[PATCH] board: starfive: handle compatible property in dynamic DT configuration
The difference between the StarFive VisionFive 2 1.2A and 1.3B boards is handled dynamically by looking at the PCB version in the EEPROM in order to have a single u-boot version for both versions of the board. While the "model" property is correctly handled, the "compatible" one is always the the one of version 1.3b.
This patch add support for dynamically configuring that property.
Fixes: 9b7060bd15e7 ("riscv: dts: jh7110: Combine the board device tree files of 1.2A and 1.3B")
Signed-off-by: Aurelien Jarno aurelien@aurel32.net --- board/starfive/visionfive2/spl.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/starfive/visionfive2/spl.c b/board/starfive/visionfive2/spl.c index 336f0cdfc9..911add429d 100644 --- a/board/starfive/visionfive2/spl.c +++ b/board/starfive/visionfive2/spl.c @@ -61,11 +61,13 @@ static const struct starfive_vf2_pro starfive_verb[] = {
void spl_fdt_fixup_version_a(void *fdt) { + static const char compat[] = "starfive,visionfive-2-v1.2a\0starfive,jh7110"; u32 phandle; u8 i; int offset; int ret;
+ fdt_setprop(fdt, fdt_path_offset(fdt, "/"), "compatible", compat, sizeof(compat)); fdt_setprop_string(fdt, fdt_path_offset(fdt, "/"), "model", "StarFive VisionFive 2 v1.2A");
@@ -106,11 +108,13 @@ void spl_fdt_fixup_version_a(void *fdt)
void spl_fdt_fixup_version_b(void *fdt) { + static const char compat[] = "starfive,visionfive-2-v1.3b\0starfive,jh7110"; u32 phandle; u8 i; int offset; int ret;
+ fdt_setprop(fdt, fdt_path_offset(fdt, "/"), "compatible", compat, sizeof(compat)); fdt_setprop_string(fdt, fdt_path_offset(fdt, "/"), "model", "StarFive VisionFive 2 v1.3B");
Gentle ping. Note that the maintainer address bounces, I am not sure it is still valid. Thanks
-- 2.42.0
Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com
Aurelien Jarno
Leo Liang
