[PATCH v1] arm: dts: k3-am625-verdin: fix boot
A53 U-Boot proper got broken because nodes marked as 'bootph-pre-ram' are no longer available in U-Boot proper before relocation.
Fix this by marking all nodes in u-boot.dtsi as 'bootph-all'.
Fixes: 9e644284ab812 ("dm: core: Report bootph-pre-ram/sram node as pre-reloc after relocation") Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
.../dts/k3-am625-verdin-wifi-dev-u-boot.dtsi | 72 +++++++++---------- 1 file changed, 36 insertions(+), 36 deletions(-)
diff --git a/arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi b/arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi index 5d564603eb2..afa24d07a4c 100644 --- a/arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-verdin-wifi-dev-u-boot.dtsi @@ -17,49 +17,49 @@ };
memory@80000000 { - bootph-pre-ram; + bootph-all; }; };
&cbass_main { - bootph-pre-ram; + bootph-all;
timer@2400000 { clock-frequency = <25000000>; - bootph-pre-ram; + bootph-all; }; };
&cbass_mcu { - bootph-pre-ram; + bootph-all; };
&cbass_wakeup { - bootph-pre-ram; + bootph-all; };
&chipid { - bootph-pre-ram; + bootph-all; };
&cpsw3g { - bootph-pre-ram; + bootph-all; };
&cpsw3g_phy0 { - bootph-pre-ram; + bootph-all; };
&cpsw3g_phy1 { - bootph-pre-ram; + bootph-all; };
&cpsw_port1 { - bootph-pre-ram; + bootph-all; };
&cpsw_port2 { - bootph-pre-ram; + bootph-all; };
/* MDIO, shared by Verdin ETH_1 (On-module PHY) and Verdin ETH_2_RGMII */ @@ -67,40 +67,40 @@ /delete-property/ assigned-clocks; /delete-property/ assigned-clock-parents; /delete-property/ assigned-clock-rates; - bootph-pre-ram; + bootph-all; };
&dmsc { - bootph-pre-ram; + bootph-all;
k3_sysreset: sysreset-controller { compatible = "ti,sci-sysreset"; - bootph-pre-ram; + bootph-all; }; };
&dmss { - bootph-pre-ram; + bootph-all; };
&fss { - bootph-pre-ram; + bootph-all; };
&k3_clks { - bootph-pre-ram; + bootph-all; };
&k3_pds { - bootph-pre-ram; + bootph-all; };
&k3_reset { - bootph-pre-ram; + bootph-all; };
&main_gpio0 { - bootph-pre-ram; + bootph-all; };
/* On-module I2C - PMIC_I2C */ @@ -130,53 +130,53 @@ };
&main_pmx0 { - bootph-pre-ram; + bootph-all; };
/* Verdin UART_3, used as the Linux console */ &main_uart0 { - bootph-pre-ram; + bootph-all; };
/* Verdin UART_1 */ &main_uart1 { - bootph-pre-ram; + bootph-all; };
&mcu_pmx0 { - bootph-pre-ram; + bootph-all; };
&pinctrl_ctrl_sleep_moci { - bootph-pre-ram; + bootph-all; };
&pinctrl_i2c0 { - bootph-pre-ram; + bootph-all; };
&pinctrl_i2c1 { - bootph-pre-ram; + bootph-all; };
&pinctrl_sdhci0 { - bootph-pre-ram; + bootph-all; };
&pinctrl_uart0 { - bootph-pre-ram; + bootph-all; };
&pinctrl_uart1 { - bootph-pre-ram; + bootph-all; };
&pinctrl_wkup_uart0 { - bootph-pre-ram; + bootph-all; };
&sdhci0 { - bootph-pre-ram; + bootph-all; };
&sdhci2 { @@ -184,18 +184,18 @@ };
&secure_proxy_main { - bootph-pre-ram; + bootph-all; };
&verdin_ctrl_sleep_moci { - bootph-pre-ram; + bootph-all; };
&wkup_conf { - bootph-pre-ram; + bootph-all; };
/* Verdin UART_2 */ &wkup_uart0 { - bootph-pre-ram; + bootph-all; };
Reviewed-by: Nishanth Menon nm@ti.com
memory@80000000 {
bootph-pre-ram;
};bootph-all;
&cbass_main {
- bootph-pre-ram;
bootph-all;
bootph-pre-ram;
};bootph-all;
&cbass_mcu {
- bootph-pre-ram;
- bootph-all;
&cbass_wakeup {
- bootph-pre-ram;
- bootph-all;
&chipid {
- bootph-pre-ram;
- bootph-all;
&cpsw3g {
- bootph-pre-ram;
- bootph-all;
&cpsw3g_phy0 {
- bootph-pre-ram;
- bootph-all;
&cpsw3g_phy1 {
- bootph-pre-ram;
- bootph-all;
&cpsw_port1 {
- bootph-pre-ram;
- bootph-all;
&cpsw_port2 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&dmsc {
- bootph-pre-ram;
bootph-all;
bootph-pre-ram;
};bootph-all;
&dmss {
- bootph-pre-ram;
- bootph-all;
&fss {
- bootph-pre-ram;
- bootph-all;
&k3_clks {
- bootph-pre-ram;
- bootph-all;
&k3_pds {
- bootph-pre-ram;
- bootph-all;
&k3_reset {
- bootph-pre-ram;
- bootph-all;
&main_gpio0 {
- bootph-pre-ram;
- bootph-all;
&main_pmx0 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&mcu_pmx0 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&pinctrl_i2c0 {
- bootph-pre-ram;
- bootph-all;
&pinctrl_i2c1 {
- bootph-pre-ram;
- bootph-all;
&pinctrl_sdhci0 {
- bootph-pre-ram;
- bootph-all;
&pinctrl_uart0 {
- bootph-pre-ram;
- bootph-all;
&pinctrl_uart1 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&sdhci0 {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
&wkup_conf {
- bootph-pre-ram;
- bootph-all;
- bootph-pre-ram;
- bootph-all;
2.36.1
Marcel Ziswiler
Nishanth Menon
