[U-Boot] *** Your dtc is too old, please upgrade to dtc 1.4 or newer make: *** [checkdtc] Error 1
Hai, I am running u-boot time DTC is old is coming, Actually i am upgraded my system Just know once again same problem coming i think DTC old means Device tree Compiler old: *** Your dtc is too old, please upgrade to dtc 1.4 or newer make: *** [checkdtc] Error 1
Thanking you
-- View this message in context: http://u-boot.10912.n7.nabble.com/Your-dtc-is-too-old-please-upgrade-to-dtc-... Sent from the U-Boot mailing list archive at Nabble.com.
If you play on ubuntu, try apt-get install device-tree- compiler
Thanking you
-- View this message in context: http://u-boot.10912.n7.nabble.com/Your-dtc-is-too-old-please-upgrade-to-dtc-... Sent from the U-Boot mailing list archive at Nabble.com. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Already i am installed using sudo apt-get install device-tree-compiler butt same problem coming
Thanking you, Ram.
Make sure your dtc version, MUST be V1.4 or newer.
e.g.
$ dtc -v Version: DTC 1.4.0
________________________________ Best Regards! Phenix
________________________________________ 发件人: U-Boot u-boot-bounces@lists.denx.de 代表 pc.ramachandra pc.ramachandra@gmail.com 发送时间: 2016年8月26日 19:34 收件人: u-boot@lists.denx.de 主题: Re: [U-Boot] *** Your dtc is too old, please upgrade to dtc 1.4 or newer make: *** [checkdtc] Error 1
Thanking you, Ram.
pc.ramachandra
Yan Phenix
Ziyuan Xu
