[U-Boot] [PATCH 1/2] spi: Add Designware SPI controller Kconfig entry
Add DWC SPI controller Kconfig entry.
Signed-off-by: Marek Vasut marex@denx.de Cc: Chin Liang See clsee@opensource.altera.com Cc: Dinh Nguyen dinguyen@opensource.altera.com Cc: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com Cc: Pavel Machek pavel@denx.de Cc: Simon Glass sjg@chromium.org Cc: Stefan Roese sr@denx.de Cc: Tom Rini trini@konsulko.com Cc: Vince Bridgers vbridger@opensource.altera.com --- drivers/spi/Kconfig | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 7ae2727..c0b2570 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -10,3 +10,9 @@ config DM_SPI as 'parent data' to every slave on each bus. Slaves typically use driver-private data instead of extending the spi_slave structure. + +config DESIGNWARE_SPI + bool "Designware SPI driver" + depends on DM_SPI + help + Enable the Designware SPI driver.
Add Cadence QSPI controller Kconfig entry.
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index c0b2570..eaf31ed 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -16,3 +16,9 @@ config DESIGNWARE_SPI depends on DM_SPI help Enable the Designware SPI driver. + +config CADENCE_QSPI + bool "Cadence QSPI driver" + depends on DM_SPI + help + Enable the Cadence QSPI driver.
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
Hi Marek,
depends on DM_SPI
help
Can we get a bit more detail here? What does QSPI mean? What features does it support?
On Thursday, March 05, 2015 at 04:58:19 PM, Simon Glass wrote:
Hi Marek,
depends on DM_SPI
help
Stefan ? ;-)
Best regards, Marek Vasut
depends on DM_SPI
help
Stefan ? ;-)
Its the IP core from Cadence supporting SPI NOR flash and is present on the Altera SoCFPGA. Enabling access to such SPI NOR flash devices. QSPI stands for Quad-SPI and refers to the optional use of up to 4 data lines for flash access.
So perhaps something like this:
+ +config CADENCE_QSPI + bool "Cadence QSPI driver" + depends on DM_SPI + help + Enable the Cadence QSPI driver. This driver can be used to + access the SPI NOR flash on platforms embedding this + Cadence IP core (like the Altera SoCFPGA). QSPI stands for + Quad-SPI and refers to the optional use of up to 4 data lines + for flash access.
HTP.
Thanks, Stefan
depends on DM_SPI
help
Stefan ? ;-)
- bool "Cadence QSPI driver"
- depends on DM_SPI
- help
for flash access.
Please don't mention platforms in the help for what I think of as IP-block-vendor drivers. The Cadence QSPI block will be reused by others and I can see someone "needing" to patch the help text. How about: Enable the Cadence Quad-SPI (QSPI) driver. This driver can be used to access the SPI NOR flash on platforms embedding this Cadence IP core.
depends on DM_SPI
help
Stefan ? ;-)
- depends on DM_SPI
- help
for flash access.
Even better.
Thanks, Stefan
On Thursday, March 05, 2015 at 05:47:01 PM, Stefan Roese wrote: [...]
Even better.
Thanks
Thanks, Stefan
Acked-by: Pavel Machek pavel@denx.de
(For both patches in the series).
depends on DM_SPI
help
At least for driver model I'd like to have a nice long help message.
participants (5)
Pavel Machek
Stefan Roese
