[U-Boot] Can't read kernel if bad blocks are present in partition
I'm working on a STM chip under linux and U-Boot 1.3.1.
Here's my problem. To boot linux up I load the kernel stored in a NAND device. If a bad block is present in the nand I can't load the kernel.
To store the kernel I first erase the partition and write the kernel image. During the erase stage, U-Boottells that a bad block has been skipped but everything's fine.
NAND erase: device 0 offset 0x520000, size 0x400000 Skipping bad block at 0x005c0000 Erasing at 0x900000 -- 100% complete. OK
When I write the kernel image, U-Boottells that everything's fine.
NAND write: device 0 offset 0x520000, size 0x400000 4194304 bytes written: OK
But when I try to read the kernel, it fails.
NAND read: device 0 offset 0x520000, size 0x1a4bff 1723391 bytes read: ERROR
I though U-Boot was able to handle bad block when reading back data..
Did I forget to initialize something ?
BEst regards.
Did you use "nand write.i" to write the kernel and "nand read.i" to read the kernel? the ".i" tells u-boot to skip bad blocks...
That has been the default for a while now. Why use something as ancient as 1.3.1?
-Scott
No I use "nand read $load_addr AppKernel" cause I didn't know we can use "nand read.i" - "help nand" doesn't display this information. I tried "nand read.i" and now it works fine but I still can't boot the kernel cause its crc is wrong I will flash the kernel again with "nand write.i" and check if it works.
Because my embedded linux distribution is STLinux which includes support for STM chips with this version of u-boot.
Alex.
Assuming you load the kernel to ram with tftp (and that "AppKernel" is an mtdparts partition in NAND), then you could do:
nand erase.part AppKernel tftp $load_addr uImage crc32 $load_addr $filesize nand write.i $load_addr AppKernel $filesize nand read.i $load_addr AppKernel $filesize crc32 $load_addr $filesize
To verify the CRCs match between what you load off tftp and what you read back from NAND.
There is no U-Boot version that both has "nand erase.part" and requires a .i suffix on nand read/write.
-Scott
Everything works fine now. I now use "nand write.i" and "nand read.i" instead of "nand write" and "nand.read".
Does STLinux have a support contact?
This list is for mainline U-Boot. Have you checked whether these chips are supported in current mainline U-Boot?
It was just a misunderstanding of u-boot commands.
Thank you guys for your help.
-Scott
Alexandre Gambier
Peter Barada
Scott Wood
