[U-Boot] [U-Boot PATCH 1/1] am335x: cpsw: optimize cpsw_send to increase network performance
Before submitting packets to cpdma, phy status is updated on every packet which leads to delay in packet send intern reduces the Ethernet performance. Checking mdio status for each packet will reduce timetaken to send a packet and there by increasing the Ethernet performance. With this the performance is increased from 208KiB/s to 375KiB/s on EVMsk
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- This patch is applicable for u-boot-ti git repo
drivers/net/cpsw.c | 20 ++++++++++++++++++-- 1 file changed, 18 insertions(+), 2 deletions(-)
diff --git a/drivers/net/cpsw.c b/drivers/net/cpsw.c index db04795..93f8417 100644 --- a/drivers/net/cpsw.c +++ b/drivers/net/cpsw.c @@ -227,6 +227,9 @@ struct cpsw_priv { struct cpsw_slave *slaves; struct phy_device *phydev; struct mii_dev *bus; + + u32 mdio_link; + u32 phy_mask; };
static inline int cpsw_ale_get_field(u32 *ale_entry, u32 start, u32 bits) @@ -598,10 +601,21 @@ static int cpsw_update_link(struct cpsw_priv *priv)
for_each_slave(slave, priv) cpsw_slave_update_link(slave, priv, &link); - + priv->mdio_link = readl(&mdio_regs->link); return link; }
+static int cpsw_check_link(struct cpsw_priv *priv) +{ + u32 link = 0; + + link = __raw_readl(&mdio_regs->link) & priv->phy_mask; + if ((link) && (link == priv->mdio_link)) + return 1; + + return cpsw_update_link(priv); +} + static inline u32 cpsw_get_slave_port(struct cpsw_priv *priv, u32 slave_num) { if (priv->host_port == 0) @@ -631,6 +645,8 @@ static void cpsw_slave_init(struct cpsw_slave *slave, struct cpsw_priv *priv) cpsw_ale_port_state(priv, slave_port, ALE_PORT_STATE_FORWARD);
cpsw_ale_add_mcast(priv, NetBcastAddr, 1 << slave_port); + + priv->phy_mask |= 1 << slave->data->phy_id; }
static struct cpdma_desc *cpdma_desc_alloc(struct cpsw_priv *priv) @@ -862,7 +878,7 @@ static int cpsw_send(struct eth_device *dev, void *packet, int length) int len; int timeout = CPDMA_TIMEOUT;
- if (!cpsw_update_link(priv)) + if (!cpsw_check_link(priv)) return -EIO;
flush_dcache_range((unsigned long)packet,
Mugunthan V N
