[U-Boot] [PATCH v4 1/5] dma: lpc32xx: add DMA driver
Incorporate DMA driver from legacy LPCLinux NXP BSP. The files taken from the legacy patch are: - lpc32xx DMA driver - lpc3250 header file DMA registers definition.
The legacy driver was updated and clean-up as part of the integration with the latest u-boot.
Signed-off-by: Sylvain Lemieux slemieux@tycoint.com --- Changes from v3 to v4: * Addressed Marek's comments on LPC32xx DMA driver: - updated multiline comments style. - use "u32" instead of "uint32_t". - fixed unbounded loop.
Changes from v2 to v3: * Addressed Marek's comments on LPC32xx DMA driver: - use defined in header file instead of local definition. - remove for loop and use "ffz()". * Provide define to assign next DMA linked list item address to removed typecast in DMA client (ex. NAND SLC).
Changes from v1 to v2: * Moved the DMA patch as the first patch of the series. * The NAND SLC patch (link below) is applied before this patch: https://patchwork.ozlabs.org/patch/497308/
Update to the legacy driver to integrate with the latest u-boot: 1) Fixed checkpatch script output in legacy code. 2) Use LPC32xx definition from "cpu.h" and "clk.h". 3) Incorporate DMA specific register definition from "lpc3250.h" header file from legacy BSP patch from LPCLinux. 4) Use u-boot API for register access to remove the volatile in register definition taken from "lpc3250.h" header file. 5) Add DMA interface to "dma.h". 6) Add dma clock control register bits (clk.h). 7) Add functions to initialize the DMA clock.
The legacy BSP patch (u-boot-2009.03_lpc32x0-v1.07.patch.tar.bz2) was downloaded from the LPCLinux Web site.
arch/arm/cpu/arm926ejs/lpc32xx/devices.c | 6 + arch/arm/include/asm/arch-lpc32xx/clk.h | 3 + arch/arm/include/asm/arch-lpc32xx/dma.h | 44 ++++++++ arch/arm/include/asm/arch-lpc32xx/sys_proto.h | 1 + drivers/dma/Makefile | 1 + drivers/dma/lpc32xx_dma.c | 157 ++++++++++++++++++++++++++ 6 files changed, 212 insertions(+) create mode 100644 arch/arm/include/asm/arch-lpc32xx/dma.h create mode 100644 drivers/dma/lpc32xx_dma.c
diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/devices.c b/arch/arm/cpu/arm926ejs/lpc32xx/devices.c index c0c9c6c..0d2ef7a 100644 --- a/arch/arm/cpu/arm926ejs/lpc32xx/devices.c +++ b/arch/arm/cpu/arm926ejs/lpc32xx/devices.c @@ -65,6 +65,12 @@ void lpc32xx_slc_nand_init(void) writel(CLK_NAND_SLC | CLK_NAND_SLC_SELECT, &clk->flashclk_ctrl); }
+void lpc32xx_dma_init(void) +{ + /* Enable DMA interface */ + setbits_le32(&clk->dmaclk_ctrl, DMA_CLK_ENABLE); +} + void lpc32xx_i2c_init(unsigned int devnum) { /* Enable I2C interface */ diff --git a/arch/arm/include/asm/arch-lpc32xx/clk.h b/arch/arm/include/asm/arch-lpc32xx/clk.h index 010211a..663f6bc 100644 --- a/arch/arm/include/asm/arch-lpc32xx/clk.h +++ b/arch/arm/include/asm/arch-lpc32xx/clk.h @@ -158,6 +158,9 @@ struct clk_pm_regs { #define CLK_NAND_SLC_SELECT (1 << 2) #define CLK_NAND_MLC_INT (1 << 5)
+/* DMA Clock Control Register bits */ +#define DMA_CLK_ENABLE (1 << 0) + /* SSP Clock Control Register bits */ #define CLK_SSP0_ENABLE_CLOCK (1 << 0)
diff --git a/arch/arm/include/asm/arch-lpc32xx/dma.h b/arch/arm/include/asm/arch-lpc32xx/dma.h new file mode 100644 index 0000000..4f0cf7e --- /dev/null +++ b/arch/arm/include/asm/arch-lpc32xx/dma.h @@ -0,0 +1,44 @@ +/* + * LPC32xx DMA Controller Interface + * + * Copyright (C) 2008-2015 by NXP Semiconductors + * All rights reserved. + * + * @Author: Kevin Wells + * @Descr: Definitions for LPC3250 chip + * @References: NXP LPC3250 User's Guide + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _LPC32XX_DMA_H +#define _LPC32XX_DMA_H + +#include <common.h> + + +/* + * The "dmac_ll" structure is mapping the DMA channel register, + * as per UM10326, "LPC32x0 and LPC32x0/01 User manual" - Rev. 3 + * tables 84, 85, 86 & 87. + * + * The DMA client (ex. NAND SLC) can use this macro to write the + * next DMA linked list item address. + */ +#define lpc32xx_dmac_next_lli(x) (uint32_t)x + +/* DMA linked list structure used with a channel's LLI register */ +struct lpc32xx_dmac_ll { + u32 dma_src; + u32 dma_dest; + u32 next_lli; + u32 next_ctrl; +}; + +int lpc32xx_dma_get_channel(void); +int lpc32xx_dma_start_xfer(int channel, const struct lpc32xx_dmac_ll *desc, + u32 config); +int lpc32xx_dma_wait_status(int channel); +void lpc32xx_dma_put_channel(int channel); + +#endif /* _LPC32XX_DMA_H */ diff --git a/arch/arm/include/asm/arch-lpc32xx/sys_proto.h b/arch/arm/include/asm/arch-lpc32xx/sys_proto.h index 0845f83..7f997d9 100644 --- a/arch/arm/include/asm/arch-lpc32xx/sys_proto.h +++ b/arch/arm/include/asm/arch-lpc32xx/sys_proto.h @@ -13,6 +13,7 @@ void lpc32xx_uart_init(unsigned int uart_id); void lpc32xx_mac_init(void); void lpc32xx_mlc_nand_init(void); void lpc32xx_slc_nand_init(void); +void lpc32xx_dma_init(void); void lpc32xx_i2c_init(unsigned int devnum); void lpc32xx_ssp_init(void); #if defined(CONFIG_SPL_BUILD) diff --git a/drivers/dma/Makefile b/drivers/dma/Makefile index 4c8fcc2..f95fe70 100644 --- a/drivers/dma/Makefile +++ b/drivers/dma/Makefile @@ -10,3 +10,4 @@ obj-$(CONFIG_APBH_DMA) += apbh_dma.o obj-$(CONFIG_FSL_DMA) += fsl_dma.o obj-$(CONFIG_TI_KSNAV) += keystone_nav.o keystone_nav_cfg.o obj-$(CONFIG_TI_EDMA3) += ti-edma3.o +obj-$(CONFIG_DMA_LPC32XX) += lpc32xx_dma.o diff --git a/drivers/dma/lpc32xx_dma.c b/drivers/dma/lpc32xx_dma.c new file mode 100644 index 0000000..3cf32fb --- /dev/null +++ b/drivers/dma/lpc32xx_dma.c @@ -0,0 +1,157 @@ +/* + * Copyright (C) 2008-2015 by NXP Semiconductors + * All rights reserved. + * + * @Author: Kevin Wells + * @Descr: LPC3250 DMA controller interface support functions + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/dma.h> +#include <asm/arch/cpu.h> +#include <asm/arch/clk.h> +#include <asm/arch/sys_proto.h> +#include <asm/io.h> + +/* + * Notes: + * + * Only bitfield masks/values which are actually used by the driver + * are defined. + */ + +/* DMA controller channel register structure */ +struct dmac_chan_reg { + u32 src_addr; + u32 dest_addr; + u32 lli; + u32 control; + u32 config_ch; + u32 reserved[3]; +}; + +/* DMA controller register structures */ +struct dma_reg { + u32 int_stat; + u32 int_tc_stat; + u32 int_tc_clear; + u32 int_err_stat; + u32 int_err_clear; + u32 raw_tc_stat; + u32 raw_err_stat; + u32 chan_enable; + u32 sw_burst_req; + u32 sw_single_req; + u32 sw_last_burst_req; + u32 sw_last_single_req; + u32 config; + u32 sync; + u32 reserved[50]; + struct dmac_chan_reg dma_chan[8]; +}; + +/* Macro pointing to DMA registers */ +#define DMA_NO_OF_CHANNELS 8 + +/* config register definitions */ +#define DMAC_CTRL_ENABLE (1 << 0) /* For enabling the DMA controller */ + +static u32 alloc_ch; + +static struct dma_reg *dma = (struct dma_reg *)DMA_BASE; + +int lpc32xx_dma_get_channel(void) +{ + int i; + + if (!alloc_ch) { /* First time caller */ + /* DMA clock are enable by "lpc32xx_dma_init()" and should + * be call by board "board_early_init_f()" function. */ + + /* Make sure DMA controller and all channels are disabled. + * Controller is in little-endian mode. Disable sync signals */ + writel(0, &dma->config); + writel(0, &dma->sync); + + /* Clear interrupt and error statuses */ + writel(0xFF, &dma->int_tc_clear); + writel(0xFF, &dma->raw_tc_stat); + writel(0xFF, &dma->int_err_clear); + writel(0xFF, &dma->raw_err_stat); + + /* Enable DMA controller */ + writel(DMAC_CTRL_ENABLE, &dma->config); + } + + i = ffz(alloc_ch); + + /* Check if all the available channels are busy */ + if (unlikely(i == DMA_NO_OF_CHANNELS)) + return -1; + alloc_ch |= BIT_MASK(i); + return i; +} + +int lpc32xx_dma_start_xfer(int channel, const struct lpc32xx_dmac_ll *desc, + u32 config) +{ + if (unlikely((BIT_MASK(channel) & alloc_ch) == 0)) { + printf("ERR: Request for xfer on unallocated channel %d\r\n", + channel); + BUG(); + } + writel(BIT_MASK(channel), &dma->int_tc_clear); + writel(BIT_MASK(channel), &dma->int_err_clear); + writel(desc->dma_src, &dma->dma_chan[channel].src_addr); + writel(desc->dma_dest, &dma->dma_chan[channel].dest_addr); + writel(desc->next_lli, &dma->dma_chan[channel].lli); + writel(desc->next_ctrl, &dma->dma_chan[channel].control); + writel(config, &dma->dma_chan[channel].config_ch); + + return 0; +} + +int lpc32xx_dma_wait_status(int channel) +{ + unsigned long start; + + start = get_timer(0); + while (1) { + if (((readl(&dma->raw_tc_stat) | readl(dma->raw_err_stat)) + & BIT_MASK(channel)) != 0) + break; + + if (get_timer(start) > 10000) + return -1; + + udelay(1); + } + + if (unlikely(readl(&dma->raw_err_stat) & BIT_MASK(channel))) { + setbits_le32(&dma->int_err_clear, BIT_MASK(channel)); + setbits_le32(&dma->raw_err_stat, BIT_MASK(channel)); + return -1; + } + setbits_le32(&dma->int_tc_clear, BIT_MASK(channel)); + setbits_le32(&dma->raw_tc_stat, BIT_MASK(channel)); + return 0; +} + +void lpc32xx_dma_put_channel(int channel) +{ + /* Check if given channel no is valid */ + if (channel >= DMA_NO_OF_CHANNELS || channel < 0) + return; + alloc_ch &= ~BIT_MASK(channel); + + /* Shut down channel */ + writel(0, &dma->dma_chan[channel].control); + writel(0, &dma->dma_chan[channel].config_ch); + clrbits_le32(&dma->sync, BIT_MASK(channel)); + + if (!alloc_ch) + /* Disable DMA controller */ + clrbits_le32(&dma->config, DMAC_CTRL_ENABLE); +}
- The "dmac_ll" structure is mapping the DMA channel register,
- as per UM10326, "LPC32x0 and LPC32x0/01 User manual" - Rev. 3
- tables 84, 85, 86 & 87.
- The DMA client (ex. NAND SLC) can use this macro to write the
- next DMA linked list item address.
Ew, and it's not even used :-)
- u32 dma_src;
- u32 dma_dest;
- u32 next_lli;
- u32 next_ctrl;
- unsigned long start;
- start = get_timer(0);
- while (1) {
Here , you can do
reg = readl(); reg |= readl(); if (reg & BIT_MASK()) break;
break;
return -1;
udelay(1);
- if (unlikely(readl(&dma->raw_err_stat) & BIT_MASK(channel))) {
return -1;
- setbits_le32(&dma->int_tc_clear, BIT_MASK(channel));
- setbits_le32(&dma->raw_tc_stat, BIT_MASK(channel));
Other than that,
Acked-by: Marek Vasut marex@denx.de
Hi Marek,
See comment and question below.
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: 4-Aug-15 5:32 PM
This is used inside "drivers/mtd/nand/lpc32xx_nand_slc.c"; Refer to this patch for details: https://patchwork.ozlabs.org/patch/503815/
Are we OK to keep this define there?
- u32 dma_src;
- u32 dma_dest;
- u32 next_lli;
- u32 next_ctrl;
- while (1) {
Here , you can do
Will update the patch.
break;
return -1;
udelay(1);
return -1;
Other than that,
________________________________
This e-mail contains privileged and confidential information intended for the use of the addressees named above. If you are not the intended recipient of this e-mail, you are hereby notified that you must not disseminate, copy or take any action in respect of any information contained in it. If you have received this e-mail in error, please notify the sender immediately by e-mail and immediately destroy this e-mail and its attachments.
On Wednesday, August 05, 2015 at 01:00:03 PM, LEMIEUX, SYLVAIN wrote:
Hi Marek,
Hi!
Sorry, I didn't realize that. But in that case, just use (x) in lpc32xx_nand_slc.c ? The macro is only obfuscating the code.
Also, the macro is wrong, not only does it do explicit cast (not a very nice thing to do), but it also doens't put parenthesis around the x, which can have ugly impacts.
Best regards, Marek Vasut
LEMIEUX, SYLVAIN
slemieux.tycoï¼ gmail.com
