[U-Boot] Building tools without building firmware
We have a need to build and package at the very least 'mkimage' for SuSE 11.1 and since we have multiple board targets in mind (MPC8641D, MPC8610, MPC5121e) it does not make any sense to pick any in particular or build the entire u-boot.bin just for a few kilobytes we need to prep kernels and initrd images.
Is it possible to simply build the tools/ directory (a make target that works would be great) without building a firmware from BLAH_config first?
you can see the method we use in Gentoo here: http://sources.gentoo.org/dev-embedded/u-boot-tools/
but i'd agree that i wish it were easier to just build the helper utilities. and if they werent so tightly intertwined with the rest of the u-boot code ... atm you cant build mkimage on a non-Linux system due to the libfdt stuff. -mike
Ouch.
Am I reading this right.. I'm using SUSE 11.0 here so I guess I do
touch include/config.h include/config.mk make HOSTSTRIP=echo BIN_FILES="mkimage"
And that'd do it? I'll have to check it out later..
Ouch.
should be ... seemed to work for me
btw, we do HOSTSTRIP=echo in Gentoo only because we dont let packages strip things themselves ... it's not like u-boot will break things otherwise -mike
Ouch.
It doesn't work; I get a lot of errors about asm/blah.h include files being missing.
make MPC8610HPCN_config make BIN_FILES="mkimage"
this works fine though. I also tried filling out ARCH=ppc into config.mk just in case, but it's obvious some weird arch setup is being done to glue in the right includes. So, I symlinked asm-ppc to asm, just like mkconfig does, and this made it at least get to compile.
So the correct solution is;
touch include/config.h include/config.mk ln -sf include/asm-ppc include/asm make BIN_FILES="mkimage" tools
(this also builds bmp_logo for some reason.. I don't quite understand why?)
Ouch.
while yes, you'll see a lot of errors, they dont actually matter. just ignore them and you'll get the right tools built up. -mike
Matt Sealey
Mike Frysinger
