[BUG] efi_loader: incorrect creation of device paths
Hello Takahiro,
in a prior mail we have discussed the creation of device paths for USB mass storage devices.
On the sand boxyou get the following devices after 'usb start':
Class Index Probed Driver Name ----------------------------------------------------------- usb 0 [ + ] usb_sandbox |-- usb@1 usb_hub 0 [ + ] usb_hub | `-- hub usb_mass_s 0 [ + ] usb_mass_storage | |-- usb_mass_storage blk 3 [ ] usb_storage_blk | | `-- usb_mass_storage.lun0 usb_mass_s 1 [ + ] usb_mass_storage | |-- usb_mass_storage blk 4 [ ] usb_storage_blk | | `-- usb_mass_storage.lun0 usb_mass_s 2 [ + ] usb_mass_storage | `-- usb_mass_storage blk 5 [ ] usb_storage_blk | `-- usb_mass_storage.lun0
For of these storage devices we try to create the same device path which is not allowable:
=> usb start starting USB... Bus usb@1: scanning bus usb@1 for devices... 5 USB Device(s) found scanning usb for storage devices... 3 Storage Device(s) found => => efidebug dh Scanning disk mmc2.blk... handle 0000000015e34f00, /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/SD(2)/SD(0) Scanning disk mmc1.blk... handle 0000000015e36b30, /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/SD(1)/SD(1) Scanning disk mmc0.blk... handle 0000000015e35b00, /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/SD(0)/SD(2) Scanning disk usb_mass_storage.lun0... handle 0000000015e35c10, /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/UsbClass(0x1234,0x5678,0x9,0x0,0x0)/UsbClass(0x1234,0x5678,0x0,0x0,0x0) fs_devread read outside partition 2 Failed to mount ext2 filesystem... BTRFS: superblock end 69632 is larger than device size 512 Scanning disk usb_mass_storage.lun0... handle 0000000015e361f0, /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/UsbClass(0x1234,0x5678,0x9,0x0,0x0)/UsbClass(0x1234,0x5678,0x0,0x0,0x0) ERROR: failure to add disk device usb_mass_storage.lun0, r = 20 Error: Cannot initialize UEFI sub-system, r = 20
I will provide a patch that will allow the first USB device to be used and avoids stopping the boot process. But we really have to walk the dm tree to create a device patch for USB devices based on port IDs.
We should add a new field to struct uclass_driver:
struct efi_device_path *get_node(udevice *dev);
This function shall return a pointer to an freshly allocated buffer with the device node for the device. To build the devicepath we can then walk the dm tree.
To make migration easier: If the function pointer or the return value is NULL we can create a CTRL() node as dummy using the uclass_id and the device number.
Best regards
Heinrich
On Sat, Nov 20, 2021 at 01:54:30PM +0100, Heinrich Schuchardt wrote:
Hello Takahiro,
I'm not sure this is an acceptable solution.
Let me make sure: The goal would be to create a device path like .../USB(0x1,0x0)/HD(1,...) instead of .../UsbHub(0x0,0x0,0x0,0x3)/UsbMassStorage(0x46f4,0x1,0x0,0x0)/HD(1,...) as we already see this format for SCSI: .../Scsi(0,0)/HD(1,..)
Right?
-Takahiro Akashi
Best regards
Heinrich
Heinrich,
Hello Takahiro,
Right?
Please try the tweak attached below. (I think what I did here is trivial.)
If you like, I will post it as a patch. (See "10.3.4.5.1 USB Device Path Example".)
-Takahiro Akashi
From cda91e9d8144f89f0d73738b338289a7940bbe0e Mon Sep 17 00:00:00 2001 From: AKASHI Takahiro takahiro.akashi@linaro.org Date: Thu, 25 Nov 2021 14:20:08 +0900 Subject: [PATCH] efi_loader: disk: usb mass-storage
- use path_usb instead of path_usb_class for existing USB dp nodes - add a dp node for UCLASS_USB
=> usb start starting USB... Bus xhci_pci: Register 8001040 NbrPorts 8 Starting the controller USB XHCI 1.00 scanning bus xhci_pci for devices... 4 USB Device(s) found scanning usb for storage devices... 2 Storage Device(s) found => dm tree Class Index Probed Driver Name ----------------------------------------------------------- root 0 [ + ] root_driver root_driver ... pci 0 [ + ] pci_generic_ecam |-- pcie@10000000 pci_generi 0 [ ] pci_generic_drv | |-- pci_0:0.0 virtio 32 [ + ] virtio-pci.l | |-- virtio-pci.l#0 ethernet 0 [ + ] virtio-net | | `-- virtio-net#32 usb 0 [ + ] xhci_pci | `-- xhci_pci usb_hub 0 [ + ] usb_hub | `-- usb_hub usb_dev_ge 0 [ + ] usb_dev_generic_drv | |-- generic_bus_0_dev_2 usb_mass_s 0 [ + ] usb_mass_storage | |-- usb_mass_storage blk 0 [ ] usb_storage_blk | | `-- usb_mass_storage.lun0 usb_mass_s 1 [ + ] usb_mass_storage | `-- usb_mass_storage blk 1 [ ] usb_storage_blk | `-- usb_mass_storage.lun0 ... => efidebug devices Scanning disk usb_mass_storage.lun0... Scanning disk usb_mass_storage.lun0... Found 6 disks Missing RNG device for EFI_RNG_PROTOCOL ** Unable to read file ubootefi.var ** Failed to load EFI variables Unable to find TPMv2 device Device Device Path ================ ==================== 000000013eef3a50 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b) 000000013eefe840 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/USB(0xf3,0x0)/USB(0x0,0x0)/USB(0x2,0x0) 000000013eefe990 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/USB(0xf3,0x0)/USB(0x0,0x0)/USB(0x2,0x0)/HD(1,0x01,0,0x0,0x99800) 000000013eefeae0 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/USB(0xf3,0x0)/USB(0x0,0x0)/USB(0x2,0x0)/HD(2,0x01,0,0x99800,0x1800) 000000013eeff5f0 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/USB(0xf3,0x0)/USB(0x0,0x0)/USB(0x3,0x0) 000000013eeff990 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/USB(0xf3,0x0)/USB(0x0,0x0)/USB(0x3,0x0)/HD(1,GPT,ce86c5a7-b32a-488f-a346-88fe698e0edc,0x22,0x4c2a) 000000013eeffda0 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/USB(0xf3,0x0)/USB(0x0,0x0)/USB(0x3,0x0)/HD(2,GPT,aa80aab9-33e6-42b6-b5db-def2cb8d7844,0x5000,0x1a800) 000000013ef00270 /VenHw(e61d73b9-a384-4acc-aeab-82e828f3628b)/MAC(525252525252,1)
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- lib/efi_loader/efi_device_path.c | 36 ++++++++++++++++++++++-- lib/efi_loader/efi_device_path_to_text.c | 17 ++++++++--- 2 files changed, 47 insertions(+), 6 deletions(-)
diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index 735ed0bd0f4c..a8ec6809c422 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -557,10 +557,18 @@ __maybe_unused static unsigned int dp_size(struct udevice *dev) return dp_size(dev->parent) + sizeof(struct efi_device_path_sd_mmc_path); #endif +#if 1 + case UCLASS_USB: + case UCLASS_USB_HUB: + case UCLASS_MASS_STORAGE: + return dp_size(dev->parent) + + sizeof(struct efi_device_path_usb); +#else case UCLASS_MASS_STORAGE: case UCLASS_USB_HUB: return dp_size(dev->parent) + sizeof(struct efi_device_path_usb_class); +#endif default: /* just skip over unknown classes: */ return dp_size(dev->parent); @@ -740,6 +748,24 @@ __maybe_unused static void *dp_fill(void *buf, struct udevice *dev) return &sddp[1]; } #endif +#if 1 + case UCLASS_USB: + case UCLASS_USB_HUB: + case UCLASS_MASS_STORAGE: { + struct efi_device_path_usb *udp = + dp_fill(buf, dev->parent); + struct usb_device *udev = dev_get_parent_priv(dev); + + udp->dp.type = DEVICE_PATH_TYPE_MESSAGING_DEVICE; + udp->dp.sub_type = DEVICE_PATH_SUB_TYPE_MSG_USB; + udp->dp.length = sizeof(*udp); + udp->parent_port_number = udev->portnr; + /* TODO: see usb_new_device() */ + udp->usb_interface = 0; + + return &udp[1]; + } +#else case UCLASS_MASS_STORAGE: case UCLASS_USB_HUB: { struct efi_device_path_usb_class *udp = @@ -750,14 +776,20 @@ __maybe_unused static void *dp_fill(void *buf, struct udevice *dev) udp->dp.type = DEVICE_PATH_TYPE_MESSAGING_DEVICE; udp->dp.sub_type = DEVICE_PATH_SUB_TYPE_MSG_USB_CLASS; udp->dp.length = sizeof(*udp); - udp->vendor_id = desc->idVendor; - udp->product_id = desc->idProduct; +#if 1 + if (dev->driver->id == UCLASS_MASS_STORAGE) + udp->device_class = 8; + else if (dev->driver->id == UCLASS_USB_HUB) + udp->device_class = 9; +#else udp->device_class = desc->bDeviceClass; +#endif udp->device_subclass = desc->bDeviceSubClass; udp->device_protocol = desc->bDeviceProtocol;
return &udp[1]; } +#endif default: debug("%s(%u) %s: unhandled device class: %s (%u)\n", __FILE__, __LINE__, __func__, diff --git a/lib/efi_loader/efi_device_path_to_text.c b/lib/efi_loader/efi_device_path_to_text.c index 57fa9d97f712..a21de4157307 100644 --- a/lib/efi_loader/efi_device_path_to_text.c +++ b/lib/efi_loader/efi_device_path_to_text.c @@ -158,10 +158,19 @@ static char *dp_msging(char *s, struct efi_device_path *dp) struct efi_device_path_usb_class *ucdp = (struct efi_device_path_usb_class *)dp;
- s += sprintf(s, "UsbClass(0x%x,0x%x,0x%x,0x%x,0x%x)", - ucdp->vendor_id, ucdp->product_id, - ucdp->device_class, ucdp->device_subclass, - ucdp->device_protocol); + if (ucdp->device_class == 8) + s += sprintf(s, "UsbMassStorage(0x%x,0x%x,0x%x,0x%x)", + ucdp->vendor_id, ucdp->product_id, + ucdp->device_subclass, ucdp->device_protocol); + else if (ucdp->device_class == 9) + s += sprintf(s, "UsbHub(0x%x,0x%x,0x%x,0x%x)", + ucdp->vendor_id, ucdp->product_id, + ucdp->device_subclass, ucdp->device_protocol); + else + s += sprintf(s, "UsbClass(0x%x,0x%x,0x%x,0x%x,0x%x)", + ucdp->vendor_id, ucdp->product_id, + ucdp->device_class, ucdp->device_subclass, + ucdp->device_protocol);
break; }
Heinrich,
On Thu, Nov 25, 2021 at 02:44:28PM +0900, AKASHI Takahiro wrote:
Heinrich,
Hello Takahiro,
Right?
Any comment on my proposal?
-Takahiro Akashi
- case UCLASS_USB:
- case UCLASS_USB_HUB:
- case UCLASS_MASS_STORAGE:
- case UCLASS_USB:
- case UCLASS_MASS_STORAGE: {
return &udp[1];
+#if 1
return &udp[1];
else
break; }
-- 2.33.0
On 11/25/21 06:44, AKASHI Takahiro wrote:
Heinrich,
Hello Takahiro,
Right?
-Takahiro Akashi
I am missing a PCI() node here for the USB root Hub. In the DM tree: Is xhci_pci the root hub and usb_hub a hub connected to this root hub? Or do both nodes together model a root hub? Anyway USB(0xf3,0x0) seems to be wrong. There is no USB hub with a port 243.
Please, see the examples on p. 303ff of the UEFI 2.9 specification:
PciRoot(0)/PCI(31,2)/USB(0,0) PciRoot(0)/PCI(31,2)/USB(1,0)/USB(3,0)
The first example is a USB controller connected to port 0 of the root hub. The second is a USB controller connected to port 3 of a USB hub which is connected to port 1 of the root hub.
Best regards
Heinrich
- case UCLASS_USB:
- case UCLASS_USB:
return &udp[1];
+#if 1
return &udp[1];
else
break; }
Heinrich,
Hello Takahiro,
Right?
-Takahiro Akashi
As the code suggests, the path was generated this way:
/VenHw(...)/ USB(0xf3,0x0)/ <= usb_controller (xhci_pci) USB(0x0,0x0)/ <= usb_hub USB(0x3,0x0)/ <= usb_mass_storage HD(1,GPT,...)
USB(0xf3,0x0) was incorrectly encoded here, instead we will be able to generate PCI(xx,yy) by examining struct pci_child_plat *pplat = dev_get_parent_plat(dev); xx = PCI_DEV(pplat->devfn), yy = PCI_FUNC(pplat->devfn) if the dev's parent is a PCI (controller).
But we will have to confirm that this is the only case that we need to take care of the parent's bus. Please note that any kind of pci component is not encoded in a device path under the current UEFI implementation on U-Boot.
So do you agree that this is a right approach even if it will break some sort of compatibility (of device path representation) with the current U-Boot UEFI implementation?
-Takahiro Akashi
Best regards
Heinrich
- case UCLASS_USB:
- case UCLASS_USB:
return &udp[1];
+#if 1
return &udp[1];
else
break; }
Date: Mon, 6 Dec 2021 13:16:23 +0900 From: AKASHI Takahiro takahiro.akashi@linaro.org
Heinrich,
Hello Takahiro,
Right?
-Takahiro Akashi
You'll need to take into account any PCI-PCI bridges, so you need to do this in a loop, walking up the tree until you encounter the PCI host bridge / root complex ("PciRoot").
The stadard also is of the opinion that PciRoot needs to be an ACPI device path entry, which obviously doesn't make sense in a DT context. Using VenHW makes more sense, but maybe UEFI needs to grow support for proper DT device path entries...
This will break any Boot#### variables that have been set by users isn't it? I guess there is no way to avoid that, but it probably is a good idea to only break it once.
Hi Mark,
Thank you for the comment.
Heinrich,
Hello Takahiro,
Right?
-Takahiro Akashi
> From cda91e9d8144f89f0d73738b338289a7940bbe0e Mon Sep 17 00:00:00 2001 > From: AKASHI Takahiro takahiro.akashi@linaro.org > Date: Thu, 25 Nov 2021 14:20:08 +0900 > Subject: [PATCH] efi_loader: disk: usb mass-storage
Yes, you're right, but the current U-Boot's DM framework doesn't model the root complex. Instead, calling pci_get_controller() would be enough. (Need confirm this.)
-> Simon?
Yeah, the current VenHW(e61d73b9-a384-4acc-aeab-82e828f3628b) represents "efi_root" in our UEFI implementation and it is another incompatibility with other UEFI firmware.
After all, we might want to insert a dummy PciRoot(0) (as EDK2 does?).
Indeed.
-Takahiro Akashi
Heinrich,
Hello Takahiro,
Right?
-Takahiro Akashi
Best regards
Heinrich
The USB() node is for devices attached to a USB port of the parent device.
The UEFI specification requires:
"Devices that do not have a serial number string must use the USB Device Path (type 5) as described in USB Device Path Example"
but you don't set a serial number here.
Subtype 15 (= DEVICE_PATH_SUB_TYPE_MSG_USB_CLASS) translates to UsbMassStorage(). This does not look correct for a USB hub.
Best regards
Heinrich
break; }
AKASHI Takahiro
Mark Kettenis
