[U-Boot-Users] [PATCH] sh: Add support SH3 and SH7720
Add support Renesas SH3 and SH7720.
Signed-off-by: Yoshihiro Shimoda shimoda.yoshihiro@renesas.com CC: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- cpu/sh3/Makefile | 49 ++++++++ cpu/sh3/cache.c | 112 ++++++++++++++++++ cpu/sh3/config.mk | 31 +++++ cpu/sh3/cpu.c | 84 +++++++++++++ cpu/sh3/interrupts.c | 43 +++++++ cpu/sh3/start.S | 78 ++++++++++++ cpu/sh3/time.c | 103 ++++++++++++++++ cpu/sh3/watchdog.c | 34 +++++ include/asm-sh/cpu_sh3.h | 40 ++++++ include/asm-sh/cpu_sh7720.h | 207 ++++++++++++++++++++++++++++++++++ 10 files changed, 781 insertions(+)
diff -uprN a/cpu/sh3/cache.c b/cpu/sh3/cache.c --- a/cpu/sh3/cache.c 1970-01-01 09:00:00.000000000 +0900 +++ b/cpu/sh3/cache.c 2007-12-03 21:52:04.000000000 +0900 @@ -0,0 +1,112 @@ +/* + * (C) Copyright 2007 + * Yoshihiro Shimoda shimoda.yoshihiro@renesas.com + * + * (C) Copyright 2007 + * Nobobuhiro Iwamatsu iwamatsu@nigauri.org + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <asm/processor.h> +#include <asm/io.h> + +/* + * Jump to P2 area. + * When handling TLB or caches, we need to do it from P2 area. + */ +#define jump_to_P2() \ + do { \ + unsigned long __dummy; \ + __asm__ __volatile__( \ + "mov.l 1f, %0\n\t" \ + "or %1, %0\n\t" \ + "jmp @%0\n\t" \ + " nop\n\t" \ + ".balign 4\n" \ + "1: .long 2f\n" \ + "2:" \ + : "=&r" (__dummy) \ + : "r" (0x20000000)); \ + } while (0) + +/* + * Back to P1 area. + */ +#define back_to_P1() \ + do { \ + unsigned long __dummy; \ + __asm__ __volatile__( \ + "nop;nop;nop;nop;nop;nop;nop\n\t" \ + "mov.l 1f, %0\n\t" \ + "jmp @%0\n\t" \ + " nop\n\t" \ + ".balign 4\n" \ + "1: .long 2f\n" \ + "2:" \ + : "=&r" (__dummy)); \ + } while (0) + +#define CACHE_VALID 1 +#define CACHE_UPDATED 2 + +static inline void cache_wback_all(void) +{ + unsigned long addr, data, i, j; + + jump_to_P2(); + for (i = 0; i < CACHE_OC_NUM_ENTRIES; i++) { + for (j = 0; j < CACHE_OC_NUM_WAYS; j++) { + addr = CACHE_OC_ADDRESS_ARRAY + | (j << CACHE_OC_WAY_SHIFT) + | (i << CACHE_OC_ENTRY_SHIFT); + data = inl(addr); + if (data & CACHE_UPDATED) { + data &= ~CACHE_UPDATED; + outl(data, addr); + } + } + } + back_to_P1(); +} + + +#define CACHE_ENABLE 0 +#define CACHE_DISABLE 1 + +int cache_control(unsigned int cmd) +{ + unsigned long ccr; + + jump_to_P2(); + ccr = inl(CCR); + + if (ccr & CCR_CACHE_ENABLE) + cache_wback_all(); + + if (cmd == CACHE_DISABLE) + outl(CCR_CACHE_STOP, CCR); + else + outl(CCR_CACHE_INIT, CCR); + back_to_P1(); + + return 0; +} diff -uprN a/cpu/sh3/config.mk b/cpu/sh3/config.mk --- a/cpu/sh3/config.mk 1970-01-01 09:00:00.000000000 +0900 +++ b/cpu/sh3/config.mk 2007-12-03 18:53:12.000000000 +0900 @@ -0,0 +1,31 @@ +# +# (C) Copyright 2000-2004 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2007 +# Nobuhiro Iwamatsu iwamatsu@nigauri.org +# +# (C) Copyright 2007 +# Yoshihiro Shimoda shimoda.yoshihiro@renesas.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +# +PLATFORM_CPPFLAGS += -m3 +PLATFORM_RELFLAGS += -ffixed-r13 diff -uprN a/cpu/sh3/cpu.c b/cpu/sh3/cpu.c --- a/cpu/sh3/cpu.c 1970-01-01 09:00:00.000000000 +0900 +++ b/cpu/sh3/cpu.c 2007-12-03 22:49:16.000000000 +0900 @@ -0,0 +1,84 @@ +/* + * (C) Copyright 2007 + * Yoshihiro Shimoda shimoda.yoshihiro@renesas.com + * + * (C) Copyright 2007 + * Nobuhiro Iwamatsu iwamatsu@nigauri.org + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <asm/processor.h> + +int checkcpu(void) +{ + puts("CPU: SH3\n"); + return 0; +} + +int cpu_init(void) +{ + return 0; +} + +int cleanup_before_linux(void) +{ + disable_interrupts(); + return 0; +} + +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + disable_interrupts(); + reset_cpu(0); + return 0; +} + +void flush_cache(unsigned long addr, unsigned long size) +{ + +} + +void icache_enable(void) +{ +} + +void icache_disable(void) +{ +} + +int icache_status(void) +{ + return 0; +} + +void dcache_enable(void) +{ +} + +void dcache_disable(void) +{ +} + +int dcache_status(void) +{ + return 0; +} diff -uprN a/cpu/sh3/interrupts.c b/cpu/sh3/interrupts.c --- a/cpu/sh3/interrupts.c 1970-01-01 09:00:00.000000000 +0900 +++ b/cpu/sh3/interrupts.c 2007-12-03 22:49:28.000000000 +0900 @@ -0,0 +1,43 @@ +/* + * (C) Copyright 2007 + * Yoshihiro Shimoda shimoda.yoshihiro@renesas.com + * + * (C) Copyright 2007 + * Nobuhiro Iwamatsu iwamatsu@nigauri.org + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> + +int interrupt_init(void) +{ + return 0; +} + +void enable_interrupts(void) +{ + +} + +int disable_interrupts(void) +{ + return 0; +} + diff -uprN a/cpu/sh3/Makefile b/cpu/sh3/Makefile --- a/cpu/sh3/Makefile 1970-01-01 09:00:00.000000000 +0900 +++ b/cpu/sh3/Makefile 2007-12-03 18:54:40.000000000 +0900 @@ -0,0 +1,49 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2007 +# Nobuhiro Iwamatsu iwamatsu@nigauri.org +# +# (C) Copyright 2007 +# Yoshihiro Shimoda shimoda.yoshihiro@renesas.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(CPU).a + +START = start.o +OBJS = cpu.o interrupts.o watchdog.o time.o cache.o + +all: .depend $(START) $(LIB) + +$(LIB): $(OBJS) + $(AR) crv $@ $(OBJS) + +######################################################################### + +.depend: Makefile $(START:.o=.S) $(OBJS:.o=.c) + $(CC) -M $(CFLAGS) $(START:.o=.S) $(OBJS:.o=.c) > $@ + +sinclude .depend + +######################################################################### diff -uprN a/cpu/sh3/start.S b/cpu/sh3/start.S --- a/cpu/sh3/start.S 1970-01-01 09:00:00.000000000 +0900 +++ b/cpu/sh3/start.S 2007-12-03 22:49:44.000000000 +0900 @@ -0,0 +1,78 @@ +/* + * (C) Copyright 2007 + * Yoshihiro Shimoda shimoda.yoshihiro@renesas.com + * + * (C) Copyright 2007 + * Nobuhiro Iwamatsu iwamatsu@nigauri.org + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> + + .text + .align 2 + + .global _start +_start: + mov.l ._lowlevel_init, r0 +100: bsrf r0 + nop + + bsr 1f + nop +1: sts pr, r5 + mov.l ._reloc_dst, r4 + add #(_start-1b), r5 + mov.l ._reloc_dst_end, r6 + +2: mov.l @r5+, r1 + mov.l r1, @r4 + add #4, r4 + cmp/hs r6, r4 + bf 2b + + mov.l ._bss_start, r4 + mov.l ._bss_end, r5 + mov #0, r1 + +3: mov.l r1, @r4 /* bss clear */ + add #4, r4 + cmp/hs r5, r4 + bf 3b + + mov.l ._gd_init, r13 /* global data */ + mov.l ._stack_init, r15 /* stack */ + + mov.l ._sh_generic_init, r0 + jsr @r0 + nop + +loop: + bra loop + + .align 2 + +._lowlevel_init: .long (lowlevel_init - (100b + 4)) +._reloc_dst: .long reloc_dst +._reloc_dst_end: .long reloc_dst_end +._bss_start: .long bss_start +._bss_end: .long bss_end +._gd_init: .long (_start - CFG_GBL_DATA_SIZE) +._stack_init: .long (_start - CFG_GBL_DATA_SIZE - CFG_MALLOC_LEN - 16) +._sh_generic_init: .long sh_generic_init + diff -uprN a/cpu/sh3/time.c b/cpu/sh3/time.c --- a/cpu/sh3/time.c 1970-01-01 09:00:00.000000000 +0900 +++ b/cpu/sh3/time.c 2007-12-03 22:42:33.000000000 +0900 @@ -0,0 +1,103 @@ +/* + * (C) Copyright 2007 + * Yoshihiro Shimoda shimoda.yoshihiro@renesas.com + * + * (C) Copyright 2007 + * Nobobuhiro Iwamatsu iwamatsu@nigauri.org + * + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/processor.h> +#include <asm/io.h> + +#define TMU_MAX_COUNTER (~0UL) + +static void tmu_timer_start(unsigned int timer) +{ + if (timer > 2) + return; + + outb(inb(TSTR) | (1 << timer), TSTR); +} + +static void tmu_timer_stop(unsigned int timer) +{ + u8 val = inb(TSTR); + + if (timer > 2) + return; + outb(val & ~(1 << timer), TSTR); +} + +int timer_init(void) +{ + /* Divide clock by 4 */ + outw(0, TCR0); + + tmu_timer_stop(0); + tmu_timer_start(0); + return 0; +} + +/* + In theory we should return a true 64bit value (ie something that doesn't + overflow). However, we don't. Therefore if TMU runs at fastest rate of + 6.75 MHz this value will wrap after u-boot has been running for approx + 10 minutes. +*/ +unsigned long long get_ticks(void) +{ + return (0 - inl(TCNT0)); +} + +unsigned long get_timer(unsigned long base) +{ + return ((0 - inl(TCNT0)) - base); +} + +void set_timer(unsigned long t) +{ + outl(0 - t, TCNT0); +} + +void reset_timer(void) +{ + tmu_timer_stop(0); + set_timer(0); + tmu_timer_start(0); +} + +void udelay(unsigned long usec) +{ + unsigned int start = get_timer(0); + unsigned int end = start + (usec * ((CFG_HZ + 500000) / 1000000)); + + while (get_timer(0) < end) + continue; +} + +unsigned long get_tbclk(void) +{ + return CFG_HZ; +} diff -uprN a/cpu/sh3/watchdog.c b/cpu/sh3/watchdog.c --- a/cpu/sh3/watchdog.c 1970-01-01 09:00:00.000000000 +0900 +++ b/cpu/sh3/watchdog.c 2007-12-03 22:07:40.000000000 +0900 @@ -0,0 +1,34 @@ +/* + * (C) Copyright 2007 + * Yoshihiro Shimoda shimoda.yoshihiro@renesas.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/processor.h> + +int watchdog_init(void) +{ + return 0; +} + +void reset_cpu(unsigned long ignored) +{ + while (1) + ; +} + diff -uprN a/include/asm-sh/cpu_sh3.h b/include/asm-sh/cpu_sh3.h --- a/include/asm-sh/cpu_sh3.h 1970-01-01 09:00:00.000000000 +0900 +++ b/include/asm-sh/cpu_sh3.h 2007-12-03 22:08:18.000000000 +0900 @@ -0,0 +1,40 @@ +/* + * (C) Copyright 2007 Nobuhiro Iwamatsu iwamatsu@nigauri.org + * (C) Copyright 2007 Yoshihiro Shimoda shimoda.yoshihiro@renesas.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _ASM_CPU_SH3_H_ +#define _ASM_CPU_SH3_H_ + +/* cache control */ +#define CCR_CACHE_STOP 0x00000008 +#define CCR_CACHE_ENABLE 0x00000005 +#define CCR_CACHE_ICI 0x00000008 + +#define CACHE_OC_ADDRESS_ARRAY 0xf0000000 +#define CACHE_OC_WAY_SHIFT 13 +#define CACHE_OC_NUM_ENTRIES 256 +#define CACHE_OC_ENTRY_SHIFT 4 + +#if defined(CONFIG_CPU_SH7720) +#include <asm/cpu_sh7720.h> +#else +#error "Unknown SH3 variant" +#endif + +#endif /* _ASM_CPU_SH3_H_ */ diff -uprN a/include/asm-sh/cpu_sh7720.h b/include/asm-sh/cpu_sh7720.h --- a/include/asm-sh/cpu_sh7720.h 1970-01-01 09:00:00.000000000 +0900 +++ b/include/asm-sh/cpu_sh7720.h 2007-12-03 22:54:18.000000000 +0900 @@ -0,0 +1,207 @@ +/* + * (C) Copyright 2007 Yoshihiro Shimoda shimoda.yoshihiro@renesas.com + * + * SH7720 Internal I/O register + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _ASM_CPU_SH7720_H_ +#define _ASM_CPU_SH7720_H_ + +#define CACHE_OC_NUM_WAYS 4 +#define CCR_CACHE_INIT 0x0000000B + +/* EXP */ +#define TRA 0xFFFFFFD0 +#define EXPEVT 0xFFFFFFD4 +#define INTEVT 0xFFFFFFD8 + +/* MMU */ +#define MMUCR 0xFFFFFFE0 +#define PTEH 0xFFFFFFF0 +#define PTEL 0xFFFFFFF4 +#define TTB 0xFFFFFFF8 + +/* CACHE */ +#define CCR 0xFFFFFFEC + +/* INTC */ +#define IPRF 0xA4080000 +#define IPRG 0xA4080002 +#define IPRH 0xA4080004 +#define IPRI 0xA4080006 +#define IPRJ 0xA4080008 +#define IRR5 0xA4080020 +#define IRR6 0xA4080022 +#define IRR7 0xA4080024 +#define IRR8 0xA4080026 +#define IRR9 0xA4080028 +#define IRR0 0xA4140004 +#define IRR1 0xA4140006 +#define IRR2 0xA4140008 +#define IRR3 0xA414000A +#define IRR4 0xA414000C +#define ICR1 0xA4140010 +#define ICR2 0xA4140012 +#define PINTER 0xA4140014 +#define IPRC 0xA4140016 +#define IPRD 0xA4140018 +#define IPRE 0xA414001A +#define ICR0 0xA414FEE0 +#define IPRA 0xA414FEE2 +#define IPRB 0xA414FEE4 + +/* BSC */ +#define BSC_BASE 0xA4FD0000 +#define CMNCR (BSC_BASE + 0x00) +#define CS0BCR (BSC_BASE + 0x04) +#define CS2BCR (BSC_BASE + 0x08) +#define CS3BCR (BSC_BASE + 0x0C) +#define CS4BCR (BSC_BASE + 0x10) +#define CS5ABCR (BSC_BASE + 0x14) +#define CS5BBCR (BSC_BASE + 0x18) +#define CS6ABCR (BSC_BASE + 0x1C) +#define CS6BBCR (BSC_BASE + 0x20) +#define CS0WCR (BSC_BASE + 0x24) +#define CS2WCR (BSC_BASE + 0x28) +#define CS3WCR (BSC_BASE + 0x2C) +#define CS4WCR (BSC_BASE + 0x30) +#define CS5AWCR (BSC_BASE + 0x34) +#define CS5BWCR (BSC_BASE + 0x38) +#define CS6AWCR (BSC_BASE + 0x3C) +#define CS6BWCR (BSC_BASE + 0x40) +#define SDCR (BSC_BASE + 0x44) +#define RTCSR (BSC_BASE + 0x48) +#define RTCNR (BSC_BASE + 0x4C) +#define RTCOR (BSC_BASE + 0x50) +#define SDMR2 (BSC_BASE + 0x4000) +#define SDMR3 (BSC_BASE + 0x5000) + +/* DMAC */ + +/* CPG */ +#define UCLKCR 0xA40A0008 +#define FRQCR 0xA415FF80 + +/* LOW POWER MODE */ + +/* TMU */ +#define TMU_BASE 0xA412FE90 +#define TSTR (TMU_BASE + 0x02) +#define TCOR0 (TMU_BASE + 0x04) +#define TCNT0 (TMU_BASE + 0x08) +#define TCR0 (TMU_BASE + 0x0C) +#define TCOR1 (TMU_BASE + 0x10) +#define TCNT1 (TMU_BASE + 0x14) +#define TCR1 (TMU_BASE + 0x18) +#define TCOR2 (TMU_BASE + 0x1C) +#define TCNT2 (TMU_BASE + 0x20) +#define TCR2 (TMU_BASE + 0x24) + +/* TPU */ +#define TPU_BASE 0xA4480000 +#define TPU_TSTR (TPU_BASE + 0x00) +#define TPU_TCR0 (TPU_BASE + 0x10) +#define TPU_TMDR0 (TPU_BASE + 0x14) +#define TPU_TIOR0 (TPU_BASE + 0x18) +#define TPU_TIER0 (TPU_BASE + 0x1C) +#define TPU_TSR0 (TPU_BASE + 0x20) +#define TPU_TCNT0 (TPU_BASE + 0x24) +#define TPU_TGRA0 (TPU_BASE + 0x28) +#define TPU_TGRB0 (TPU_BASE + 0x2C) +#define TPU_TGRC0 (TPU_BASE + 0x30) +#define TPU_TGRD0 (TPU_BASE + 0x34) +#define TPU_TCR1 (TPU_BASE + 0x50) +#define TPU_TMDR1 (TPU_BASE + 0x54) +#define TPU_TIOR1 (TPU_BASE + 0x58) +#define TPU_TIER1 (TPU_BASE + 0x5C) +#define TPU_TSR1 (TPU_BASE + 0x60) +#define TPU_TCNT1 (TPU_BASE + 0x64) +#define TPU_TGRA1 (TPU_BASE + 0x68) +#define TPU_TGRB1 (TPU_BASE + 0x6C) +#define TPU_TGRC1 (TPU_BASE + 0x70) +#define TPU_TGRD1 (TPU_BASE + 0x74) +#define TPU_TCR2 (TPU_BASE + 0x90) +#define TPU_TMDR2 (TPU_BASE + 0x94) +#define TPU_TIOR2 (TPU_BASE + 0x98) +#define TPU_TIER2 (TPU_BASE + 0x9C) +#define TPU_TSR2 (TPU_BASE + 0xB0) +#define TPU_TCNT2 (TPU_BASE + 0xB4) +#define TPU_TGRA2 (TPU_BASE + 0xB8) +#define TPU_TGRB2 (TPU_BASE + 0xBC) +#define TPU_TGRC2 (TPU_BASE + 0xC0) +#define TPU_TGRD2 (TPU_BASE + 0xC4) +#define TPU_TCR3 (TPU_BASE + 0xD0) +#define TPU_TMDR3 (TPU_BASE + 0xD4) +#define TPU_TIOR3 (TPU_BASE + 0xD8) +#define TPU_TIER3 (TPU_BASE + 0xDC) +#define TPU_TSR3 (TPU_BASE + 0xE0) +#define TPU_TCNT3 (TPU_BASE + 0xE4) +#define TPU_TGRA3 (TPU_BASE + 0xE8) +#define TPU_TGRB3 (TPU_BASE + 0xEC) +#define TPU_TGRC3 (TPU_BASE + 0xF0) +#define TPU_TGRD3 (TPU_BASE + 0xF4) + +/* CMT */ + +/* SIOF */ + +/* SCIF */ +#define SCIF0_BASE 0xA4430000 + +/* SIM */ + +/* IrDA */ + +/* IIC */ + +/* LCDC */ + +/* USBF */ + +/* MMCIF */ + +/* PFC */ +#define PFC_BASE 0xA4050100 +#define PACR (PFC_BASE + 0x00) +#define PBCR (PFC_BASE + 0x02) +#define PCCR (PFC_BASE + 0x04) +#define PDCR (PFC_BASE + 0x06) +#define PECR (PFC_BASE + 0x08) +#define PFCR (PFC_BASE + 0x0A) +#define PGCR (PFC_BASE + 0x0C) +#define PHCR (PFC_BASE + 0x0E) +#define PJCR (PFC_BASE + 0x10) +#define PKCR (PFC_BASE + 0x12) +#define PLCR (PFC_BASE + 0x14) +#define PMCR (PFC_BASE + 0x16) +#define PPCR (PFC_BASE + 0x18) +#define PRCR (PFC_BASE + 0x1A) +#define PSCR (PFC_BASE + 0x1C) +#define PTCR (PFC_BASE + 0x1E) +#define PUCR (PFC_BASE + 0x20) +#define PVCR (PFC_BASE + 0x22) +#define PSELA (PFC_BASE + 0x24) +#define PSELB (PFC_BASE + 0x26) +#define PSELC (PFC_BASE + 0x28) +#define PSELD (PFC_BASE + 0x2A) + +/* I/O Port */ + +/* H-UDI */ + +#endif /* _ASM_CPU_SH7720_H_ */
On Mon, 03 Dec 2007 22:58:45 +0900 Yoshihiro Shimoda shimoda.yoshihiro@renesas.com wrote:
Applied, thanks.
Nobuhiro Iwamatsu
Yoshihiro Shimoda
