep++] = '\0'; + } + } else if (filebuf[fp] == '#') { + if (fp != 0 && filebuf[fp-1] == '\n') { + /* This line is a comment, let's skip it */ + while (fp < txt_file_stat.st_size && fp++ && + filebuf[fp] != '\n'); + } else { + envptr[ep++] = filebuf[fp]; + } + } else { + envptr[ep++] = filebuf[fp]; + } + } + /* + * Make sure there is a final '\0' + * And do it again on the next byte to mark the end of the environment. + */ + if (envptr[ep-1] != '\0') { + envptr[ep++] = '\0'; + /* + * The text file doesn't have an ending newline. We need to + * check the env size again to make sure we have room for two \0 + */ + if (ep >= envsize) { + fprintf(stderr, "The environment file is too large for " + "the target environment storage\n"); + return EXIT_FAILURE; + } + envptr[ep] = '\0'; + } else { + envptr[ep] = '\0'; + } + + /* Computes the CRC and put it at the beginning of the data */ + crc = crc32(0, envptr, envsize); + targetendian_crc = bigendian ? cpu_to_be32(crc) : cpu_to_le32(crc); + + memcpy(dataptr, &targetendian_crc, sizeof(uint32_t)); + + bin_fd = creat(bin_filename, S_IRUSR | S_IWUSR | S_IRGRP | S_IWGRP); + if (bin_fd == -1) { + fprintf(stderr, "Can't open output file "%s": %s\n", + bin_filename, strerror(errno)); + return EXIT_FAILURE; + } + + if (write(bin_fd, dataptr, sizeof(*dataptr) * datasize) != + sizeof(*dataptr) * datasize) { + fprintf(stderr, "write() failed: %s\n", strerror(errno)); + return EXIT_FAILURE; + } + + ret = close(bin_fd); + + return ret; +}
- if (strcmp(txt_filename, "-") == 0) {
- } else {
if (txt_fd == -1) {
fprintf(stderr, "Can't open \"%s\": %s\n",
- ret = fstat(txt_fd, &txt_file_stat);
- if (ret == -1) {
fprintf(stderr, "Can't stat() on \"%s\": "
- /* Read the raw input file and transform it */
- filebuf = malloc(sizeof(*envptr) * txt_file_stat.st_size);
- ret = read(txt_fd, filebuf, sizeof(*envptr) * txt_file_stat.st_size);
- if (ret != txt_file_stat.st_size) {
i think the stdin logic here is broken. when you fstat() stdin, you get back st_size == 0, and so you end up doing a read() on stdin of 0 bytes, and it writes out an empty image.
simple test: echo foo=var | ./mkenvimage -s 0x1000 -o foo - hexdump -C foo <see that the env is empty>
running it through strace shows the bum read(0, "", 0) ... -mike
changes since v5 ~~~~~~~~~~~~~~~~
- fix reading from stdin
- remove an obsolete TODO
tools/Makefile | 5 + tools/mkenvimage.c | 270 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 275 insertions(+), 0 deletions(-) create mode 100644 tools/mkenvimage.c
+$(obj)mkenvimage$(SFX): $(obj)crc32.o $(obj)mkenvimage.o + $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ + $(obj)mkimage$(SFX): $(obj)crc32.o \ $(obj)default_image.o \ $(obj)fit_image.o \ diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c new file mode 100644 index 0000000..c2636fd --- /dev/null +++ b/tools/mkenvimage.c @@ -0,0 +1,270 @@ +/* + * (C) Copyright 2011 Free Electrons + * David Wagner david.wagner@free-electrons.com + * + * Inspired from envcrc.c: + * (C) Copyright 2001 + * Paolo Scaffardi, AIRVENT SAM s.p.a - RIMINI(ITALY), arsenio@tin.it + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <errno.h> +#include <fcntl.h> +#include <stdio.h> +#include <stdint.h> +#include <string.h> +#include <unistd.h> +#include <compiler.h> +#include <sys/types.h> +#include <sys/stat.h> + +#include <u-boot/crc.h> + +#define CRC_SIZE sizeof(uint32_t) + +static void usage(const char *exec_name) +{ + fprintf(stderr, "%s [-h] [-r] [-b] [-p <byte>] " + "-s <envrionment partition size> -o <output> <input file>\n" + "\n" + "This tool takes a key=value input file (same as would a " + "`printenv' show) and generates the corresponding environment " + "image, ready to be flashed.\n" + "\n" + "\tThe input file is in format:\n" + "\t\tkey1=value1\n" + "\t\tkey2=value2\n" + "\t\t...\n" + "\t-r : the environment has multiple copies in flash\n" + "\t-b : the target is big endian (default is little endian)\n" + "\t-p <byte> : fill the image with <byte> bytes instead of " + "0xff bytes\n" + "\n" + "If the input file is "-", data is read from standard input\n", + exec_name); +} + +int main(int argc, char **argv) +{ + uint32_t crc, targetendian_crc; + const char *txt_filename = NULL, *bin_filename = NULL; + int txt_fd, bin_fd; + unsigned char *dataptr, *envptr; + unsigned char *filebuf = NULL; + unsigned int filesize = 0, envsize = 0, datasize = 0; + int bigendian = 0; + int redundant = 0; + unsigned char padbyte = 0xff; + + int option; + int ret = EXIT_SUCCESS; + + struct stat txt_file_stat; + + int fp, ep; + + /* Parse the cmdline */ + while ((option = getopt(argc, argv, "s:o:rbp:h")) != -1) { + switch (option) { + case 's': + datasize = strtol(optarg, NULL, 0); + break; + case 'o': + bin_filename = strdup(optarg); + if (!bin_filename) { + fprintf(stderr, "Can't strdup() the output " + "filename\n"); + return EXIT_FAILURE; + } + break; + case 'r': + redundant = 1; + break; + case 'b': + bigendian = 1; + break; + case 'p': + padbyte = strtol(optarg, NULL, 0); + break; + case 'h': + usage(argv[0]); + return EXIT_SUCCESS; + default: + fprintf(stderr, "Wrong option -%c\n", option); + usage(argv[0]); + return EXIT_FAILURE; + } + } + + /* Check datasize and allocate the data */ + if (datasize == 0) { + fprintf(stderr, + "Please specify the size of the envrionnment " + "partition.\n"); + usage(argv[0]); + return EXIT_FAILURE; + } + + dataptr = malloc(datasize * sizeof(*dataptr)); + if (!dataptr) { + fprintf(stderr, "Can't alloc dataptr.\n"); + return EXIT_FAILURE; + } + + /* + * envptr points to the beginning of the actual environment (after the + * crc and possible `redundant' bit + */ + envsize = datasize - (CRC_SIZE + redundant); + envptr = dataptr + CRC_SIZE + redundant; + + /* Pad the environment with the padding byte */ + memset(envptr, padbyte, envsize); + + /* Open the input file ... */ + if (optind >= argc) { + fprintf(stderr, "Please specify an input filename\n"); + return EXIT_FAILURE; + } + + txt_filename = argv[optind]; + if (strcmp(txt_filename, "-") == 0) { + int readbytes = 0; + int readlen = sizeof(*envptr) * 2048; + txt_fd = STDIN_FILENO; + + do { + filebuf = realloc(filebuf, readlen); + readbytes = read(txt_fd, filebuf + filesize, readlen); + filesize += readbytes; + } while (readbytes == readlen); + + } else { + txt_fd = open(txt_filename, O_RDONLY); + if (txt_fd == -1) { + fprintf(stderr, "Can't open "%s": %s\n", + txt_filename, strerror(errno)); + return EXIT_FAILURE; + } + /* ... and check it */ + ret = fstat(txt_fd, &txt_file_stat); + if (ret == -1) { + fprintf(stderr, "Can't stat() on "%s": " + "%s\n", txt_filename, strerror(errno)); + return EXIT_FAILURE; + } + + filesize = txt_file_stat.st_size; + /* Read the raw input file and transform it */ + filebuf = malloc(sizeof(*envptr) * filesize); + ret = read(txt_fd, filebuf, sizeof(*envptr) * filesize); + if (ret != sizeof(*envptr) * filesize) { + fprintf(stderr, "Can't read the whole input file\n"); + return EXIT_FAILURE; + } + ret = close(txt_fd); + } + /* + * The right test to do is "=>" (not ">") because of the additionnal + * ending \0. See below. + */ + if (filesize >= envsize) { + fprintf(stderr, "The input file is larger than the " + "envrionnment partition size\n"); + return EXIT_FAILURE; + } + + /* Replace newlines separating variables with \0 */ + for (fp = 0, ep = 0 ; fp < filesize ; fp++) { + if (filebuf[fp] == '\n') { + if (fp == 0) { + /* + * Newline at the beggining of the file ? + * Ignore it. + */ + continue; + } else if (filebuf[fp-1] == '\') { + /* + * Embedded newline in a variable. + * + * The backslash was added to the envptr ; + * rewind and replace it with a newline + */ + ep--; + envptr[ep++] = '\n'; + } else { + /* End of a variable */ + envptr[ep++] = '\0'; + } + } else if (filebuf[fp] == '#') { + if (fp != 0 && filebuf[fp-1] == '\n') { + /* This line is a comment, let's skip it */ + while (fp < txt_file_stat.st_size && fp++ && + filebuf[fp] != '\n'); + } else { + envptr[ep++] = filebuf[fp]; + } + } else { + envptr[ep++] = filebuf[fp]; + } + } + /* + * Make sure there is a final '\0' + * And do it again on the next byte to mark the end of the environment. + */ + if (envptr[ep-1] != '\0') { + envptr[ep++] = '\0'; + /* + * The text file doesn't have an ending newline. We need to + * check the env size again to make sure we have room for two \0 + */ + if (ep >= envsize) { + fprintf(stderr, "The environment file is too large for " + "the target environment storage\n"); + return EXIT_FAILURE; + } + envptr[ep] = '\0'; + } else { + envptr[ep] = '\0'; + } + + /* Computes the CRC and put it at the beginning of the data */ + crc = crc32(0, envptr, envsize); + targetendian_crc = bigendian ? cpu_to_be32(crc) : cpu_to_le32(crc); + + memcpy(dataptr, &targetendian_crc, sizeof(uint32_t)); + + bin_fd = creat(bin_filename, S_IRUSR | S_IWUSR | S_IRGRP | S_IWGRP); + if (bin_fd == -1) { + fprintf(stderr, "Can't open output file "%s": %s\n", + bin_filename, strerror(errno)); + return EXIT_FAILURE; + } + + if (write(bin_fd, dataptr, sizeof(*dataptr) * datasize) != + sizeof(*dataptr) * datasize) { + fprintf(stderr, "write() failed: %s\n", strerror(errno)); + return EXIT_FAILURE; + } + + ret = close(bin_fd); + + return ret; +}
oops, subject is missing "v6". I just resent a correct version.
David
Acked-by: Mike Frysinger vapier@gentoo.org -mike
Hello,
Le Fri, 2 Sep 2011 10:48:03 +0200, David Wagner david.wagner@free-electrons.com a écrit :
^^^^^^ typo
Thomas
Signed-off-by: David Wagner david.wagner@free-electrons.com Acked-by; Mike Frysinger vapier@gentoo.org Tested-by: Thomas Petazzoni thomas.petazzoni@free-electrons.com ---
changes since v6: ~~~~~~~~~~~~~~~~~
* fix a typo * add Mike's Acked-by and Thomas' Tested-by
+$(obj)mkenvimage$(SFX): $(obj)crc32.o $(obj)mkenvimage.o + $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ + $(obj)mkimage$(SFX): $(obj)crc32.o \ $(obj)default_image.o \ $(obj)fit_image.o \ diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c new file mode 100644 index 0000000..9c32f4a --- /dev/null +++ b/tools/mkenvimage.c @@ -0,0 +1,270 @@ +/* + * (C) Copyright 2011 Free Electrons + * David Wagner david.wagner@free-electrons.com + * + * Inspired from envcrc.c: + * (C) Copyright 2001 + * Paolo Scaffardi, AIRVENT SAM s.p.a - RIMINI(ITALY), arsenio@tin.it + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <errno.h> +#include <fcntl.h> +#include <stdio.h> +#include <stdint.h> +#include <string.h> +#include <unistd.h> +#include <compiler.h> +#include <sys/types.h> +#include <sys/stat.h> + +#include <u-boot/crc.h> + +#define CRC_SIZE sizeof(uint32_t) + +static void usage(const char *exec_name) +{ + fprintf(stderr, "%s [-h] [-r] [-b] [-p <byte>] " + "-s <environment partition size> -o <output> <input file>\n" + "\n" + "This tool takes a key=value input file (same as would a " + "`printenv' show) and generates the corresponding environment " + "image, ready to be flashed.\n" + "\n" + "\tThe input file is in format:\n" + "\t\tkey1=value1\n" + "\t\tkey2=value2\n" + "\t\t...\n" + "\t-r : the environment has multiple copies in flash\n" + "\t-b : the target is big endian (default is little endian)\n" + "\t-p <byte> : fill the image with <byte> bytes instead of " + "0xff bytes\n" + "\n" + "If the input file is "-", data is read from standard input\n", + exec_name); +} + +int main(int argc, char **argv) +{ + uint32_t crc, targetendian_crc; + const char *txt_filename = NULL, *bin_filename = NULL; + int txt_fd, bin_fd; + unsigned char *dataptr, *envptr; + unsigned char *filebuf = NULL; + unsigned int filesize = 0, envsize = 0, datasize = 0; + int bigendian = 0; + int redundant = 0; + unsigned char padbyte = 0xff; + + int option; + int ret = EXIT_SUCCESS; + + struct stat txt_file_stat; + + int fp, ep; + + /* Parse the cmdline */ + while ((option = getopt(argc, argv, "s:o:rbp:h")) != -1) { + switch (option) { + case 's': + datasize = strtol(optarg, NULL, 0); + break; + case 'o': + bin_filename = strdup(optarg); + if (!bin_filename) { + fprintf(stderr, "Can't strdup() the output " + "filename\n"); + return EXIT_FAILURE; + } + break; + case 'r': + redundant = 1; + break; + case 'b': + bigendian = 1; + break; + case 'p': + padbyte = strtol(optarg, NULL, 0); + break; + case 'h': + usage(argv[0]); + return EXIT_SUCCESS; + default: + fprintf(stderr, "Wrong option -%c\n", option); + usage(argv[0]); + return EXIT_FAILURE; + } + } + + /* Check datasize and allocate the data */ + if (datasize == 0) { + fprintf(stderr, + "Please specify the size of the envrionnment " + "partition.\n"); + usage(argv[0]); + return EXIT_FAILURE; + } + + dataptr = malloc(datasize * sizeof(*dataptr)); + if (!dataptr) { + fprintf(stderr, "Can't alloc dataptr.\n"); + return EXIT_FAILURE; + } + + /* + * envptr points to the beginning of the actual environment (after the + * crc and possible `redundant' bit + */ + envsize = datasize - (CRC_SIZE + redundant); + envptr = dataptr + CRC_SIZE + redundant; + + /* Pad the environment with the padding byte */ + memset(envptr, padbyte, envsize); + + /* Open the input file ... */ + if (optind >= argc) { + fprintf(stderr, "Please specify an input filename\n"); + return EXIT_FAILURE; + } + + txt_filename = argv[optind]; + if (strcmp(txt_filename, "-") == 0) { + int readbytes = 0; + int readlen = sizeof(*envptr) * 2048; + txt_fd = STDIN_FILENO; + + do { + filebuf = realloc(filebuf, readlen); + readbytes = read(txt_fd, filebuf + filesize, readlen); + filesize += readbytes; + } while (readbytes == readlen); + + } else { + txt_fd = open(txt_filename, O_RDONLY); + if (txt_fd == -1) { + fprintf(stderr, "Can't open "%s": %s\n", + txt_filename, strerror(errno)); + return EXIT_FAILURE; + } + /* ... and check it */ + ret = fstat(txt_fd, &txt_file_stat); + if (ret == -1) { + fprintf(stderr, "Can't stat() on "%s": " + "%s\n", txt_filename, strerror(errno)); + return EXIT_FAILURE; + } + + filesize = txt_file_stat.st_size; + /* Read the raw input file and transform it */ + filebuf = malloc(sizeof(*envptr) * filesize); + ret = read(txt_fd, filebuf, sizeof(*envptr) * filesize); + if (ret != sizeof(*envptr) * filesize) { + fprintf(stderr, "Can't read the whole input file\n"); + return EXIT_FAILURE; + } + ret = close(txt_fd); + } + /* + * The right test to do is "=>" (not ">") because of the additionnal + * ending \0. See below. + */ + if (filesize >= envsize) { + fprintf(stderr, "The input file is larger than the " + "envrionnment partition size\n"); + return EXIT_FAILURE; + } + + /* Replace newlines separating variables with \0 */ + for (fp = 0, ep = 0 ; fp < filesize ; fp++) { + if (filebuf[fp] == '\n') { + if (fp == 0) { + /* + * Newline at the beggining of the file ? + * Ignore it. + */ + continue; + } else if (filebuf[fp-1] == '\') { + /* + * Embedded newline in a variable. + * + * The backslash was added to the envptr ; + * rewind and replace it with a newline + */ + ep--; + envptr[ep++] = '\n'; + } else { + /* End of a variable */ + envptr[ep++] = '\0'; + } + } else if (filebuf[fp] == '#') { + if (fp != 0 && filebuf[fp-1] == '\n') { + /* This line is a comment, let's skip it */ + while (fp < txt_file_stat.st_size && fp++ && + filebuf[fp] != '\n'); + } else { + envptr[ep++] = filebuf[fp]; + } + } else { + envptr[ep++] = filebuf[fp]; + } + } + /* + * Make sure there is a final '\0' + * And do it again on the next byte to mark the end of the environment. + */ + if (envptr[ep-1] != '\0') { + envptr[ep++] = '\0'; + /* + * The text file doesn't have an ending newline. We need to + * check the env size again to make sure we have room for two \0 + */ + if (ep >= envsize) { + fprintf(stderr, "The environment file is too large for " + "the target environment storage\n"); + return EXIT_FAILURE; + } + envptr[ep] = '\0'; + } else { + envptr[ep] = '\0'; + } + + /* Computes the CRC and put it at the beginning of the data */ + crc = crc32(0, envptr, envsize); + targetendian_crc = bigendian ? cpu_to_be32(crc) : cpu_to_le32(crc); + + memcpy(dataptr, &targetendian_crc, sizeof(uint32_t)); + + bin_fd = creat(bin_filename, S_IRUSR | S_IWUSR | S_IRGRP | S_IWGRP); + if (bin_fd == -1) { + fprintf(stderr, "Can't open output file "%s": %s\n", + bin_filename, strerror(errno)); + return EXIT_FAILURE; + } + + if (write(bin_fd, dataptr, sizeof(*dataptr) * datasize) != + sizeof(*dataptr) * datasize) { + fprintf(stderr, "write() failed: %s\n", strerror(errno)); + return EXIT_FAILURE; + } + + ret = close(bin_fd); + + return ret; +}
change since v7:
add a missing header (stdlib.h)
tools/Makefile | 5 + tools/mkenvimage.c | 271 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 276 insertions(+), 0 deletions(-) create mode 100644 tools/mkenvimage.c
+$(obj)mkenvimage$(SFX): $(obj)crc32.o $(obj)mkenvimage.o + $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ + $(obj)mkimage$(SFX): $(obj)crc32.o \ $(obj)default_image.o \ $(obj)fit_image.o \ diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c new file mode 100644 index 0000000..ad2c8d3 --- /dev/null +++ b/tools/mkenvimage.c @@ -0,0 +1,271 @@ +/* + * (C) Copyright 2011 Free Electrons + * David Wagner david.wagner@free-electrons.com + * + * Inspired from envcrc.c: + * (C) Copyright 2001 + * Paolo Scaffardi, AIRVENT SAM s.p.a - RIMINI(ITALY), arsenio@tin.it + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <errno.h> +#include <fcntl.h> +#include <stdio.h> +#include <stdlib.h> +#include <stdint.h> +#include <string.h> +#include <unistd.h> +#include <compiler.h> +#include <sys/types.h> +#include <sys/stat.h> + +#include <u-boot/crc.h> + +#define CRC_SIZE sizeof(uint32_t) + +static void usage(const char *exec_name) +{ + fprintf(stderr, "%s [-h] [-r] [-b] [-p <byte>] " + "-s <environment partition size> -o <output> <input file>\n" + "\n" + "This tool takes a key=value input file (same as would a " + "`printenv' show) and generates the corresponding environment " + "image, ready to be flashed.\n" + "\n" + "\tThe input file is in format:\n" + "\t\tkey1=value1\n" + "\t\tkey2=value2\n" + "\t\t...\n" + "\t-r : the environment has multiple copies in flash\n" + "\t-b : the target is big endian (default is little endian)\n" + "\t-p <byte> : fill the image with <byte> bytes instead of " + "0xff bytes\n" + "\n" + "If the input file is "-", data is read from standard input\n", + exec_name); +} + +int main(int argc, char **argv) +{ + uint32_t crc, targetendian_crc; + const char *txt_filename = NULL, *bin_filename = NULL; + int txt_fd, bin_fd; + unsigned char *dataptr, *envptr; + unsigned char *filebuf = NULL; + unsigned int filesize = 0, envsize = 0, datasize = 0; + int bigendian = 0; + int redundant = 0; + unsigned char padbyte = 0xff; + + int option; + int ret = EXIT_SUCCESS; + + struct stat txt_file_stat; + + int fp, ep; + + /* Parse the cmdline */ + while ((option = getopt(argc, argv, "s:o:rbp:h")) != -1) { + switch (option) { + case 's': + datasize = strtol(optarg, NULL, 0); + break; + case 'o': + bin_filename = strdup(optarg); + if (!bin_filename) { + fprintf(stderr, "Can't strdup() the output " + "filename\n"); + return EXIT_FAILURE; + } + break; + case 'r': + redundant = 1; + break; + case 'b': + bigendian = 1; + break; + case 'p': + padbyte = strtol(optarg, NULL, 0); + break; + case 'h': + usage(argv[0]); + return EXIT_SUCCESS; + default: + fprintf(stderr, "Wrong option -%c\n", option); + usage(argv[0]); + return EXIT_FAILURE; + } + } + + /* Check datasize and allocate the data */ + if (datasize == 0) { + fprintf(stderr, + "Please specify the size of the envrionnment " + "partition.\n"); + usage(argv[0]); + return EXIT_FAILURE; + } + + dataptr = malloc(datasize * sizeof(*dataptr)); + if (!dataptr) { + fprintf(stderr, "Can't alloc dataptr.\n"); + return EXIT_FAILURE; + } + + /* + * envptr points to the beginning of the actual environment (after the + * crc and possible `redundant' bit + */ + envsize = datasize - (CRC_SIZE + redundant); + envptr = dataptr + CRC_SIZE + redundant; + + /* Pad the environment with the padding byte */ + memset(envptr, padbyte, envsize); + + /* Open the input file ... */ + if (optind >= argc) { + fprintf(stderr, "Please specify an input filename\n"); + return EXIT_FAILURE; + } + + txt_filename = argv[optind]; + if (strcmp(txt_filename, "-") == 0) { + int readbytes = 0; + int readlen = sizeof(*envptr) * 2048; + txt_fd = STDIN_FILENO; + + do { + filebuf = realloc(filebuf, readlen); + readbytes = read(txt_fd, filebuf + filesize, readlen); + filesize += readbytes; + } while (readbytes == readlen); + + } else { + txt_fd = open(txt_filename, O_RDONLY); + if (txt_fd == -1) { + fprintf(stderr, "Can't open "%s": %s\n", + txt_filename, strerror(errno)); + return EXIT_FAILURE; + } + /* ... and check it */ + ret = fstat(txt_fd, &txt_file_stat); + if (ret == -1) { + fprintf(stderr, "Can't stat() on "%s": " + "%s\n", txt_filename, strerror(errno)); + return EXIT_FAILURE; + } + + filesize = txt_file_stat.st_size; + /* Read the raw input file and transform it */ + filebuf = malloc(sizeof(*envptr) * filesize); + ret = read(txt_fd, filebuf, sizeof(*envptr) * filesize); + if (ret != sizeof(*envptr) * filesize) { + fprintf(stderr, "Can't read the whole input file\n"); + return EXIT_FAILURE; + } + ret = close(txt_fd); + } + /* + * The right test to do is "=>" (not ">") because of the additionnal + * ending \0. See below. + */ + if (filesize >= envsize) { + fprintf(stderr, "The input file is larger than the " + "envrionnment partition size\n"); + return EXIT_FAILURE; + } + + /* Replace newlines separating variables with \0 */ + for (fp = 0, ep = 0 ; fp < filesize ; fp++) { + if (filebuf[fp] == '\n') { + if (fp == 0) { + /* + * Newline at the beggining of the file ? + * Ignore it. + */ + continue; + } else if (filebuf[fp-1] == '\') { + /* + * Embedded newline in a variable. + * + * The backslash was added to the envptr ; + * rewind and replace it with a newline + */ + ep--; + envptr[ep++] = '\n'; + } else { + /* End of a variable */ + envptr[ep++] = '\0'; + } + } else if (filebuf[fp] == '#') { + if (fp != 0 && filebuf[fp-1] == '\n') { + /* This line is a comment, let's skip it */ + while (fp < txt_file_stat.st_size && fp++ && + filebuf[fp] != '\n'); + } else { + envptr[ep++] = filebuf[fp]; + } + } else { + envptr[ep++] = filebuf[fp]; + } + } + /* + * Make sure there is a final '\0' + * And do it again on the next byte to mark the end of the environment. + */ + if (envptr[ep-1] != '\0') { + envptr[ep++] = '\0'; + /* + * The text file doesn't have an ending newline. We need to + * check the env size again to make sure we have room for two \0 + */ + if (ep >= envsize) { + fprintf(stderr, "The environment file is too large for " + "the target environment storage\n"); + return EXIT_FAILURE; + } + envptr[ep] = '\0'; + } else { + envptr[ep] = '\0'; + } + + /* Computes the CRC and put it at the beginning of the data */ + crc = crc32(0, envptr, envsize); + targetendian_crc = bigendian ? cpu_to_be32(crc) : cpu_to_le32(crc); + + memcpy(dataptr, &targetendian_crc, sizeof(uint32_t)); + + bin_fd = creat(bin_filename, S_IRUSR | S_IWUSR | S_IRGRP | S_IWGRP); + if (bin_fd == -1) { + fprintf(stderr, "Can't open output file "%s": %s\n", + bin_filename, strerror(errno)); + return EXIT_FAILURE; + } + + if (write(bin_fd, dataptr, sizeof(*dataptr) * datasize) != + sizeof(*dataptr) * datasize) { + fprintf(stderr, "write() failed: %s\n", strerror(errno)); + return EXIT_FAILURE; + } + + ret = close(bin_fd); + + return ret; +}
Dear David Wagner,
In message 1317367880-13986-1-git-send-email-david.wagner@free-electrons.com you wrote:
change since v7:
Checkpatch says:
total: 1 errors, 0 warnings, 294 lines checked
Please clean up and resubmit. Thanks.
Signed-off-by: David Wagner david.wagner@free-electrons.com Acked-by; Mike Frysinger vapier@gentoo.org Tested-by: Thomas Petazzoni thomas.petazzoni@free-electrons.com --- (My first try to send it seems to have failed ; please disregard if it actually suceeded)
change since v8 ~~~~~~~~~~~~~~~
* Make checkpatch happy by putting an instruction out of a while(). Incidently, it also fixes a possible segfault (in the event of a comment being at the end of a file that hasn't an ending newline).
tools/Makefile | 5 + tools/mkenvimage.c | 272 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 277 insertions(+), 0 deletions(-) create mode 100644 tools/mkenvimage.c
+$(obj)mkenvimage$(SFX): $(obj)crc32.o $(obj)mkenvimage.o + $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ + $(obj)mkimage$(SFX): $(obj)crc32.o \ $(obj)default_image.o \ $(obj)fit_image.o \ diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c new file mode 100644 index 0000000..2c7fbe7 --- /dev/null +++ b/tools/mkenvimage.c @@ -0,0 +1,272 @@ +/* + * (C) Copyright 2011 Free Electrons + * David Wagner david.wagner@free-electrons.com + * + * Inspired from envcrc.c: + * (C) Copyright 2001 + * Paolo Scaffardi, AIRVENT SAM s.p.a - RIMINI(ITALY), arsenio@tin.it + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <errno.h> +#include <fcntl.h> +#include <stdio.h> +#include <stdlib.h> +#include <stdint.h> +#include <string.h> +#include <unistd.h> +#include <compiler.h> +#include <sys/types.h> +#include <sys/stat.h> + +#include <u-boot/crc.h> + +#define CRC_SIZE sizeof(uint32_t) + +static void usage(const char *exec_name) +{ + fprintf(stderr, "%s [-h] [-r] [-b] [-p <byte>] " + "-s <environment partition size> -o <output> <input file>\n" + "\n" + "This tool takes a key=value input file (same as would a " + "`printenv' show) and generates the corresponding environment " + "image, ready to be flashed.\n" + "\n" + "\tThe input file is in format:\n" + "\t\tkey1=value1\n" + "\t\tkey2=value2\n" + "\t\t...\n" + "\t-r : the environment has multiple copies in flash\n" + "\t-b : the target is big endian (default is little endian)\n" + "\t-p <byte> : fill the image with <byte> bytes instead of " + "0xff bytes\n" + "\n" + "If the input file is "-", data is read from standard input\n", + exec_name); +} + +int main(int argc, char **argv) +{ + uint32_t crc, targetendian_crc; + const char *txt_filename = NULL, *bin_filename = NULL; + int txt_fd, bin_fd; + unsigned char *dataptr, *envptr; + unsigned char *filebuf = NULL; + unsigned int filesize = 0, envsize = 0, datasize = 0; + int bigendian = 0; + int redundant = 0; + unsigned char padbyte = 0xff; + + int option; + int ret = EXIT_SUCCESS; + + struct stat txt_file_stat; + + int fp, ep; + + /* Parse the cmdline */ + while ((option = getopt(argc, argv, "s:o:rbp:h")) != -1) { + switch (option) { + case 's': + datasize = strtol(optarg, NULL, 0); + break; + case 'o': + bin_filename = strdup(optarg); + if (!bin_filename) { + fprintf(stderr, "Can't strdup() the output " + "filename\n"); + return EXIT_FAILURE; + } + break; + case 'r': + redundant = 1; + break; + case 'b': + bigendian = 1; + break; + case 'p': + padbyte = strtol(optarg, NULL, 0); + break; + case 'h': + usage(argv[0]); + return EXIT_SUCCESS; + default: + fprintf(stderr, "Wrong option -%c\n", option); + usage(argv[0]); + return EXIT_FAILURE; + } + } + + /* Check datasize and allocate the data */ + if (datasize == 0) { + fprintf(stderr, + "Please specify the size of the envrionnment " + "partition.\n"); + usage(argv[0]); + return EXIT_FAILURE; + } + + dataptr = malloc(datasize * sizeof(*dataptr)); + if (!dataptr) { + fprintf(stderr, "Can't alloc dataptr.\n"); + return EXIT_FAILURE; + } + + /* + * envptr points to the beginning of the actual environment (after the + * crc and possible `redundant' bit + */ + envsize = datasize - (CRC_SIZE + redundant); + envptr = dataptr + CRC_SIZE + redundant; + + /* Pad the environment with the padding byte */ + memset(envptr, padbyte, envsize); + + /* Open the input file ... */ + if (optind >= argc) { + fprintf(stderr, "Please specify an input filename\n"); + return EXIT_FAILURE; + } + + txt_filename = argv[optind]; + if (strcmp(txt_filename, "-") == 0) { + int readbytes = 0; + int readlen = sizeof(*envptr) * 2048; + txt_fd = STDIN_FILENO; + + do { + filebuf = realloc(filebuf, readlen); + readbytes = read(txt_fd, filebuf + filesize, readlen); + filesize += readbytes; + } while (readbytes == readlen); + + } else { + txt_fd = open(txt_filename, O_RDONLY); + if (txt_fd == -1) { + fprintf(stderr, "Can't open "%s": %s\n", + txt_filename, strerror(errno)); + return EXIT_FAILURE; + } + /* ... and check it */ + ret = fstat(txt_fd, &txt_file_stat); + if (ret == -1) { + fprintf(stderr, "Can't stat() on "%s": " + "%s\n", txt_filename, strerror(errno)); + return EXIT_FAILURE; + } + + filesize = txt_file_stat.st_size; + /* Read the raw input file and transform it */ + filebuf = malloc(sizeof(*envptr) * filesize); + ret = read(txt_fd, filebuf, sizeof(*envptr) * filesize); + if (ret != sizeof(*envptr) * filesize) { + fprintf(stderr, "Can't read the whole input file\n"); + return EXIT_FAILURE; + } + ret = close(txt_fd); + } + /* + * The right test to do is "=>" (not ">") because of the additionnal + * ending \0. See below. + */ + if (filesize >= envsize) { + fprintf(stderr, "The input file is larger than the " + "envrionnment partition size\n"); + return EXIT_FAILURE; + } + + /* Replace newlines separating variables with \0 */ + for (fp = 0, ep = 0 ; fp < filesize ; fp++) { + if (filebuf[fp] == '\n') { + if (fp == 0) { + /* + * Newline at the beggining of the file ? + * Ignore it. + */ + continue; + } else if (filebuf[fp-1] == '\') { + /* + * Embedded newline in a variable. + * + * The backslash was added to the envptr ; + * rewind and replace it with a newline + */ + ep--; + envptr[ep++] = '\n'; + } else { + /* End of a variable */ + envptr[ep++] = '\0'; + } + } else if (filebuf[fp] == '#') { + if (fp != 0 && filebuf[fp-1] == '\n') { + /* This line is a comment, let's skip it */ + while (fp < txt_file_stat.st_size && + filebuf[fp] != '\n') + fp++; + } else { + envptr[ep++] = filebuf[fp]; + } + } else { + envptr[ep++] = filebuf[fp]; + } + } + /* + * Make sure there is a final '\0' + * And do it again on the next byte to mark the end of the environment. + */ + if (envptr[ep-1] != '\0') { + envptr[ep++] = '\0'; + /* + * The text file doesn't have an ending newline. We need to + * check the env size again to make sure we have room for two \0 + */ + if (ep >= envsize) { + fprintf(stderr, "The environment file is too large for " + "the target environment storage\n"); + return EXIT_FAILURE; + } + envptr[ep] = '\0'; + } else { + envptr[ep] = '\0'; + } + + /* Computes the CRC and put it at the beginning of the data */ + crc = crc32(0, envptr, envsize); + targetendian_crc = bigendian ? cpu_to_be32(crc) : cpu_to_le32(crc); + + memcpy(dataptr, &targetendian_crc, sizeof(uint32_t)); + + bin_fd = creat(bin_filename, S_IRUSR | S_IWUSR | S_IRGRP | S_IWGRP); + if (bin_fd == -1) { + fprintf(stderr, "Can't open output file "%s": %s\n", + bin_filename, strerror(errno)); + return EXIT_FAILURE; + } + + if (write(bin_fd, dataptr, sizeof(*dataptr) * datasize) != + sizeof(*dataptr) * datasize) { + fprintf(stderr, "write() failed: %s\n", strerror(errno)); + return EXIT_FAILURE; + } + + ret = close(bin_fd); + + return ret; +}
Hi David,
There's a semi-colon instead of a colon - this might make the tools choke.
Cheers Detlev
Signed-off-by: David Wagner david.wagner@free-electrons.com Acked-by: Mike Frysinger vapier@gentoo.org Tested-by: Thomas Petazzoni thomas.petazzoni@free-electrons.com --- change since v9: ~~~~~~~~~~~~~~~~
* fix a typo in the commit message spotted by Detlev Zundel
Hello,
Le Fri, 14 Oct 2011 19:16:56 +0200, David Wagner david.wagner@free-electrons.com a écrit :
Unless there are further comments, would it be possible to get this merged for the upcoming U-Boot, or is the merge window already closed?
Thanks!
Thomas
Dear David Wagner,
In message 1318612616-16799-1-git-send-email-david.wagner@free-electrons.com you wrote:
This patch fails to build when I try to run a plain "make tools/mkenvimage":
tools/mkenvimage.c:35:22: fatal error: compiler.h: No such file or directory
tools/mkenvimage.c:39:24: fatal error: u-boot/crc.h: No such file or directory
- /* Parse the cmdline */
- while ((option = getopt(argc, argv, "s:o:rbp:h")) != -1) {
switch (option) {
case 's':
Please add error checking for invalid input formats here.
- if (datasize == 0) {
fprintf(stderr,
"partition.\n");
Please don't split that string, and fix the "envrionment" typo.
- dataptr = malloc(datasize * sizeof(*dataptr));
- if (!dataptr) {
It might be helpful to know how many bytes you were trying to allocate.
s/bit/byte/
- /* Open the input file ... */
Please also allow to use stdin as input when no "<input file>" arg is given.
do {
This is pretty much inefficient. Consider a size increment of something like min(readlen, 4096).
Also, realloc() can fail - add error handling.
And read() can fail, too - add error handling.
Why don't you just use mmap() here?
- if (filesize >= envsize) {
Please don't split such strings. See CodingStyle:
"However, never break user-visible strings such as printk messages, because that breaks the ability to grep for them."
Please fix globally.
fp++;
} else {
printenv output does not contain any such "comments". And - aren't you also catching embedded hashes here, like in "serial#" for example?
- /* Computes the CRC and put it at the beginning of the data */
- crc = crc32(0, envptr, envsize);
- targetendian_crc = bigendian ? cpu_to_be32(crc) : cpu_to_le32(crc);
- memcpy(dataptr, &targetendian_crc, sizeof(uint32_t));
I fail to see where you set the redundant flag?
tools/mkenvimage.c:35:22: fatal error: compiler.h: No such file or directory tools/mkenvimage.c:39:24: fatal error: u-boot/crc.h: No such file or directory
i think that's expected. if you do `make tools`, does it build correctly ? -mike
Applied to u-boot-staging, sbabic@denx.de, thanks.
Best regards, Stefano Babic
participants (7)
Albert ARIBAUD
David Wagner
Detlev Zundel
Mike Frysinger
Stefano Babic
Thomas Petazzoni
