[U-Boot] [PATCH v4] rtc: Add DM support to ds3231
Add an implementation of the ds3231 driver that uses the driver model i2c APIs.
Signed-off-by: Chuanhua Han chuanhua.han@nxp.com --- Changes in v4: - Delete the original 'rel' variable in the ds3231_rtc_get function, return 0 successfully, and return -EINVAL directly when the RTC oscillator is stopped. Changes in v3: - Update copyright information. Changes in v2: - Replace "#ifndef CONFIG_DM_RTC" with "#if !CONFIG_IS_ENABLED(DM_RTC)".
drivers/rtc/ds3231.c | 107 +++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 107 insertions(+)
diff --git a/drivers/rtc/ds3231.c b/drivers/rtc/ds3231.c index 9352ff87a2..79b026af4b 100644 --- a/drivers/rtc/ds3231.c +++ b/drivers/rtc/ds3231.c @@ -2,6 +2,9 @@ /* * (C) Copyright 2006 * Markus Klotzbuecher, mk@denx.de + * + * (C) Copyright 2019 NXP + * Chuanhua Han chuanhua.han@nxp.com */
/* @@ -13,6 +16,7 @@
#include <common.h> #include <command.h> +#include <dm.h> #include <rtc.h> #include <i2c.h>
@@ -50,6 +54,7 @@ #define RTC_STAT_BIT_EN32KHZ 0x8 /* Enable 32KHz Output */
+#if !CONFIG_IS_ENABLED(DM_RTC) static uchar rtc_read (uchar reg); static void rtc_write (uchar reg, uchar val);
@@ -164,3 +169,105 @@ static void rtc_write (uchar reg, uchar val) { i2c_reg_write (CONFIG_SYS_I2C_RTC_ADDR, reg, val); } +#else +static int ds3231_rtc_get(struct udevice *dev, struct rtc_time *tmp) +{ + uchar sec, min, hour, mday, wday, mon_cent, year, status; + + status = dm_i2c_reg_read(dev, RTC_STAT_REG_ADDR); + sec = dm_i2c_reg_read(dev, RTC_SEC_REG_ADDR); + min = dm_i2c_reg_read(dev, RTC_MIN_REG_ADDR); + hour = dm_i2c_reg_read(dev, RTC_HR_REG_ADDR); + wday = dm_i2c_reg_read(dev, RTC_DAY_REG_ADDR); + mday = dm_i2c_reg_read(dev, RTC_DATE_REG_ADDR); + mon_cent = dm_i2c_reg_read(dev, RTC_MON_REG_ADDR); + year = dm_i2c_reg_read(dev, RTC_YR_REG_ADDR); + + if (status & RTC_STAT_BIT_OSF) { + printf("### Warning: RTC oscillator has stopped\n"); + /* clear the OSF flag */ + dm_i2c_reg_write(dev, RTC_STAT_REG_ADDR, + dm_i2c_reg_read(dev, RTC_STAT_REG_ADDR) + & ~RTC_STAT_BIT_OSF); + return -EINVAL; + } + + tmp->tm_sec = bcd2bin(sec & 0x7F); + tmp->tm_min = bcd2bin(min & 0x7F); + tmp->tm_hour = bcd2bin(hour & 0x3F); + tmp->tm_mday = bcd2bin(mday & 0x3F); + tmp->tm_mon = bcd2bin(mon_cent & 0x1F); + tmp->tm_year = bcd2bin(year) + ((mon_cent & 0x80) ? 2000 : 1900); + tmp->tm_wday = bcd2bin((wday - 1) & 0x07); + tmp->tm_yday = 0; + tmp->tm_isdst = 0; + + debug("Get DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", + tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, + tmp->tm_hour, tmp->tm_min, tmp->tm_sec); + + return 0; +} + +static int ds3231_rtc_set(struct udevice *dev, const struct rtc_time *tmp) +{ + uchar century; + + debug("Set DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", + tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, + tmp->tm_hour, tmp->tm_min, tmp->tm_sec); + + dm_i2c_reg_write(dev, RTC_YR_REG_ADDR, bin2bcd(tmp->tm_year % 100)); + + century = (tmp->tm_year >= 2000) ? 0x80 : 0; + dm_i2c_reg_write(dev, RTC_MON_REG_ADDR, bin2bcd(tmp->tm_mon) | century); + + dm_i2c_reg_write(dev, RTC_DAY_REG_ADDR, bin2bcd(tmp->tm_wday + 1)); + dm_i2c_reg_write(dev, RTC_DATE_REG_ADDR, bin2bcd(tmp->tm_mday)); + dm_i2c_reg_write(dev, RTC_HR_REG_ADDR, bin2bcd(tmp->tm_hour)); + dm_i2c_reg_write(dev, RTC_MIN_REG_ADDR, bin2bcd(tmp->tm_min)); + dm_i2c_reg_write(dev, RTC_SEC_REG_ADDR, bin2bcd(tmp->tm_sec)); + + return 0; +} + +static int ds3231_rtc_reset(struct udevice *dev) +{ + int ret; + + ret = dm_i2c_reg_write(dev, RTC_CTL_REG_ADDR, + RTC_CTL_BIT_RS1 | RTC_CTL_BIT_RS2); + if (ret < 0) + return ret; + + return 0; +} + +static int ds3231_probe(struct udevice *dev) +{ + i2c_set_chip_flags(dev, DM_I2C_CHIP_RD_ADDRESS | + DM_I2C_CHIP_WR_ADDRESS); + + return 0; +} + +static const struct rtc_ops ds3231_rtc_ops = { + .get = ds3231_rtc_get, + .set = ds3231_rtc_set, + .reset = ds3231_rtc_reset, +}; + +static const struct udevice_id ds3231_rtc_ids[] = { + { .compatible = "dallas,ds3231" }, + { .compatible = "dallas,ds3232" }, + { } +}; + +U_BOOT_DRIVER(rtc_ds3231) = { + .name = "rtc-ds3231", + .id = UCLASS_RTC, + .probe = ds3231_probe, + .of_match = ds3231_rtc_ids, + .ops = &ds3231_rtc_ops, +}; +#endif
Changes in v4:
Changes in v2:
- (C) Copyright 2006
- Markus Klotzbuecher, mk@denx.de
- (C) Copyright 2019 NXP
- Chuanhua Han chuanhua.han@nxp.com
- uchar sec, min, hour, mday, wday, mon_cent, year, status;
- status = dm_i2c_reg_read(dev, RTC_STAT_REG_ADDR);
- sec = dm_i2c_reg_read(dev, RTC_SEC_REG_ADDR);
- min = dm_i2c_reg_read(dev, RTC_MIN_REG_ADDR);
- hour = dm_i2c_reg_read(dev, RTC_HR_REG_ADDR);
- wday = dm_i2c_reg_read(dev, RTC_DAY_REG_ADDR);
- mday = dm_i2c_reg_read(dev, RTC_DATE_REG_ADDR);
- mon_cent = dm_i2c_reg_read(dev, RTC_MON_REG_ADDR);
- year = dm_i2c_reg_read(dev, RTC_YR_REG_ADDR);
- if (status & RTC_STAT_BIT_OSF) {
RTC_STAT_REG_ADDR)
return -EINVAL;
- tmp->tm_sec = bcd2bin(sec & 0x7F);
- tmp->tm_min = bcd2bin(min & 0x7F);
- tmp->tm_hour = bcd2bin(hour & 0x3F);
- tmp->tm_mday = bcd2bin(mday & 0x3F);
- tmp->tm_mon = bcd2bin(mon_cent & 0x1F);
- tmp->tm_year = bcd2bin(year) + ((mon_cent & 0x80) ? 2000 :
1900);
- tmp->tm_wday = bcd2bin((wday - 1) & 0x07);
- tmp->tm_yday = 0;
- tmp->tm_isdst = 0;
- debug("Get DATE: %4d-%02d-%02d (wday=%d) TIME:
%2d:%02d:%02d\n",
- uchar century;
- debug("Set DATE: %4d-%02d-%02d (wday=%d) TIME:
%2d:%02d:%02d\n",
- dm_i2c_reg_write(dev, RTC_YR_REG_ADDR, bin2bcd(tmp->tm_year
% 100)); +
- century = (tmp->tm_year >= 2000) ? 0x80 : 0;
- dm_i2c_reg_write(dev, RTC_MON_REG_ADDR, bin2bcd(tmp->tm_mon)
| century); +
- dm_i2c_reg_write(dev, RTC_DAY_REG_ADDR, bin2bcd(tmp->tm_wday
- 1));
- dm_i2c_reg_write(dev, RTC_DATE_REG_ADDR,
- dm_i2c_reg_write(dev, RTC_HR_REG_ADDR,
- dm_i2c_reg_write(dev, RTC_MIN_REG_ADDR,
- dm_i2c_reg_write(dev, RTC_SEC_REG_ADDR,
- int ret;
- ret = dm_i2c_reg_write(dev, RTC_CTL_REG_ADDR,
- if (ret < 0)
return ret;
- i2c_set_chip_flags(dev, DM_I2C_CHIP_RD_ADDRESS |
- .get = ds3231_rtc_get,
- .set = ds3231_rtc_set,
- .reset = ds3231_rtc_reset,
- { .compatible = "dallas,ds3231" },
- { .compatible = "dallas,ds3232" },
- .name = "rtc-ds3231",
- .id = UCLASS_RTC,
- .probe = ds3231_probe,
- .of_match = ds3231_rtc_ids,
- .ops = &ds3231_rtc_ops,
+}; +#endif
Reviewed-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
-----Original Message----- From: Lukasz Majewski lukma@denx.de Sent: 2019年6月21日 19:33 To: Chuanhua Han chuanhua.han@nxp.com Cc: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; u-boot@lists.denx.de Subject: [EXT] Re: [PATCH v4] rtc: Add DM support to ds3231
Changes in v4:
Changes in v2:
RTC_STAT_REG_ADDR)
return -EINVAL;
1900);
- tmp->tm_yday = 0;
%2d:%02d:%02d\n",
- uchar century;
%2d:%02d:%02d\n",
% 100)); +
| century); +
1));
+static int ds3231_rtc_reset(struct udevice *dev) {
- int ret;
- if (ret < 0)
return ret;
+static int ds3231_probe(struct udevice *dev) {
- .id = UCLASS_RTC,
+}; +#endif
Hi, Any other questions? Whether can merge into the uboot mainlines? Thanks!
Lukasz Majewski
Hi, Lukasz Majewski
Changes in v4:
Changes in v2:
RTC_STAT_REG_ADDR)
return -EINVAL;
1900);
- tmp->tm_yday = 0;
%2d:%02d:%02d\n",
- uchar century;
%2d:%02d:%02d\n",
% 100)); +
| century); +
1));
- int ret;
- if (ret < 0)
return ret;
- .id = UCLASS_RTC,
+}; +#endif
Does this patch need to be modified? Can this patch be merged with the mainline of uboot? Looking forward to your reply. Thank you very much!
Lukasz Majewski
Hi Chuanhua,
Hi, Lukasz Majewski
Changes in v4:
Changes in v2:
stopped\n");
RTC_STAT_REG_ADDR)
~RTC_STAT_BIT_OSF);
return -EINVAL;
2000 : 1900);
- tmp->tm_yday = 0;
%2d:%02d:%02d\n",
tmp->tm_wday,
- uchar century;
%2d:%02d:%02d\n",
tmp->tm_wday,
1));
- int ret;
RTC_CTL_BIT_RS1 |
RTC_CTL_BIT_RS2);
- if (ret < 0)
return ret;
- .id = UCLASS_RTC,
+}; +#endif
If there are no other comments, then yes - this patch is eligible for upstreaming.
In the patchwork [1] - there is a delegate assigned - in this case Tom Rini is supposed to pull this patch.
I've added Tom to CC, so maybe he will pull this code soon.
Note:
[1] - https://patchwork.ozlabs.org/patch/1120001/
Lukasz Majewski
Lukasz Majewski
Hi,tom and Lukasz
-----Original Message----- From: Lukasz Majewski lukma@denx.de Sent: 2019年7月16日 15:07 To: Chuanhua Han chuanhua.han@nxp.com Cc: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; u-boot@lists.denx.de; Tom Rini trini@konsulko.com Subject: Re: [EXT] Re: [PATCH v4] rtc: Add DM support to ds3231
Hi Chuanhua,
Hi, Lukasz Majewski
Changes in v4:
Changes in v2:
107
insertions(+)
stopped\n");
RTC_STAT_REG_ADDR)
~RTC_STAT_BIT_OSF);
return -EINVAL;
2000 : 1900);
- tmp->tm_yday = 0;
%2d:%02d:%02d\n",
tmp->tm_wday,
- uchar century;
%2d:%02d:%02d\n",
tmp->tm_wday,
1));
- int ret;
RTC_CTL_BIT_RS1 |
RTC_CTL_BIT_RS2);
- if (ret < 0)
return ret;
- .id = UCLASS_RTC,
+}; +#endif
Thank you very much!!!
Note:
Lukasz Majewski
Lukasz Majewski
Signed-off-by: Chuanhua Han chuanhua.han@nxp.com Reviewed-by: Lukasz Majewski lukma@denx.de
Chuanhua Han
Lukasz Majewski
