[U-Boot] error when building env
when trying to build env with "-mfloat-abi=hard" I'm hitting this error:
/opt/openwrt/trunk/staging_dir/toolchain-arm_cortex-a9+neon_gcc-4.8-linaro_uClibc-0.9.33.2_eabi/bin/arm-openwrt-linux-uclibcgnueabi-gcc -o tools/env/fw_printenv_unstripped tools/env/fw_env.o tools/env/fw_env_main.o tools/env/crc32.o tools/env/ctype.o tools/env/linux_string.o tools/env/env_attr.o tools/env/env_flags.o tools/env/aes.o /opt/build/owrt_staging_dir/toolchain-arm_cortex-a9+neon_gcc-4.8-linaro_uClibc-0.9.33.2_eabi/bin/../lib/gcc/arm-openwrt-linux-uclibcgnueabi/4.8.3/../../../../arm-openwrt-linux-uclibcgnueabi/bin/ld: error: tools/env/fw_printenv_unstripped uses VFP register arguments, tools/env/fw_env.o does not /opt/build/owrt_staging_dir/toolchain-arm_cortex-a9+neon_gcc-4.8-linaro_uClibc-0.9.33.2_eabi/bin/../lib/gcc/arm-openwrt-linux-uclibcgnueabi/4.8.3/../../../../arm-openwrt-linux-uclibcgnueabi/bin/ld: failed to merge target specific data of file tools/env/fw_env.o /opt/build/owrt_staging_dir/toolchain-arm_cortex-a9+neon_gcc-4.8-linaro_uClibc-0.9.33.2_eabi/bin/../lib/gcc/arm-openwrt-linux-uclibcgnueabi/4.8.3/../../../../arm-openwrt-linux-uclibcgnueabi/bin/ld: error: tools/env/fw_printenv_unstripped uses VFP register arguments, tools/env/fw_env_main.o does not /opt/build/owrt_staging_dir/toolchain-arm_cortex-a9+neon_gcc-4.8-linaro_uClibc-0.9.33.2_eabi/bin/../lib/gcc/arm-openwrt-linux-uclibcgnueabi/4.8.3/../../../../arm-openwrt-linux-uclibcgnueabi/bin/ld: failed to merge target specific data of file tools/env/fw_env_main.o /opt/build/owrt_staging_dir/toolchain-arm_cortex-a9+neon_gcc-4.8-linaro_uClibc-0.9.33.2_eabi/bin/../lib/gcc/arm-openwrt-linux-uclibcgnueabi/4.8.3/../../../../arm-openwrt-linux-uclibcgnueabi/bin/ld: error: tools/env/fw_printenv_unstripped uses VFP register arguments, tools/env/crc32.o does not /opt/build/owrt_staging_dir/toolchain-arm_cortex-a9+neon_gcc-4.8-linaro_uClibc-0.9.33.2_eabi/bin/../lib/gcc/arm-openwrt-linux-uclibcgnueabi/4.8.3/../../../../arm-openwrt-linux-uclibcgnueabi/bin/ld: failed to merge target specific data of file tools/env/crc32.o /opt/build/owrt_staging_dir/toolchain-arm_cortex-a9+neon_gcc-4.8-linaro_uClibc-0.9.33.2_eabi/bin/../lib/gcc/arm-openwrt-linux-uclibcgnueabi/4.8.3/../../../../arm-openwrt-linux-uclibcgnueabi/bin/ld: error: tools/env/fw_printenv_unstripped uses VFP register arguments, tools/env/ctype.o does not /opt/build/owrt_staging_dir/toolchain-arm_cortex-a9+neon_gcc-4.8-linaro_uClibc-0.9.33.2_eabi/bin/../lib/gcc/arm-openwrt-linux-uclibcgnueabi/4.8.3/../../../../arm-openwrt-linux-uclibcgnueabi/bin/ld: failed to merge target specific data of file tools/env/ctype.o /opt/build/owrt_staging_dir/toolchain-arm_cortex-a9+neon_gcc-4.8-linaro_uClibc-0.9.33.2_eabi/bin/../lib/gcc/arm-openwrt-linux-uclibcgnueabi/4.8.3/../../../../arm-openwrt-linux-uclibcgnueabi/bin/ld: error: tools/env/fw_printenv_unstripped uses VFP register arguments, tools/env/linux_string.o does not /opt/build/owrt_staging_dir/toolchain-arm_cortex-a9+neon_gcc-4.8-linaro_uClibc-0.9.33.2_eabi/bin/../lib/gcc/arm-openwrt-linux-uclibcgnueabi/4.8.3/../../../../arm-openwrt-linux-uclibcgnueabi/bin/ld: failed to merge target specific data of file tools/env/linux_string.o /opt/build/owrt_staging_dir/toolchain-arm_cortex-a9+neon_gcc-4.8-linaro_uClibc-0.9.33.2_eabi/bin/../lib/gcc/arm-openwrt-linux-uclibcgnueabi/4.8.3/../../../../arm-openwrt-linux-uclibcgnueabi/bin/ld: error: tools/env/fw_printenv_unstripped uses VFP register arguments, tools/env/env_attr.o does not /opt/build/owrt_staging_dir/toolchain-arm_cortex-a9+neon_gcc-4.8-linaro_uClibc-0.9.33.2_eabi/bin/../lib/gcc/arm-openwrt-linux-uclibcgnueabi/4.8.3/../../../../arm-openwrt-linux-uclibcgnueabi/bin/ld: failed to merge target specific data of file tools/env/env_attr.o /opt/build/owrt_staging_dir/toolchain-arm_cortex-a9+neon_gcc-4.8-linaro_uClibc-0.9.33.2_eabi/bin/../lib/gcc/arm-openwrt-linux-uclibcgnueabi/4.8.3/../../../../arm-openwrt-linux-uclibcgnueabi/bin/ld: error: tools/env/fw_printenv_unstripped uses VFP register arguments, tools/env/env_flags.o does not /opt/build/owrt_staging_dir/toolchain-arm_cortex-a9+neon_gcc-4.8-linaro_uClibc-0.9.33.2_eabi/bin/../lib/gcc/arm-openwrt-linux-uclibcgnueabi/4.8.3/../../../../arm-openwrt-linux-uclibcgnueabi/bin/ld: failed to merge target specific data of file tools/env/env_flags.o /opt/build/owrt_staging_dir/toolchain-arm_cortex-a9+neon_gcc-4.8-linaro_uClibc-0.9.33.2_eabi/bin/../lib/gcc/arm-openwrt-linux-uclibcgnueabi/4.8.3/../../../../arm-openwrt-linux-uclibcgnueabi/bin/ld: error: tools/env/fw_printenv_unstripped uses VFP register arguments, tools/env/aes.o does not
When env is built with "-mfloat-abi=soft" everything is fine. Has this been triggered by anyone else?
Thanks!
Luka
Odd. I can build 'tools-only' with my hard float toolchain fine. Can you build with V=1 and see what files are perhaps not getting passed in a -mfloat option?
Hi Tom,
The patch below fixes the problem I was having. Is that good enough for proper patch submission?
With it I am able to use replace default HOSTCFLAGS with what was defined in TARGET_CFLAGS.
Luka
diff --git a/tools/env/Makefile b/tools/env/Makefile index f5368bc..4de1d51 100644 --- a/tools/env/Makefile +++ b/tools/env/Makefile @@ -10,6 +10,10 @@ # with "CC" here for the maximum code reuse of scripts/Makefile.host. HOSTCC = $(CC)
+ifneq ($(TARGET_CFLAGS),) +HOSTCFLAGS = $(TARGET_CFLAGS) +endif + # Compile for a hosted environment on the target HOST_EXTRACFLAGS = $(patsubst -I%,-idirafter%, $(UBOOTINCLUDE)) \ -idirafter $(srctree)/tools/env \
On Mon, May 19, 2014 at 02:14:03PM +0200, Luka Perkov wrote:
Hi Tom,
Luka
This still seems odd. Masahiro?
Hi Tom,
Luka
Yes is seems odd indeed, shouldn't it be unconditionally be part of the CROSS_BUILD_TOOLS check below? Since it switches compiler, but not related flags..
Regards, Jeroen
Hi Luka, Tom,
Hi Tom,
Luka
Looks odd to me.
According to Luka's build log, he is trying to compile the C sources with hard float, but link them against soft float library.
In my understanding, consistency should be kept between compile and link stage by the compiler as is . We don't have to tweak HOSTCFLAGS from the outside.
Best Regards Masahiro Yamada
Hi Masahiro,
Luka
Looks odd to me.
Back when I was debugging this I've seen that in main Makefile this line is defined:
HOSTCFLAGS = -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer
I needed to replace it to whatever I have defined in TARGET_CFLAGS, thus I've proposed the patch above.
It's not a problem to keep this workaround externally, I thought others were hitting this problem as well.
Luka
Jeroen Hofstee
Luka Perkov
Masahiro Yamada
