Re: [U-Boot] [PATCH 11/13 v5] ARM: OMAP3: Add EVM board
Dear Wolfgang,
Wolfgang Denk wrote:
Dear Jean-Christophe PLAGNIOL-VILLARD,
In message 20081109150321.GF25307@game.jcrosoft.org you wrote:
- i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE);
+#if defined(CONFIG_CMD_NET)
- setup_net_chip();
- Routine: set_muxconf_regs
- Description: Setting up the configuration Mux registers specific to the
hardware. Many pins need to be moved from protect to primary
mode.
+void set_muxconf_regs(void) +{
- MUX_EVM();
- Routine: setup_net_chip
- Description: Setting up the configuration GPMC registers specific to the
Ethernet hardware. Pin Muxing for the SMC9118 is initialized
here.
+static int setup_net_chip(void) +{
in this function please add some blank line to make the code more readable
- int i = 0;
- /* Configure GPMC registers */
- (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x0150)) = 0x00001000;
- (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x0154)) = 0x001e1e01;
- (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x0158)) = 0x00080300;
- (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x015C)) = 0x1c091c09;
- (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x0160)) = 0x04181f1f;
- (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x0164)) = 0x00000FCF;
- (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x0168)) = 0x00000f6c;
- /* Configure PIN MUX registers */
- /* Enable GPMC Pin Mux Registers */
- /* Enable GPMC_CLK Pin in CONTROL_PADCONF_gpmc_ncs7 register */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xBC)) |= 0x00180000;
- /* Enable CS5 Pin in CONTROL_PADCONF_gpmc_ncs5 register */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xB8)) |= 0x00000018;
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xB8)) &= 0xFFFFFFF8;
- /* Enable offmode for nwe in CONTROL_PADCONF_GPMC_NWE register */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xC4)) |= 0x00000F00;
- /* En off mode for noe and ale in CONTROL_PADCONF_GPMC_NADV_ALE reg */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xC0)) |= 0x0E000E00;
- /* Enable gpmc_nbe0_cle in CONTROL_PADCONF_GPMC_NWE register */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xC4)) |= 0x00180000;
- /* Enable gpmc_nbe1 in CONTROL_PADCONF_GPMC_NBE1 register and
- configuring the mux mode to 0 */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xC8)) |= 0x00000018;
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xC8)) &= 0xFFFFFFF8;
- /* Enable d15 in CONTROL_PADCONF_GPMC_D15 register */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xAC)) |= 0x00000018;
- /* Enable d14 - d13 in CONTROL_PADCONF_GPMC_D13 register */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xA8)) |= 0x00180018;
- /* Enable d12 - d11 in CONTROL_PADCONF_GPMC_D11 register */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xA4)) |= 0x00180018;
- /* Enable d10 - d9 in CONTROL_PADCONF_GPMC_D9 register */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xA0)) |= 0x00180018;
- /* Enable d8 - d7 in CONTROL_PADCONF_GPMC_D7 register */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x9C)) |= 0x00180018;
- /* Enable d6 - d5 in CONTROL_PADCONF_GPMC_D5 register */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x98)) |= 0x00180018;
And please use accessor functions / macros to access the registers. Access through volatile pointers is considered a Bad Thing (TM).
Sorry for not mentioning this earlier, but you don't have to comment on
a) readx/writex accessor functions / macros b) hardcoded values vs. speaking macros
These are known issues of OMAP3 patch set I will fix step by step. Once we send the "final" OMAP3 patch set to the mailing list, if I missed something, then you are welcome to comment on it, though ;)
Thanks for your review and best regards
Dirk
Dirk Behme
