RE: [U-Boot-Users] u-boot 834x spd_ram
When is mentioned "cs" i meant the DDR bank cs bounds. In cpu/mpc83xx/spd_ram.c. They are hardcoded to be 2 and 3. Shouldn't this come from the config ? cpu/mpc83xx/spd_ram.c should be a common code for any 83xx based board not only the freescale board which have the DDR module in the back of the board.
cheers
-----Original Message----- From: u-boot-users-admin@lists.sourceforge.net [mailto:u-boot-users-admin@lists.sourceforge.net]On Behalf Of Ben Warren Sent: Tuesday, April 18, 2006 10:08 AM To: Jerry Van Baren Cc: u-boot-users@lists.sourceforge.net Subject: Re: [U-Boot-Users] u-boot 834x spd_ram
Jerry,
The 83xx chips have a separate memory bus for DDR, with its own chip selects. For these chips, you do in fact need to use the local bus CS0 for your boot flash/EEPROM.
I can't find anything in the manual that differentiates between the DDR chip selects, so using CS2/3 was probably just a design choice.
regards, Ben
On Tue, 2006-04-18 at 10:02 -0400, Jerry Van Baren wrote:
Aziz Mzili wrote:
Hi
I'm wondering why in cpu/83xx/spd_ram.c we expect the DDR ram to be on
cs2 and cs3. Is there any issue with it on cs0 and cs1 ?
thank you
Aziz Mzili
I'm not a 834x expert, but all my experience is that CS0 is used to boot
the processor. If it is DDR RAM rather than flash, someone other than
the 834x must initialize the DDR RAM and load it with the boot program.
That is possible, but very uncommon.
gvb
This SF.Net email is sponsored by xPML, a groundbreaking scripting language
that extends applications into web and mobile media. Attend the live webcast
and join the prime developer group breaking into this new coding territory!
http://sel.as-us.falkag.net/sel?cmd=lnk http://sel.as-us.falkag.net/sel?cmd=lnk&kid=110944&bid=241720&dat=121642 &kid=110944&bid=241720&dat=121642
_______________________________________________
U-Boot-Users mailing list
U-Boot-Users@lists.sourceforge.net
Aziz Mzili
