[PATCH] configs: am65x_evm: Use envboot before distro_bootcmd
Use envboot cmd before issuring distro_bootcmd as otherwise environment variables from uEnv.txt are not getting imported.
The commands after distro_bootcmd have no impact since board starts booting after distro_bootcmd, so it need to run last after all environment variables are configured correctly.
Fixes: bde6ac54905 ("configs: am65x_evm: Switch envboot out for distro_bootcmd")
Signed-off-by: Devarsh Thakkar devarsht@ti.com --- Boot logs (with display overlay) : https://gist.github.com/devarsht/2bac56933847d3e954d6ee275d711e27 --- configs/am65x_evm_a53_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index 4301553af8..4f1ef10e69 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -34,7 +34,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 CONFIG_OF_SYSTEM_SETUP=y CONFIG_DISTRO_DEFAULTS=y -CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd; run init_${boot}; run boot_rprocs; run get_kern_${boot}; run get_fdt_${boot}; run get_overlay_${boot}; run run_kern" +CONFIG_BOOTCOMMAND="run envboot; run distro_bootcmd;" CONFIG_LOGLEVEL=7 CONFIG_CONSOLE_MUX=y CONFIG_SPL_MAX_SIZE=0x58000
This should just be switched to standard boot instead.
Devarsh Thakkar
