[U-Boot] [PATCH 01/13] pico-imx6ul: Convert to distro config
Instead of keeping a custom environment, use a more generic approach by switching to disto config.
Signed-off-by: Fabio Estevam festevam@gmail.com Signed-off-by: Otavio Salvador otavio@ossystems.com.br ---
configs/pico-imx6ul_defconfig | 2 + include/configs/pico-imx6ul.h | 69 ++++++++++------------------------- 2 files changed, 21 insertions(+), 50 deletions(-)
diff --git a/configs/pico-imx6ul_defconfig b/configs/pico-imx6ul_defconfig index 59ef7b7f22..3f969a2d6e 100644 --- a/configs/pico-imx6ul_defconfig +++ b/configs/pico-imx6ul_defconfig @@ -4,7 +4,9 @@ CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_TARGET_PICO_IMX6UL=y # CONFIG_CMD_BMODE is not set CONFIG_NR_DRAM_BANKS=1 +CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/technexion/pico-imx6ul/imximage.cfg" +CONFIG_BOOTCOMMAND="run finduuid; run distro_bootcmd" CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y CONFIG_DEFAULT_FDT_FILE="imx6ul-pico-hobbit.dtb" diff --git a/include/configs/pico-imx6ul.h b/include/configs/pico-imx6ul.h index 80a2d1fbdb..1a148bf1a6 100644 --- a/include/configs/pico-imx6ul.h +++ b/include/configs/pico-imx6ul.h @@ -52,64 +52,33 @@ #define CONFIG_SYS_MMC_IMG_LOAD_PART 1
#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ "image=zImage\0" \ "console=ttymxc5\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ - "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ "fdt_addr=0x83000000\0" \ - "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ - "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ + "fdt_addr_r=0x83000000\0" \ + "kernel_addr_r=" __stringify(CONFIG_LOADADDR) "\0" \ + "pxefile_addr_r=" __stringify(CONFIG_LOADADDR) "\0" \ + "ramdisk_addr_r=0x83000000\0" \ + "ramdiskaddr=0x83000000\0" \ + "scriptaddr=" __stringify(CONFIG_LOADADDR) "\0" \ CONFIG_DFU_ENV_SETTINGS \ - "finduuid=part uuid mmc 0:2 uuid\0" \ + "finduuid=part uuid mmc 0:1 uuid\0" \ "partitions=" \ "uuid_disk=${uuid_gpt_disk};" \ - "name=boot,size=16MiB;name=rootfs,size=0,uuid=${uuid_gpt_rootfs}\0" \ - "setup_emmc=gpt write mmc 0 $partitions; reset;\0" \ - "mmcargs=setenv bootargs console=${console},${baudrate} " \ - "root=PARTUUID=${uuid} rootwait rw\0" \ - "loadimage=load mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ - "loadfdt=load mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ - "mmcboot=echo Booting from mmc ...; " \ - "run finduuid; " \ - "run mmcargs; " \ - "if run loadfdt; then " \ - "bootz ${loadaddr} - ${fdt_addr}; " \ - "else " \ - "echo WARN: Cannot load the DT; " \ - "fi;\0" \ - "netargs=setenv bootargs console=${console},${baudrate} " \ - "root=/dev/nfs " \ - "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ - "netboot=echo Booting from net ...; " \ - "run netargs; " \ - "if test ${ip_dyn} = yes; then " \ - "setenv get_cmd dhcp; " \ - "else " \ - "setenv get_cmd tftp; " \ - "fi; " \ - "${get_cmd} ${image}; " \ - "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ - "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ - "bootz ${loadaddr} - ${fdt_addr}; " \ - "else " \ - "if test ${boot_fdt} = try; then " \ - "bootz; " \ - "else " \ - "echo WARN: Cannot load the DT; " \ - "fi; " \ - "fi; " \ - "else " \ - "bootz; " \ - "fi;\0" \ - -#define CONFIG_BOOTCOMMAND \ - "if mmc rescan; then " \ - "if run loadimage; then " \ - "run mmcboot; " \ - "else run netboot; " \ - "fi; " \ - "else run netboot; fi" + "name=rootfs,size=0,uuid=${uuid_gpt_rootfs}\0" \ + "fastboot_partition_alias_system=rootfs\0" \ + "setup_emmc=mmc dev 0; gpt write mmc 0 $partitions; reset;\0" \ + BOOTENV + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(DHCP, dhcp, na) + +#include <config_distro_bootcmd.h>
#define CONFIG_SYS_MEMTEST_START 0x80000000 #define CONFIG_SYS_MEMTEST_END CONFIG_SYS_MEMTEST_START + SZ_128M
There are two versions of imx6ul pico SOMs: one with 256MB and another one with 512MB of RAM.
Convert to SPL so that both versions can be supported.
Currently only the 256MB is tested/supported.
Signed-off-by: Fabio Estevam festevam@gmail.com Signed-off-by: Fabio Berton fabio.berton@ossystems.com.br Signed-off-by: Otavio Salvador otavio@ossystems.com.br ---
arch/arm/mach-imx/mx6/Kconfig | 1 + board/technexion/pico-imx6ul/Makefile | 2 +- board/technexion/pico-imx6ul/spl.c | 115 ++++++++++++++++++++++++++ configs/pico-imx6ul_defconfig | 14 +++- include/configs/pico-imx6ul.h | 1 + 5 files changed, 131 insertions(+), 2 deletions(-) create mode 100644 board/technexion/pico-imx6ul/spl.c
diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index a2799c436e..06c25bae36 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -402,6 +402,7 @@ config TARGET_OT1200 config TARGET_PICO_IMX6UL bool "PICO-IMX6UL-EMMC" select MX6UL + select SUPPORT_SPL
config TARGET_LITEBOARD bool "Grinn liteBoard (i.MX6UL)" diff --git a/board/technexion/pico-imx6ul/Makefile b/board/technexion/pico-imx6ul/Makefile index 8fdb7875ac..b7493df01c 100644 --- a/board/technexion/pico-imx6ul/Makefile +++ b/board/technexion/pico-imx6ul/Makefile @@ -2,4 +2,4 @@ # (C) Copyright 2015 Technexion Ltd. # (C) Copyright 2015 Freescale Semiconductor, Inc.
-obj-y := pico-imx6ul.o +obj-y := pico-imx6ul.o spl.o diff --git a/board/technexion/pico-imx6ul/spl.c b/board/technexion/pico-imx6ul/spl.c new file mode 100644 index 0000000000..6989c81946 --- /dev/null +++ b/board/technexion/pico-imx6ul/spl.c @@ -0,0 +1,115 @@ +// SPDX-License-Identifier: GPL-2.0+ +#include <asm/arch/clock.h> +#include <asm/arch/iomux.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/mx6ul_pins.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/mach-imx/boot_mode.h> +#include <linux/libfdt.h> +#include <spl.h> + +#if defined(CONFIG_SPL_BUILD) +#include <asm/arch/mx6-ddr.h> + +static struct mx6ul_iomux_grp_regs mx6_grp_ioregs = { + .grp_addds = 0x00000030, + .grp_ddrmode_ctl = 0x00020000, + .grp_b0ds = 0x00000030, + .grp_ctlds = 0x00000030, + .grp_b1ds = 0x00000030, + .grp_ddrpke = 0x00000000, + .grp_ddrmode = 0x00020000, + .grp_ddr_type = 0x00080000, +}; + +static struct mx6ul_iomux_ddr_regs mx6_ddr_ioregs = { + .dram_dqm0 = 0x00000030, + .dram_dqm1 = 0x00000030, + .dram_ras = 0x00000030, + .dram_cas = 0x00000030, + .dram_odt0 = 0x00000030, + .dram_odt1 = 0x00000030, + .dram_sdba2 = 0x00000000, + .dram_sdclk_0 = 0x00000030, + .dram_sdqs0 = 0x00000030, + .dram_sdqs1 = 0x00000030, + .dram_reset = 0x00000030, +}; + +static struct mx6_mmdc_calibration mx6_mmcd_calib = { + .p0_mpwldectrl0 = 0x00000000, + .p0_mpdgctrl0 = 0x01380134, + .p0_mprddlctl = 0x40404244, + .p0_mpwrdlctl = 0x40405050, +}; + +static struct mx6_ddr_sysinfo ddr_sysinfo = { + .dsize = 0, + .cs1_mirror = 0, + .cs_density = 32, + .ncs = 1, + .bi_on = 1, + .rtt_nom = 1, + .rtt_wr = 0, + .ralat = 5, + .walat = 0, + .mif3_mode = 3, + .rst_to_cke = 0x23, + .sde_to_rst = 0x10, + .refsel = 1, + .refr = 3, +}; + +static struct mx6_ddr3_cfg mem_ddr = { + .mem_speed = 1333, + .density = 2, + .width = 16, + .banks = 8, + .rowaddr = 14, + .coladdr = 10, + .pagesz = 2, + .trcd = 1350, + .trcmin = 4950, + .trasmin = 3600, +}; + +static void ccgr_init(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + writel(0xFFFFFFFF, &ccm->CCGR0); + writel(0xFFFFFFFF, &ccm->CCGR1); + writel(0xFFFFFFFF, &ccm->CCGR2); + writel(0xFFFFFFFF, &ccm->CCGR3); + writel(0xFFFFFFFF, &ccm->CCGR4); + writel(0xFFFFFFFF, &ccm->CCGR5); + writel(0xFFFFFFFF, &ccm->CCGR6); + writel(0xFFFFFFFF, &ccm->CCGR7); +} + +static void spl_dram_init(void) +{ + mx6ul_dram_iocfg(mem_ddr.width, &mx6_ddr_ioregs, &mx6_grp_ioregs); + mx6_dram_cfg(&ddr_sysinfo, &mx6_mmcd_calib, &mem_ddr); +} + +void board_init_f(ulong dummy) +{ + ccgr_init(); + arch_cpu_init(); + board_early_init_f(); + timer_init(); + preloader_console_init(); + spl_dram_init(); + memset(__bss_start, 0, __bss_end - __bss_start); + board_init_r(NULL, 0); +} + +void reset_cpu(ulong addr) +{ +} +#endif diff --git a/configs/pico-imx6ul_defconfig b/configs/pico-imx6ul_defconfig index 3f969a2d6e..589e67be96 100644 --- a/configs/pico-imx6ul_defconfig +++ b/configs/pico-imx6ul_defconfig @@ -1,12 +1,23 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x87800000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_TARGET_PICO_IMX6UL=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL=y +CONFIG_SPL_LIBDISK_SUPPORT=y # CONFIG_CMD_BMODE is not set CONFIG_NR_DRAM_BANKS=1 CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/technexion/pico-imx6ul/imximage.cfg" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTCOMMAND="run finduuid; run distro_bootcmd" +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_USB_HOST_SUPPORT=y +CONFIG_SPL_USB_GADGET_SUPPORT=y +CONFIG_SPL_USB_SDP_SUPPORT=y CONFIG_BOOTDELAY=3 CONFIG_SUPPORT_RAW_INITRD=y CONFIG_DEFAULT_FDT_FILE="imx6ul-pico-hobbit.dtb" @@ -21,6 +32,7 @@ CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y diff --git a/include/configs/pico-imx6ul.h b/include/configs/pico-imx6ul.h index 1a148bf1a6..14d5cc3ddb 100644 --- a/include/configs/pico-imx6ul.h +++ b/include/configs/pico-imx6ul.h @@ -12,6 +12,7 @@ #include <linux/sizes.h> #include "mx6_common.h" #include <asm/mach-imx/gpio.h> +#include "imx6_spl.h"
/* Network support */
On Fri, Aug 31, 2018 at 12:40 AM, Otavio Salvador otavio@ossystems.com.br wrote:
select SUPPORT_SPL
space
.dsize = 0,
.cs1_mirror = 0,
.cs_density = 32,
.ncs = 1,
.bi_on = 1,
.rtt_nom = 1,
.rtt_wr = 0,
.ralat = 5,
.walat = 0,
.mif3_mode = 3,
.rst_to_cke = 0x23,
.sde_to_rst = 0x10,
.refsel = 1,
.refr = 3,
.mem_speed = 1333,
.density = 2,
.width = 16,
.banks = 8,
.rowaddr = 14,
.coladdr = 10,
.pagesz = 2,
.trcd = 1350,
.trcmin = 4950,
.trasmin = 3600,
These can be know values.
Hi Jagan,
space
I am sorry, but I did not understand your comments.
Please clarify.
Thanks
Hi Fabio
On Mon, Sep 3, 2018 at 3:01 PM Fabio Estevam festevam@gmail.com wrote:
Hi Jagan,
space
are you sure that arrive to 7?
I think that it's not a good strategy to enable all the gate in general here.
Michael
Please clarify.
Thanks _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Hi Michael,
On Mon, Sep 3, 2018 at 10:05 AM, Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
You are right. CCGR7 is not available on mx6ul. I will fix it.
Yes, the main point of this patch is to convert from DCD table to SPL.
As the DCD table enables all the clocks I kept the same approach.
I agree that this can be further improved by only turning on the clocks that are used by the bootloader.
However this is subject for a separate patch.
Thanks
Hi
On Tue, Sep 4, 2018 at 2:33 PM Fabio Estevam festevam@gmail.com wrote:
Hi Michael,
Well, yes and no. Not all the bits can be writable according to the documentation if I remember and if the value you put are the value after reset and if I remember are all the clock on, you need to explain better you you write them.
Michael
Thanks
On Tue, Sep 4, 2018 at 9:41 AM, Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
0xFFFFFFFF is the value of the CCGR registers after power on reset.
It is true that some fields are marked as "reserved", but I don't see the issue in writing '11' to them since this is the POR value.
Again, I am not doing anything different than the DCD table in this aspect.
Hi Fabio
Ok, if you resend with the change discussed I'm fine with it. The reason that I'm trying to make much clean is just because I get random problem in the past just for few bits ;)
Michael
Hi Michael,
On Tue, Sep 4, 2018 at 9:53 AM, Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
Sorry, I am not sure what exactly you want me to do differently in v2.
Please clarify.
Hi
On Tue, Sep 4, 2018 at 2:56 PM Fabio Estevam festevam@gmail.com wrote:
Hi Michael,
Please clarify.
I miss v2 ;), I think
Michael
I'm just commenting since Stefano did mention the similar this [1] previously. may be he can found any random problem with setting up all 11's
[1] https://lists.denx.de/pipermail/u-boot/2017-January/279566.html
fastboot tool is a convenient way to flash the eMMC, so add support for it.
Examples of usages:
On the pico-imx6ul U-Boot prompt:
=> fastboot 0
On the Linux PC connected via USB:
1. Retrieving the U-Boot version
$ sudo fastboot getvar bootloader-version -i 0x0525 bootloader-version: U-Boot 2018.07-rc2-00130-g0881835-dirty finished. total time: 0.000s
2. Resetting the board
$ sudo fastboot reboot -i 0x0525
(this causes the pico-imx6ul to reboot)
configs/pico-imx6ul_defconfig | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/configs/pico-imx6ul_defconfig b/configs/pico-imx6ul_defconfig index 589e67be96..cae7ded1fa 100644 --- a/configs/pico-imx6ul_defconfig +++ b/configs/pico-imx6ul_defconfig @@ -45,6 +45,12 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y CONFIG_DFU_MMC=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x82000000 +CONFIG_FASTBOOT_BUF_SIZE=0x10000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y @@ -56,5 +62,4 @@ CONFIG_USB_GADGET_MANUFACTURER="FSL" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_OF_LIBFDT=y
The 'bmode' command is helpful for switching the boot media.
In the case of pico-imx6ul there are two possible boot media: eMMC or USB.
To boot from eMMC:
=> bmode emmc
To boot from USB (via Serial Download Protocol):
=> bmode usb
configs/pico-imx6ul_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/pico-imx6ul_defconfig b/configs/pico-imx6ul_defconfig index cae7ded1fa..daa898fb22 100644 --- a/configs/pico-imx6ul_defconfig +++ b/configs/pico-imx6ul_defconfig @@ -9,7 +9,6 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y -# CONFIG_CMD_BMODE is not set CONFIG_NR_DRAM_BANKS=1 CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg"
Currently only the module with 256MB of RAM is supported.
Add support for the 512MB of RAM variant as well.
board/technexion/pico-imx6ul/spl.c | 27 ++++++++++++++++++++++++--- 1 file changed, 24 insertions(+), 3 deletions(-)
diff --git a/board/technexion/pico-imx6ul/spl.c b/board/technexion/pico-imx6ul/spl.c index 6989c81946..428d3b10fb 100644 --- a/board/technexion/pico-imx6ul/spl.c +++ b/board/technexion/pico-imx6ul/spl.c @@ -69,7 +69,6 @@ static struct mx6_ddr3_cfg mem_ddr = { .density = 2, .width = 16, .banks = 8, - .rowaddr = 14, .coladdr = 10, .pagesz = 2, .trcd = 1350, @@ -91,12 +90,34 @@ static void ccgr_init(void) writel(0xFFFFFFFF, &ccm->CCGR7); }
-static void spl_dram_init(void) +static void imx6ul_spl_dram_cfg_size(u32 ram_size) { + if (ram_size == SZ_256M) + mem_ddr.rowaddr = 14; + else + mem_ddr.rowaddr = 15; + mx6ul_dram_iocfg(mem_ddr.width, &mx6_ddr_ioregs, &mx6_grp_ioregs); mx6_dram_cfg(&ddr_sysinfo, &mx6_mmcd_calib, &mem_ddr); }
+static void imx6ul_spl_dram_cfg(void) +{ + ulong ram_size_test, ram_size = 0; + + for (ram_size = SZ_512M; ram_size >= SZ_256M; ram_size >>= 1) { + imx6ul_spl_dram_cfg_size(ram_size); + ram_size_test = get_ram_size((long int *)PHYS_SDRAM, ram_size); + if (ram_size_test == ram_size) + break; + } + + if (ram_size < SZ_256M) { + puts("ERROR: DRAM size detection failed\n"); + hang(); + } +} + void board_init_f(ulong dummy) { ccgr_init(); @@ -104,7 +125,7 @@ void board_init_f(ulong dummy) board_early_init_f(); timer_init(); preloader_console_init(); - spl_dram_init(); + imx6ul_spl_dram_cfg(); memset(__bss_start, 0, __bss_end - __bss_start); board_init_r(NULL, 0); }
Update the README file to take into accound the switch to SPL.
board/technexion/pico-imx7d/README | 24 +++++++++++++++++------- 1 file changed, 17 insertions(+), 7 deletions(-)
diff --git a/board/technexion/pico-imx7d/README b/board/technexion/pico-imx7d/README index aa9d72c5d1..24eb97e82c 100644 --- a/board/technexion/pico-imx7d/README +++ b/board/technexion/pico-imx7d/README @@ -11,7 +11,13 @@ $ make mrproper $ make pico-imx7d_defconfig $ make
-This generates the U-Boot binary called u-boot.imx. +This generates the SPL and u-boot.img binaries. + +1. Loading U-Boot via USB Serial Download Protocol + +Note: This method is convenient for development purposes. +If the eMMC has already a U-Boot flashed with DFU support then +the user can go to step 2 below in order to update U-Boot.
Put pico board in USB download mode (refer to the PICO-iMX7D Quick Start Guide page 3) @@ -22,11 +28,15 @@ Connect a USB cable between the OTG pico port and the host PC.
Open a terminal program such as minicom.
-Copy u-boot.imx to the imx_usb_loader folder. +Copy SPL and u-boot.img to the imx_usb_loader folder. + +Load the SPL binary via USB:
-Load u-boot.imx via USB: +$ sudo ./imx_usb SPL
-$ sudo ./imx_usb u-boot.imx +Load the u-boot.img binary via USB: + +$ sudo ./imx_usb u-boot.img
Then U-Boot starts and its messages appear in the console program.
@@ -35,16 +45,16 @@ Use the default environment variables: => env default -f -a => saveenv
+2. Flashing U-Boot into the eMMC + Run the DFU agent so we can flash the new images using dfu-util tool:
=> dfu 0 mmc 0
-Flash SPL into the eMMC: +Flash SPL and u-boot.img into the eMMC running the following commands on a PC:
$ sudo dfu-util -D SPL -a spl
-Flash u-boot.img into the eMMC: - $ sudo dfu-util -D u-boot.img -a u-boot
Remove power from the pico board.
board/technexion/pico-imx6ul/README | 26 ++++++++++++++++++++------ 1 file changed, 20 insertions(+), 6 deletions(-)
diff --git a/board/technexion/pico-imx6ul/README b/board/technexion/pico-imx6ul/README index 2f66095097..a5415714ee 100644 --- a/board/technexion/pico-imx6ul/README +++ b/board/technexion/pico-imx6ul/README @@ -13,7 +13,13 @@ $ make mrproper $ make pico-imx6ul_defconfig $ make
-This will generate the U-Boot binary called u-boot.imx. +This generates the SPL and u-boot.img binaries. + +1. Loading U-Boot via USB Serial Download Protocol + +Note: This method is convenient for development purposes. +If the eMMC has already a U-Boot flashed with DFU support then +the user can go to step 2 below in order to update U-Boot.
Put pico board in USB download mode (refer to the document http://www.wandboard.org/images/hobbit/hobbitboard-imx6ul-reva1.pdf page 15) @@ -24,11 +30,15 @@ Connect a USB cable between the OTG pico port and the host PC
Then U-Boot should start and its messages will appear in the console program.
@@ -37,12 +47,16 @@ Use the default environment variables: => env default -f -a => saveenv
+2. Flashing U-Boot into the eMMC + Run the DFU command: => dfu 0 mmc 0
-Transfer u-boot.imx that will be flashed into the eMMC: +Flash SPL and u-boot.img into the eMMC running the following commands on a PC: + +$ sudo dfu-util -D SPL -a spl
-$ sudo dfu-util -D u-boot.imx -a boot +$ sudo dfu-util -D u-boot.img -a u-boot
Then on the U-Boot prompt the following message should be seen after a successful upgrade:
Due the changes in previous commits, we need to resync the defconfig to reduce noise in next commits.
configs/pico-imx6ul_defconfig | 20 ++++---------------- 1 file changed, 4 insertions(+), 16 deletions(-)
diff --git a/configs/pico-imx6ul_defconfig b/configs/pico-imx6ul_defconfig index daa898fb22..56cb4810dc 100644 --- a/configs/pico-imx6ul_defconfig +++ b/configs/pico-imx6ul_defconfig @@ -9,43 +9,31 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y CONFIG_SPL_LIBDISK_SUPPORT=y -CONFIG_NR_DRAM_BANKS=1 CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" +CONFIG_BOOTDELAY=3 CONFIG_BOOTCOMMAND="run finduuid; run distro_bootcmd" +CONFIG_DEFAULT_FDT_FILE="imx6ul-pico-hobbit.dtb" +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_USB_HOST_SUPPORT=y CONFIG_SPL_USB_GADGET_SUPPORT=y CONFIG_SPL_USB_SDP_SUPPORT=y -CONFIG_BOOTDELAY=3 -CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_DEFAULT_FDT_FILE="imx6ul-pico-hobbit.dtb" -CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y -CONFIG_CMD_PART=y CONFIG_CMD_USB=y CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y CONFIG_DFU_MMC=y CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_BUF_ADDR=0x82000000 CONFIG_FASTBOOT_BUF_SIZE=0x10000000 CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=0
Currently the baseboards do not offer a way to autodetect which one is in use, so we ask the user if no value has been set.
configs/pico-imx6ul_defconfig | 5 +++-- include/configs/pico-imx6ul.h | 10 ++++++++++ 2 files changed, 13 insertions(+), 2 deletions(-)
diff --git a/configs/pico-imx6ul_defconfig b/configs/pico-imx6ul_defconfig index 56cb4810dc..3d4063b136 100644 --- a/configs/pico-imx6ul_defconfig +++ b/configs/pico-imx6ul_defconfig @@ -13,13 +13,14 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 -CONFIG_BOOTCOMMAND="run finduuid; run distro_bootcmd" -CONFIG_DEFAULT_FDT_FILE="imx6ul-pico-hobbit.dtb" +CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" +CONFIG_DEFAULT_FDT_FILE="ask" CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_USB_HOST_SUPPORT=y CONFIG_SPL_USB_GADGET_SUPPORT=y CONFIG_SPL_USB_SDP_SUPPORT=y +CONFIG_CMD_BOOTMENU=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_DFU=y # CONFIG_CMD_FLASH is not set diff --git a/include/configs/pico-imx6ul.h b/include/configs/pico-imx6ul.h index 14d5cc3ddb..2276f72bae 100644 --- a/include/configs/pico-imx6ul.h +++ b/include/configs/pico-imx6ul.h @@ -50,6 +50,10 @@ "/imx6ul-pico-hobbit.dtb ext4 0 1;" \ "rootfs part 0 2\0" \
+#define BOOTMENU_ENV \ + "bootmenu_0=Boot using PICO-Hobbit baseboard=" \ + "setenv fdtfile imx6ul-pico-hobbit.dtb\0" \ + #define CONFIG_SYS_MMC_IMG_LOAD_PART 1
#define CONFIG_EXTRA_ENV_SETTINGS \ @@ -59,6 +63,7 @@ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ + BOOTMENU_ENV \ "fdt_addr=0x83000000\0" \ "fdt_addr_r=0x83000000\0" \ "kernel_addr_r=" __stringify(CONFIG_LOADADDR) "\0" \ @@ -67,6 +72,11 @@ "ramdiskaddr=0x83000000\0" \ "scriptaddr=" __stringify(CONFIG_LOADADDR) "\0" \ CONFIG_DFU_ENV_SETTINGS \ + "findfdt=" \ + "if test $fdtfile = ask ; then " \ + "bootmenu -1; fi;" \ + "if test $fdtfile != ask ; then " \ + "saveenv; fi;\0" \ "finduuid=part uuid mmc 0:1 uuid\0" \ "partitions=" \ "uuid_disk=${uuid_gpt_disk};" \
This rework the DFU settings so it supports the SPL and U-Boot image, as well as the single partition layout we are using by default.
include/configs/pico-imx6ul.h | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/include/configs/pico-imx6ul.h b/include/configs/pico-imx6ul.h index 2276f72bae..a510fd1554 100644 --- a/include/configs/pico-imx6ul.h +++ b/include/configs/pico-imx6ul.h @@ -44,11 +44,12 @@ #define DFU_DEFAULT_POLL_TIMEOUT 300
#define CONFIG_DFU_ENV_SETTINGS \ - "dfu_alt_info=uboot raw 0x2 0x400 mmcpart 1;" \ - "boot part 0 1;" \ - "/zImage ext4 0 1;" \ - "/imx6ul-pico-hobbit.dtb ext4 0 1;" \ - "rootfs part 0 2\0" \ + "dfu_alt_info=" \ + "spl raw 0x2 0x400 mmcpart 1;" \ + "u-boot raw 0x8a 0x400 mmcpart 1;" \ + "/boot/zImage ext4 0 1;" \ + "/boot/imx6ul-pico-hobbit.dtb ext4 0 1;" \ + "rootfs part 0 1\0" \
#define BOOTMENU_ENV \ "bootmenu_0=Boot using PICO-Hobbit baseboard=" \
board/technexion/pico-imx6ul/README | 22 +++++++++------------- 1 file changed, 9 insertions(+), 13 deletions(-)
diff --git a/board/technexion/pico-imx6ul/README b/board/technexion/pico-imx6ul/README index a5415714ee..66dc977d49 100644 --- a/board/technexion/pico-imx6ul/README +++ b/board/technexion/pico-imx6ul/README @@ -22,13 +22,14 @@ If the eMMC has already a U-Boot flashed with DFU support then the user can go to step 2 below in order to update U-Boot.
Put pico board in USB download mode (refer to the document -http://www.wandboard.org/images/hobbit/hobbitboard-imx6ul-reva1.pdf page 15) +http://www.wandboard.org/images/hobbit/hobbitboard-imx6ul-reva1.pdf +page 15).
-Connect a USB to serial adapter between the host PC and pico +Connect a USB to serial adapter between the host PC and pico.
-Connect a USB cable between the OTG pico port and the host PC +Connect a USB cable between the OTG pico port and the host PC.
-Open a terminal program such as minicom +Open a terminal program such as minicom.
@@ -40,7 +41,7 @@ Load the u-boot.img binary via USB:
-Then U-Boot should start and its messages will appear in the console program. +Then U-Boot starts and its messages appear in the console program.
@@ -49,7 +50,8 @@ Use the default environment variables:
-Run the DFU command: +Run the DFU agent so we can flash the new images using dfu-util tool: + => dfu 0 mmc 0
Flash SPL and u-boot.img into the eMMC running the following commands on a PC: @@ -58,14 +60,8 @@ $ sudo dfu-util -D SPL -a spl
-Then on the U-Boot prompt the following message should be seen after a -successful upgrade: - -#DOWNLOAD ... OK -Ctrl+C to exit ... - Remove power from the pico board.
-Put pico board into normal boot mode +Put pico board into normal boot mode.
Power up the board and the new updated U-Boot should boot from eMMC.
The new config skips the boot menu which asks which board is in use. This is useful to allow direct booting of image without user iteration.
board/technexion/pico-imx6ul/MAINTAINERS | 5 +++ configs/pico-hobbit-imx6ul_defconfig | 53 ++++++++++++++++++++++++ 2 files changed, 58 insertions(+) create mode 100644 configs/pico-hobbit-imx6ul_defconfig
diff --git a/board/technexion/pico-imx6ul/MAINTAINERS b/board/technexion/pico-imx6ul/MAINTAINERS index 594a883d15..334847cf71 100644 --- a/board/technexion/pico-imx6ul/MAINTAINERS +++ b/board/technexion/pico-imx6ul/MAINTAINERS @@ -5,3 +5,8 @@ S: Maintained F: board/technexion/pico-imx6ul/ F: include/configs/pico-imx6ul.h F: configs/pico-imx6ul_defconfig + +Technexion PICO-HOBBIT-IMX6UL +M: Otavio Salvador otavio@ossystems.com.br +S: Maintained +F: configs/pico-hobbit-imx6ul_defconfig diff --git a/configs/pico-hobbit-imx6ul_defconfig b/configs/pico-hobbit-imx6ul_defconfig new file mode 100644 index 0000000000..362c0a251d --- /dev/null +++ b/configs/pico-hobbit-imx6ul_defconfig @@ -0,0 +1,53 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SYS_TEXT_BASE=0x87800000 +CONFIG_SPL_GPIO_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TARGET_PICO_IMX6UL=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" +CONFIG_BOOTDELAY=3 +CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" +CONFIG_DEFAULT_FDT_FILE="imx6ul-pico-hobbit.dtb" +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_USB_HOST_SUPPORT=y +CONFIG_SPL_USB_GADGET_SUPPORT=y +CONFIG_SPL_USB_SDP_SUPPORT=y +CONFIG_CMD_BOOTMENU=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_DFU=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_DFU_MMC=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_SIZE=0x10000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 +CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_FSL_ESDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_MICREL=y +CONFIG_MII=y +CONFIG_USB=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_OF_LIBFDT=y
The FSL_USDHC support is now handled by Kconfig and it is enabled on the respective `defconfig` so the setting in .h is pointless.
include/configs/pico-imx6ul.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/configs/pico-imx6ul.h b/include/configs/pico-imx6ul.h index a510fd1554..94c14a7a43 100644 --- a/include/configs/pico-imx6ul.h +++ b/include/configs/pico-imx6ul.h @@ -28,7 +28,6 @@ #define CONFIG_MXC_UART_BASE UART6_BASE_ADDR
/* MMC Configs */ -#define CONFIG_FSL_USDHC #define CONFIG_SYS_FSL_ESDHC_ADDR USDHC1_BASE_ADDR #define CONFIG_SUPPORT_EMMC_BOOT
Fabio Estevam
Jagan Teki
Otavio Salvador
