[U-Boot] [PATCH] atmel, at91: fix taurus board
since commit: f8b7fff1d5c5 "serial: atmel_usart: Add clk support"
taurus board comes not up anymore. Fix it.
Signed-off-by: Heiko Schocher hs@denx.de ---
arch/arm/dts/at91sam9g20-taurus.dts | 2 ++ board/siemens/taurus/taurus.c | 9 --------- configs/taurus_defconfig | 3 +++ 3 files changed, 5 insertions(+), 9 deletions(-)
diff --git a/arch/arm/dts/at91sam9g20-taurus.dts b/arch/arm/dts/at91sam9g20-taurus.dts index f27d772..7931c0a 100644 --- a/arch/arm/dts/at91sam9g20-taurus.dts +++ b/arch/arm/dts/at91sam9g20-taurus.dts @@ -18,6 +18,7 @@ compatible = "atmel,at91sam9g20ek", "atmel,at91sam9g20", "atmel,at91sam9";
chosen { + u-boot,dm-pre-reloc; stdout-path = &dbgu; };
@@ -48,6 +49,7 @@ };
dbgu: serial@fffff200 { + u-boot,dm-pre-reloc; status = "okay"; };
diff --git a/board/siemens/taurus/taurus.c b/board/siemens/taurus/taurus.c index 8da24be..4aa8d64 100644 --- a/board/siemens/taurus/taurus.c +++ b/board/siemens/taurus/taurus.c @@ -448,12 +448,3 @@ U_BOOT_CMD( ); #endif #endif - -static struct atmel_serial_platdata at91sam9260_serial_plat = { - .base_addr = ATMEL_BASE_DBGU, -}; - -U_BOOT_DEVICE(at91sam9260_serial) = { - .name = "serial_atmel", - .platdata = &at91sam9260_serial_plat, -}; diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 2de9cad..70d44a7 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -7,6 +7,7 @@ CONFIG_TARGET_TAURUS=y CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x1000 CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_SPI_FLASH_SUPPORT=y @@ -36,6 +37,8 @@ CONFIG_CMD_PING=y # CONFIG_DOS_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y CONFIG_DFU_NAND=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y
Thank you.
Acked-by: Wenyou Yang wenyou.yang@microchip.com
chosen {
stdout-path = &dbgu; };u-boot,dm-pre-reloc;
Best Regards, Wenyou Yang
Signed-off-by: Heiko Schocher hs@denx.de Acked-by: Wenyou Yang wenyou.yang@microchip.com
Heiko Schocher
Yang, Wenyou
