Hi Tom,
This PR includes the following changes for v2020.01:
- Rename existing FSP code to fsp1 - Add fsp2 directory in preparation to support FSP 2.0 - Various x86 platform codes update - Various bug fixes and updates in dm core, sandbox and spl
GitLab CI passed https://gitlab.denx.de/u-boot/custodians/u-boot-x86/pipelines/867
The following changes since commit 61ba1244b548463dbfb3c5285b6b22e7c772c5bd:
Prepare v2019.10 (2019-10-07 17:14:02 -0400)
for you to fetch changes up to cc2d27dcdc3e1c76d09d54015e3992380bd7e0fa:
x86: Use mtrr_commit() with FSP2 (2019-10-08 13:57:49 +0800)
---------------------------------------------------------------- Simon Glass (95): x86: Rename existing FSP code to fsp1 x86: Move fsp_azalia.h to the generic fsp directory x86: Create a new fsp_arch.h header x86: Move fsp_api.h inclusion out of fsp_support.h x86: Move fsp_types.h to the generic fsp directory x86: Move fsp_fv.h to the generic fsp directory x86: Move fsp_hob.h to the generic fsp directory x86: Move fsp_infoheader.h to the generic fsp directory x86: Move fsp_bootmode.h to the generic fsp directory x86: Move fsp_ffs.h include to fsp_arch.h binman: Pass the toolpath to binman from the main Makefile binman: Allow selection of logging verbosity mtd: spi: Add 'struct spi_flash {' to the code serial: ns16550: Allow serial to enabled/disabled in SPL spl: Avoid checking for Ctrl-C in SPL with print_buffer() spl: handoff: Correct Kconfig condition for SPL and TPL spl: Add an arch-specific hook for writing to SPL handoff spl: Set up the bloblist in board_init_r() spl: Add a function to determine the U-Boot phase x86: sysreset: Allow reset driver to be included in SPL/TPL x86: Rename some FSP functions to have an fsp_ prefix x86: fsp: Create a common fsp_support.h header x86: fsp: Use if() instead of #ifdef x86: fsp: Tidy up comment style a little x86: fsp: Move common dram functions into a common file x86: Move common fsp functions into a common file x86: fsp: Move common support functions into a common file efi: Move inline functions to unconditional part of header x86: fsp: Add a few more definitions for FSP2 x86: fsp: Add access to variable MRC data x86: Move common Intel CPU info code into a function x86: Add binman symbols to the image x86: pci: Add a function to clear and set PCI config regs x86: spl: Use hang() instead of a while() loop x86: spl: Reduce priority of the basic SPL image loader x86: spl: Move broadwell-specific code out of generic x86 spl x86: fsp: Save usable RAM and hob_list in the handoff area x86: Change condition for using CAR x86: Add more comments to the start-up code x86: Add various MTRR indexes and values x86: Rename turbo ratio MSR to MSR_TURBO_RATIO_LIMIT dm: core: Use U-Boot logging instead of pr_debug() dm: core: Drop a few early returns dm: core: Add documentation on how to debug driver model dm: test: Fix running of multiple test from command line dm: test: Don't fail when tests are skipped due to build dm: core: Call ofdata_to_platdata() with of-platdata dm: core: Correct the return value for uclass_find_first_device() dm: core: Add device_foreach_child() dm: test: Correct a stray backslash in dm_test_destroy() sandbox: spmi: Add ranges property for address translation sandbox: mmc: Fix up MMC emulator for valgrind sandbox: Rename PCI ID for swap_case to be more specific sandbox: Add support for clrsetio_32() and friends sandbox: swap_case: Use statics where possible sandbox: pci: Drop the get_devfn() method sandbox: pci: Move pci_offset_to_barnum() to pci.h sandbox: Add a -T flag to use the test device tree sandbox: pci: Increase the memory space sandbox: Allow use of real I/O with readl(), etc. pci: sandbox: Move the emulators into their own node pci: sandbox: Probe PCI emulation devices when used pci: Show the result of binding a device pci: Disable autoconfig in SPL pci: Correct 'specifified' and 'Plese' typos pci: Add more debug detail when resources are exhausted pci: Show a message if PCI autoconfig fails dm: pci: Add a function to read a PCI BAR serial: ns16550: Add a PCI device/function field binman: Allow verbose output with all commands binman: Add a base implementation of Entry.ReadChildData() binman: Handle reading data for end-at-4gb sections binman: Take account of skip-at-start with image-header log: Add log_nop() to avoid unused-variable warnings cros_ec: Add MEC_EMI_BASE and size to the header file iod: Enhance to support display of multiple values arm: mxs: Correct CONFIG_SPL_NO_CPU_SUPPORT option spl: Allow tiny printf() to be controlled in SPL and TPL spl: Convert CONFIG_SPL_SIZE_LIMIT to hex spl: Allow distinguishing between two phases in U-Boot x86: Move acpi_s3.h to a common location x86: pci: Drop the first parameter in pci_x86_r/w_config() x86: Use a common definition of MSR_IA32_PERF_CTL x86: Add a common function to set CPU thermal target x86: Use a common bus clock for Intel CPUs x86: Add common functions for TDP and perf control x86: Tidy up some duplicate MSR defines x86: Add new common CPU functions for turbo/burst mode dm: core: Drop fdtdec_get_pci_addr() sandbox: pci: Create a new sandbox_pci_read_bar() function x86: Allow the PCH and LPC uclasses to work with of-platdata x86: Refactor mtrr_commit() to allow for shared code x86: Add a function to set variable MTRRs x86: cpu: Don't include the cpu driver in TPL x86: Use mtrr_commit() with FSP2
Makefile | 14 +++++--- arch/arm/Kconfig | 2 +- arch/arm/cpu/arm926ejs/Makefile | 2 +- arch/arm/mach-omap2/Kconfig | 6 ++-- arch/arm/mach-rmobile/Kconfig | 2 +- arch/arm/mach-rmobile/Kconfig.32 | 14 ++++---- arch/arm/mach-socfpga/Kconfig | 6 ++-- arch/arm/mach-uniphier/pinctrl-glue.c | 4 +-- arch/sandbox/cpu/cpu.c | 52 +++++++++++++++++++++++++++ arch/sandbox/cpu/spl.c | 7 ++++ arch/sandbox/cpu/start.c | 25 +++++++++++++ arch/sandbox/dts/sandbox.dtsi | 11 ++++-- arch/sandbox/dts/test.dts | 49 +++++++++++++++++--------- arch/sandbox/include/asm/io.h | 70 ++++++++++++++++++++++++++++-------- arch/sandbox/include/asm/state.h | 1 + arch/sandbox/include/asm/test.h | 17 ++++++++- arch/sandbox/lib/pci_io.c | 12 +++---- arch/x86/Kconfig | 33 ++++++++++++++++- arch/x86/cpu/Makefile | 5 ++- arch/x86/cpu/baytrail/acpi.c | 4 +-- arch/x86/cpu/baytrail/cpu.c | 6 ++-- arch/x86/cpu/baytrail/fsp_configs.c | 4 +-- arch/x86/cpu/braswell/fsp_configs.c | 4 +-- arch/x86/cpu/broadwell/cpu.c | 23 ++++++------ arch/x86/cpu/broadwell/cpu_full.c | 57 ++++++++---------------------- arch/x86/cpu/cpu.c | 2 +- arch/x86/cpu/intel_common/cpu.c | 116 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/x86/cpu/intel_common/cpu_from_spl.c | 6 ++++ arch/x86/cpu/ivybridge/cpu.c | 3 +- arch/x86/cpu/ivybridge/fsp_configs.c | 4 +-- arch/x86/cpu/ivybridge/model_206ax.c | 60 ++++++++----------------------- arch/x86/cpu/ivybridge/northbridge.c | 2 +- arch/x86/cpu/mtrr.c | 57 ++++++++++++++++++++++++++---- arch/x86/cpu/pci.c | 23 +++++++++--- arch/x86/cpu/queensbay/fsp_configs.c | 4 +-- arch/x86/cpu/queensbay/tnc.c | 2 +- arch/x86/cpu/start.S | 16 +++++++-- arch/x86/cpu/start_from_spl.S | 5 +-- arch/x86/cpu/start_from_tpl.S | 3 +- arch/x86/cpu/turbo.c | 10 +++--- arch/x86/cpu/u-boot-spl.lds | 6 ++++ arch/x86/cpu/wakeup.S | 2 +- arch/x86/include/asm/arch-broadwell/cpu.h | 3 -- arch/x86/include/asm/arch-broadwell/pch.h | 3 -- arch/x86/include/asm/arch-ivybridge/model_206ax.h | 5 +-- arch/x86/include/asm/cpu_common.h | 99 ++++++++++++++++++++++++++++++++++++++++++++++++++- arch/x86/include/asm/fsp/fsp_hob.h | 4 +++ arch/x86/include/asm/fsp/fsp_infoheader.h | 15 +++++++- arch/x86/include/asm/fsp/fsp_support.h | 141 ++++++++++++++++++++++++++++++------------------------------------------- arch/x86/include/asm/{fsp => fsp1}/fsp_api.h | 0 arch/x86/include/asm/{fsp => fsp1}/fsp_ffs.h | 0 arch/x86/include/asm/fsp1/fsp_support.h | 72 +++++++++++++++++++++++++++++++++++++ arch/x86/include/asm/fsp_arch.h | 22 ++++++++++++ arch/x86/include/asm/handoff.h | 8 +++++ arch/x86/include/asm/hob.h | 18 +++++----- arch/x86/include/asm/msr-index.h | 131 ++++++++++++++++++++++++++++++++++---------------------------------- arch/x86/include/asm/mtrr.h | 13 +++++++ arch/x86/include/asm/pci.h | 45 +++++++++++++++++++++--- arch/x86/include/asm/spl.h | 3 +- arch/x86/include/asm/u-boot-x86.h | 2 +- arch/x86/lib/Makefile | 2 ++ arch/x86/lib/acpi_s3.c | 2 +- arch/x86/lib/coreboot_table.c | 2 +- arch/x86/lib/fsp/Makefile | 4 +-- arch/x86/lib/fsp/fsp_common.c | 65 ++-------------------------------- arch/x86/lib/fsp/fsp_dram.c | 38 ++++++++------------ arch/x86/lib/fsp/fsp_support.c | 203 ++++++--------------------------------------------------------------------------------------------------- arch/x86/lib/fsp1/Makefile | 9 +++++ arch/x86/lib/{fsp => fsp1}/fsp_car.S | 10 +++--- arch/x86/lib/fsp1/fsp_common.c | 77 ++++++++++++++++++++++++++++++++++++++++ arch/x86/lib/fsp1/fsp_dram.c | 36 +++++++++++++++++++ arch/x86/lib/{fsp => fsp1}/fsp_graphics.c | 2 +- arch/x86/lib/fsp1/fsp_support.c | 199 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/x86/lib/hob.c | 8 ++--- arch/x86/lib/init_helpers.c | 22 ++++++++---- arch/x86/lib/lpc-uclass.c | 2 ++ arch/x86/lib/spl.c | 13 +++---- arch/x86/lib/tpl.c | 7 ++-- board/advantech/som-db5800-som-6867/som-db5800-som-6867.c | 2 +- board/intel/cherryhill/cherryhill.c | 2 +- cmd/io.c | 85 ++++++++++++++++++++++++++++++++++---------- cmd/x86/fsp.c | 4 +-- common/spl/Kconfig | 8 ++--- common/spl/spl.c | 47 ++++++++++++++----------- common/xyzModem.c | 2 +- configs/am335x_pdu001_defconfig | 2 +- configs/evb-rk3288_defconfig | 2 +- configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 2 +- configs/ls1043ardb_nand_defconfig | 2 +- configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig | 2 +- configs/ls1043ardb_sdcard_defconfig | 2 +- configs/sandbox_spl_defconfig | 2 +- configs/slimbootloader_defconfig | 1 + configs/tinker-rk3288_defconfig | 2 +- doc/arch/sandbox.rst | 9 +++++ doc/driver-model/debugging.rst | 62 ++++++++++++++++++++++++++++++++ doc/driver-model/index.rst | 1 + doc/driver-model/pci-info.rst | 25 ++++++------- drivers/block/blk-uclass.c | 4 +-- drivers/core/device.c | 3 +- drivers/core/fdtaddr.c | 30 ++++++++++++++++ drivers/core/lists.c | 20 ++++++----- drivers/core/read.c | 11 ++++++ drivers/core/uclass.c | 16 ++++++--- drivers/gpio/gpio-uclass.c | 4 +-- drivers/gpio/pm8916_gpio.c | 12 +++---- drivers/misc/Makefile | 2 +- drivers/misc/swap_case.c | 48 +++++++------------------ drivers/mmc/mmc.c | 2 +- drivers/mmc/sandbox_mmc.c | 4 +++ drivers/mtd/spi/sf-uclass.c | 2 +- drivers/pch/pch-uclass.c | 2 ++ drivers/pci/pci-emul-uclass.c | 55 +++++++++++++++++++++++++---- drivers/pci/pci-uclass.c | 5 +-- drivers/pci/pci_auto.c | 12 +++++-- drivers/pci/pci_auto_common.c | 4 ++- drivers/pci/pci_rom.c | 2 +- drivers/pci/pci_x86.c | 16 +++++++-- drivers/serial/ns16550.c | 37 +++---------------- drivers/serial/sandbox.c | 2 ++ drivers/sysreset/Kconfig | 12 +++++++ drivers/sysreset/Makefile | 2 +- drivers/sysreset/sysreset_x86.c | 2 +- {arch/x86/include/asm => include}/acpi_s3.h | 0 include/configs/mxs.h | 2 +- include/dm/device.h | 9 +++++ include/dm/fdtaddr.h | 8 +++++ include/dm/read.h | 25 +++++++++++++ include/dm/uclass-id.h | 1 + include/dm/uclass-internal.h | 4 +-- include/ec_commands.h | 4 +++ include/efi_loader.h | 10 +++--- include/fdtdec.h | 17 --------- include/handoff.h | 13 +++++++ include/linux/mtd/spi-nor.h | 8 ++++- include/log.h | 33 +++++++++++++---- include/ns16550.h | 4 +++ include/pci.h | 13 +++---- include/spl.h | 66 ++++++++++++++++++++++++++++++++++ lib/Kconfig | 20 ++++++++--- lib/Makefile | 2 +- lib/display_options.c | 2 ++ lib/fdtdec.c | 54 ---------------------------- scripts/config_whitelist.txt | 1 - test/dm/core.c | 3 +- test/dm/pci.c | 51 +++++++++++++++++++++++++-- test/dm/test-main.c | 16 +++++---- tools/binman/README | 6 ++++ tools/binman/control.py | 36 ++++++++----------- tools/binman/entry.py | 18 ++++++++++ tools/binman/etype/image_header.py | 1 + tools/binman/etype/section.py | 16 +++------ tools/binman/image.py | 2 ++ 153 files changed, 2036 insertions(+), 1018 deletions(-) rename arch/x86/include/asm/{fsp => fsp1}/fsp_api.h (100%) rename arch/x86/include/asm/{fsp => fsp1}/fsp_ffs.h (100%) create mode 100644 arch/x86/include/asm/fsp1/fsp_support.h create mode 100644 arch/x86/include/asm/fsp_arch.h create mode 100644 arch/x86/lib/fsp1/Makefile rename arch/x86/lib/{fsp => fsp1}/fsp_car.S (94%) create mode 100644 arch/x86/lib/fsp1/fsp_common.c create mode 100644 arch/x86/lib/fsp1/fsp_dram.c rename arch/x86/lib/{fsp => fsp1}/fsp_graphics.c (98%) create mode 100644 arch/x86/lib/fsp1/fsp_support.c create mode 100644 doc/driver-model/debugging.rst rename {arch/x86/include/asm => include}/acpi_s3.h (100%)
Regards, Bin
On Tue, Oct 08, 2019 at 04:28:33PM +0800, Bin Meng wrote:
Hi Tom,
Bin Meng
