[PATCH v3] board: gateworks: venice: enable DM_SERIAL
Enable DM_SERIAL for both U_Boot and the SPL. The uart2 and its pinmux are already marked with u-boot,dm-spl but we need to move the call to preloader_console_init() after spl_early_init() to avoid a board hang as dm can't be used until after spl_early_init().
Remove the manual config of the UART pinmux now that it is no longer needed.
Signed-off-by: Tim Harvey tharvey@gateworks.com Cc: Michael Nazzareno Trimarchi michael@amarulasolutions.com --- v3: enable DM_SERIAL for SPL as well per Michael's suggestion v2: rebase on imx/master --- board/gateworks/venice/spl.c | 17 ++--------------- configs/imx8mm_venice_defconfig | 1 + configs/imx8mn_venice_defconfig | 1 + 3 files changed, 4 insertions(+), 15 deletions(-)
diff --git a/board/gateworks/venice/spl.c b/board/gateworks/venice/spl.c index b56e1b607d58..59a6a29f70d8 100644 --- a/board/gateworks/venice/spl.c +++ b/board/gateworks/venice/spl.c @@ -87,25 +87,14 @@ static void spl_dram_init(int size) ddr_init(dram_timing); }
-#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) #define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE)
#ifdef CONFIG_IMX8MM -static iomux_v3_cfg_t const uart_pads[] = { - IMX8MM_PAD_UART2_RXD_UART2_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - IMX8MM_PAD_UART2_TXD_UART2_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - static iomux_v3_cfg_t const wdog_pads[] = { IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), }; #endif #ifdef CONFIG_IMX8MN -static const iomux_v3_cfg_t uart_pads[] = { - IMX8MN_PAD_UART2_RXD__UART2_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - IMX8MN_PAD_UART2_TXD__UART2_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - static const iomux_v3_cfg_t wdog_pads[] = { IMX8MN_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), }; @@ -119,8 +108,6 @@ int board_early_init_f(void)
set_wdog_reset(wdog);
- imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); - return 0; }
@@ -232,8 +219,6 @@ void board_init_f(ulong dummy)
timer_init();
- preloader_console_init(); - /* Clear the BSS. */ memset(__bss_start, 0, __bss_end - __bss_start);
@@ -243,6 +228,8 @@ void board_init_f(ulong dummy) hang(); }
+ preloader_console_init(); + ret = uclass_get_device_by_name(UCLASS_CLK, "clock-controller@30380000", &dev); diff --git a/configs/imx8mm_venice_defconfig b/configs/imx8mm_venice_defconfig index dd61ec9b70fb..1ccbe9970a6c 100644 --- a/configs/imx8mm_venice_defconfig +++ b/configs/imx8mm_venice_defconfig @@ -110,6 +110,7 @@ CONFIG_SPL_DM_PMIC_MP5416=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y diff --git a/configs/imx8mn_venice_defconfig b/configs/imx8mn_venice_defconfig index c3a96a378553..ff926dac0e18 100644 --- a/configs/imx8mn_venice_defconfig +++ b/configs/imx8mn_venice_defconfig @@ -108,6 +108,7 @@ CONFIG_SPL_DM_PMIC_MP5416=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y
Hi Tim,
This preloader_console_init() comment is what I was expecting when I went trough Peng's patches.
It looks good now:
Reviewed-by: Fabio Estevam festevam@denx.de
HI Tim
What about the clock? I'm a bit surprised that it works without the clock enabled.
Michael
timer_init();
diff --git a/configs/imx8mm_venice_defconfig b/configs/imx8mm_venice_defconfig index dd61ec9b70fb..1ccbe9970a6c 100644 --- a/configs/imx8mm_venice_defconfig +++ b/configs/imx8mm_venice_defconfig @@ -110,6 +110,7 @@ CONFIG_SPL_DM_PMIC_MP5416=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y diff --git a/configs/imx8mn_venice_defconfig b/configs/imx8mn_venice_defconfig index c3a96a378553..ff926dac0e18 100644 --- a/configs/imx8mn_venice_defconfig +++ b/configs/imx8mn_venice_defconfig @@ -108,6 +108,7 @@ CONFIG_SPL_DM_PMIC_MP5416=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y -- 2.17.1
On Thu, Apr 14, 2022 at 11:02 AM Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
HI Tim
Michael,
The clock hasn't changed. Like Peng's series for converting imx8mm-evk, imx8mn-evk, and imx8mp-evk to DM_SERIAL, the board_init_f() function still calls 'init_uart_clk(1)' for UART2 (index is 0-based UART) and that is still required. I'm not sure why the dm IMX driver can't do that but it doesn't currently and that could always be an imx8mm general cleanup later.
Are your questions because you are trying to implement DM_SERIAL for one of your boards and having issues? If so, please submit your patch as an RFC so we can try to help.
Best Regards,
Tim
Michael
timer_init();
-- Michael Nazzareno Trimarchi Co-Founder & Chief Executive Officer M. +39 347 913 2170 michael@amarulasolutions.com __________________________________
Amarula Solutions BV Joop Geesinkweg 125, 1114 AB, Amsterdam, NL T. +31 (0)85 111 9172 info@amarulasolutions.com www.amarulasolutions.com
HI Tim
Michael,
I think that's because the clock driver doesn't have the uart clocks in it. I was investigating the hanging in SPL with DM_SERIAL and noticed from the clk dump that the uart clocks were not present, so I added them to the clock driver, but I didn't have success. I also tried moving the preloader_console_init and switching to early spl init instead of a regular one. Because I wasn't successful, I didn't do anything with those patches, but I can post them to the mailing list if there is interest.
adam
Best Regards,
Tim
Michael
timer_init();
HI Adam
HI Tim
Michael,
I have sent mine but I was thinking of doing the same. What I found that is really strange
commit b41d4b83f0203be79a3bfa1e4bde316355c7f2a0 Author: Sean Anderson seanga2@gmail.com Date: Sun Feb 2 13:15:17 2020 -0500
serial: Set baudrate on boot
Currently, the baud rate is never set on boot. This works ok when a previous bootloader has configured the baudrate properly, or when the baudrate is set to a reasonable default in the serial driver's probe(). However, when this is not the case, we could be using a different baud rate than what was configured.
Signed-off-by: Sean Anderson seanga2@gmail.com
Where I don't know if the probe is called later and we can not set or get the clock from there. imx7d enable all the clock for clock serial in clk init
Michael
adam
Best Regards,
Tim
Michael
timer_init();
Hi Tim
HI Tim
PAD_CTL_PE)
Michael,
Was just a question on your changes. I already have my patch and I will post. Clk for me is not removed.
Michael
Best Regards,
Tim
Michael
timer_init();
Adam Ford
Fabio Estevam
Tim Harvey
