[U-Boot] [PATCH] doc: README.mxsimage: Use mkimage provided by U-boot
Fix the text to make clear that the 'mkimage' provided by U-boot should be used instead of the one provided by the host PC distribution.
While at it, also fix the directory location of the configuration files.
After these changes, it is possible succesfully generate a u-boot.sb image.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- doc/README.mxsimage | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/doc/README.mxsimage b/doc/README.mxsimage index 88a2caf..79cd06e 100644 --- a/doc/README.mxsimage +++ b/doc/README.mxsimage @@ -9,12 +9,12 @@ Usage -- producing image: The mxsimage tool is targeted to be a simple replacement for the elftosb2 . To generate an image, write an image configuration file and run:
- mkimage -A arm -O u-boot -T mxsimage -n <path to configuration file> \ + ./tools/mkimage -A arm -O u-boot -T mxsimage -n <path to configuration file> \ <output bootstream file>
The output bootstream file is usually using the .sb file extension. Note that the example configuration files for producing bootable BootStream with -the U-Boot bootloader can be found under arch/arm/boot/cpu/arm926ejs/mxs/ +the U-Boot bootloader can be found under arch/arm/cpu/arm926ejs/mxs/ directory. See the following files:
mxsimage.mx23.cfg -- This is an example configuration for i.MX23 @@ -158,7 +158,7 @@ Usage -- verifying image: The mxsimage can also verify and dump contents of an image. Use the following syntax to verify and dump contents of an image:
- mkimage -l <input bootstream file> + ./tools/mkimage -l <input bootstream file>
This will output all the information from the SB image header and all the instructions contained in the SB image. It will also check if the various
Dear Fabio Estevam,
- ./tools/mkimage -A arm -O u-boot -T mxsimage -n <path to configuration
- ./tools/mkimage -l <input bootstream file>
Tom, are you OK with such a hack (invoking the in-tree mkimage) in the documentation?
Best regards, Marek Vasut
Hi Marek,
This seems to be a common practice in the U-boot doc directory:
doc/README.imximage:./tools/mkimage -l <mx u-boot_file> doc/README.imximage:./tools/mkimage -T imximage \ doc/README.imximage:./tools/mkimage -n ./board/freescale/mx51evk/imximage.cfg \ doc/README.kwbimage:./tools/mkimage -l <kwboot_file> doc/README.kwbimage:./tools/mkimage -n <board specific configuration file> \ doc/README.kwbimage:./tools/mkimage -n ./board/Marvell/openrd_base/kwbimage.cfg doc/README.mxsimage: ./tools/mkimage -A arm -O u-boot -T mxsimage -n <path to co doc/README.mxsimage: ./tools/mkimage -l <input bootstream file> doc/README.qemu-mips:# tools/mkimage -A mips -O linux -T kernel -C gzip -a 0x800 doc/README.ublimage:./tools/mkimage -l <u-boot_file> doc/README.ublimage:./tools/mkimage -T ublimage \ doc/README.ublimage:./tools/mkimage -n ./board/davinci/dm365evm/ublimage.cfg \ doc/SPL/README.am335x-network:$ ./tools/mkimage -A arm -O U-Boot -C none -T scri
Regards,
Fabio Estevam
On Sun, Sep 15, 2013 at 1:50 PM, Fabio Estevam festevam@gmail.com wrote:
Hi Marek,
Acked-by: Otavio Salvador otavio@ossystems.com.br
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
Hi Marek,
Acked-by: Tom Rini trini@ti.com
- -- Tom
Fabio Estevam
Otavio Salvador
