[U-Boot] CUSTODIANS: Urgent boarding call for flight 2009.03
Hi Custodians (and everybody else),
can you please check if all urgent patches have been added to the U-Boot master branch?
If anything should still be missing, please respond *now*.
My intention is to push out the 2009.03 release on schedule, i. e. on Saturday, March 21, 2009.
At the moment I am not planning for another release candidate.
Note: after the release is out, I will merge the current "next" branch into "master", so this will be the starting point for the next merge window.
Thanks.
Hello Wolfgang,
I miss the following patchseries:
http://lists.denx.de/pipermail/u-boot/2009-March/048916.html
bye Heiko
Dear Heiko Schocher,
Thanks for pointing out (I though this was for "next").
Hi Wolfgang,
Microblaze code is OK - without build errors.
Thanks, Michal
Thanks.
Hello,
* With GCC 4.2.3, all MIPS targets builds fine without any errors. MAKEALL output is attached.
* But with GCC 4.3.2, you would see hundreds of bitops.h warnings. Besides, some could be compiled (gth2, etc.), but some failed (qemu_mips, etc.). Bitops.h warnings are as follows:
In file included from /home/skuribay/git/u-boot.git/include/linux/bitops.h:69, from /home/skuribay/git/u-boot.git/include/common.h:36, from qemu-mips.c:24: /home/skuribay/git/u-boot.git/include/asm/bitops.h: In function 'ext2_find_next_zero_bit': /home/skuribay/git/u-boot.git/include/asm/bitops.h:862: warning: '__fswab32' is static but used in inline function 'ext2_find_next_zero_bit' which is not static /home/skuribay/git/u-boot.git/include/asm/bitops.h:885: warning: '__fswab32' is static but used in inline function 'ext2_find_next_zero_bit' which is not static /home/skuribay/git/u-boot.git/include/asm/bitops.h:887: warning: '__fswab32' is static but used in inline function 'ext2_find_next_zero_bit' which is not static
I have to look into these warnings, but couldn't make it into the upcomming v2009.03 release.
Thanks,
Shinya
--- MAKEALL log with GCC 4.2.3
skuribay@ubuntu:u-boot.git$ ./MAKEALL mips mips_el Configuring for incaip board... text data bss dec hex filename 144552 6652 20240 171444 29db4 ./u-boot Configuring for qemu-mips board... text data bss dec hex filename 158600 6480 221768 386848 5e720 ./u-boot ... on Platinum board variant Configuring for vct board... text data bss dec hex filename 196240 12916 284356 493512 787c8 ./u-boot ... on Platinum board variant ... stripped down image variant Configuring for vct board... text data bss dec hex filename 87616 4336 13716 105668 19cc4 ./u-boot ... on Platinum board variant ... on OneNAND board variant Configuring for vct board... text data bss dec hex filename 290272 14076 287772 592120 908f8 ./u-boot ... on Platinum board variant ... on OneNAND board variant ... stripped down image variant Configuring for vct board... text data bss dec hex filename 180592 5484 17116 203192 319b8 ./u-boot ... on PlatinumAVC board variant Configuring for vct board... text data bss dec hex filename 117040 5400 14944 137384 218a8 ./u-boot ... on PlatinumAVC board variant ... stripped down image variant Configuring for vct board... text data bss dec hex filename 87168 4336 13716 105220 19b04 ./u-boot ... on PlatinumAVC board variant ... on OneNAND board variant Configuring for vct board... text data bss dec hex filename 211132 6556 18344 236032 39a00 ./u-boot ... on PlatinumAVC board variant ... on OneNAND board variant ... stripped down image variant Configuring for vct board... text data bss dec hex filename 180136 5484 17116 202736 317f0 ./u-boot ... on Premium board variant Configuring for vct board... text data bss dec hex filename 196240 12916 284356 493512 787c8 ./u-boot ... on Premium board variant ... stripped down image variant Configuring for vct board... text data bss dec hex filename 87616 4336 13716 105668 19cc4 ./u-boot ... on Premium board variant ... on OneNAND board variant Configuring for vct board... text data bss dec hex filename 290272 14076 287772 592120 908f8 ./u-boot ... on Premium board variant ... on OneNAND board variant ... stripped down image variant Configuring for vct board... text data bss dec hex filename 180592 5484 17116 203192 319b8 ./u-boot Configuring for purple board... text data bss dec hex filename 146120 6308 18956 171384 29d78 ./u-boot Configuring for dbau1x00 board... text data bss dec hex filename 118524 5292 20680 144496 23470 ./u-boot Configuring for dbau1x00 board... text data bss dec hex filename 118524 5292 20680 144496 23470 ./u-boot Configuring for dbau1x00 board... text data bss dec hex filename 118524 5292 20680 144496 23470 ./u-boot Configuring for dbau1x00 board... text data bss dec hex filename 115540 5376 23352 144268 2338c ./u-boot Configuring for dbau1x00 board... text data bss dec hex filename 115540 5376 23352 144268 2338c ./u-boot Configuring for gth2 board... text data bss dec hex filename 110900 5284 18376 134560 20da0 ./u-boot Configuring for dbau1x00 board... text data bss dec hex filename 115540 5376 23352 144268 2338c ./u-boot Configuring for pb1x00 board... text data bss dec hex filename 104600 6144 20488 131232 200a0 ./u-boot skuribay@ubuntu:u-boot.git$ skuribay@ubuntu:u-boot.git$ skuribay@ubuntu:u-boot.git$ mips-linux-gnu-gcc --version mips-linux-gnu-gcc (Sourcery G++ Lite 4.2-177) 4.2.3 Copyright (C) 2007 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Dear Shinya,
In message 49C26C23.2030808@ruby.dti.ne.jp you wrote:
- With GCC 4.2.3, all MIPS targets builds fine without any errors. MAKEALL output is attached.
Thanks.
- But with GCC 4.3.2, you would see hundreds of bitops.h warnings. Besides, some could be compiled (gth2, etc.), but some failed (qemu_mips, etc.). Bitops.h warnings are as follows:
I am aware of these issues. There are similar problems for other architectures as well. I agree that wepost-pone such work for the next release.
Thanks a lot.
For ARM the only pending patch are the OMAP3 usb clock which I wait the new version and the NetStar
The AVR32 failled to build
Configuring for atstk1002 board... In file included from cpu.c:25: /private/u-boot-arm/include/asm/io.h:129: error: conflicting types for 'virt_to_phys' /private/u-boot-arm/include/asm/io.h:80: error: previous definition of 'virt_to_phys' was here make[1]: *** [cpu.o] Error 1 make: *** [cpu/at32ap/libat32ap.a] Error 2 make: *** Waiting for unfinished jobs.... In file included from gpio.c:24: /private/u-boot-arm/include/asm/io.h:129: error: conflicting types for 'virt_to_phys' /private/u-boot-arm/include/asm/io.h:80: error: previous definition of 'virt_to_phys' was here make[1]: *** [gpio.o] Error 1 make[1]: In file included from clk.c:24: /private/u-boot-arm/include/asm/io.h:129: error: conflicting types for 'virt_to_phys' /private/u-boot-arm/include/asm/io.h:80: error: previous definition of 'virt_to_phys' was here
Haavard could you take a look?
Best Regards, J.
Latest upstream master builds just fine here...though the last release may be broken because I pushed the fix too late.
Thanks a lot for keeping an eye on things.
Haavard
I've try the next branch and it's failled too
cache.c:25:33: error: asm/arch/cacheflush.h: No such file or directory board.c:89:33: error: asm/arch/cacheflush.h: No such file or directory cache.c:25:33: error: asm/arch/cacheflush.h: No such file or directory cache.c: In function 'dcache_clean_range': cache.c:38: warning: implicit declaration of function 'dcache_clean_line' cache.c:40: warning: implicit declaration of function 'sync_write_buffer' cache.c: In function 'dcache_invalidate_range': cache.c:54: warning: implicit declaration of function 'dcache_invalidate_line' cache.c: In function 'dcache_flush_range': cache.c:68: warning: implicit declaration of function 'dcache_flush_line' cache.c: In function 'icache_invalidate_range': cache.c:84: warning: implicit declaration of function 'icache_invalidate_line' make[1]: *** [cache.o] Error 1 make: *** [cpu/at32ap/libat32ap.a] Error 2 make: *** Waiting for unfinished jobs.... board.c:89:33: error: asm/arch/cacheflush.h: No such file or directory board.c: In function 'dma_alloc_init': board.c:108: warning: implicit declaration of function 'dcache_invalidate_range' make[1]: *** [board.o] Error 1 make[1]: *** Waiting for unfinished jobs.... make: *** [lib_avr32/libavr32.a] Error 2
your welcome
Best Regards, J.
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- .../asm-avr32/{ => arch-at32ap700x}/cacheflush.h | 0 1 files changed, 0 insertions(+), 0 deletions(-) rename include/asm-avr32/{ => arch-at32ap700x}/cacheflush.h (100%)
diff --git a/include/asm-avr32/cacheflush.h b/include/asm-avr32/arch-at32ap700x/cacheflush.h similarity index 100% rename from include/asm-avr32/cacheflush.h rename to include/asm-avr32/arch-at32ap700x/cacheflush.h
Applied, thanks
Haavard
Ah, I see the avr32 master branch is still broken. I've fixed it by pulling from mainline.
Right...looks like one of the UC3 patches got mangled somehow. I'll have a look at that.
Haavard
Deari Wolfgang.
SH build status(sh2/sh3/sh4) is fine. My manage boards and some other boards work without problem.
However, there is a problem because the following patches are not taken in. - [U-Boot] [PATCH to 2008.03] net: sh_eth: Remove sh_eth_reset() from halt function
A title makes a mistake in this. To be right is 2009.03. I sent the email which already pointed out a mistake.
Best regards, Nobuhiro
Thanks.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "There are three principal ways to lose money: wine, women, and en- gineers. While the first two are more pleasant, the third is by far the more certain." -- Baron Rothschild, ca. 1800 _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Dear Nobuhiro Iwamatsu,
No problem, I will apply this patch later tonight.
Thanks again.
participants (7)
Haavard Skinnemoen
Heiko Schocher
Michal Simek
Nobuhiro Iwamatsu
Shinya Kuribayashi
