[U-Boot] [PATCH v0 0/4] env: reworking + default/import individual vars
This is a resubmission (after removing remove checkpatch errors) of http://lists.denx.de/pipermail/u-boot/2011-September/102875.html
Here I am proposing a set of changes in the behaviour of the environment import/set_to_default functions.
PATCH 1: Add a "new" himport_ex() function (reworking of himport_r which is now a wrapper around it), which has 3 new arguments:
"nvars", "vars":, number and list of variables to take into account (0 means ALL)
"apply" callback function which is in charge of checking whether a variable can be overwritten, and possibly immediately apply the changes. This parameter would be either set to NULL (in which case nothing should change wrt to the past -- i.e. environment is blindly imported) or to "env_check_apply()" function, whose code was taken away from _do_env_set(). This would be useful, for instance, for "baudrate" or "stdin,stderr,stdout", whose changes would not otherwise be effective until the next reboot.
The idea is that there should be a single place where all the checks are to be performed. So the same function env_check_apply() is called from _do_env_set() as well (thus keeping the previous behavior).
PATCH 2: Add the same behaviour when deleting variables. Not quite sure whether this makes sense or not.
PATCH 3: Add the code for setting individual variables to default
PATCH 4: Impolement importing of individual variables (also taking into account "-f" for forcing).
Gerlando Falauto (4): Groundwork for generalization of env interface env: check and apply changes on delete/destroy env: implement selective "env default" env: implement "env import -n var[,var...]"
README | 2 + common/cmd_nvedit.c | 231 ++++++++++++++++++++++++++++++++-------------- common/env_common.c | 29 ++++++- include/config_cmd_all.h | 1 + include/environment.h | 12 +++ include/search.h | 19 ++++- lib/hashtable.c | 68 ++++++++++++- 7 files changed, 284 insertions(+), 78 deletions(-)
Signed-off-by: Gerlando Falauto gerlando.falauto@keymile.com --- common/cmd_nvedit.c | 152 +++++++++++++++++++++++++++++++------------------ common/env_common.c | 15 ++++- include/environment.h | 7 ++ include/search.h | 13 ++++ lib/hashtable.c | 50 ++++++++++++++++ 5 files changed, 179 insertions(+), 58 deletions(-)
diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index fa99c44..10b9552 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -194,32 +194,23 @@ static int do_env_grep (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[ #endif
/* - * Set a new environment variable, - * or replace or delete an existing one. + * Performs consistency checking before setting, replacing, + * or deleting an environment variable, then (if successful) + * apply the changes to internals so to make them effective. + * Code for this function was taken out of _do_env_set(), + * which now calls it. + * Also called as a callback function by himport_ex(). + * Returns 0 in case of success, 1 in case of failure. + * When (flag & H_FORCE) is set, force overwriting of + * write-once variables. */
-int _do_env_set (int flag, int argc, char * const argv[]) +int env_check_apply(const char *name, const char *oldval, + const char *newval, int flag) { bd_t *bd = gd->bd; - int i, len; + int i; int console = -1; - char *name, *value, *s; - ENTRY e, *ep; - - name = argv[1]; - - if (strchr(name, '=')) { - printf("## Error: illegal character '=' in variable name "%s"\n", name); - return 1; - } - - env_id++; - /* - * search if variable with this name already exists - */ - e.key = name; - e.data = NULL; - hsearch_r(e, FIND, &ep, &env_htab);
/* Check for console redirection */ if (strcmp(name, "stdin") == 0) @@ -230,22 +221,23 @@ int _do_env_set (int flag, int argc, char * const argv[]) console = stderr;
if (console != -1) { - if (argc < 3) { /* Cannot delete it! */ + if ((newval == NULL) || (*newval == '\0')) { + /* We cannot delete stdin/stdout/stderr */ printf("Can't delete "%s"\n", name); return 1; }
#ifdef CONFIG_CONSOLE_MUX - i = iomux_doenv(console, argv[2]); + i = iomux_doenv(console, newval); if (i) return i; #else /* Try assigning specified device */ - if (console_assign(console, argv[2]) < 0) + if (console_assign(console, newval) < 0) return 1;
#ifdef CONFIG_SERIAL_MULTI - if (serial_assign(argv[2]) < 0) + if (serial_assign(newval) < 0) return 1; #endif #endif /* CONFIG_CONSOLE_MUX */ @@ -255,23 +247,29 @@ int _do_env_set (int flag, int argc, char * const argv[]) * Some variables like "ethaddr" and "serial#" can be set only * once and cannot be deleted; also, "ver" is readonly. */ - if (ep) { /* variable exists */ + if ((oldval != NULL) /* variable exists */ + && ((flag & H_FORCE) == 0)) { /* and we are not forced */ #ifndef CONFIG_ENV_OVERWRITE if ((strcmp(name, "serial#") == 0) || ((strcmp(name, "ethaddr") == 0) #if defined(CONFIG_OVERWRITE_ETHADDR_ONCE) && defined(CONFIG_ETHADDR) - && (strcmp(ep->data, MK_STR(CONFIG_ETHADDR)) != 0) + && (strcmp(oldval, MK_STR(CONFIG_ETHADDR)) != 0) #endif /* CONFIG_OVERWRITE_ETHADDR_ONCE && CONFIG_ETHADDR */ ) ) { printf("Can't overwrite "%s"\n", name); return 1; } #endif + } + /* if variable exists... */ + if ((oldval != NULL) + /* or we are in a scratched-out environment */ + || ((flag & H_NOCLEAR) == 0)) { /* * Switch to new baudrate if new baudrate is supported */ if (strcmp(name, "baudrate") == 0) { - int baudrate = simple_strtoul(argv[2], NULL, 10); + int baudrate = simple_strtoul(newval, NULL, 10); int i; for (i = 0; i < N_BAUDRATES; ++i) { if (baudrate == baudrate_table[i]) @@ -282,6 +280,10 @@ int _do_env_set (int flag, int argc, char * const argv[]) baudrate); return 1; } + if (gd->baudrate == baudrate) { + /* If unchanged, we just say it's OK */ + return 0; + } printf ("## Switch baudrate to %d bps and press ENTER ...\n", baudrate); udelay(50000); @@ -299,6 +301,72 @@ int _do_env_set (int flag, int argc, char * const argv[]) } }
+ /* + * Some variables should be updated when the corresponding + * entry in the environment is changed + */ + + if (strcmp(name, "ipaddr") == 0) { + const char *s = newval; /* always use only one arg */ + char *e; + unsigned long addr; + bd->bi_ip_addr = 0; + for (addr = 0, i = 0; i < 4; ++i) { + ulong val = s ? simple_strtoul(s, &e, 10) : 0; + addr <<= 8; + addr |= (val & 0xFF); + if (s) + s = (*e) ? e+1 : e; + } + bd->bi_ip_addr = htonl(addr); + return 0; + } else if (strcmp(newval, "loadaddr") == 0) { + load_addr = simple_strtoul(newval, NULL, 16); + return 0; + } +#if defined(CONFIG_CMD_NET) + else if (strcmp(newval, "bootfile") == 0) { + copy_filename(BootFile, newval, sizeof(BootFile)); + return 0; + } +#endif + return 0; +} + +/* + * Set a new environment variable, + * or replace or delete an existing one. +*/ +int _do_env_set(int flag, int argc, char * const argv[]) +{ + int i, len; + char *name, *value, *s; + ENTRY e, *ep; + + name = argv[1]; + value = argv[2]; + + if (strchr(name, '=')) { + printf("## Error: illegal character '='" + "in variable name "%s"\n", name); + return 1; + } + + env_id++; + /* + * search if variable with this name already exists + */ + e.key = name; + e.data = NULL; + hsearch_r(e, FIND, &ep, &env_htab); + + /* Perform requested checks. Notice how since we are overwriting + * a single variable, we need to set H_NOCLEAR */ + if (env_check_apply(name, ep ? ep->data : NULL, value, H_NOCLEAR)) { + debug("check function did not approve, refusing\n"); + return 1; + } + /* Delete only ? */ if ((argc < 3) || argv[2] == NULL) { int rc = hdelete_r(name, &env_htab); @@ -336,34 +404,6 @@ int _do_env_set (int flag, int argc, char * const argv[]) return 1; }
- /* - * Some variables should be updated when the corresponding - * entry in the environment is changed - */ - - if (strcmp(name, "ipaddr") == 0) { - char *s = argv[2]; /* always use only one arg */ - char *e; - unsigned long addr; - bd->bi_ip_addr = 0; - for (addr = 0, i = 0; i < 4; ++i) { - ulong val = s ? simple_strtoul(s, &e, 10) : 0; - addr <<= 8; - addr |= (val & 0xFF); - if (s) s = (*e) ? e+1 : e; - } - bd->bi_ip_addr = htonl(addr); - return 0; - } else if (strcmp(argv[1], "loadaddr") == 0) { - load_addr = simple_strtoul(argv[2], NULL, 16); - return 0; - } -#if defined(CONFIG_CMD_NET) - else if (strcmp(argv[1], "bootfile") == 0) { - copy_filename(BootFile, argv[2], sizeof(BootFile)); - return 0; - } -#endif return 0; }
diff --git a/common/env_common.c b/common/env_common.c index c7e9bea..db607e1 100644 --- a/common/env_common.c +++ b/common/env_common.c @@ -172,6 +172,9 @@ const uchar *env_get_addr (int index)
void set_default_env(const char *s) { + /* By default, do not apply changes as they will eventually + * be applied by someone else */ + apply_cb apply_function = NULL; if (sizeof(default_environment) > ENV_SIZE) { puts("*** Error - default environment is too large\n\n"); return; @@ -183,14 +186,22 @@ void set_default_env(const char *s) "using default environment\n\n", s+1); } else { + /* This set_to_default was explicitly asked for + * by the user, as opposed to being a recovery + * mechanism. Therefore we chack every single + * variable and apply changes to the system + * right away (e.g. baudrate, console). + */ + apply_function = env_check_apply; puts(s); } } else { puts("Using default environment\n\n"); }
- if (himport_r(&env_htab, (char *)default_environment, - sizeof(default_environment), '\0', 0) == 0) { + if (himport_ex(&env_htab, (char *)default_environment, + sizeof(default_environment), '\0', 0, + 0, NULL, apply_function) == 0) { error("Environment import failed: errno = %d\n", errno); } gd->flags |= GD_FLG_ENV_READY; diff --git a/include/environment.h b/include/environment.h index 6394a96..cd98f91 100644 --- a/include/environment.h +++ b/include/environment.h @@ -174,6 +174,13 @@ void set_default_env(const char *s); /* Import from binary representation into hash table */ int env_import(const char *buf, int check);
+/* + * Check if variable "name" can be changed from oldval to newval, + * and if so, apply the changes (e.g. baudrate) + */ +int env_check_apply(const char *name, const char *oldval, + const char *newval, int flag); + #endif
#endif /* _ENVIRONMENT_H_ */ diff --git a/include/search.h b/include/search.h index b4edd43..4ac7171 100644 --- a/include/search.h +++ b/include/search.h @@ -46,6 +46,11 @@ typedef struct entry { /* Opaque type for internal use. */ struct _ENTRY;
+/* Callback function to be called for checking whether the given change may + * be applied or not. Must return 0 for approval, 1 for denial. */ +typedef int (*apply_cb)(const char *name, const char *oldval, + const char *newval, int flag); + /* * Family of hash table handling functions. The functions also * have reentrant counterparts ending with _r. The non-reentrant @@ -97,7 +102,15 @@ extern int himport_r(struct hsearch_data *__htab, const char *__env, size_t __size, const char __sep, int __flag);
+extern int himport_ex(struct hsearch_data *__htab, + const char *__env, size_t __size, const char __sep, + int __flag, + int __argc, char * const __argv[], + apply_cb apply); + + /* Flags for himport_r() */ #define H_NOCLEAR 1 /* do not clear hash table before importing */ +#define H_FORCE 2 /* overwrite read-only/write-once variables */
#endif /* search.h */ diff --git a/lib/hashtable.c b/lib/hashtable.c index 6895550..a2c268f 100644 --- a/lib/hashtable.c +++ b/lib/hashtable.c @@ -630,6 +630,33 @@ ssize_t hexport_r(struct hsearch_data *htab, const char sep, int himport_r(struct hsearch_data *htab, const char *env, size_t size, const char sep, int flag) { + return himport_ex(htab, env, size, sep, flag, 0, NULL, NULL); +} + +/* Check whether variable name is amongst vars[] */ +static int process_var(const char *name, int nvars, char * const vars[]) +{ + int i = 0; + /* No variables specified means process all of them*/ + if (nvars == 0) + return 1; + + for (i = 0; i < nvars; i++) { + if (!strcmp(name, vars[i])) + return 1; + } + debug("Skipping non-listed variable %s\n", name); + return 0; +} + + + +int himport_ex(struct hsearch_data *htab, + const char *env, size_t size, const char sep, int flag, + int nvars, char * const vars[], + int(*apply)(const char *, const char *, const char *, int) + ) +{ char *data, *sp, *dp, *name, *value;
/* Test for correct arguments. */ @@ -715,6 +742,8 @@ int himport_r(struct hsearch_data *htab, *dp++ = '\0'; /* terminate name */
debug("DELETE CANDIDATE: "%s"\n", name); + if (!process_var(name, nvars, vars)) + continue;
if (hdelete_r(name, htab) == 0) debug("DELETE ERROR ##############################\n"); @@ -732,10 +761,31 @@ int himport_r(struct hsearch_data *htab, *sp++ = '\0'; /* terminate value */ ++dp;
+ /* Skip variables which are not supposed to be treated */ + if (!process_var(name, nvars, vars)) + continue; + /* enter into hash table */ e.key = name; e.data = value;
+ /* if there is an apply function, check what it has to say */ + if (apply != NULL) { + debug("searching before calling cb function" + " for %s\n", name); + /* + * Search for variable in existing env, so to pass + * its previous value to the apply callback + */ + hsearch_r(e, FIND, &rv, htab); + debug("previous value was %s\n", rv ? rv->data : ""); + if (apply(name, rv ? rv->data : NULL, value, flag)) { + debug("callback function refused to set" + " variable %s, skipping it!\n", name); + continue; + } + } + hsearch_r(e, ENTER, &rv, htab); if (rv == NULL) { printf("himport_r: can't insert "%s=%s" into hash table\n",
Dear Gerlando Falauto,
In message 1319647072-17504-2-git-send-email-gerlando.falauto@keymile.com you wrote:
Please use only TAB for indentation. Please fix globally.
- if ((oldval != NULL) /* variable exists */
Incorrect indentation.
- Set a new environment variable,
- or replace or delete an existing one.
Incorrect multiline comment style.
- /* Perform requested checks. Notice how since we are overwriting
- /* By default, do not apply changes as they will eventually
Please fix globally!
- if (himport_ex(&env_htab, (char *)default_environment,
Incorrect / inconsistent indentation. Please fix globally.
On 11/05/2011 05:09 PM, Wolfgang Denk wrote:
[NOTE: I removed the quoting from the hunks as it would not make any sense]
From fs/ubibfs/ubifs.h:
int ubifs_decompress(const void *buf, int len, void *out, int *out_len, int compr_type);
Here there are 2 tabs + 5 spaces to align arguments from the first line with those on the second line. I did the same (except that in a patch hunk the plus sign before the first tab shifts it to the right).
Could you please provide some examples as to what would be the correct coding style for function declarations and/or function calls that spawn on multiple lines? I could not find anything on the topic.
As for:
Ditto. Here I was trying to align parentheses. Could you please provide an example? In my opinion, using only tabs would definitely make the two lines not aligned and make the code much harder to read.
As for:
What should be the right indentation?
Perhaps for function calls you would want something like:
As soon as I have these questions answered, I will apply all the other changes you requested, and submit a new patchset. I would very much appreciate some feedback about the idea though.
Thank you, Gerlando Falauto
Never ever use examples from other code to argument your's was right - the example you chose might be wrong as well.
http://www.denx.de/wiki/U-Boot/CodingStyle:
Use TAB characters for indentation and vertical alignment, not spaces
In any case it makse no sense to have the 2nd and 3rd line indented differently, right?
It is impossible to align this nicely with tabs alone. Such alignment is not just an isolated example, but quite common in both the Linux kernel and U-Boot.
Grep for a tab followed by a space...
They generally shouldn't be different from each other, but that doesn't answer the question of what it should look like.
Documentation/CodingStyle calls for something like this:
if (himport_ex(&env_htab, (char *)default_environment, sizeof(default_environment), '\0', 0, 0, NULL, apply_function) == 0) {
...but judging by how common it is, many people find this nicer:
I vote for allowing it, if anyone's counting.
-Scott
Thank you! :-)
I would have thought this would make more sense (offset by 1, not 9):
Or maybe even:
which would save a lot of screen real estate. Now we can also argue that the argument list is really too big...
Actually I don't have that much of a preference in this case, it's just a matter of aesthetics, and I think it doesn't affect readabilty that much. As long as we agree on what is OK and what is not (or, rather, what is the preferred way).
What bothers me more is, for instance, the condition under which my smartphone will work correctly:
if (((day_of_week() % 2 == 0) && (temperature() < 14.4 || temperature() > 15.3)) || ((sky_color() == E_BLUE) && (sim_credit() % 100 != 27)) || (uptime() < 3600) ) { work = 1; } else if ( ((received_calls() > 1) && (zenith_angle() == 0)) || (call_is_important()) ) { work = 0; } else { udelay(rand()); work = ((rand() % 2) == 1); }
Any ideas how to align that? Please don't answer: get a real phone. :-)
Thanks! Gerlando Falauto
Documentation/CodingStyle simply says continuation lines "are always substantially shorter than the parent and are placed substantially to the right".
Or maybe even:
It would also make it harder to distinguish the continuation lines from the if-body:
if (himport_ex(... sizeof(... 0, 0, ...) { body goes here, at the same column have to look for the brace to distinguish }
-Scott
I like aligning based on which level of nested parens the line break is in (and removing unnecessary parens when precedence is obvious, to make it easier to track the relevant ones):
if ((day_of_week() % 2 == 0 && (temperature() < 14.4 || temperature() > 15.3)) || (sky_color() == E_BLUE && sim_credit() % 100 != 27) || uptime() < 3600) { work = 1; } else if ((received_calls() > 1 && zenith_angle() == 0) || call_is_important()) { work = 0; } else { udelay(rand()); work = ((rand() % 2) == 1); }
-Scott
if ((day_of_week() % 2 == 0&& (temperature()< 14.4 || temperature()> 15.3)) || (sky_color() == E_BLUE&& sim_credit() % 100 != 27) || uptime()< 3600) { work = 1; } else if ((received_calls()> 1&& zenith_angle() == 0) || call_is_important()) { work = 0; } else { udelay(rand()); work = ((rand() % 2) == 1); }
I like that too.
Anyway... Are there are any guidelines for indenting comments on the right side of the code? Like:
if ((day_of_week() % 2 == 0 && /* even days are OK */ (temperature() < 14.4 || temperature() > 15.3)) || /* * but only outside of a * certain temp. range */ (sky_color() == E_BLUE && sim_credit() % 100 != 27) || /* * or, it's a nice a day * but balance does not * have 27 cents as * decimal part */ uptime() < 3600) { /* work 4 the 1st hr! */ work = 1; } else if ((received_calls() > 1 && zenith_angle() == 0) || call_is_important()) { work = 0; } else { udelay(rand()); work = ((rand() % 2) == 1); }
... becuase git-gui will interpret all tabs which are on the right of some non-whitespace text in a very weird way. Is using tabs on the right of text forbidden/not recommended for some reason?
The purpose was not to argument mine was right.
That's exactly what you told me in your reply, and doesn't answer my question. The only way I could think of to achieve vertical alignment in a complex if statement without recurring to spaces is by adding extra tabs between parentheses, with an enormous waste of space. Your answer might as well be: "forget about alignment altogether, nobody wants that, just indent it somehow".
That's absolutely right. Once again, though, you did not help me understand what The Right Thing (tm) is. I also made a shy attempt, but you're not telling me whether it's good or not. It's hard to follow some guidelines when they're not clearly stated.
Sory, but I don;t know how else to put it.
In the first step you should try and avoid complex if statements.
Well, my suggestion is to align by TABs:
if (himport_ex(&env_htab, (char *)default_environment, sizeof(default_environment), '\0', 0, 0, NULL, apply_function) == 0) { ... }
Yes, the 's' and the '0' don't start exactly below the '&'. But who says they should? We also don't align the closing ')' below the opeing '(' ...
And does above code look difficult to read?
This patch introduces new build warnings:
cmd_nvedit.c: In function 'env_check_apply': cmd_nvedit.c:242:3: warning: passing argument 1 of 'serial_assign' discards 'const' qualifier from pointer target type [enabled by default] /home/wd/git/u-boot/env-substitute/include/serial.h:95:12: note: expected 'char *' but argument is of type 'const char *'
Please fix.
Signed-off-by: Gerlando Falauto gerlando.falauto@keymile.com --- common/cmd_nvedit.c | 2 +- include/search.h | 6 ++++-- lib/hashtable.c | 18 ++++++++++++------ 3 files changed, 17 insertions(+), 9 deletions(-)
diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 10b9552..905d3be 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -369,7 +369,7 @@ int _do_env_set(int flag, int argc, char * const argv[])
/* Delete only ? */ if ((argc < 3) || argv[2] == NULL) { - int rc = hdelete_r(name, &env_htab); + int rc = hdelete_r(name, &env_htab, NULL); return !rc; }
diff --git a/include/search.h b/include/search.h index 4ac7171..cc620bd 100644 --- a/include/search.h +++ b/include/search.h @@ -68,7 +68,8 @@ struct hsearch_data { extern int hcreate_r(size_t __nel, struct hsearch_data *__htab);
/* Destroy current internal hashing table. */ -extern void hdestroy_r(struct hsearch_data *__htab); +extern void hdestroy_r(struct hsearch_data *__htab, + apply_cb apply);
/* * Search for entry matching ITEM.key in internal hash table. If @@ -93,7 +94,8 @@ extern int hstrstr_r(const char *__match, int __last_idx, ENTRY ** __retval, struct hsearch_data *__htab);
/* Search and delete entry matching ITEM.key in internal hash table. */ -extern int hdelete_r(const char *__key, struct hsearch_data *__htab); +extern int hdelete_r(const char *__key, struct hsearch_data *__htab, + apply_cb apply);
extern ssize_t hexport_r(struct hsearch_data *__htab, const char __sep, char **__resp, size_t __size); diff --git a/lib/hashtable.c b/lib/hashtable.c index a2c268f..d84882f 100644 --- a/lib/hashtable.c +++ b/lib/hashtable.c @@ -142,7 +142,8 @@ int hcreate_r(size_t nel, struct hsearch_data *htab) * be freed and the local static variable can be marked as not used. */
-void hdestroy_r(struct hsearch_data *htab) +void hdestroy_r(struct hsearch_data *htab, + int(*apply)(const char *, const char *, const char *, int)) { int i;
@@ -156,7 +157,10 @@ void hdestroy_r(struct hsearch_data *htab) for (i = 1; i <= htab->size; ++i) { if (htab->table[i].used > 0) { ENTRY *ep = &htab->table[i].entry; - + if (apply != NULL) { + /* deletion is always forced */ + apply(ep->key, ep->data, NULL, H_FORCE); + } free((void *)ep->key); free(ep->data); } @@ -401,7 +405,8 @@ int hsearch_r(ENTRY item, ACTION action, ENTRY ** retval, * do that. */
-int hdelete_r(const char *key, struct hsearch_data *htab) +int hdelete_r(const char *key, struct hsearch_data *htab, + int(*apply)(const char *, const char *, const char *, int)) { ENTRY e, *ep; int idx; @@ -417,7 +422,8 @@ int hdelete_r(const char *key, struct hsearch_data *htab)
/* free used ENTRY */ debug("hdelete: DELETING key "%s"\n", key); - + if (apply != NULL) + apply(ep->key, ep->data, NULL, H_FORCE); free((void *)ep->key); free(ep->data); htab->table[idx].used = -1; @@ -679,7 +685,7 @@ int himport_ex(struct hsearch_data *htab, debug("Destroy Hash Table: %p table = %p\n", htab, htab->table); if (htab->table) - hdestroy_r(htab); + hdestroy_r(htab, apply); }
/* @@ -745,7 +751,7 @@ int himport_ex(struct hsearch_data *htab, if (!process_var(name, nvars, vars)) continue;
- if (hdelete_r(name, htab) == 0) + if (hdelete_r(name, htab, apply) == 0) debug("DELETE ERROR ##############################\n");
continue;
In message 1319647072-17504-3-git-send-email-gerlando.falauto@keymile.com you wrote:
Are you sure these changes are really independent from the previous and following ones? Ordo we introduc bisectability issues here?
apply_cb apply);
See provious comments - indentation always by TAB. Please fix globally, i. e. in all your patches.
Um.... why is this the case?
Signed-off-by: Gerlando Falauto gerlando.falauto@keymile.com --- README | 2 ++ common/cmd_nvedit.c | 42 ++++++++++++++++++++++++++++++++++++------ common/env_common.c | 14 ++++++++++++++ include/config_cmd_all.h | 1 + include/environment.h | 5 +++++ 5 files changed, 58 insertions(+), 6 deletions(-)
diff --git a/README b/README index c6b179c..b5b316f 100644 --- a/README +++ b/README @@ -724,6 +724,8 @@ The following options need to be configured: CONFIG_CMD_CONSOLE coninfo CONFIG_CMD_CRC32 * crc32 CONFIG_CMD_DATE * support for RTC, date/time... + CONFIG_CMD_DEFAULTENV_VARS + * Reset individual variables to default CONFIG_CMD_DHCP * DHCP support CONFIG_CMD_DIAG * Diagnostics CONFIG_CMD_DS4510 * ds4510 I2C gpio commands diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 905d3be..07cd062 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -638,13 +638,40 @@ int envmatch(uchar *s1, int i2) return -1; }
-static int do_env_default(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +static int do_env_default(cmd_tbl_t *cmdtp, int __flag, int argc, + char * const argv[]) { - if ((argc != 2) || (strcmp(argv[1], "-f") != 0)) - return cmd_usage(cmdtp); - - set_default_env("## Resetting to default environment\n"); - return 0; + int all = 0, flag = 0; + debug("Initial value for argc=%d\n", argc); + while (--argc > 0 && **++argv == '-') { + char *arg = *argv; + while (*++arg) { + switch (*arg) { + case 'a': /* default all */ + all = 1; + break; + case 'f': /* force */ + flag |= H_FORCE; + break; + default: + return cmd_usage(cmdtp); + } + } + } + debug("Final value for argc=%d\n", argc); + if (all && (argc == 0)) { + /* Reset the whole environment */ + set_default_env("## Resetting to default environment\n"); + return 0; + } +#if CONFIG_CMD_DEFAULTENV_VARS + if (!all && (argc > 0)) { + /* Reset individual variables */ + env_default_vars(argc, argv); + return 0; + } +#endif + return cmd_usage(cmdtp); }
static int do_env_delete(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) @@ -970,6 +997,9 @@ U_BOOT_CMD( "ask name [message] [size] - ask for environment variable\nenv " #endif "default -f - reset default environment\n" +#if defined(CONFIG_CMD_DEFAULTENV_VARS) + "env default var [...] - reset variable(s) to their default value\n" +#endif #if defined(CONFIG_CMD_EDITENV) "env edit name - edit environment variable\n" #endif diff --git a/common/env_common.c b/common/env_common.c index db607e1..af28d47 100644 --- a/common/env_common.c +++ b/common/env_common.c @@ -207,6 +207,20 @@ void set_default_env(const char *s) gd->flags |= GD_FLG_ENV_READY; }
+#ifdef CONFIG_CMD_DEFAULTENV_VARS + +/* [re]set individual variables to their value in the default environment */ +int env_default_vars(int nvars, char * const vars[]) +{ + /* Special use-case: import from default environment + (and use \0 as a separator) */ + return himport_ex(&env_htab, (const char *)default_environment, + sizeof(default_environment), '\0', H_NOCLEAR, + nvars, vars, env_check_apply); +} + +#endif /* CONFIG_CMD_DEFAULTENV_VARS */ + /* * Check if CRC is valid and (if yes) import the environment. * Note that "buf" may or may not be aligned. diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index 9716f9c..e728eae 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -25,6 +25,7 @@ #define CONFIG_CMD_CDP /* Cisco Discovery Protocol */ #define CONFIG_CMD_CONSOLE /* coninfo */ #define CONFIG_CMD_DATE /* support for RTC, date/time...*/ +#define CONFIG_CMD_DEFAULTENV_VARS /* default individ variables */ #define CONFIG_CMD_DHCP /* DHCP Support */ #define CONFIG_CMD_DIAG /* Diagnostics */ #define CONFIG_CMD_DISPLAY /* Display support */ diff --git a/include/environment.h b/include/environment.h index cd98f91..b9201d3 100644 --- a/include/environment.h +++ b/include/environment.h @@ -171,6 +171,11 @@ void env_crc_update (void); /* [re]set to the default environment */ void set_default_env(const char *s);
+#ifdef CONFIG_CMD_DEFAULTENV_VARS +/* [re]set individual variables to their value in the default environment */ +int env_default_vars(int nvars, char * const vars[]); +#endif + /* Import from binary representation into hash table */ int env_import(const char *buf, int check);
In message 1319647072-17504-4-git-send-email-gerlando.falauto@keymile.com you wrote:
Did you actually ever try to compile your code, and test it?
When I try and enable your code by adding
to a board config file, this will result in a an error:
cmd_nvedit.c:699:31: error: #if with no expression
Implemented selective importing of variables in env import
Signed-off-by: Gerlando Falauto gerlando.falauto@keymile.com --- common/cmd_nvedit.c | 35 ++++++++++++++++++++++++++++++----- 1 files changed, 30 insertions(+), 5 deletions(-)
diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 07cd062..0984a53 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -831,15 +831,19 @@ sep_err: * size: length of input data; if missing, proper '\0' * termination is mandatory */ -static int do_env_import(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +#define MAX_NVARS 16 +static int do_env_import(cmd_tbl_t *cmdtp, int __flag, int argc, + char * const argv[]) { char *cmd, *addr; char sep = '\n'; int chk = 0; int fmt = 0; - int del = 0; + int flag = H_NOCLEAR; size_t size; - + char *vars[MAX_NVARS]; + int nvars = 0; + char *s; cmd = *argv;
while (--argc > 0 && **++argv == '-') { @@ -863,7 +867,27 @@ static int do_env_import(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv sep = '\n'; break; case 'd': - del = 1; + flag &= ~H_NOCLEAR; + break; + case 'f': + flag |= H_FORCE; + break; + case 'n': + s = *++argv; + argc--; + do { + if (nvars >= MAX_NVARS) { + printf("Cannot import more " + "than %d variables at a" + " time!", MAX_NVARS); + return 1; + } + vars[nvars++] = strsep(&s, ","); + debug("Considering variable %s\n", + vars[nvars-1]); + } while (s); + debug("Importing a total of %d variables\n", + nvars); break; default: return cmd_usage(cmdtp); @@ -914,7 +938,8 @@ static int do_env_import(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv addr = (char *)ep->data; }
- if (himport_r(&env_htab, addr, size, sep, del ? 0 : H_NOCLEAR) == 0) { + if (himport_ex(&env_htab, addr, size, sep, flag, + nvars, vars, NULL) == 0) { error("Environment import failed: errno = %d\n", errno); return 1; }
The "env ask" traditionally uses a somewhat awkward syntax:
env ask name [message ...] [size]
So far, when a mesage was given, you always also had to enter a size. If you forgot to do that, the command would terminate without any indication of the problem.
To avoid incompatible changes of the interface, we now check the last argument if it can be converted into a decimal number. If this is the case, we assume it is a size; otherwise we treat it as part of the message.
Also, add a space after the message fore easier reading.
Signed-off-by: Wolfgang Denk wd@denx.de --- Note: this patch was generated on top of Gerlando Falauto's "generalization of env interface" patch series. THis should be applied before.
common/cmd_nvedit.c | 46 ++++++++++++++++++++++++++++------------------ 1 files changed, 28 insertions(+), 18 deletions(-)
diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 5507922..2dd4eba 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -465,40 +465,50 @@ int do_env_ask(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { extern char console_buffer[CONFIG_SYS_CBSIZE]; char message[CONFIG_SYS_CBSIZE]; - int size = CONFIG_SYS_CBSIZE - 1; - int i, len, pos; + int i, len, pos, size; char *local_args[4]; + char *endptr;
local_args[0] = argv[0]; local_args[1] = argv[1]; local_args[2] = NULL; local_args[3] = NULL;
- /* Check the syntax */ - switch (argc) { - case 1: + /* + * Check the syntax: + * + * env_ask envname [message1 ...] [size] + */ + if (argc == 1) return cmd_usage(cmdtp);
- case 2: /* env_ask envname */ - sprintf(message, "Please enter '%s':", argv[1]); - break; - - case 3: /* env_ask envname size */ - sprintf(message, "Please enter '%s':", argv[1]); - size = simple_strtoul(argv[2], NULL, 10); - break; - - default: /* env_ask envname message1 ... messagen size */ - for (i = 2, pos = 0; i < argc - 1; i++) { + /* + * We test the last argument if it can be converted + * into a decimal number. If yes, we assume it's + * the size. Otherwise we echo it as part of the + * message. + */ + i = simple_strtoul(argv[argc - 1], &endptr, 10); + if (*endptr != '\0') { /* no size */ + size = CONFIG_SYS_CBSIZE - 1; + } else { /* size given */ + size = i; + --argc; + } + + if (argc <= 2) { + sprintf(message, "Please enter '%s': ", argv[1]); + } else { + /* env_ask envname message1 ... messagen [size] */ + for (i = 2, pos = 0; i < argc; i++) { if (pos) message[pos++] = ' ';
strcpy(message+pos, argv[i]); pos += strlen(argv[i]); } + message[pos++] = ' '; message[pos] = '\0'; - size = simple_strtoul(argv[argc - 1], NULL, 10); - break; }
if (size >= CONFIG_SYS_CBSIZE)
Downloaded from http://slre.sourceforge.net/ and adapted for U-Boot environment.
Used to implement regex operations on environment variables. Code size is ~ 3.5 KiB on PPC.
Signed-off-by: Wolfgang Denk wd@denx.de --- Note: This patch was generated on top of my ``env: fix "env ask" command'' patch. This should be applied before.
include/slre.h | 100 ++++++++ lib/slre.c | 709 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 809 insertions(+), 0 deletions(-) create mode 100644 include/slre.h create mode 100644 lib/slre.c
diff --git a/include/slre.h b/include/slre.h new file mode 100644 index 0000000..4b41a4b --- /dev/null +++ b/include/slre.h @@ -0,0 +1,100 @@ +/* + * Copyright (c) 2004-2005 Sergey Lyubka valenok@gmail.com + * All rights reserved + * + * "THE BEER-WARE LICENSE" (Revision 42): + * Sergey Lyubka wrote this file. As long as you retain this notice you + * can do whatever you want with this stuff. If we meet some day, and you think + * this stuff is worth it, you can buy me a beer in return. + */ + +/* + * Downloaded Sat Nov 5 17:42:08 CET 2011 at + * http://slre.sourceforge.net/1.0/slre.h + */ + +/* + * This is a regular expression library that implements a subset of Perl RE. + * Please refer to http://slre.sourceforge.net for detailed description. + * + * Usage example (parsing HTTP request): + * + * struct slre slre; + * struct cap captures[4 + 1]; // Number of braket pairs + 1 + * ... + * + * slre_compile(&slre,"^(GET|POST) (\S+) HTTP/(\S+?)\r\n"); + * + * if (slre_match(&slre, buf, len, captures)) { + * printf("Request line length: %d\n", captures[0].len); + * printf("Method: %.*s\n", captures[1].len, captures[1].ptr); + * printf("URI: %.*s\n", captures[2].len, captures[2].ptr); + * } + * + * Supported syntax: + * ^ Match beginning of a buffer + * $ Match end of a buffer + * () Grouping and substring capturing + * [...] Match any character from set + * [^...] Match any character but ones from set + * \s Match whitespace + * \S Match non-whitespace + * \d Match decimal digit + * \r Match carriage return + * \n Match newline + * + Match one or more times (greedy) + * +? Match one or more times (non-greedy) + * * Match zero or more times (greedy) + * *? Match zero or more times (non-greedy) + * ? Match zero or once + * \xDD Match byte with hex value 0xDD + * \meta Match one of the meta character: ^$().[*+?\ + */ + +#ifndef SLRE_HEADER_DEFINED +#define SLRE_HEADER_DEFINED + +/* + * Compiled regular expression + */ +struct slre { + unsigned char code[256]; + unsigned char data[256]; + int code_size; + int data_size; + int num_caps; /* Number of bracket pairs */ + int anchored; /* Must match from string start */ + const char *err_str; /* Error string */ +}; + +/* + * Captured substring + */ +struct cap { + const char *ptr; /* Pointer to the substring */ + int len; /* Substring length */ +}; + +/* + * Compile regular expression. If success, 1 is returned. + * If error, 0 is returned and slre.err_str points to the error message. + */ +int slre_compile(struct slre *, const char *re); + +/* + * Return 1 if match, 0 if no match. + * If `captured_substrings' array is not NULL, then it is filled with the + * values of captured substrings. captured_substrings[0] element is always + * a full matched substring. The round bracket captures start from + * captured_substrings[1]. + * It is assumed that the size of captured_substrings array is enough to + * hold all captures. The caller function must make sure it is! So, the + * array_size = number_of_round_bracket_pairs + 1 + */ +int slre_match(const struct slre *, const char *buf, int buf_len, + struct cap *captured_substrings); + +#ifdef SLRE_TEST +void slre_dump(const struct slre *r, FILE *fp); +#endif /* SLRE_TEST */ +#endif /* SLRE_HEADER_DEFINED */ diff --git a/lib/slre.c b/lib/slre.c new file mode 100644 index 0000000..3069c6d --- /dev/null +++ b/lib/slre.c @@ -0,0 +1,709 @@ +/* + * Copyright (c) 2004-2005 Sergey Lyubka valenok@gmail.com + * All rights reserved + * + * "THE BEER-WARE LICENSE" (Revision 42): + * Sergey Lyubka wrote this file. As long as you retain this notice you + * can do whatever you want with this stuff. If we meet some day, and you think + * this stuff is worth it, you can buy me a beer in return. + */ + +/* + * Downloaded Sat Nov 5 17:43:06 CET 2011 at + * http://slre.sourceforge.net/1.0/slre.c + */ + +#ifdef SLRE_TEST +#include <stdio.h> +#include <assert.h> +#include <ctype.h> +#include <stdlib.h> +#include <string.h> +#else +#include <common.h> +#include <linux/ctype.h> +#endif /* SLRE_TEST */ + +#include <errno.h> + +#include <slre.h> + +enum {END, BRANCH, ANY, EXACT, ANYOF, ANYBUT, OPEN, CLOSE, BOL, EOL, + STAR, PLUS, STARQ, PLUSQ, QUEST, SPACE, NONSPACE, DIGIT}; + +#ifdef SLRE_TEST +static struct { + const char *name; + int narg; + const char *flags; +} opcodes[] = { + {"END", 0, ""}, /* End of code block or program */ + {"BRANCH", 2, "oo"}, /* Alternative operator, "|" */ + {"ANY", 0, ""}, /* Match any character, "." */ + {"EXACT", 2, "d"}, /* Match exact string */ + {"ANYOF", 2, "D"}, /* Match any from set, "[]" */ + {"ANYBUT", 2, "D"}, /* Match any but from set, "[^]"*/ + {"OPEN ", 1, "i"}, /* Capture start, "(" */ + {"CLOSE", 1, "i"}, /* Capture end, ")" */ + {"BOL", 0, ""}, /* Beginning of string, "^" */ + {"EOL", 0, ""}, /* End of string, "$" */ + {"STAR", 1, "o"}, /* Match zero or more times "*" */ + {"PLUS", 1, "o"}, /* Match one or more times, "+" */ + {"STARQ", 1, "o"}, /* Non-greedy STAR, "*?" */ + {"PLUSQ", 1, "o"}, /* Non-greedy PLUS, "+?" */ + {"QUEST", 1, "o"}, /* Match zero or one time, "?" */ + {"SPACE", 0, ""}, /* Match whitespace, "\s" */ + {"NONSPACE", 0, ""}, /* Match non-space, "\S" */ + {"DIGIT", 0, ""} /* Match digit, "\d" */ +}; +#endif /* SLRE_TEST */ + +/* + * Commands and operands are all unsigned char (1 byte long). All code offsets + * are relative to current address, and positive (always point forward). Data + * offsets are absolute. Commands with operands: + * + * BRANCH offset1 offset2 + * Try to match the code block that follows the BRANCH instruction + * (code block ends with END). If no match, try to match code block that + * starts at offset1. If either of these match, jump to offset2. + * + * EXACT data_offset data_length + * Try to match exact string. String is recorded in data section from + * data_offset, and has length data_length. + * + * OPEN capture_number + * CLOSE capture_number + * If the user have passed 'struct cap' array for captures, OPEN + * records the beginning of the matched substring (cap->ptr), CLOSE + * sets the length (cap->len) for respective capture_number. + * + * STAR code_offset + * PLUS code_offset + * QUEST code_offset + * *, +, ?, respectively. Try to gobble as much as possible from the + * matched buffer, until code block that follows these instructions + * matches. When the longest possible string is matched, + * jump to code_offset + * + * STARQ, PLUSQ are non-greedy versions of STAR and PLUS. + */ + +static const char *meta_chars = "|.^$*+?()[\"; + +#ifdef SLRE_TEST + +static void +print_character_set(FILE *fp, const unsigned char *p, int len) +{ + int i; + + for (i = 0; i < len; i++) { + if (i > 0) + (void) fputc(',', fp); + if (p[i] == 0) { + i++; + if (p[i] == 0) + (void) fprintf(fp, "\x%02x", p[i]); + else + (void) fprintf(fp, "%s", opcodes[p[i]].name); + } else if (isprint(p[i])) { + (void) fputc(p[i], fp); + } else { + (void) fprintf(fp, "\x%02x", p[i]); + } + } +} + +void +slre_dump(const struct slre *r, FILE *fp) +{ + int i, j, ch, op, pc; + + for (pc = 0; pc < r->code_size; pc++) { + + op = r->code[pc]; + (void) fprintf(fp, "%3d %s ", pc, opcodes[op].name); + + for (i = 0; opcodes[op].flags[i] != '\0'; i++) + switch (opcodes[op].flags[i]) { + case 'i': + (void) fprintf(fp, "%d ", r->code[pc + 1]); + pc++; + break; + case 'o': + (void) fprintf(fp, "%d ", + pc + r->code[pc + 1] - i); + pc++; + break; + case 'D': + print_character_set(fp, r->data + + r->code[pc + 1], r->code[pc + 2]); + pc += 2; + break; + case 'd': + (void) fputc('"', fp); + for (j = 0; j < r->code[pc + 2]; j++) { + ch = r->data[r->code[pc + 1] + j]; + if (isprint(ch)) { + (void) fputc(ch, fp); + } else { + (void) fprintf(fp, + "\x%02x", ch); + } + } + (void) fputc('"', fp); + pc += 2; + break; + } + + (void) fputc('\n', fp); + } +} +#endif /* SLRE_TEST */ + +static void +set_jump_offset(struct slre *r, int pc, int offset) +{ + assert(offset < r->code_size); + + if (r->code_size - offset > 0xff) + r->err_str = "Jump offset is too big"; + else + r->code[pc] = (unsigned char) (r->code_size - offset); +} + +static void +emit(struct slre *r, int code) +{ + if (r->code_size >= (int) (sizeof(r->code) / sizeof(r->code[0]))) + r->err_str = "RE is too long (code overflow)"; + else + r->code[r->code_size++] = (unsigned char) code; +} + +static void +store_char_in_data(struct slre *r, int ch) +{ + if (r->data_size >= (int) sizeof(r->data)) + r->err_str = "RE is too long (data overflow)"; + else + r->data[r->data_size++] = ch; +} + +static void +exact(struct slre *r, const char **re) +{ + int old_data_size = r->data_size; + + while (**re != '\0' && (strchr(meta_chars, **re)) == NULL) + store_char_in_data(r, *(*re)++); + + emit(r, EXACT); + emit(r, old_data_size); + emit(r, r->data_size - old_data_size); +} + +static int +get_escape_char(const char **re) +{ + int res; + + switch (*(*re)++) { + case 'n': + res = '\n'; + break; + case 'r': + res = '\r'; + break; + case 't': + res = '\t'; + break; + case '0': + res = 0; + break; + case 'S': + res = NONSPACE << 8; + break; + case 's': + res = SPACE << 8; + break; + case 'd': + res = DIGIT << 8; + break; + default: + res = (*re)[-1]; + break; + } + + return res; +} + +static void +anyof(struct slre *r, const char **re) +{ + int esc, old_data_size = r->data_size, op = ANYOF; + + if (**re == '^') { + op = ANYBUT; + (*re)++; + } + + while (**re != '\0') + + switch (*(*re)++) { + case ']': + emit(r, op); + emit(r, old_data_size); + emit(r, r->data_size - old_data_size); + return; + /* NOTREACHED */ + break; + case '\': + esc = get_escape_char(re); + if ((esc & 0xff) == 0) { + store_char_in_data(r, 0); + store_char_in_data(r, esc >> 8); + } else { + store_char_in_data(r, esc); + } + break; + default: + store_char_in_data(r, (*re)[-1]); + break; + } + + r->err_str = "No closing ']' bracket"; +} + +static void +relocate(struct slre *r, int begin, int shift) +{ + emit(r, END); + memmove(r->code + begin + shift, r->code + begin, r->code_size - begin); + r->code_size += shift; +} + +static void +quantifier(struct slre *r, int prev, int op) +{ + if (r->code[prev] == EXACT && r->code[prev + 2] > 1) { + r->code[prev + 2]--; + emit(r, EXACT); + emit(r, r->code[prev + 1] + r->code[prev + 2]); + emit(r, 1); + prev = r->code_size - 3; + } + relocate(r, prev, 2); + r->code[prev] = op; + set_jump_offset(r, prev + 1, prev); +} + +static void +exact_one_char(struct slre *r, int ch) +{ + emit(r, EXACT); + emit(r, r->data_size); + emit(r, 1); + store_char_in_data(r, ch); +} + +static void +fixup_branch(struct slre *r, int fixup) +{ + if (fixup > 0) { + emit(r, END); + set_jump_offset(r, fixup, fixup - 2); + } +} + +static void +compile(struct slre *r, const char **re) +{ + int op, esc, branch_start, last_op, fixup, cap_no, level; + + fixup = 0; + level = r->num_caps; + branch_start = last_op = r->code_size; + + for (;;) + switch (*(*re)++) { + case '\0': + (*re)--; + return; + /* NOTREACHED */ + break; + case '^': + emit(r, BOL); + break; + case '$': + emit(r, EOL); + break; + case '.': + last_op = r->code_size; + emit(r, ANY); + break; + case '[': + last_op = r->code_size; + anyof(r, re); + break; + case '\': + last_op = r->code_size; + esc = get_escape_char(re); + if (esc & 0xff00) + emit(r, esc >> 8); + else + exact_one_char(r, esc); + break; + case '(': + last_op = r->code_size; + cap_no = ++r->num_caps; + emit(r, OPEN); + emit(r, cap_no); + + compile(r, re); + if (*(*re)++ != ')') { + r->err_str = "No closing bracket"; + return; + } + + emit(r, CLOSE); + emit(r, cap_no); + break; + case ')': + (*re)--; + fixup_branch(r, fixup); + if (level == 0) { + r->err_str = "Unbalanced brackets"; + return; + } + return; + /* NOTREACHED */ + break; + case '+': + case '*': + op = (*re)[-1] == '*' ? STAR : PLUS; + if (**re == '?') { + (*re)++; + op = op == STAR ? STARQ : PLUSQ; + } + quantifier(r, last_op, op); + break; + case '?': + quantifier(r, last_op, QUEST); + break; + case '|': + fixup_branch(r, fixup); + relocate(r, branch_start, 3); + r->code[branch_start] = BRANCH; + set_jump_offset(r, branch_start + 1, branch_start); + fixup = branch_start + 2; + r->code[fixup] = 0xff; + break; + default: + (*re)--; + last_op = r->code_size; + exact(r, re); + break; + } +} + +int +slre_compile(struct slre *r, const char *re) +{ + r->err_str = NULL; + r->code_size = r->data_size = r->num_caps = r->anchored = 0; + + if (*re == '^') + r->anchored++; + + emit(r, OPEN); /* This will capture what matches full RE */ + emit(r, 0); + + while (*re != '\0') + compile(r, &re); + + if (r->code[2] == BRANCH) + fixup_branch(r, 4); + + emit(r, CLOSE); + emit(r, 0); + emit(r, END); + + return (r->err_str == NULL ? 1 : 0); +} + +static int match(const struct slre *, int, + const char *, int, int *, struct cap *); + +static void +loop_greedy(const struct slre *r, int pc, const char *s, int len, int *ofs) +{ + int saved_offset, matched_offset; + + saved_offset = matched_offset = *ofs; + + while (match(r, pc + 2, s, len, ofs, NULL)) { + saved_offset = *ofs; + if (match(r, pc + r->code[pc + 1], s, len, ofs, NULL)) + matched_offset = saved_offset; + *ofs = saved_offset; + } + + *ofs = matched_offset; +} + +static void +loop_non_greedy(const struct slre *r, int pc, const char *s, int len, int *ofs) +{ + int saved_offset = *ofs; + + while (match(r, pc + 2, s, len, ofs, NULL)) { + saved_offset = *ofs; + if (match(r, pc + r->code[pc + 1], s, len, ofs, NULL)) + break; + } + + *ofs = saved_offset; +} + +static int +is_any_of(const unsigned char *p, int len, const char *s, int *ofs) +{ + int i, ch; + + ch = s[*ofs]; + + for (i = 0; i < len; i++) + if (p[i] == ch) { + (*ofs)++; + return 1; + } + + return 0; +} + +static int +is_any_but(const unsigned char *p, int len, const char *s, int *ofs) +{ + int i, ch; + + ch = s[*ofs]; + + for (i = 0; i < len; i++) { + if (p[i] == ch) + return 0; + } + + (*ofs)++; + return 1; +} + +static int +match(const struct slre *r, int pc, const char *s, int len, + int *ofs, struct cap *caps) +{ + int n, saved_offset, res = 1; + + while (res && r->code[pc] != END) { + + assert(pc < r->code_size); + assert(pc < (int) (sizeof(r->code) / sizeof(r->code[0]))); + + switch (r->code[pc]) { + case BRANCH: + saved_offset = *ofs; + res = match(r, pc + 3, s, len, ofs, caps); + if (res == 0) { + *ofs = saved_offset; + res = match(r, pc + r->code[pc + 1], + s, len, ofs, caps); + } + pc += r->code[pc + 2]; + break; + case EXACT: + res = 0; + n = r->code[pc + 2]; /* String length */ + if (n <= len - *ofs && !memcmp(s + *ofs, r->data + + r->code[pc + 1], n)) { + (*ofs) += n; + res = 1; + } + pc += 3; + break; + case QUEST: + res = 1; + saved_offset = *ofs; + if (!match(r, pc + 2, s, len, ofs, caps)) + *ofs = saved_offset; + pc += r->code[pc + 1]; + break; + case STAR: + res = 1; + loop_greedy(r, pc, s, len, ofs); + pc += r->code[pc + 1]; + break; + case STARQ: + res = 1; + loop_non_greedy(r, pc, s, len, ofs); + pc += r->code[pc + 1]; + break; + case PLUS: + res = match(r, pc + 2, s, len, ofs, caps); + if (res == 0) + break; + + loop_greedy(r, pc, s, len, ofs); + pc += r->code[pc + 1]; + break; + case PLUSQ: + res = match(r, pc + 2, s, len, ofs, caps); + if (res == 0) + break; + + loop_non_greedy(r, pc, s, len, ofs); + pc += r->code[pc + 1]; + break; + case SPACE: + res = 0; + if (*ofs < len && isspace(((unsigned char *)s)[*ofs])) { + (*ofs)++; + res = 1; + } + pc++; + break; + case NONSPACE: + res = 0; + if (*ofs < len && + !isspace(((unsigned char *)s)[*ofs])) { + (*ofs)++; + res = 1; + } + pc++; + break; + case DIGIT: + res = 0; + if (*ofs < len && isdigit(((unsigned char *)s)[*ofs])) { + (*ofs)++; + res = 1; + } + pc++; + break; + case ANY: + res = 0; + if (*ofs < len) { + (*ofs)++; + res = 1; + } + pc++; + break; + case ANYOF: + res = 0; + if (*ofs < len) + res = is_any_of(r->data + r->code[pc + 1], + r->code[pc + 2], s, ofs); + pc += 3; + break; + case ANYBUT: + res = 0; + if (*ofs < len) + res = is_any_but(r->data + r->code[pc + 1], + r->code[pc + 2], s, ofs); + pc += 3; + break; + case BOL: + res = *ofs == 0 ? 1 : 0; + pc++; + break; + case EOL: + res = *ofs == len ? 1 : 0; + pc++; + break; + case OPEN: + if (caps != NULL) + caps[r->code[pc + 1]].ptr = s + *ofs; + pc += 2; + break; + case CLOSE: + if (caps != NULL) + caps[r->code[pc + 1]].len = (s + *ofs) - + caps[r->code[pc + 1]].ptr; + pc += 2; + break; + case END: + pc++; + break; + default: + printf("unknown cmd (%d) at %d\n", r->code[pc], pc); + assert(0); + break; + } + } + + return res; +} + +int +slre_match(const struct slre *r, const char *buf, int len, + struct cap *caps) +{ + int i, ofs = 0, res = 0; + + if (r->anchored) { + res = match(r, 0, buf, len, &ofs, caps); + } else { + for (i = 0; i < len && res == 0; i++) { + ofs = i; + res = match(r, 0, buf, len, &ofs, caps); + } + } + + return res; +} + +#ifdef SLRE_TEST +int main(int argc, char *argv[]) +{ + struct slre slre; + struct cap caps[20]; + char data[1 * 1024 * 1024]; + FILE *fp; + int i, count, res, len; + + if (argc < 3) { + printf("Usage: %s 'slre' <file> [count]\n", argv[0]); + } else { + fp = fopen(argv[2], "rb"); + if (fp == NULL) { + printf("Error: cannot open %s:%s\n", + argv[2], strerror(errno)); + } else if (!slre_compile(&slre, argv[1])) { + printf("Error compiling slre: %s\n", slre.err_str); + } else { + slre_dump(&slre, stderr); + + (void) memset(caps, 0, sizeof(caps)); + + /* Read first 128K of file */ + len = fread(data, 1, sizeof(data), fp); + (void) fclose(fp); + + res = 0; + count = argc > 3 ? atoi(argv[3]) : 1; + for (i = 0; i < count; i++) + res = slre_match(&slre, data, len, caps); + + printf("Result: %d\n", res); + + for (i = 0; i < 20; i++) { + if (caps[i].len > 0) { + printf("Substring %d: [%.*s]\n", i, + caps[i].len, caps[i].ptr); + } + } + } + } + + return 0; +} +#endif /* SLRE_TEST */
Syntax: env regex [-g] [-s subst] regex name [...]
The code is based on SLRE (http://slre.sourceforge.net/) which provides a tiny subset of Perl regular expressions.
Without options, this will implement regex pattern matching on environment variables. Variables with matching values will be printd as with "env print", so this basicly performs a "grep" on the given list of variables.
With "-s subst", the matching pattern gets replaced with the string given in "subst". Back references '\0' ... '\9' are allowed, where '\0' stands for the whole matched string, and '\1', '\2', ... are replaced with the first, second, ... sub-pattern.
"-g" allows for global replacement.
Examples: => setenv foo abcdefghijklmnop => env reg 'A' '[bdgmo]' foo => env reg -s 'A' '[bdgmo]' foo foo=aAcdefghijklmnop => env reg -g -s 'B' '[bdgmo]' foo foo=aAcBefBhijklBnBp => env reg -g -s '\2--\1' '(Be).*(kl)' foo foo=aAckl--BeBnBp
[Note: the double backslashes are needed by U-Boot's "shell" so one backslash gets passed to the actual command.]
Signed-off-by: Wolfgang Denk wd@denx.de --- common/cmd_nvedit.c | 288 +++++++++++++++++++++++++++++++++++++++++++++++++++ lib/Makefile | 1 + 2 files changed, 289 insertions(+), 0 deletions(-)
diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 2dd4eba..4307d27 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -164,6 +164,288 @@ int do_env_print (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return rcode; }
+#ifdef CONFIG_CMD_REGEX + +/* + * memstr - Find the first substring in memory + * @s1: The string to be searched + * @s2: The string to search for + * + * Similar to and based on strstr(), + * but strings do not need to be NUL terminated. + */ +static char *memstr(const char *s1, int l1, const char *s2, int l2) +{ + if (!l2) + return (char *) s1; + + while (l1 >= l2) { + l1--; + if (!memcmp(s1, s2, l2)) + return (char *) s1; + s1++; + } + return NULL; +} + +static char *substitute(char *string, /* string buffer */ + int *slen, /* current string length */ + int ssize, /* string bufer size */ + const char *old,/* old (replaced) string */ + int olen, /* length of old string */ + const char *new,/* new (replacement) string */ + int nlen) /* length of new string */ +{ + char *p = memstr(string, *slen, old, olen); + + if (p == NULL) + return NULL; + + debug("## Match at pos %ld: match len %d, subst len %d\n", + (long)(p - string), olen, nlen); + + /* make sure replacement matches */ + if (*slen + nlen - olen > ssize) { + printf("## error: substitution buffer overflow\n"); + return NULL; + } + + /* move tail if needed */ + if (olen != nlen) { + int tail, len; + + len = (olen > nlen) ? olen : nlen; + + tail = ssize - (p + len - string); + + debug("## tail len %d\n", tail); + + memmove(p + nlen, p + olen, tail); + } + + /* insert substitue */ + memcpy(p, new, nlen); + + *slen += nlen - olen; + + return p + nlen; +} + +#include "slre.h" + +#define SLRE_BUFSZ 16384 +#define SLRE_PATSZ 4096 + +/* + * Perform regex operations on a environment variable + * + * Returns 0 in case of error, or length of printed string + */ +static int env_regex(const char *name, const char *regexp, const char *subst, + int global) +{ + ENTRY e, *ep; + struct slre slre; + struct cap caps[32]; + char data[SLRE_BUFSZ]; + char *datap = data; + int res, len, nlen, loop; + + if (name == NULL) + return 0; + + if (slre_compile(&slre, regexp) == 0) { + printf("Error compiling regex: %s\n", slre.err_str); + return 1; + } + + e.key = name; + e.data = NULL; + hsearch_r(e, FIND, &ep, &env_htab); + if (ep == NULL) { + printf("## Error: "%s" not defined\n", name); + return 1; + } + + debug("REGEX on %s=%s\n", ep->key, ep->data); + debug("REGEX="%s", SUBST="%s", GLOBAL=%d\n", + regexp, subst ? subst : "<NULL>", global); + + len = strlen(ep->data); + if (len + 1 > SLRE_BUFSZ) { + printf("## error: substitution buffer overflow\n"); + return 1; + } + + strcpy(data, ep->data); + + if (subst == NULL) + nlen = 0; + else + nlen = strlen(subst); + + for (loop = 0; ;loop++) { + char nbuf[SLRE_PATSZ]; + const char *old;; + char *np; + int i, olen; + + (void) memset(caps, 0, sizeof(caps)); + + res = slre_match(&slre, datap, len, caps); + + debug("Result: %d\n", res); + + for (i = 0; i < 20; i++) { + if (caps[i].len > 0) { + debug("Substring %d: [%.*s]\n", i, + caps[i].len, caps[i].ptr); + } + } + + if (res == 0) { + if (loop == 0) { + printf("%s: No match\n", ep->key); + return 1; + } else { + break; + } + } + + debug("## MATCH ## %s\n", data); + + if (subst == NULL) { + printf("%s=%s\n", ep->key, ep->data); + return 0; + } + + old = caps[0].ptr; + olen = caps[0].len; + + if (nlen + 1 >= SLRE_PATSZ) { + printf("## error: pattern buffer overflow\n"); + return 1; + } + strcpy(nbuf, subst); + + debug("## SUBST(1) ## %s\n", nbuf); + + /* + * Handle back references + * + * Support for \0 ... \9, where \0 is the + * whole matched pattern (similar to &). + * + * Implementation is a bit simpleminded as + * backrefs are substituted sequentially, one + * by one. This will lead to somewhat + * unexpected results if the replacement + * strings contain any \N strings then then + * may get substitued, too. We accept this + * restriction for the sake of simplicity. + */ + for (i = 0; i < 10; ++i) { + char backref[2] = { + '\', + '0', + }; + + if (caps[i].len == 0) + break; + + backref[1] += i; + + debug("## BACKREF %d: replace "%.*s" by "%.*s" in "%s"\n", + i, + 2, backref, + caps[i].len, caps[i].ptr, + nbuf); + + for (np = nbuf;;) { + char *p = memstr(np, nlen, + backref, 2); + + if (p == NULL) + break; + + np = substitute(np, &nlen, + SLRE_PATSZ, + backref, 2, + caps[i].ptr, caps[i].len); + + if (np == NULL) + return 1; + } + } + debug("## SUBST(2) ## %s\n", nbuf); + + datap = substitute(datap, &len, SLRE_BUFSZ, + old, olen, + nbuf, nlen); + + if (datap == NULL) + return 1; + + debug("## REMAINDER: %s\n", datap); + + debug("## RESULT: %s\n", data); + + if (!global) + break; + } + debug("## FINAL (now setenv()) : %s\n", data); + + printf("%s=%s\n", ep->key, data); + + return setenv(ep->key, data); +} + +static int do_env_regex(cmd_tbl_t *cmdtp, int flag, int argc, + char *const argv[]) +{ + int i; + int rcode = 0; + int global = 0; + const char *regex, *subst = NULL; + + while (--argc > 0 && **++argv == '-') { + char *arg = *argv; + while (*++arg) { + switch (*arg) { + case 'e': + /* allow regex starting with '-' */ + ++argv; + goto DONE; + case 'g': + global = 1; + break; + case 's': + if (--argc <= 0) + return cmd_usage(cmdtp); + subst = *++argv; + goto NXTARG; + default: + return cmd_usage(cmdtp); + } + } +NXTARG: ; + } +DONE: + if (argc < 2) + return cmd_usage(cmdtp); + + regex = argv[0]; + + /* process selected env vars */ + for (i = 1; i < argc; ++i) { + if (env_regex(argv[i], regex, subst, global) != 0) + rcode = 1; + } + + return rcode; +} +#endif + #ifdef CONFIG_CMD_GREPENV static int do_env_grep (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { @@ -1022,6 +1304,9 @@ static cmd_tbl_t cmd_env_sub[] = { U_BOOT_CMD_MKENT(import, 5, 0, do_env_import, "", ""), #endif U_BOOT_CMD_MKENT(print, CONFIG_SYS_MAXARGS, 1, do_env_print, "", ""), +#if defined(CONFIG_CMD_REGEX) + U_BOOT_CMD_MKENT(regex, CONFIG_SYS_MAXARGS, 1, do_env_regex, "", ""), +#endif #if defined(CONFIG_CMD_RUN) U_BOOT_CMD_MKENT(run, CONFIG_SYS_MAXARGS, 1, do_run, "", ""), #endif @@ -1076,6 +1361,9 @@ U_BOOT_CMD( #endif "env import [-d] [-t | -b | -c] addr [size] - import environment\n" "env print [name ...] - print environment\n" +#ifdef CONFIG_CMD_REGEX + "env regex [-g] [-s subst] regex name [...] - search and substitute regular expression\n" +#endif #if defined(CONFIG_CMD_RUN) "env run var [...] - run commands in an environment variable\n" #endif diff --git a/lib/Makefile b/lib/Makefile index 54708c2..346409c 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -48,6 +48,7 @@ COBJS-y += net_utils.o COBJS-y += qsort.o COBJS-$(CONFIG_SHA1) += sha1.o COBJS-$(CONFIG_SHA256) += sha256.o +COBJS-$(CONFIG_CMD_REGEX) += slre.o COBJS-y += strmhz.o COBJS-$(CONFIG_RBTREE) += rbtree.o endif
Hi Wolfgang,
this really is an interesting addition!
Ok, this usage looks fine.
But IMHO this usage doesn't really belong into the "env" command. It much rather is a further operation of the setexpr command:
set environment variable as the result of eval expression", name value1 <op> value2\n" - set environment variable 'name' to the result of the evaluated\n" express specified by <op>. <op> can be &, |, ^, +, -, *, /, %"
We could add the <op>erations for regsubst and regsubstg. For actual names for the operations, I'm somewhat unsure. Maybe "function like", i.e. "regsubst(string, pattern, replacement)" and "regsubstg(string, pattern, replacement)"?
So I'd vote for
=> setenv result regsubst($foo, '[bdgmo]', 'A')
What do you think?
Cheers Detlev
Also, add a space after the message fore easier reading, and clean up help mesage.
Signed-off-by: Wolfgang Denk wd@denx.de --- common/cmd_nvedit.c | 56 +++++++++++++++++++++++++++-------------------------- 1 file changed, 29 insertions(+), 27 deletions(-)
diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 7633f0c..5f30f86 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -325,41 +325,50 @@ static int do_env_set(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) int do_env_ask(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { char message[CONFIG_SYS_CBSIZE]; - int size = CONFIG_SYS_CBSIZE - 1; - int i, len, pos; + int i, len, pos, size; char *local_args[4]; + char *endptr;
- /* Check the syntax */ - switch (argc) { - case 1: + /* + * Check the syntax: + * + * env_ask envname [message1 ...] [size] + */ + if (argc == 1) return CMD_RET_USAGE;
strcpy(message + pos, argv[i]); pos += strlen(argv[i]); } - + message[pos++] = ' '; message[pos] = '\0'; - size = simple_strtoul(argv[argc - 1], NULL, 10); - break; }
if (size >= CONFIG_SYS_CBSIZE) @@ -1168,14 +1177,7 @@ U_BOOT_CMD( askenv, CONFIG_SYS_MAXARGS, 1, do_env_ask, "get environment variables from stdin", "name [message] [size]\n" - " - get environment variable 'name' from stdin (max 'size' chars)\n" - "askenv name\n" - " - get environment variable 'name' from stdin\n" - "askenv name size\n" - " - get environment variable 'name' from stdin (max 'size' chars)\n" - "askenv name [message] size\n" - " - display 'message' string and get environment variable 'name'" - "from stdin (max 'size' chars)" + " - get environment variable 'name' from stdin (max 'size' chars)" ); #endif
The following patch series adds the SLRE "Super Light Regular Expression" library and uses this to add regex support for the "env grep" (aka "grepenv") command, and new functions (or operators?) "gsub" and "sub" to the "setexpr" command.
The rework to "env grep" also fixed a few bugs (which cuased it to dump always _all_ environment varioables on some systems), and adds the capability to grep in either the variable name, or the value, or in both (the old version olways did the latter). Instead of special functions we now use common code (i. e. hexport_r()) for the variable lookup, which gives us sorted output as a free additional benefit.
This allows to do things like
- print all MAC addresses:
=> env grep -e eth.*addr eth1addr=00:10:ec:80:c5:15 ethaddr=00:10:ec:00:c5:15
- print all variables that have at least 2 colons in their value:
=> env grep -v -e :.*: addip=setenv bootargs ${bootargs} ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}:${netdev}:off panic=1 eth1addr=00:10:ec:80:c5:15 ethaddr=00:10:ec:00:c5:15 ver=U-Boot 2013.04-rc1-00289-g497746b-dirty (Mar 22 2013 - 12:50:25)
- Generate broadcast address by substituting the last two numbers of the IP address by "255.255":
=> print ipaddr ipaddr=192.168.1.104 => setexpr broadcast sub "(.*\.).*\..*" "\1255.255" $ipaddr broadcast=192.168.255.255
- Depending on keyboard configuration (German vs. US keyboard) a barcode scanner may initialize the MAC address as C0:E5:4E:02:06:DC or as C0>E5>4E>02>06>DC. Make sure we always have a correct value:
=> print ethaddr ethaddr=C0>E5>4E>02>06>DC => setexpr ethaddr gsub > : ethaddr=C0:E5:4E:02:06:DC
etc.
Regex support can be enabled by defining CONFIG_REGEX in the board config file.
Wolfgang Denk (9): hashtable: preparations to use hexport_r() for "env grep" "env grep" - reimplement command using hexport_r() "env grep" - add options to grep in name, value, or both. Add SLRE - Super Light Regular Expression library "env grep" - add support for regular expression matches setexpr: simplify code, improve help message setexpr: add regex substring matching and substitution m28evk: enable "env grep" and regexp support amcc-common.h: enable support for "env grep", "setexpr", and regex.
README | 7 + common/cmd_nvedit.c | 87 +++-- common/cmd_setexpr.c | 296 ++++++++++++++++- include/configs/amcc-common.h | 9 +- include/configs/m28evk.h | 3 + include/search.h | 15 +- include/slre.h | 100 ++++++ lib/Makefile | 1 + lib/hashtable.c | 93 ++++-- lib/slre.c | 724 ++++++++++++++++++++++++++++++++++++++++++ 10 files changed, 1263 insertions(+), 72 deletions(-) create mode 100644 include/slre.h create mode 100644 lib/slre.c
The output of "env grep" is unsorted, and printing is done by a private implementation to parse the hash table. We have all the needed code in place in hexport_r() alsready, so let's use this instead. Here we prepare the code for this, without any functional changes yet.
Signed-off-by: Wolfgang Denk wd@denx.de --- common/cmd_nvedit.c | 10 +++++++--- include/search.h | 8 +++++++- lib/hashtable.c | 32 ++++++++++++++++++++++++-------- 3 files changed, 38 insertions(+), 12 deletions(-)
diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 947d6c4..5c84795 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2000-2010 + * (C) Copyright 2000-2013 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. * * (C) Copyright 2001 Sysgo Real-Time Solutions, GmbH <www.elinos.com> @@ -871,7 +871,9 @@ NXTARG: ; argv++;
if (sep) { /* export as text file */ - len = hexport_r(&env_htab, sep, 0, &addr, size, argc, argv); + len = hexport_r(&env_htab, sep, + H_MATCH_KEY | H_MATCH_IDENT, + &addr, size, argc, argv); if (len < 0) { error("Cannot export environment: errno = %d\n", errno); return 1; @@ -889,7 +891,9 @@ NXTARG: ; else /* export as raw binary data */ res = addr;
- len = hexport_r(&env_htab, '\0', 0, &res, ENV_SIZE, argc, argv); + len = hexport_r(&env_htab, '\0', + H_MATCH_KEY | H_MATCH_IDENT, + &res, ENV_SIZE, argc, argv); if (len < 0) { error("Cannot export environment: errno = %d\n", errno); return 1; diff --git a/include/search.h b/include/search.h index 13d3be6..9d9abd6 100644 --- a/include/search.h +++ b/include/search.h @@ -22,7 +22,7 @@ /* * Based on code from uClibc-0.9.30.3 * Extensions for use within U-Boot - * Copyright (C) 2010 Wolfgang Denk wd@denx.de + * Copyright (C) 2010-2013 Wolfgang Denk wd@denx.de */
#ifndef _SEARCH_H @@ -131,5 +131,11 @@ extern int hwalk_r(struct hsearch_data *__htab, int (*callback)(ENTRY *)); #define H_FORCE (1 << 1) /* overwrite read-only/write-once variables */ #define H_INTERACTIVE (1 << 2) /* indicate that an import is user directed */ #define H_HIDE_DOT (1 << 3) /* don't print env vars that begin with '.' */ +#define H_MATCH_KEY (1 << 4) /* search/grep key = variable names */ +#define H_MATCH_DATA (1 << 5) /* search/grep data = variable values */ +#define H_MATCH_BOTH (H_MATCH_KEY | H_MATCH_DATA) /* search/grep both */ +#define H_MATCH_IDENT (1 << 6) /* search for indentical strings */ +#define H_MATCH_SUBSTR (1 << 7) /* search for substring matches */ +#define H_MATCH_METHOD (H_MATCH_IDENT | H_MATCH_SUBSTR)
#endif /* search.h */ diff --git a/lib/hashtable.c b/lib/hashtable.c index 07ebfb2..1d18d15 100644 --- a/lib/hashtable.c +++ b/lib/hashtable.c @@ -2,7 +2,7 @@ * This implementation is based on code from uClibc-0.9.30.3 but was * modified and extended for use within U-Boot. * - * Copyright (C) 2010 Wolfgang Denk wd@denx.de + * Copyright (C) 2010-2013 Wolfgang Denk wd@denx.de * * Original license header: * @@ -563,6 +563,28 @@ static int cmpkey(const void *p1, const void *p2) return (strcmp(e1->key, e2->key)); }
+static int match_strings(ENTRY *ep, int flag, + int argc, char * const argv[]) +{ + int arg; + + for (arg = 0; arg < argc; ++arg) { + if (flag & H_MATCH_KEY) { + switch (flag & H_MATCH_METHOD) { + case H_MATCH_IDENT: + if (strcmp(argv[arg], ep->key) == 0) + return 1; + break; + default: + printf("## ERROR: unsupported match method: 0x%02x\n", + flag & H_MATCH_METHOD); + break; + } + } + } + return 0; +} + ssize_t hexport_r(struct hsearch_data *htab, const char sep, int flag, char **resp, size_t size, int argc, char * const argv[]) @@ -589,14 +611,8 @@ ssize_t hexport_r(struct hsearch_data *htab, const char sep, int flag,
if (htab->table[i].used > 0) { ENTRY *ep = &htab->table[i].entry; - int arg, found = 0; + int found = match_strings(ep, flag, argc, argv);
- for (arg = 0; arg < argc; ++arg) { - if (strcmp(argv[arg], ep->key) == 0) { - found = 1; - break; - } - } if ((argc > 0) && (found == 0)) continue;
Also drop hstrstr_r() which is not needed any more. The new code is way more flexible.
Signed-off-by: Wolfgang Denk wd@denx.de --- common/cmd_nvedit.c | 30 ++++++++++--------------- include/search.h | 6 ----- lib/hashtable.c | 64 +++++++++++++++++++++++------------------------------ 3 files changed, 40 insertions(+), 60 deletions(-)
diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 5c84795..40d9f7a 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -162,31 +162,25 @@ static int do_env_print(cmd_tbl_t *cmdtp, int flag, int argc, static int do_env_grep(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - ENTRY *match; - unsigned char matched[env_htab.size / 8]; - int rcode = 1, arg = 1, idx; + char *res = NULL; + int len;
if (argc < 2) return CMD_RET_USAGE;
- memset(matched, 0, env_htab.size / 8); + len = hexport_r(&env_htab, '\n', + flag | H_MATCH_BOTH | H_MATCH_SUBSTR, + &res, 0, argc, argv);
- while (arg <= argc) { - idx = 0; - while ((idx = hstrstr_r(argv[arg], idx, &match, &env_htab))) { - if (!(matched[idx / 8] & (1 << (idx & 7)))) { - puts(match->key); - puts("="); - puts(match->data); - puts("\n"); - } - matched[idx / 8] |= 1 << (idx & 7); - rcode = 0; - } - arg++; + if (len > 0) { + puts(res); + free(res); }
- return rcode; + if (len < 2) + return 1; + + return 0; } #endif #endif /* CONFIG_SPL_BUILD */ diff --git a/include/search.h b/include/search.h index 9d9abd6..d06a201 100644 --- a/include/search.h +++ b/include/search.h @@ -98,12 +98,6 @@ extern int hsearch_r(ENTRY __item, ACTION __action, ENTRY ** __retval, */ extern int hmatch_r(const char *__match, int __last_idx, ENTRY ** __retval, struct hsearch_data *__htab); -/* - * Search for an entry whose key or data contains `MATCH'. Otherwise, - * Same semantics as hsearch_r(). - */ -extern int hstrstr_r(const char *__match, int __last_idx, ENTRY ** __retval, - struct hsearch_data *__htab);
/* Search and delete entry matching ITEM.key in internal hash table. */ extern int hdelete_r(const char *__key, struct hsearch_data *__htab, diff --git a/lib/hashtable.c b/lib/hashtable.c index 1d18d15..8ad56ec 100644 --- a/lib/hashtable.c +++ b/lib/hashtable.c @@ -210,29 +210,6 @@ void hdestroy_r(struct hsearch_data *htab) * example for functions like hdelete(). */
-/* - * hstrstr_r - return index to entry whose key and/or data contains match - */ -int hstrstr_r(const char *match, int last_idx, ENTRY ** retval, - struct hsearch_data *htab) -{ - unsigned int idx; - - for (idx = last_idx + 1; idx < htab->size; ++idx) { - if (htab->table[idx].used <= 0) - continue; - if (strstr(htab->table[idx].entry.key, match) || - strstr(htab->table[idx].entry.data, match)) { - *retval = &htab->table[idx].entry; - return idx; - } - } - - __set_errno(ESRCH); - *retval = NULL; - return 0; -} - int hmatch_r(const char *match, int last_idx, ENTRY ** retval, struct hsearch_data *htab) { @@ -563,23 +540,38 @@ static int cmpkey(const void *p1, const void *p2) return (strcmp(e1->key, e2->key)); }
-static int match_strings(ENTRY *ep, int flag, +static int match_string(int flag, const char * str, const char * pat) +{ + switch (flag & H_MATCH_METHOD) { + case H_MATCH_IDENT: + if (strcmp(str, pat) == 0) + return 1; + break; + case H_MATCH_SUBSTR: + if (strstr(str, pat)) + return 1; + break; + default: + printf("## ERROR: unsupported match method: 0x%02x\n", + flag & H_MATCH_METHOD); + break; + } + return 0; +} + +static int match_entry(ENTRY *ep, int flag, int argc, char * const argv[]) { int arg;
- for (arg = 0; arg < argc; ++arg) { + for (arg = 1; arg < argc; ++arg) { if (flag & H_MATCH_KEY) { - switch (flag & H_MATCH_METHOD) { - case H_MATCH_IDENT: - if (strcmp(argv[arg], ep->key) == 0) - return 1; - break; - default: - printf("## ERROR: unsupported match method: 0x%02x\n", - flag & H_MATCH_METHOD); - break; - } + if (match_string(flag, ep->key, argv[arg])) + return 1; + } + if (flag & H_MATCH_DATA) { + if (match_string(flag, ep->data, argv[arg])) + return 1; } } return 0; @@ -611,7 +603,7 @@ ssize_t hexport_r(struct hsearch_data *htab, const char sep, int flag,
if (htab->table[i].used > 0) { ENTRY *ep = &htab->table[i].entry; - int found = match_strings(ep, flag, argc, argv); + int found = match_entry(ep, flag, argc, argv);
Add options to "env grep" command:
-n : search only the envrironment variable names -v : search only their values -b : search both names and values (= default)
An option "--" will stop parsing options, so to print variables that contain the striing "- " please use:
env grep -- "- "
Or to print all environment varioables which have a '-' in their name, use:
env grep -n -- -
Signed-off-by: Wolfgang Denk wd@denx.de --- common/cmd_nvedit.c | 38 +++++++++++++++++++++++++++++++++----- 1 file changed, 33 insertions(+), 5 deletions(-)
diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 40d9f7a..441bf40 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -163,13 +163,39 @@ static int do_env_grep(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { char *res = NULL; - int len; + int len, grep_flags;
+ grep_flags = H_MATCH_BOTH; + + while (argc > 1 && **(argv + 1) == '-') { + char *arg = *++argv; + + --argc; + while (*++arg) { + switch (*arg) { + case 'n': /* grep for name */ + grep_flags = H_MATCH_KEY; + break; + case 'v': /* grep for value */ + grep_flags = H_MATCH_DATA; + break; + case 'b': /* grep for both */ + grep_flags = H_MATCH_BOTH; + break; + case '-': + goto DONE; + default: + return CMD_RET_USAGE; + } + } + } + +DONE: len = hexport_r(&env_htab, '\n', - flag | H_MATCH_BOTH | H_MATCH_SUBSTR, + flag | grep_flags | H_MATCH_SUBSTR, &res, 0, argc, argv);
if (len > 0) { @@ -1106,7 +1132,7 @@ static char env_help_text[] = "env flags - print variables that have non-default flags\n" #endif #if defined(CONFIG_CMD_GREPENV) - "env grep string [...] - search environment\n" + "env grep [-n | -v | -b] string [...] - search environment\n" #endif #if defined(CONFIG_CMD_IMPORTENV) "env import [-d] [-t | -b | -c] addr [size] - import environment\n" @@ -1153,8 +1179,10 @@ U_BOOT_CMD_COMPLETE( U_BOOT_CMD_COMPLETE( grepenv, CONFIG_SYS_MAXARGS, 0, do_env_grep, "search environment variables", - "string ...\n" - " - list environment name=value pairs matching 'string'", + "[-n | -v | -b] string ...\n" + " - list environment name=value pairs matching 'string'\n" + " "-n": search variable names; "-v": search values;\n" + " "-b": search both names and values (default)", var_complete ); #endif
To enable this code, define the CONFIG_REGEX option in your board config file.
Note: There are more recent versions of the SLRE library available at http://slre.googlecode.com ; unfortunately, the new code has a heavily reorked API which makes it less usable for our purposes: - the return code is strings, which are more difficult to process - we don't get any information any more which sub-string of the data was matched by the given regex - it is much more cumbersome to work with arbitrary expressions, where for example the number of substrings for capturing are not known at compile time Also, there does not seem to be any real changes or improvements of the functionality.
Because of this, we deliberately stick with the older code.
Note 2: the test code (built when SLRE_TEST is defined) was modified to allow for more extensive testing; now we can test the regexp matching on all lines on a text file (instead of the whole data in the file as a single block).
Signed-off-by: Wolfgang Denk wd@denx.de --- README | 7 + include/slre.h | 100 ++++++++ lib/Makefile | 1 + lib/slre.c | 724 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 832 insertions(+) create mode 100644 include/slre.h create mode 100644 lib/slre.c
diff --git a/README b/README index 7f2506a..f088d28 100644 --- a/README +++ b/README @@ -930,6 +930,13 @@ The following options need to be configured:
XXX - this list needs to get updated!
+- Regular expression support: + CONFIG_REGEX + If this variable is defined, U-Boot is linked against + the SLRE (Super Light Regular Expression) library, + which adds regex support to some commands, as for + example "env grep" and "setexpr". + - Device tree: CONFIG_OF_CONTROL If this variable is defined, U-Boot will use a device tree diff --git a/include/slre.h b/include/slre.h new file mode 100644 index 0000000..4b41a4b --- /dev/null +++ b/include/slre.h @@ -0,0 +1,100 @@ +/* + * Copyright (c) 2004-2005 Sergey Lyubka valenok@gmail.com + * All rights reserved + * + * "THE BEER-WARE LICENSE" (Revision 42): + * Sergey Lyubka wrote this file. As long as you retain this notice you + * can do whatever you want with this stuff. If we meet some day, and you think + * this stuff is worth it, you can buy me a beer in return. + */ + +/* + * Downloaded Sat Nov 5 17:42:08 CET 2011 at + * http://slre.sourceforge.net/1.0/slre.h + */ + +/* + * This is a regular expression library that implements a subset of Perl RE. + * Please refer to http://slre.sourceforge.net for detailed description. + * + * Usage example (parsing HTTP request): + * + * struct slre slre; + * struct cap captures[4 + 1]; // Number of braket pairs + 1 + * ... + * + * slre_compile(&slre,"^(GET|POST) (\S+) HTTP/(\S+?)\r\n"); + * + * if (slre_match(&slre, buf, len, captures)) { + * printf("Request line length: %d\n", captures[0].len); + * printf("Method: %.*s\n", captures[1].len, captures[1].ptr); + * printf("URI: %.*s\n", captures[2].len, captures[2].ptr); + * } + * + * Supported syntax: + * ^ Match beginning of a buffer + * $ Match end of a buffer + * () Grouping and substring capturing + * [...] Match any character from set + * [^...] Match any character but ones from set + * \s Match whitespace + * \S Match non-whitespace + * \d Match decimal digit + * \r Match carriage return + * \n Match newline + * + Match one or more times (greedy) + * +? Match one or more times (non-greedy) + * * Match zero or more times (greedy) + * *? Match zero or more times (non-greedy) + * ? Match zero or once + * \xDD Match byte with hex value 0xDD + * \meta Match one of the meta character: ^$().[*+?\ + */ + +#ifndef SLRE_HEADER_DEFINED +#define SLRE_HEADER_DEFINED + +/* + * Compiled regular expression + */ +struct slre { + unsigned char code[256]; + unsigned char data[256]; + int code_size; + int data_size; + int num_caps; /* Number of bracket pairs */ + int anchored; /* Must match from string start */ + const char *err_str; /* Error string */ +}; + +/* + * Captured substring + */ +struct cap { + const char *ptr; /* Pointer to the substring */ + int len; /* Substring length */ +}; + +/* + * Compile regular expression. If success, 1 is returned. + * If error, 0 is returned and slre.err_str points to the error message. + */ +int slre_compile(struct slre *, const char *re); + +/* + * Return 1 if match, 0 if no match. + * If `captured_substrings' array is not NULL, then it is filled with the + * values of captured substrings. captured_substrings[0] element is always + * a full matched substring. The round bracket captures start from + * captured_substrings[1]. + * It is assumed that the size of captured_substrings array is enough to + * hold all captures. The caller function must make sure it is! So, the + * array_size = number_of_round_bracket_pairs + 1 + */ +int slre_match(const struct slre *, const char *buf, int buf_len, + struct cap *captured_substrings); + +#ifdef SLRE_TEST +void slre_dump(const struct slre *r, FILE *fp); +#endif /* SLRE_TEST */ +#endif /* SLRE_HEADER_DEFINED */ diff --git a/lib/Makefile b/lib/Makefile index 1bfd3ee..57a1cae 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -71,6 +71,7 @@ COBJS-y += crc32.o COBJS-y += ctype.o COBJS-y += div64.o COBJS-y += linux_string.o +COBJS-$(CONFIG_REGEX) += slre.o COBJS-y += string.o COBJS-y += time.o COBJS-$(CONFIG_BOOTP_PXE) += uuid.o diff --git a/lib/slre.c b/lib/slre.c new file mode 100644 index 0000000..8cdd192 --- /dev/null +++ b/lib/slre.c @@ -0,0 +1,724 @@ +/* + * Copyright (c) 2004-2005 Sergey Lyubka valenok@gmail.com + * All rights reserved + * + * "THE BEER-WARE LICENSE" (Revision 42): + * Sergey Lyubka wrote this file. As long as you retain this notice you + * can do whatever you want with this stuff. If we meet some day, and you think + * this stuff is worth it, you can buy me a beer in return. + */ + +/* + * Downloaded Sat Nov 5 17:43:06 CET 2011 at + * http://slre.sourceforge.net/1.0/slre.c + */ + +#ifdef SLRE_TEST +#include <stdio.h> +#include <assert.h> +#include <ctype.h> +#include <stdlib.h> +#include <string.h> +#else +#include <common.h> +#include <linux/ctype.h> +#endif /* SLRE_TEST */ + +#include <errno.h> + +#include <slre.h> + +enum {END, BRANCH, ANY, EXACT, ANYOF, ANYBUT, OPEN, CLOSE, BOL, EOL, + STAR, PLUS, STARQ, PLUSQ, QUEST, SPACE, NONSPACE, DIGIT}; + +#ifdef SLRE_TEST +static struct { + const char *name; + int narg; + const char *flags; +} opcodes[] = { + {"END", 0, ""}, /* End of code block or program */ + {"BRANCH", 2, "oo"}, /* Alternative operator, "|" */ + {"ANY", 0, ""}, /* Match any character, "." */ + {"EXACT", 2, "d"}, /* Match exact string */ + {"ANYOF", 2, "D"}, /* Match any from set, "[]" */ + {"ANYBUT", 2, "D"}, /* Match any but from set, "[^]"*/ + {"OPEN ", 1, "i"}, /* Capture start, "(" */ + {"CLOSE", 1, "i"}, /* Capture end, ")" */ + {"BOL", 0, ""}, /* Beginning of string, "^" */ + {"EOL", 0, ""}, /* End of string, "$" */ + {"STAR", 1, "o"}, /* Match zero or more times "*" */ + {"PLUS", 1, "o"}, /* Match one or more times, "+" */ + {"STARQ", 1, "o"}, /* Non-greedy STAR, "*?" */ + {"PLUSQ", 1, "o"}, /* Non-greedy PLUS, "+?" */ + {"QUEST", 1, "o"}, /* Match zero or one time, "?" */ + {"SPACE", 0, ""}, /* Match whitespace, "\s" */ + {"NONSPACE", 0, ""}, /* Match non-space, "\S" */ + {"DIGIT", 0, ""} /* Match digit, "\d" */ +}; +#endif /* SLRE_TEST */ + +/* + * Commands and operands are all unsigned char (1 byte long). All code offsets + * are relative to current address, and positive (always point forward). Data + * offsets are absolute. Commands with operands: + * + * BRANCH offset1 offset2 + * Try to match the code block that follows the BRANCH instruction + * (code block ends with END). If no match, try to match code block that + * starts at offset1. If either of these match, jump to offset2. + * + * EXACT data_offset data_length + * Try to match exact string. String is recorded in data section from + * data_offset, and has length data_length. + * + * OPEN capture_number + * CLOSE capture_number + * If the user have passed 'struct cap' array for captures, OPEN + * records the beginning of the matched substring (cap->ptr), CLOSE + * sets the length (cap->len) for respective capture_number. + * + * STAR code_offset + * PLUS code_offset + * QUEST code_offset + * *, +, ?, respectively. Try to gobble as much as possible from the + * matched buffer, until code block that follows these instructions + * matches. When the longest possible string is matched, + * jump to code_offset + * + * STARQ, PLUSQ are non-greedy versions of STAR and PLUS. + */ + +static const char *meta_chars = "|.^$*+?()[\"; + +#ifdef SLRE_TEST + +static void +print_character_set(FILE *fp, const unsigned char *p, int len) +{ + int i; + + for (i = 0; i < len; i++) { + if (i > 0) + (void) fputc(',', fp); + if (p[i] == 0) { + i++; + if (p[i] == 0) + (void) fprintf(fp, "\x%02x", p[i]); + else + (void) fprintf(fp, "%s", opcodes[p[i]].name); + } else if (isprint(p[i])) { + (void) fputc(p[i], fp); + } else { + (void) fprintf(fp, "\x%02x", p[i]); + } + } +} + +void +slre_dump(const struct slre *r, FILE *fp) +{ + int i, j, ch, op, pc; + + for (pc = 0; pc < r->code_size; pc++) { + + op = r->code[pc]; + (void) fprintf(fp, "%3d %s ", pc, opcodes[op].name); + + for (i = 0; opcodes[op].flags[i] != '\0'; i++) + switch (opcodes[op].flags[i]) { + case 'i': + (void) fprintf(fp, "%d ", r->code[pc + 1]); + pc++; + break; + case 'o': + (void) fprintf(fp, "%d ", + pc + r->code[pc + 1] - i); + pc++; + break; + case 'D': + print_character_set(fp, r->data + + r->code[pc + 1], r->code[pc + 2]); + pc += 2; + break; + case 'd': + (void) fputc('"', fp); + for (j = 0; j < r->code[pc + 2]; j++) { + ch = r->data[r->code[pc + 1] + j]; + if (isprint(ch)) { + (void) fputc(ch, fp); + } else { + (void) fprintf(fp, + "\x%02x", ch); + } + } + (void) fputc('"', fp); + pc += 2; + break; + } + + (void) fputc('\n', fp); + } +} +#endif /* SLRE_TEST */ + +static void +set_jump_offset(struct slre *r, int pc, int offset) +{ + assert(offset < r->code_size); + + if (r->code_size - offset > 0xff) + r->err_str = "Jump offset is too big"; + else + r->code[pc] = (unsigned char) (r->code_size - offset); +} + +static void +emit(struct slre *r, int code) +{ + if (r->code_size >= (int) (sizeof(r->code) / sizeof(r->code[0]))) + r->err_str = "RE is too long (code overflow)"; + else + r->code[r->code_size++] = (unsigned char) code; +} + +static void +store_char_in_data(struct slre *r, int ch) +{ + if (r->data_size >= (int) sizeof(r->data)) + r->err_str = "RE is too long (data overflow)"; + else + r->data[r->data_size++] = ch; +} + +static void +exact(struct slre *r, const char **re) +{ + int old_data_size = r->data_size; + + while (**re != '\0' && (strchr(meta_chars, **re)) == NULL) + store_char_in_data(r, *(*re)++); + + emit(r, EXACT); + emit(r, old_data_size); + emit(r, r->data_size - old_data_size); +} + +static int +get_escape_char(const char **re) +{ + int res; + + switch (*(*re)++) { + case 'n': + res = '\n'; + break; + case 'r': + res = '\r'; + break; + case 't': + res = '\t'; + break; + case '0': + res = 0; + break; + case 'S': + res = NONSPACE << 8; + break; + case 's': + res = SPACE << 8; + break; + case 'd': + res = DIGIT << 8; + break; + default: + res = (*re)[-1]; + break; + } + + return res; +} + +static void +anyof(struct slre *r, const char **re) +{ + int esc, old_data_size = r->data_size, op = ANYOF; + + if (**re == '^') { + op = ANYBUT; + (*re)++; + } + + while (**re != '\0') + + switch (*(*re)++) { + case ']': + emit(r, op); + emit(r, old_data_size); + emit(r, r->data_size - old_data_size); + return; + /* NOTREACHED */ + break; + case '\': + esc = get_escape_char(re); + if ((esc & 0xff) == 0) { + store_char_in_data(r, 0); + store_char_in_data(r, esc >> 8); + } else { + store_char_in_data(r, esc); + } + break; + default: + store_char_in_data(r, (*re)[-1]); + break; + } + + r->err_str = "No closing ']' bracket"; +} + +static void +relocate(struct slre *r, int begin, int shift) +{ + emit(r, END); + memmove(r->code + begin + shift, r->code + begin, r->code_size - begin); + r->code_size += shift; +} + +static void +quantifier(struct slre *r, int prev, int op) +{ + if (r->code[prev] == EXACT && r->code[prev + 2] > 1) { + r->code[prev + 2]--; + emit(r, EXACT); + emit(r, r->code[prev + 1] + r->code[prev + 2]); + emit(r, 1); + prev = r->code_size - 3; + } + relocate(r, prev, 2); + r->code[prev] = op; + set_jump_offset(r, prev + 1, prev); +} + +static void +exact_one_char(struct slre *r, int ch) +{ + emit(r, EXACT); + emit(r, r->data_size); + emit(r, 1); + store_char_in_data(r, ch); +} + +static void +fixup_branch(struct slre *r, int fixup) +{ + if (fixup > 0) { + emit(r, END); + set_jump_offset(r, fixup, fixup - 2); + } +} + +static void +compile(struct slre *r, const char **re) +{ + int op, esc, branch_start, last_op, fixup, cap_no, level; + + fixup = 0; + level = r->num_caps; + branch_start = last_op = r->code_size; + + for (;;) + switch (*(*re)++) { + case '\0': + (*re)--; + return; + /* NOTREACHED */ + break; + case '^': + emit(r, BOL); + break; + case '$': + emit(r, EOL); + break; + case '.': + last_op = r->code_size; + emit(r, ANY); + break; + case '[': + last_op = r->code_size; + anyof(r, re); + break; + case '\': + last_op = r->code_size; + esc = get_escape_char(re); + if (esc & 0xff00) + emit(r, esc >> 8); + else + exact_one_char(r, esc); + break; + case '(': + last_op = r->code_size; + cap_no = ++r->num_caps; + emit(r, OPEN); + emit(r, cap_no); + + compile(r, re); + if (*(*re)++ != ')') { + r->err_str = "No closing bracket"; + return; + } + + emit(r, CLOSE); + emit(r, cap_no); + break; + case ')': + (*re)--; + fixup_branch(r, fixup); + if (level == 0) { + r->err_str = "Unbalanced brackets"; + return; + } + return; + /* NOTREACHED */ + break; + case '+': + case '*': + op = (*re)[-1] == '*' ? STAR : PLUS; + if (**re == '?') { + (*re)++; + op = op == STAR ? STARQ : PLUSQ; + } + quantifier(r, last_op, op); + break; + case '?': + quantifier(r, last_op, QUEST); + break; + case '|': + fixup_branch(r, fixup); + relocate(r, branch_start, 3); + r->code[branch_start] = BRANCH; + set_jump_offset(r, branch_start + 1, branch_start); + fixup = branch_start + 2; + r->code[fixup] = 0xff; + break; + default: + (*re)--; + last_op = r->code_size; + exact(r, re); + break; + } +} + +int +slre_compile(struct slre *r, const char *re) +{ + r->err_str = NULL; + r->code_size = r->data_size = r->num_caps = r->anchored = 0; + + if (*re == '^') + r->anchored++; + + emit(r, OPEN); /* This will capture what matches full RE */ + emit(r, 0); + + while (*re != '\0') + compile(r, &re); + + if (r->code[2] == BRANCH) + fixup_branch(r, 4); + + emit(r, CLOSE); + emit(r, 0); + emit(r, END); + + return (r->err_str == NULL ? 1 : 0); +} + +static int match(const struct slre *, int, + const char *, int, int *, struct cap *); + +static void +loop_greedy(const struct slre *r, int pc, const char *s, int len, int *ofs) +{ + int saved_offset, matched_offset; + + saved_offset = matched_offset = *ofs; + + while (match(r, pc + 2, s, len, ofs, NULL)) { + saved_offset = *ofs; + if (match(r, pc + r->code[pc + 1], s, len, ofs, NULL)) + matched_offset = saved_offset; + *ofs = saved_offset; + } + + *ofs = matched_offset; +} + +static void +loop_non_greedy(const struct slre *r, int pc, const char *s, int len, int *ofs) +{ + int saved_offset = *ofs; + + while (match(r, pc + 2, s, len, ofs, NULL)) { + saved_offset = *ofs; + if (match(r, pc + r->code[pc + 1], s, len, ofs, NULL)) + break; + } + + *ofs = saved_offset; +} + +static int +is_any_of(const unsigned char *p, int len, const char *s, int *ofs) +{ + int i, ch; + + ch = s[*ofs]; + + for (i = 0; i < len; i++) + if (p[i] == ch) { + (*ofs)++; + return 1; + } + + return 0; +} + +static int +is_any_but(const unsigned char *p, int len, const char *s, int *ofs) +{ + int i, ch; + + ch = s[*ofs]; + + for (i = 0; i < len; i++) { + if (p[i] == ch) + return 0; + } + + (*ofs)++; + return 1; +} + +static int +match(const struct slre *r, int pc, const char *s, int len, + int *ofs, struct cap *caps) +{ + int n, saved_offset, res = 1; + + while (res && r->code[pc] != END) { + + assert(pc < r->code_size); + assert(pc < (int) (sizeof(r->code) / sizeof(r->code[0]))); + + switch (r->code[pc]) { + case BRANCH: + saved_offset = *ofs; + res = match(r, pc + 3, s, len, ofs, caps); + if (res == 0) { + *ofs = saved_offset; + res = match(r, pc + r->code[pc + 1], + s, len, ofs, caps); + } + pc += r->code[pc + 2]; + break; + case EXACT: + res = 0; + n = r->code[pc + 2]; /* String length */ + if (n <= len - *ofs && !memcmp(s + *ofs, r->data + + r->code[pc + 1], n)) { + (*ofs) += n; + res = 1; + } + pc += 3; + break; + case QUEST: + res = 1; + saved_offset = *ofs; + if (!match(r, pc + 2, s, len, ofs, caps)) + *ofs = saved_offset; + pc += r->code[pc + 1]; + break; + case STAR: + res = 1; + loop_greedy(r, pc, s, len, ofs); + pc += r->code[pc + 1]; + break; + case STARQ: + res = 1; + loop_non_greedy(r, pc, s, len, ofs); + pc += r->code[pc + 1]; + break; + case PLUS: + res = match(r, pc + 2, s, len, ofs, caps); + if (res == 0) + break; + + loop_greedy(r, pc, s, len, ofs); + pc += r->code[pc + 1]; + break; + case PLUSQ: + res = match(r, pc + 2, s, len, ofs, caps); + if (res == 0) + break; + + loop_non_greedy(r, pc, s, len, ofs); + pc += r->code[pc + 1]; + break; + case SPACE: + res = 0; + if (*ofs < len && isspace(((unsigned char *)s)[*ofs])) { + (*ofs)++; + res = 1; + } + pc++; + break; + case NONSPACE: + res = 0; + if (*ofs < len && + !isspace(((unsigned char *)s)[*ofs])) { + (*ofs)++; + res = 1; + } + pc++; + break; + case DIGIT: + res = 0; + if (*ofs < len && isdigit(((unsigned char *)s)[*ofs])) { + (*ofs)++; + res = 1; + } + pc++; + break; + case ANY: + res = 0; + if (*ofs < len) { + (*ofs)++; + res = 1; + } + pc++; + break; + case ANYOF: + res = 0; + if (*ofs < len) + res = is_any_of(r->data + r->code[pc + 1], + r->code[pc + 2], s, ofs); + pc += 3; + break; + case ANYBUT: + res = 0; + if (*ofs < len) + res = is_any_but(r->data + r->code[pc + 1], + r->code[pc + 2], s, ofs); + pc += 3; + break; + case BOL: + res = *ofs == 0 ? 1 : 0; + pc++; + break; + case EOL: + res = *ofs == len ? 1 : 0; + pc++; + break; + case OPEN: + if (caps != NULL) + caps[r->code[pc + 1]].ptr = s + *ofs; + pc += 2; + break; + case CLOSE: + if (caps != NULL) + caps[r->code[pc + 1]].len = (s + *ofs) - + caps[r->code[pc + 1]].ptr; + pc += 2; + break; + case END: + pc++; + break; + default: + printf("unknown cmd (%d) at %d\n", r->code[pc], pc); + assert(0); + break; + } + } + + return res; +} + +int +slre_match(const struct slre *r, const char *buf, int len, + struct cap *caps) +{ + int i, ofs = 0, res = 0; + + if (r->anchored) { + res = match(r, 0, buf, len, &ofs, caps); + } else { + for (i = 0; i < len && res == 0; i++) { + ofs = i; + res = match(r, 0, buf, len, &ofs, caps); + } + } + + return res; +} + +#ifdef SLRE_TEST +#define N_CAPS 5 + +int main(int argc, char *argv[]) +{ + struct slre slre; + struct cap caps[N_CAPS]; + unsigned char data[1 * 1024 * 1024]; + FILE *fp; + int i, res, len; + + if (argc < 2) { + fprintf(stderr, "Usage: %s 'slre' <file>\n", argv[0]); + return 1; + } + + fp = fopen(argv[2], "rb"); + if (fp == NULL) { + fprintf(stderr, "Error: cannot open %s:%s\n", + argv[2], strerror(errno)); + return 1; + } + + if (!slre_compile(&slre, argv[1])) { + fprintf(stderr, "Error compiling slre: %s\n", slre.err_str); + return 1; + } + + slre_dump(&slre, stderr); + + while (fgets(data, sizeof(data), fp) != NULL) { + len = strlen(data); + + if ((len > 0) && (data[len-1] == '\n')) { + data[len-1] = '\0'; + --len; + } + + printf("Data = "%s"\n", data); + + (void) memset(caps, 0, sizeof(caps)); + + res = 0; + + res = slre_match(&slre, data, len, caps); + printf("Result [%d]: %d\n", i, res); + + for (i = 0; i < N_CAPS; i++) { + if (caps[i].len > 0) { + printf("Substring %d: len=%d [%.*s]\n", i, + caps[i].len, + caps[i].len, caps[i].ptr); + } + } + printf("----------------------------------------------------\n"); + } + (void) fclose(fp); + + return 0; +} +#endif /* SLRE_TEST */
When CONFIG_REGEX is enabled, the new option "-e" becomes available which causes regular expression matches to be used. This allows for example things like these:
etc.
Signed-off-by: Wolfgang Denk wd@denx.de --- common/cmd_nvedit.c | 29 +++++++++++++++++++++++------ include/search.h | 5 +++-- lib/hashtable.c | 29 ++++++++++++++++++++++++++--- 3 files changed, 52 insertions(+), 11 deletions(-)
diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index 441bf40..aecc803 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -163,12 +163,13 @@ static int do_env_grep(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { char *res = NULL; - int len, grep_flags; + int len, grep_how, grep_what;
- grep_flags = H_MATCH_BOTH; + grep_how = H_MATCH_SUBSTR; /* default: substring search */ + grep_what = H_MATCH_BOTH; /* default: grep names and values */
while (argc > 1 && **(argv + 1) == '-') { char *arg = *++argv; @@ -176,14 +177,19 @@ static int do_env_grep(cmd_tbl_t *cmdtp, int flag, --argc; while (*++arg) { switch (*arg) { +#ifdef CONFIG_REGEX + case 'e': /* use regex matching */ + grep_how = H_MATCH_REGEX; + break; +#endif case 'n': /* grep for name */ - grep_flags = H_MATCH_KEY; + grep_what = H_MATCH_KEY; break; case 'v': /* grep for value */ - grep_flags = H_MATCH_DATA; + grep_what = H_MATCH_DATA; break; case 'b': /* grep for both */ - grep_flags = H_MATCH_BOTH; + grep_what = H_MATCH_BOTH; break; case '-': goto DONE; @@ -195,7 +201,7 @@ static int do_env_grep(cmd_tbl_t *cmdtp, int flag,
DONE: len = hexport_r(&env_htab, '\n', - flag | grep_flags | H_MATCH_SUBSTR, + flag | grep_what | grep_how, &res, 0, argc, argv);
if (len > 0) { @@ -1132,8 +1138,12 @@ static char env_help_text[] = "env flags - print variables that have non-default flags\n" #endif #if defined(CONFIG_CMD_GREPENV) +#ifdef CONFIG_REGEX + "env grep [-e] [-n | -v | -b] string [...] - search environment\n" +#else "env grep [-n | -v | -b] string [...] - search environment\n" #endif +#endif #if defined(CONFIG_CMD_IMPORTENV) "env import [-d] [-t | -b | -c] addr [size] - import environment\n" #endif @@ -1179,8 +1189,15 @@ U_BOOT_CMD_COMPLETE( U_BOOT_CMD_COMPLETE( grepenv, CONFIG_SYS_MAXARGS, 0, do_env_grep, "search environment variables", +#ifdef CONFIG_REGEX + "[-e] [-n | -v | -b] string ...\n" +#else "[-n | -v | -b] string ...\n" +#endif " - list environment name=value pairs matching 'string'\n" +#ifdef CONFIG_REGEX + " "-e": enable regular expressions;\n" +#endif " "-n": search variable names; "-v": search values;\n" " "-b": search both names and values (default)", var_complete diff --git a/include/search.h b/include/search.h index d06a201..d9ac8df 100644 --- a/include/search.h +++ b/include/search.h @@ -129,7 +129,8 @@ extern int hwalk_r(struct hsearch_data *__htab, int (*callback)(ENTRY *)); #define H_MATCH_DATA (1 << 5) /* search/grep data = variable values */ #define H_MATCH_BOTH (H_MATCH_KEY | H_MATCH_DATA) /* search/grep both */ #define H_MATCH_IDENT (1 << 6) /* search for indentical strings */ -#define H_MATCH_SUBSTR (1 << 7) /* search for substring matches */ -#define H_MATCH_METHOD (H_MATCH_IDENT | H_MATCH_SUBSTR) +#define H_MATCH_SUBSTR (1 << 7) /* search for substring matches */ +#define H_MATCH_REGEX (1 << 8) /* search for regular expression matches */ +#define H_MATCH_METHOD (H_MATCH_IDENT | H_MATCH_SUBSTR | H_MATCH_REGEX)
#endif /* search.h */ diff --git a/lib/hashtable.c b/lib/hashtable.c index 8ad56ec..e0d3a19 100644 --- a/lib/hashtable.c +++ b/lib/hashtable.c @@ -57,6 +57,7 @@ #include <env_callback.h> #include <env_flags.h> #include <search.h> +#include <slre.h>
/* * [Aho,Sethi,Ullman] Compilers: Principles, Techniques and Tools, 1986 @@ -540,7 +541,7 @@ static int cmpkey(const void *p1, const void *p2) return (strcmp(e1->key, e2->key)); }
-static int match_string(int flag, const char * str, const char * pat) +static int match_string(int flag, const char *str, const char *pat, void *priv) { switch (flag & H_MATCH_METHOD) { case H_MATCH_IDENT: @@ -551,6 +552,17 @@ static int match_string(int flag, const char * str, const char * pat) if (strstr(str, pat)) return 1; break; +#ifdef CONFIG_REGEX + case H_MATCH_REGEX: + { + struct slre *slrep = (struct slre *)priv; + struct cap caps[slrep->num_caps + 2]; + + if (slre_match(slrep, str, strlen(str), caps)) + return 1; + } + break; +#endif default: printf("## ERROR: unsupported match method: 0x%02x\n", flag & H_MATCH_METHOD); @@ -563,14 +575,25 @@ static int match_entry(ENTRY *ep, int flag, int argc, char * const argv[]) { int arg; + void *priv = NULL;
for (arg = 1; arg < argc; ++arg) { +#ifdef CONFIG_REGEX + struct slre slre; + + if (slre_compile(&slre, argv[arg]) == 0) { + printf("Error compiling regex: %s\n", slre.err_str); + return 0; + } + + priv = (void *)&slre; +#endif if (flag & H_MATCH_KEY) { - if (match_string(flag, ep->key, argv[arg])) + if (match_string(flag, ep->key, argv[arg], priv)) return 1; } if (flag & H_MATCH_DATA) { - if (match_string(flag, ep->data, argv[arg])) + if (match_string(flag, ep->data, argv[arg], priv)) return 1; } }
Simplify the argument checking for the "setexpr" command. This is done mainly to make future extensions easier.
Also improve the help message for the one argument version of the command - this does not "load an address", but a value, which in this context may be a plain number or a pointer dereference.
Signed-off-by: Wolfgang Denk wd@denx.de --- common/cmd_setexpr.c | 18 +++++++++++------- 1 file changed, 11 insertions(+), 7 deletions(-)
diff --git a/common/cmd_setexpr.c b/common/cmd_setexpr.c index 7a38e94..ccd87f4 100644 --- a/common/cmd_setexpr.c +++ b/common/cmd_setexpr.c @@ -56,22 +56,26 @@ static int do_setexpr(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) ulong value; int w;
- /* Validate arguments */ - if (argc != 5 && argc != 3) - return CMD_RET_USAGE; - if (argc == 5 && strlen(argv[3]) != 1) + if (argc < 3) return CMD_RET_USAGE;
w = cmd_get_data_size(argv[0], 4);
a = get_arg(argv[2], w);
+ /* plain assignment: "setexpr name value" */ if (argc == 3) { setenv_hex(argv[1], a); - return 0; }
+ /* standard operators: "setexpr name val1 op val2" */ + if (argc != 5) + return CMD_RET_USAGE; + + if (strlen(argv[3]) != 1) + return CMD_RET_USAGE; + b = get_arg(argv[4], w);
switch (argv[3][0]) { @@ -117,6 +121,6 @@ U_BOOT_CMD( " express specified by <op>. <op> can be &, |, ^, +, -, *, /, %\n" " size argument is only meaningful if value1 and/or value2 are\n" " memory addresses (*)\n" - "setexpr[.b, .w, .l] name *value\n" - " - load a memory address into a variable" + "setexpr[.b, .w, .l] name [*]value\n" + " - load a value into a variable" );
Add "setexpr name gsub r s [t]" and "setexpr name sub r s [t]" commands which implement substring matching for the regular expression <r> in the string <t>, and substitution of the string <s>. The result is assigned to the environment variable <name>. If <t> is not supplied, the previous value of <name> is used instead. "gsub" performs global substitution, while "sub" will replace only the first substring.
Both commands are closely modeled after the gawk functions with the same names.
Examples:
- Do the same, but substitute one step at a time in a loop until no futher matches:
=> setenv ethaddr C0>E5>4E>02>06>DC => while setexpr ethaddr sub > : > do > echo ----- > done ethaddr=C0:E5>4E>02>06>DC ----- ethaddr=C0:E5:4E>02>06>DC ----- ethaddr=C0:E5:4E:02>06>DC ----- ethaddr=C0:E5:4E:02:06>DC ----- ethaddr=C0:E5:4E:02:06:DC ----- C0:E5:4E:02:06:DC: No match => print ethaddr ethaddr=C0:E5:4E:02:06:DC
etc.
To enable this feature, the CONFIG_REGEX option has to be defined in the board config file.
Signed-off-by: Wolfgang Denk wd@denx.de --- common/cmd_setexpr.c | 280 ++++++++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 277 insertions(+), 3 deletions(-)
diff --git a/common/cmd_setexpr.c b/common/cmd_setexpr.c index ccd87f4..bfeec29 100644 --- a/common/cmd_setexpr.c +++ b/common/cmd_setexpr.c @@ -1,5 +1,6 @@ /* * Copyright 2008 Freescale Semiconductor, Inc. + * Copyright 2013 Wolfgang Denk wd@denx.de * * See file CREDITS for list of people who contributed to this * project. @@ -50,13 +51,263 @@ static ulong get_arg(char *s, int w) } }
+#ifdef CONFIG_REGEX + +#include <slre.h> + +#define SLRE_BUFSZ 16384 +#define SLRE_PATSZ 4096 + +/* + * memstr - Find the first substring in memory + * @s1: The string to be searched + * @s2: The string to search for + * + * Similar to and based on strstr(), + * but strings do not need to be NUL terminated. + */ +static char *memstr(const char *s1, int l1, const char *s2, int l2) +{ + if (!l2) + return (char *) s1; + + while (l1 >= l2) { + l1--; + if (!memcmp(s1, s2, l2)) + return (char *) s1; + s1++; + } + return NULL; +} + +static char *substitute(char *string, /* string buffer */ + int *slen, /* current string length */ + int ssize, /* string bufer size */ + const char *old,/* old (replaced) string */ + int olen, /* length of old string */ + const char *new,/* new (replacement) string */ + int nlen) /* length of new string */ +{ + char *p = memstr(string, *slen, old, olen); + + if (p == NULL) + return NULL; + + debug("## Match at pos %ld: match len %d, subst len %d\n", + (long)(p - string), olen, nlen); + + /* make sure replacement matches */ + if (*slen + nlen - olen > ssize) { + printf("## error: substitution buffer overflow\n"); + return NULL; + } + + /* move tail if needed */ + if (olen != nlen) { + int tail, len; + + len = (olen > nlen) ? olen : nlen; + + tail = ssize - (p + len - string); + + debug("## tail len %d\n", tail); + + memmove(p + nlen, p + olen, tail); + } + + /* insert substitue */ + memcpy(p, new, nlen); + + *slen += nlen - olen; + + return p + nlen; +} + +/* + * Perform regex operations on a environment variable + * + * Returns 0 if OK, 1 in case of errors. + */ +static int regex_sub(const char *name, + const char *r, const char *s, const char *t, + int global) +{ + struct slre slre; + char data[SLRE_BUFSZ]; + char *datap = data; + const char *value; + int res, len, nlen, loop; + + if (name == NULL) + return 1; + + if (slre_compile(&slre, r) == 0) { + printf("Error compiling regex: %s\n", slre.err_str); + return 1; + } + + if (t == NULL) { + value = getenv(name); + + if (value == NULL) { + printf("## Error: variable "%s" not defined\n", name); + return 1; + } + t = value; + } + + debug("REGEX on %s=%s\n", name, t); + debug("REGEX="%s", SUBST="%s", GLOBAL=%d\n", + r, s ? s : "<NULL>", global); + + len = strlen(t); + if (len + 1 > SLRE_BUFSZ) { + printf("## error: subst buffer overflow: have %d, need %d\n", + SLRE_BUFSZ, len + 1); + return 1; + } + + strcpy(data, t); + + if (s == NULL) + nlen = 0; + else + nlen = strlen(s); + + for (loop = 0; ;loop++) { + struct cap caps[slre.num_caps + 2]; + char nbuf[SLRE_PATSZ]; + const char *old; + char *np; + int i, olen; + + (void) memset(caps, 0, sizeof(caps)); + + res = slre_match(&slre, datap, len, caps); + + debug("Result: %d\n", res); + + for (i = 0; i < slre.num_caps; i++) { + if (caps[i].len > 0) { + debug("Substring %d: [%.*s]\n", i, + caps[i].len, caps[i].ptr); + } + } + + if (res == 0) { + if (loop == 0) { + printf("%s: No match\n", t); + return 1; + } else { + break; + } + } + + debug("## MATCH ## %s\n", data); + + if (s == NULL) { + printf("%s=%s\n", name, t); + return 1; + } + + old = caps[0].ptr; + olen = caps[0].len; + + if (nlen + 1 >= SLRE_PATSZ) { + printf("## error: pattern buffer overflow: have %d, need %d\n", + SLRE_BUFSZ, nlen + 1); + return 1; + } + strcpy(nbuf, s); + + debug("## SUBST(1) ## %s\n", nbuf); + + /* + * Handle back references + * + * Support for \0 ... \9, where \0 is the + * whole matched pattern (similar to &). + * + * Implementation is a bit simpleminded as + * backrefs are substituted sequentially, one + * by one. This will lead to somewhat + * unexpected results if the replacement + * strings contain any \N strings then then + * may get substitued, too. We accept this + * restriction for the sake of simplicity. + */ + for (i = 0; i < 10; ++i) { + char backref[2] = { + '\', + '0', + }; + + if (caps[i].len == 0) + break; + + backref[1] += i; + + debug("## BACKREF %d: replace "%.*s" by "%.*s" in "%s"\n", + i, + 2, backref, + caps[i].len, caps[i].ptr, + nbuf); + + for (np = nbuf;;) { + char *p = memstr(np, nlen, backref, 2); + + if (p == NULL) + break; + + np = substitute(np, &nlen, + SLRE_PATSZ, + backref, 2, + caps[i].ptr, caps[i].len); + + if (np == NULL) + return 1; + } + } + debug("## SUBST(2) ## %s\n", nbuf); + + datap = substitute(datap, &len, SLRE_BUFSZ, + old, olen, + nbuf, nlen); + + if (datap == NULL) + return 1; + + debug("## REMAINDER: %s\n", datap); + + debug("## RESULT: %s\n", data); + + if (!global) + break; + } + debug("## FINAL (now setenv()) : %s\n", data); + + printf("%s=%s\n", name, data); + + return setenv(name, data); +} +#endif + static int do_setexpr(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { ulong a, b; ulong value; int w;
- if (argc < 3) + /* + * We take 3, 5, or 6 arguments: + * 3 : setexpr name value + * 5 : setexpr name val1 op val2 + * setexpr name [g]sub r s + * 6 : setexpr name [g]sub r s t + */ + + /* > 6 already tested by max command args */ + if ((argc < 3) || (argc == 4)) return CMD_RET_USAGE;
w = cmd_get_data_size(argv[0], 4); @@ -69,6 +320,19 @@ static int do_setexpr(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 0; }
+ /* 5 or 6 args (6 args only with [g]sub) */ +#ifdef CONFIG_REGEX + /* + * rexep handling: "setexpr name [g]sub r s [t]" + * with 5 args, "t" will be NULL + */ + if (strcmp(argv[2], "gsub") == 0) + return regex_sub(argv[1], argv[3], argv[4], argv[5], 1); + + if (strcmp(argv[2], "sub") == 0) + return regex_sub(argv[1], argv[3], argv[4], argv[5], 0); +#endif + /* standard operators: "setexpr name val1 op val2" */ if (argc != 5) return CMD_RET_USAGE; @@ -114,13 +378,23 @@ static int do_setexpr(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) }
U_BOOT_CMD( - setexpr, 5, 0, do_setexpr, + setexpr, 6, 0, do_setexpr, "set environment variable as the result of eval expression", "[.b, .w, .l] name [*]value1 <op> [*]value2\n" " - set environment variable 'name' to the result of the evaluated\n" - " express specified by <op>. <op> can be &, |, ^, +, -, *, /, %\n" + " expression specified by <op>. <op> can be &, |, ^, +, -, *, /, %\n" " size argument is only meaningful if value1 and/or value2 are\n" " memory addresses (*)\n" "setexpr[.b, .w, .l] name [*]value\n" " - load a value into a variable" +#ifdef CONFIG_REGEX + "\n" + "setexpr name gsub r s [t]\n" + " - For each substring matching the regular expression <r> in the\n" + " string <t>, substitute the string <s>. The result is\n" + " assigned to <name>. If <t> is not supplied, use the old\n" + " value of <name>\n" + "setexpr name sub r s [t]\n" + " - Just like gsub(), but replace only the first matching substring" +#endif );
Dear Wolfgang Denk,
- if (!l2)
return (char *) s1;
- while (l1 >= l2) {
l1--;
return (char *) s1;
s1++;
- return NULL;
Will this memstr() not crash with wrong parameters? Or is this safe?
btw. there is a checkpatch issue and two warnings: ERROR: space required after that ';' (ctx:WxV) #294: FILE: common/cmd_setexpr.c:177: + for (loop = 0; ;loop++) { ^
I think the warnings are ok.
Best regards, Marek Vasut
Dear Marek,
- if (!l2)
return (char *) s1;
l1--;
return (char *) s1;
s1++;
- return NULL;
I'm not sure thwat you mean by "will it crash" / "is this safe"?
Of course you can pass bogus parameters that will cause issues - in the very same way as you can do it with existing standard functions like memcmp() or strstr().
Or do you see any specific problems in above code.
Will fix that (though I'm not sure if the result is easier to read).
Signed-off-by: Wolfgang Denk wd@denx.de Cc: Marek Vasut marek.vasut@gmail.com --- include/configs/m28evk.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/configs/m28evk.h b/include/configs/m28evk.h index f2725cc..4540bf0 100644 --- a/include/configs/m28evk.h +++ b/include/configs/m28evk.h @@ -65,6 +65,7 @@ #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT #define CONFIG_CMD_GPIO +#define CONFIG_CMD_GREPENV #define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_MMC @@ -77,6 +78,8 @@ #define CONFIG_CMD_SPI #define CONFIG_CMD_USB
+#define CONFIG_REGEX /* Enable regular expression support */ + /* * Memory configurations */
Signed-off-by: Wolfgang Denk wd@denx.de Cc: Stefan Roese sr@denx.de --- include/configs/amcc-common.h | 9 ++++++--- 1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/include/configs/amcc-common.h b/include/configs/amcc-common.h index f2f522d..80e5735 100644 --- a/include/configs/amcc-common.h +++ b/include/configs/amcc-common.h @@ -71,6 +71,7 @@ #define CONFIG_CMD_DIAG #define CONFIG_CMD_EEPROM #define CONFIG_CMD_ELF +#define CONFIG_CMD_GREPENV #define CONFIG_CMD_I2C #define CONFIG_CMD_IRQ #define CONFIG_CMD_MII @@ -78,6 +79,7 @@ #define CONFIG_CMD_NFS #define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO +#define CONFIG_CMD_SETEXPR
/* * Miscellaneous configurable options @@ -108,13 +110,14 @@ #define CONFIG_MX_CYCLIC /* enable mdc/mwc commands */ #define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ #define CONFIG_VERSION_VARIABLE /* include version env variable */ -#define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup*/ +#define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup*/
-#define CONFIG_SYS_HUSH_PARSER /* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER /* Use the HUSH parser */
#define CONFIG_LOADS_ECHO /* echo on for serial download */ -#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
+#define CONFIG_REGEX /* Enable regular expression support */ /* * BOOTP options */
I should probably add:
- This patch series has been compile-tested (and found to be clean with ELDK v5.3) on all of the following boards:
ARM: m28evk
PPC4xx: acadia bamboo bluestone bubinga canyonlands dlvision-10g dlvision ebony gdppc440etx icon intip io io64 iocon katmai kilauea luan makalu neo ocotea redwood sequoia t3corp taihu taishan walnut yosemite yucca
- Runtime / functional testing has been done mostly on PPC (Sequoia board).
It is awesome :-)
I just found some indenting formating changing in the code mixed with code change, it'd be good to keep those in specific patches. It is easy to see in the last patch of serie, for example.
-- Otavio Salvador O.S. Systems E-mail: otavio@ossystems.com.br http://www.ossystems.com.br Mobile: +55 53 9981-7854 http://projetos.ossystems.com.br
Dear Otavio,
In message CAP9ODKoDSwBRp7sweLwX-7LrQyeHaq0JP1fhe2GJ86E=_ev0fA@mail.gmail.com you wrote:
It is awesome :-)
I'm glad you like it.
Yes, I will do this. Thanks!
Dear Gerlando Falauto,
In message 1319647072-17504-1-git-send-email-gerlando.falauto@keymile.com you wrote:
This is a resubmission (after removing remove checkpatch errors) of http://lists.denx.de/pipermail/u-boot/2011-September/102875.html
Here I am proposing a set of changes in the behaviour of the environment import/set_to_default functions.
PATCH 1: Add a "new" himport_ex() function (reworking of himport_r which is now a wrapper around it), which has 3 new arguments:
"nvars", "vars":, number and list of variables to take into account (0 means ALL)
"apply" callback function which is in charge of checking whether a variable can be overwritten, and possibly immediately apply the changes. This parameter would be either set to NULL (in which case nothing should change wrt to the past -- i.e. environment is blindly imported) or to "env_check_apply()" function, whose code was taken away from _do_env_set(). This would be useful, for instance, for "baudrate" or "stdin,stderr,stdout", whose changes would not otherwise be effective until the next reboot.
The idea is that there should be a single place where all the checks are to be performed. So the same function env_check_apply() is called from _do_env_set() as well (thus keeping the previous behavior).
Would you please also update the help messages for the respective commands so we can see their correct (new) usage there?
Thanks.
Hmmm.... I wonder how much testing you did. For me, env import is broken now.
In
message1319647072-17504-1-git-send-email-gerlando.falauto@keymile.com you wrote:
I tested "env import" with and without -n. Same for "env default". Also tested special variables.
I am not able to see how it's obviously broken. Perhaps you mean that when you don't provide an argument to -n, the following argument (e.g., -t) is interpreted as a variable name (and therefore consumed)? That doesn't look like an error to me. Could you please elaborate and/or provide a test case?
Thank you, Gerlando Falauto
It just didn't work for me.
Yes, this is a serious bug. Aor design problem.
The whole interface is wrong. I have just extendend "env export" to do a similar thing. The new syntax is:
env export [-t | -b | -c] [-s size] addr [var ...]
We should do exactly the same for "env import", i. e. make the size parameter an option to be passed with "-s size", and pass the names of any variables to import as additional arguments:
env import [-t | -b | -c] [-s size] addr [var ...]
This also greatly simplifies the implementation.
Honestly, I didn't try it against the latest master branch.
When/where? I can't see that in the latest master branch.
Totally agree. Question is: won't that break all the existing scripts???
If you agree, I can post an updated patch with the same behavior for import. Although I am bit concerned about our scripts.
Best, Gerlando Falauto
Dear Gerlando,
Ah, I didn't actually send it yet. Done now.
Yes. It _is_ an incompatible change of the API. I hate it, but mostly because I didn't chose such a format right from the beginning.
My hope is that probably not too many people use these features in scripts - at least so far it's only omap3_beagle and omap3_mvblx that use "env import -t $loadaddr $filesize". It is IMO better to change this now, instead of waiting until we have more users and the problem hits us in another place, hard.
We would fix these, too.
But agreed, incompatible API changes are always a bad thing.
we use it too in keymile-common.h and in the scripts we load with this command e.g. board/keymile/scripts/develop-ppc_82xx.txt
The resulting incompatibility is indeed not very nice. I don't see big issues for the command line and keymile-common.h where we can live with different API for different u-boot versions. But the usage in the scripts directory is more complicated, because then we have to make sure that uboot version x loads scripts x and u-boot version y loads scripts y. Ok we could prepare a second scripts directory e.g. "scripts_v2" or similar in addition to the current scripts directory in tftpboot, but this is not very nice.
Best regards Holger
participants (7)
Detlev Zundel
Gerlando Falauto
Holger Brunck
Otavio Salvador
Scott Wood
