[U-Boot] [PATCH v2] net: phy: Add gmiitorgmii converter support
From: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com
This patch adds support for gmiitorgmii converter. This converter sits between the MAC and the external phy MAC <==> GMII2RGMII <==> RGMII_PHY. The ethernet driver probes this bridge and this bridge driver probes real phy driver and invokes the real phy functionalities as requested. This bridge just needs to be configured based on real phy negotiated speed and duplex.
Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
Changes in v2: - Include "net: phy: Fix logic around gmiitorgmii wiring" patch - Update patch on the top of "net: phy: Add clause 45 identifier to phy_device (sha1: b3eabd82f21b4d9206622fc5aee16751d2f4be8f) which adds one more parameter to phy_device_create (bool is_c45)
drivers/net/phy/Kconfig | 7 +++ drivers/net/phy/Makefile | 1 + drivers/net/phy/phy.c | 42 +++++++++++++++ drivers/net/phy/xilinx_gmii2rgmii.c | 103 ++++++++++++++++++++++++++++++++++++ include/phy.h | 6 +++ 5 files changed, 159 insertions(+) create mode 100644 drivers/net/phy/xilinx_gmii2rgmii.c
diff --git a/drivers/net/phy/Kconfig b/drivers/net/phy/Kconfig index 3dc0822d9c21..a68e1678de61 100644 --- a/drivers/net/phy/Kconfig +++ b/drivers/net/phy/Kconfig @@ -217,6 +217,13 @@ config PHY_VITESSE config PHY_XILINX bool "Xilinx Ethernet PHYs support"
+config PHY_XILINX_GMII2RGMII + bool "Xilinx GMII to RGMII Ethernet PHYs support" + help + This adds support for Xilinx GMII to RGMII IP core. This IP acts + as bridge between MAC connected over GMII and external phy that + is connected over RGMII interface. + config PHY_FIXED bool "Fixed-Link PHY" depends on DM_ETH diff --git a/drivers/net/phy/Makefile b/drivers/net/phy/Makefile index 555da83630f4..76b6197009bc 100644 --- a/drivers/net/phy/Makefile +++ b/drivers/net/phy/Makefile @@ -27,6 +27,7 @@ obj-$(CONFIG_PHY_SMSC) += smsc.o obj-$(CONFIG_PHY_TERANETICS) += teranetics.o obj-$(CONFIG_PHY_TI) += ti.o obj-$(CONFIG_PHY_XILINX) += xilinx_phy.o +obj-$(CONFIG_PHY_XILINX_GMII2RGMII) += xilinx_gmii2rgmii.o obj-$(CONFIG_PHY_VITESSE) += vitesse.o obj-$(CONFIG_PHY_MSCC) += mscc.o obj-$(CONFIG_PHY_FIXED) += fixed.o diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index 0c8b29dae44a..17cfcfe62a78 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -528,6 +528,9 @@ int phy_init(void) #ifdef CONFIG_PHY_FIXED phy_fixed_init(); #endif +#ifdef CONFIG_PHY_XILINX_GMII2RGMII + phy_xilinx_gmii2rgmii_init(); +#endif return 0; }
@@ -881,6 +884,41 @@ void phy_connect_dev(struct phy_device *phydev, struct eth_device *dev) debug("%s connected to %s\n", dev->name, phydev->drv->name); }
+#ifdef CONFIG_PHY_XILINX_GMII2RGMII +#ifdef CONFIG_DM_ETH +static struct phy_device *phy_connect_gmii2rgmii(struct mii_dev *bus, + struct udevice *dev, + phy_interface_t interface) +#else +static struct phy_device *phy_connect_gmii2rgmii(struct mii_dev *bus, + struct eth_device *dev, + phy_interface_t interface) +#endif +{ + struct phy_device *phydev = NULL; + int sn = dev_of_offset(dev); + int off; + + while (sn > 0) { + off = fdt_node_offset_by_compatible(gd->fdt_blob, sn, + "xlnx,gmii-to-rgmii-1.0"); + if (off > 0) { + phydev = phy_device_create(bus, off, + PHY_GMII2RGMII_ID, false, + interface); + break; + } + if (off == -FDT_ERR_NOTFOUND) + sn = fdt_first_subnode(gd->fdt_blob, sn); + else + printf("%s: Error finding compat string:%d\n", + __func__, off); + } + + return phydev; +} +#endif + #ifdef CONFIG_PHY_FIXED #ifdef CONFIG_DM_ETH static struct phy_device *phy_connect_fixed(struct mii_dev *bus, @@ -926,6 +964,10 @@ struct phy_device *phy_connect(struct mii_dev *bus, int addr, #ifdef CONFIG_PHY_FIXED phydev = phy_connect_fixed(bus, dev, interface); #endif +#ifdef CONFIG_PHY_XILINX_GMII2RGMII + if (!phydev) + phydev = phy_connect_gmii2rgmii(bus, dev, interface); +#endif
if (!phydev) phydev = phy_find_by_mask(bus, 1 << addr, interface); diff --git a/drivers/net/phy/xilinx_gmii2rgmii.c b/drivers/net/phy/xilinx_gmii2rgmii.c new file mode 100644 index 000000000000..aa4ce86d2e36 --- /dev/null +++ b/drivers/net/phy/xilinx_gmii2rgmii.c @@ -0,0 +1,103 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Xilinx GMII2RGMII phy driver + * + * Copyright (C) 2018 Xilinx, Inc. + */ + +#include <dm.h> +#include <phy.h> +#include <config.h> +#include <common.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define ZYNQ_GMII2RGMII_REG 0x10 +#define ZYNQ_GMII2RGMII_SPEED_MASK (BMCR_SPEED1000 | BMCR_SPEED100) + +static int xilinxgmiitorgmii_config(struct phy_device *phydev) +{ + struct phy_device *ext_phydev = phydev->priv; + + debug("%s\n", __func__); + if (ext_phydev->drv->config) + ext_phydev->drv->config(ext_phydev); + + return 0; +} + +static int xilinxgmiitorgmii_startup(struct phy_device *phydev) +{ + u16 val = 0; + struct phy_device *ext_phydev = phydev->priv; + + debug("%s\n", __func__); + ext_phydev->dev = phydev->dev; + if (ext_phydev->drv->startup) + ext_phydev->drv->startup(ext_phydev); + + val = phy_read(phydev, phydev->addr, ZYNQ_GMII2RGMII_REG); + val &= ~ZYNQ_GMII2RGMII_SPEED_MASK; + + if (ext_phydev->speed == SPEED_1000) + val |= BMCR_SPEED1000; + else if (ext_phydev->speed == SPEED_100) + val |= BMCR_SPEED100; + + phy_write(phydev, phydev->addr, ZYNQ_GMII2RGMII_REG, val | + BMCR_FULLDPLX); + + phydev->duplex = ext_phydev->duplex; + phydev->speed = ext_phydev->speed; + phydev->link = ext_phydev->link; + + return 0; +} + +static int xilinxgmiitorgmii_probe(struct phy_device *phydev) +{ + int ofnode = phydev->addr; + u32 phy_of_handle; + int ext_phyaddr = -1; + + debug("%s\n", __func__); + + /* + * Read the phy address again as the one we read in ethernet driver + * was overwritten for the purpose of storing the ofnode + */ + phydev->addr = fdtdec_get_int(gd->fdt_blob, ofnode, "reg", -1); + phy_of_handle = fdtdec_lookup_phandle(gd->fdt_blob, ofnode, + "phy-handle"); + if (phy_of_handle > 0) + ext_phyaddr = fdtdec_get_int(gd->fdt_blob, + phy_of_handle, + "reg", -1); + phydev->priv = phy_find_by_mask(phydev->bus, + 1 << ext_phyaddr, + phydev->interface); + + debug("%s, gmii2rgmmi:0x%x, extphy:0x%x\n", __func__, phydev->addr, + ext_phyaddr); + + phydev->flags |= PHY_FLAG_BROKEN_RESET; + + return 0; +} + +static struct phy_driver gmii2rgmii_driver = { + .name = "XILINX GMII2RGMII", + .uid = PHY_GMII2RGMII_ID, + .mask = 0xffffffff, + .features = PHY_GBIT_FEATURES, + .probe = xilinxgmiitorgmii_probe, + .config = xilinxgmiitorgmii_config, + .startup = xilinxgmiitorgmii_startup, +}; + +int phy_xilinx_gmii2rgmii_init(void) +{ + phy_register(&gmii2rgmii_driver); + + return 0; +} diff --git a/include/phy.h b/include/phy.h index f23ca63f3b84..c613415c1dee 100644 --- a/include/phy.h +++ b/include/phy.h @@ -17,6 +17,11 @@ #include <phy_interface.h>
#define PHY_FIXED_ID 0xa5a55a5a +/* + * There is no actual id for this. + * This is just a dummy id for gmii2rgmmi converter. + */ +#define PHY_GMII2RGMII_ID 0x5a5a5a5a
#define PHY_MAX_ADDR 32
@@ -241,6 +246,7 @@ int phy_vitesse_init(void); int phy_xilinx_init(void); int phy_mscc_init(void); int phy_fixed_init(void); +int phy_xilinx_gmii2rgmii_init(void);
int board_phy_config(struct phy_device *phydev); int get_phy_id(struct mii_dev *bus, int addr, int devad, u32 *phy_id);
Michal Simek
