[U-Boot-Users] [PATCH 2/2] libfdt: Remove no longer used code from fdt_node_offset_by_compatible()
Since fdt_node_offset_by_compatible() was converted to the new fdt_next_node() iterator, a chunk of initialization code became redundant, but was not removed by oversight. This patch cleans it up.
Signed-off-by: David Gibson david@gibson.dropbear.id.au --- libfdt/fdt_ro.c | 12 +----------- 1 files changed, 1 insertions(+), 11 deletions(-)
diff --git a/libfdt/fdt_ro.c b/libfdt/fdt_ro.c index 15d5f6b..63fa129 100644 --- a/libfdt/fdt_ro.c +++ b/libfdt/fdt_ro.c @@ -453,20 +453,10 @@ int fdt_node_check_compatible(const void *fdt, int nodeoffset, int fdt_node_offset_by_compatible(const void *fdt, int startoffset, const char *compatible) { - uint32_t tag; - int offset, nextoffset; - int err; + int offset, err;
CHECK_HEADER(fdt);
- if (startoffset >= 0) { - tag = fdt_next_tag(fdt, startoffset, &nextoffset); - if (tag != FDT_BEGIN_NODE) - return -FDT_ERR_BADOFFSET; - } else { - nextoffset = 0; - } - /* FIXME: The algorithm here is pretty horrible: we scan each * property of a node in fdt_node_check_compatible(), then if * that didn't find what we want, we scan over them again
Jerry Van Baren
