[PATCH 1/3] mtd: spi-nor-ids: Add support for ESMT/EON EN25Q80B
The datasheet can be found here: https://www.esmt.com.tw/upload/pdf/ESMT/datasheets/EN25Q80B_Ver.E.pdf
Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de --- drivers/mtd/spi/spi-nor-ids.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index 38a287487ed..4e83b8c94c9 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -80,6 +80,7 @@ const struct flash_info spi_nor_ids[] = { #endif #ifdef CONFIG_SPI_FLASH_EON /* EON */ /* EON -- en25xxx */ + { INFO("en25q80b", 0x1c3014, 0, 64 * 1024, 16, SECT_4K) }, { INFO("en25q32b", 0x1c3016, 0, 64 * 1024, 64, 0) }, { INFO("en25q64", 0x1c3017, 0, 64 * 1024, 128, SECT_4K) }, { INFO("en25q128b", 0x1c3018, 0, 64 * 1024, 256, 0) },
The Sielaff i.MX6 Solo board is a control and HMI board for vending machines. Add support for this board.
The devicetree files are taken from pending changes in the Linux kernel that are available from linux-next and will likely be part of Linux v6.9.
Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de --- arch/arm/dts/Makefile | 1 + arch/arm/dts/imx6dl-sielaff-u-boot.dtsi | 33 ++ arch/arm/dts/imx6dl-sielaff.dts | 533 ++++++++++++++++++ arch/arm/mach-imx/mx6/Kconfig | 10 + board/sielaff/imx6dl-sielaff/Kconfig | 15 + board/sielaff/imx6dl-sielaff/Makefile | 8 + board/sielaff/imx6dl-sielaff/imx6dl-sielaff.c | 111 ++++ .../sielaff/imx6dl-sielaff/imx6dl-sielaff.env | 115 ++++ board/sielaff/imx6dl-sielaff/spl.c | 277 +++++++++ configs/imx6dl_sielaff_defconfig | 117 ++++ include/configs/imx6dl-sielaff.h | 25 + 11 files changed, 1245 insertions(+) create mode 100644 arch/arm/dts/imx6dl-sielaff-u-boot.dtsi create mode 100644 arch/arm/dts/imx6dl-sielaff.dts create mode 100644 board/sielaff/imx6dl-sielaff/Kconfig create mode 100644 board/sielaff/imx6dl-sielaff/Makefile create mode 100644 board/sielaff/imx6dl-sielaff/imx6dl-sielaff.c create mode 100644 board/sielaff/imx6dl-sielaff/imx6dl-sielaff.env create mode 100644 board/sielaff/imx6dl-sielaff/spl.c create mode 100644 configs/imx6dl_sielaff_defconfig create mode 100644 include/configs/imx6dl-sielaff.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 0fcae77cefe..d60fa1179af 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -930,6 +930,7 @@ dtb-y += \ imx6dl-riotboard.dtb \ imx6dl-sabreauto.dtb \ imx6dl-sabresd.dtb \ + imx6dl-sielaff.dtb \ imx6dl-wandboard-revd1.dtb \ imx6s-dhcom-drc02.dtb
diff --git a/arch/arm/dts/imx6dl-sielaff-u-boot.dtsi b/arch/arm/dts/imx6dl-sielaff-u-boot.dtsi new file mode 100644 index 00000000000..47f4c499031 --- /dev/null +++ b/arch/arm/dts/imx6dl-sielaff-u-boot.dtsi @@ -0,0 +1,33 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +/* + * Copyright (C) 2022 Kontron Electronics GmbH + */ + +#include "imx6qdl-u-boot.dtsi" + +/ { + binman: binman { + filename = "flash.bin"; + pad-byte = <0x00>; + + spl: blob-ext@1 { + offset = <0x0>; + filename = "SPL"; + }; + + uboot: blob-ext@2 { + offset = <0x11000>; + filename = "u-boot.img"; + }; + }; +}; + +&fec { + phy-mode = "rmii"; + phy-reset-gpios = <&gpio5 2 GPIO_ACTIVE_LOW>; + phy-reset-duration = <100>; +}; + +&gpmi { + fsl,legacy-bch-geometry; +}; diff --git a/arch/arm/dts/imx6dl-sielaff.dts b/arch/arm/dts/imx6dl-sielaff.dts new file mode 100644 index 00000000000..7de8d5f2651 --- /dev/null +++ b/arch/arm/dts/imx6dl-sielaff.dts @@ -0,0 +1,533 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +/* + * Copyright (C) 2022 Kontron Electronics GmbH + */ + +/dts-v1/; + +#include "imx6dl.dtsi" +#include <dt-bindings/clock/imx6qdl-clock.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> + +/ { + model = "Sielaff i.MX6 Solo"; + compatible = "sielaff,imx6dl-board", "fsl,imx6dl"; + + chosen { + stdout-path = &uart2; + }; + + backlight: pwm-backlight { + compatible = "pwm-backlight"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_backlight>; + pwms = <&pwm3 0 50000 0>; + brightness-levels = <0 0 64 88 112 136 184 232 255>; + default-brightness-level = <4>; + enable-gpios = <&gpio6 16 GPIO_ACTIVE_HIGH>; + power-supply = <®_backlight>; + }; + + cec { + compatible = "cec-gpio"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hdmi_cec>; + cec-gpios = <&gpio2 7 GPIO_ACTIVE_HIGH>; + hdmi-phandle = <&hdmi>; + }; + + enet_ref: clock-enet-ref { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <50000000>; + clock-output-names = "enet-ref"; + }; + + gpio-keys { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_keys>; + + key-0 { + gpios = <&gpio2 16 0>; + debounce-interval = <10>; + linux,code = <1>; + }; + + key-1 { + gpios = <&gpio3 27 0>; + debounce-interval = <10>; + linux,code = <2>; + }; + + key-2 { + gpios = <&gpio5 4 0>; + debounce-interval = <10>; + linux,code = <3>; + }; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_leds>; + + led-debug { + label = "debug-led"; + gpios = <&gpio5 21 GPIO_ACTIVE_HIGH>; + default-state = "off"; + linux,default-trigger = "heartbeat"; + }; + }; + + memory@80000000 { + reg = <0x80000000 0x20000000>; + device_type = "memory"; + }; + + osc_eth_phy: clock-osc-eth-phy { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <25000000>; + clock-output-names = "osc-eth-phy"; + }; + + panel { + compatible = "lg,lb070wv8"; + backlight = <&backlight>; + power-supply = <®_3v3>; + + port { + panel_in_lvds: endpoint { + remote-endpoint = <&lvds_out>; + }; + }; + }; + + reg_3v3: regulator-3v3 { + compatible = "regulator-fixed"; + regulator-name = "3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + reg_backlight: regulator-backlight { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_backlight>; + enable-active-high; + gpio = <&gpio1 23 GPIO_ACTIVE_HIGH>; + regulator-name = "backlight"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + reg_usb_otg_vbus: regulator-usb-otg-vbus { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_usbotg_vbus>; + enable-active-high; + gpio = <&gpio4 15 GPIO_ACTIVE_HIGH>; + regulator-name = "usb_otg_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; +}; + +&ecspi2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ecspi2>; + cs-gpios = <&gpio5 29 GPIO_ACTIVE_LOW>; + status = "okay"; + + flash@0 { + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <20000000>; + }; +}; + +&fec { + /* + * Set PTP clock to external instead of internal reference, as the + * REF_CLK from the PHY is fed back into the i.MX6 and the GPR + * register needs to be set accordingly (see mach-imx6q.c). + */ + clocks = <&clks IMX6QDL_CLK_ENET>, + <&clks IMX6QDL_CLK_ENET>, + <&enet_ref>, + <&clks IMX6QDL_CLK_ENET_REF>; + clock-names = "ipg", "ahb", "ptp", "enet_out"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet>; + phy-connection-type = "rmii"; + phy-handle = <ðphy>; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy: ethernet-phy@1 { + reg = <1>; + clocks = <&osc_eth_phy>; + clock-names = "rmii-ref"; + micrel,led-mode = <1>; + reset-assert-us = <500>; + reset-deassert-us = <100>; + reset-gpios = <&gpio5 2 GPIO_ACTIVE_LOW>; + }; + }; +}; + +&gpio1 { + gpio-line-names = + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "key-out", "key-in", + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", ""; +}; + +&gpio2 { + gpio-line-names = + "", "", "", "", "", "", "", "", + "lan9500a-rst", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", ""; +}; + +&gpmi { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpmi_nand>; + status = "okay"; +}; + +&hdmi { + ddc-i2c-bus = <&i2c4>; + status = "okay"; +}; + +&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + clock-frequency = <100000>; + status = "okay"; + + rtc@51 { + compatible = "nxp,pcf8563"; + reg = <0x51>; + }; +}; + +&i2c3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + clock-frequency = <100000>; + status = "okay"; + + touchscreen@55 { + compatible = "sitronix,st1633"; + reg = <0x55>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_touch>; + interrupts = <18 IRQ_TYPE_EDGE_FALLING>; + interrupt-parent = <&gpio5>; + gpios = <&gpio1 2 GPIO_ACTIVE_LOW>; + status = "disabled"; + }; + + touchscreen@5d { + compatible = "goodix,gt928"; + reg = <0x5d>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_touch>; + interrupts = <18 IRQ_TYPE_LEVEL_LOW>; + interrupt-parent = <&gpio5>; + irq-gpios = <&gpio5 18 GPIO_ACTIVE_HIGH>; + reset-gpios = <&gpio1 2 GPIO_ACTIVE_HIGH>; + status = "disabled"; + }; +}; + +&i2c4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c4>; + clock-frequency = <100000>; + status = "okay"; +}; + +&ldb { + status = "okay"; + + lvds: lvds-channel@0 { + fsl,data-mapping = "spwg"; + fsl,data-width = <24>; + status = "okay"; + + port@4 { + reg = <4>; + + lvds_out: endpoint { + remote-endpoint = <&panel_in_lvds>; + }; + }; + }; +}; + +&pwm3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm3>; + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "okay"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + status = "okay"; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + status = "okay"; +}; + +&usbh1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbh1>; + disable-over-current; + status = "okay"; + + #address-cells = <1>; + #size-cells = <0>; + + usb1@1 { + compatible = "usb4b4,6570"; + reg = <1>; + clocks = <&clks IMX6QDL_CLK_CKO>; + + assigned-clocks = <&clks IMX6QDL_CLK_CKO>, + <&clks IMX6QDL_CLK_CKO2_SEL>; + assigned-clock-parents = <&clks IMX6QDL_CLK_CKO2>, + <&clks IMX6QDL_CLK_OSC>; + assigned-clock-rates = <12000000 0>; + }; +}; + +&usbotg { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbotg>; + dr_mode = "host"; + over-current-active-low; + vbus-supply = <®_usb_otg_vbus>; + status = "okay"; +}; + +&usdhc3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc3>; + cd-gpios = <&gpio1 4 GPIO_ACTIVE_LOW>; + vmmc-supply = <®_3v3>; + voltage-ranges = <3300 3300>; + no-1-8-v; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog>; + + pinctrl_hog: hoggrp { + fsl,pins = < + MX6QDL_PAD_RGMII_RD0__GPIO6_IO25 0x1b0b0 /* PMIC_IRQ */ + MX6QDL_PAD_SD2_DAT3__GPIO1_IO12 0x1b0b0 + MX6QDL_PAD_SD2_DAT1__GPIO1_IO14 0x1b0b0 + MX6QDL_PAD_SD2_DAT0__GPIO1_IO15 0x1b0b0 + MX6QDL_PAD_SD4_DAT0__GPIO2_IO08 0x1b0b0 + MX6QDL_PAD_EIM_D29__GPIO3_IO29 0x1b0b0 + >; + }; + + pinctrl_backlight: backlightgrp { + fsl,pins = < + MX6QDL_PAD_NANDF_CS3__GPIO6_IO16 0x100b1 + >; + }; + + pinctrl_ecspi2: ecspi2grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT10__ECSPI2_MISO 0x100b1 + MX6QDL_PAD_CSI0_DAT9__ECSPI2_MOSI 0x100b1 + MX6QDL_PAD_CSI0_DAT8__ECSPI2_SCLK 0x100b1 + MX6QDL_PAD_CSI0_DAT11__GPIO5_IO29 0x100b1 + >; + }; + + pinctrl_enet: enetgrp { + fsl,pins = < + MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1b0b0 + MX6QDL_PAD_ENET_MDC__ENET_MDC 0x1b0b0 + MX6QDL_PAD_ENET_RXD0__ENET_RX_DATA0 0x1b0b0 + MX6QDL_PAD_ENET_RXD1__ENET_RX_DATA1 0x1b0b0 + MX6QDL_PAD_ENET_CRS_DV__ENET_RX_EN 0x1b0b0 + MX6QDL_PAD_ENET_RX_ER__ENET_RX_ER 0x1b0b0 + MX6QDL_PAD_ENET_TXD0__ENET_TX_DATA0 0x1b0b0 + MX6QDL_PAD_ENET_TXD1__ENET_TX_DATA1 0x1b0b0 + MX6QDL_PAD_ENET_TX_EN__ENET_TX_EN 0x1b0b0 + MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x4001b0a8 + MX6QDL_PAD_EIM_A25__GPIO5_IO02 0x100b1 + >; + }; + + pinctrl_gpio_keys: gpiokeysgrp { + fsl,pins = < + MX6QDL_PAD_EIM_A22__GPIO2_IO16 0x1b080 + MX6QDL_PAD_EIM_D27__GPIO3_IO27 0x1b080 + MX6QDL_PAD_EIM_A24__GPIO5_IO04 0x1b080 + >; + }; + + pinctrl_gpio_leds: gpioledsgrp { + fsl,pins = < + MX6QDL_PAD_CSI0_VSYNC__GPIO5_IO21 0x1b0b0 + >; + }; + + pinctrl_gpmi_nand: gpminandgrp { + fsl,pins = < + MX6QDL_PAD_NANDF_CLE__NAND_CLE 0xb0b1 + MX6QDL_PAD_NANDF_ALE__NAND_ALE 0xb0b1 + MX6QDL_PAD_NANDF_WP_B__NAND_WP_B 0xb0b1 + MX6QDL_PAD_NANDF_RB0__NAND_READY_B 0xb000 + MX6QDL_PAD_NANDF_CS0__NAND_CE0_B 0xb0b1 + MX6QDL_PAD_SD4_CMD__NAND_RE_B 0xb0b1 + MX6QDL_PAD_SD4_CLK__NAND_WE_B 0xb0b1 + MX6QDL_PAD_NANDF_D0__NAND_DATA00 0xb0b1 + MX6QDL_PAD_NANDF_D1__NAND_DATA01 0xb0b1 + MX6QDL_PAD_NANDF_D2__NAND_DATA02 0xb0b1 + MX6QDL_PAD_NANDF_D3__NAND_DATA03 0xb0b1 + MX6QDL_PAD_NANDF_D4__NAND_DATA04 0xb0b1 + MX6QDL_PAD_NANDF_D5__NAND_DATA05 0xb0b1 + MX6QDL_PAD_NANDF_D6__NAND_DATA06 0xb0b1 + MX6QDL_PAD_NANDF_D7__NAND_DATA07 0xb0b1 + >; + }; + + pinctrl_hdmi_cec: hdmicecgrp { + fsl,pins = < + MX6QDL_PAD_EIM_A21__GPIO2_IO17 0x1b8b1 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL3__I2C2_SCL 0x4001b8b1 + MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX6QDL_PAD_GPIO_5__I2C3_SCL 0x4001f8b1 + MX6QDL_PAD_GPIO_6__I2C3_SDA 0x4001f8b1 + >; + }; + + pinctrl_i2c4: i2c4grp { + fsl,pins = < + MX6QDL_PAD_GPIO_7__I2C4_SCL 0x4001b8b1 + MX6QDL_PAD_GPIO_8__I2C4_SDA 0x4001b8b1 + >; + }; + + pinctrl_pwm3: pwm3grp { + fsl,pins = < + MX6QDL_PAD_SD4_DAT1__PWM3_OUT 0x1b0b1 + >; + }; + + pinctrl_reg_backlight: regbacklightgrp { + fsl,pins = < + MX6QDL_PAD_ENET_REF_CLK__GPIO1_IO23 0x1b0b1 + >; + }; + + pinctrl_reg_usbotg_vbus: regusbotgvbusgrp { + fsl,pins = < + MX6QDL_PAD_KEY_ROW4__GPIO4_IO15 0x1b0b1 + >; + }; + + pinctrl_touch: touchgrp { + fsl,pins = < + MX6QDL_PAD_GPIO_2__GPIO1_IO02 0x1b0b0 + MX6QDL_PAD_CSI0_PIXCLK__GPIO5_IO18 0x1b0b0 + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX6QDL_PAD_SD3_DAT7__UART1_TX_DATA 0x1b0b1 + MX6QDL_PAD_SD3_DAT6__UART1_RX_DATA 0x1b0b1 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX6QDL_PAD_SD4_DAT7__UART2_TX_DATA 0x1b0b1 + MX6QDL_PAD_SD4_DAT4__UART2_RX_DATA 0x1b0b1 + >; + }; + + pinctrl_uart3: uart3grp { + fsl,pins = < + MX6QDL_PAD_EIM_D24__UART3_TX_DATA 0x1b0b0 + MX6QDL_PAD_EIM_D25__UART3_RX_DATA 0x1b0b0 + >; + }; + + pinctrl_usbh1: usbh1grp { + fsl,pins = < + MX6QDL_PAD_GPIO_3__USB_H1_OC 0x1b0b1 + MX6QDL_PAD_CSI0_MCLK__CCM_CLKO1 0x1b0b0 + >; + }; + + pinctrl_usbotg: usbotggrp { + fsl,pins = < + MX6QDL_PAD_KEY_COL4__USB_OTG_OC 0x1b0b1 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX6QDL_PAD_SD3_CMD__SD3_CMD 0x17059 + MX6QDL_PAD_SD3_CLK__SD3_CLK 0x10059 + MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x17059 + MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x17059 + MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x17059 + MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x17059 + MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x100b1 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX6QDL_PAD_GPIO_9__WDOG1_B 0x1b0b0 + >; + }; +}; diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index 114cce4d9b9..15ee2b933f6 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -356,6 +356,15 @@ config TARGET_MX6Q_ACC select DM_THERMAL select SUPPORT_SPL
+config TARGET_MX6S_SIELAFF + bool "Sielaff i.MX6 Solo Board" + depends on MX6S + select BINMAN + select DM + select DM_THERMAL + select SUPPORT_SPL + imply CMD_DM + config TARGET_MX6SABREAUTO bool "mx6sabreauto" depends on MX6QDL @@ -708,6 +717,7 @@ source "board/softing/vining_2000/Kconfig" source "board/liebherr/display5/Kconfig" source "board/liebherr/mccmon6/Kconfig" source "board/logicpd/imx6/Kconfig" +source "board/sielaff/imx6dl-sielaff/Kconfig" source "board/solidrun/mx6cuboxi/Kconfig" source "board/somlabs/visionsom-6ull/Kconfig" source "board/technexion/pico-imx6/Kconfig" diff --git a/board/sielaff/imx6dl-sielaff/Kconfig b/board/sielaff/imx6dl-sielaff/Kconfig new file mode 100644 index 00000000000..1b74a7d90ee --- /dev/null +++ b/board/sielaff/imx6dl-sielaff/Kconfig @@ -0,0 +1,15 @@ +if TARGET_MX6S_SIELAFF + +config SYS_BOARD + string + default "imx6dl-sielaff" + +config SYS_VENDOR + string + default "sielaff" + +config SYS_CONFIG_NAME + string + default "imx6dl-sielaff" + +endif diff --git a/board/sielaff/imx6dl-sielaff/Makefile b/board/sielaff/imx6dl-sielaff/Makefile new file mode 100644 index 00000000000..65cecfe6f6c --- /dev/null +++ b/board/sielaff/imx6dl-sielaff/Makefile @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0+ +# (C) Copyright 2022 Kontron Electronics GmbH + +ifdef CONFIG_SPL_BUILD +obj-y := spl.o +else +obj-y := imx6dl-sielaff.o +endif diff --git a/board/sielaff/imx6dl-sielaff/imx6dl-sielaff.c b/board/sielaff/imx6dl-sielaff/imx6dl-sielaff.c new file mode 100644 index 00000000000..dec9948282f --- /dev/null +++ b/board/sielaff/imx6dl-sielaff/imx6dl-sielaff.c @@ -0,0 +1,111 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 Kontron Electronics GmbH + */ + +#include <compiler.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/clock.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/mx6-pins.h> +#include <asm/io.h> +#include <init.h> + +DECLARE_GLOBAL_DATA_PTR; + +iomux_v3_cfg_t nfc_pads[] = { + MX6_PAD_NANDF_CLE__NAND_CLE | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_ALE__NAND_ALE | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_WP_B__NAND_WP_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_RB0__NAND_READY_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS0__NAND_CE0_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS1__NAND_CE1_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS2__NAND_CE2_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS3__NAND_CE3_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_CMD__NAND_RE_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_CLK__NAND_WE_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D0__NAND_DATA00 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D1__NAND_DATA01 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D2__NAND_DATA02 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D3__NAND_DATA03 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D4__NAND_DATA04 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D5__NAND_DATA05 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D6__NAND_DATA06 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D7__NAND_DATA07 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_DAT0__NAND_DQS | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); + return 0; +} + +static void setup_gpmi_nand(void) +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + /* config gpmi nand iomux */ + imx_iomux_v3_setup_multiple_pads(nfc_pads, + ARRAY_SIZE(nfc_pads)); + + /* gate ENFC_CLK_ROOT clock first,before clk source switch */ + clrbits_le32(&mxc_ccm->CCGR2, MXC_CCM_CCGR2_IOMUX_IPT_CLK_IO_MASK); + + /* config gpmi and bch clock to 100 MHz */ + clrsetbits_le32(&mxc_ccm->cs2cdr, + MXC_CCM_CS2CDR_ENFC_CLK_PODF_MASK | + MXC_CCM_CS2CDR_ENFC_CLK_PRED_MASK | + MXC_CCM_CS2CDR_ENFC_CLK_SEL_MASK, + MXC_CCM_CS2CDR_ENFC_CLK_PODF(0) | + MXC_CCM_CS2CDR_ENFC_CLK_PRED(3) | + MXC_CCM_CS2CDR_ENFC_CLK_SEL(3)); + + /* enable ENFC_CLK_ROOT clock */ + setbits_le32(&mxc_ccm->CCGR2, MXC_CCM_CCGR2_IOMUX_IPT_CLK_IO_MASK); + + /* enable gpmi and bch clock gating */ + setbits_le32(&mxc_ccm->CCGR4, + MXC_CCM_CCGR4_RAWNAND_U_BCH_INPUT_APB_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_BCH_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_GPMI_IO_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_INPUT_APB_MASK | + MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET); + + /* enable apbh clock gating */ + setbits_le32(&mxc_ccm->CCGR0, MXC_CCM_CCGR0_APBHDMA_MASK); +} + +int board_init(void) +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + u32 reg; + + setup_gpmi_nand(); + + /* Enable SPI2 clock */ + enable_spi_clk(true, 1); + + /* + * Configure clock output for USB hub + * 1. Disabling CLK01 and CLK02 + */ + clrbits_le32(&mxc_ccm->ccosr, MXC_CCM_CCOSR_CKOL_EN); + clrbits_le32(&mxc_ccm->ccosr, MXC_CCM_CCOSR_CKO2_EN_OFFSET); + + /* + * 2. Setting ccm timer - osc_clk (24 MHz) divide by 2 -> 12 Mhz + * CLK02_DIV: 001b CLK02_SEL: 01110b -> 0010 1110b -> 0x2e + */ + reg = readl(&mxc_ccm->ccosr); + reg &= ~MXC_CCM_CCOSR_CKO2_SEL_MASK; + reg &= ~MXC_CCM_CCOSR_CKO2_DIV_MASK; + reg |= (0x2e << MXC_CCM_CCOSR_CKO2_SEL_OFFSET); + writel(reg, &mxc_ccm->ccosr); + + /* 3. Enabling CLK02 on output CCM_CLK01 */ + setbits_le32(&mxc_ccm->ccosr, MXC_CCM_CCOSR_CLK_OUT_SEL); + setbits_le32(&mxc_ccm->ccosr, MXC_CCM_CCOSR_CKO2_EN_OFFSET); + + return 0; +} diff --git a/board/sielaff/imx6dl-sielaff/imx6dl-sielaff.env b/board/sielaff/imx6dl-sielaff/imx6dl-sielaff.env new file mode 100644 index 00000000000..e0fab5477c9 --- /dev/null +++ b/board/sielaff/imx6dl-sielaff/imx6dl-sielaff.env @@ -0,0 +1,115 @@ +blkloadfdt=fatload ${device} ${devnum}:${partnum} ${fdt_addr} ${load_fdt_file} +blkloadimage=fatload ${device} ${devnum}:${partnum} ${loadaddr} ${load_image} +boot_devices=usb mmc ubi +bootargs_base=vt.global_cursor_default=0 consoleblank=0 cma=200M fbcon=rotate:1 +bootdelay=3 +bootdir= +console=ttymxc1,115200 +ethact=FEC0 +fdt_addr=0x18000000 +fdt_file_legacy=imx6dl_sielaff.dtb +fdt_file=imx6dl-sielaff.dtb +fdt_high=0xffffffff +hostname=mx6s-siline-hmi +image_legacy=zImage +image=fitImage +initrd_high=0xffffffff +ip_dyn=no +loadaddr=0x12000000 +mmcargs=setenv bootargs ${bootargs_base} console=${console} root=${mmcroot} +mmcroot=/dev/mmcblk2p2 rootwait rw +ramdisk_addr=0x18C00000 +script=boot.scr +touch_rst_gpio=2 +touch_irq_gpio=146 +ubiargs=setenv bootargs ${bootargs_base} console=${console} rootfstype=ubifs ubi.mtd=0 root=ubi0_0 rw +ubiloadfdt=ubifsload ${fdt_addr} /boot/${load_fdt_file} +ubiloadimage=ubifsload ${loadaddr} /boot/${load_image} +usb_pgood_delay=2000 +usbargs=setenv bootargs ${bootargs_base} console=${console} root=${usbroot} +usbroot=/dev/sda2 rootwait rw + +bootcmd= + for b in ${boot_devices}; do + if test ${b} = mmc; then + run mmcboot; + fi; + if test ${b} = net; then + run netboot; + fi; + if test ${b} = ubi; then + run ubiboot; + fi; + if test ${b} = usb; then + run usbboot; + fi; + done; + +boot= + load_image=${image}; + run loadimagecmd; + if test $? = 0; then + imxtract ${loadaddr} fdt-${fdt_file} ${fdt_addr}; + run detect_touch; + bootm ${loadaddr} - ${fdt_addr}; + else + load_image=${image_legacy}; + load_fdt_file=${fdt_file_legacy}; + run loadimagecmd; + run loadfdtcmd; + if test $? = 0; then + run detect_touch; + bootz ${loadaddr} - ${fdt_addr}; + fi; + fi; + +detect_touch= + gpio clear ${touch_irq_gpio}; + gpio clear ${touch_rst_gpio}; + sleep 0.02; + gpio set ${touch_rst_gpio}; + sleep 0.1; + gpio input ${touch_irq_gpio}; + i2c dev 2; + fdt addr ${fdt_addr}; + if i2c probe 0x55; then + echo 'Detected Sitronix Touch'; + fdt set /soc/bus@2100000/i2c@21a8000/touchscreen@55 status okay; + else + if i2c probe 0x5d; then + echo 'Detected Goodix Touch'; + fdt set /soc/bus@2100000/i2c@21a8000/touchscreen@5d status okay; + fi; + fi; + gpio clear ${touch_rst_gpio}; + +mmcboot= + echo Booting from MMC ...; + run mmcargs; + device=mmc; + devnum=2; + partnum=1; + setenv loadimagecmd ${blkloadimage}; + setenv loadfdtcmd ${blkloadfdt}; + run boot; + +ubiboot= + echo Booting from NAND (UBI); + run ubiargs; + ubi part rootfs; + ubifsmount ubi0; + setenv loadimagecmd ${ubiloadimage}; + setenv loadfdtcmd ${ubiloadfdt}; + load_image=${image}; + run boot; + +usbboot= + echo Booting from USB Storage ...; + run usbargs; + usb start; + device=usb; + devnum=0; + partnum=1; + setenv loadimagecmd ${blkloadimage}; + setenv loadfdtcmd ${blkloadfdt}; + run boot; diff --git a/board/sielaff/imx6dl-sielaff/spl.c b/board/sielaff/imx6dl-sielaff/spl.c new file mode 100644 index 00000000000..00fd817918a --- /dev/null +++ b/board/sielaff/imx6dl-sielaff/spl.c @@ -0,0 +1,277 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 Kontron Electronics GmbH + */ + +#include <asm/arch/clock.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/crm_regs.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/sections.h> +#include <init.h> +#include <spl.h> +#include <fsl_esdhc_imx.h> +#include <mmc.h> + +#define SPI_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + +#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define GPIO_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_DOWN | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +static const iomux_v3_cfg_t ecspi2_pads[] = { + MX6_PAD_CSI0_DAT10__ECSPI2_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_CSI0_DAT9__ECSPI2_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_CSI0_DAT8__ECSPI2_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_CSI0_DAT11__GPIO5_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static const iomux_v3_cfg_t uart2_pads[] = { + MX6_PAD_SD4_DAT7__UART2_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_SD4_DAT4__UART2_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static const iomux_v3_cfg_t usdhc3_pads[] = { + MX6_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + + /* CD */ + MX6_PAD_GPIO_4__GPIO1_IO04 | MUX_PAD_CTRL(GPIO_PAD_CTRL), +}; + +#define USDHC3_CD_GPIO IMX_GPIO_NR(1, 4) +#define SPI2_CS_GPIO IMX_GPIO_NR(5, 29) + +static struct fsl_esdhc_cfg usdhc_cfg[1] = { + {USDHC3_BASE_ADDR, 0, 4}, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC3_BASE_ADDR: + ret = !gpio_get_value(USDHC3_CD_GPIO); + break; + } + + return ret; +} + +int board_mmc_init(struct bd_info *bis) +{ + int i, ret; + + /* + * According to the board_mmc_init() the following map is done: + * (U-boot device node) (Physical Port) + * mmc0 USDHC1 + * mmc1 USDHC2 + */ + for (i = 0; i < CFG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + imx_iomux_v3_setup_multiple_pads(usdhc3_pads, + ARRAY_SIZE(usdhc3_pads)); + gpio_direction_input(USDHC3_CD_GPIO); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + break; + default: + printf("Warning: you configured more USDHC controllers \ + (%d) than supported by the board\n", i + 1); + return -EINVAL; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) { + printf("Warning: failed to initialize mmc dev %d\n", i); + return ret; + } + } + return 0; +} + +static void ccgr_init(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + writel(0x00C03F3F, &ccm->CCGR0); + writel(0x0030FC03, &ccm->CCGR1); + writel(0x0FFFC000, &ccm->CCGR2); + writel(0x3FF00000, &ccm->CCGR3); + writel(0x00FFF300, &ccm->CCGR4); + writel(0x0F0000C3, &ccm->CCGR5); + writel(0x000003FF, &ccm->CCGR6); +} + +static int mx6ssielaff_dcd_table[] = { + 0x020e0774, 0x000C0000, + 0x020e0754, 0x00000000, + 0x020e04ac, 0x00000030, + 0x020e04b0, 0x00000030, + 0x020e0464, 0x00000030, + 0x020e0490, 0x00000030, + 0x020e074c, 0x00000030, + 0x020e0494, 0x00000030, + 0x020e04a0, 0x00000000, + 0x020e04b4, 0x00000030, + 0x020e04b8, 0x00000030, + 0x020e076c, 0x00000030, + 0x020e0750, 0x00020000, + 0x020e04bc, 0x00000030, + 0x020e04c0, 0x00000030, + 0x020e04c4, 0x00000030, + 0x020e04c8, 0x00000030, + 0x020e0760, 0x00020000, + 0x020e0764, 0x00000030, + 0x020e0770, 0x00000030, + 0x020e0778, 0x00000030, + 0x020e077c, 0x00000030, + 0x020e0470, 0x00000030, + 0x020e0474, 0x00000030, + 0x020e0478, 0x00000030, + 0x020e047c, 0x00000030, + 0x021b001c, 0x00008000, + 0x021b0800, 0xA1390003, + 0x021b080c, 0x00350035, + 0x021b0810, 0x002A0032, + 0x021b083c, 0x02340234, + 0x021b0840, 0x02200220, + 0x021b0848, 0x4650504E, + 0x021b0850, 0x3A342E34, + 0x021b081c, 0x33333333, + 0x021b0820, 0x33333333, + 0x021b0824, 0x33333333, + 0x021b0828, 0x33333333, + 0x021b08b8, 0x00000800, + 0x021b0004, 0x0002002D, + 0x021b0008, 0x00333040, + 0x021b000c, 0x676B52F3, + 0x021b0010, 0xB66D8B63, + 0x021b0014, 0x01FF00DB, + 0x021b0018, 0x00011740, + 0x021b001c, 0x00008000, + 0x021b002c, 0x000026D2, + 0x021b0030, 0x006B1023, + 0x021b0040, 0x00000027, + 0x021b0000, 0x84190000, + 0x021b001c, 0x02008032, + 0x021b001c, 0x00008033, + 0x021b001c, 0x00048031, + 0x021b001c, 0x15208030, + 0x021b001c, 0x04008040, + 0x021b0020, 0x00007800, + 0x021b0818, 0x00022227, + 0x021b0004, 0x0002556D, + 0x021b0404, 0x00011006, + 0x021b001c, 0x00000000, + 0x020c4068, 0x00C03F3F, + 0x020c406c, 0x0030FC03, + 0x020c4070, 0x0FFFC000, + 0x020c4074, 0x3FF00000, + 0x020c4078, 0xFFFFF300, + 0x020c407c, 0x0F0000C3, + 0x020c4080, 0x000003FF, + 0x020e0010, 0xF00000CF, + 0x020e0018, 0x007F007F, + 0x020e001c, 0x007F007F, +}; + +static void ddr_init(int *table, int size) +{ + int i; + + for (i = 0; i < size / 2 ; i++) + writel(table[2 * i + 1], table[2 * i]); +} + +static void spl_dram_init(void) +{ + ddr_init(mx6ssielaff_dcd_table, ARRAY_SIZE(mx6ssielaff_dcd_table)); +} + +int board_spi_cs_gpio(unsigned int bus, unsigned int cs) +{ + return (bus == CONFIG_SF_DEFAULT_BUS && cs == CONFIG_SF_DEFAULT_CS) + ? SPI2_CS_GPIO : -1; +} + +static void setup_spi(void) +{ + imx_iomux_v3_setup_multiple_pads(ecspi2_pads, ARRAY_SIZE(ecspi2_pads)); + gpio_request(SPI2_CS_GPIO, "spi2_cs0"); + gpio_direction_output(SPI2_CS_GPIO, 1); + enable_spi_clk(true, 1); +} + +void board_init_f(ulong dummy) +{ + /* setup AIPS and disable watchdog */ + arch_cpu_init(); + + ccgr_init(); + gpr_init(); + + /* IOMUX UART */ + imx_iomux_v3_setup_multiple_pads(uart2_pads, ARRAY_SIZE(uart2_pads)); + + /* setup GP timer */ + timer_init(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + /* DDR initialization */ + spl_dram_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + /* SPI */ + setup_spi(); + + /* load/boot image from boot device */ + board_init_r(NULL, 0); +} + +void board_boot_order(u32 *spl_boot_list) +{ + u32 bootdev = spl_boot_device(); + + /* + * The default boot fuse settings use the SD card (MMC1) as primary + * boot device, but allow SPI NOR as a fallback boot device. + * We can't detect the fallback case and spl_boot_device() will return + * BOOT_DEVICE_MMC1 despite the actual boot device being SPI NOR. + * Therefore we try to load U-Boot proper vom SPI NOR after loading + * from MMC has failed. + */ + spl_boot_list[0] = bootdev; + + switch (bootdev) { + case BOOT_DEVICE_MMC1: + case BOOT_DEVICE_MMC2: + spl_boot_list[1] = BOOT_DEVICE_SPI; + break; + } +} + +void reset_cpu(void) +{ +} diff --git a/configs/imx6dl_sielaff_defconfig b/configs/imx6dl_sielaff_defconfig new file mode 100644 index 00000000000..c989e4d4af2 --- /dev/null +++ b/configs/imx6dl_sielaff_defconfig @@ -0,0 +1,117 @@ +CONFIG_ARM=y +CONFIG_SPL_SYS_ICACHE_OFF=y +CONFIG_SPL_SYS_DCACHE_OFF=y +CONFIG_ARCH_MX6=y +CONFIG_TEXT_BASE=0x17800000 +CONFIG_SYS_MALLOC_LEN=0x4000000 +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SOURCE_FILE="imx6dl-sielaff" +CONFIG_SF_DEFAULT_SPEED=20000000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0xF0000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_MX6S=y +CONFIG_TARGET_MX6S_SIELAFF=y +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx6dl-sielaff" +CONFIG_SPL_TEXT_BASE=0x00908000 +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y +CONFIG_FIT=y +CONFIG_SPL_FIT_PRINT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SUPPORT_RAW_INITRD=y +CONFIG_SPI_BOOT=y +CONFIG_SPL_RAW_IMAGE_SUPPORT=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8A +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x11400 +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_WRITE_SIZE=0x20000 +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nand0=nand0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=nand0:-@0x0(rootfs)" +CONFIG_CMD_UBI=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_EFI_PARTITION=y +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOUNCE_BUFFER=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x12000000 +CONFIG_FASTBOOT_BUF_SIZE=0x10000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=2 +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MXC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_USDHC=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_MXS=y +CONFIG_NAND_MXS_DT=y +CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_PHYLIB=y +CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y +CONFIG_DM_MDIO=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_CONS_INDEX=2 +CONFIG_DM_SERIAL=y +CONFIG_MXC_UART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_MXC_SPI=y +CONFIG_IMX_THERMAL=y +CONFIG_USB=y +CONFIG_SPL_USB_HOST=y +CONFIG_USB_STORAGE=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_GADGET=y +CONFIG_SPL_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_SPL_USB_SDP_SUPPORT=y diff --git a/include/configs/imx6dl-sielaff.h b/include/configs/imx6dl-sielaff.h new file mode 100644 index 00000000000..df074135079 --- /dev/null +++ b/include/configs/imx6dl-sielaff.h @@ -0,0 +1,25 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2022 Kontron Electronics GmbH + */ +#ifndef __MX6SSIELAFF_CONFIG_H +#define __MX6SSIELAFF_CONFIG_H + +#include <asm/arch/imx-regs.h> +#include <linux/sizes.h> +#include "mx6_common.h" + +#define CFG_MXC_UART_BASE UART2_BASE + +#define PHYS_SDRAM_SIZE SZ_512M +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR +#define CFG_SYS_SDRAM_BASE PHYS_SDRAM +#define CFG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CFG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CFG_SYS_FSL_ESDHC_ADDR USDHC3_BASE_ADDR +#define CFG_SYS_FSL_USDHC_NUM 1 + +#define CFG_SYS_NAND_BASE 0x40000000 + +#endif /* __MX6SSIELAFF_CONFIG_H */
Hi Frieder,
On Thu, Feb 8, 2024 at 1:59 PM Frieder Schrempf frieder@fris.de wrote:
binman: binman {
pad-byte = <0x00>;
spl: blob-ext@1 {
offset = <0x0>;
filename = "SPL";
uboot: blob-ext@2 {
offset = <0x11000>;
As mentioned in patch 3/3, please remove the binman entry and use u-boot-with-spl.imx instead.
depends on MX6S
select BINMAN
Please drop it.
Make it static.
Please remove it.
Is this needed?
Does the 'reset' command work on this board?
These options should be dropped.
As you use DM_SERIAL, this can be dropped.
Hi Fabio,
thanks for reviewing!
On 10.02.24 19:12, Fabio Estevam wrote:
Hi Frieder,
binman: binman {
pad-byte = <0x00>;
spl: blob-ext@1 {
offset = <0x0>;
filename = "SPL";
uboot: blob-ext@2 {
offset = <0x11000>;
I understand the reasoning and I can change that if you insist. But I'm not really happy about it as we already use the flash.bin as common name for the binary across all platforms downstream. Also in our upstream config for the i.MX6UL/ULL SoMs we already use this pattern (see [1]).
depends on MX6S
select BINMAN
Please drop it.
Make it static.
OK
Please remove it.
OK
Is this needed?
No, I will drop it.
No, I will fix it.
OK
This is still needed as SPL runs without DM due to internal RAM size constraints.
Thanks Frieder
[1] https://source.denx.de/u-boot/u-boot/-/blob/master/arch/arm/dts/imx6ul-kontr...
Hi Frieder,
On Tue, Feb 13, 2024 at 1:58 PM Frieder Schrempf frieder.schrempf@kontron.de wrote:
Ok, I just wanted to point out that there was an alternative, but if you prefer to go with the binman approach in your platforms, I am OK with that.
No, I will fix it.
Here is an example of how to fix it: https://gitlab.com/u-boot/u-boot/-/commit/dbc4814515d37a3d1c4bb237f4e1c16d1f...
Describe how to build and boot for the Sielaff i.MX6 Solo board.
Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de --- doc/board/sielaff/imx6dl-sielaff.rst | 32 ++++++++++++++++++++++++++++ doc/board/sielaff/index.rst | 9 ++++++++ 2 files changed, 41 insertions(+) create mode 100644 doc/board/sielaff/imx6dl-sielaff.rst create mode 100644 doc/board/sielaff/index.rst
diff --git a/doc/board/sielaff/imx6dl-sielaff.rst b/doc/board/sielaff/imx6dl-sielaff.rst new file mode 100644 index 00000000000..24dd67ccaef --- /dev/null +++ b/doc/board/sielaff/imx6dl-sielaff.rst @@ -0,0 +1,32 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Sielaff i.MX6 Solo Board +======================== + +The Sielaff i.MX6 Solo board is a control and HMI board for vending +machines. + +Quick Start +----------- + +- Build U-Boot +- Boot + +Build U-Boot +^^^^^^^^^^^^ + +.. code-block:: bash + + $ make imx6dl_sielaff_defconfig + $ make CROSS_COMPILE=arm-none-linux-gnueabihf- + +Burn the flash.bin to SD card at an offset of 1 KiB: + +.. code-block:: bash + + $ dd if=flash.bin of=/dev/sd[x] bs=1K seek=1 conv=notrunc + +Boot +^^^^ + +Put the SD card in the slot on the board and apply power. diff --git a/doc/board/sielaff/index.rst b/doc/board/sielaff/index.rst new file mode 100644 index 00000000000..a8376484d88 --- /dev/null +++ b/doc/board/sielaff/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Sielaff +======= + +.. toctree:: + :maxdepth: 2 + + imx6dl-sielaff
Hi Frieder,
- $ dd if=flash.bin of=/dev/sd[x] bs=1K seek=1 conv=notrunc
I see that you used binman to create the flash.bin file.
You could simply use the standard u-boot-with-spl.imx instead:
$ sha256sum flash.bin a0a4536876f2957ef88776036f13c6604a9f7e7fd78a236e8ea7322c2ae3e4cf flash.bin
$ sha256sum u-boot-with-spl.imx a0a4536876f2957ef88776036f13c6604a9f7e7fd78a236e8ea7322c2ae3e4cf u-boot-with-spl.imx
As you can see they have the same content.
I would suggest dropping the binman generation and just flash u-boot-with-spl.imx.
Reviewed-by: Fabio Estevam festevam@gmail.com
Fabio Estevam
Frieder Schrempf
Frieder Schrempf
