[U-Boot] [PATCH] davinci: spl: Create board_init_f for explicit initialization
The arch_cpu_init() and preloader_console_init() functions were not getting called until board_init_r() as part of the spl_board_init() functions. This patch explicitly moves these initialization sequences earlier in startup, and now clears BSS per the suggested workflow in the README. This also means that CONFIG_SPL_BOARD_INIT can be removed from the defconfig
Suggested-by: Sekhar Nori nsekhar@ti.com Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/mach-davinci/spl.c b/arch/arm/mach-davinci/spl.c index 103639e347..05c78f1801 100644 --- a/arch/arm/mach-davinci/spl.c +++ b/arch/arm/mach-davinci/spl.c @@ -37,6 +37,33 @@ void spl_board_init(void) preloader_console_init(); }
+void board_init_f(ulong boot_flags) +{ + gd->flags = boot_flags; + gd->have_console = 0; + + if (!(gd->flags & GD_FLG_SPL_INIT)) { + if (spl_init()) + hang(); + } + + arch_cpu_init(); + + board_early_init_f(); + + /* setup GP timer */ + timer_init(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + /* load/boot image from boot device */ + board_init_r(NULL, 0); +} + u32 spl_boot_device(void) { switch (davinci_syscfg_regs->bootcfg) { diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 8c16d5c4f5..c095058282 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -21,7 +21,6 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_TEXT_BASE=0x80000000 -CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index b8eac0e659..7271016346 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -19,7 +19,6 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_TEXT_BASE=0x80000000 -CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_NAND_SUPPORT=y
- gd->flags = boot_flags;
- gd->have_console = 0;
- if (!(gd->flags & GD_FLG_SPL_INIT)) {
if (spl_init())
hang();
- arch_cpu_init();
- board_early_init_f();
- /* setup GP timer */
- timer_init();
- /* UART clocks enabled and gd valid - init serial console */
- preloader_console_init();
- /* Clear the BSS. */
- memset(__bss_start, 0, __bss_end - __bss_start);
- /* load/boot image from boot device */
- board_init_r(NULL, 0);
This seems incorrect. board_init_r() is already called by arch/arm/lib/crt0.S. A much simple fix should do. I was able to get back to working on this today. Will send a patch soon.
Thanks, Sekhar
if (spl_init())
hang();
arch_cpu_init();
timer_init();
I used the board_init_f functions I found for a bunch of various other boards as the basis and they do this, but I confirmed that removing the board_init_r() call from here appears to work correctly. However, I'll test your patch when it's available.
adam
Thanks, Sekhar
if (spl_init())
hang();
arch_cpu_init();
timer_init();
I reduced it further
void board_init_f(ulong dummy) { arch_cpu_init(); spl_early_init(); board_early_init_f(); preloader_console_init(); }
adam
Thanks, Sekhar
Tom,
You can drop this. Use Sekhar's implementation [1] instead of mine.
[1] - https://patchwork.ozlabs.org/patch/1107760/
adam
if (spl_init())
hang();
arch_cpu_init();
timer_init();
u32 spl_boot_device(void) { switch (davinci_syscfg_regs->bootcfg) { diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 8c16d5c4f5..c095058282 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -21,7 +21,6 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_TEXT_BASE=0x80000000 -CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_SPI_LOAD=y diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index b8eac0e659..7271016346 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -19,7 +19,6 @@ CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_TEXT_BASE=0x80000000 -CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_NAND_SUPPORT=y -- 2.17.1
Adam Ford
Sekhar Nori
