[U-Boot-Users] [PATCH v2] 85xx: add ability to upload QE firmware
Define the layout of a binary blob that contains a QE firmware and instructions on how to upload it. Add function qe_upload_firmware() to parse the blob and perform the actual upload. Add command-line command "qe fw" to take a firmware blob in memory and upload it. Update ft_cpu_setup() on 83xx to create the 'firmware' device tree node if U-Boot has uploaded a firmware. Fully define 'struct rsp' in immap_qe.h to include the actual RISC Special Registers.
Signed-off-by: Timur Tabi timur@freescale.com ---
Updated device tree property names, based on mailing list review.
Tested on an MPC8568 MDS.
common/fdt_support.c | 48 ++++++++++ cpu/mpc85xx/fdt.c | 1 + drivers/qe/qe.c | 219 ++++++++++++++++++++++++++++++++++++++++++++ drivers/qe/qe.h | 56 +++++++++++ include/asm-ppc/immap_qe.h | 33 ++++++- include/fdt_support.h | 1 + 6 files changed, 356 insertions(+), 2 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index b5ee6e9..973d527 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -30,6 +30,9 @@ #include <fdt_support.h> #include <exports.h>
+#ifdef CONFIG_QE +#include "../drivers/qe/qe.h" +#endif /* * Global data (for the gd->bd) */ @@ -607,4 +610,49 @@ void fdt_fixup_ethernet(void *fdt, bd_t *bd) #endif } } + +#ifdef CONFIG_QE +/* + * If a QE firmware has been uploaded, then add the 'firmware' node under + * the 'qe' node. + */ +void fdt_fixup_qe_firmware(void *fdt) +{ + struct qe_firmware_info *qe_fw_info; + int node, ret; + + qe_fw_info = qe_get_firmware_info(); + if (!qe_fw_info) + return; + + node = fdt_path_offset(fdt, "/qe"); + if (node < 0) + return; + + /* We assume the node doesn't exist yet */ + node = fdt_add_subnode(fdt, node, "firmware"); + if (node < 0) + return; + + ret = fdt_setprop(fdt, node, "extended-modes", + &qe_fw_info->extended_modes, sizeof(u64)); + if (ret < 0) + goto error; + + ret = fdt_setprop_string(fdt, node, "id", qe_fw_info->id); + if (ret < 0) + goto error; + + ret = fdt_setprop(fdt, node, "virtual-traps", qe_fw_info->vtraps, + sizeof(qe_fw_info->vtraps)); + if (ret < 0) + goto error; + + return; + +error: + fdt_del_node(fdt, node); +} +#endif + #endif diff --git a/cpu/mpc85xx/fdt.c b/cpu/mpc85xx/fdt.c index 737a6c4..0812c89 100644 --- a/cpu/mpc85xx/fdt.c +++ b/cpu/mpc85xx/fdt.c @@ -45,6 +45,7 @@ void ft_cpu_setup(void *blob, bd_t *bd) #ifdef CONFIG_QE do_fixup_by_prop_u32(blob, "device_type", "soc", 4, "bus-frequency", bd->bi_busfreq, 1); + fdt_fixup_qe_firmware(blob); #endif
#ifdef CFG_NS16550 diff --git a/drivers/qe/qe.c b/drivers/qe/qe.c index 7559e92..276788c 100644 --- a/drivers/qe/qe.c +++ b/drivers/qe/qe.c @@ -21,6 +21,7 @@ */
#include "common.h" +#include <command.h> #include "asm/errno.h" #include "asm/io.h" #include "asm/immap_qe.h" @@ -248,4 +249,222 @@ int qe_set_mii_clk_src(int ucc_num) return 0; }
+/* The maximum number of RISCs we support */ +#define MAX_QE_RISC 2 + +/* Firmware information stored here for qe_get_firmware_info() */ +static struct qe_firmware_info qe_firmware_info; + +/* + * Set to 1 if QE firmware has been uploaded, and therefore + * qe_firmware_info contains valid data. + */ +static int qe_firmware_uploaded; + +/* + * Upload a QE microcode + * + * This function is a worker function for qe_upload_firmware(). It does + * the actual uploading of the microcode. + */ +static void qe_upload_microcode(const void *base, + const struct qe_microcode *ucode) +{ + const u32 *code = base + be32_to_cpu(ucode->code_offset); + unsigned int i; + + if (ucode->major || ucode->minor || ucode->revision) + printf("QE: uploading microcode '%s' version %u.%u.%u\n", + ucode->id, ucode->major, ucode->minor, ucode->revision); + else + printf("QE: uploading microcode '%s'\n", ucode->id); + + /* Use auto-increment */ + out_be32(&qe_immr->iram.iadd, be32_to_cpu(ucode->iram_offset) | + QE_IRAM_IADD_AIE | QE_IRAM_IADD_BADDR); + + for (i = 0; i < be32_to_cpu(ucode->count); i++) + out_be32(&qe_immr->iram.idata, be32_to_cpu(code[i])); +} + +/* + * Upload a microcode to the I-RAM at a specific address. + * + * See docs/README.qe_firmware for information on QE microcode uploading. + * + * Currently, only version 1 is supported, so the 'version' field must be + * set to 1. + * + * The SOC model and revision are not validated, they are only displayed for + * informational purposes. + * + * 'calc_size' is the calculated size, in bytes, of the firmware structure and + * all of the microcode structures, minus the CRC. + * + * 'length' is the size that the structure says it is, including the CRC. + */ +int qe_upload_firmware(const struct qe_firmware *firmware) +{ + unsigned int i; + unsigned int j; + u32 crc; + size_t calc_size = sizeof(struct qe_firmware); + size_t length; + const struct qe_header *hdr; + + if (!firmware) { + printf("Invalid address\n"); + return -EINVAL; + } + + hdr = &firmware->header; + length = be32_to_cpu(hdr->length); + + /* Check the magic */ + if ((hdr->magic[0] != 'Q') || (hdr->magic[1] != 'E') || + (hdr->magic[2] != 'F')) { + printf("Not a microcode\n"); + return -EPERM; + } + + /* Check the version */ + if (hdr->version != 1) { + printf("Unsupported version\n"); + return -EPERM; + } + + /* Validate some of the fields */ + if ((firmware->count < 1) || (firmware->count >= MAX_QE_RISC)) { + printf("Invalid data\n"); + return -EINVAL; + } + + /* Validate the length and check if there's a CRC */ + calc_size += (firmware->count - 1) * sizeof(struct qe_microcode); + + for (i = 0; i < firmware->count; i++) + /* + * For situations where the second RISC uses the same microcode + * as the first, the 'code_offset' and 'count' fields will be + * zero, so it's okay to add those. + */ + calc_size += sizeof(u32) * + be32_to_cpu(firmware->microcode[i].count); + + /* Validate the length */ + if (length != calc_size + sizeof(u32)) { + printf("Invalid length\n"); + return -EPERM; + } + + /* + * Validate the CRC. We would normally call crc32_no_comp(), but that + * function isn't available unless you turn on JFFS support. + */ + crc = be32_to_cpu(*(u32 *)((void *)firmware + calc_size)); + if (crc != (crc32(-1, (const void *) firmware, calc_size) ^ -1)) { + printf("Firmware CRC is invalid\n"); + return -EIO; + } + + /* + * If the microcode calls for it, split the I-RAM. + */ + if (!firmware->split) { + out_be16(&qe_immr->cp.cercr, + in_be16(&qe_immr->cp.cercr) | QE_CP_CERCR_CIR); + } + + if (firmware->soc.model) + printf("Firmware '%s' for %u V%u.%u\n", + firmware->id, be16_to_cpu(firmware->soc.model), + firmware->soc.major, firmware->soc.minor); + else + printf("Firmware '%s'\n", firmware->id); + + /* + * The QE only supports one microcode per RISC, so clear out all the + * saved microcode information and put in the new. + */ + memset(&qe_firmware_info, 0, sizeof(qe_firmware_info)); + strcpy(qe_firmware_info.id, firmware->id); + qe_firmware_info.extended_modes = firmware->extended_modes; + memcpy(qe_firmware_info.vtraps, firmware->vtraps, + sizeof(firmware->vtraps)); + qe_firmware_uploaded = 1; + + /* Loop through each microcode. */ + for (i = 0; i < firmware->count; i++) { + const struct qe_microcode *ucode = &firmware->microcode[i]; + + /* Upload a microcode if it's present */ + if (ucode->code_offset) + qe_upload_microcode(firmware, ucode); + + /* Program the traps for this processor */ + for (j = 0; j < 16; j++) { + u32 trap = be32_to_cpu(ucode->traps[j]); + + if (trap) + out_be32(&qe_immr->rsp[i].tibcr[j], trap); + } + + /* Enable traps */ + out_be32(&qe_immr->rsp[i].eccr, be32_to_cpu(ucode->eccr)); + } + + return 0; +} + +struct qe_firmware_info *qe_get_firmware_info(void) +{ + return qe_firmware_uploaded ? &qe_firmware_info : NULL; +} + +static int qe_cmd(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + ulong addr; + + if (argc < 3) { + printf ("Usage:\n%s\n", cmdtp->usage); + return 1; + } + + if (strcmp(argv[1], "fw") == 0) { + addr = simple_strtoul(argv[2], NULL, 16); + + if (!addr) { + printf("Invalid address\n"); + return -EINVAL; + } + + /* + * If a length was supplied, compare that with the 'length' + * field. + */ + + if (argc > 3) { + ulong length = simple_strtoul(argv[3], NULL, 16); + struct qe_firmware *firmware = (void *) addr; + + if (length != be32_to_cpu(firmware->header.length)) { + printf("Length mismatch\n"); + return -EINVAL; + } + } + + return qe_upload_firmware((const struct qe_firmware *) addr); + } + + printf ("Usage:\n%s\n", cmdtp->usage); + return 1; +} + +U_BOOT_CMD( + qe, 4, 0, qe_cmd, + "qe - QUICC Engine commands\n", + "fw <addr> [<length>] - Upload firmware binary at address <addr> to " + "the QE,\n\twith optional length <length> verification.\n" + ); + #endif /* CONFIG_QE */ diff --git a/drivers/qe/qe.h b/drivers/qe/qe.h index 400b1a6..4c96c67 100644 --- a/drivers/qe/qe.h +++ b/drivers/qe/qe.h @@ -222,6 +222,60 @@ typedef enum qe_clock {
#define QE_SDEBCR_BA_MASK 0x01FFFFFF
+/* Communication Processor */ +#define QE_CP_CERCR_MEE 0x8000 /* Multi-user RAM ECC enable */ +#define QE_CP_CERCR_IEE 0x4000 /* Instruction RAM ECC enable */ +#define QE_CP_CERCR_CIR 0x0800 /* Common instruction RAM */ + +/* I-RAM */ +#define QE_IRAM_IADD_AIE 0x80000000 /* Auto Increment Enable */ +#define QE_IRAM_IADD_BADDR 0x00080000 /* Base Address */ + +/* Structure that defines QE firmware binary files. + * + * See doc/README.qe_firmware for a description of these fields. + */ +struct qe_firmware { + struct qe_header { + u32 length; /* Length of the entire structure, in bytes */ + u8 magic[3]; /* Set to { 'Q', 'E', 'F' } */ + u8 version; /* Version of this layout. First ver is '1' */ + } header; + u8 id[62]; /* Null-terminated identifier string */ + u8 split; /* 0 = shared I-RAM, 1 = split I-RAM */ + u8 count; /* Number of microcode[] structures */ + struct { + u16 model; /* The SOC model */ + u8 major; /* The SOC revision major */ + u8 minor; /* The SOC revision minor */ + } __attribute__ ((packed)) soc; + u8 padding[4]; /* Reserved, for alignment */ + u64 extended_modes; /* Extended modes */ + u32 vtraps[8]; /* Virtual trap addresses */ + u8 reserved[4]; /* Reserved, for future expansion */ + struct qe_microcode { + u8 id[32]; /* Null-terminated identifier */ + u32 traps[16]; /* Trap addresses, 0 == ignore */ + u32 eccr; /* The value for the ECCR register */ + u32 iram_offset; /* Offset into I-RAM for the code */ + u32 count; /* Number of 32-bit words of the code */ + u32 code_offset; /* Offset of the actual microcode */ + u8 major; /* The microcode version major */ + u8 minor; /* The microcode version minor */ + u8 revision; /* The microcode version revision */ + u8 padding; /* Reserved, for alignment */ + u8 reserved[4]; /* Reserved, for future expansion */ + } __attribute__ ((packed)) microcode[1]; + /* All microcode binaries should be located here */ + /* CRC32 should be located here, after the microcode binaries */ +} __attribute__ ((packed)); + +struct qe_firmware_info { + char id[64]; /* Firmware name */ + u32 vtraps[8]; /* Virtual trap addresses */ + u64 extended_modes; /* Extended modes */ +}; + void qe_config_iopin(u8 port, u8 pin, int dir, int open_drain, int assign); void qe_issue_cmd(uint cmd, uint sbc, u8 mcn, u32 cmd_data); uint qe_muram_alloc(uint size, uint align); @@ -233,5 +287,7 @@ void qe_reset(void); void qe_assign_page(uint snum, uint para_ram_base); int qe_set_brg(uint brg, uint rate); int qe_set_mii_clk_src(int ucc_num); +int qe_upload_firmware(const struct qe_firmware *firmware); +struct qe_firmware_info *qe_get_firmware_info(void);
#endif /* __QE_H__ */ diff --git a/include/asm-ppc/immap_qe.h b/include/asm-ppc/immap_qe.h index a16a6d3..39da377 100644 --- a/include/asm-ppc/immap_qe.h +++ b/include/asm-ppc/immap_qe.h @@ -513,10 +513,39 @@ typedef struct dbg { u8 res2[0x48]; } __attribute__ ((packed)) dbg_t;
-/* RISC Special Registers (Trap and Breakpoint) +/* + * RISC Special Registers (Trap and Breakpoint). These are described in + * the QE Developer's Handbook. */ typedef struct rsp { - u8 fixme[0x100]; + u32 tibcr[16]; /* Trap/instruction breakpoint control regs */ + u8 res0[64]; + u32 ibcr0; + u32 ibs0; + u32 ibcnr0; + u8 res1[4]; + u32 ibcr1; + u32 ibs1; + u32 ibcnr1; + u32 npcr; + u32 dbcr; + u32 dbar; + u32 dbamr; + u32 dbsr; + u32 dbcnr; + u8 res2[12]; + u32 dbdr_h; + u32 dbdr_l; + u32 dbdmr_h; + u32 dbdmr_l; + u32 bsr; + u32 bor; + u32 bior; + u8 res3[4]; + u32 iatr[4]; + u32 eccr; /* Exception control configuration register */ + u32 eicr; + u8 res4[0x100-0xf8]; } __attribute__ ((packed)) rsp_t;
typedef struct qe_immap { diff --git a/include/fdt_support.h b/include/fdt_support.h index 3d6c1a8..859eaa8 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -46,6 +46,7 @@ void do_fixup_by_compat_u32(void *fdt, const char *compat, const char *prop, u32 val, int create); int fdt_fixup_memory(void *blob, u64 start, u64 size); void fdt_fixup_ethernet(void *fdt, bd_t *bd); +void fdt_fixup_qe_firmware(void *fdt);
#ifdef CONFIG_OF_HAS_UBOOT_ENV int fdt_env(void *fdt);
Did you mean "Update ft_cpu_setup() on 85xx"?
Andy
applied, thanks!
I changed the 83xx to 85xx in the description
- Global data (for the gd->bd)
- If a QE firmware has been uploaded, then add the 'firmware' node under
- the 'qe' node.
int node, ret;
if (!qe_fw_info)
return;
if (node < 0)
return;
if (node < 0)
return;
if (ret < 0)
goto error;
if (ret < 0)
goto error;
if (ret < 0)
goto error;
return;
+error:
+} +#endif
#endif
- Set to 1 if QE firmware has been uploaded, and therefore
- qe_firmware_info contains valid data.
- Upload a QE microcode
- This function is a worker function for qe_upload_firmware(). It does
- the actual uploading of the microcode.
unsigned int i;
else
- Upload a microcode to the I-RAM at a specific address.
- See docs/README.qe_firmware for information on QE microcode uploading.
- Currently, only version 1 is supported, so the 'version' field must be
- set to 1.
- The SOC model and revision are not validated, they are only displayed for
- informational purposes.
- 'calc_size' is the calculated size, in bytes, of the firmware structure and
- all of the microcode structures, minus the CRC.
- 'length' is the size that the structure says it is, including the CRC.
unsigned int i;
unsigned int j;
u32 crc;
size_t length;
if (!firmware) {
return -EINVAL;
return -EPERM;
return -EPERM;
return -EINVAL;
return -EPERM;
return -EIO;
else
if (trap)
/* Enable traps */
ulong addr;
if (argc < 3) {
return 1;
if (!addr) {
return -EINVAL;
* field.
if (argc > 3) {
return -EINVAL;
return 1;
+U_BOOT_CMD(
qe, 4, 0, qe_cmd,
- See doc/README.qe_firmware for a description of these fields.
struct qe_header {
} header;
struct {
- RISC Special Registers (Trap and Breakpoint). These are described in
- the QE Developer's Handbook.
u8 fixme[0x100];
u8 res0[64];
u32 ibcr0;
u32 ibs0;
u32 ibcnr0;
u8 res1[4];
u32 ibcr1;
u32 ibs1;
u32 ibcnr1;
u32 npcr;
u32 dbcr;
u32 dbar;
u32 dbamr;
u32 dbsr;
u32 dbcnr;
u8 res2[12];
u32 dbdr_h;
u32 dbdr_l;
u32 dbdmr_h;
u32 dbdmr_l;
u32 bsr;
u32 bor;
u32 bior;
u8 res3[4];
u32 iatr[4];
u32 eicr;
#ifdef CONFIG_OF_HAS_UBOOT_ENV int fdt_env(void *fdt); -- 1.5.2.4
Check out the new SourceForge.net Marketplace. It's the best place to buy or sell services for just about anything Open Source. http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Andy Fleming
Timur Tabi
