[U-Boot] kirkwood sheevaplug - broken build using git.denx.de/u-boot.git
Hi all,
I've tried to build u-boot for sheevaplug from git.denx.de/u-boot.git Is this expected to work or are there some missing dependencies or what am I doing wrong? (The same happens on u-boot-arm custodian tree. Only Prafullas tree from git.marvell.com allows me to build u-boot for sheevaplug.)
The build gives me following error (without any prior warnings!):
make[1]: Verlasse Verzeichnis '/home/dieter/git/u-boot/u-boot.git/cpu/arm926ejs' UNDEF_SYM=`arm-none-linux-gnueabi-objdump -x board/Marvell/sheevaplug/libsheevaplug.a lib_generic/libgeneric.a lib_generic/lzma/liblzma.a lib_generic/lzo/liblzo.a cpu/arm926ejs/libarm926ejs.a cpu/arm926ejs/kirkwood/libkirkwood.a lib_arm/libarm.a fs/cramfs/libcramfs.a fs/fat/libfat.a fs/fdos/libfdos.a fs/jffs2/libjffs2.a fs/reiserfs/libreiserfs.a fs/ext2/libext2fs.a fs/yaffs2/libyaffs2.a fs/ubifs/libubifs.a net/libnet.a disk/libdisk.a drivers/bios_emulator/libatibiosemu.a drivers/block/libblock.a drivers/dma/libdma.a drivers/fpga/libfpga.a drivers/gpio/libgpio.a drivers/hwmon/libhwmon.a drivers/i2c/libi2c.a drivers/input/libinput.a drivers/misc/libmisc.a drivers/mmc/libmmc.a drivers/mtd/libmtd.a drivers/mtd/nand/libnand.a drivers/mtd/onenand/libonenand.a drivers/mtd/ubi/libubi.a drivers/mtd/spi/libspi_flash.a drivers/net/libnet.a drivers/net/phy/libphy.a drivers/net/sk98lin/libsk98lin.a drivers/pci/libpci.a drivers/pcmcia/libpcmcia.a drivers/spi/libspi.a drivers/rtc/librtc.a drivers/serial/libserial.a drivers/twserial/libtws.a drivers/usb/gadget/libusb_gadget.a drivers/usb/host/libusb_host.a drivers/usb/musb/libusb_musb.a drivers/video/libvideo.a drivers/watchdog/libwatchdog.a common/libcommon.a libfdt/libfdt.a api/libapi.a post/libpost.a | sed -n -e 's/.*(__u_boot_cmd_.*)/-u\1/p'|sort|uniq`; cd /home/dieter/git/u-boot/u-boot.git && arm-none-linux-gnueabi-ld -Bstatic -T /home/dieter/git/u-boot/u-boot.git/cpu/arm926ejs/u-boot.lds -Ttext 0x00600000 $UNDEF_SYM cpu/arm926ejs/start.o --start-group lib_generic/libgeneric.a lib_generic/lzma/liblzma.a lib_generic/lzo/liblzo.a cpu/arm926ejs/libarm926ejs.a cpu/arm926ejs/kirkwood/libkirkwood.a lib_arm/libarm.a fs/cramfs/libcramfs.a fs/fat/libfat.a fs/fdos/libfdos.a fs/jffs2/libjffs2.a fs/reiserfs/libreiserfs.a fs/ext2/libext2fs.a fs/yaffs2/libyaffs2.a fs/ubifs/libubifs.a net/libnet.a disk/libdisk.a drivers/bios_emulator/libatibiosemu.a drivers/block/libblock.a drivers/dma/libdma.a drivers/fpga/libfpga.a drivers/gpio/libgpio.a drivers/hwmon/libhwmon.a drivers/i2c/libi2c.a drivers/input/libinput.a drivers/misc/libmisc.a drivers/mmc/libmmc.a drivers/mtd/libmtd.a drivers/mtd/nand/libnand.a drivers/mtd/onenand/libonenand.a drivers/mtd/ubi/libubi.a drivers/mtd/spi/libspi_flash.a drivers/net/libnet.a drivers/net/phy/libphy.a drivers/net/sk98lin/libsk98lin.a drivers/pci/libpci.a drivers/pcmcia/libpcmcia.a drivers/spi/libspi.a drivers/rtc/librtc.a drivers/serial/libserial.a drivers/twserial/libtws.a drivers/usb/gadget/libusb_gadget.a drivers/usb/host/libusb_host.a drivers/usb/musb/libusb_musb.a drivers/video/libvideo.a drivers/watchdog/libwatchdog.a common/libcommon.a libfdt/libfdt.a api/libapi.a post/libpost.a board/Marvell/sheevaplug/libsheevaplug.a --end-group -L /opt/Orion-SDK/armel-2.0/tools/gcc/bin/../lib/gcc/arm-none-linux-gnueabi/4.2.0 -lgcc -Map u-boot.map -o u-boot arm-none-linux-gnueabi-ld: ERROR: Source object /opt/Orion-SDK/armel-2.0/tools/gcc/bin/../lib/gcc/arm-none-linux-gnueabi/4.2.0/libgcc.a(_lshrdi3.o) has EABI version 4, but target u-boot has EABI version 0 arm-none-linux-gnueabi-ld: failed to merge target specific data of file /opt/Orion-SDK/armel-2.0/tools/gcc/bin/../lib/gcc/arm-none-linux-gnueabi/4.2.0/libgcc.a(_lshrdi3.o) make: *** [u-boot] Fehler 1
Used gcc is: arm-none-linux-gnueabi-gcc (GCC) 4.2.0 20070413 (prerelease)
Any hints are very welcome.
Many thanks, Dieter
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Dieter Kiermaier Sent: Thursday, July 23, 2009 2:13 PM To: u-boot@lists.denx.de Subject: [U-Boot] kirkwood sheevaplug - broken build using git.denx.de/u-boot.git
Hi all,
Dear Dieter No it will not work at this moment.
I have added few patches and u-boot-kw.git at git.marvell.com is full functional for sheevaplug. It is also in sync with latest u-boot.git/master
Regards.. Prafulla . .
Hi Prafulla,
Hi all,
ok
Thanks, so I've overseen this. I thought I've looked at it before I start trying denx u-boot.git because I missed some patches.
Sorry for the noise, Dieter
Dieter Kiermaier
Prafulla Wadaskar
