The following changes since commit 6b3943f1b04be60f147ee540fbd72c4c7ea89f80:
siemens,am33x: add draco etamin board (2016-06-09 13:53:13 -0400)
git://git.denx.de/u-boot-usb.git master
for you to fetch changes up to 1e6fb0e367564d427d7c57fa7b3b972ecb7147a3:
usb: ehci: only shutdown opened controller (2016-06-18 00:49:00 +0200)
---------------------------------------------------------------- Peng Fan (2): cmd: usb: check if_type before using this device usb: ehci: only shutdown opened controller
Sriram Dash (5): arm64: fsl-layerscape: add get_svr and IS_SVR_REV helper usb: xhci: fsl: code cleanup for device tree fixup for fsl usb controllers fsl: usb: make errata function common for PPC and ARM armv8/ls2080: Remove workaround for erratum A008751 usb: xhci: fsl: Add workaround for USB erratum A008751
Steve Rae (2): usb: dwc2_udc_otg: support 8-bit interface arm: bcm281xx: choose 8-bit phy bus width
arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 7 +++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 10 ----- arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h | 2 + arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h | 4 ++ arch/arm/include/asm/arch-fsl-layerscape/soc.h | 2 + board/freescale/ls2080aqds/ls2080aqds.c | 2 + board/freescale/ls2080ardb/ls2080ardb.c | 2 + cmd/usb.c | 3 +- configs/bcm11130_defconfig | 1 + configs/bcm11130_nand_defconfig | 1 +
configs/bcm28155_ap_defconfig | 1 +
configs/bcm28155_w1d_defconfig | 1 +
drivers/usb/common/Makefile | 4 +-
drivers/usb/common/fsl-dt-fixup.c | 100 +++++++++++++++++++++++++++----------------
drivers/usb/common/fsl-errata.c | 193 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
drivers/usb/gadget/Kconfig | 10 +++++
drivers/usb/gadget/dwc2_udc_otg.c | 4 ++
drivers/usb/host/ehci-hcd.c | 3 ++ drivers/usb/host/xhci-fsl.c | 24 +++++++++++ include/fsl_usb.h | 192 ++++------------------------------------------------------------------------------ 20 files changed, 333 insertions(+), 233 deletions(-) create mode 100644 drivers/usb/common/fsl-errata.c
