[PATCH] test/py: fix SquashFS tests
Use "cons.config.build_dir" instead of writing to the source directory (read-only). This will fix the test failures in Azure.
Signed-off-by: Joao Marcos Costa joaomarcos.costa@bootlin.com --- test/py/tests/test_fs/test_squashfs/sqfs_common.py | 12 ++++++------ .../py/tests/test_fs/test_squashfs/test_sqfs_load.py | 9 +++++---- test/py/tests/test_fs/test_squashfs/test_sqfs_ls.py | 9 +++++---- 3 files changed, 16 insertions(+), 14 deletions(-)
diff --git a/test/py/tests/test_fs/test_squashfs/sqfs_common.py b/test/py/tests/test_fs/test_squashfs/sqfs_common.py index 9ef7b19ad9..2dc344d1b2 100644 --- a/test/py/tests/test_fs/test_squashfs/sqfs_common.py +++ b/test/py/tests/test_fs/test_squashfs/sqfs_common.py @@ -20,9 +20,9 @@ def sqfs_generate_file(path, size): file.close()
# generate image with three files and a symbolic link -def sqfs_generate_image(): - src = "test/py/tests/test_fs/test_squashfs/sqfs_src/" - dest = "test/py/tests/test_fs/test_squashfs/sqfs" +def sqfs_generate_image(cons): + src = os.path.join(cons.config.build_dir, "sqfs_src/") + dest = os.path.join(cons.config.build_dir, "sqfs") os.mkdir(src) sqfs_generate_file(src + "frag_only", 100) sqfs_generate_file(src + "blks_frag", 5100) @@ -31,9 +31,9 @@ def sqfs_generate_image(): os.system("mksquashfs " + src + " " + dest + " -b 4096 -always-use-fragments")
# removes all files created by sqfs_generate_image() -def sqfs_clean(): - src = "test/py/tests/test_fs/test_squashfs/sqfs_src/" - dest = "test/py/tests/test_fs/test_squashfs/sqfs" +def sqfs_clean(cons): + src = os.path.join(cons.config.build_dir, "sqfs_src/") + dest = os.path.join(cons.config.build_dir, "sqfs") os.remove(src + "frag_only") os.remove(src + "blks_frag") os.remove(src + "blks_only") diff --git a/test/py/tests/test_fs/test_squashfs/test_sqfs_load.py b/test/py/tests/test_fs/test_squashfs/test_sqfs_load.py index 9b828fdf04..eb1baae5c5 100644 --- a/test/py/tests/test_fs/test_squashfs/test_sqfs_load.py +++ b/test/py/tests/test_fs/test_squashfs/test_sqfs_load.py @@ -12,9 +12,10 @@ from sqfs_common import * @pytest.mark.buildconfigspec('fs_squashfs') @pytest.mark.requiredtool('mksquashfs') def test_sqfs_load(u_boot_console): - sqfs_generate_image() + cons = u_boot_console + sqfs_generate_image(cons) command = "sqfsload host 0 $kernel_addr_r " - path = "test/py/tests/test_fs/test_squashfs/sqfs" + path = os.path.join(cons.config.build_dir, "sqfs")
try: output = u_boot_console.run_command("host bind 0 " + path) @@ -29,5 +30,5 @@ def test_sqfs_load(u_boot_console): output = u_boot_console.run_command(command + "sym") assert "100 bytes read in" in output except: - sqfs_clean() - sqfs_clean() + sqfs_clean(cons) + sqfs_clean(cons) diff --git a/test/py/tests/test_fs/test_squashfs/test_sqfs_ls.py b/test/py/tests/test_fs/test_squashfs/test_sqfs_ls.py index dc31f1a50e..3a7b75c778 100644 --- a/test/py/tests/test_fs/test_squashfs/test_sqfs_ls.py +++ b/test/py/tests/test_fs/test_squashfs/test_sqfs_ls.py @@ -12,8 +12,9 @@ from sqfs_common import * @pytest.mark.buildconfigspec('fs_squashfs') @pytest.mark.requiredtool('mksquashfs') def test_sqfs_ls(u_boot_console): - sqfs_generate_image() - path = "test/py/tests/test_fs/test_squashfs/sqfs" + cons = u_boot_console + sqfs_generate_image(cons) + path = os.path.join(cons.config.build_dir, "sqfs") try: output = u_boot_console.run_command("host bind 0 " + path) output = u_boot_console.run_command("sqfsls host 0") @@ -22,5 +23,5 @@ def test_sqfs_ls(u_boot_console): output = u_boot_console.run_command("sqfsls host 0 xxx") assert "** Cannot find directory. **" in output except: - sqfs_clean() - sqfs_clean() + sqfs_clean(cons) + sqfs_clean(cons)
Joao Marcos Costa
