[PATCH] configs: turing-rk1: disable SPI flash by default
While the Turing RK1 board has a pad on the PCB for SPI flash, it is not populated at the factory: supporting SPI flash boot is a user modification, not an out-of-the-box feature. The defconfig for this board should therefore not be enabling the SPI flash image nor SPI support in the SPL, as it causes confusion among downstream users as to whether the SPI image needs to be distributed.
Fixes: 153ac950a599 ("board: rockchip: Add the Turing RK1 SoM") Suggested-by: Florian Klink flokli@flokli.de Signed-off-by: Sam Edwards CFSworks@gmail.com Acked-by: Joshua Riek jjriek@verizon.net --- configs/turing-rk1-rk3588_defconfig | 6 ------ 1 file changed, 6 deletions(-)
diff --git a/configs/turing-rk1-rk3588_defconfig b/configs/turing-rk1-rk3588_defconfig index 07f7b84852..28c3e50ed4 100644 --- a/configs/turing-rk1-rk3588_defconfig +++ b/configs/turing-rk1-rk3588_defconfig @@ -8,13 +8,10 @@ CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SF_DEFAULT_MODE=0x2000 CONFIG_DEFAULT_DEVICE_TREE="rk3588-turing-rk1" CONFIG_ROCKCHIP_RK3588=y -CONFIG_ROCKCHIP_SPI_IMAGE=y CONFIG_SPL_SERIAL=y CONFIG_TARGET_TURINGRK1_RK3588=y CONFIG_DEBUG_UART_BASE=0xFEBC0000 CONFIG_DEBUG_UART_CLOCK=24000000 -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI=y CONFIG_SYS_LOAD_ADDR=0xc00800 CONFIG_PCI=y CONFIG_DEBUG_UART=y @@ -31,8 +28,6 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set -CONFIG_SPL_SPI_LOAD=y -CONFIG_SYS_SPI_U_BOOT_OFFS=0x60000 CONFIG_SPL_ATF=y CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y @@ -109,7 +104,6 @@ CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_RTL8152=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_PRODUCT_NUM=0x350b CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_FUNCTION_ROCKUSB=y CONFIG_ERRNO_STR=y
Hi Sam,
The device tree synced from linux does not even enable the sfc node, so please either remove all related config options for spi flash or only remove the ROCKCHIP_SPI_IMAGE option if the sfc and a flash node will be enabled/added to upstream linux devicetree.
Additional options related to spi flash not removed in this patch: - SF_DEFAULT_SPEED - SF_DEFAULT_MODE - SF_DEFAULT_BUS - SPI_FLASH_SFDP_SUPPORT - SPI_FLASH_MACRONIX - SPI_FLASH_XMC - SPI_FLASH_XTX - ROCKCHIP_SFC
This is an unrelated change that may cause apply issues if "rockchip: rk35xx: DropUSB_GADGET_PRODUCT_NUM Kconfig option" [1] or is Tom make a sync defconfigs commit that is applied before this patch.
[1] https://patchwork.ozlabs.org/patch/1917934/
With above fixed,
Reviewed-by: Jonas Karlman jonas@kwiboo.se
Regards, Jonas
Jonas Karlman
Sam Edwards
