[U-Boot] [PATCH] pico-imx6ul: Add USB Host support
Add USB host support.
Tested by connecting a USB pen drive:
=> usb start starting USB... USB0: Port not available. USB1: USB EHCI 1.00 scanning bus 1 for devices... 2 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found
Signed-off-by: Vanessa Maegima vanessa.maegima@nxp.com --- board/technexion/pico-imx6ul/pico-imx6ul.c | 24 +++++++++++++++++++++++- include/configs/pico-imx6ul.h | 2 +- 2 files changed, 24 insertions(+), 2 deletions(-)
diff --git a/board/technexion/pico-imx6ul/pico-imx6ul.c b/board/technexion/pico-imx6ul/pico-imx6ul.c index c038d43..bdf32f4 100644 --- a/board/technexion/pico-imx6ul/pico-imx6ul.c +++ b/board/technexion/pico-imx6ul/pico-imx6ul.c @@ -59,6 +59,9 @@ static iomux_v3_cfg_t const usdhc1_pads[] = { MX6_PAD_NAND_CLE__USDHC1_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), };
+#define USB_OTHERREGS_OFFSET 0x800 +#define UCTRL_PWR_POL (1 << 9) + static iomux_v3_cfg_t const usb_otg_pad[] = { MX6_PAD_GPIO1_IO00__ANATOP_OTG1_ID | MUX_PAD_CTRL(OTG_ID_PAD_CTRL), }; @@ -98,7 +101,26 @@ int board_early_init_f(void)
int board_usb_phy_mode(int port) { - return USB_INIT_DEVICE; + if (port == 1) + return USB_INIT_HOST; + else + return USB_INIT_DEVICE; +} + +int board_ehci_hcd_init(int port) +{ + u32 *usbnc_usb_ctrl; + + if (port > 1) + return -EINVAL; + + usbnc_usb_ctrl = (u32 *)(USB_BASE_ADDR + USB_OTHERREGS_OFFSET + + port * 4); + + /* Set Power polarity */ + setbits_le32(usbnc_usb_ctrl, UCTRL_PWR_POL); + + return 0; }
int board_init(void) diff --git a/include/configs/pico-imx6ul.h b/include/configs/pico-imx6ul.h index d848ead..01edc03 100644 --- a/include/configs/pico-imx6ul.h +++ b/include/configs/pico-imx6ul.h @@ -42,7 +42,7 @@ #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0 -#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 /* Only OTG1 port enabled */ +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2
#define CONFIG_CI_UDC #define CONFIG_USBD_HS
On Mon, Jun 13, 2016 at 1:01 PM, Vanessa Maegima vanessa.maegima@nxp.com wrote:
Reviewed-by: Fabio Estevam fabio.estevam@nxp.com
Hi Stefano,
Looks like this one did not go into your -next branch yet.
Please consider applying it if you are happy with it.
Thanks
On 11/07/2016 14:41, Fabio Estevam wrote:
Hi Stefano,
Ok, thnaks - I will push it.
Regards, Stefano
Fabio Estevam
Stefano Babic
Vanessa Maegima
