[U-Boot] [PATCH v4 1/2] spl: Add spl_early_init()
At present malloc_base/_limit/_ptr are not initialised in spl_init() when we call spl_init() in board_init_f(). This is due to a recent change aimed at avoiding overwriting the malloc area set up on some boards by spl_relocate_stack_gd().
However if CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN is not defined, we now skip setting up the memory area in spl_init() which is obviously wrong.
To fix this, add a new function spl_early_init() which can be called in board_init_f().
Fixes: b3d2861e (spl: Remove overwrite of relocated malloc limit) Signed-off-by: Eddie Cai eddie.cai.linux@gmail.com Rewrote spl_{,early_}init() to avoid duplicate code: Rewrite/expand commit message: Signed-off-by: Simon Glass sjg@chromium.org ---
Changes in v4: None Changes in v3: None Changes in v2: - Rewrote spl_{,early_}init() to avoid duplicate code - Rewrite commit message
common/spl/spl.c | 46 +++++++++++++++++++++++++++++---------- include/asm-generic/global_data.h | 1 + include/spl.h | 24 +++++++++++++++++--- 3 files changed, 57 insertions(+), 14 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index 766fb3d6f4..2bc8b42027 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -170,22 +170,20 @@ __weak void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image) image_entry(); }
-int spl_init(void) +static int spl_common_init(bool setup_malloc) { int ret;
- debug("spl_init()\n"); -/* - * with CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN we set malloc_base and - * malloc_limit in spl_relocate_stack_gd - */ -#if defined(CONFIG_SYS_MALLOC_F_LEN) && \ - !defined(CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN) + debug("spl_early_init()\n"); + +#if defined(CONFIG_SYS_MALLOC_F_LEN) + if (setup_malloc) { #ifdef CONFIG_MALLOC_F_ADDR - gd->malloc_base = CONFIG_MALLOC_F_ADDR; + gd->malloc_base = CONFIG_MALLOC_F_ADDR; #endif - gd->malloc_limit = CONFIG_SYS_MALLOC_F_LEN; - gd->malloc_ptr = 0; + gd->malloc_limit = CONFIG_SYS_MALLOC_F_LEN; + gd->malloc_ptr = 0; + } #endif if (CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA)) { ret = fdtdec_setup(); @@ -202,6 +200,32 @@ int spl_init(void) return ret; } } + + return 0; +} + +int spl_early_init(void) +{ + int ret; + + ret = spl_common_init(true); + if (ret) + return ret; + gd->flags |= GD_FLG_SPL_EARLY_INIT; + + return 0; +} + +int spl_init(void) +{ + int ret; + + if (!(gd->flags & GD_FLG_SPL_EARLY_INIT)) { + ret = spl_common_init( + !IS_ENABLED(CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN)); + if (ret) + return ret; + } gd->flags |= GD_FLG_SPL_INIT;
return 0; diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index e02863dc03..5b356dd231 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -127,5 +127,6 @@ typedef struct global_data { #define GD_FLG_SKIP_RELOC 0x00800 /* Don't relocate */ #define GD_FLG_RECORD 0x01000 /* Record console */ #define GD_FLG_ENV_DEFAULT 0x02000 /* Default variable flag */ +#define GD_FLG_SPL_EARLY_INIT 0x04000 /* Early SPL init is done */
#endif /* __ASM_GENERIC_GBL_DATA_H */ diff --git a/include/spl.h b/include/spl.h index bde44374ea..cdd196d187 100644 --- a/include/spl.h +++ b/include/spl.h @@ -213,11 +213,29 @@ int spl_load_image_ext_os(struct spl_image_info *spl_image, struct blk_desc *block_dev, int partition);
/** - * spl_init() - Set up device tree and driver model in SPL if enabled + * spl_early_init() - Set up device tree and driver model in SPL if enabled * * Call this function in board_init_f() if you want to use device tree and - * driver model early, before board_init_r() is called. This function will - * be called from board_init_r() if not called earlier. + * driver model early, before board_init_r() is called. + * + * If this is not called, then driver model will be inactive in SPL's + * board_init_f(), and no device tree will be available. + */ +int spl_early_init(void); + +/** + * spl_init() - Set up device tree and driver model in SPL if enabled + * + * You can optionally call spl_early_init(), then optionally call spl_init(). + * This function will be called from board_init_r() if not called earlier. + * + * Both spl_early_init() and spl_init() perform a similar function except that + * the latter will not set up the malloc() area if + * CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN is enabled, since it is assumed to + * already be done by a calll to spl_relocate_stack_gd() before board_init_r() + * is reached. + * + * This function will be called from board_init_r() if not called earlier. * * If this is not called, then driver model will be inactive in SPL's * board_init_f(), and no device tree will be available.
Use spl_early_init() to make sure that early malloc() is initialised. This fixes booting on firefly-rk3288, for example.
Signed-off-by: Eddie Cai eddie.cai.linux@gmail.com Signed-off-by: Simon Glass sjg@chromium.org ---
Changes in v4: - Change debug() message to match new function name
Changes in v3: - Rewrite both commit messages
Changes in v2: - Add v2 to the series since this is a new version
arch/arm/mach-rockchip/rk3288-board-spl.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3288-board-spl.c b/arch/arm/mach-rockchip/rk3288-board-spl.c index e51e19bb2d..74f3379194 100644 --- a/arch/arm/mach-rockchip/rk3288-board-spl.c +++ b/arch/arm/mach-rockchip/rk3288-board-spl.c @@ -185,9 +185,9 @@ void board_init_f(ulong dummy) debug_uart_init(); #endif
- ret = spl_init(); + ret = spl_early_init(); if (ret) { - debug("spl_init() failed: %d\n", ret); + debug("spl_early_init() failed: %d\n", ret); hang(); }
Hi Eddie, Simon,
Could you help to correct rk3188, rk3399 spl at the same time?
Changes in v4:
Changes in v3:
Changes in v2:
- ret = spl_init();
- ret = spl_early_init(); if (ret) {
hang(); }debug("spl_early_init() failed: %d\n", ret);
Hi Kever,
On 16 March 2017 at 01:08, Kever Yang kever.yang@rock-chips.com wrote:
Hi Eddie, Simon,
I don't have boards to test with for these, sorry.
2017-03-15 22:43 GMT+08:00 Simon Glass sjg@chromium.org:
Reviewed-by: Eddie Cai eddie.cai.linux@gmail.com
Changes in v4:
Changes in v3:
Changes in v2:
ret = spl_init();
-- 2.12.0.367.g23dc2f6d3c-goog
Applied to u-boot-rockchip.
- with CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN we set malloc_base and
- malloc_limit in spl_relocate_stack_gd
if (setup_malloc) {
#endif
gd->malloc_ptr = 0;
gd->malloc_ptr = 0;
int ret;
if (ret)
return ret;
int ret;
if (ret)
return ret;
} gd->flags |= GD_FLG_SPL_INIT; return 0;
- spl_init() - Set up device tree and driver model in SPL if enabled
- spl_early_init() - Set up device tree and driver model in SPL if
enabled
- Call this function in board_init_f() if you want to use device tree and
- driver model early, before board_init_r() is called. This function will
- be called from board_init_r() if not called earlier.
- If this is not called, then driver model will be inactive in SPL's
- board_init_f(), and no device tree will be available.
- You can optionally call spl_early_init(), then optionally call
spl_init().
- This function will be called from board_init_r() if not called earlier.
- Both spl_early_init() and spl_init() perform a similar function except
that
- the latter will not set up the malloc() area if
- CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN is enabled, since it is assumed
to
- already be done by a calll to spl_relocate_stack_gd() before
board_init_r()
- is reached.
Hi Simon,
- debug("spl_early_init()\n");
- if (setup_malloc) {
#endif
gd->malloc_ptr = 0;
- int ret;
- ret = spl_common_init(true);
- if (ret)
return ret;
- gd->flags |= GD_FLG_SPL_EARLY_INIT;
- int ret;
- if (!(gd->flags & GD_FLG_SPL_EARLY_INIT)) {
IS_ENABLED(CONFIG defined as hex) is always false. So this will always return true and overriding the malloc_limit, which is causing boot failures on DRA7xx based boards.:wq
Thanks and regards, Lokesh
On Mon, Mar 20, 2017 at 10:58:57AM +0530, Lokesh Vutla wrote:
Hi Simon,
#endif
gd->malloc_ptr = 0;
- int ret;
- if (ret)
return ret;
- int ret;
Maybe we should use a bool that we set based on (SPL_STACK_R && SPL_SYS_MALLOC_SIMPLE) being true or not as that's the gating condition for CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN being set.
Hi Tom,
Hi Simon,
#endif
gd->malloc_ptr = 0;
- int ret;
- if (ret)
return ret;
- int ret;
And it looks like you fixed this with:
cf334edfbb spl: Correct call to spl_common_init() with SPL_STACK_R_MALLOC_SIMPLE_LEN
Thanks! - Simon
participants (5)
Eddie Cai
Kever Yang
Lokesh Vutla
