[U-Boot] [PATCH][v2] powerpc/b4860: Updated default hwconfig so as to enable only
CPC1 is not being enabled by default as powerpc is supposed to use only CPC2. Though by editing hwconfig en_cpc option, CPC1 can also be enabled
Signed-off-by: Shaveta Leekha shaveta@freescale.com Signed-off-by: Sandeep Singh Sandeep@freescale.com --- Tested on B4860QDS
Changes in V2: Inserted "en_cpc:cpc2" at right place, not to broke into the settings for DDR
include/configs/B4860QDS.h | 11 +++++++++-- 1 files changed, 9 insertions(+), 2 deletions(-)
diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 953d06b..6deb784 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -819,9 +819,16 @@ unsigned long get_board_ddr_clk(void);
#define __USB_PHY_TYPE ulpi
+#ifdef CONFIG_PPC_B4860 +#define HWCONFIG "hwconfig=fsl_ddr:ctlr_intlv=null," \ + "bank_intlv=cs0_cs1;" \ + "en_cpc:cpc2;" +#else +#define HWCONFIG "hwconfig=fsl_ddr:ctlr_intlv=null,bank_intlv=cs0_cs1;" +#endif + #define CONFIG_EXTRA_ENV_SETTINGS \ - "hwconfig=fsl_ddr:ctlr_intlv=null," \ - "bank_intlv=cs0_cs1;" \ + HWCONFIG \ "usb1:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) "\0"\ "netdev=eth0\0" \ "uboot=" __stringify(CONFIG_UBOOTPATH) "\0" \
Tested on B4860QDS
Appended cpc2 to the subject.
Applied to u-boot-mpc85xx, awaiting upstream.
York
Shaveta Leekha
York Sun
