[PATCH] ARM: dts: imx6q-dhcom: Use 1G ethernet on the PDK2 board
From: Christoph Niedermaier cniedermaier@dh-electronics.com
The PDK2 board is capable of running both 100M and 1G ethernet. However, the i.MX6 has only one ethernet MAC, so it is possible to configure either 100M or 1G Ethernet. In case of 100M option, the PHY is on the SoM and the signals are routed to a RJ45 port. For 1G the PHY is on the PDK2 board with another RJ45 port. 100M and 1G ethernet use different signal pins from the i.MX6, but share the MDIO bus.
This SoM board combination is used to demonstrate how to enable 1G ethernet configuration.
Signed-off-by: Christoph Niedermaier cniedermaier@dh-electronics.com Signed-off-by: Marek Vasut marex@denx.de Cc: Christoph Niedermaier cniedermaier@dh-electronics.com Cc: Stefano Babic sbabic@denx.de --- NOTE: Adapted from Linux 298591bf725a ("ARM: dts: imx6q-dhcom: Use 1G ethernet on the PDK2 board") --- arch/arm/dts/imx6qdl-dhcom-pdk2-u-boot.dtsi | 2 +- arch/arm/dts/imx6qdl-dhcom-pdk2.dtsi | 50 +++++++++++++++++++-- include/configs/dh_imx6.h | 4 +- 3 files changed, 50 insertions(+), 6 deletions(-)
diff --git a/arch/arm/dts/imx6qdl-dhcom-pdk2-u-boot.dtsi b/arch/arm/dts/imx6qdl-dhcom-pdk2-u-boot.dtsi index 32128d4d2ab..a1ffb1d6fc5 100644 --- a/arch/arm/dts/imx6qdl-dhcom-pdk2-u-boot.dtsi +++ b/arch/arm/dts/imx6qdl-dhcom-pdk2-u-boot.dtsi @@ -15,7 +15,7 @@ };
&fec { - phy-reset-gpios = <&gpio5 0 GPIO_ACTIVE_LOW>; + phy-reset-gpios = <&gpio3 29 GPIO_ACTIVE_LOW>; phy-reset-duration = <1>; phy-reset-post-delay = <10>;
diff --git a/arch/arm/dts/imx6qdl-dhcom-pdk2.dtsi b/arch/arm/dts/imx6qdl-dhcom-pdk2.dtsi index af4719aaeba..d8772a98966 100644 --- a/arch/arm/dts/imx6qdl-dhcom-pdk2.dtsi +++ b/arch/arm/dts/imx6qdl-dhcom-pdk2.dtsi @@ -38,6 +38,45 @@ status = "okay"; };
+/* 1G ethernet */ +/delete-node/ ðphy0; +&fec { + phy-mode = "rgmii"; + phy-handle = <ðphy7>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet_1G>; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy7: ethernet-phy@7 { /* KSZ 9021 */ + compatible = "ethernet-phy-ieee802.3-c22"; + interrupt-parent = <&gpio1>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + pinctrl-0 = <&pinctrl_ethphy7>; + pinctrl-names = "default"; + reg = <7>; + reset-gpios = <&gpio3 29 GPIO_ACTIVE_LOW>; + reset-assert-us = <1000>; + reset-deassert-us = <1000>; + rxc-skew-ps = <3000>; + rxd0-skew-ps = <0>; + rxd1-skew-ps = <0>; + rxd2-skew-ps = <0>; + rxd3-skew-ps = <0>; + txc-skew-ps = <3000>; + txd0-skew-ps = <0>; + txd1-skew-ps = <0>; + txd2-skew-ps = <0>; + txd3-skew-ps = <0>; + rxdv-skew-ps = <0>; + txen-skew-ps = <0>; + }; + }; +}; + &hdmi { ddc-i2c-bus = <&i2c2>; status = "okay"; @@ -113,9 +152,14 @@ MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x1b0b0 MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x1b0b0 MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x1b0b0 - MX6QDL_PAD_EIM_D29__GPIO3_IO29 0x000b0 - MX6QDL_PAD_GPIO_0__GPIO1_IO00 0x000b1 - MX6QDL_PAD_EIM_D26__GPIO3_IO26 0x000b1 + >; + }; + + pinctrl_ethphy7: ethphy7-grp { + fsl,pins = < + MX6QDL_PAD_EIM_D29__GPIO3_IO29 0xb0 /* Reset */ + MX6QDL_PAD_GPIO_0__GPIO1_IO00 0xb1 /* Int */ + MX6QDL_PAD_EIM_D26__GPIO3_IO26 0xb1 /* WOL */ >; };
diff --git a/include/configs/dh_imx6.h b/include/configs/dh_imx6.h index 8183e7debd4..3cf0578b5e1 100644 --- a/include/configs/dh_imx6.h +++ b/include/configs/dh_imx6.h @@ -32,9 +32,9 @@
/* FEC ethernet */ #define IMX_FEC_BASE ENET_BASE_ADDR -#define CONFIG_FEC_XCV_TYPE RMII +#define CONFIG_FEC_XCV_TYPE RGMII #define CONFIG_ETHPRIME "FEC" -#define CONFIG_FEC_MXC_PHYADDR 0 +#define CONFIG_FEC_MXC_PHYADDR 7 #define CONFIG_ARP_TIMEOUT 200UL
/* MMC Configs */
From: Christoph Niedermaier cniedermaier@dh-electronics.com The PDK2 board is capable of running both 100M and 1G ethernet. However, the i.MX6 has only one ethernet MAC, so it is possible to configure either 100M or 1G Ethernet. In case of 100M option, the PHY is on the SoM and the signals are routed to a RJ45 port. For 1G the PHY is on the PDK2 board with another RJ45 port. 100M and 1G ethernet use different signal pins from the i.MX6, but share the MDIO bus. This SoM board combination is used to demonstrate how to enable 1G ethernet configuration. Signed-off-by: Christoph Niedermaier cniedermaier@dh-electronics.com Signed-off-by: Marek Vasut marex@denx.de Cc: Christoph Niedermaier cniedermaier@dh-electronics.com Cc: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
sbabic@denx.de
