[PATCH] mtd: cqspi: Fix division by zero
Both dummy.nbytes and dummy.buswidth may be zero. By not checking the later, it is possible to trigger division by zero and a crash. This does happen with tiny SPI NOR framework in SPL. Fix this by adding the check and returning zero dummy bytes in such a case.
Fixes: 38b0852b0ea ("spi: cadence-qspi: Add support for octal DTR flashes") Signed-off-by: Marek Vasut marex@denx.de Cc: Jagan Teki jagan@amarulasolutions.com Cc: Vignesh R vigneshr@ti.com Cc: Pratyush Yadav p.yadav@ti.com --- drivers/spi/cadence_qspi_apb.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index c36a652211a..429ee335db6 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -219,6 +219,9 @@ static unsigned int cadence_qspi_calc_dummy(const struct spi_mem_op *op, { unsigned int dummy_clk;
+ if (!op->dummy.nbytes || !op->dummy.buswidth) + return 0; + dummy_clk = op->dummy.nbytes * (8 / op->dummy.buswidth); if (dtr) dummy_clk /= 2;
- if (!op->dummy.nbytes || !op->dummy.buswidth)
Thanks. A similar fix was sent for Linux as well [0]. I don't think you should check for dummy buswidth here since nbytes == 0 should be enough of an indicator that the dummy phase does not exist. Any op with dummy.nbytes > 1 and dummy.buswidth == 0 is a malformed op that should ideally never happen, or if it does, then it should be dealt by the SPI MEM core.
With this fixed,
Reviewed-by: Pratyush Yadav p.yadav@ti.com
[0] https://patchwork.kernel.org/project/spi-devel-general/patch/92eea403-9b21-2...
- dummy_clk = op->dummy.nbytes * (8 / op->dummy.buswidth); if (dtr) dummy_clk /= 2;
-- 2.33.0
With this fixed,
Yes, indeed, the division by zero happens if op->dummy.buswidth == 0, so we must check it. Checking for op->dummy.nbytes == 0 is a minor optimization.
Pratyush Yadav
