[U-Boot] [PATCH v9 1/8] ppa/fm/qe: use block layer in ppa/fm/qe driver
At present the MMC subsystem maintains its own list of MMC devices. This cannot work with driver model when CONFIG_BLK is enabled, use blk_dread to replace previous mmc read interface, use mmc_get_blk_desc to get the mmc device property
Signed-off-by: Yinbo Zhu yinbo.zhu@nxp.com --- Change in v9: fix ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig compiling errors
arch/arm/cpu/armv8/fsl-layerscape/ppa.c | 7 +++---- drivers/net/fm/fm.c | 2 +- drivers/qe/qe.c | 2 +- 3 files changed, 5 insertions(+), 6 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ppa.c b/arch/arm/cpu/armv8/fsl-layerscape/ppa.c index a31c4d9..d391f93 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ppa.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ppa.c @@ -99,7 +99,7 @@ int ppa_init(void) cnt = DIV_ROUND_UP(fdt_header_len, 512); debug("%s: MMC read PPA FIT header: dev # %u, block # %u, count %u\n", __func__, dev, blk, cnt); - ret = mmc->block_dev.block_read(&mmc->block_dev, blk, cnt, fitp); + ret = blk_dread(mmc_get_blk_desc(mmc), blk, cnt, fitp); if (ret != cnt) { free(fitp); printf("MMC/SD read of PPA FIT header at offset 0x%x failed\n", @@ -123,7 +123,7 @@ int ppa_init(void)
blk = CONFIG_SYS_LS_PPA_ESBC_ADDR >> 9; cnt = DIV_ROUND_UP(CONFIG_LS_PPA_ESBC_HDR_SIZE, 512); - ret = mmc->block_dev.block_read(&mmc->block_dev, blk, cnt, ppa_hdr_ddr); + ret = blk_dread(mmc_get_blk_desc(mmc), blk, cnt, ppa_hdr_ddr); if (ret != cnt) { free(ppa_hdr_ddr); printf("MMC/SD read of PPA header failed\n"); @@ -149,8 +149,7 @@ int ppa_init(void) cnt = DIV_ROUND_UP(fw_length, 512); debug("%s: MMC read PPA FIT image: dev # %u, block # %u, count %u\n", __func__, dev, blk, cnt); - ret = mmc->block_dev.block_read(&mmc->block_dev, - blk, cnt, ppa_fit_addr); + ret = blk_dread(mmc_get_blk_desc(mmc), blk, cnt, ppa_fit_addr); if (ret != cnt) { free(ppa_fit_addr); printf("MMC/SD read of PPA FIT header at offset 0x%x failed\n", diff --git a/drivers/net/fm/fm.c b/drivers/net/fm/fm.c index 3327073..c5cf188 100644 --- a/drivers/net/fm/fm.c +++ b/drivers/net/fm/fm.c @@ -402,7 +402,7 @@ int fm_init_common(int index, struct ccsr_fman *reg) printf("\nMMC read: dev # %u, block # %u, count %u ...\n", dev, blk, cnt); mmc_init(mmc); - (void)mmc->block_dev.block_read(&mmc->block_dev, blk, cnt, + (void)blk_dread(mmc_get_blk_desc(mmc), blk, cnt, addr); } #elif defined(CONFIG_SYS_QE_FMAN_FW_IN_REMOTE) diff --git a/drivers/qe/qe.c b/drivers/qe/qe.c index 7654df8..7010bbc 100644 --- a/drivers/qe/qe.c +++ b/drivers/qe/qe.c @@ -218,7 +218,7 @@ void u_qe_init(void) printf("\nMMC read: dev # %u, block # %u, count %u ...\n", dev, blk, cnt); mmc_init(mmc); - (void)mmc->block_dev.block_read(&mmc->block_dev, blk, cnt, + (void)blk_dread(mmc_get_blk_desc(mmc), blk, cnt, addr); } #endif
This patch adds esdhc clock support for ls1088a and ls2088a.
.../arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c | 14 ++++++++++++++ 1 files changed, 14 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c index 653c6dd..bc268e2 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch3_speed.c @@ -192,6 +192,16 @@ int get_dspi_freq(ulong dummy) return get_bus_freq(0) / CONFIG_SYS_FSL_DSPI_CLK_DIV; }
+#ifdef CONFIG_FSL_ESDHC +int get_sdhc_freq(ulong dummy) +{ + if (!gd->arch.sdhc_clk) + get_clocks(); + + return gd->arch.sdhc_clk; +} +#endif + int get_serial_clock(void) { return get_bus_freq(0) / CONFIG_SYS_FSL_DUART_CLK_DIV; @@ -202,6 +212,10 @@ unsigned int mxc_get_clock(enum mxc_clock clk) switch (clk) { case MXC_I2C_CLK: return get_i2c_freq(0); +#if defined(CONFIG_FSL_ESDHC) + case MXC_ESDHC_CLK: + return get_sdhc_freq(0); +#endif case MXC_DSPI_CLK: return get_dspi_freq(0); default:
This patch is to add eSDHC node for ls2088a.
arch/arm/dts/fsl-ls2080a.dtsi | 8 ++++++++ 1 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/arch/arm/dts/fsl-ls2080a.dtsi b/arch/arm/dts/fsl-ls2080a.dtsi index b0f8517..2d537ae 100644 --- a/arch/arm/dts/fsl-ls2080a.dtsi +++ b/arch/arm/dts/fsl-ls2080a.dtsi @@ -75,6 +75,14 @@ num-cs = <4>; };
+ esdhc: esdhc@0 { + compatible = "fsl,esdhc"; + reg = <0x0 0x2140000 0x0 0x10000>; + interrupts = <0 28 0x4>; /* Level high type */ + little-endian; + bus-width = <4>; + }; + usb0: usb3@3100000 { compatible = "fsl,layerscape-dwc3"; reg = <0x0 0x3100000 0x0 0x10000>;
This patch is to add eSDHC node for ls1088a.
arch/arm/dts/fsl-ls1088a.dtsi | 9 +++++++++ 1 files changed, 9 insertions(+), 0 deletions(-)
diff --git a/arch/arm/dts/fsl-ls1088a.dtsi b/arch/arm/dts/fsl-ls1088a.dtsi index 077caf3..72d755a 100644 --- a/arch/arm/dts/fsl-ls1088a.dtsi +++ b/arch/arm/dts/fsl-ls1088a.dtsi @@ -74,6 +74,15 @@ reg-names = "QuadSPI", "QuadSPI-memory"; num-cs = <4>; }; + + esdhc: esdhc@2140000 { + compatible = "fsl,esdhc"; + reg = <0x0 0x2140000 0x0 0x10000>; + interrupts = <0 28 0x4>; /* Level high type */ + little-endian; + bus-width = <4>; + }; + ifc: ifc@1530000 { compatible = "fsl,ifc", "simple-bus"; reg = <0x0 0x2240000 0x0 0x20000>;
This patch is to add eSDHC node for ls1043a.
arch/arm/dts/fsl-ls1043a.dtsi | 8 ++++++++ 1 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/arch/arm/dts/fsl-ls1043a.dtsi b/arch/arm/dts/fsl-ls1043a.dtsi index ff40122..a804f51 100644 --- a/arch/arm/dts/fsl-ls1043a.dtsi +++ b/arch/arm/dts/fsl-ls1043a.dtsi @@ -70,6 +70,14 @@ status = "disabled"; };
+ esdhc: esdhc@1560000 { + compatible = "fsl,esdhc"; + reg = <0x0 0x1560000 0x0 0x10000>; + interrupts = <0 62 0x4>; + big-endian; + bus-width = <4>; + }; + ifc: ifc@1530000 { compatible = "fsl,ifc", "simple-bus"; reg = <0x0 0x1530000 0x0 0x10000>;
This patch is to add eSDHC node for ls1046a.
arch/arm/dts/fsl-ls1046a.dtsi | 8 ++++++++ 1 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/arch/arm/dts/fsl-ls1046a.dtsi b/arch/arm/dts/fsl-ls1046a.dtsi index 4acbaf7..7687d12 100644 --- a/arch/arm/dts/fsl-ls1046a.dtsi +++ b/arch/arm/dts/fsl-ls1046a.dtsi @@ -70,6 +70,14 @@ status = "disabled"; };
This patch is to enable eSDHC for ls1021a.
arch/arm/dts/ls1021a.dtsi | 1 - 1 files changed, 0 insertions(+), 1 deletions(-)
diff --git a/arch/arm/dts/ls1021a.dtsi b/arch/arm/dts/ls1021a.dtsi index 5b3fc6a..59c97d5 100644 --- a/arch/arm/dts/ls1021a.dtsi +++ b/arch/arm/dts/ls1021a.dtsi @@ -96,7 +96,6 @@ sdhci,auto-cmd12; big-endian; bus-width = <4>; - status = "disabled"; };
scfg: scfg@1570000 {
This enables the folowing to Kconfig: CONFIG_BLK CONFIG_DM_MMC
configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 2 ++ configs/ls1021atwr_nor_defconfig | 2 ++ configs/ls1021atwr_nor_lpuart_defconfig | 2 ++ configs/ls1021atwr_qspi_defconfig | 2 ++ configs/ls1021atwr_sdcard_ifc_defconfig | 2 ++ configs/ls1021atwr_sdcard_qspi_defconfig | 2 ++ configs/ls1043aqds_defconfig | 2 ++ configs/ls1043aqds_lpuart_defconfig | 2 ++ configs/ls1043aqds_nand_defconfig | 2 ++ configs/ls1043aqds_nor_ddr3_defconfig | 2 ++ configs/ls1043aqds_qspi_defconfig | 2 ++ configs/ls1043aqds_sdcard_ifc_defconfig | 2 ++ configs/ls1043aqds_sdcard_qspi_defconfig | 2 ++ configs/ls1043ardb_SECURE_BOOT_defconfig | 2 ++ configs/ls1043ardb_defconfig | 2 ++ configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 2 ++ configs/ls1043ardb_nand_defconfig | 2 ++ configs/ls1043ardb_sdcard_defconfig | 2 ++ configs/ls1046aqds_SECURE_BOOT_defconfig | 2 ++ configs/ls1046aqds_defconfig | 2 ++ configs/ls1046aqds_lpuart_defconfig | 2 ++ configs/ls1046aqds_nand_defconfig | 2 ++ configs/ls1046aqds_qspi_defconfig | 2 ++ configs/ls1046aqds_sdcard_ifc_defconfig | 2 ++ configs/ls1046aqds_sdcard_qspi_defconfig | 2 ++ configs/ls1046ardb_emmc_defconfig | 2 ++ configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 2 ++ configs/ls1046ardb_qspi_defconfig | 2 ++ configs/ls1046ardb_sdcard_defconfig | 2 ++ configs/ls1088aqds_defconfig | 2 ++ configs/ls1088aqds_qspi_SECURE_BOOT_defconfig | 2 ++ configs/ls1088aqds_qspi_defconfig | 2 ++ configs/ls1088aqds_sdcard_ifc_defconfig | 2 ++ configs/ls1088aqds_sdcard_qspi_defconfig | 2 ++ configs/ls1088ardb_qspi_SECURE_BOOT_defconfig | 2 ++ configs/ls1088ardb_qspi_defconfig | 2 ++ configs/ls1088ardb_sdcard_qspi_defconfig | 2 ++ configs/ls2080a_emu_defconfig | 2 ++ configs/ls2080a_simu_defconfig | 2 ++ configs/ls2080aqds_SECURE_BOOT_defconfig | 2 ++ configs/ls2080aqds_defconfig | 2 ++ configs/ls2080aqds_nand_defconfig | 2 ++ configs/ls2080aqds_qspi_defconfig | 2 ++ configs/ls2080aqds_sdcard_defconfig | 2 ++ configs/ls2080ardb_SECURE_BOOT_defconfig | 2 ++ configs/ls2080ardb_defconfig | 2 ++ configs/ls2080ardb_nand_defconfig | 2 ++ configs/ls2088ardb_qspi_SECURE_BOOT_defconfig | 2 ++ configs/ls2088ardb_qspi_defconfig | 2 ++ 49 files changed, 98 insertions(+), 0 deletions(-)
diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index 17a202d..4d85983 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -48,3 +48,5 @@ CONFIG_VIDEO=y # CONFIG_VIDEO_SW_CURSOR is not set CONFIG_RSA=y CONFIG_SPL_RSA=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index a18426e..f4f7998 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -48,3 +48,5 @@ CONFIG_USB_STORAGE=y CONFIG_VIDEO_FSL_DCU_FB=y CONFIG_VIDEO=y # CONFIG_VIDEO_SW_CURSOR is not set +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index 83ffa19..037f56c 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -49,3 +49,5 @@ CONFIG_USB_STORAGE=y CONFIG_VIDEO_FSL_DCU_FB=y CONFIG_VIDEO=y # CONFIG_VIDEO_SW_CURSOR is not set +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index 46d8dbb..084bd27 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -55,3 +55,5 @@ CONFIG_USB_STORAGE=y CONFIG_VIDEO_FSL_DCU_FB=y CONFIG_VIDEO=y # CONFIG_VIDEO_SW_CURSOR is not set +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 14044fd..bf719f4 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -59,3 +59,5 @@ CONFIG_USB_STORAGE=y CONFIG_VIDEO_FSL_DCU_FB=y CONFIG_VIDEO=y # CONFIG_VIDEO_SW_CURSOR is not set +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index a69dd96..cf6055e 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -65,3 +65,5 @@ CONFIG_USB_STORAGE=y CONFIG_VIDEO_FSL_DCU_FB=y CONFIG_VIDEO=y # CONFIG_VIDEO_SW_CURSOR is not set +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index f6a8b74..73f7f8a 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -46,3 +46,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index b23ecf2..5ab6a77 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -48,3 +48,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index 28131b2..385c3fd 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -61,3 +61,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index 800f884..c9b047c 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -47,3 +47,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1043aqds_qspi_defconfig b/configs/ls1043aqds_qspi_defconfig index fdbcf7c..65613c7 100644 --- a/configs/ls1043aqds_qspi_defconfig +++ b/configs/ls1043aqds_qspi_defconfig @@ -45,3 +45,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index b6ad638..eca3abf 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -61,3 +61,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1043aqds_sdcard_qspi_defconfig b/configs/ls1043aqds_sdcard_qspi_defconfig index 054fc0d..59ddfaa 100644 --- a/configs/ls1043aqds_sdcard_qspi_defconfig +++ b/configs/ls1043aqds_sdcard_qspi_defconfig @@ -58,3 +58,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index 478fdc8..defcf6c 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -44,3 +44,5 @@ CONFIG_USB_STORAGE=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index c308882..cbf7e4f 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -42,3 +42,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig index ec90e48..6d8a4f1 100644 --- a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig @@ -61,3 +61,5 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_RSA=y CONFIG_SPL_RSA=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index 04d2934..8bfa3ec 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -59,3 +59,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index 09ff4c3..e25a543 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -57,3 +57,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1046aqds_SECURE_BOOT_defconfig b/configs/ls1046aqds_SECURE_BOOT_defconfig index 9649919..ec63e75 100644 --- a/configs/ls1046aqds_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_SECURE_BOOT_defconfig @@ -48,3 +48,5 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_RSA=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1046aqds_defconfig b/configs/ls1046aqds_defconfig index 6a3e4f8..5801563 100644 --- a/configs/ls1046aqds_defconfig +++ b/configs/ls1046aqds_defconfig @@ -48,3 +48,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1046aqds_lpuart_defconfig b/configs/ls1046aqds_lpuart_defconfig index cb4c5f0..9b690e3 100644 --- a/configs/ls1046aqds_lpuart_defconfig +++ b/configs/ls1046aqds_lpuart_defconfig @@ -50,3 +50,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index c6b6986..0276ba3 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -55,3 +55,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1046aqds_qspi_defconfig b/configs/ls1046aqds_qspi_defconfig index b2c1885..618af6b 100644 --- a/configs/ls1046aqds_qspi_defconfig +++ b/configs/ls1046aqds_qspi_defconfig @@ -48,3 +48,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index b0538c1..e821d1a 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -64,3 +64,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1046aqds_sdcard_qspi_defconfig b/configs/ls1046aqds_sdcard_qspi_defconfig index d067ba9..491f712 100644 --- a/configs/ls1046aqds_sdcard_qspi_defconfig +++ b/configs/ls1046aqds_sdcard_qspi_defconfig @@ -63,3 +63,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig index 9e4f275..d08998b 100644 --- a/configs/ls1046ardb_emmc_defconfig +++ b/configs/ls1046ardb_emmc_defconfig @@ -59,3 +59,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig index 139e1ab..41fb739 100644 --- a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig @@ -45,3 +45,5 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_RSA=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1046ardb_qspi_defconfig b/configs/ls1046ardb_qspi_defconfig index 45bef3d..c39547a 100644 --- a/configs/ls1046ardb_qspi_defconfig +++ b/configs/ls1046ardb_qspi_defconfig @@ -45,3 +45,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig index e82d389..8bee529 100644 --- a/configs/ls1046ardb_sdcard_defconfig +++ b/configs/ls1046ardb_sdcard_defconfig @@ -58,3 +58,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1088aqds_defconfig b/configs/ls1088aqds_defconfig index 8f9c491..769f2a6 100644 --- a/configs/ls1088aqds_defconfig +++ b/configs/ls1088aqds_defconfig @@ -46,3 +46,5 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig index c761102..89473d5 100644 --- a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig @@ -53,3 +53,5 @@ CONFIG_USB_GADGET=y CONFIG_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1088aqds_qspi_defconfig b/configs/ls1088aqds_qspi_defconfig index a7bed8c..2d3abf3 100644 --- a/configs/ls1088aqds_qspi_defconfig +++ b/configs/ls1088aqds_qspi_defconfig @@ -51,3 +51,5 @@ CONFIG_USB_DWC3=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1088aqds_sdcard_ifc_defconfig b/configs/ls1088aqds_sdcard_ifc_defconfig index a7efd68..78a18a0 100644 --- a/configs/ls1088aqds_sdcard_ifc_defconfig +++ b/configs/ls1088aqds_sdcard_ifc_defconfig @@ -54,3 +54,5 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1088aqds_sdcard_qspi_defconfig b/configs/ls1088aqds_sdcard_qspi_defconfig index f724bd3..a3287c9 100644 --- a/configs/ls1088aqds_sdcard_qspi_defconfig +++ b/configs/ls1088aqds_sdcard_qspi_defconfig @@ -60,3 +60,5 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig index d0334a2..973f220 100644 --- a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig @@ -53,3 +53,5 @@ CONFIG_USB_GADGET=y CONFIG_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1088ardb_qspi_defconfig b/configs/ls1088ardb_qspi_defconfig index d806966..c0de0d7 100644 --- a/configs/ls1088ardb_qspi_defconfig +++ b/configs/ls1088ardb_qspi_defconfig @@ -51,3 +51,5 @@ CONFIG_USB_DWC3=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls1088ardb_sdcard_qspi_defconfig b/configs/ls1088ardb_sdcard_qspi_defconfig index bf1c0a2..51c47fe 100644 --- a/configs/ls1088ardb_sdcard_qspi_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_defconfig @@ -60,3 +60,5 @@ CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls2080a_emu_defconfig b/configs/ls2080a_emu_defconfig index 5d81d06..b7bdd82 100644 --- a/configs/ls2080a_emu_defconfig +++ b/configs/ls2080a_emu_defconfig @@ -32,3 +32,5 @@ CONFIG_FSL_CAAM=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls2080a_simu_defconfig b/configs/ls2080a_simu_defconfig index b6de767..24cc230 100644 --- a/configs/ls2080a_simu_defconfig +++ b/configs/ls2080a_simu_defconfig @@ -35,3 +35,5 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index c879f80..b84c387 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -53,3 +53,5 @@ CONFIG_USB_STORAGE=y CONFIG_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index 9ee003d..a90420f 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -52,3 +52,5 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 039672f..a069fa3 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -61,3 +61,5 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls2080aqds_qspi_defconfig b/configs/ls2080aqds_qspi_defconfig index 53e55c8..7a6cf8d 100644 --- a/configs/ls2080aqds_qspi_defconfig +++ b/configs/ls2080aqds_qspi_defconfig @@ -52,3 +52,5 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig index efea22f..3c0d73c 100644 --- a/configs/ls2080aqds_sdcard_defconfig +++ b/configs/ls2080aqds_sdcard_defconfig @@ -59,3 +59,5 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index 906fa9a..0984156 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -53,3 +53,5 @@ CONFIG_USB_STORAGE=y CONFIG_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index ea54383..3d6ffcb 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -52,3 +52,5 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index 81d1b6c..070d0f9 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -56,3 +56,5 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig index cc88c88..189bf0f 100644 --- a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig @@ -51,3 +51,5 @@ CONFIG_USB_STORAGE=y CONFIG_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y diff --git a/configs/ls2088ardb_qspi_defconfig b/configs/ls2088ardb_qspi_defconfig index b2ca618..f78b0bf 100644 --- a/configs/ls2088ardb_qspi_defconfig +++ b/configs/ls2088ardb_qspi_defconfig @@ -53,3 +53,5 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_BLK=y +CONFIG_DM_MMC=y
You didn't "fix" it. You simply dropped the change to ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig. Do you know why ls1021atwr_nor_SECURE_BOOT_defconfig and ls1021atwr_sdcard_ifc_defconfig work, but not ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig?
York
-----Original Message----- From: York Sun Sent: 2018年9月26日 0:59 To: Yinbo Zhu yinbo.zhu@nxp.com; Y.b. Lu yangbo.lu@nxp.com Cc: u-boot@lists.denx.de; Xiaobo Xie xiaobo.xie@nxp.com; Andy Tang andy.tang@nxp.com; Peng Ma peng.ma@nxp.com Subject: Re: [PATCH v9 8/8] Enable CONFIG_BLK and CONFIG_DM_MMC to Kconfig
York
Hi York,
Secure boot has compile error because of that "CONFIG_SPL_DM" is enabled, from the present situation that which SPL device model seems can't be supported, so I intend to support sd dm in secure boot in the future when SPL device model is supported.
Best Regards, Yinbo Zhu
OK. Thanks.
York
This patch set has been applied to fsl-qoriq master, awaiting upstream. Thanks.
York
Yinbo Zhu
York Sun
