[PATCH] buildman: Include symbols in the read-only data section
When symbols switch between the inited data section and the read-only data section their visbility changes, at present, with the -B option.
This is confusing, since adding 'const' to a variable declaration can make it look like a significant improvement in bloat. But in fact nothing has changed.
Add 'r' to the list of symbols types that are recorded, to correct this problem. Add a constant to make it easier to find this code next time.
tools/buildman/builder.py | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/tools/buildman/builder.py b/tools/buildman/builder.py index 5305477c5be6..3e42c987d1cd 100644 --- a/tools/buildman/builder.py +++ b/tools/buildman/builder.py @@ -35,6 +35,10 @@ from u_boot_pylib.terminal import tprint # which indicates that BREAK_ME has an empty default RE_NO_DEFAULT = re.compile(b'((\w+)) [] (NEW)')
+# Symbol types which appear in the bloat feature (-B). Others are silently +# dropped when reading in the 'nm' output +NM_SYMBOL_TYPES = 'tTdDbBr' + """ Theory of Operation
@@ -693,7 +697,7 @@ class Builder: parts = line.split() if line and len(parts) == 3: size, type, name = line.split() - if type in 'tTdDbB': + if type in NM_SYMBOL_TYPES: # function names begin with '.' on 64-bit powerpc if '.' in name[1:]: name = 'static.' + name.split('.')[0]
Thanks for fixing this.
Reported-by: Tom Rini trini@konsulko.com Reviewed-by: Tom Rini trini@konsulko.com Link: https://source.denx.de/u-boot/custodians/u-boot-dm/-/issues/6
