[U-Boot] [PATCH] 86xx: Update CPU info output on bootup
- Update style of 86xx CPU information on boot to more closely match 85xx boards - Fix detection of 8641/8641D - Use strmhz() to display frequencies - Display L1 information - Display L2 cache size
== Before == Freescale PowerPC CPU: Core: E600 Core 0, Version: 0.2, (0x80040202) System: Unknown, Version: 2.1, (0x80900121) Clocks: CPU:1066 MHz, MPX: 533 MHz, DDR: 266 MHz, LBC: 133 MHz L2: Enabled Board: X-ES XPedite5170 3U VPX SBC
== After == CPU: 8641D, Version: 2.1, (0x80900121) Core: E600 Core 0, Version: 0.2, (0x80040202) Clock Configuration: CPU:1066.667 MHz, MPX:533.333 MHz DDR:266.667 MHz (533.333 MT/s data rate), LBC:133.333 MHz L1: D-cache 32 KB enabled I-cache 32 KB enabled L2: 512 KB enabled Board: X-ES XPedite5170 3U VPX SBC
Signed-off-by: Peter Tyser ptyser@xes-inc.com --- cpu/mpc86xx/cpu.c | 80 +++++++++++++++++++++++++++++------------------------ 1 files changed, 44 insertions(+), 36 deletions(-)
diff --git a/cpu/mpc86xx/cpu.c b/cpu/mpc86xx/cpu.c index b2a107d..42436ba 100644 --- a/cpu/mpc86xx/cpu.c +++ b/cpu/mpc86xx/cpu.c @@ -50,19 +50,39 @@ checkcpu(void) uint pvr, svr; uint ver; uint major, minor; + char buf1[32], buf2[32]; volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; volatile ccsr_gur_t *gur = &immap->im_gur;
- puts("Freescale PowerPC\n"); + svr = get_svr(); + ver = SVR_SOC_VER(svr); + major = SVR_MAJ(svr); + minor = SVR_MIN(svr); + + puts("CPU: "); + + switch (ver) { + case SVR_8641: + puts("8641"); + break; + case SVR_8641D: + puts("8641D"); + break; + case SVR_8610: + puts("8610"); + break; + default: + puts("Unknown"); + break; + } + printf(", Version: %d.%d, (0x%08x)\n", major, minor, svr); + puts("Core: ");
pvr = get_pvr(); ver = PVR_VER(pvr); major = PVR_MAJ(pvr); minor = PVR_MIN(pvr);
- puts("CPU:\n"); - puts(" Core: "); - switch (ver) { case PVR_VER(PVR_86xx): { @@ -79,48 +99,36 @@ checkcpu(void) } printf(", Version: %d.%d, (0x%08x)\n", major, minor, pvr);
- svr = get_svr(); - ver = SVR_SOC_VER(svr); - major = SVR_MAJ(svr); - minor = SVR_MIN(svr); - - puts(" System: "); - switch (ver) { - case SVR_8641: - if (SVR_SUBVER(svr) == 1) { - puts("8641D"); - } else { - puts("8641"); - } - break; - case SVR_8610: - puts("8610"); - break; - default: - puts("Unknown"); - break; - } - printf(", Version: %d.%d, (0x%08x)\n", major, minor, svr); - get_sys_info(&sysinfo);
- puts(" Clocks: "); - printf("CPU:%4lu MHz, ", sysinfo.freqProcessor / 1000000); - printf("MPX:%4lu MHz, ", sysinfo.freqSystemBus / 1000000); - printf("DDR:%4lu MHz, ", sysinfo.freqSystemBus / 2000000); + puts("Clock Configuration:\n"); + printf(" CPU:%-4s MHz, ", strmhz(buf1, sysinfo.freqProcessor)); + printf("MPX:%-4s MHz\n", strmhz(buf1, sysinfo.freqSystemBus)); + printf(" DDR:%-4s MHz (%s MT/s data rate), ", + strmhz(buf1, sysinfo.freqSystemBus / 2), + strmhz(buf2, sysinfo.freqSystemBus));
if (sysinfo.freqLocalBus > LCRR_CLKDIV) { - printf("LBC:%4lu MHz\n", sysinfo.freqLocalBus / 1000000); + printf("LBC:%-4s MHz\n", strmhz(buf1, sysinfo.freqLocalBus)); } else { printf("LBC: unknown (LCRR[CLKDIV] = 0x%02lx)\n", sysinfo.freqLocalBus); }
- puts(" L2: "); - if (get_l2cr() & 0x80000000) - puts("Enabled\n"); - else + puts("L1: D-cache 32 KB enabled\n"); + puts(" I-cache 32 KB enabled\n"); + + puts("L2: "); + if (get_l2cr() & 0x80000000) { +#if defined(CONFIG_MPC8610) + puts("256"); +#elif defined(CONFIG_MPC8641) + puts("512"); +#endif + puts(" KB enabled\n"); + } else { puts("Disabled\n"); + }
return 0; }
On Thu, 2009-02-05 at 20:13 -0600, Kumar Gala wrote:
Since you are touching things here.. mind fixing the Version print. Its clearly not Version 0.2
Will do.
While we're discussing it I had 2 other questions: 1. Can anyone at Freescale give a hint about how to tell the difference between the 8640 and 8641?
2. Does anyone know how the PVR in IBM's 750 line of processors is parsed? I didn't see it in 750 processor datasheets and wanted to update the following line of code in cpu/74xx_7xx.c while updating the 86xx: - printf ("%s v%d.%d", str, (pvr >> 8) & 0xFF, pvr & 0xFF);
The 86xx and 74xx processors all use the convention below but I wanted to make sure it wouldn't break any 750-based cpus when changing it: - printf ("%s v%d.%d", str, (pvr >> 8) & 0xF, pvr & 0xFF);
Thanks, Peter
Will do.
- Can anyone at Freescale give a hint about how to tell the
why do you need to? If I'm not mistaken the 8640 is identical to 8641 except for freq and maybe the package.
- Does anyone know how the PVR in IBM's 750 line of processors is
take a look at the linux kernel tree (arch/powerpc/kernel/setup- common.c) (I think it does the right thing for 750)
- k
Will do.
It would be nice for aesthetic reasons only. My understanding was that the 8640 was just a die shrunk 8641 and that there was no functional difference as you mention.
Linux seems to match U-Boot for the 750 PVR, but there are some suspicious question marks in the comments in setup-common.c for the 750 PVR settings which make me wonder...
In any case I'll just modify the 86xx for now.
Thanks, Peter
As far as I can tell there is NO software way to tell the two from each other.
- k
Kumar Gala
Peter Tyser
