[U-Boot] [PATCH 11/13 v5] ARM: OMAP3: Add EVM board
Subject: [PATCH 11/13 v5] ARM: OMAP3: Add EVM board
Add EVM board
Signed-off-by: Dirk Behme dirk.behme@gmail.com
Changes in version v5:
- Update Makefile style and replace hardcoded values by macros as proposed by Jean-Christophe PLAGNIOL-VILLARD. - Add EVM to MAINTAINERS and MAKEALL
Changes in version v2:
- Rebase against u-boot-arm.git next (CFG vs. CONFIG changes)
MAINTAINERS | 4 MAKEALL | 1 Makefile | 3 board/omap3/evm/Makefile | 49 +++++ board/omap3/evm/config.mk | 17 + board/omap3/evm/evm.c | 189 +++++++++++++++++++++ board/omap3/evm/evm.h | 390 +++++++++++++++++++++++++++++++++++++++++++++ board/omap3/evm/u-boot.lds | 63 +++++++ 8 files changed, 716 insertions(+)
Index: u-boot-main/board/omap3/evm/Makefile =================================================================== --- /dev/null +++ u-boot-main/board/omap3/evm/Makefile @@ -0,0 +1,49 @@ +# +# (C) Copyright 2000, 2001, 2002 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := evm.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### \ No newline at end of file Index: u-boot-main/board/omap3/evm/config.mk =================================================================== --- /dev/null +++ u-boot-main/board/omap3/evm/config.mk @@ -0,0 +1,17 @@ +# +# (C) Copyright 2006 +# Texas Instruments, <www.ti.com> +# +# Begale Board uses OMAP3 (ARM-CortexA8) cpu +# see http://www.ti.com/ for more information on Texas Instruments +# +# Physical Address: +# 8000'0000 (bank0) +# A000/0000 (bank1) +# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 +# (mem base + reserved) + +# For use with external or internal boots. +TEXT_BASE = 0x80e80000 + + Index: u-boot-main/board/omap3/evm/evm.c =================================================================== --- /dev/null +++ u-boot-main/board/omap3/evm/evm.c @@ -0,0 +1,189 @@ +/* + * (C) Copyright 2004-2008 + * Texas Instruments, <www.ti.com> + * + * Author : + * Manikandan Pillai mani.pillai@ti.com + * + * Derived from Beagle Board and 3430 SDP code by + * Richard Woodruff r-woodruff2@ti.com + * Syed Mohammed Khasim khasim@ti.com + * + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/io.h> +#include <asm/arch/mux.h> +#include <asm/arch/sys_proto.h> +#include <i2c.h> +#include <asm/mach-types.h> +#include "evm.h" + +/****************************************************************************** + * Routine: board_init + * Description: Early hardware init. + *****************************************************************************/ +int board_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + gpmc_init(); /* in SRAM or SDRAM, finish GPMC */ + /* board id for Linux */ + gd->bd->bi_arch_number = MACH_TYPE_OMAP3EVM; + /* boot param addr */ + gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100); + + return 0; +} + +/****************************************************************************** + * Routine: misc_init_r + * Description: Init ethernet (done here so udelay works) + *****************************************************************************/ +int misc_init_r(void) +{ + +#ifdef CONFIG_DRIVER_OMAP34XX_I2C + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); +#endif + +#if defined(CONFIG_CMD_NET) + setup_net_chip(); +#endif + + return 0; +} + +/****************************************************************************** + * Routine: set_muxconf_regs + * Description: Setting up the configuration Mux registers specific to the + * hardware. Many pins need to be moved from protect to primary + * mode. + *****************************************************************************/ +void set_muxconf_regs(void) +{ + MUX_EVM(); +} + +/****************************************************************************** + * Routine: setup_net_chip + * Description: Setting up the configuration GPMC registers specific to the + * Ethernet hardware. Pin Muxing for the SMC9118 is initialized + * here. + *****************************************************************************/ +static int setup_net_chip(void) +{ + int i = 0; + + /* Configure GPMC registers */ + (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x0150)) = 0x00001000; + (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x0154)) = 0x001e1e01; + (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x0158)) = 0x00080300; + (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x015C)) = 0x1c091c09; + (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x0160)) = 0x04181f1f; + (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x0164)) = 0x00000FCF; + (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x0168)) = 0x00000f6c; + + /* Configure PIN MUX registers */ + /* Enable GPMC Pin Mux Registers */ + /* Enable GPMC_CLK Pin in CONTROL_PADCONF_gpmc_ncs7 register */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xBC)) |= 0x00180000; + /* Enable CS5 Pin in CONTROL_PADCONF_gpmc_ncs5 register */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xB8)) |= 0x00000018; + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xB8)) &= 0xFFFFFFF8; + /* Enable offmode for nwe in CONTROL_PADCONF_GPMC_NWE register */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xC4)) |= 0x00000F00; + /* En off mode for noe and ale in CONTROL_PADCONF_GPMC_NADV_ALE reg */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xC0)) |= 0x0E000E00; + /* Enable gpmc_nbe0_cle in CONTROL_PADCONF_GPMC_NWE register */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xC4)) |= 0x00180000; + + /* Enable gpmc_nbe1 in CONTROL_PADCONF_GPMC_NBE1 register and + configuring the mux mode to 0 */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xC8)) |= 0x00000018; + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xC8)) &= 0xFFFFFFF8; + /* Enable d15 in CONTROL_PADCONF_GPMC_D15 register */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xAC)) |= 0x00000018; + /* Enable d14 - d13 in CONTROL_PADCONF_GPMC_D13 register */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xA8)) |= 0x00180018; + /* Enable d12 - d11 in CONTROL_PADCONF_GPMC_D11 register */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xA4)) |= 0x00180018; + /* Enable d10 - d9 in CONTROL_PADCONF_GPMC_D9 register */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xA0)) |= 0x00180018; + /* Enable d8 - d7 in CONTROL_PADCONF_GPMC_D7 register */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x9C)) |= 0x00180018; + /* Enable d6 - d5 in CONTROL_PADCONF_GPMC_D5 register */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x98)) |= 0x00180018; + /* Enable d4 - d3 in CONTROL_PADCONF_GPMC_D3 register */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x94)) |= 0x00180018; + /* Enable d2 - d1 in CONTROL_PADCONF_GPMC_D1 register */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x90)) |= 0x00180018; + /* Enable d0 and a10 in CONTROL_PADCONF_GPMC_a10 register */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x8C)) |= 0x00180018; + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x8C)) &= 0xFFFFFFF8; + /* Enable a9 - a8 in CONTROL_PADCONF_GPMC_a8 register */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x88)) |= 0x00180018; + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x88)) &= 0xFFF8FFF8; + /* Enable a7 - a6 in CONTROL_PADCONF_GPMC_a6 register */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x84)) |= 0x00180018; + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x84)) &= 0xFFF8FFF8; + /* Enable a5 - a4 in CONTROL_PADCONF_GPMC_a4 register */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x80)) |= 0x00180018; + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x80)) &= 0xFFF8FFF8; + /* Enable a3 - a2 in CONTROL_PADCONF_GPMC_a2 register */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x7C)) |= 0x00180018; + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x7C)) &= 0xFFF8FFF8; + /* Enable a1 - a0 in CONTROL_PADCONF_GPMC_a0 register */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x78)) |= 0x00000018; + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x78)) &= 0xFFFFFFF8; + +#if defined(CPU_3430_ES1) || defined(CPU_3430_ES2) + /* GPIO 64 configuration in CONTROL_PADCONF_GPMC_WAIT2 + register mux mode is 4. */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xD0)) |= 0x00000018; + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xD0)) &= 0xFFFFFFF8; + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xD0)) |= 0x00000004; + + /* Configure GPIO 176 in CONTROL_PADCONF_MCSPI1_CS1 + register for ethernet ISR mux mode is 4 */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x1D0)) |= 0x00180000; + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x1D0)) &= 0xFFF8FFFF; + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x1D0)) |= 0x00040000; + + /* Enable Clock for GPIO 1-6 module in CM_FCLKEN_PER + and CM_ICLKEN_PER registers */ + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x5000)) |= 0x0003E800; + (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x5010)) |= 0x0003E800; + + /* Make GPIO 64 as output pin */ + (*(volatile int *)(OMAP34XX_GPIO3_BASE + 0x34)) &= ~(0x00000001); + + /* Now send a pulse on the GPIO pin */ + (*(volatile int *)(OMAP34XX_GPIO3_BASE + 0x3C)) |= 0x00000001; + for (i = 0; i < 99 ; i++); + (*(volatile int *)(OMAP34XX_GPIO3_BASE + 0x3C)) &= ~(0x00000001); + for (i = 0; i < 99 ; i++); + (*(volatile int *)(OMAP34XX_GPIO3_BASE + 0x3C)) |= 0x00000001; +#else + printf("Unknown revision... \n\n"); +#endif + return 0; +} + Index: u-boot-main/board/omap3/evm/u-boot.lds =================================================================== --- /dev/null +++ u-boot-main/board/omap3/evm/u-boot.lds @@ -0,0 +1,63 @@ +/* + * January 2004 - Changed to support H4 device + * Copyright (c) 2004 Texas Instruments + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/arm_cortexa8/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + .ARM.extab : { *(.ARM.extab* .gnu.linkonce.armextab.*) } + __exidx_start = .; + .ARM.exidx : { *(.ARM.exidx* .gnu.linkonce.armexidx.*) } + __exidx_end = .; + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} Index: u-boot-main/Makefile =================================================================== --- u-boot-main.orig/Makefile +++ u-boot-main/Makefile @@ -2759,6 +2759,9 @@ SMN42_config : unconfig omap3_beagle_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm_cortexa8 beagle omap3 omap3
+omap3_evm_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm_cortexa8 evm omap3 omap3 + ######################################################################### ## XScale Systems ######################################################################### Index: u-boot-main/MAINTAINERS =================================================================== --- u-boot-main.orig/MAINTAINERS +++ u-boot-main/MAINTAINERS @@ -548,6 +548,10 @@ Guennadi Liakhovetski <g.liakhovetski@gm mx31ads i.MX31 SMDK6400 S3C6400
+Nishanth Menon menon.nishanth@gmail.com + + omap3_evm ARM CORTEX-A8 (OMAP3xx SoC) + David Müller d.mueller@elsoft.ch
smdk2410 ARM920T Index: u-boot-main/MAKEALL =================================================================== --- u-boot-main.orig/MAKEALL +++ u-boot-main/MAKEALL @@ -507,6 +507,7 @@ LIST_ARM9=" \ davinci_sffsdr \ davinci_sonata \ omap3_beagle \ + omap3_evm \ "
######################################################################### Index: u-boot-main/board/omap3/evm/evm.h =================================================================== --- /dev/null +++ u-boot-main/board/omap3/evm/evm.h @@ -0,0 +1,390 @@ +/* + * (C) Copyright 2008 + * Nishanth Menon menon.nishanth@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _EVM_H_ +#define _EVM_H_ + +const omap3_sysinfo sysinfo = { + OMAP3EVM_V1, + OMAP3EVM_V2, + "35X-Family", + "OMAP3 EVM board", +}; + +static int setup_net_chip(void); + +/* + * IEN - Input Enable + * IDIS - Input Disable + * PTD - Pull type Down + * PTU - Pull type Up + * DIS - Pull type selection is inactive + * EN - Pull type selection is active + * M0 - Mode 0 + * The commented string gives the final mux configuration for that pin + */ +#define MUX_EVM() \ + /*SDRC*/\ + MUX_VAL(CP(SDRC_D0), (IEN | PTD | DIS | M0)) /*SDRC_D0*/\ + MUX_VAL(CP(SDRC_D1), (IEN | PTD | DIS | M0)) /*SDRC_D1*/\ + MUX_VAL(CP(SDRC_D2), (IEN | PTD | DIS | M0)) /*SDRC_D2*/\ + MUX_VAL(CP(SDRC_D3), (IEN | PTD | DIS | M0)) /*SDRC_D3*/\ + MUX_VAL(CP(SDRC_D4), (IEN | PTD | DIS | M0)) /*SDRC_D4*/\ + MUX_VAL(CP(SDRC_D5), (IEN | PTD | DIS | M0)) /*SDRC_D5*/\ + MUX_VAL(CP(SDRC_D6), (IEN | PTD | DIS | M0)) /*SDRC_D6*/\ + MUX_VAL(CP(SDRC_D7), (IEN | PTD | DIS | M0)) /*SDRC_D7*/\ + MUX_VAL(CP(SDRC_D8), (IEN | PTD | DIS | M0)) /*SDRC_D8*/\ + MUX_VAL(CP(SDRC_D9), (IEN | PTD | DIS | M0)) /*SDRC_D9*/\ + MUX_VAL(CP(SDRC_D10), (IEN | PTD | DIS | M0)) /*SDRC_D10*/\ + MUX_VAL(CP(SDRC_D11), (IEN | PTD | DIS | M0)) /*SDRC_D11*/\ + MUX_VAL(CP(SDRC_D12), (IEN | PTD | DIS | M0)) /*SDRC_D12*/\ + MUX_VAL(CP(SDRC_D13), (IEN | PTD | DIS | M0)) /*SDRC_D13*/\ + MUX_VAL(CP(SDRC_D14), (IEN | PTD | DIS | M0)) /*SDRC_D14*/\ + MUX_VAL(CP(SDRC_D15), (IEN | PTD | DIS | M0)) /*SDRC_D15*/\ + MUX_VAL(CP(SDRC_D16), (IEN | PTD | DIS | M0)) /*SDRC_D16*/\ + MUX_VAL(CP(SDRC_D17), (IEN | PTD | DIS | M0)) /*SDRC_D17*/\ + MUX_VAL(CP(SDRC_D18), (IEN | PTD | DIS | M0)) /*SDRC_D18*/\ + MUX_VAL(CP(SDRC_D19), (IEN | PTD | DIS | M0)) /*SDRC_D19*/\ + MUX_VAL(CP(SDRC_D20), (IEN | PTD | DIS | M0)) /*SDRC_D20*/\ + MUX_VAL(CP(SDRC_D21), (IEN | PTD | DIS | M0)) /*SDRC_D21*/\ + MUX_VAL(CP(SDRC_D22), (IEN | PTD | DIS | M0)) /*SDRC_D22*/\ + MUX_VAL(CP(SDRC_D23), (IEN | PTD | DIS | M0)) /*SDRC_D23*/\ + MUX_VAL(CP(SDRC_D24), (IEN | PTD | DIS | M0)) /*SDRC_D24*/\ + MUX_VAL(CP(SDRC_D25), (IEN | PTD | DIS | M0)) /*SDRC_D25*/\ + MUX_VAL(CP(SDRC_D26), (IEN | PTD | DIS | M0)) /*SDRC_D26*/\ + MUX_VAL(CP(SDRC_D27), (IEN | PTD | DIS | M0)) /*SDRC_D27*/\ + MUX_VAL(CP(SDRC_D28), (IEN | PTD | DIS | M0)) /*SDRC_D28*/\ + MUX_VAL(CP(SDRC_D29), (IEN | PTD | DIS | M0)) /*SDRC_D29*/\ + MUX_VAL(CP(SDRC_D30), (IEN | PTD | DIS | M0)) /*SDRC_D30*/\ + MUX_VAL(CP(SDRC_D31), (IEN | PTD | DIS | M0)) /*SDRC_D31*/\ + MUX_VAL(CP(SDRC_CLK), (IEN | PTD | DIS | M0)) /*SDRC_CLK*/\ + MUX_VAL(CP(SDRC_DQS0), (IEN | PTD | DIS | M0)) /*SDRC_DQS0*/\ + MUX_VAL(CP(SDRC_DQS1), (IEN | PTD | DIS | M0)) /*SDRC_DQS1*/\ + MUX_VAL(CP(SDRC_DQS2), (IEN | PTD | DIS | M0)) /*SDRC_DQS2*/\ + MUX_VAL(CP(SDRC_DQS3), (IEN | PTD | DIS | M0)) /*SDRC_DQS3*/\ + /*GPMC*/\ + MUX_VAL(CP(GPMC_A1), (IDIS | PTD | DIS | M0)) /*GPMC_A1*/\ + MUX_VAL(CP(GPMC_A2), (IDIS | PTD | DIS | M0)) /*GPMC_A2*/\ + MUX_VAL(CP(GPMC_A3), (IDIS | PTD | DIS | M0)) /*GPMC_A3*/\ + MUX_VAL(CP(GPMC_A4), (IDIS | PTD | DIS | M0)) /*GPMC_A4*/\ + MUX_VAL(CP(GPMC_A5), (IDIS | PTD | DIS | M0)) /*GPMC_A5*/\ + MUX_VAL(CP(GPMC_A6), (IDIS | PTD | DIS | M0)) /*GPMC_A6*/\ + MUX_VAL(CP(GPMC_A7), (IDIS | PTD | DIS | M0)) /*GPMC_A7*/\ + MUX_VAL(CP(GPMC_A8), (IDIS | PTD | DIS | M0)) /*GPMC_A8*/\ + MUX_VAL(CP(GPMC_A9), (IDIS | PTD | DIS | M0)) /*GPMC_A9*/\ + MUX_VAL(CP(GPMC_A10), (IDIS | PTD | DIS | M0)) /*GPMC_A10*/\ + MUX_VAL(CP(GPMC_D0), (IEN | PTD | DIS | M0)) /*GPMC_D0*/\ + MUX_VAL(CP(GPMC_D1), (IEN | PTD | DIS | M0)) /*GPMC_D1*/\ + MUX_VAL(CP(GPMC_D2), (IEN | PTD | DIS | M0)) /*GPMC_D2*/\ + MUX_VAL(CP(GPMC_D3), (IEN | PTD | DIS | M0)) /*GPMC_D3*/\ + MUX_VAL(CP(GPMC_D4), (IEN | PTD | DIS | M0)) /*GPMC_D4*/\ + MUX_VAL(CP(GPMC_D5), (IEN | PTD | DIS | M0)) /*GPMC_D5*/\ + MUX_VAL(CP(GPMC_D6), (IEN | PTD | DIS | M0)) /*GPMC_D6*/\ + MUX_VAL(CP(GPMC_D7), (IEN | PTD | DIS | M0)) /*GPMC_D7*/\ + MUX_VAL(CP(GPMC_D8), (IEN | PTD | DIS | M0)) /*GPMC_D8*/\ + MUX_VAL(CP(GPMC_D9), (IEN | PTD | DIS | M0)) /*GPMC_D9*/\ + MUX_VAL(CP(GPMC_D10), (IEN | PTD | DIS | M0)) /*GPMC_D10*/\ + MUX_VAL(CP(GPMC_D11), (IEN | PTD | DIS | M0)) /*GPMC_D11*/\ + MUX_VAL(CP(GPMC_D12), (IEN | PTD | DIS | M0)) /*GPMC_D12*/\ + MUX_VAL(CP(GPMC_D13), (IEN | PTD | DIS | M0)) /*GPMC_D13*/\ + MUX_VAL(CP(GPMC_D14), (IEN | PTD | DIS | M0)) /*GPMC_D14*/\ + MUX_VAL(CP(GPMC_D15), (IEN | PTD | DIS | M0)) /*GPMC_D15*/\ + MUX_VAL(CP(GPMC_NCS0), (IDIS | PTU | EN | M0)) /*GPMC_nCS0*/\ + MUX_VAL(CP(GPMC_NCS1), (IDIS | PTU | EN | M0)) /*GPMC_nCS1*/\ + MUX_VAL(CP(GPMC_NCS2), (IDIS | PTU | EN | M0)) /*GPMC_nCS2*/\ + MUX_VAL(CP(GPMC_NCS3), (IDIS | PTU | EN | M0)) /*GPMC_nCS3*/\ + MUX_VAL(CP(GPMC_NCS4), (IEN | PTU | EN | M0)) /*GPMC_nCS4*/\ + MUX_VAL(CP(GPMC_NCS5), (IDIS | PTD | DIS | M0)) /*GPMC_nCS5*/\ + MUX_VAL(CP(GPMC_NCS6), (IEN | PTD | DIS | M0)) /*GPMC_nCS6*/\ + MUX_VAL(CP(GPMC_NCS7), (IEN | PTU | EN | M0)) /*GPMC_nCS7*/\ + MUX_VAL(CP(GPMC_CLK), (IDIS | PTD | DIS | M0)) /*GPMC_CLK*/\ + MUX_VAL(CP(GPMC_NADV_ALE), (IDIS | PTD | DIS | M0)) /*GPMC_nADV_ALE*/\ + MUX_VAL(CP(GPMC_NOE), (IDIS | PTD | DIS | M0)) /*GPMC_nOE*/\ + MUX_VAL(CP(GPMC_NWE), (IDIS | PTD | DIS | M0)) /*GPMC_nWE*/\ + MUX_VAL(CP(GPMC_NBE0_CLE), (IDIS | PTD | DIS | M0)) /*GPMC_nBE0_CLE*/\ + MUX_VAL(CP(GPMC_NBE1), (IEN | PTD | DIS | M0)) /*GPMC_nBE1*/\ + MUX_VAL(CP(GPMC_NWP), (IEN | PTD | DIS | M0)) /*GPMC_nWP*/\ + MUX_VAL(CP(GPMC_WAIT0), (IEN | PTU | EN | M0)) /*GPMC_WAIT0*/\ + MUX_VAL(CP(GPMC_WAIT1), (IEN | PTU | EN | M0)) /*GPMC_WAIT1*/\ + MUX_VAL(CP(GPMC_WAIT2), (IEN | PTU | EN | M4)) /*GPIO_64*/\ + /* - ETH_nRESET*/\ + MUX_VAL(CP(GPMC_WAIT3), (IEN | PTU | EN | M0)) /*GPMC_WAIT3*/\ + /*DSS*/\ + MUX_VAL(CP(DSS_PCLK), (IDIS | PTD | DIS | M0)) /*DSS_PCLK*/\ + MUX_VAL(CP(DSS_HSYNC), (IDIS | PTD | DIS | M0)) /*DSS_HSYNC*/\ + MUX_VAL(CP(DSS_VSYNC), (IDIS | PTD | DIS | M0)) /*DSS_VSYNC*/\ + MUX_VAL(CP(DSS_ACBIAS), (IDIS | PTD | DIS | M0)) /*DSS_ACBIAS*/\ + MUX_VAL(CP(DSS_DATA0), (IDIS | PTD | DIS | M0)) /*DSS_DATA0*/\ + MUX_VAL(CP(DSS_DATA1), (IDIS | PTD | DIS | M0)) /*DSS_DATA1*/\ + MUX_VAL(CP(DSS_DATA2), (IDIS | PTD | DIS | M0)) /*DSS_DATA2*/\ + MUX_VAL(CP(DSS_DATA3), (IDIS | PTD | DIS | M0)) /*DSS_DATA3*/\ + MUX_VAL(CP(DSS_DATA4), (IDIS | PTD | DIS | M0)) /*DSS_DATA4*/\ + MUX_VAL(CP(DSS_DATA5), (IDIS | PTD | DIS | M0)) /*DSS_DATA5*/\ + MUX_VAL(CP(DSS_DATA6), (IDIS | PTD | DIS | M0)) /*DSS_DATA6*/\ + MUX_VAL(CP(DSS_DATA7), (IDIS | PTD | DIS | M0)) /*DSS_DATA7*/\ + MUX_VAL(CP(DSS_DATA8), (IDIS | PTD | DIS | M0)) /*DSS_DATA8*/\ + MUX_VAL(CP(DSS_DATA9), (IDIS | PTD | DIS | M0)) /*DSS_DATA9*/\ + MUX_VAL(CP(DSS_DATA10), (IDIS | PTD | DIS | M0)) /*DSS_DATA10*/\ + MUX_VAL(CP(DSS_DATA11), (IDIS | PTD | DIS | M0)) /*DSS_DATA11*/\ + MUX_VAL(CP(DSS_DATA12), (IDIS | PTD | DIS | M0)) /*DSS_DATA12*/\ + MUX_VAL(CP(DSS_DATA13), (IDIS | PTD | DIS | M0)) /*DSS_DATA13*/\ + MUX_VAL(CP(DSS_DATA14), (IDIS | PTD | DIS | M0)) /*DSS_DATA14*/\ + MUX_VAL(CP(DSS_DATA15), (IDIS | PTD | DIS | M0)) /*DSS_DATA15*/\ + MUX_VAL(CP(DSS_DATA16), (IDIS | PTD | DIS | M0)) /*DSS_DATA16*/\ + MUX_VAL(CP(DSS_DATA17), (IDIS | PTD | DIS | M0)) /*DSS_DATA17*/\ + MUX_VAL(CP(DSS_DATA18), (IDIS | PTD | DIS | M0)) /*DSS_DATA18*/\ + MUX_VAL(CP(DSS_DATA19), (IDIS | PTD | DIS | M0)) /*DSS_DATA19*/\ + MUX_VAL(CP(DSS_DATA20), (IDIS | PTD | DIS | M0)) /*DSS_DATA20*/\ + MUX_VAL(CP(DSS_DATA21), (IDIS | PTD | DIS | M0)) /*DSS_DATA21*/\ + MUX_VAL(CP(DSS_DATA22), (IDIS | PTD | DIS | M0)) /*DSS_DATA22*/\ + MUX_VAL(CP(DSS_DATA23), (IDIS | PTD | DIS | M0)) /*DSS_DATA23*/\ + /*CAMERA*/\ + MUX_VAL(CP(CAM_HS), (IEN | PTU | EN | M0)) /*CAM_HS */\ + MUX_VAL(CP(CAM_VS), (IEN | PTU | EN | M0)) /*CAM_VS */\ + MUX_VAL(CP(CAM_XCLKA), (IDIS | PTD | DIS | M0)) /*CAM_XCLKA*/\ + MUX_VAL(CP(CAM_PCLK), (IEN | PTU | EN | M0)) /*CAM_PCLK*/\ + MUX_VAL(CP(CAM_FLD), (IDIS | PTD | DIS | M4)) /*GPIO_98*/\ + /* - CAM_RESET*/\ + MUX_VAL(CP(CAM_D0), (IEN | PTD | DIS | M0)) /*CAM_D0*/\ + MUX_VAL(CP(CAM_D1), (IEN | PTD | DIS | M0)) /*CAM_D1*/\ + MUX_VAL(CP(CAM_D2), (IEN | PTD | DIS | M0)) /*CAM_D2*/\ + MUX_VAL(CP(CAM_D3), (IEN | PTD | DIS | M0)) /*CAM_D3*/\ + MUX_VAL(CP(CAM_D4), (IEN | PTD | DIS | M0)) /*CAM_D4*/\ + MUX_VAL(CP(CAM_D5), (IEN | PTD | DIS | M0)) /*CAM_D5*/\ + MUX_VAL(CP(CAM_D6), (IEN | PTD | DIS | M0)) /*CAM_D6*/\ + MUX_VAL(CP(CAM_D7), (IEN | PTD | DIS | M0)) /*CAM_D7*/\ + MUX_VAL(CP(CAM_D8), (IEN | PTD | DIS | M0)) /*CAM_D8*/\ + MUX_VAL(CP(CAM_D9), (IEN | PTD | DIS | M0)) /*CAM_D9*/\ + MUX_VAL(CP(CAM_D10), (IEN | PTD | DIS | M0)) /*CAM_D10*/\ + MUX_VAL(CP(CAM_D11), (IEN | PTD | DIS | M0)) /*CAM_D11*/\ + MUX_VAL(CP(CAM_XCLKB), (IDIS | PTD | DIS | M0)) /*CAM_XCLKB*/\ + MUX_VAL(CP(CAM_WEN), (IEN | PTD | DIS | M4)) /*GPIO_167*/\ + MUX_VAL(CP(CAM_STROBE), (IDIS | PTD | DIS | M0)) /*CAM_STROBE*/\ + MUX_VAL(CP(CSI2_DX0), (IEN | PTD | DIS | M0)) /*CSI2_DX0*/\ + MUX_VAL(CP(CSI2_DY0), (IEN | PTD | DIS | M0)) /*CSI2_DY0*/\ + MUX_VAL(CP(CSI2_DX1), (IEN | PTD | DIS | M0)) /*CSI2_DX1*/\ + MUX_VAL(CP(CSI2_DY1), (IEN | PTD | DIS | M0)) /*CSI2_DY1*/\ + /*Audio Interface */\ + MUX_VAL(CP(MCBSP2_FSX), (IEN | PTD | DIS | M0)) /*McBSP2_FSX*/\ + MUX_VAL(CP(MCBSP2_CLKX), (IEN | PTD | DIS | M0)) /*McBSP2_CLKX*/\ + MUX_VAL(CP(MCBSP2_DR), (IEN | PTD | DIS | M0)) /*McBSP2_DR*/\ + MUX_VAL(CP(MCBSP2_DX), (IDIS | PTD | DIS | M0)) /*McBSP2_DX*/\ + /*Expansion card */\ + MUX_VAL(CP(MMC1_CLK), (IDIS | PTU | EN | M0)) /*MMC1_CLK*/\ + MUX_VAL(CP(MMC1_CMD), (IEN | PTU | EN | M0)) /*MMC1_CMD*/\ + MUX_VAL(CP(MMC1_DAT0), (IEN | PTU | EN | M0)) /*MMC1_DAT0*/\ + MUX_VAL(CP(MMC1_DAT1), (IEN | PTU | EN | M0)) /*MMC1_DAT1*/\ + MUX_VAL(CP(MMC1_DAT2), (IEN | PTU | EN | M0)) /*MMC1_DAT2*/\ + MUX_VAL(CP(MMC1_DAT3), (IEN | PTU | EN | M0)) /*MMC1_DAT3*/\ + MUX_VAL(CP(MMC1_DAT4), (IEN | PTU | EN | M0)) /*MMC1_DAT4*/\ + MUX_VAL(CP(MMC1_DAT5), (IEN | PTU | EN | M0)) /*MMC1_DAT5*/\ + MUX_VAL(CP(MMC1_DAT6), (IEN | PTU | EN | M0)) /*MMC1_DAT6*/\ + MUX_VAL(CP(MMC1_DAT7), (IEN | PTU | EN | M0)) /*MMC1_DAT7*/\ + /*Wireless LAN */\ + MUX_VAL(CP(MMC2_CLK), (IEN | PTD | DIS | M0)) /*MMC2_CLK*/\ + MUX_VAL(CP(MMC2_CMD), (IEN | PTU | EN | M0)) /*MMC2_CMD*/\ + MUX_VAL(CP(MMC2_DAT0), (IEN | PTU | EN | M0)) /*MMC2_DAT0*/\ + MUX_VAL(CP(MMC2_DAT1), (IEN | PTU | EN | M0)) /*MMC2_DAT1*/\ + MUX_VAL(CP(MMC2_DAT2), (IEN | PTU | EN | M0)) /*MMC2_DAT2*/\ + MUX_VAL(CP(MMC2_DAT3), (IEN | PTU | EN | M0)) /*MMC2_DAT3*/\ + MUX_VAL(CP(MMC2_DAT4), (IDIS | PTD | DIS | M0)) /*MMC2_DAT4*/\ + MUX_VAL(CP(MMC2_DAT5), (IDIS | PTD | DIS | M0)) /*MMC2_DAT5*/\ + MUX_VAL(CP(MMC2_DAT6), (IDIS | PTD | DIS | M0)) /*MMC2_DAT6 */\ + MUX_VAL(CP(MMC2_DAT7), (IEN | PTU | EN | M0)) /*MMC2_DAT7*/\ + /*Bluetooth*/\ + MUX_VAL(CP(MCBSP3_DX), (IDIS | PTD | DIS | M0)) /*McBSP3_DX*/\ + MUX_VAL(CP(MCBSP3_DR), (IEN | PTD | DIS | M0)) /*McBSP3_DR*/\ + MUX_VAL(CP(MCBSP3_CLKX), (IEN | PTD | DIS | M0)) /*McBSP3_CLKX */\ + MUX_VAL(CP(MCBSP3_FSX), (IEN | PTD | DIS | M0)) /*McBSP3_FSX*/\ + MUX_VAL(CP(UART2_CTS), (IEN | PTU | EN | M0)) /*UART2_CTS*/\ + MUX_VAL(CP(UART2_RTS), (IDIS | PTD | DIS | M0)) /*UART2_RTS*/\ + MUX_VAL(CP(UART2_TX), (IDIS | PTD | DIS | M0)) /*UART2_TX*/\ + MUX_VAL(CP(UART2_RX), (IEN | PTD | DIS | M0)) /*UART2_RX*/\ + /*Modem Interface */\ + MUX_VAL(CP(UART1_TX), (IDIS | PTD | DIS | M0)) /*UART1_TX*/\ + MUX_VAL(CP(UART1_RTS), (IDIS | PTD | DIS | M0)) /*UART1_RTS*/\ + MUX_VAL(CP(UART1_CTS), (IEN | PTU | DIS | M0)) /*UART1_CTS*/\ + MUX_VAL(CP(UART1_RX), (IEN | PTD | DIS | M0)) /*UART1_RX*/\ + MUX_VAL(CP(MCBSP4_CLKX), (IDIS | PTD | DIS | M4)) /*GPIO_152*/\ + /* - LCD_INI*/\ + MUX_VAL(CP(MCBSP4_DR), (IDIS | PTD | DIS | M4)) /*GPIO_153*/\ + /* - LCD_ENVDD */\ + MUX_VAL(CP(MCBSP4_DX), (IDIS | PTD | DIS | M4)) /*GPIO_154*/\ + /* - LCD_QVGA/nVGA */\ + MUX_VAL(CP(MCBSP4_FSX), (IDIS | PTD | DIS | M4)) /*GPIO_155*/\ + /* - LCD_RESB */\ + MUX_VAL(CP(MCBSP1_CLKR), (IEN | PTD | DIS | M0)) /*MCBSP1_CLKR */\ + MUX_VAL(CP(MCBSP1_FSR), (IDIS | PTU | EN | M0)) /*MCBSP1_FSR*/\ + MUX_VAL(CP(MCBSP1_DX), (IDIS | PTD | DIS | M0)) /*MCBSP1_DX*/\ + MUX_VAL(CP(MCBSP1_DR), (IEN | PTD | DIS | M0)) /*MCBSP1_DR*/\ + MUX_VAL(CP(MCBSP_CLKS), (IEN | PTU | DIS | M0)) /*MCBSP_CLKS */\ + MUX_VAL(CP(MCBSP1_FSX), (IEN | PTD | DIS | M0)) /*MCBSP1_FSX*/\ + MUX_VAL(CP(MCBSP1_CLKX), (IEN | PTD | DIS | M0)) /*MCBSP1_CLKX */\ + /*Serial Interface*/\ + MUX_VAL(CP(UART3_CTS_RCTX), (IEN | PTD | EN | M0)) /*UART3_CTS_*/\ + /* RCTX*/\ + MUX_VAL(CP(UART3_RTS_SD), (IDIS | PTD | DIS | M0)) /*UART3_RTS_SD */\ + MUX_VAL(CP(UART3_RX_IRRX), (IEN | PTD | DIS | M0)) /*UART3_RX_IRRX*/\ + MUX_VAL(CP(UART3_TX_IRTX), (IDIS | PTD | DIS | M0)) /*UART3_TX_IRTX*/\ + MUX_VAL(CP(HSUSB0_CLK), (IEN | PTD | DIS | M0)) /*HSUSB0_CLK*/\ + MUX_VAL(CP(HSUSB0_STP), (IDIS | PTU | EN | M0)) /*HSUSB0_STP*/\ + MUX_VAL(CP(HSUSB0_DIR), (IEN | PTD | DIS | M0)) /*HSUSB0_DIR*/\ + MUX_VAL(CP(HSUSB0_NXT), (IEN | PTD | DIS | M0)) /*HSUSB0_NXT*/\ + MUX_VAL(CP(HSUSB0_DATA0), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA0*/\ + MUX_VAL(CP(HSUSB0_DATA1), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA1*/\ + MUX_VAL(CP(HSUSB0_DATA2), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA2*/\ + MUX_VAL(CP(HSUSB0_DATA3), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA3*/\ + MUX_VAL(CP(HSUSB0_DATA4), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA4*/\ + MUX_VAL(CP(HSUSB0_DATA5), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA5*/\ + MUX_VAL(CP(HSUSB0_DATA6), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA6*/\ + MUX_VAL(CP(HSUSB0_DATA7), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA7*/\ + MUX_VAL(CP(I2C1_SCL), (IEN | PTU | EN | M0)) /*I2C1_SCL*/\ + MUX_VAL(CP(I2C1_SDA), (IEN | PTU | EN | M0)) /*I2C1_SDA*/\ + MUX_VAL(CP(I2C2_SCL), (IEN | PTU | EN | M0)) /*I2C2_SCL*/\ + MUX_VAL(CP(I2C2_SDA), (IEN | PTU | EN | M0)) /*I2C2_SDA*/\ + MUX_VAL(CP(I2C3_SCL), (IEN | PTU | EN | M0)) /*I2C3_SCL*/\ + MUX_VAL(CP(I2C3_SDA), (IEN | PTU | EN | M0)) /*I2C3_SDA*/\ + MUX_VAL(CP(I2C4_SCL), (IEN | PTU | EN | M0)) /*I2C4_SCL*/\ + MUX_VAL(CP(I2C4_SDA), (IEN | PTU | EN | M0)) /*I2C4_SDA*/\ + MUX_VAL(CP(HDQ_SIO), (IEN | PTU | EN | M0)) /*HDQ_SIO*/\ + MUX_VAL(CP(MCSPI1_CLK), (IEN | PTD | DIS | M0)) /*McSPI1_CLK*/\ + MUX_VAL(CP(MCSPI1_SIMO), (IEN | PTD | DIS | M0)) /*McSPI1_SIMO */\ + MUX_VAL(CP(MCSPI1_SOMI), (IEN | PTD | DIS | M0)) /*McSPI1_SOMI */\ + MUX_VAL(CP(MCSPI1_CS0), (IEN | PTD | EN | M0)) /*McSPI1_CS0*/\ + MUX_VAL(CP(MCSPI1_CS1), (IEN | PTD | EN | M4)) /*GPIO_175*/\ + /* TS_PEN_IRQ */\ + MUX_VAL(CP(MCSPI1_CS2), (IEN | PTD | DIS | M4)) /*GPIO_176*/\ + /* - LAN_INTR*/\ + MUX_VAL(CP(MCSPI1_CS3), (IEN | PTD | EN | M0)) /*McSPI1_CS3*/\ + MUX_VAL(CP(MCSPI2_CLK), (IEN | PTD | DIS | M0)) /*McSPI2_CLK*/\ + MUX_VAL(CP(MCSPI2_SIMO), (IEN | PTD | DIS | M0)) /*McSPI2_SIMO*/\ + MUX_VAL(CP(MCSPI2_SOMI), (IEN | PTD | DIS | M0)) /*McSPI2_SOMI*/\ + MUX_VAL(CP(MCSPI2_CS0), (IEN | PTD | EN | M0)) /*McSPI2_CS0*/\ + MUX_VAL(CP(MCSPI2_CS1), (IEN | PTD | EN | M0)) /*McSPI2_CS1*/\ + /*Control and debug */\ + MUX_VAL(CP(SYS_32K), (IEN | PTD | DIS | M0)) /*SYS_32K*/\ + MUX_VAL(CP(SYS_CLKREQ), (IEN | PTD | DIS | M0)) /*SYS_CLKREQ*/\ + MUX_VAL(CP(SYS_NIRQ), (IEN | PTU | EN | M0)) /*SYS_nIRQ*/\ + MUX_VAL(CP(SYS_BOOT0), (IEN | PTD | DIS | M4)) /*GPIO_2*/\ + /* - PEN_IRQ */\ + MUX_VAL(CP(SYS_BOOT1), (IEN | PTD | DIS | M4)) /*GPIO_3 */\ + MUX_VAL(CP(SYS_BOOT2), (IEN | PTD | DIS | M4)) /*GPIO_4*/\ + MUX_VAL(CP(SYS_BOOT3), (IEN | PTD | DIS | M4)) /*GPIO_5*/\ + MUX_VAL(CP(SYS_BOOT4), (IEN | PTD | DIS | M4)) /*GPIO_6*/\ + MUX_VAL(CP(SYS_BOOT5), (IEN | PTD | DIS | M4)) /*GPIO_7*/\ + MUX_VAL(CP(SYS_BOOT6), (IDIS | PTD | DIS | M4)) /*GPIO_8*/\ + /* - VIO_1V8*/\ + MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0)) /*SYS_OFF_MODE*/\ + MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M0)) /*SYS_CLKOUT1*/\ + MUX_VAL(CP(SYS_CLKOUT2), (IEN | PTU | EN | M0)) /*SYS_CLKOUT2*/\ + MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0)) /*JTAG_nTRST*/\ + MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0)) /*JTAG_TCK*/\ + MUX_VAL(CP(JTAG_TMS), (IEN | PTD | DIS | M0)) /*JTAG_TMS*/\ + MUX_VAL(CP(JTAG_TDI), (IEN | PTD | DIS | M0)) /*JTAG_TDI*/\ + MUX_VAL(CP(JTAG_EMU0), (IEN | PTD | DIS | M0)) /*JTAG_EMU0*/\ + MUX_VAL(CP(JTAG_EMU1), (IEN | PTD | DIS | M0)) /*JTAG_EMU1*/\ + MUX_VAL(CP(ETK_CLK_ES2), (IDIS | PTU | EN | M0)) /*ETK_CLK*/\ + MUX_VAL(CP(ETK_CTL_ES2), (IDIS | PTD | DIS | M0)) /*ETK_CTL*/\ + MUX_VAL(CP(ETK_D0_ES2 ), (IEN | PTD | DIS | M0)) /*ETK_D0*/\ + MUX_VAL(CP(ETK_D1_ES2 ), (IEN | PTD | DIS | M0)) /*ETK_D1*/\ + MUX_VAL(CP(ETK_D2_ES2 ), (IEN | PTD | EN | M0)) /*ETK_D2*/\ + MUX_VAL(CP(ETK_D3_ES2 ), (IEN | PTD | DIS | M0)) /*ETK_D3*/\ + MUX_VAL(CP(ETK_D4_ES2 ), (IEN | PTD | DIS | M0)) /*ETK_D4*/\ + MUX_VAL(CP(ETK_D5_ES2 ), (IEN | PTD | DIS | M0)) /*ETK_D5*/\ + MUX_VAL(CP(ETK_D6_ES2 ), (IEN | PTD | DIS | M0)) /*ETK_D6*/\ + MUX_VAL(CP(ETK_D7_ES2 ), (IEN | PTD | DIS | M0)) /*ETK_D7*/\ + MUX_VAL(CP(ETK_D8_ES2 ), (IEN | PTD | DIS | M0)) /*ETK_D8*/\ + MUX_VAL(CP(ETK_D9_ES2 ), (IEN | PTD | DIS | M0)) /*ETK_D9*/\ + MUX_VAL(CP(ETK_D10_ES2), (IEN | PTD | DIS | M0)) /*ETK_D10*/\ + MUX_VAL(CP(ETK_D11_ES2), (IEN | PTD | DIS | M0)) /*ETK_D11*/\ + MUX_VAL(CP(ETK_D12_ES2), (IEN | PTD | DIS | M0)) /*ETK_D12*/\ + MUX_VAL(CP(ETK_D13_ES2), (IEN | PTD | DIS | M0)) /*ETK_D13*/\ + MUX_VAL(CP(ETK_D14_ES2), (IEN | PTD | DIS | M0)) /*ETK_D14*/\ + MUX_VAL(CP(ETK_D15_ES2), (IEN | PTD | DIS | M0)) /*ETK_D15*/\ + /*Die to Die */\ + MUX_VAL(CP(D2D_MCAD1), (IEN | PTD | EN | M0)) /*d2d_mcad1*/\ + MUX_VAL(CP(D2D_MCAD2), (IEN | PTD | EN | M0)) /*d2d_mcad2*/\ + MUX_VAL(CP(D2D_MCAD3), (IEN | PTD | EN | M0)) /*d2d_mcad3*/\ + MUX_VAL(CP(D2D_MCAD4), (IEN | PTD | EN | M0)) /*d2d_mcad4*/\ + MUX_VAL(CP(D2D_MCAD5), (IEN | PTD | EN | M0)) /*d2d_mcad5*/\ + MUX_VAL(CP(D2D_MCAD6), (IEN | PTD | EN | M0)) /*d2d_mcad6*/\ + MUX_VAL(CP(D2D_MCAD7), (IEN | PTD | EN | M0)) /*d2d_mcad7*/\ + MUX_VAL(CP(D2D_MCAD8), (IEN | PTD | EN | M0)) /*d2d_mcad8*/\ + MUX_VAL(CP(D2D_MCAD9), (IEN | PTD | EN | M0)) /*d2d_mcad9*/\ + MUX_VAL(CP(D2D_MCAD10), (IEN | PTD | EN | M0)) /*d2d_mcad10*/\ + MUX_VAL(CP(D2D_MCAD11), (IEN | PTD | EN | M0)) /*d2d_mcad11*/\ + MUX_VAL(CP(D2D_MCAD12), (IEN | PTD | EN | M0)) /*d2d_mcad12*/\ + MUX_VAL(CP(D2D_MCAD13), (IEN | PTD | EN | M0)) /*d2d_mcad13*/\ + MUX_VAL(CP(D2D_MCAD14), (IEN | PTD | EN | M0)) /*d2d_mcad14*/\ + MUX_VAL(CP(D2D_MCAD15), (IEN | PTD | EN | M0)) /*d2d_mcad15*/\ + MUX_VAL(CP(D2D_MCAD16), (IEN | PTD | EN | M0)) /*d2d_mcad16*/\ + MUX_VAL(CP(D2D_MCAD17), (IEN | PTD | EN | M0)) /*d2d_mcad17*/\ + MUX_VAL(CP(D2D_MCAD18), (IEN | PTD | EN | M0)) /*d2d_mcad18*/\ + MUX_VAL(CP(D2D_MCAD19), (IEN | PTD | EN | M0)) /*d2d_mcad19*/\ + MUX_VAL(CP(D2D_MCAD20), (IEN | PTD | EN | M0)) /*d2d_mcad20*/\ + MUX_VAL(CP(D2D_MCAD21), (IEN | PTD | EN | M0)) /*d2d_mcad21*/\ + MUX_VAL(CP(D2D_MCAD22), (IEN | PTD | EN | M0)) /*d2d_mcad22*/\ + MUX_VAL(CP(D2D_MCAD23), (IEN | PTD | EN | M0)) /*d2d_mcad23*/\ + MUX_VAL(CP(D2D_MCAD24), (IEN | PTD | EN | M0)) /*d2d_mcad24*/\ + MUX_VAL(CP(D2D_MCAD25), (IEN | PTD | EN | M0)) /*d2d_mcad25*/\ + MUX_VAL(CP(D2D_MCAD26), (IEN | PTD | EN | M0)) /*d2d_mcad26*/\ + MUX_VAL(CP(D2D_MCAD27), (IEN | PTD | EN | M0)) /*d2d_mcad27*/\ + MUX_VAL(CP(D2D_MCAD28), (IEN | PTD | EN | M0)) /*d2d_mcad28*/\ + MUX_VAL(CP(D2D_MCAD29), (IEN | PTD | EN | M0)) /*d2d_mcad29*/\ + MUX_VAL(CP(D2D_MCAD30), (IEN | PTD | EN | M0)) /*d2d_mcad30*/\ + MUX_VAL(CP(D2D_MCAD31), (IEN | PTD | EN | M0)) /*d2d_mcad31*/\ + MUX_VAL(CP(D2D_MCAD32), (IEN | PTD | EN | M0)) /*d2d_mcad32*/\ + MUX_VAL(CP(D2D_MCAD33), (IEN | PTD | EN | M0)) /*d2d_mcad33*/\ + MUX_VAL(CP(D2D_MCAD34), (IEN | PTD | EN | M0)) /*d2d_mcad34*/\ + MUX_VAL(CP(D2D_MCAD35), (IEN | PTD | EN | M0)) /*d2d_mcad35*/\ + MUX_VAL(CP(D2D_MCAD36), (IEN | PTD | EN | M0)) /*d2d_mcad36*/\ + MUX_VAL(CP(D2D_CLK26MI), (IEN | PTD | DIS | M0)) /*d2d_clk26mi*/\ + MUX_VAL(CP(D2D_NRESPWRON), (IEN | PTD | EN | M0)) /*d2d_nrespwron*/\ + MUX_VAL(CP(D2D_NRESWARM), (IEN | PTU | EN | M0)) /*d2d_nreswarm */\ + MUX_VAL(CP(D2D_ARM9NIRQ), (IEN | PTD | DIS | M0)) /*d2d_arm9nirq */\ + MUX_VAL(CP(D2D_UMA2P6FIQ), (IEN | PTD | DIS | M0)) /*d2d_uma2p6fiq*/\ + MUX_VAL(CP(D2D_SPINT), (IEN | PTD | EN | M0)) /*d2d_spint*/\ + MUX_VAL(CP(D2D_FRINT), (IEN | PTD | EN | M0)) /*d2d_frint*/\ + MUX_VAL(CP(D2D_DMAREQ0), (IEN | PTD | DIS | M0)) /*d2d_dmareq0*/\ + MUX_VAL(CP(D2D_DMAREQ1), (IEN | PTD | DIS | M0)) /*d2d_dmareq1*/\ + MUX_VAL(CP(D2D_DMAREQ2), (IEN | PTD | DIS | M0)) /*d2d_dmareq2*/\ + MUX_VAL(CP(D2D_DMAREQ3), (IEN | PTD | DIS | M0)) /*d2d_dmareq3*/\ + MUX_VAL(CP(D2D_N3GTRST), (IEN | PTD | DIS | M0)) /*d2d_n3gtrst*/\ + MUX_VAL(CP(D2D_N3GTDI), (IEN | PTD | DIS | M0)) /*d2d_n3gtdi*/\ + MUX_VAL(CP(D2D_N3GTDO), (IEN | PTD | DIS | M0)) /*d2d_n3gtdo*/\ + MUX_VAL(CP(D2D_N3GTMS), (IEN | PTD | DIS | M0)) /*d2d_n3gtms*/\ + MUX_VAL(CP(D2D_N3GTCK), (IEN | PTD | DIS | M0)) /*d2d_n3gtck*/\ + MUX_VAL(CP(D2D_N3GRTCK), (IEN | PTD | DIS | M0)) /*d2d_n3grtck*/\ + MUX_VAL(CP(D2D_MSTDBY), (IEN | PTU | EN | M0)) /*d2d_mstdby*/\ + MUX_VAL(CP(D2D_SWAKEUP), (IEN | PTD | EN | M0)) /*d2d_swakeup*/\ + MUX_VAL(CP(D2D_IDLEREQ), (IEN | PTD | DIS | M0)) /*d2d_idlereq*/\ + MUX_VAL(CP(D2D_IDLEACK), (IEN | PTU | EN | M0)) /*d2d_idleack*/\ + MUX_VAL(CP(D2D_MWRITE), (IEN | PTD | DIS | M0)) /*d2d_mwrite*/\ + MUX_VAL(CP(D2D_SWRITE), (IEN | PTD | DIS | M0)) /*d2d_swrite*/\ + MUX_VAL(CP(D2D_MREAD), (IEN | PTD | DIS | M0)) /*d2d_mread*/\ + MUX_VAL(CP(D2D_SREAD), (IEN | PTD | DIS | M0)) /*d2d_sread*/\ + MUX_VAL(CP(D2D_MBUSFLAG), (IEN | PTD | DIS | M0)) /*d2d_mbusflag*/\ + MUX_VAL(CP(D2D_SBUSFLAG), (IEN | PTD | DIS | M0)) /*d2d_sbusflag*/\ + MUX_VAL(CP(SDRC_CKE0), (IDIS | PTU | EN | M0)) /*sdrc_cke0*/\ + MUX_VAL(CP(SDRC_CKE1), (IDIS | PTD | DIS | M7)) /*sdrc_cke1*/\ + +#endif
- i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE);
- setup_net_chip();
- Routine: set_muxconf_regs
- Description: Setting up the configuration Mux registers specific to the
mode.
- MUX_EVM();
- Routine: setup_net_chip
- Description: Setting up the configuration GPMC registers specific to the
here.
in this function please add some blank line to make the code more readable
- int i = 0;
- /* Configure GPMC registers */
- (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x0150)) = 0x00001000;
- (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x0154)) = 0x001e1e01;
- (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x0158)) = 0x00080300;
- (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x015C)) = 0x1c091c09;
- (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x0160)) = 0x04181f1f;
- (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x0164)) = 0x00000FCF;
- (*(volatile int *)(OMAP34XX_GPMC_BASE + 0x0168)) = 0x00000f6c;
- /* Configure PIN MUX registers */
- /* Enable GPMC Pin Mux Registers */
- /* Enable GPMC_CLK Pin in CONTROL_PADCONF_gpmc_ncs7 register */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xBC)) |= 0x00180000;
- /* Enable CS5 Pin in CONTROL_PADCONF_gpmc_ncs5 register */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xB8)) |= 0x00000018;
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xB8)) &= 0xFFFFFFF8;
- /* Enable offmode for nwe in CONTROL_PADCONF_GPMC_NWE register */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xC4)) |= 0x00000F00;
- /* En off mode for noe and ale in CONTROL_PADCONF_GPMC_NADV_ALE reg */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xC0)) |= 0x0E000E00;
- /* Enable gpmc_nbe0_cle in CONTROL_PADCONF_GPMC_NWE register */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xC4)) |= 0x00180000;
- /* Enable gpmc_nbe1 in CONTROL_PADCONF_GPMC_NBE1 register and
- configuring the mux mode to 0 */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xC8)) |= 0x00000018;
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xC8)) &= 0xFFFFFFF8;
- /* Enable d15 in CONTROL_PADCONF_GPMC_D15 register */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xAC)) |= 0x00000018;
- /* Enable d14 - d13 in CONTROL_PADCONF_GPMC_D13 register */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xA8)) |= 0x00180018;
- /* Enable d12 - d11 in CONTROL_PADCONF_GPMC_D11 register */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xA4)) |= 0x00180018;
- /* Enable d10 - d9 in CONTROL_PADCONF_GPMC_D9 register */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0xA0)) |= 0x00180018;
- /* Enable d8 - d7 in CONTROL_PADCONF_GPMC_D7 register */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x9C)) |= 0x00180018;
- /* Enable d6 - d5 in CONTROL_PADCONF_GPMC_D5 register */
- (*(volatile int *)(OMAP34XX_CTRL_BASE + 0x98)) |= 0x00180018;
Best Regards, J.
Dear Jean-Christophe PLAGNIOL-VILLARD,
- setup_net_chip();
mode.
- MUX_EVM();
here.
- int i = 0;
And please use accessor functions / macros to access the registers. Access through volatile pointers is considered a Bad Thing (TM).
dirk.behme@googlemail.com
