[U-Boot] [PATCH v3 0/4] Stratix10 FPGA reconfiguration support
Summary of v3 changes: - Patch 1/4, 2/4 and 4/4 are unchanged - Patch 3/4: Removed unnecessary empty socfpga_fpga_add() from misc.c - Patch 3/4: Removed unnecessary '#ifdef CONFIG_FPGA' from misc_s10.c
v2 patchsets: https://lists.denx.de/pipermail/u-boot/2018-October/343473.html
Ang, Chee Hong (4): arm: socfpga: stratix10: Add macros for mailbox's arguments arm: socfpga: stratix10: Add Stratix 10 FPGA Reconfiguration Driver arm: socfpga: stratix10: Add Stratix10 FPGA into FPGA device table arm: socfpga: stratix10: Enable Stratix10 FPGA Reconfiguration
arch/arm/mach-socfpga/include/mach/mailbox_s10.h | 6 + arch/arm/mach-socfpga/misc.c | 22 ++ arch/arm/mach-socfpga/misc_s10.c | 2 + configs/socfpga_stratix10_defconfig | 1 + drivers/fpga/Kconfig | 11 + drivers/fpga/Makefile | 1 + drivers/fpga/altera.c | 6 + drivers/fpga/stratix10.c | 288 +++++++++++++++++++++++ include/altera.h | 8 + 9 files changed, 345 insertions(+) create mode 100644 drivers/fpga/stratix10.c
Add macros for specifying number of arguments in mailbox command.
Signed-off-by: Ang, Chee Hong chee.hong.ang@intel.com --- arch/arm/mach-socfpga/include/mach/mailbox_s10.h | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/mach-socfpga/include/mach/mailbox_s10.h b/arch/arm/mach-socfpga/include/mach/mailbox_s10.h index 660df35..ae728a5 100644 --- a/arch/arm/mach-socfpga/include/mach/mailbox_s10.h +++ b/arch/arm/mach-socfpga/include/mach/mailbox_s10.h @@ -107,6 +107,12 @@ enum ALT_SDM_MBOX_RESP_CODE { #define RECONFIG_STATUS_PIN_STATUS 2 #define RECONFIG_STATUS_SOFTFUNC_STATUS 3
+/* Macros for specifying number of arguments in mailbox command */ +#define MBOX_NUM_ARGS(n, b) (((n) & 0xFF) << (b)) +#define MBOX_DIRECT_COUNT(n) MBOX_NUM_ARGS((n), 0) +#define MBOX_ARG_DESC_COUNT(n) MBOX_NUM_ARGS((n), 8) +#define MBOX_RESP_DESC_COUNT(n) MBOX_NUM_ARGS((n), 16) + #define MBOX_CFGSTAT_STATE_IDLE 0x00000000 #define MBOX_CFGSTAT_STATE_CONFIG 0x10000000 #define MBOX_CFGSTAT_STATE_FAILACK 0x08000000
Enable FPGA reconfiguration support for Stratix 10 SoC.
Signed-off-by: Ang, Chee Hong chee.hong.ang@intel.com --- drivers/fpga/Kconfig | 11 ++ drivers/fpga/Makefile | 1 + drivers/fpga/stratix10.c | 288 +++++++++++++++++++++++++++++++++++++++++++++++ include/altera.h | 4 + 4 files changed, 304 insertions(+) create mode 100644 drivers/fpga/stratix10.c
diff --git a/drivers/fpga/Kconfig b/drivers/fpga/Kconfig index 50e9019..8f59193 100644 --- a/drivers/fpga/Kconfig +++ b/drivers/fpga/Kconfig @@ -31,6 +31,17 @@ config FPGA_CYCLON2 Enable FPGA driver for loading bitstream in BIT and BIN format on Altera Cyclone II device.
+config FPGA_STRATIX10 + bool "Enable Altera FPGA driver for Stratix 10" + depends on TARGET_SOCFPGA_STRATIX10 + select FPGA_ALTERA + help + Say Y here to enable the Altera Stratix 10 FPGA specific driver + + This provides common functionality for Altera Stratix 10 devices. + Enable FPGA driver for writing bitstream into Altera Stratix10 + device. + config FPGA_XILINX bool "Enable Xilinx FPGA drivers" select FPGA diff --git a/drivers/fpga/Makefile b/drivers/fpga/Makefile index 97d7d5d..5a778c1 100644 --- a/drivers/fpga/Makefile +++ b/drivers/fpga/Makefile @@ -17,6 +17,7 @@ obj-$(CONFIG_FPGA_ACEX1K) += ACEX1K.o obj-$(CONFIG_FPGA_CYCLON2) += cyclon2.o obj-$(CONFIG_FPGA_STRATIX_II) += stratixII.o obj-$(CONFIG_FPGA_STRATIX_V) += stratixv.o +obj-$(CONFIG_FPGA_STRATIX10) += stratix10.o obj-$(CONFIG_FPGA_SOCFPGA) += socfpga.o obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += socfpga_gen5.o obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += socfpga_arria10.o diff --git a/drivers/fpga/stratix10.c b/drivers/fpga/stratix10.c new file mode 100644 index 0000000..6728291 --- /dev/null +++ b/drivers/fpga/stratix10.c @@ -0,0 +1,288 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Intel Corporation <www.intel.com> + */ + +#include <common.h> +#include <altera.h> +#include <asm/arch/mailbox_s10.h> + +#define RECONFIG_STATUS_POLL_RESP_TIMEOUT_MS 60000 +#define RECONFIG_STATUS_INTERVAL_DELAY_US 1000000 + +static const struct mbox_cfgstat_state { + int err_no; + const char *error_name; +} mbox_cfgstat_state[] = { + {MBOX_CFGSTAT_STATE_IDLE, "FPGA in idle mode."}, + {MBOX_CFGSTAT_STATE_CONFIG, "FPGA in config mode."}, + {MBOX_CFGSTAT_STATE_FAILACK, "Acknowledgment failed!"}, + {MBOX_CFGSTAT_STATE_ERROR_INVALID, "Invalid bitstream!"}, + {MBOX_CFGSTAT_STATE_ERROR_CORRUPT, "Corrupted bitstream!"}, + {MBOX_CFGSTAT_STATE_ERROR_AUTH, "Authentication failed!"}, + {MBOX_CFGSTAT_STATE_ERROR_CORE_IO, "I/O error!"}, + {MBOX_CFGSTAT_STATE_ERROR_HARDWARE, "Hardware error!"}, + {MBOX_CFGSTAT_STATE_ERROR_FAKE, "Fake error!"}, + {MBOX_CFGSTAT_STATE_ERROR_BOOT_INFO, "Error in boot info!"}, + {MBOX_CFGSTAT_STATE_ERROR_QSPI_ERROR, "Error in QSPI!"}, + {MBOX_RESP_ERROR, "Mailbox general error!"}, + {-ETIMEDOUT, "I/O timeout error"}, + {-1, "Unknown error!"} +}; + +#define MBOX_CFGSTAT_MAX ARRAY_SIZE(mbox_cfgstat_state) + +static const char *mbox_cfgstat_to_str(int err) +{ + int i; + + for (i = 0; i < MBOX_CFGSTAT_MAX - 1; i++) { + if (mbox_cfgstat_state[i].err_no == err) + return mbox_cfgstat_state[i].error_name; + } + + return mbox_cfgstat_state[MBOX_CFGSTAT_MAX - 1].error_name; +} + +/* + * Add the ongoing transaction's command ID into pending list and return + * the command ID for next transfer. + */ +static u8 add_transfer(u32 *xfer_pending_list, size_t list_size, u8 id) +{ + int i; + + for (i = 0; i < list_size; i++) { + if (xfer_pending_list[i]) + continue; + xfer_pending_list[i] = id; + debug("ID(%d) added to transaction pending list\n", id); + /* + * Increment command ID for next transaction. + * Valid command ID (4 bits) is from 1 to 15. + */ + id = (id % 15) + 1; + break; + } + + return id; +} + +/* + * Check whether response ID match the command ID in the transfer + * pending list. If a match is found in the transfer pending list, + * it clears the transfer pending list and return the matched + * command ID. + */ +static int get_and_clr_transfer(u32 *xfer_pending_list, size_t list_size, + u8 id) +{ + int i; + + for (i = 0; i < list_size; i++) { + if (id != xfer_pending_list[i]) + continue; + xfer_pending_list[i] = 0; + return id; + } + + return 0; +} + +/* + * Polling the FPGA configuration status. + * Return 0 for success, non-zero for error. + */ +static int reconfig_status_polling_resp(void) +{ + int ret; + unsigned long start = get_timer(0); + + while (1) { + ret = mbox_get_fpga_config_status(MBOX_RECONFIG_STATUS); + if (!ret) + return 0; /* configuration success */ + + if (ret != MBOX_CFGSTAT_STATE_CONFIG) + return ret; + + if (get_timer(start) > RECONFIG_STATUS_POLL_RESP_TIMEOUT_MS) + break; /* time out */ + + puts("."); + udelay(RECONFIG_STATUS_INTERVAL_DELAY_US); + } + + return -ETIMEDOUT; +} + +static u32 get_resp_hdr(u32 *r_index, u32 *w_index, u32 *resp_count, + u32 *resp_buf, u32 buf_size, u32 client_id) +{ + u32 buf[MBOX_RESP_BUFFER_SIZE]; + u32 mbox_hdr; + u32 resp_len; + u32 hdr_len; + u32 i; + + if (*resp_count < buf_size) { + u32 rcv_len_max = buf_size - *resp_count; + + if (rcv_len_max > MBOX_RESP_BUFFER_SIZE) + rcv_len_max = MBOX_RESP_BUFFER_SIZE; + resp_len = mbox_rcv_resp(buf, rcv_len_max); + + for (i = 0; i < resp_len; i++) { + resp_buf[(*w_index)++] = buf[i]; + *w_index %= buf_size; + *resp_count++; + } + } + + /* No response in buffer */ + if (*resp_count == 0) + return 0; + + mbox_hdr = resp_buf[*r_index]; + + hdr_len = MBOX_RESP_LEN_GET(mbox_hdr); + + /* Insufficient header length to return a mailbox header */ + if ((*resp_count - 1) < hdr_len) + return 0; + + *r_index += (hdr_len + 1); + *r_index %= buf_size; + *resp_count -= (hdr_len + 1); + + /* Make sure response belongs to us */ + if (MBOX_RESP_CLIENT_GET(mbox_hdr) != client_id) + return 0; + + return mbox_hdr; +} + +/* Send bit stream data to SDM via RECONFIG_DATA mailbox command */ +static int send_reconfig_data(const void *rbf_data, size_t rbf_size, + u32 xfer_max, u32 buf_size_max) +{ + u32 response_buffer[MBOX_RESP_BUFFER_SIZE]; + u32 xfer_pending[MBOX_RESP_BUFFER_SIZE]; + u32 resp_rindex = 0; + u32 resp_windex = 0; + u32 resp_count = 0; + u32 xfer_count = 0; + u8 resp_err = 0; + u8 cmd_id = 1; + u32 args[3]; + int ret; + + debug("SDM xfer_max = %d\n", xfer_max); + debug("SDM buf_size_max = %x\n\n", buf_size_max); + + memset(xfer_pending, 0, sizeof(xfer_pending)); + + while (rbf_size || xfer_count) { + if (!resp_err && rbf_size && xfer_count < xfer_max) { + args[0] = MBOX_ARG_DESC_COUNT(1); + args[1] = (u32)rbf_data; + if (rbf_size >= buf_size_max) { + args[2] = buf_size_max; + rbf_size -= buf_size_max; + rbf_data += buf_size_max; + } else { + args[2] = (u32)rbf_size; + rbf_size = 0; + } + + ret = mbox_send_cmd_only(cmd_id, MBOX_RECONFIG_DATA, + MBOX_CMD_INDIRECT, 3, args); + if (ret) { + resp_err = 1; + } else { + xfer_count++; + cmd_id = add_transfer(xfer_pending, + MBOX_RESP_BUFFER_SIZE, + cmd_id); + } + puts("."); + } else { + u32 resp_hdr = get_resp_hdr(&resp_rindex, &resp_windex, + &resp_count, + response_buffer, + MBOX_RESP_BUFFER_SIZE, + MBOX_CLIENT_ID_UBOOT); + + /* + * If no valid response header found or + * non-zero length from RECONFIG_DATA + */ + if (!resp_hdr || MBOX_RESP_LEN_GET(resp_hdr)) + continue; + + /* Check for response's status */ + if (!resp_err) { + ret = MBOX_RESP_ERR_GET(resp_hdr); + debug("Response error code: %08x\n", ret); + /* Error in response */ + if (ret) + resp_err = 1; + } + + ret = get_and_clr_transfer(xfer_pending, + MBOX_RESP_BUFFER_SIZE, + MBOX_RESP_ID_GET(resp_hdr)); + if (ret) { + /* Claim and reuse the ID */ + cmd_id = (u8)ret; + xfer_count--; + } + + if (resp_err && !xfer_count) + return ret; + } + } + + return 0; +} + +/* + * This is the interface used by FPGA driver. + * Return 0 for success, non-zero for error. + */ +int stratix10_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size) +{ + int ret; + u32 resp_len = 2; + u32 resp_buf[2]; + + debug("Sending MBOX_RECONFIG...\n"); + ret = mbox_send_cmd(MBOX_ID_UBOOT, MBOX_RECONFIG, MBOX_CMD_DIRECT, 0, + NULL, 0, &resp_len, resp_buf); + if (ret) { + puts("Failure in RECONFIG mailbox command!\n"); + return ret; + } + + ret = send_reconfig_data(rbf_data, rbf_size, resp_buf[0], resp_buf[1]); + if (ret) { + printf("RECONFIG_DATA error: %08x, %s\n", ret, + mbox_cfgstat_to_str(ret)); + return ret; + } + + /* Make sure we don't send MBOX_RECONFIG_STATUS too fast */ + udelay(RECONFIG_STATUS_INTERVAL_DELAY_US); + + debug("Polling with MBOX_RECONFIG_STATUS...\n"); + ret = reconfig_status_polling_resp(); + if (ret) { + printf("RECONFIG_STATUS Error: %08x, %s\n", ret, + mbox_cfgstat_to_str(ret)); + return ret; + } + + puts("FPGA reconfiguration OK!\n"); + + return ret; +} diff --git a/include/altera.h b/include/altera.h index ead5d3d..233b467 100644 --- a/include/altera.h +++ b/include/altera.h @@ -116,4 +116,8 @@ int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size); int stratixv_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size); #endif
+#ifdef CONFIG_FPGA_STRATIX10 +int stratix10_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size); +#endif + #endif /* _ALTERA_H_ */
Enable 'fpga' command in u-boot. User will be able to use the fpga command to program the FPGA on Stratix10 SoC.
Signed-off-by: Ang, Chee Hong chee.hong.ang@intel.com --- arch/arm/mach-socfpga/misc.c | 22 ++++++++++++++++++++++ arch/arm/mach-socfpga/misc_s10.c | 2 ++ drivers/fpga/altera.c | 6 ++++++ include/altera.h | 4 ++++ 4 files changed, 34 insertions(+)
diff --git a/arch/arm/mach-socfpga/misc.c b/arch/arm/mach-socfpga/misc.c index a4f6d5c..350aad1 100644 --- a/arch/arm/mach-socfpga/misc.c +++ b/arch/arm/mach-socfpga/misc.c @@ -88,6 +88,27 @@ int overwrite_console(void) #endif
#ifdef CONFIG_FPGA +#ifdef CONFIG_FPGA_STRATIX10 +/* + * FPGA programming support for SoC FPGA Stratix 10 + */ +static Altera_desc altera_fpga[] = { + { + /* Family */ + Intel_FPGA_Stratix10, + /* Interface type */ + secure_device_manager_mailbox, + /* No limitation as additional data will be ignored */ + -1, + /* No device function table */ + NULL, + /* Base interface address specified in driver */ + NULL, + /* No cookie implementation */ + 0 + }, +}; +#else /* * FPGA programming support for SoC FPGA Cyclone V */ @@ -107,6 +128,7 @@ static Altera_desc altera_fpga[] = { 0 }, }; +#endif
/* add device descriptor to FPGA device table */ void socfpga_fpga_add(void) diff --git a/arch/arm/mach-socfpga/misc_s10.c b/arch/arm/mach-socfpga/misc_s10.c index 918baac..f23c0dc 100644 --- a/arch/arm/mach-socfpga/misc_s10.c +++ b/arch/arm/mach-socfpga/misc_s10.c @@ -124,6 +124,8 @@ int arch_misc_init(void)
int arch_early_init_r(void) { + socfpga_fpga_add(); + return 0; }
diff --git a/drivers/fpga/altera.c b/drivers/fpga/altera.c index 9605554..7c8f518 100644 --- a/drivers/fpga/altera.c +++ b/drivers/fpga/altera.c @@ -39,6 +39,9 @@ static const struct altera_fpga { #if defined(CONFIG_FPGA_STRATIX_V) { Altera_StratixV, "StratixV", stratixv_load, NULL, NULL }, #endif +#if defined(CONFIG_FPGA_STRATIX10) + { Intel_FPGA_Stratix10, "Stratix10", stratix10_load, NULL, NULL }, +#endif #if defined(CONFIG_FPGA_SOCFPGA) { Altera_SoCFPGA, "SoC FPGA", socfpga_load, NULL, NULL }, #endif @@ -154,6 +157,9 @@ int altera_info(Altera_desc *desc) case fast_passive_parallel_security: printf("Fast Passive Parallel with Security (FPPS)\n"); break; + case secure_device_manager_mailbox: + puts("Secure Device Manager (SDM) Mailbox\n"); + break; /* Add new interface types here */ default: printf("Unsupported interface type, %d\n", desc->iface); diff --git a/include/altera.h b/include/altera.h index 233b467..22d55cf 100644 --- a/include/altera.h +++ b/include/altera.h @@ -39,6 +39,8 @@ enum altera_iface { fast_passive_parallel, /* fast passive parallel with security (FPPS) */ fast_passive_parallel_security, + /* secure device manager (SDM) mailbox */ + secure_device_manager_mailbox, /* insert all new types before this */ max_altera_iface_type, }; @@ -54,6 +56,8 @@ enum altera_family { Altera_StratixII, /* StratixV Family */ Altera_StratixV, + /* Stratix10 Family */ + Intel_FPGA_Stratix10, /* SoCFPGA Family */ Altera_SoCFPGA,
Enable Stratix10 FPGA reconfiguration support in defconfig.
Signed-off-by: Ang, Chee Hong chee.hong.ang@intel.com --- configs/socfpga_stratix10_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig index 5f3d733..155c406 100644 --- a/configs/socfpga_stratix10_defconfig +++ b/configs/socfpga_stratix10_defconfig @@ -10,6 +10,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_BOOTDELAY=5 CONFIG_SPL_SPI_LOAD=y CONFIG_HUSH_PARSER=y +CONFIG_FPGA_STRATIX10=y CONFIG_SYS_PROMPT="SOCFPGA_STRATIX10 # " CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set
