[U-Boot] [PATCH V2 0/7] ARM: OMAP4+: Cleanup clocks, control and emif code
This series is intended to cleanup code which is duplicated across soc specific files. This is accomplished by moving soc specifc data to one place and having the code common. This helps in avoiding un necessary cpu checks and minimal code addition for future socs.
Tested this on OMAP5 ES1.0, OMAP4460 Panda boards and verified MAKEALL for all armv7 boards.
Lokesh Vutla (4): ARM: OMAP4+: emif: Detect SDRAM from SDRAM config register ARM: OMAP4+: Cleanup emif specific files ARM: OMAP4+: Make control module register structure generic ARM: OMAP5: Clean up iosettings code
R Sricharan (3): ARM: OMAP4+: Change the PRCM structure prototype common for all Socs ARM: OMAP4+: Cleanup the clocks layer ARM: OMAP4+: Clean up the pmic code
arch/arm/cpu/armv7/omap-common/clocks-common.c | 283 ++++++++---- arch/arm/cpu/armv7/omap-common/emif-common.c | 71 ++- arch/arm/cpu/armv7/omap-common/hwinit-common.c | 8 +- arch/arm/cpu/armv7/omap-common/vc.c | 11 +- arch/arm/cpu/armv7/omap4/Makefile | 3 +- arch/arm/cpu/armv7/omap4/clocks.c | 517 ---------------------- arch/arm/cpu/armv7/omap4/hw_data.c | 502 +++++++++++++++++++++ arch/arm/cpu/armv7/omap4/hwinit.c | 36 +- arch/arm/cpu/armv7/omap4/prcm-regs.c | 315 +++++++++++++ arch/arm/cpu/armv7/omap4/sdram_elpida.c | 16 +- arch/arm/cpu/armv7/omap5/Makefile | 3 +- arch/arm/cpu/armv7/omap5/clocks.c | 494 --------------------- arch/arm/cpu/armv7/omap5/hw_data.c | 494 +++++++++++++++++++++ arch/arm/cpu/armv7/omap5/hwinit.c | 131 +++--- arch/arm/cpu/armv7/omap5/prcm-regs.c | 380 ++++++++++++++++ arch/arm/cpu/armv7/omap5/sdram.c | 119 +++-- arch/arm/include/asm/arch-omap4/clocks.h | 562 ++---------------------- arch/arm/include/asm/arch-omap4/omap.h | 33 +- arch/arm/include/asm/arch-omap4/sys_proto.h | 3 +- arch/arm/include/asm/arch-omap5/clocks.h | 506 +-------------------- arch/arm/include/asm/arch-omap5/omap.h | 96 +--- arch/arm/include/asm/arch-omap5/sys_proto.h | 4 +- arch/arm/include/asm/emif.h | 18 +- arch/arm/include/asm/omap_common.h | 482 ++++++++++++++++++++ drivers/mmc/omap_hsmmc.c | 25 +- include/configs/omap5_evm.h | 1 + 26 files changed, 2659 insertions(+), 2454 deletions(-) delete mode 100644 arch/arm/cpu/armv7/omap4/clocks.c create mode 100644 arch/arm/cpu/armv7/omap4/hw_data.c create mode 100644 arch/arm/cpu/armv7/omap4/prcm-regs.c delete mode 100644 arch/arm/cpu/armv7/omap5/clocks.c create mode 100644 arch/arm/cpu/armv7/omap5/hw_data.c create mode 100644 arch/arm/cpu/armv7/omap5/prcm-regs.c
Now SDRAM initialization is done on the basis of omap revision. Instead this should be done on basis of SDRAM type read from EMIF_SDRAM_CONFIG register. This will be helpful to avoid unnessecary cpu checks for new boards
Signed-off-by: R Sricharan r.sricharan@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- [V2] Addressed Tom Rini's trini@ti.com comments
arch/arm/cpu/armv7/omap-common/clocks-common.c | 3 ++- arch/arm/cpu/armv7/omap-common/emif-common.c | 21 +++++++++++++++++---- arch/arm/cpu/armv7/omap5/clocks.c | 3 ++- arch/arm/cpu/armv7/omap5/hwinit.c | 2 +- arch/arm/include/asm/emif.h | 6 ++++++ 5 files changed, 28 insertions(+), 7 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/clocks-common.c b/arch/arm/cpu/armv7/omap-common/clocks-common.c index b1fd277..1f95fba 100644 --- a/arch/arm/cpu/armv7/omap-common/clocks-common.c +++ b/arch/arm/cpu/armv7/omap-common/clocks-common.c @@ -36,6 +36,7 @@ #include <asm/arch/sys_proto.h> #include <asm/utils.h> #include <asm/omap_gpio.h> +#include <asm/emif.h>
#ifndef CONFIG_SPL_BUILD /* @@ -299,7 +300,7 @@ static void setup_dplls(void) * Core DPLL will be locked after setting up EMIF * using the FREQ_UPDATE method(freq_update_core()) */ - if (omap_revision() != OMAP5432_ES1_0) + if (emif_sdram_type() == EMIF_SDRAM_TYPE_LPDDR2) do_setup_dpll(&prcm->cm_clkmode_dpll_core, params, DPLL_NO_LOCK, "core"); else diff --git a/arch/arm/cpu/armv7/omap-common/emif-common.c b/arch/arm/cpu/armv7/omap-common/emif-common.c index 88253cf..8864abc 100644 --- a/arch/arm/cpu/armv7/omap-common/emif-common.c +++ b/arch/arm/cpu/armv7/omap-common/emif-common.c @@ -66,6 +66,19 @@ inline u32 emif_num(u32 base) return 0; }
+/* + * Get SDRAM type connected to EMIF. + * Assuming similar SDRAM parts are connected to both EMIF's + * which is typically the case. So it is sufficient to get + * SDRAM type from EMIF1. + */ +u32 emif_sdram_type() +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)EMIF1_BASE; + + return (readl(&emif->emif_sdram_config) & + EMIF_REG_SDRAM_TYPE_MASK) >> EMIF_REG_SDRAM_TYPE_SHIFT; +}
static inline u32 get_mr(u32 base, u32 cs, u32 mr_addr) { @@ -1079,7 +1092,7 @@ static void do_sdram_init(u32 base) * OPP to another) */ if (!(in_sdram || warm_reset())) { - if (omap_revision() != OMAP5432_ES1_0) + if (emif_sdram_type() == EMIF_SDRAM_TYPE_LPDDR2) lpddr2_init(base, regs); else ddr3_init(base, regs); @@ -1264,7 +1277,7 @@ void dmm_init(u32 base) void sdram_init(void) { u32 in_sdram, size_prog, size_detect; - u32 omap_rev = omap_revision(); + u32 sdram_type = emif_sdram_type();
debug(">>sdram_init()\n");
@@ -1275,7 +1288,7 @@ void sdram_init(void) debug("in_sdram = %d\n", in_sdram);
if (!(in_sdram || warm_reset())) { - if (omap_rev != OMAP5432_ES1_0) + if (sdram_type == EMIF_SDRAM_TYPE_LPDDR2) bypass_dpll(&prcm->cm_clkmode_dpll_core); else writel(CM_DLL_CTRL_NO_OVERRIDE, &prcm->cm_dll_ctrl); @@ -1298,7 +1311,7 @@ void sdram_init(void) }
/* for the shadow registers to take effect */ - if (omap_rev != OMAP5432_ES1_0) + if (sdram_type == EMIF_SDRAM_TYPE_LPDDR2) freq_update_core();
/* Do some testing after the init */ diff --git a/arch/arm/cpu/armv7/omap5/clocks.c b/arch/arm/cpu/armv7/omap5/clocks.c index eecfbad..1f33692 100644 --- a/arch/arm/cpu/armv7/omap5/clocks.c +++ b/arch/arm/cpu/armv7/omap5/clocks.c @@ -36,6 +36,7 @@ #include <asm/arch/sys_proto.h> #include <asm/utils.h> #include <asm/omap_gpio.h> +#include <asm/emif.h>
#ifndef CONFIG_SPL_BUILD /* @@ -279,7 +280,7 @@ void scale_vcores(void) do_scale_vcore(SMPS_REG_ADDR_12_MPU, volt_mpu); do_scale_vcore(SMPS_REG_ADDR_45_IVA, volt_mm);
- if (omap_revision() == OMAP5432_ES1_0) { + if (emif_sdram_type() == EMIF_SDRAM_TYPE_DDR3) { /* Configure LDO SRAM "magic" bits */ writel(2, &prcm->prm_sldo_core_setup); writel(2, &prcm->prm_sldo_mpu_setup); diff --git a/arch/arm/cpu/armv7/omap5/hwinit.c b/arch/arm/cpu/armv7/omap5/hwinit.c index d0c3ff7..4def422 100644 --- a/arch/arm/cpu/armv7/omap5/hwinit.c +++ b/arch/arm/cpu/armv7/omap5/hwinit.c @@ -191,7 +191,7 @@ void do_io_settings(void) (sc_fast << 17) | (sc_fast << 14); writel(io_settings, &(ioregs_base->control_smart3io_padconf_1));
- if (omap_revision() <= OMAP5430_ES1_0) + if (emif_sdram_type() == EMIF_SDRAM_TYPE_LPDDR2) io_settings_lpddr2(); else io_settings_ddr3(); diff --git a/arch/arm/include/asm/emif.h b/arch/arm/include/asm/emif.h index ed251ec..0824a80 100644 --- a/arch/arm/include/asm/emif.h +++ b/arch/arm/include/asm/emif.h @@ -1027,6 +1027,11 @@ extern const u32 ddr3_ext_phy_ctrl_const_base[EMIF_EXT_PHY_CTRL_CONST_REG]; #define MR8_IO_WIDTH_SHIFT 0x6 #define MR8_IO_WIDTH_MASK (0x3 << 0x6)
+/* SDRAM TYPE */ +#define EMIF_SDRAM_TYPE_DDR2 0x2 +#define EMIF_SDRAM_TYPE_DDR3 0x3 +#define EMIF_SDRAM_TYPE_LPDDR2 0x4 + struct lpddr2_addressing { u8 num_banks; u8 t_REFI_us_x10; @@ -1156,4 +1161,5 @@ extern u32 *const emif_sizes; #endif
void config_data_eye_leveling_samples(u32 emif_base); +u32 emif_sdram_type(void); #endif
Reviewed-by: Tom Rini trini@ti.com
The current PRCM structure prototype directly matches the hardware register layout. So there is a need to change this for every new silicon revision which has register space changes.
Avoiding this by making the prototye generic and populating the register addresses seperately for all Socs.
arch/arm/cpu/armv7/omap-common/clocks-common.c | 106 ++--- arch/arm/cpu/armv7/omap-common/emif-common.c | 4 +- arch/arm/cpu/armv7/omap-common/hwinit-common.c | 3 + arch/arm/cpu/armv7/omap-common/vc.c | 11 +- arch/arm/cpu/armv7/omap4/Makefile | 2 + arch/arm/cpu/armv7/omap4/clocks.c | 199 +++++---- arch/arm/cpu/armv7/omap4/hw_data.c | 38 ++ arch/arm/cpu/armv7/omap4/prcm-regs.c | 295 +++++++++++++ arch/arm/cpu/armv7/omap5/Makefile | 2 + arch/arm/cpu/armv7/omap5/clocks.c | 215 +++++----- arch/arm/cpu/armv7/omap5/hw_data.c | 38 ++ arch/arm/cpu/armv7/omap5/prcm-regs.c | 306 ++++++++++++++ arch/arm/include/asm/arch-omap4/clocks.h | 524 +++--------------------- arch/arm/include/asm/arch-omap4/omap.h | 3 +- arch/arm/include/asm/arch-omap4/sys_proto.h | 2 +- arch/arm/include/asm/arch-omap5/clocks.h | 460 +-------------------- arch/arm/include/asm/arch-omap5/omap.h | 3 +- arch/arm/include/asm/arch-omap5/sys_proto.h | 2 +- arch/arm/include/asm/omap_common.h | 304 ++++++++++++++ 19 files changed, 1312 insertions(+), 1205 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap4/hw_data.c create mode 100644 arch/arm/cpu/armv7/omap4/prcm-regs.c create mode 100644 arch/arm/cpu/armv7/omap5/hw_data.c create mode 100644 arch/arm/cpu/armv7/omap5/prcm-regs.c
diff --git a/arch/arm/cpu/armv7/omap-common/clocks-common.c b/arch/arm/cpu/armv7/omap-common/clocks-common.c index 1f95fba..d36fccc 100644 --- a/arch/arm/cpu/armv7/omap-common/clocks-common.c +++ b/arch/arm/cpu/armv7/omap-common/clocks-common.c @@ -61,7 +61,7 @@ static inline u32 __get_sys_clk_index(void) ind = OMAP_SYS_CLK_IND_38_4_MHZ; else { /* SYS_CLKSEL - 1 to match the dpll param array indices */ - ind = (readl(&prcm->cm_sys_clksel) & + ind = (readl((*prcm)->cm_sys_clksel) & CM_SYS_CLKSEL_SYS_CLKSEL_MASK) - 1; } return ind; @@ -76,7 +76,7 @@ u32 get_sys_clk_freq(void) return sys_clk_array[index]; }
-static inline void do_bypass_dpll(u32 *const base) +static inline void do_bypass_dpll(u32 const base) { struct dpll_regs *dpll_regs = (struct dpll_regs *)base;
@@ -86,17 +86,17 @@ static inline void do_bypass_dpll(u32 *const base) CM_CLKMODE_DPLL_EN_SHIFT); }
-static inline void wait_for_bypass(u32 *const base) +static inline void wait_for_bypass(u32 const base) { struct dpll_regs *const dpll_regs = (struct dpll_regs *)base;
if (!wait_on_value(ST_DPLL_CLK_MASK, 0, &dpll_regs->cm_idlest_dpll, LDELAY)) { - printf("Bypassing DPLL failed %p\n", base); + printf("Bypassing DPLL failed %x\n", base); } }
-static inline void do_lock_dpll(u32 *const base) +static inline void do_lock_dpll(u32 const base) { struct dpll_regs *const dpll_regs = (struct dpll_regs *)base;
@@ -105,18 +105,18 @@ static inline void do_lock_dpll(u32 *const base) DPLL_EN_LOCK << CM_CLKMODE_DPLL_EN_SHIFT); }
-static inline void wait_for_lock(u32 *const base) +static inline void wait_for_lock(u32 const base) { struct dpll_regs *const dpll_regs = (struct dpll_regs *)base;
if (!wait_on_value(ST_DPLL_CLK_MASK, ST_DPLL_CLK_MASK, &dpll_regs->cm_idlest_dpll, LDELAY)) { - printf("DPLL locking failed for %p\n", base); + printf("DPLL locking failed for %x\n", base); hang(); } }
-inline u32 check_for_lock(u32 *const base) +inline u32 check_for_lock(u32 const base) { struct dpll_regs *const dpll_regs = (struct dpll_regs *)base; u32 lock = readl(&dpll_regs->cm_idlest_dpll) & ST_DPLL_CLK_MASK; @@ -124,7 +124,7 @@ inline u32 check_for_lock(u32 *const base) return lock; }
-static void do_setup_dpll(u32 *const base, const struct dpll_params *params, +static void do_setup_dpll(u32 const base, const struct dpll_params *params, u8 lock, char *dpll) { u32 temp, M, N; @@ -236,24 +236,24 @@ void configure_mpu_dpll(void) */ if ((omap_rev >= OMAP4460_ES1_0) && (omap_rev < OMAP5430_ES1_0)) { mpu_dpll_regs = - (struct dpll_regs *)&prcm->cm_clkmode_dpll_mpu; - bypass_dpll(&prcm->cm_clkmode_dpll_mpu); - clrbits_le32(&prcm->cm_mpu_mpu_clkctrl, + (struct dpll_regs *)((*prcm)->cm_clkmode_dpll_mpu); + bypass_dpll((*prcm)->cm_clkmode_dpll_mpu); + clrbits_le32((*prcm)->cm_mpu_mpu_clkctrl, MPU_CLKCTRL_CLKSEL_EMIF_DIV_MODE_MASK); - setbits_le32(&prcm->cm_mpu_mpu_clkctrl, + setbits_le32((*prcm)->cm_mpu_mpu_clkctrl, MPU_CLKCTRL_CLKSEL_ABE_DIV_MODE_MASK); clrbits_le32(&mpu_dpll_regs->cm_clksel_dpll, CM_CLKSEL_DCC_EN_MASK); }
- setbits_le32(&prcm->cm_mpu_mpu_clkctrl, + setbits_le32((*prcm)->cm_mpu_mpu_clkctrl, MPU_CLKCTRL_CLKSEL_EMIF_DIV_MODE_MASK); - setbits_le32(&prcm->cm_mpu_mpu_clkctrl, + setbits_le32((*prcm)->cm_mpu_mpu_clkctrl, MPU_CLKCTRL_CLKSEL_ABE_DIV_MODE_MASK);
params = get_mpu_dpll_params();
- do_setup_dpll(&prcm->cm_clkmode_dpll_mpu, params, DPLL_LOCK, "mpu"); + do_setup_dpll((*prcm)->cm_clkmode_dpll_mpu, params, DPLL_LOCK, "mpu"); debug("MPU DPLL locked\n"); }
@@ -277,12 +277,12 @@ static void setup_usb_dpll(void) den = (params->n + 1) * 250 * 1000; num += den - 1; sd_div = num / den; - clrsetbits_le32(&prcm->cm_clksel_dpll_usb, + clrsetbits_le32((*prcm)->cm_clksel_dpll_usb, CM_CLKSEL_DPLL_DPLL_SD_DIV_MASK, sd_div << CM_CLKSEL_DPLL_DPLL_SD_DIV_SHIFT);
/* Now setup the dpll with the regular function */ - do_setup_dpll(&prcm->cm_clkmode_dpll_usb, params, DPLL_LOCK, "usb"); + do_setup_dpll((*prcm)->cm_clkmode_dpll_usb, params, DPLL_LOCK, "usb"); } #endif
@@ -301,21 +301,21 @@ static void setup_dplls(void) * using the FREQ_UPDATE method(freq_update_core()) */ if (emif_sdram_type() == EMIF_SDRAM_TYPE_LPDDR2) - do_setup_dpll(&prcm->cm_clkmode_dpll_core, params, + do_setup_dpll((*prcm)->cm_clkmode_dpll_core, params, DPLL_NO_LOCK, "core"); else - do_setup_dpll(&prcm->cm_clkmode_dpll_core, params, + do_setup_dpll((*prcm)->cm_clkmode_dpll_core, params, DPLL_LOCK, "core"); /* Set the ratios for CORE_CLK, L3_CLK, L4_CLK */ temp = (CLKSEL_CORE_X2_DIV_1 << CLKSEL_CORE_SHIFT) | (CLKSEL_L3_CORE_DIV_2 << CLKSEL_L3_SHIFT) | (CLKSEL_L4_L3_DIV_2 << CLKSEL_L4_SHIFT); - writel(temp, &prcm->cm_clksel_core); + writel(temp, (*prcm)->cm_clksel_core); debug("Core DPLL configured\n");
/* lock PER dpll */ params = get_per_dpll_params(); - do_setup_dpll(&prcm->cm_clkmode_dpll_per, + do_setup_dpll((*prcm)->cm_clkmode_dpll_per, params, DPLL_LOCK, "per"); debug("PER DPLL locked\n");
@@ -334,11 +334,11 @@ static void setup_non_essential_dplls(void) const struct dpll_params *params;
/* IVA */ - clrsetbits_le32(&prcm->cm_bypclk_dpll_iva, + clrsetbits_le32((*prcm)->cm_bypclk_dpll_iva, CM_BYPCLK_DPLL_IVA_CLKSEL_MASK, DPLL_IVA_CLKSEL_CORE_X2_DIV_2);
params = get_iva_dpll_params(); - do_setup_dpll(&prcm->cm_clkmode_dpll_iva, params, DPLL_LOCK, "iva"); + do_setup_dpll((*prcm)->cm_clkmode_dpll_iva, params, DPLL_LOCK, "iva");
/* Configure ABE dpll */ params = get_abe_dpll_params(); @@ -350,23 +350,23 @@ static void setup_non_essential_dplls(void) * We need to enable some additional options to achieve * 196.608MHz from 32768 Hz */ - setbits_le32(&prcm->cm_clkmode_dpll_abe, + setbits_le32((*prcm)->cm_clkmode_dpll_abe, CM_CLKMODE_DPLL_DRIFTGUARD_EN_MASK| CM_CLKMODE_DPLL_RELOCK_RAMP_EN_MASK| CM_CLKMODE_DPLL_LPMODE_EN_MASK| CM_CLKMODE_DPLL_REGM4XEN_MASK); /* Spend 4 REFCLK cycles at each stage */ - clrsetbits_le32(&prcm->cm_clkmode_dpll_abe, + clrsetbits_le32((*prcm)->cm_clkmode_dpll_abe, CM_CLKMODE_DPLL_RAMP_RATE_MASK, 1 << CM_CLKMODE_DPLL_RAMP_RATE_SHIFT); #endif
/* Select the right reference clk */ - clrsetbits_le32(&prcm->cm_abe_pll_ref_clksel, + clrsetbits_le32((*prcm)->cm_abe_pll_ref_clksel, CM_ABE_PLL_REF_CLKSEL_CLKSEL_MASK, abe_ref_clk << CM_ABE_PLL_REF_CLKSEL_CLKSEL_SHIFT); /* Lock the dpll */ - do_setup_dpll(&prcm->cm_clkmode_dpll_abe, params, DPLL_LOCK, "abe"); + do_setup_dpll((*prcm)->cm_clkmode_dpll_abe, params, DPLL_LOCK, "abe"); } #endif
@@ -417,14 +417,14 @@ void do_scale_vcore(u32 vcore_reg, u32 volt_mv) printf("Scaling voltage failed for 0x%x\n", vcore_reg); }
-static inline void enable_clock_domain(u32 *const clkctrl_reg, u32 enable_mode) +static inline void enable_clock_domain(u32 const clkctrl_reg, u32 enable_mode) { clrsetbits_le32(clkctrl_reg, CD_CLKCTRL_CLKTRCTRL_MASK, enable_mode << CD_CLKCTRL_CLKTRCTRL_SHIFT); - debug("Enable clock domain - %p\n", clkctrl_reg); + debug("Enable clock domain - %x\n", clkctrl_reg); }
-static inline void wait_for_clk_enable(u32 *clkctrl_addr) +static inline void wait_for_clk_enable(u32 clkctrl_addr) { u32 clkctrl, idlest = MODULE_CLKCTRL_IDLEST_DISABLED; u32 bound = LDELAY; @@ -436,19 +436,19 @@ static inline void wait_for_clk_enable(u32 *clkctrl_addr) idlest = (clkctrl & MODULE_CLKCTRL_IDLEST_MASK) >> MODULE_CLKCTRL_IDLEST_SHIFT; if (--bound == 0) { - printf("Clock enable failed for 0x%p idlest 0x%x\n", + printf("Clock enable failed for 0x%x idlest 0x%x\n", clkctrl_addr, clkctrl); return; } } }
-static inline void enable_clock_module(u32 *const clkctrl_addr, u32 enable_mode, +static inline void enable_clock_module(u32 const clkctrl_addr, u32 enable_mode, u32 wait_for_enable) { clrsetbits_le32(clkctrl_addr, MODULE_CLKCTRL_MODULEMODE_MASK, enable_mode << MODULE_CLKCTRL_MODULEMODE_SHIFT); - debug("Enable clock module - %p\n", clkctrl_addr); + debug("Enable clock module - %x\n", clkctrl_addr); if (wait_for_enable) wait_for_clk_enable(clkctrl_addr); } @@ -461,10 +461,10 @@ void freq_update_core(void)
core_dpll_params = get_core_dpll_params(); /* Put EMIF clock domain in sw wakeup mode */ - enable_clock_domain(&prcm->cm_memif_clkstctrl, + enable_clock_domain((*prcm)->cm_memif_clkstctrl, CD_CLKCTRL_CLKTRCTRL_SW_WKUP); - wait_for_clk_enable(&prcm->cm_memif_emif_1_clkctrl); - wait_for_clk_enable(&prcm->cm_memif_emif_2_clkctrl); + wait_for_clk_enable((*prcm)->cm_memif_emif_1_clkctrl); + wait_for_clk_enable((*prcm)->cm_memif_emif_2_clkctrl);
freq_config1 = SHADOW_FREQ_CONFIG1_FREQ_UPDATE_MASK | SHADOW_FREQ_CONFIG1_DLL_RESET_MASK; @@ -476,9 +476,9 @@ void freq_update_core(void) SHADOW_FREQ_CONFIG1_M2_DIV_SHIFT) & SHADOW_FREQ_CONFIG1_M2_DIV_MASK;
- writel(freq_config1, &prcm->cm_shadow_freq_config1); + writel(freq_config1, (*prcm)->cm_shadow_freq_config1); if (!wait_on_value(SHADOW_FREQ_CONFIG1_FREQ_UPDATE_MASK, 0, - &prcm->cm_shadow_freq_config1, LDELAY)) { + (u32 *) (*prcm)->cm_shadow_freq_config1, LDELAY)) { puts("FREQ UPDATE procedure failed!!"); hang(); } @@ -490,20 +490,20 @@ void freq_update_core(void) */ if (omap_rev != OMAP5430_ES1_0) { /* Put EMIF clock domain back in hw auto mode */ - enable_clock_domain(&prcm->cm_memif_clkstctrl, + enable_clock_domain((*prcm)->cm_memif_clkstctrl, CD_CLKCTRL_CLKTRCTRL_HW_AUTO); - wait_for_clk_enable(&prcm->cm_memif_emif_1_clkctrl); - wait_for_clk_enable(&prcm->cm_memif_emif_2_clkctrl); + wait_for_clk_enable((*prcm)->cm_memif_emif_1_clkctrl); + wait_for_clk_enable((*prcm)->cm_memif_emif_2_clkctrl); } }
-void bypass_dpll(u32 *const base) +void bypass_dpll(u32 const base) { do_bypass_dpll(base); wait_for_bypass(base); }
-void lock_dpll(u32 *const base) +void lock_dpll(u32 const base) { do_lock_dpll(base); wait_for_lock(base); @@ -512,39 +512,39 @@ void lock_dpll(u32 *const base) void setup_clocks_for_console(void) { /* Do not add any spl_debug prints in this function */ - clrsetbits_le32(&prcm->cm_l4per_clkstctrl, CD_CLKCTRL_CLKTRCTRL_MASK, + clrsetbits_le32((*prcm)->cm_l4per_clkstctrl, CD_CLKCTRL_CLKTRCTRL_MASK, CD_CLKCTRL_CLKTRCTRL_SW_WKUP << CD_CLKCTRL_CLKTRCTRL_SHIFT);
/* Enable all UARTs - console will be on one of them */ - clrsetbits_le32(&prcm->cm_l4per_uart1_clkctrl, + clrsetbits_le32((*prcm)->cm_l4per_uart1_clkctrl, MODULE_CLKCTRL_MODULEMODE_MASK, MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN << MODULE_CLKCTRL_MODULEMODE_SHIFT);
- clrsetbits_le32(&prcm->cm_l4per_uart2_clkctrl, + clrsetbits_le32((*prcm)->cm_l4per_uart2_clkctrl, MODULE_CLKCTRL_MODULEMODE_MASK, MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN << MODULE_CLKCTRL_MODULEMODE_SHIFT);
- clrsetbits_le32(&prcm->cm_l4per_uart3_clkctrl, + clrsetbits_le32((*prcm)->cm_l4per_uart3_clkctrl, MODULE_CLKCTRL_MODULEMODE_MASK, MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN << MODULE_CLKCTRL_MODULEMODE_SHIFT);
- clrsetbits_le32(&prcm->cm_l4per_clkstctrl, CD_CLKCTRL_CLKTRCTRL_MASK, + clrsetbits_le32((*prcm)->cm_l4per_clkstctrl, CD_CLKCTRL_CLKTRCTRL_MASK, CD_CLKCTRL_CLKTRCTRL_HW_AUTO << CD_CLKCTRL_CLKTRCTRL_SHIFT); }
-void do_enable_clocks(u32 *const *clk_domains, - u32 *const *clk_modules_hw_auto, - u32 *const *clk_modules_explicit_en, +void do_enable_clocks(u32 const *clk_domains, + u32 const *clk_modules_hw_auto, + u32 const *clk_modules_explicit_en, u8 wait_for_enable) { u32 i, max = 100; diff --git a/arch/arm/cpu/armv7/omap-common/emif-common.c b/arch/arm/cpu/armv7/omap-common/emif-common.c index 8864abc..bb37cf3 100644 --- a/arch/arm/cpu/armv7/omap-common/emif-common.c +++ b/arch/arm/cpu/armv7/omap-common/emif-common.c @@ -1289,9 +1289,9 @@ void sdram_init(void)
if (!(in_sdram || warm_reset())) { if (sdram_type == EMIF_SDRAM_TYPE_LPDDR2) - bypass_dpll(&prcm->cm_clkmode_dpll_core); + bypass_dpll((*prcm)->cm_clkmode_dpll_core); else - writel(CM_DLL_CTRL_NO_OVERRIDE, &prcm->cm_dll_ctrl); + writel(CM_DLL_CTRL_NO_OVERRIDE, (*prcm)->cm_dll_ctrl); }
if (!in_sdram) diff --git a/arch/arm/cpu/armv7/omap-common/hwinit-common.c b/arch/arm/cpu/armv7/omap-common/hwinit-common.c index 4eaf75b..4faf120 100644 --- a/arch/arm/cpu/armv7/omap-common/hwinit-common.c +++ b/arch/arm/cpu/armv7/omap-common/hwinit-common.c @@ -34,6 +34,7 @@ #include <asm/emif.h> #include <asm/cache.h> #include <asm/system.h> +#include <asm/omap_common.h>
#define ARMV7_DCACHE_WRITEBACK 0xe #define ARMV7_DOMAIN_CLIENT 1 @@ -122,6 +123,8 @@ void spl_display_print(void) void s_init(void) { init_omap_revision(); + hw_data_init(); + #ifdef CONFIG_SPL_BUILD if (warm_reset() && (omap_revision() <= OMAP5430_ES1_0)) force_emif_self_refresh(); diff --git a/arch/arm/cpu/armv7/omap-common/vc.c b/arch/arm/cpu/armv7/omap-common/vc.c index a045b77..e6e5f78 100644 --- a/arch/arm/cpu/armv7/omap-common/vc.c +++ b/arch/arm/cpu/armv7/omap-common/vc.c @@ -81,13 +81,13 @@ void omap_vc_init(u16 speed_khz) cycles_low -= 7; val = (cycles_hi << PRM_VC_CFG_I2C_CLK_SCLH_SHIFT) | (cycles_low << PRM_VC_CFG_I2C_CLK_SCLL_SHIFT); - writel(val, &prcm->prm_vc_cfg_i2c_clk); + writel(val, (*prcm)->prm_vc_cfg_i2c_clk);
val = CONFIG_OMAP_VC_I2C_HS_MCODE << PRM_VC_CFG_I2C_MODE_HSMCODE_SHIFT; /* No HS mode for now */ val &= ~PRM_VC_CFG_I2C_MODE_HSMODEEN_BIT; - writel(val, &prcm->prm_vc_cfg_i2c_mode); + writel(val, (*prcm)->prm_vc_cfg_i2c_mode); }
/** @@ -113,14 +113,15 @@ int omap_vc_bypass_send_value(u8 sa, u8 reg_addr, u8 reg_data) reg_val = sa << PRM_VC_VAL_BYPASS_SLAVEADDR_SHIFT | reg_addr << PRM_VC_VAL_BYPASS_REGADDR_SHIFT | reg_data << PRM_VC_VAL_BYPASS_DATA_SHIFT; - writel(reg_val, &prcm->prm_vc_val_bypass); + writel(reg_val, (*prcm)->prm_vc_val_bypass);
/* Signal VC to send data */ - writel(reg_val | PRM_VC_VAL_BYPASS_VALID_BIT, &prcm->prm_vc_val_bypass); + writel(reg_val | PRM_VC_VAL_BYPASS_VALID_BIT, + (*prcm)->prm_vc_val_bypass);
/* Wait on VC to complete transmission */ do { - reg_val = readl(&prcm->prm_vc_val_bypass) & + reg_val = readl((*prcm)->prm_vc_val_bypass) & PRM_VC_VAL_BYPASS_VALID_BIT; if (!reg_val) break; diff --git a/arch/arm/cpu/armv7/omap4/Makefile b/arch/arm/cpu/armv7/omap4/Makefile index 83160a2..0365148 100644 --- a/arch/arm/cpu/armv7/omap4/Makefile +++ b/arch/arm/cpu/armv7/omap4/Makefile @@ -29,6 +29,8 @@ COBJS += sdram_elpida.o COBJS += hwinit.o COBJS += clocks.o COBJS += emif.o +COBJS += prcm-regs.o +COBJS += hw_data.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) diff --git a/arch/arm/cpu/armv7/omap4/clocks.c b/arch/arm/cpu/armv7/omap4/clocks.c index 12c5803..9acceb0 100644 --- a/arch/arm/cpu/armv7/omap4/clocks.c +++ b/arch/arm/cpu/armv7/omap4/clocks.c @@ -46,8 +46,6 @@ #define puts(s) #endif /* !CONFIG_SPL_BUILD */
-struct omap4_prcm_regs *const prcm = (struct omap4_prcm_regs *)0x4A004100; - const u32 sys_clk_array[8] = { 12000000, /* 12 MHz */ 13000000, /* 13 MHz */ @@ -176,7 +174,7 @@ static const struct dpll_params usb_dpll_params_1920mhz[NUM_SYS_CLKS] = { {25, 0, 2, -1, -1, -1, -1, -1} /* 38.4 MHz */ };
-void setup_post_dividers(u32 *const base, const struct dpll_params *params) +void setup_post_dividers(u32 const base, const struct dpll_params *params) { struct dpll_regs *const dpll_regs = (struct dpll_regs *)base;
@@ -345,54 +343,54 @@ u32 get_offset_code(u32 offset) */ void enable_basic_clocks(void) { - u32 *const clk_domains_essential[] = { - &prcm->cm_l4per_clkstctrl, - &prcm->cm_l3init_clkstctrl, - &prcm->cm_memif_clkstctrl, - &prcm->cm_l4cfg_clkstctrl, + u32 const clk_domains_essential[] = { + (*prcm)->cm_l4per_clkstctrl, + (*prcm)->cm_l3init_clkstctrl, + (*prcm)->cm_memif_clkstctrl, + (*prcm)->cm_l4cfg_clkstctrl, 0 };
- u32 *const clk_modules_hw_auto_essential[] = { - &prcm->cm_l3_2_gpmc_clkctrl, - &prcm->cm_memif_emif_1_clkctrl, - &prcm->cm_memif_emif_2_clkctrl, - &prcm->cm_l4cfg_l4_cfg_clkctrl, - &prcm->cm_wkup_gpio1_clkctrl, - &prcm->cm_l4per_gpio2_clkctrl, - &prcm->cm_l4per_gpio3_clkctrl, - &prcm->cm_l4per_gpio4_clkctrl, - &prcm->cm_l4per_gpio5_clkctrl, - &prcm->cm_l4per_gpio6_clkctrl, + u32 const clk_modules_hw_auto_essential[] = { + (*prcm)->cm_l3_2_gpmc_clkctrl, + (*prcm)->cm_memif_emif_1_clkctrl, + (*prcm)->cm_memif_emif_2_clkctrl, + (*prcm)->cm_l4cfg_l4_cfg_clkctrl, + (*prcm)->cm_wkup_gpio1_clkctrl, + (*prcm)->cm_l4per_gpio2_clkctrl, + (*prcm)->cm_l4per_gpio3_clkctrl, + (*prcm)->cm_l4per_gpio4_clkctrl, + (*prcm)->cm_l4per_gpio5_clkctrl, + (*prcm)->cm_l4per_gpio6_clkctrl, 0 };
- u32 *const clk_modules_explicit_en_essential[] = { - &prcm->cm_wkup_gptimer1_clkctrl, - &prcm->cm_l3init_hsmmc1_clkctrl, - &prcm->cm_l3init_hsmmc2_clkctrl, - &prcm->cm_l4per_gptimer2_clkctrl, - &prcm->cm_wkup_wdtimer2_clkctrl, - &prcm->cm_l4per_uart3_clkctrl, + u32 const clk_modules_explicit_en_essential[] = { + (*prcm)->cm_wkup_gptimer1_clkctrl, + (*prcm)->cm_l3init_hsmmc1_clkctrl, + (*prcm)->cm_l3init_hsmmc2_clkctrl, + (*prcm)->cm_l4per_gptimer2_clkctrl, + (*prcm)->cm_wkup_wdtimer2_clkctrl, + (*prcm)->cm_l4per_uart3_clkctrl, 0 };
/* Enable optional additional functional clock for GPIO4 */ - setbits_le32(&prcm->cm_l4per_gpio4_clkctrl, + setbits_le32((*prcm)->cm_l4per_gpio4_clkctrl, GPIO4_CLKCTRL_OPTFCLKEN_MASK);
/* Enable 96 MHz clock for MMC1 & MMC2 */ - setbits_le32(&prcm->cm_l3init_hsmmc1_clkctrl, + setbits_le32((*prcm)->cm_l3init_hsmmc1_clkctrl, HSMMC_CLKCTRL_CLKSEL_MASK); - setbits_le32(&prcm->cm_l3init_hsmmc2_clkctrl, + setbits_le32((*prcm)->cm_l3init_hsmmc2_clkctrl, HSMMC_CLKCTRL_CLKSEL_MASK);
/* Select 32KHz clock as the source of GPTIMER1 */ - setbits_le32(&prcm->cm_wkup_gptimer1_clkctrl, + setbits_le32((*prcm)->cm_wkup_gptimer1_clkctrl, GPTIMER1_CLKCTRL_CLKSEL_MASK);
/* Enable optional 48M functional clock for USB PHY */ - setbits_le32(&prcm->cm_l3init_usbphy_clkctrl, + setbits_le32((*prcm)->cm_l3init_usbphy_clkctrl, USBPHY_CLKCTRL_OPTFCLKEN_PHY_48M_MASK);
do_enable_clocks(clk_domains_essential, @@ -403,26 +401,26 @@ void enable_basic_clocks(void)
void enable_basic_uboot_clocks(void) { - u32 *const clk_domains_essential[] = { + u32 const clk_domains_essential[] = { 0 };
- u32 *const clk_modules_hw_auto_essential[] = { - &prcm->cm_l3init_hsusbotg_clkctrl, - &prcm->cm_l3init_usbphy_clkctrl, - &prcm->cm_l3init_usbphy_clkctrl, - &prcm->cm_clksel_usb_60mhz, - &prcm->cm_l3init_hsusbtll_clkctrl, + u32 const clk_modules_hw_auto_essential[] = { + (*prcm)->cm_l3init_hsusbotg_clkctrl, + (*prcm)->cm_l3init_usbphy_clkctrl, + (*prcm)->cm_l3init_usbphy_clkctrl, + (*prcm)->cm_clksel_usb_60mhz, + (*prcm)->cm_l3init_hsusbtll_clkctrl, 0 };
- u32 *const clk_modules_explicit_en_essential[] = { - &prcm->cm_l4per_mcspi1_clkctrl, - &prcm->cm_l4per_i2c1_clkctrl, - &prcm->cm_l4per_i2c2_clkctrl, - &prcm->cm_l4per_i2c3_clkctrl, - &prcm->cm_l4per_i2c4_clkctrl, - &prcm->cm_l3init_hsusbhost_clkctrl, + u32 const clk_modules_explicit_en_essential[] = { + (*prcm)->cm_l4per_mcspi1_clkctrl, + (*prcm)->cm_l4per_i2c1_clkctrl, + (*prcm)->cm_l4per_i2c2_clkctrl, + (*prcm)->cm_l4per_i2c3_clkctrl, + (*prcm)->cm_l4per_i2c4_clkctrl, + (*prcm)->cm_l3init_hsusbhost_clkctrl, 0 };
@@ -438,72 +436,72 @@ void enable_basic_uboot_clocks(void) */ void enable_non_essential_clocks(void) { - u32 *const clk_domains_non_essential[] = { - &prcm->cm_mpu_m3_clkstctrl, - &prcm->cm_ivahd_clkstctrl, - &prcm->cm_dsp_clkstctrl, - &prcm->cm_dss_clkstctrl, - &prcm->cm_sgx_clkstctrl, - &prcm->cm1_abe_clkstctrl, - &prcm->cm_c2c_clkstctrl, - &prcm->cm_cam_clkstctrl, - &prcm->cm_dss_clkstctrl, - &prcm->cm_sdma_clkstctrl, + u32 const clk_domains_non_essential[] = { + (*prcm)->cm_mpu_m3_clkstctrl, + (*prcm)->cm_ivahd_clkstctrl, + (*prcm)->cm_dsp_clkstctrl, + (*prcm)->cm_dss_clkstctrl, + (*prcm)->cm_sgx_clkstctrl, + (*prcm)->cm1_abe_clkstctrl, + (*prcm)->cm_c2c_clkstctrl, + (*prcm)->cm_cam_clkstctrl, + (*prcm)->cm_dss_clkstctrl, + (*prcm)->cm_sdma_clkstctrl, 0 };
- u32 *const clk_modules_hw_auto_non_essential[] = { - &prcm->cm_l3instr_l3_3_clkctrl, - &prcm->cm_l3instr_l3_instr_clkctrl, - &prcm->cm_l3instr_intrconn_wp1_clkctrl, - &prcm->cm_l3init_hsi_clkctrl, + u32 const clk_modules_hw_auto_non_essential[] = { + (*prcm)->cm_l3instr_l3_3_clkctrl, + (*prcm)->cm_l3instr_l3_instr_clkctrl, + (*prcm)->cm_l3instr_intrconn_wp1_clkctrl, + (*prcm)->cm_l3init_hsi_clkctrl, 0 };
- u32 *const clk_modules_explicit_en_non_essential[] = { - &prcm->cm1_abe_aess_clkctrl, - &prcm->cm1_abe_pdm_clkctrl, - &prcm->cm1_abe_dmic_clkctrl, - &prcm->cm1_abe_mcasp_clkctrl, - &prcm->cm1_abe_mcbsp1_clkctrl, - &prcm->cm1_abe_mcbsp2_clkctrl, - &prcm->cm1_abe_mcbsp3_clkctrl, - &prcm->cm1_abe_slimbus_clkctrl, - &prcm->cm1_abe_timer5_clkctrl, - &prcm->cm1_abe_timer6_clkctrl, - &prcm->cm1_abe_timer7_clkctrl, - &prcm->cm1_abe_timer8_clkctrl, - &prcm->cm1_abe_wdt3_clkctrl, - &prcm->cm_l4per_gptimer9_clkctrl, - &prcm->cm_l4per_gptimer10_clkctrl, - &prcm->cm_l4per_gptimer11_clkctrl, - &prcm->cm_l4per_gptimer3_clkctrl, - &prcm->cm_l4per_gptimer4_clkctrl, - &prcm->cm_l4per_hdq1w_clkctrl, - &prcm->cm_l4per_mcbsp4_clkctrl, - &prcm->cm_l4per_mcspi2_clkctrl, - &prcm->cm_l4per_mcspi3_clkctrl, - &prcm->cm_l4per_mcspi4_clkctrl, - &prcm->cm_l4per_mmcsd3_clkctrl, - &prcm->cm_l4per_mmcsd4_clkctrl, - &prcm->cm_l4per_mmcsd5_clkctrl, - &prcm->cm_l4per_uart1_clkctrl, - &prcm->cm_l4per_uart2_clkctrl, - &prcm->cm_l4per_uart4_clkctrl, - &prcm->cm_wkup_keyboard_clkctrl, - &prcm->cm_wkup_wdtimer2_clkctrl, - &prcm->cm_cam_iss_clkctrl, - &prcm->cm_cam_fdif_clkctrl, - &prcm->cm_dss_dss_clkctrl, - &prcm->cm_sgx_sgx_clkctrl, + u32 const clk_modules_explicit_en_non_essential[] = { + (*prcm)->cm1_abe_aess_clkctrl, + (*prcm)->cm1_abe_pdm_clkctrl, + (*prcm)->cm1_abe_dmic_clkctrl, + (*prcm)->cm1_abe_mcasp_clkctrl, + (*prcm)->cm1_abe_mcbsp1_clkctrl, + (*prcm)->cm1_abe_mcbsp2_clkctrl, + (*prcm)->cm1_abe_mcbsp3_clkctrl, + (*prcm)->cm1_abe_slimbus_clkctrl, + (*prcm)->cm1_abe_timer5_clkctrl, + (*prcm)->cm1_abe_timer6_clkctrl, + (*prcm)->cm1_abe_timer7_clkctrl, + (*prcm)->cm1_abe_timer8_clkctrl, + (*prcm)->cm1_abe_wdt3_clkctrl, + (*prcm)->cm_l4per_gptimer9_clkctrl, + (*prcm)->cm_l4per_gptimer10_clkctrl, + (*prcm)->cm_l4per_gptimer11_clkctrl, + (*prcm)->cm_l4per_gptimer3_clkctrl, + (*prcm)->cm_l4per_gptimer4_clkctrl, + (*prcm)->cm_l4per_hdq1w_clkctrl, + (*prcm)->cm_l4per_mcbsp4_clkctrl, + (*prcm)->cm_l4per_mcspi2_clkctrl, + (*prcm)->cm_l4per_mcspi3_clkctrl, + (*prcm)->cm_l4per_mcspi4_clkctrl, + (*prcm)->cm_l4per_mmcsd3_clkctrl, + (*prcm)->cm_l4per_mmcsd4_clkctrl, + (*prcm)->cm_l4per_mmcsd5_clkctrl, + (*prcm)->cm_l4per_uart1_clkctrl, + (*prcm)->cm_l4per_uart2_clkctrl, + (*prcm)->cm_l4per_uart4_clkctrl, + (*prcm)->cm_wkup_keyboard_clkctrl, + (*prcm)->cm_wkup_wdtimer2_clkctrl, + (*prcm)->cm_cam_iss_clkctrl, + (*prcm)->cm_cam_fdif_clkctrl, + (*prcm)->cm_dss_dss_clkctrl, + (*prcm)->cm_sgx_sgx_clkctrl, 0 };
/* Enable optional functional clock for ISS */ - setbits_le32(&prcm->cm_cam_iss_clkctrl, ISS_CLKCTRL_OPTFCLKEN_MASK); + setbits_le32((*prcm)->cm_cam_iss_clkctrl, ISS_CLKCTRL_OPTFCLKEN_MASK);
/* Enable all optional functional clocks of DSS */ - setbits_le32(&prcm->cm_dss_dss_clkctrl, DSS_CLKCTRL_OPTFCLKEN_MASK); + setbits_le32((*prcm)->cm_dss_dss_clkctrl, DSS_CLKCTRL_OPTFCLKEN_MASK);
do_enable_clocks(clk_domains_non_essential, clk_modules_hw_auto_non_essential, @@ -511,7 +509,8 @@ void enable_non_essential_clocks(void) 0);
/* Put camera module in no sleep mode */ - clrsetbits_le32(&prcm->cm_cam_clkstctrl, MODULE_CLKCTRL_MODULEMODE_MASK, + clrsetbits_le32((*prcm)->cm_cam_clkstctrl, + MODULE_CLKCTRL_MODULEMODE_MASK, CD_CLKCTRL_CLKTRCTRL_NO_SLEEP << MODULE_CLKCTRL_MODULEMODE_SHIFT); } diff --git a/arch/arm/cpu/armv7/omap4/hw_data.c b/arch/arm/cpu/armv7/omap4/hw_data.c new file mode 100644 index 0000000..3174cc3 --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/hw_data.c @@ -0,0 +1,38 @@ +/* + * + * HW data initialization for OMAP4 + * + * (C) Copyright 2013 + * Texas Instruments, <www.ti.com> + * + * Sricharan R r.sricharan@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/arch/omap.h> +#include <asm/omap_common.h> + +struct prcm_regs const **prcm = + (struct prcm_regs const **) OMAP_SRAM_SCRATCH_PRCM_PTR; + +void hw_data_init(void) +{ + *prcm = &omap4_prcm; +} diff --git a/arch/arm/cpu/armv7/omap4/prcm-regs.c b/arch/arm/cpu/armv7/omap4/prcm-regs.c new file mode 100644 index 0000000..815b9d2 --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/prcm-regs.c @@ -0,0 +1,295 @@ +/* + * + * HW regs data for OMAP4 + * + * (C) Copyright 2013 + * Texas Instruments, <www.ti.com> + * + * Sricharan R r.sricharan@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm/omap_common.h> + +struct prcm_regs const omap4_prcm = { + /* cm1.ckgen */ + .cm_clksel_core = 0x4a004100, + .cm_clksel_abe = 0x4a004108, + .cm_dll_ctrl = 0x4a004110, + .cm_clkmode_dpll_core = 0x4a004120, + .cm_idlest_dpll_core = 0x4a004124, + .cm_autoidle_dpll_core = 0x4a004128, + .cm_clksel_dpll_core = 0x4a00412c, + .cm_div_m2_dpll_core = 0x4a004130, + .cm_div_m3_dpll_core = 0x4a004134, + .cm_div_m4_dpll_core = 0x4a004138, + .cm_div_m5_dpll_core = 0x4a00413c, + .cm_div_m6_dpll_core = 0x4a004140, + .cm_div_m7_dpll_core = 0x4a004144, + .cm_ssc_deltamstep_dpll_core = 0x4a004148, + .cm_ssc_modfreqdiv_dpll_core = 0x4a00414c, + .cm_emu_override_dpll_core = 0x4a004150, + .cm_clkmode_dpll_mpu = 0x4a004160, + .cm_idlest_dpll_mpu = 0x4a004164, + .cm_autoidle_dpll_mpu = 0x4a004168, + .cm_clksel_dpll_mpu = 0x4a00416c, + .cm_div_m2_dpll_mpu = 0x4a004170, + .cm_ssc_deltamstep_dpll_mpu = 0x4a004188, + .cm_ssc_modfreqdiv_dpll_mpu = 0x4a00418c, + .cm_bypclk_dpll_mpu = 0x4a00419c, + .cm_clkmode_dpll_iva = 0x4a0041a0, + .cm_idlest_dpll_iva = 0x4a0041a4, + .cm_autoidle_dpll_iva = 0x4a0041a8, + .cm_clksel_dpll_iva = 0x4a0041ac, + .cm_div_m4_dpll_iva = 0x4a0041b8, + .cm_div_m5_dpll_iva = 0x4a0041bc, + .cm_ssc_deltamstep_dpll_iva = 0x4a0041c8, + .cm_ssc_modfreqdiv_dpll_iva = 0x4a0041cc, + .cm_bypclk_dpll_iva = 0x4a0041dc, + .cm_clkmode_dpll_abe = 0x4a0041e0, + .cm_idlest_dpll_abe = 0x4a0041e4, + .cm_autoidle_dpll_abe = 0x4a0041e8, + .cm_clksel_dpll_abe = 0x4a0041ec, + .cm_div_m2_dpll_abe = 0x4a0041f0, + .cm_div_m3_dpll_abe = 0x4a0041f4, + .cm_ssc_deltamstep_dpll_abe = 0x4a004208, + .cm_ssc_modfreqdiv_dpll_abe = 0x4a00420c, + .cm_clkmode_dpll_ddrphy = 0x4a004220, + .cm_idlest_dpll_ddrphy = 0x4a004224, + .cm_autoidle_dpll_ddrphy = 0x4a004228, + .cm_clksel_dpll_ddrphy = 0x4a00422c, + .cm_div_m2_dpll_ddrphy = 0x4a004230, + .cm_div_m4_dpll_ddrphy = 0x4a004238, + .cm_div_m5_dpll_ddrphy = 0x4a00423c, + .cm_div_m6_dpll_ddrphy = 0x4a004240, + .cm_ssc_deltamstep_dpll_ddrphy = 0x4a004248, + .cm_shadow_freq_config1 = 0x4a004260, + .cm_mpu_mpu_clkctrl = 0x4a004320, + + /* cm1.dsp */ + .cm_dsp_clkstctrl = 0x4a004400, + .cm_dsp_dsp_clkctrl = 0x4a004420, + + /* cm1.abe */ + .cm1_abe_clkstctrl = 0x4a004500, + .cm1_abe_l4abe_clkctrl = 0x4a004520, + .cm1_abe_aess_clkctrl = 0x4a004528, + .cm1_abe_pdm_clkctrl = 0x4a004530, + .cm1_abe_dmic_clkctrl = 0x4a004538, + .cm1_abe_mcasp_clkctrl = 0x4a004540, + .cm1_abe_mcbsp1_clkctrl = 0x4a004548, + .cm1_abe_mcbsp2_clkctrl = 0x4a004550, + .cm1_abe_mcbsp3_clkctrl = 0x4a004558, + .cm1_abe_slimbus_clkctrl = 0x4a004560, + .cm1_abe_timer5_clkctrl = 0x4a004568, + .cm1_abe_timer6_clkctrl = 0x4a004570, + .cm1_abe_timer7_clkctrl = 0x4a004578, + .cm1_abe_timer8_clkctrl = 0x4a004580, + .cm1_abe_wdt3_clkctrl = 0x4a004588, + + /* cm2.ckgen */ + .cm_clksel_mpu_m3_iss_root = 0x4a008100, + .cm_clksel_usb_60mhz = 0x4a008104, + .cm_scale_fclk = 0x4a008108, + .cm_core_dvfs_perf1 = 0x4a008110, + .cm_core_dvfs_perf2 = 0x4a008114, + .cm_core_dvfs_perf3 = 0x4a008118, + .cm_core_dvfs_perf4 = 0x4a00811c, + .cm_core_dvfs_current = 0x4a008124, + .cm_iva_dvfs_perf_tesla = 0x4a008128, + .cm_iva_dvfs_perf_ivahd = 0x4a00812c, + .cm_iva_dvfs_perf_abe = 0x4a008130, + .cm_iva_dvfs_current = 0x4a008138, + .cm_clkmode_dpll_per = 0x4a008140, + .cm_idlest_dpll_per = 0x4a008144, + .cm_autoidle_dpll_per = 0x4a008148, + .cm_clksel_dpll_per = 0x4a00814c, + .cm_div_m2_dpll_per = 0x4a008150, + .cm_div_m3_dpll_per = 0x4a008154, + .cm_div_m4_dpll_per = 0x4a008158, + .cm_div_m5_dpll_per = 0x4a00815c, + .cm_div_m6_dpll_per = 0x4a008160, + .cm_div_m7_dpll_per = 0x4a008164, + .cm_ssc_deltamstep_dpll_per = 0x4a008168, + .cm_ssc_modfreqdiv_dpll_per = 0x4a00816c, + .cm_emu_override_dpll_per = 0x4a008170, + .cm_clkmode_dpll_usb = 0x4a008180, + .cm_idlest_dpll_usb = 0x4a008184, + .cm_autoidle_dpll_usb = 0x4a008188, + .cm_clksel_dpll_usb = 0x4a00818c, + .cm_div_m2_dpll_usb = 0x4a008190, + .cm_ssc_deltamstep_dpll_usb = 0x4a0081a8, + .cm_ssc_modfreqdiv_dpll_usb = 0x4a0081ac, + .cm_clkdcoldo_dpll_usb = 0x4a0081b4, + .cm_clkmode_dpll_unipro = 0x4a0081c0, + .cm_idlest_dpll_unipro = 0x4a0081c4, + .cm_autoidle_dpll_unipro = 0x4a0081c8, + .cm_clksel_dpll_unipro = 0x4a0081cc, + .cm_div_m2_dpll_unipro = 0x4a0081d0, + .cm_ssc_deltamstep_dpll_unipro = 0x4a0081e8, + .cm_ssc_modfreqdiv_dpll_unipro = 0x4a0081ec, + + /* cm2.core */ + .cm_l3_1_clkstctrl = 0x4a008700, + .cm_l3_1_dynamicdep = 0x4a008708, + .cm_l3_1_l3_1_clkctrl = 0x4a008720, + .cm_l3_2_clkstctrl = 0x4a008800, + .cm_l3_2_dynamicdep = 0x4a008808, + .cm_l3_2_l3_2_clkctrl = 0x4a008820, + .cm_l3_2_gpmc_clkctrl = 0x4a008828, + .cm_l3_2_ocmc_ram_clkctrl = 0x4a008830, + .cm_mpu_m3_clkstctrl = 0x4a008900, + .cm_mpu_m3_staticdep = 0x4a008904, + .cm_mpu_m3_dynamicdep = 0x4a008908, + .cm_mpu_m3_mpu_m3_clkctrl = 0x4a008920, + .cm_sdma_clkstctrl = 0x4a008a00, + .cm_sdma_staticdep = 0x4a008a04, + .cm_sdma_dynamicdep = 0x4a008a08, + .cm_sdma_sdma_clkctrl = 0x4a008a20, + .cm_memif_clkstctrl = 0x4a008b00, + .cm_memif_dmm_clkctrl = 0x4a008b20, + .cm_memif_emif_fw_clkctrl = 0x4a008b28, + .cm_memif_emif_1_clkctrl = 0x4a008b30, + .cm_memif_emif_2_clkctrl = 0x4a008b38, + .cm_memif_dll_clkctrl = 0x4a008b40, + .cm_memif_emif_h1_clkctrl = 0x4a008b50, + .cm_memif_emif_h2_clkctrl = 0x4a008b58, + .cm_memif_dll_h_clkctrl = 0x4a008b60, + .cm_c2c_clkstctrl = 0x4a008c00, + .cm_c2c_staticdep = 0x4a008c04, + .cm_c2c_dynamicdep = 0x4a008c08, + .cm_c2c_sad2d_clkctrl = 0x4a008c20, + .cm_c2c_modem_icr_clkctrl = 0x4a008c28, + .cm_c2c_sad2d_fw_clkctrl = 0x4a008c30, + .cm_l4cfg_clkstctrl = 0x4a008d00, + .cm_l4cfg_dynamicdep = 0x4a008d08, + .cm_l4cfg_l4_cfg_clkctrl = 0x4a008d20, + .cm_l4cfg_hw_sem_clkctrl = 0x4a008d28, + .cm_l4cfg_mailbox_clkctrl = 0x4a008d30, + .cm_l4cfg_sar_rom_clkctrl = 0x4a008d38, + .cm_l3instr_clkstctrl = 0x4a008e00, + .cm_l3instr_l3_3_clkctrl = 0x4a008e20, + .cm_l3instr_l3_instr_clkctrl = 0x4a008e28, + .cm_l3instr_intrconn_wp1_clkct = 0x4a008e40, + .cm_ivahd_clkstctrl = 0x4a008f00, + + /* cm2.ivahd */ + .cm_ivahd_ivahd_clkctrl = 0x4a008f20, + .cm_ivahd_sl2_clkctrl = 0x4a008f28, + + /* cm2.cam */ + .cm_cam_clkstctrl = 0x4a009000, + .cm_cam_iss_clkctrl = 0x4a009020, + .cm_cam_fdif_clkctrl = 0x4a009028, + + /* cm2.dss */ + .cm_dss_clkstctrl = 0x4a009100, + .cm_dss_dss_clkctrl = 0x4a009120, + + /* cm2.sgx */ + .cm_sgx_clkstctrl = 0x4a009200, + .cm_sgx_sgx_clkctrl = 0x4a009220, + + /* cm2.l3init */ + .cm_l3init_clkstctrl = 0x4a009300, + .cm_l3init_hsmmc1_clkctrl = 0x4a009328, + .cm_l3init_hsmmc2_clkctrl = 0x4a009330, + .cm_l3init_hsi_clkctrl = 0x4a009338, + .cm_l3init_hsusbhost_clkctrl = 0x4a009358, + .cm_l3init_hsusbotg_clkctrl = 0x4a009360, + .cm_l3init_hsusbtll_clkctrl = 0x4a009368, + .cm_l3init_p1500_clkctrl = 0x4a009378, + .cm_l3init_fsusb_clkctrl = 0x4a0093d0, + .cm_l3init_usbphy_clkctrl = 0x4a0093e0, + + /* cm2.l4per */ + .cm_l4per_clkstctrl = 0x4a009400, + .cm_l4per_dynamicdep = 0x4a009408, + .cm_l4per_adc_clkctrl = 0x4a009420, + .cm_l4per_gptimer10_clkctrl = 0x4a009428, + .cm_l4per_gptimer11_clkctrl = 0x4a009430, + .cm_l4per_gptimer2_clkctrl = 0x4a009438, + .cm_l4per_gptimer3_clkctrl = 0x4a009440, + .cm_l4per_gptimer4_clkctrl = 0x4a009448, + .cm_l4per_gptimer9_clkctrl = 0x4a009450, + .cm_l4per_elm_clkctrl = 0x4a009458, + .cm_l4per_gpio2_clkctrl = 0x4a009460, + .cm_l4per_gpio3_clkctrl = 0x4a009468, + .cm_l4per_gpio4_clkctrl = 0x4a009470, + .cm_l4per_gpio5_clkctrl = 0x4a009478, + .cm_l4per_gpio6_clkctrl = 0x4a009480, + .cm_l4per_hdq1w_clkctrl = 0x4a009488, + .cm_l4per_hecc1_clkctrl = 0x4a009490, + .cm_l4per_hecc2_clkctrl = 0x4a009498, + .cm_l4per_i2c1_clkctrl = 0x4a0094a0, + .cm_l4per_i2c2_clkctrl = 0x4a0094a8, + .cm_l4per_i2c3_clkctrl = 0x4a0094b0, + .cm_l4per_i2c4_clkctrl = 0x4a0094b8, + .cm_l4per_l4per_clkctrl = 0x4a0094c0, + .cm_l4per_mcasp2_clkctrl = 0x4a0094d0, + .cm_l4per_mcasp3_clkctrl = 0x4a0094d8, + .cm_l4per_mcbsp4_clkctrl = 0x4a0094e0, + .cm_l4per_mgate_clkctrl = 0x4a0094e8, + .cm_l4per_mcspi1_clkctrl = 0x4a0094f0, + .cm_l4per_mcspi2_clkctrl = 0x4a0094f8, + .cm_l4per_mcspi3_clkctrl = 0x4a009500, + .cm_l4per_mcspi4_clkctrl = 0x4a009508, + .cm_l4per_mmcsd3_clkctrl = 0x4a009520, + .cm_l4per_mmcsd4_clkctrl = 0x4a009528, + .cm_l4per_msprohg_clkctrl = 0x4a009530, + .cm_l4per_slimbus2_clkctrl = 0x4a009538, + .cm_l4per_uart1_clkctrl = 0x4a009540, + .cm_l4per_uart2_clkctrl = 0x4a009548, + .cm_l4per_uart3_clkctrl = 0x4a009550, + .cm_l4per_uart4_clkctrl = 0x4a009558, + .cm_l4per_mmcsd5_clkctrl = 0x4a009560, + .cm_l4per_i2c5_clkctrl = 0x4a009568, + .cm_l4sec_clkstctrl = 0x4a009580, + .cm_l4sec_staticdep = 0x4a009584, + .cm_l4sec_dynamicdep = 0x4a009588, + .cm_l4sec_aes1_clkctrl = 0x4a0095a0, + .cm_l4sec_aes2_clkctrl = 0x4a0095a8, + .cm_l4sec_des3des_clkctrl = 0x4a0095b0, + .cm_l4sec_pkaeip29_clkctrl = 0x4a0095b8, + .cm_l4sec_rng_clkctrl = 0x4a0095c0, + .cm_l4sec_sha2md51_clkctrl = 0x4a0095c8, + .cm_l4sec_cryptodma_clkctrl = 0x4a0095d8, + + /* l4 wkup regs */ + .cm_abe_pll_ref_clksel = 0x4a30610c, + .cm_sys_clksel = 0x4a306110, + .cm_wkup_clkstctrl = 0x4a307800, + .cm_wkup_l4wkup_clkctrl = 0x4a307820, + .cm_wkup_wdtimer1_clkctrl = 0x4a307828, + .cm_wkup_wdtimer2_clkctrl = 0x4a307830, + .cm_wkup_gpio1_clkctrl = 0x4a307838, + .cm_wkup_gptimer1_clkctrl = 0x4a307840, + .cm_wkup_gptimer12_clkctrl = 0x4a307848, + .cm_wkup_synctimer_clkctrl = 0x4a307850, + .cm_wkup_usim_clkctrl = 0x4a307858, + .cm_wkup_sarram_clkctrl = 0x4a307860, + .cm_wkup_keyboard_clkctrl = 0x4a307878, + .cm_wkup_rtc_clkctrl = 0x4a307880, + .cm_wkup_bandgap_clkctrl = 0x4a307888, + .prm_vc_val_bypass = 0x4a307ba0, + .prm_vc_cfg_channel = 0x4a307ba4, + .prm_vc_cfg_i2c_mode = 0x4a307ba8, + .prm_vc_cfg_i2c_clk = 0x4a307bac, +}; diff --git a/arch/arm/cpu/armv7/omap5/Makefile b/arch/arm/cpu/armv7/omap5/Makefile index 9b261c4..81625f6 100644 --- a/arch/arm/cpu/armv7/omap5/Makefile +++ b/arch/arm/cpu/armv7/omap5/Makefile @@ -29,6 +29,8 @@ COBJS += hwinit.o COBJS += clocks.o COBJS += emif.o COBJS += sdram.o +COBJS += prcm-regs.o +COBJS += hw_data.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) diff --git a/arch/arm/cpu/armv7/omap5/clocks.c b/arch/arm/cpu/armv7/omap5/clocks.c index 1f33692..a90f922 100644 --- a/arch/arm/cpu/armv7/omap5/clocks.c +++ b/arch/arm/cpu/armv7/omap5/clocks.c @@ -47,8 +47,6 @@ #define puts(s) #endif
-struct omap5_prcm_regs *const prcm = (struct omap5_prcm_regs *)0x4A004100; - const u32 sys_clk_array[8] = { 12000000, /* 12 MHz */ 0, /* NA */ @@ -188,7 +186,7 @@ static const struct dpll_params usb_dpll_params_1920mhz[NUM_SYS_CLKS] = { {400, 15, 2, -1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ };
@@ -282,9 +280,9 @@ void scale_vcores(void)
if (emif_sdram_type() == EMIF_SDRAM_TYPE_DDR3) { /* Configure LDO SRAM "magic" bits */ - writel(2, &prcm->prm_sldo_core_setup); - writel(2, &prcm->prm_sldo_mpu_setup); - writel(2, &prcm->prm_sldo_mm_setup); + writel(2, (*prcm)->prm_sldo_core_setup); + writel(2, (*prcm)->prm_sldo_mpu_setup); + writel(2, (*prcm)->prm_sldo_mm_setup); } }
@@ -309,57 +307,57 @@ u32 get_offset_code(u32 volt_offset) */ void enable_basic_clocks(void) { - u32 *const clk_domains_essential[] = { - &prcm->cm_l4per_clkstctrl, - &prcm->cm_l3init_clkstctrl, - &prcm->cm_memif_clkstctrl, - &prcm->cm_l4cfg_clkstctrl, + u32 const clk_domains_essential[] = { + (*prcm)->cm_l4per_clkstctrl, + (*prcm)->cm_l3init_clkstctrl, + (*prcm)->cm_memif_clkstctrl, + (*prcm)->cm_l4cfg_clkstctrl, 0 };
- u32 *const clk_modules_explicit_en_essential[] = { - &prcm->cm_wkup_gptimer1_clkctrl, - &prcm->cm_l3init_hsmmc1_clkctrl, - &prcm->cm_l3init_hsmmc2_clkctrl, - &prcm->cm_l4per_gptimer2_clkctrl, - &prcm->cm_wkup_wdtimer2_clkctrl, - &prcm->cm_l4per_uart3_clkctrl, - &prcm->cm_l4per_i2c1_clkctrl, + u32 const clk_modules_explicit_en_essential[] = { + (*prcm)->cm_wkup_gptimer1_clkctrl, + (*prcm)->cm_l3init_hsmmc1_clkctrl, + (*prcm)->cm_l3init_hsmmc2_clkctrl, + (*prcm)->cm_l4per_gptimer2_clkctrl, + (*prcm)->cm_wkup_wdtimer2_clkctrl, + (*prcm)->cm_l4per_uart3_clkctrl, + (*prcm)->cm_l4per_i2c1_clkctrl, 0 };
/* Set the correct clock dividers for mmc */ - setbits_le32(&prcm->cm_l3init_hsmmc1_clkctrl, + setbits_le32((*prcm)->cm_l3init_hsmmc1_clkctrl, HSMMC_CLKCTRL_CLKSEL_DIV_MASK); - setbits_le32(&prcm->cm_l3init_hsmmc2_clkctrl, + setbits_le32((*prcm)->cm_l3init_hsmmc2_clkctrl, HSMMC_CLKCTRL_CLKSEL_DIV_MASK);
do_enable_clocks(clk_domains_essential, @@ -368,36 +366,36 @@ void enable_basic_clocks(void) 1);
/* Select 384Mhz for GPU as its the POR for ES1.0 */ - setbits_le32(&prcm->cm_sgx_sgx_clkctrl, + setbits_le32((*prcm)->cm_sgx_sgx_clkctrl, CLKSEL_GPU_HYD_GCLK_MASK); - setbits_le32(&prcm->cm_sgx_sgx_clkctrl, + setbits_le32((*prcm)->cm_sgx_sgx_clkctrl, CLKSEL_GPU_CORE_GCLK_MASK);
/* Enable SCRM OPT clocks for PER and CORE dpll */ - setbits_le32(&prcm->cm_wkupaon_scrm_clkctrl, + setbits_le32((*prcm)->cm_wkupaon_scrm_clkctrl, OPTFCLKEN_SCRM_PER_MASK); - setbits_le32(&prcm->cm_wkupaon_scrm_clkctrl, + setbits_le32((*prcm)->cm_wkupaon_scrm_clkctrl, OPTFCLKEN_SCRM_CORE_MASK); }
- u32 *const clk_modules_hw_auto_essential[] = { + u32 const clk_modules_hw_auto_essential[] = { 0 };
- u32 *const clk_modules_explicit_en_essential[] = { - &prcm->cm_l4per_mcspi1_clkctrl, - &prcm->cm_l4per_i2c2_clkctrl, - &prcm->cm_l4per_i2c3_clkctrl, - &prcm->cm_l4per_i2c4_clkctrl, - &prcm->cm_l3init_hsusbtll_clkctrl, - &prcm->cm_l3init_hsusbhost_clkctrl, - &prcm->cm_l3init_fsusb_clkctrl, + u32 const clk_modules_explicit_en_essential[] = { + (*prcm)->cm_l4per_mcspi1_clkctrl, + (*prcm)->cm_l4per_i2c2_clkctrl, + (*prcm)->cm_l4per_i2c3_clkctrl, + (*prcm)->cm_l4per_i2c4_clkctrl, + (*prcm)->cm_l3init_hsusbtll_clkctrl, + (*prcm)->cm_l3init_hsusbhost_clkctrl, + (*prcm)->cm_l3init_fsusb_clkctrl, 0 };
@@ -413,75 +411,75 @@ void enable_basic_uboot_clocks(void) */ void enable_non_essential_clocks(void) { - u32 *const clk_domains_non_essential[] = { - &prcm->cm_mpu_m3_clkstctrl, - &prcm->cm_ivahd_clkstctrl, - &prcm->cm_dsp_clkstctrl, - &prcm->cm_dss_clkstctrl, - &prcm->cm_sgx_clkstctrl, - &prcm->cm1_abe_clkstctrl, - &prcm->cm_c2c_clkstctrl, - &prcm->cm_cam_clkstctrl, - &prcm->cm_dss_clkstctrl, - &prcm->cm_sdma_clkstctrl, + u32 const clk_domains_non_essential[] = { + (*prcm)->cm_mpu_m3_clkstctrl, + (*prcm)->cm_ivahd_clkstctrl, + (*prcm)->cm_dsp_clkstctrl, + (*prcm)->cm_dss_clkstctrl, + (*prcm)->cm_sgx_clkstctrl, + (*prcm)->cm1_abe_clkstctrl, + (*prcm)->cm_c2c_clkstctrl, + (*prcm)->cm_cam_clkstctrl, + (*prcm)->cm_dss_clkstctrl, + (*prcm)->cm_sdma_clkstctrl, 0 };
- u32 *const clk_modules_hw_auto_non_essential[] = { - &prcm->cm_mpu_m3_mpu_m3_clkctrl, - &prcm->cm_ivahd_ivahd_clkctrl, - &prcm->cm_ivahd_sl2_clkctrl, - &prcm->cm_dsp_dsp_clkctrl, - &prcm->cm_l3instr_l3_3_clkctrl, - &prcm->cm_l3instr_l3_instr_clkctrl, - &prcm->cm_l3instr_intrconn_wp1_clkctrl, - &prcm->cm_l3init_hsi_clkctrl, - &prcm->cm_l4per_hdq1w_clkctrl, + u32 const clk_modules_hw_auto_non_essential[] = { + (*prcm)->cm_mpu_m3_mpu_m3_clkctrl, + (*prcm)->cm_ivahd_ivahd_clkctrl, + (*prcm)->cm_ivahd_sl2_clkctrl, + (*prcm)->cm_dsp_dsp_clkctrl, + (*prcm)->cm_l3instr_l3_3_clkctrl, + (*prcm)->cm_l3instr_l3_instr_clkctrl, + (*prcm)->cm_l3instr_intrconn_wp1_clkctrl, + (*prcm)->cm_l3init_hsi_clkctrl, + (*prcm)->cm_l4per_hdq1w_clkctrl, 0 };
- u32 *const clk_modules_explicit_en_non_essential[] = { - &prcm->cm1_abe_aess_clkctrl, - &prcm->cm1_abe_pdm_clkctrl, - &prcm->cm1_abe_dmic_clkctrl, - &prcm->cm1_abe_mcasp_clkctrl, - &prcm->cm1_abe_mcbsp1_clkctrl, - &prcm->cm1_abe_mcbsp2_clkctrl, - &prcm->cm1_abe_mcbsp3_clkctrl, - &prcm->cm1_abe_slimbus_clkctrl, - &prcm->cm1_abe_timer5_clkctrl, - &prcm->cm1_abe_timer6_clkctrl, - &prcm->cm1_abe_timer7_clkctrl, - &prcm->cm1_abe_timer8_clkctrl, - &prcm->cm1_abe_wdt3_clkctrl, - &prcm->cm_l4per_gptimer9_clkctrl, - &prcm->cm_l4per_gptimer10_clkctrl, - &prcm->cm_l4per_gptimer11_clkctrl, - &prcm->cm_l4per_gptimer3_clkctrl, - &prcm->cm_l4per_gptimer4_clkctrl, - &prcm->cm_l4per_mcspi2_clkctrl, - &prcm->cm_l4per_mcspi3_clkctrl, - &prcm->cm_l4per_mcspi4_clkctrl, - &prcm->cm_l4per_mmcsd3_clkctrl, - &prcm->cm_l4per_mmcsd4_clkctrl, - &prcm->cm_l4per_mmcsd5_clkctrl, - &prcm->cm_l4per_uart1_clkctrl, - &prcm->cm_l4per_uart2_clkctrl, - &prcm->cm_l4per_uart4_clkctrl, - &prcm->cm_wkup_keyboard_clkctrl, - &prcm->cm_wkup_wdtimer2_clkctrl, - &prcm->cm_cam_iss_clkctrl, - &prcm->cm_cam_fdif_clkctrl, - &prcm->cm_dss_dss_clkctrl, - &prcm->cm_sgx_sgx_clkctrl, + u32 const clk_modules_explicit_en_non_essential[] = { + (*prcm)->cm1_abe_aess_clkctrl, + (*prcm)->cm1_abe_pdm_clkctrl, + (*prcm)->cm1_abe_dmic_clkctrl, + (*prcm)->cm1_abe_mcasp_clkctrl, + (*prcm)->cm1_abe_mcbsp1_clkctrl, + (*prcm)->cm1_abe_mcbsp2_clkctrl, + (*prcm)->cm1_abe_mcbsp3_clkctrl, + (*prcm)->cm1_abe_slimbus_clkctrl, + (*prcm)->cm1_abe_timer5_clkctrl, + (*prcm)->cm1_abe_timer6_clkctrl, + (*prcm)->cm1_abe_timer7_clkctrl, + (*prcm)->cm1_abe_timer8_clkctrl, + (*prcm)->cm1_abe_wdt3_clkctrl, + (*prcm)->cm_l4per_gptimer9_clkctrl, + (*prcm)->cm_l4per_gptimer10_clkctrl, + (*prcm)->cm_l4per_gptimer11_clkctrl, + (*prcm)->cm_l4per_gptimer3_clkctrl, + (*prcm)->cm_l4per_gptimer4_clkctrl, + (*prcm)->cm_l4per_mcspi2_clkctrl, + (*prcm)->cm_l4per_mcspi3_clkctrl, + (*prcm)->cm_l4per_mcspi4_clkctrl, + (*prcm)->cm_l4per_mmcsd3_clkctrl, + (*prcm)->cm_l4per_mmcsd4_clkctrl, + (*prcm)->cm_l4per_mmcsd5_clkctrl, + (*prcm)->cm_l4per_uart1_clkctrl, + (*prcm)->cm_l4per_uart2_clkctrl, + (*prcm)->cm_l4per_uart4_clkctrl, + (*prcm)->cm_wkup_keyboard_clkctrl, + (*prcm)->cm_wkup_wdtimer2_clkctrl, + (*prcm)->cm_cam_iss_clkctrl, + (*prcm)->cm_cam_fdif_clkctrl, + (*prcm)->cm_dss_dss_clkctrl, + (*prcm)->cm_sgx_sgx_clkctrl, 0 };
do_enable_clocks(clk_domains_non_essential, clk_modules_hw_auto_non_essential, @@ -489,7 +487,8 @@ void enable_non_essential_clocks(void) 0);
/* Put camera module in no sleep mode */ - clrsetbits_le32(&prcm->cm_cam_clkstctrl, MODULE_CLKCTRL_MODULEMODE_MASK, + clrsetbits_le32((*prcm)->cm_cam_clkstctrl, + MODULE_CLKCTRL_MODULEMODE_MASK, CD_CLKCTRL_CLKTRCTRL_NO_SLEEP << MODULE_CLKCTRL_MODULEMODE_SHIFT); } diff --git a/arch/arm/cpu/armv7/omap5/hw_data.c b/arch/arm/cpu/armv7/omap5/hw_data.c new file mode 100644 index 0000000..0f1234c --- /dev/null +++ b/arch/arm/cpu/armv7/omap5/hw_data.c @@ -0,0 +1,38 @@ +/* + * + * HW data initialization for OMAP5 + * + * (C) Copyright 2013 + * Texas Instruments, <www.ti.com> + * + * Sricharan R r.sricharan@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/arch/omap.h> +#include <asm/omap_common.h> + +struct prcm_regs const **prcm = + (struct prcm_regs const **) OMAP_SRAM_SCRATCH_PRCM_PTR; + +void hw_data_init(void) +{ + *prcm = &omap5_es1_prcm; +} diff --git a/arch/arm/cpu/armv7/omap5/prcm-regs.c b/arch/arm/cpu/armv7/omap5/prcm-regs.c new file mode 100644 index 0000000..cdc4864 --- /dev/null +++ b/arch/arm/cpu/armv7/omap5/prcm-regs.c @@ -0,0 +1,306 @@ +/* + * + * HW regs data for OMAP5 Soc + * + * (C) Copyright 2013 + * Texas Instruments, <www.ti.com> + * + * Sricharan R r.sricharan@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm/omap_common.h> + +struct prcm_regs const omap5_es1_prcm = { + /* cm1.ckgen */ + .cm_clksel_core = 0x4a004100, + .cm_clksel_abe = 0x4a004108, + .cm_dll_ctrl = 0x4a004110, + .cm_clkmode_dpll_core = 0x4a004120, + .cm_idlest_dpll_core = 0x4a004124, + .cm_autoidle_dpll_core = 0x4a004128, + .cm_clksel_dpll_core = 0x4a00412c, + .cm_div_m2_dpll_core = 0x4a004130, + .cm_div_m3_dpll_core = 0x4a004134, + .cm_div_h11_dpll_core = 0x4a004138, + .cm_div_h12_dpll_core = 0x4a00413c, + .cm_div_h13_dpll_core = 0x4a004140, + .cm_div_h14_dpll_core = 0x4a004144, + .cm_ssc_deltamstep_dpll_core = 0x4a004148, + .cm_ssc_modfreqdiv_dpll_core = 0x4a00414c, + .cm_emu_override_dpll_core = 0x4a004150, + .cm_div_h22_dpllcore = 0x4a004154, + .cm_div_h23_dpll_core = 0x4a004158, + .cm_clkmode_dpll_mpu = 0x4a004160, + .cm_idlest_dpll_mpu = 0x4a004164, + .cm_autoidle_dpll_mpu = 0x4a004168, + .cm_clksel_dpll_mpu = 0x4a00416c, + .cm_div_m2_dpll_mpu = 0x4a004170, + .cm_ssc_deltamstep_dpll_mpu = 0x4a004188, + .cm_ssc_modfreqdiv_dpll_mpu = 0x4a00418c, + .cm_bypclk_dpll_mpu = 0x4a00419c, + .cm_clkmode_dpll_iva = 0x4a0041a0, + .cm_idlest_dpll_iva = 0x4a0041a4, + .cm_autoidle_dpll_iva = 0x4a0041a8, + .cm_clksel_dpll_iva = 0x4a0041ac, + .cm_div_h11_dpll_iva = 0x4a0041b8, + .cm_div_h12_dpll_iva = 0x4a0041bc, + .cm_ssc_deltamstep_dpll_iva = 0x4a0041c8, + .cm_ssc_modfreqdiv_dpll_iva = 0x4a0041cc, + .cm_bypclk_dpll_iva = 0x4a0041dc, + .cm_clkmode_dpll_abe = 0x4a0041e0, + .cm_idlest_dpll_abe = 0x4a0041e4, + .cm_autoidle_dpll_abe = 0x4a0041e8, + .cm_clksel_dpll_abe = 0x4a0041ec, + .cm_div_m2_dpll_abe = 0x4a0041f0, + .cm_div_m3_dpll_abe = 0x4a0041f4, + .cm_ssc_deltamstep_dpll_abe = 0x4a004208, + .cm_ssc_modfreqdiv_dpll_abe = 0x4a00420c, + .cm_clkmode_dpll_ddrphy = 0x4a004220, + .cm_idlest_dpll_ddrphy = 0x4a004224, + .cm_autoidle_dpll_ddrphy = 0x4a004228, + .cm_clksel_dpll_ddrphy = 0x4a00422c, + .cm_div_m2_dpll_ddrphy = 0x4a004230, + .cm_div_h11_dpll_ddrphy = 0x4a004238, + .cm_div_h12_dpll_ddrphy = 0x4a00423c, + .cm_div_h13_dpll_ddrphy = 0x4a004240, + .cm_ssc_deltamstep_dpll_ddrphy = 0x4a004248, + .cm_shadow_freq_config1 = 0x4a004260, + .cm_mpu_mpu_clkctrl = 0x4a004320, + + /* cm1.dsp */ + .cm_dsp_clkstctrl = 0x4a004400, + .cm_dsp_dsp_clkctrl = 0x4a004420, + + /* cm1.abe */ + .cm1_abe_clkstctrl = 0x4a004500, + .cm1_abe_l4abe_clkctrl = 0x4a004520, + .cm1_abe_aess_clkctrl = 0x4a004528, + .cm1_abe_pdm_clkctrl = 0x4a004530, + .cm1_abe_dmic_clkctrl = 0x4a004538, + .cm1_abe_mcasp_clkctrl = 0x4a004540, + .cm1_abe_mcbsp1_clkctrl = 0x4a004548, + .cm1_abe_mcbsp2_clkctrl = 0x4a004550, + .cm1_abe_mcbsp3_clkctrl = 0x4a004558, + .cm1_abe_slimbus_clkctrl = 0x4a004560, + .cm1_abe_timer5_clkctrl = 0x4a004568, + .cm1_abe_timer6_clkctrl = 0x4a004570, + .cm1_abe_timer7_clkctrl = 0x4a004578, + .cm1_abe_timer8_clkctrl = 0x4a004580, + .cm1_abe_wdt3_clkctrl = 0x4a004588, + + /* cm2.ckgen */ + .cm_clksel_mpu_m3_iss_root = 0x4a008100, + .cm_clksel_usb_60mhz = 0x4a008104, + .cm_scale_fclk = 0x4a008108, + .cm_core_dvfs_perf1 = 0x4a008110, + .cm_core_dvfs_perf2 = 0x4a008114, + .cm_core_dvfs_perf3 = 0x4a008118, + .cm_core_dvfs_perf4 = 0x4a00811c, + .cm_core_dvfs_current = 0x4a008124, + .cm_iva_dvfs_perf_tesla = 0x4a008128, + .cm_iva_dvfs_perf_ivahd = 0x4a00812c, + .cm_iva_dvfs_perf_abe = 0x4a008130, + .cm_iva_dvfs_current = 0x4a008138, + .cm_clkmode_dpll_per = 0x4a008140, + .cm_idlest_dpll_per = 0x4a008144, + .cm_autoidle_dpll_per = 0x4a008148, + .cm_clksel_dpll_per = 0x4a00814c, + .cm_div_m2_dpll_per = 0x4a008150, + .cm_div_m3_dpll_per = 0x4a008154, + .cm_div_h11_dpll_per = 0x4a008158, + .cm_div_h12_dpll_per = 0x4a00815c, + .cm_div_h14_dpll_per = 0x4a008164, + .cm_ssc_deltamstep_dpll_per = 0x4a008168, + .cm_ssc_modfreqdiv_dpll_per = 0x4a00816c, + .cm_emu_override_dpll_per = 0x4a008170, + .cm_clkmode_dpll_usb = 0x4a008180, + .cm_idlest_dpll_usb = 0x4a008184, + .cm_autoidle_dpll_usb = 0x4a008188, + .cm_clksel_dpll_usb = 0x4a00818c, + .cm_div_m2_dpll_usb = 0x4a008190, + .cm_ssc_deltamstep_dpll_usb = 0x4a0081a8, + .cm_ssc_modfreqdiv_dpll_usb = 0x4a0081ac, + .cm_clkdcoldo_dpll_usb = 0x4a0081b4, + .cm_clkmode_dpll_unipro = 0x4a0081c0, + .cm_idlest_dpll_unipro = 0x4a0081c4, + .cm_autoidle_dpll_unipro = 0x4a0081c8, + .cm_clksel_dpll_unipro = 0x4a0081cc, + .cm_div_m2_dpll_unipro = 0x4a0081d0, + .cm_ssc_deltamstep_dpll_unipro = 0x4a0081e8, + .cm_ssc_modfreqdiv_dpll_unipro = 0x4a0081ec, + + /* cm2.core */ + .cm_coreaon_bandgap_clkctrl = 0x4a008648, + .cm_l3_1_clkstctrl = 0x4a008700, + .cm_l3_1_dynamicdep = 0x4a008708, + .cm_l3_1_l3_1_clkctrl = 0x4a008720, + .cm_l3_2_clkstctrl = 0x4a008800, + .cm_l3_2_dynamicdep = 0x4a008808, + .cm_l3_2_l3_2_clkctrl = 0x4a008820, + .cm_l3_2_gpmc_clkctrl = 0x4a008828, + .cm_l3_2_ocmc_ram_clkctrl = 0x4a008830, + .cm_mpu_m3_clkstctrl = 0x4a008900, + .cm_mpu_m3_staticdep = 0x4a008904, + .cm_mpu_m3_dynamicdep = 0x4a008908, + .cm_mpu_m3_mpu_m3_clkctrl = 0x4a008920, + .cm_sdma_clkstctrl = 0x4a008a00, + .cm_sdma_staticdep = 0x4a008a04, + .cm_sdma_dynamicdep = 0x4a008a08, + .cm_sdma_sdma_clkctrl = 0x4a008a20, + .cm_memif_clkstctrl = 0x4a008b00, + .cm_memif_dmm_clkctrl = 0x4a008b20, + .cm_memif_emif_fw_clkctrl = 0x4a008b28, + .cm_memif_emif_1_clkctrl = 0x4a008b30, + .cm_memif_emif_2_clkctrl = 0x4a008b38, + .cm_memif_dll_clkctrl = 0x4a008b40, + .cm_memif_emif_h1_clkctrl = 0x4a008b50, + .cm_memif_emif_h2_clkctrl = 0x4a008b58, + .cm_memif_dll_h_clkctrl = 0x4a008b60, + .cm_c2c_clkstctrl = 0x4a008c00, + .cm_c2c_staticdep = 0x4a008c04, + .cm_c2c_dynamicdep = 0x4a008c08, + .cm_c2c_sad2d_clkctrl = 0x4a008c20, + .cm_c2c_modem_icr_clkctrl = 0x4a008c28, + .cm_c2c_sad2d_fw_clkctrl = 0x4a008c30, + .cm_l4cfg_clkstctrl = 0x4a008d00, + .cm_l4cfg_dynamicdep = 0x4a008d08, + .cm_l4cfg_l4_cfg_clkctrl = 0x4a008d20, + .cm_l4cfg_hw_sem_clkctrl = 0x4a008d28, + .cm_l4cfg_mailbox_clkctrl = 0x4a008d30, + .cm_l4cfg_sar_rom_clkctrl = 0x4a008d38, + .cm_l3instr_clkstctrl = 0x4a008e00, + .cm_l3instr_l3_3_clkctrl = 0x4a008e20, + .cm_l3instr_l3_instr_clkctrl = 0x4a008e28, + .cm_l3instr_intrconn_wp1_clkctrl = 0x4a008e40, + + /* cm2.ivahd */ + .cm_ivahd_clkstctrl = 0x4a008f00, + .cm_ivahd_ivahd_clkctrl = 0x4a008f20, + .cm_ivahd_sl2_clkctrl = 0x4a008f28, + + /* cm2.cam */ + .cm_cam_clkstctrl = 0x4a009000, + .cm_cam_iss_clkctrl = 0x4a009020, + .cm_cam_fdif_clkctrl = 0x4a009028, + + /* cm2.dss */ + .cm_dss_clkstctrl = 0x4a009100, + .cm_dss_dss_clkctrl = 0x4a009120, + + /* cm2.sgx */ + .cm_sgx_clkstctrl = 0x4a009200, + .cm_sgx_sgx_clkctrl = 0x4a009220, + + /* cm2.l3init */ + .cm_l3init_clkstctrl = 0x4a009300, + .cm_l3init_hsmmc1_clkctrl = 0x4a009328, + .cm_l3init_hsmmc2_clkctrl = 0x4a009330, + .cm_l3init_hsi_clkctrl = 0x4a009338, + .cm_l3init_hsusbhost_clkctrl = 0x4a009358, + .cm_l3init_hsusbotg_clkctrl = 0x4a009360, + .cm_l3init_hsusbtll_clkctrl = 0x4a009368, + .cm_l3init_p1500_clkctrl = 0x4a009378, + .cm_l3init_fsusb_clkctrl = 0x4a0093d0, + .cm_l3init_ocp2scp1_clkctrl = 0x4a0093e0, + + /* cm2.l4per */ + .cm_l4per_clkstctrl = 0x4a009400, + .cm_l4per_dynamicdep = 0x4a009408, + .cm_l4per_adc_clkctrl = 0x4a009420, + .cm_l4per_gptimer10_clkctrl = 0x4a009428, + .cm_l4per_gptimer11_clkctrl = 0x4a009430, + .cm_l4per_gptimer2_clkctrl = 0x4a009438, + .cm_l4per_gptimer3_clkctrl = 0x4a009440, + .cm_l4per_gptimer4_clkctrl = 0x4a009448, + .cm_l4per_gptimer9_clkctrl = 0x4a009450, + .cm_l4per_elm_clkctrl = 0x4a009458, + .cm_l4per_gpio2_clkctrl = 0x4a009460, + .cm_l4per_gpio3_clkctrl = 0x4a009468, + .cm_l4per_gpio4_clkctrl = 0x4a009470, + .cm_l4per_gpio5_clkctrl = 0x4a009478, + .cm_l4per_gpio6_clkctrl = 0x4a009480, + .cm_l4per_hdq1w_clkctrl = 0x4a009488, + .cm_l4per_hecc1_clkctrl = 0x4a009490, + .cm_l4per_hecc2_clkctrl = 0x4a009498, + .cm_l4per_i2c1_clkctrl = 0x4a0094a0, + .cm_l4per_i2c2_clkctrl = 0x4a0094a8, + .cm_l4per_i2c3_clkctrl = 0x4a0094b0, + .cm_l4per_i2c4_clkctrl = 0x4a0094b8, + .cm_l4per_l4per_clkctrl = 0x4a0094c0, + .cm_l4per_mcasp2_clkctrl = 0x4a0094d0, + .cm_l4per_mcasp3_clkctrl = 0x4a0094d8, + .cm_l4per_mgate_clkctrl = 0x4a0094e8, + .cm_l4per_mcspi1_clkctrl = 0x4a0094f0, + .cm_l4per_mcspi2_clkctrl = 0x4a0094f8, + .cm_l4per_mcspi3_clkctrl = 0x4a009500, + .cm_l4per_mcspi4_clkctrl = 0x4a009508, + .cm_l4per_gpio7_clkctrl = 0x4a009510, + .cm_l4per_gpio8_clkctrl = 0x4a009518, + .cm_l4per_mmcsd3_clkctrl = 0x4a009520, + .cm_l4per_mmcsd4_clkctrl = 0x4a009528, + .cm_l4per_msprohg_clkctrl = 0x4a009530, + .cm_l4per_slimbus2_clkctrl = 0x4a009538, + .cm_l4per_uart1_clkctrl = 0x4a009540, + .cm_l4per_uart2_clkctrl = 0x4a009548, + .cm_l4per_uart3_clkctrl = 0x4a009550, + .cm_l4per_uart4_clkctrl = 0x4a009558, + .cm_l4per_mmcsd5_clkctrl = 0x4a009560, + .cm_l4per_i2c5_clkctrl = 0x4a009568, + .cm_l4per_uart5_clkctrl = 0x4a009570, + .cm_l4per_uart6_clkctrl = 0x4a009578, + .cm_l4sec_clkstctrl = 0x4a009580, + .cm_l4sec_staticdep = 0x4a009584, + .cm_l4sec_dynamicdep = 0x4a009588, + .cm_l4sec_aes1_clkctrl = 0x4a0095a0, + .cm_l4sec_aes2_clkctrl = 0x4a0095a8, + .cm_l4sec_des3des_clkctrl = 0x4a0095b0, + .cm_l4sec_pkaeip29_clkctrl = 0x4a0095b8, + .cm_l4sec_rng_clkctrl = 0x4a0095c0, + .cm_l4sec_sha2md51_clkctrl = 0x4a0095c8, + .cm_l4sec_cryptodma_clkctrl = 0x4a0095d8, + + /* l4 wkup regs */ + .cm_abe_pll_ref_clksel = 0x4ae0610c, + .cm_sys_clksel = 0x4ae06110, + .cm_wkup_clkstctrl = 0x4ae07800, + .cm_wkup_l4wkup_clkctrl = 0x4ae07820, + .cm_wkup_wdtimer1_clkctrl = 0x4ae07828, + .cm_wkup_wdtimer2_clkctrl = 0x4ae07830, + .cm_wkup_gpio1_clkctrl = 0x4ae07838, + .cm_wkup_gptimer1_clkctrl = 0x4ae07840, + .cm_wkup_gptimer12_clkctrl = 0x4ae07848, + .cm_wkup_synctimer_clkctrl = 0x4ae07850, + .cm_wkup_usim_clkctrl = 0x4ae07858, + .cm_wkup_sarram_clkctrl = 0x4ae07860, + .cm_wkup_keyboard_clkctrl = 0x4ae07878, + .cm_wkup_rtc_clkctrl = 0x4ae07880, + .cm_wkup_bandgap_clkctrl = 0x4ae07888, + .cm_wkupaon_scrm_clkctrl = 0x4ae07890, + .prm_vc_val_bypass = 0x4ae07ba0, + .prm_vc_cfg_i2c_mode = 0x4ae07bb4, + .prm_vc_cfg_i2c_clk = 0x4ae07bb8, + .prm_sldo_core_setup = 0x4ae07bc4, + .prm_sldo_core_ctrl = 0x4ae07bc8, + .prm_sldo_mpu_setup = 0x4ae07bcc, + .prm_sldo_mpu_ctrl = 0x4ae07bd0, + .prm_sldo_mm_setup = 0x4ae07bd4, + .prm_sldo_mm_ctrl = 0x4ae07bd8, +}; diff --git a/arch/arm/include/asm/arch-omap4/clocks.h b/arch/arm/include/asm/arch-omap4/clocks.h index be20fc0..4710d88 100644 --- a/arch/arm/include/asm/arch-omap4/clocks.h +++ b/arch/arm/include/asm/arch-omap4/clocks.h @@ -25,6 +25,7 @@ #ifndef _CLOCKS_OMAP4_H_ #define _CLOCKS_OMAP4_H_ #include <common.h> +#include <asm/omap_common.h>
/* * Assuming a maximum of 1.5 GHz ARM speed and a minimum of 2 cycles per @@ -38,479 +39,6 @@ #define CM_CLKMODE_DPLL_MPU 0x4A004160 #define CM_CLKSEL_CORE 0x4A004100
-struct omap4_prcm_regs { - /* cm1.ckgen */ - u32 cm_clksel_core; - u32 pad001[1]; - u32 cm_clksel_abe; - u32 pad002[1]; - u32 cm_dll_ctrl; - u32 pad003[3]; - u32 cm_clkmode_dpll_core; - u32 cm_idlest_dpll_core; - u32 cm_autoidle_dpll_core; - u32 cm_clksel_dpll_core; - u32 cm_div_m2_dpll_core; - u32 cm_div_m3_dpll_core; - u32 cm_div_m4_dpll_core; - u32 cm_div_m5_dpll_core; - u32 cm_div_m6_dpll_core; - u32 cm_div_m7_dpll_core; - u32 cm_ssc_deltamstep_dpll_core; - u32 cm_ssc_modfreqdiv_dpll_core; - u32 cm_emu_override_dpll_core; - u32 pad004[3]; - u32 cm_clkmode_dpll_mpu; - u32 cm_idlest_dpll_mpu; - u32 cm_autoidle_dpll_mpu; - u32 cm_clksel_dpll_mpu; - u32 cm_div_m2_dpll_mpu; - u32 pad005[5]; - u32 cm_ssc_deltamstep_dpll_mpu; - u32 cm_ssc_modfreqdiv_dpll_mpu; - u32 pad006[3]; - u32 cm_bypclk_dpll_mpu; - u32 cm_clkmode_dpll_iva; - u32 cm_idlest_dpll_iva; - u32 cm_autoidle_dpll_iva; - u32 cm_clksel_dpll_iva; - u32 pad007[2]; - u32 cm_div_m4_dpll_iva; - u32 cm_div_m5_dpll_iva; - u32 pad008[2]; - u32 cm_ssc_deltamstep_dpll_iva; - u32 cm_ssc_modfreqdiv_dpll_iva; - u32 pad009[3]; - u32 cm_bypclk_dpll_iva; - u32 cm_clkmode_dpll_abe; - u32 cm_idlest_dpll_abe; - u32 cm_autoidle_dpll_abe; - u32 cm_clksel_dpll_abe; - u32 cm_div_m2_dpll_abe; - u32 cm_div_m3_dpll_abe; - u32 pad010[4]; - u32 cm_ssc_deltamstep_dpll_abe; - u32 cm_ssc_modfreqdiv_dpll_abe; - u32 pad011[4]; - u32 cm_clkmode_dpll_ddrphy; - u32 cm_idlest_dpll_ddrphy; - u32 cm_autoidle_dpll_ddrphy; - u32 cm_clksel_dpll_ddrphy; - u32 cm_div_m2_dpll_ddrphy; - u32 pad012[1]; - u32 cm_div_m4_dpll_ddrphy; - u32 cm_div_m5_dpll_ddrphy; - u32 cm_div_m6_dpll_ddrphy; - u32 pad013[1]; - u32 cm_ssc_deltamstep_dpll_ddrphy; - u32 pad014[5]; - u32 cm_shadow_freq_config1; - u32 pad0141[47]; - u32 cm_mpu_mpu_clkctrl; - - /* cm1.dsp */ - u32 pad015[55]; - u32 cm_dsp_clkstctrl; - u32 pad016[7]; - u32 cm_dsp_dsp_clkctrl; - - /* cm1.abe */ - u32 pad017[55]; - u32 cm1_abe_clkstctrl; - u32 pad018[7]; - u32 cm1_abe_l4abe_clkctrl; - u32 pad019[1]; - u32 cm1_abe_aess_clkctrl; - u32 pad020[1]; - u32 cm1_abe_pdm_clkctrl; - u32 pad021[1]; - u32 cm1_abe_dmic_clkctrl; - u32 pad022[1]; - u32 cm1_abe_mcasp_clkctrl; - u32 pad023[1]; - u32 cm1_abe_mcbsp1_clkctrl; - u32 pad024[1]; - u32 cm1_abe_mcbsp2_clkctrl; - u32 pad025[1]; - u32 cm1_abe_mcbsp3_clkctrl; - u32 pad026[1]; - u32 cm1_abe_slimbus_clkctrl; - u32 pad027[1]; - u32 cm1_abe_timer5_clkctrl; - u32 pad028[1]; - u32 cm1_abe_timer6_clkctrl; - u32 pad029[1]; - u32 cm1_abe_timer7_clkctrl; - u32 pad030[1]; - u32 cm1_abe_timer8_clkctrl; - u32 pad031[1]; - u32 cm1_abe_wdt3_clkctrl; - - /* cm2.ckgen */ - u32 pad032[3805]; - u32 cm_clksel_mpu_m3_iss_root; - u32 cm_clksel_usb_60mhz; - u32 cm_scale_fclk; - u32 pad033[1]; - u32 cm_core_dvfs_perf1; - u32 cm_core_dvfs_perf2; - u32 cm_core_dvfs_perf3; - u32 cm_core_dvfs_perf4; - u32 pad034[1]; - u32 cm_core_dvfs_current; - u32 cm_iva_dvfs_perf_tesla; - u32 cm_iva_dvfs_perf_ivahd; - u32 cm_iva_dvfs_perf_abe; - u32 pad035[1]; - u32 cm_iva_dvfs_current; - u32 pad036[1]; - u32 cm_clkmode_dpll_per; - u32 cm_idlest_dpll_per; - u32 cm_autoidle_dpll_per; - u32 cm_clksel_dpll_per; - u32 cm_div_m2_dpll_per; - u32 cm_div_m3_dpll_per; - u32 cm_div_m4_dpll_per; - u32 cm_div_m5_dpll_per; - u32 cm_div_m6_dpll_per; - u32 cm_div_m7_dpll_per; - u32 cm_ssc_deltamstep_dpll_per; - u32 cm_ssc_modfreqdiv_dpll_per; - u32 cm_emu_override_dpll_per; - u32 pad037[3]; - u32 cm_clkmode_dpll_usb; - u32 cm_idlest_dpll_usb; - u32 cm_autoidle_dpll_usb; - u32 cm_clksel_dpll_usb; - u32 cm_div_m2_dpll_usb; - u32 pad038[5]; - u32 cm_ssc_deltamstep_dpll_usb; - u32 cm_ssc_modfreqdiv_dpll_usb; - u32 pad039[1]; - u32 cm_clkdcoldo_dpll_usb; - u32 pad040[2]; - u32 cm_clkmode_dpll_unipro; - u32 cm_idlest_dpll_unipro; - u32 cm_autoidle_dpll_unipro; - u32 cm_clksel_dpll_unipro; - u32 cm_div_m2_dpll_unipro; - u32 pad041[5]; - u32 cm_ssc_deltamstep_dpll_unipro; - u32 cm_ssc_modfreqdiv_dpll_unipro; - - /* cm2.core */ - u32 pad0411[324]; - u32 cm_l3_1_clkstctrl; - u32 pad042[1]; - u32 cm_l3_1_dynamicdep; - u32 pad043[5]; - u32 cm_l3_1_l3_1_clkctrl; - u32 pad044[55]; - u32 cm_l3_2_clkstctrl; - u32 pad045[1]; - u32 cm_l3_2_dynamicdep; - u32 pad046[5]; - u32 cm_l3_2_l3_2_clkctrl; - u32 pad047[1]; - u32 cm_l3_2_gpmc_clkctrl; - u32 pad048[1]; - u32 cm_l3_2_ocmc_ram_clkctrl; - u32 pad049[51]; - u32 cm_mpu_m3_clkstctrl; - u32 cm_mpu_m3_staticdep; - u32 cm_mpu_m3_dynamicdep; - u32 pad050[5]; - u32 cm_mpu_m3_mpu_m3_clkctrl; - u32 pad051[55]; - u32 cm_sdma_clkstctrl; - u32 cm_sdma_staticdep; - u32 cm_sdma_dynamicdep; - u32 pad052[5]; - u32 cm_sdma_sdma_clkctrl; - u32 pad053[55]; - u32 cm_memif_clkstctrl; - u32 pad054[7]; - u32 cm_memif_dmm_clkctrl; - u32 pad055[1]; - u32 cm_memif_emif_fw_clkctrl; - u32 pad056[1]; - u32 cm_memif_emif_1_clkctrl; - u32 pad057[1]; - u32 cm_memif_emif_2_clkctrl; - u32 pad058[1]; - u32 cm_memif_dll_clkctrl; - u32 pad059[3]; - u32 cm_memif_emif_h1_clkctrl; - u32 pad060[1]; - u32 cm_memif_emif_h2_clkctrl; - u32 pad061[1]; - u32 cm_memif_dll_h_clkctrl; - u32 pad062[39]; - u32 cm_c2c_clkstctrl; - u32 cm_c2c_staticdep; - u32 cm_c2c_dynamicdep; - u32 pad063[5]; - u32 cm_c2c_sad2d_clkctrl; - u32 pad064[1]; - u32 cm_c2c_modem_icr_clkctrl; - u32 pad065[1]; - u32 cm_c2c_sad2d_fw_clkctrl; - u32 pad066[51]; - u32 cm_l4cfg_clkstctrl; - u32 pad067[1]; - u32 cm_l4cfg_dynamicdep; - u32 pad068[5]; - u32 cm_l4cfg_l4_cfg_clkctrl; - u32 pad069[1]; - u32 cm_l4cfg_hw_sem_clkctrl; - u32 pad070[1]; - u32 cm_l4cfg_mailbox_clkctrl; - u32 pad071[1]; - u32 cm_l4cfg_sar_rom_clkctrl; - u32 pad072[49]; - u32 cm_l3instr_clkstctrl; - u32 pad073[7]; - u32 cm_l3instr_l3_3_clkctrl; - u32 pad074[1]; - u32 cm_l3instr_l3_instr_clkctrl; - u32 pad075[5]; - u32 cm_l3instr_intrconn_wp1_clkctrl; - - - /* cm2.ivahd */ - u32 pad076[47]; - u32 cm_ivahd_clkstctrl; - u32 pad077[7]; - u32 cm_ivahd_ivahd_clkctrl; - u32 pad078[1]; - u32 cm_ivahd_sl2_clkctrl; - - /* cm2.cam */ - u32 pad079[53]; - u32 cm_cam_clkstctrl; - u32 pad080[7]; - u32 cm_cam_iss_clkctrl; - u32 pad081[1]; - u32 cm_cam_fdif_clkctrl; - - /* cm2.dss */ - u32 pad082[53]; - u32 cm_dss_clkstctrl; - u32 pad083[7]; - u32 cm_dss_dss_clkctrl; - - /* cm2.sgx */ - u32 pad084[55]; - u32 cm_sgx_clkstctrl; - u32 pad085[7]; - u32 cm_sgx_sgx_clkctrl; - - /* cm2.l3init */ - u32 pad086[55]; - u32 cm_l3init_clkstctrl; - - /* cm2.l3init */ - u32 pad087[9]; - u32 cm_l3init_hsmmc1_clkctrl; - u32 pad088[1]; - u32 cm_l3init_hsmmc2_clkctrl; - u32 pad089[1]; - u32 cm_l3init_hsi_clkctrl; - u32 pad090[7]; - u32 cm_l3init_hsusbhost_clkctrl; - u32 pad091[1]; - u32 cm_l3init_hsusbotg_clkctrl; - u32 pad092[1]; - u32 cm_l3init_hsusbtll_clkctrl; - u32 pad093[3]; - u32 cm_l3init_p1500_clkctrl; - u32 pad094[21]; - u32 cm_l3init_fsusb_clkctrl; - u32 pad095[3]; - u32 cm_l3init_usbphy_clkctrl; - - /* cm2.l4per */ - u32 pad096[7]; - u32 cm_l4per_clkstctrl; - u32 pad097[1]; - u32 cm_l4per_dynamicdep; - u32 pad098[5]; - u32 cm_l4per_adc_clkctrl; - u32 pad100[1]; - u32 cm_l4per_gptimer10_clkctrl; - u32 pad101[1]; - u32 cm_l4per_gptimer11_clkctrl; - u32 pad102[1]; - u32 cm_l4per_gptimer2_clkctrl; - u32 pad103[1]; - u32 cm_l4per_gptimer3_clkctrl; - u32 pad104[1]; - u32 cm_l4per_gptimer4_clkctrl; - u32 pad105[1]; - u32 cm_l4per_gptimer9_clkctrl; - u32 pad106[1]; - u32 cm_l4per_elm_clkctrl; - u32 pad107[1]; - u32 cm_l4per_gpio2_clkctrl; - u32 pad108[1]; - u32 cm_l4per_gpio3_clkctrl; - u32 pad109[1]; - u32 cm_l4per_gpio4_clkctrl; - u32 pad110[1]; - u32 cm_l4per_gpio5_clkctrl; - u32 pad111[1]; - u32 cm_l4per_gpio6_clkctrl; - u32 pad112[1]; - u32 cm_l4per_hdq1w_clkctrl; - u32 pad113[1]; - u32 cm_l4per_hecc1_clkctrl; - u32 pad114[1]; - u32 cm_l4per_hecc2_clkctrl; - u32 pad115[1]; - u32 cm_l4per_i2c1_clkctrl; - u32 pad116[1]; - u32 cm_l4per_i2c2_clkctrl; - u32 pad117[1]; - u32 cm_l4per_i2c3_clkctrl; - u32 pad118[1]; - u32 cm_l4per_i2c4_clkctrl; - u32 pad119[1]; - u32 cm_l4per_l4per_clkctrl; - u32 pad1191[3]; - u32 cm_l4per_mcasp2_clkctrl; - u32 pad120[1]; - u32 cm_l4per_mcasp3_clkctrl; - u32 pad121[1]; - u32 cm_l4per_mcbsp4_clkctrl; - u32 pad122[1]; - u32 cm_l4per_mgate_clkctrl; - u32 pad123[1]; - u32 cm_l4per_mcspi1_clkctrl; - u32 pad124[1]; - u32 cm_l4per_mcspi2_clkctrl; - u32 pad125[1]; - u32 cm_l4per_mcspi3_clkctrl; - u32 pad126[1]; - u32 cm_l4per_mcspi4_clkctrl; - u32 pad127[5]; - u32 cm_l4per_mmcsd3_clkctrl; - u32 pad128[1]; - u32 cm_l4per_mmcsd4_clkctrl; - u32 pad129[1]; - u32 cm_l4per_msprohg_clkctrl; - u32 pad130[1]; - u32 cm_l4per_slimbus2_clkctrl; - u32 pad131[1]; - u32 cm_l4per_uart1_clkctrl; - u32 pad132[1]; - u32 cm_l4per_uart2_clkctrl; - u32 pad133[1]; - u32 cm_l4per_uart3_clkctrl; - u32 pad134[1]; - u32 cm_l4per_uart4_clkctrl; - u32 pad135[1]; - u32 cm_l4per_mmcsd5_clkctrl; - u32 pad136[1]; - u32 cm_l4per_i2c5_clkctrl; - u32 pad137[5]; - u32 cm_l4sec_clkstctrl; - u32 cm_l4sec_staticdep; - u32 cm_l4sec_dynamicdep; - u32 pad138[5]; - u32 cm_l4sec_aes1_clkctrl; - u32 pad139[1]; - u32 cm_l4sec_aes2_clkctrl; - u32 pad140[1]; - u32 cm_l4sec_des3des_clkctrl; - u32 pad141[1]; - u32 cm_l4sec_pkaeip29_clkctrl; - u32 pad142[1]; - u32 cm_l4sec_rng_clkctrl; - u32 pad143[1]; - u32 cm_l4sec_sha2md51_clkctrl; - u32 pad144[3]; - u32 cm_l4sec_cryptodma_clkctrl; - u32 pad145[776841]; - - /* l4 wkup regs */ - u32 pad201[6211]; - u32 cm_abe_pll_ref_clksel; - u32 cm_sys_clksel; - u32 pad202[1467]; - u32 cm_wkup_clkstctrl; - u32 pad203[7]; - u32 cm_wkup_l4wkup_clkctrl; - u32 pad204; - u32 cm_wkup_wdtimer1_clkctrl; - u32 pad205; - u32 cm_wkup_wdtimer2_clkctrl; - u32 pad206; - u32 cm_wkup_gpio1_clkctrl; - u32 pad207; - u32 cm_wkup_gptimer1_clkctrl; - u32 pad208; - u32 cm_wkup_gptimer12_clkctrl; - u32 pad209; - u32 cm_wkup_synctimer_clkctrl; - u32 pad210; - u32 cm_wkup_usim_clkctrl; - u32 pad211; - u32 cm_wkup_sarram_clkctrl; - u32 pad212[5]; - u32 cm_wkup_keyboard_clkctrl; - u32 pad213; - u32 cm_wkup_rtc_clkctrl; - u32 pad214; - u32 cm_wkup_bandgap_clkctrl; - u32 pad215[197]; - u32 prm_vc_val_bypass; - u32 prm_vc_cfg_channel; - u32 prm_vc_cfg_i2c_mode; - u32 prm_vc_cfg_i2c_clk; - -}; - -struct omap4_scrm_regs { - u32 revision; /* 0x0000 */ - u32 pad00[63]; - u32 clksetuptime; /* 0x0100 */ - u32 pmicsetuptime; /* 0x0104 */ - u32 pad01[2]; - u32 altclksrc; /* 0x0110 */ - u32 pad02[2]; - u32 c2cclkm; /* 0x011c */ - u32 pad03[56]; - u32 extclkreq; /* 0x0200 */ - u32 accclkreq; /* 0x0204 */ - u32 pwrreq; /* 0x0208 */ - u32 pad04[1]; - u32 auxclkreq0; /* 0x0210 */ - u32 auxclkreq1; /* 0x0214 */ - u32 auxclkreq2; /* 0x0218 */ - u32 auxclkreq3; /* 0x021c */ - u32 auxclkreq4; /* 0x0220 */ - u32 auxclkreq5; /* 0x0224 */ - u32 pad05[3]; - u32 c2cclkreq; /* 0x0234 */ - u32 pad06[54]; - u32 auxclk0; /* 0x0310 */ - u32 auxclk1; /* 0x0314 */ - u32 auxclk2; /* 0x0318 */ - u32 auxclk3; /* 0x031c */ - u32 auxclk4; /* 0x0320 */ - u32 auxclk5; /* 0x0324 */ - u32 pad07[54]; - u32 rsttime_reg; /* 0x0400 */ - u32 pad08[6]; - u32 c2crstctrl; /* 0x041c */ - u32 extpwronrstctrl; /* 0x0420 */ - u32 pad09[59]; - u32 extwarmrstst_reg; /* 0x0510 */ - u32 apewarmrstst_reg; /* 0x0514 */ - u32 pad10[1]; - u32 c2cwarmrstst_reg; /* 0x051C */ -}; - /* DPLL register offsets */ #define CM_CLKMODE_DPLL 0 #define CM_IDLEST_DPLL 0x4 @@ -741,7 +269,6 @@ struct dpll_params { s8 m7; };
-extern struct omap4_prcm_regs *const prcm; extern const u32 sys_clk_array[8];
void scale_vcores(void); @@ -749,14 +276,14 @@ void do_scale_tps62361(int gpio, u32 reg, u32 volt_mv); u32 get_offset_code(u32 offset); u32 omap_ddr_clk(void); void do_scale_vcore(u32 vcore_reg, u32 volt_mv); -void setup_post_dividers(u32 *const base, const struct dpll_params *params); +void setup_post_dividers(u32 const base, const struct dpll_params *params); u32 get_sys_clk_index(void); void enable_basic_clocks(void); void enable_basic_uboot_clocks(void); void enable_non_essential_clocks(void); -void do_enable_clocks(u32 *const *clk_domains, - u32 *const *clk_modules_hw_auto, - u32 *const *clk_modules_explicit_en, +void do_enable_clocks(u32 const *clk_domains, + u32 const *clk_modules_hw_auto, + u32 const *clk_modules_explicit_en, u8 wait_for_enable); const struct dpll_params *get_mpu_dpll_params(void); const struct dpll_params *get_core_dpll_params(void); @@ -764,4 +291,45 @@ const struct dpll_params *get_per_dpll_params(void); const struct dpll_params *get_iva_dpll_params(void); const struct dpll_params *get_usb_dpll_params(void); const struct dpll_params *get_abe_dpll_params(void); + +struct omap4_scrm_regs { + u32 revision; /* 0x0000 */ + u32 pad00[63]; + u32 clksetuptime; /* 0x0100 */ + u32 pmicsetuptime; /* 0x0104 */ + u32 pad01[2]; + u32 altclksrc; /* 0x0110 */ + u32 pad02[2]; + u32 c2cclkm; /* 0x011c */ + u32 pad03[56]; + u32 extclkreq; /* 0x0200 */ + u32 accclkreq; /* 0x0204 */ + u32 pwrreq; /* 0x0208 */ + u32 pad04[1]; + u32 auxclkreq0; /* 0x0210 */ + u32 auxclkreq1; /* 0x0214 */ + u32 auxclkreq2; /* 0x0218 */ + u32 auxclkreq3; /* 0x021c */ + u32 auxclkreq4; /* 0x0220 */ + u32 auxclkreq5; /* 0x0224 */ + u32 pad05[3]; + u32 c2cclkreq; /* 0x0234 */ + u32 pad06[54]; + u32 auxclk0; /* 0x0310 */ + u32 auxclk1; /* 0x0314 */ + u32 auxclk2; /* 0x0318 */ + u32 auxclk3; /* 0x031c */ + u32 auxclk4; /* 0x0320 */ + u32 auxclk5; /* 0x0324 */ + u32 pad07[54]; + u32 rsttime_reg; /* 0x0400 */ + u32 pad08[6]; + u32 c2crstctrl; /* 0x041c */ + u32 extpwronrstctrl; /* 0x0420 */ + u32 pad09[59]; + u32 extwarmrstst_reg; /* 0x0510 */ + u32 apewarmrstst_reg; /* 0x0514 */ + u32 pad10[1]; + u32 c2cwarmrstst_reg; /* 0x051C */ +}; #endif /* _CLOCKS_OMAP4_H_ */ diff --git a/arch/arm/include/asm/arch-omap4/omap.h b/arch/arm/include/asm/arch-omap4/omap.h index d4b5076..86ba335 100644 --- a/arch/arm/include/asm/arch-omap4/omap.h +++ b/arch/arm/include/asm/arch-omap4/omap.h @@ -178,7 +178,8 @@ struct control_lpddr2io_regs { #define OMAP4_SRAM_SCRATCH_EMIF_SIZE (SRAM_SCRATCH_SPACE_ADDR + 0x4) #define OMAP4_SRAM_SCRATCH_EMIF_T_NUM (SRAM_SCRATCH_SPACE_ADDR + 0xC) #define OMAP4_SRAM_SCRATCH_EMIF_T_DEN (SRAM_SCRATCH_SPACE_ADDR + 0x10) -#define OMAP4_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x14) +#define OMAP_SRAM_SCRATCH_PRCM_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x14) +#define OMAP4_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x18)
/* ROM code defines */ /* Boot device */ diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index b48f81d..d5f1868 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -44,7 +44,7 @@ void sdelay(unsigned long); void set_pl310_ctrl_reg(u32 val); void setup_clocks_for_console(void); void prcm_init(void); -void bypass_dpll(u32 *const base); +void bypass_dpll(u32 const base); void freq_update_core(void); u32 get_sys_clk_freq(void); u32 omap4_ddr_clk(void); diff --git a/arch/arm/include/asm/arch-omap5/clocks.h b/arch/arm/include/asm/arch-omap5/clocks.h index 5f1a7aa..67e74ca 100644 --- a/arch/arm/include/asm/arch-omap5/clocks.h +++ b/arch/arm/include/asm/arch-omap5/clocks.h @@ -26,6 +26,7 @@ #ifndef _CLOCKS_OMAP5_H_ #define _CLOCKS_OMAP5_H_ #include <common.h> +#include <asm/omap_common.h>
/* * Assuming a maximum of 1.5 GHz ARM speed and a minimum of 2 cycles per @@ -39,456 +40,6 @@ #define CM_CLKMODE_DPLL_MPU (OMAP54XX_L4_CORE_BASE + 0x4160) #define CM_CLKSEL_CORE (OMAP54XX_L4_CORE_BASE + 0x4100)
-struct omap5_prcm_regs { - /* cm1.ckgen */ - u32 cm_clksel_core; /* 4a004100 */ - u32 pad001[1]; /* 4a004104 */ - u32 cm_clksel_abe; /* 4a004108 */ - u32 pad002[1]; /* 4a00410c */ - u32 cm_dll_ctrl; /* 4a004110 */ - u32 pad003[3]; /* 4a004114 */ - u32 cm_clkmode_dpll_core; /* 4a004120 */ - u32 cm_idlest_dpll_core; /* 4a004124 */ - u32 cm_autoidle_dpll_core; /* 4a004128 */ - u32 cm_clksel_dpll_core; /* 4a00412c */ - u32 cm_div_m2_dpll_core; /* 4a004130 */ - u32 cm_div_m3_dpll_core; /* 4a004134 */ - u32 cm_div_h11_dpll_core; /* 4a004138 */ - u32 cm_div_h12_dpll_core; /* 4a00413c */ - u32 cm_div_h13_dpll_core; /* 4a004140 */ - u32 cm_div_h14_dpll_core; /* 4a004144 */ - u32 cm_ssc_deltamstep_dpll_core; /* 4a004148 */ - u32 cm_ssc_modfreqdiv_dpll_core; /* 4a00414c */ - u32 cm_emu_override_dpll_core; /* 4a004150 */ - - u32 cm_div_h22_dpllcore; /* 4a004154 */ - u32 cm_div_h23_dpll_core; /* 4a004158 */ - u32 pad0041[1]; /* 4a00415c */ - u32 cm_clkmode_dpll_mpu; /* 4a004160 */ - u32 cm_idlest_dpll_mpu; /* 4a004164 */ - u32 cm_autoidle_dpll_mpu; /* 4a004168 */ - u32 cm_clksel_dpll_mpu; /* 4a00416c */ - u32 cm_div_m2_dpll_mpu; /* 4a004170 */ - u32 pad005[5]; /* 4a004174 */ - u32 cm_ssc_deltamstep_dpll_mpu; /* 4a004188 */ - u32 cm_ssc_modfreqdiv_dpll_mpu; /* 4a00418c */ - u32 pad006[3]; /* 4a004190 */ - u32 cm_bypclk_dpll_mpu; /* 4a00419c */ - u32 cm_clkmode_dpll_iva; /* 4a0041a0 */ - u32 cm_idlest_dpll_iva; /* 4a0041a4 */ - u32 cm_autoidle_dpll_iva; /* 4a0041a8 */ - u32 cm_clksel_dpll_iva; /* 4a0041ac */ - u32 pad007[2]; /* 4a0041b0 */ - u32 cm_div_h11_dpll_iva; /* 4a0041b8 */ - u32 cm_div_h12_dpll_iva; /* 4a0041bc */ - u32 pad008[2]; /* 4a0041c0 */ - u32 cm_ssc_deltamstep_dpll_iva; /* 4a0041c8 */ - u32 cm_ssc_modfreqdiv_dpll_iva; /* 4a0041cc */ - u32 pad009[3]; /* 4a0041d0 */ - u32 cm_bypclk_dpll_iva; /* 4a0041dc */ - u32 cm_clkmode_dpll_abe; /* 4a0041e0 */ - u32 cm_idlest_dpll_abe; /* 4a0041e4 */ - u32 cm_autoidle_dpll_abe; /* 4a0041e8 */ - u32 cm_clksel_dpll_abe; /* 4a0041ec */ - u32 cm_div_m2_dpll_abe; /* 4a0041f0 */ - u32 cm_div_m3_dpll_abe; /* 4a0041f4 */ - u32 pad010[4]; /* 4a0041f8 */ - u32 cm_ssc_deltamstep_dpll_abe; /* 4a004208 */ - u32 cm_ssc_modfreqdiv_dpll_abe; /* 4a00420c */ - u32 pad011[4]; /* 4a004210 */ - u32 cm_clkmode_dpll_ddrphy; /* 4a004220 */ - u32 cm_idlest_dpll_ddrphy; /* 4a004224 */ - u32 cm_autoidle_dpll_ddrphy; /* 4a004228 */ - u32 cm_clksel_dpll_ddrphy; /* 4a00422c */ - u32 cm_div_m2_dpll_ddrphy; /* 4a004230 */ - u32 pad012[1]; /* 4a004234 */ - u32 cm_div_h11_dpll_ddrphy; /* 4a004238 */ - u32 cm_div_h12_dpll_ddrphy; /* 4a00423c */ - u32 cm_div_h13_dpll_ddrphy; /* 4a004240 */ - u32 pad013[1]; /* 4a004244 */ - u32 cm_ssc_deltamstep_dpll_ddrphy; /* 4a004248 */ - u32 pad014[5]; /* 4a00424c */ - u32 cm_shadow_freq_config1; /* 4a004260 */ - u32 pad0141[47]; /* 4a004264 */ - u32 cm_mpu_mpu_clkctrl; /* 4a004320 */ - - - /* cm1.dsp */ - u32 pad015[55]; /* 4a004324 */ - u32 cm_dsp_clkstctrl; /* 4a004400 */ - u32 pad016[7]; /* 4a004404 */ - u32 cm_dsp_dsp_clkctrl; /* 4a004420 */ - - /* cm1.abe */ - u32 pad017[55]; /* 4a004424 */ - u32 cm1_abe_clkstctrl; /* 4a004500 */ - u32 pad018[7]; /* 4a004504 */ - u32 cm1_abe_l4abe_clkctrl; /* 4a004520 */ - u32 pad019[1]; /* 4a004524 */ - u32 cm1_abe_aess_clkctrl; /* 4a004528 */ - u32 pad020[1]; /* 4a00452c */ - u32 cm1_abe_pdm_clkctrl; /* 4a004530 */ - u32 pad021[1]; /* 4a004534 */ - u32 cm1_abe_dmic_clkctrl; /* 4a004538 */ - u32 pad022[1]; /* 4a00453c */ - u32 cm1_abe_mcasp_clkctrl; /* 4a004540 */ - u32 pad023[1]; /* 4a004544 */ - u32 cm1_abe_mcbsp1_clkctrl; /* 4a004548 */ - u32 pad024[1]; /* 4a00454c */ - u32 cm1_abe_mcbsp2_clkctrl; /* 4a004550 */ - u32 pad025[1]; /* 4a004554 */ - u32 cm1_abe_mcbsp3_clkctrl; /* 4a004558 */ - u32 pad026[1]; /* 4a00455c */ - u32 cm1_abe_slimbus_clkctrl; /* 4a004560 */ - u32 pad027[1]; /* 4a004564 */ - u32 cm1_abe_timer5_clkctrl; /* 4a004568 */ - u32 pad028[1]; /* 4a00456c */ - u32 cm1_abe_timer6_clkctrl; /* 4a004570 */ - u32 pad029[1]; /* 4a004574 */ - u32 cm1_abe_timer7_clkctrl; /* 4a004578 */ - u32 pad030[1]; /* 4a00457c */ - u32 cm1_abe_timer8_clkctrl; /* 4a004580 */ - u32 pad031[1]; /* 4a004584 */ - u32 cm1_abe_wdt3_clkctrl; /* 4a004588 */ - - /* cm2.ckgen */ - u32 pad032[3805]; /* 4a00458c */ - u32 cm_clksel_mpu_m3_iss_root; /* 4a008100 */ - u32 cm_clksel_usb_60mhz; /* 4a008104 */ - u32 cm_scale_fclk; /* 4a008108 */ - u32 pad033[1]; /* 4a00810c */ - u32 cm_core_dvfs_perf1; /* 4a008110 */ - u32 cm_core_dvfs_perf2; /* 4a008114 */ - u32 cm_core_dvfs_perf3; /* 4a008118 */ - u32 cm_core_dvfs_perf4; /* 4a00811c */ - u32 pad034[1]; /* 4a008120 */ - u32 cm_core_dvfs_current; /* 4a008124 */ - u32 cm_iva_dvfs_perf_tesla; /* 4a008128 */ - u32 cm_iva_dvfs_perf_ivahd; /* 4a00812c */ - u32 cm_iva_dvfs_perf_abe; /* 4a008130 */ - u32 pad035[1]; /* 4a008134 */ - u32 cm_iva_dvfs_current; /* 4a008138 */ - u32 pad036[1]; /* 4a00813c */ - u32 cm_clkmode_dpll_per; /* 4a008140 */ - u32 cm_idlest_dpll_per; /* 4a008144 */ - u32 cm_autoidle_dpll_per; /* 4a008148 */ - u32 cm_clksel_dpll_per; /* 4a00814c */ - u32 cm_div_m2_dpll_per; /* 4a008150 */ - u32 cm_div_m3_dpll_per; /* 4a008154 */ - u32 cm_div_h11_dpll_per; /* 4a008158 */ - u32 cm_div_h12_dpll_per; /* 4a00815c */ - u32 pad0361[1]; /* 4a008160 */ - u32 cm_div_h14_dpll_per; /* 4a008164 */ - u32 cm_ssc_deltamstep_dpll_per; /* 4a008168 */ - u32 cm_ssc_modfreqdiv_dpll_per; /* 4a00816c */ - u32 cm_emu_override_dpll_per; /* 4a008170 */ - u32 pad037[3]; /* 4a008174 */ - u32 cm_clkmode_dpll_usb; /* 4a008180 */ - u32 cm_idlest_dpll_usb; /* 4a008184 */ - u32 cm_autoidle_dpll_usb; /* 4a008188 */ - u32 cm_clksel_dpll_usb; /* 4a00818c */ - u32 cm_div_m2_dpll_usb; /* 4a008190 */ - u32 pad038[5]; /* 4a008194 */ - u32 cm_ssc_deltamstep_dpll_usb; /* 4a0081a8 */ - u32 cm_ssc_modfreqdiv_dpll_usb; /* 4a0081ac */ - u32 pad039[1]; /* 4a0081b0 */ - u32 cm_clkdcoldo_dpll_usb; /* 4a0081b4 */ - u32 pad040[2]; /* 4a0081b8 */ - u32 cm_clkmode_dpll_unipro; /* 4a0081c0 */ - u32 cm_idlest_dpll_unipro; /* 4a0081c4 */ - u32 cm_autoidle_dpll_unipro; /* 4a0081c8 */ - u32 cm_clksel_dpll_unipro; /* 4a0081cc */ - u32 cm_div_m2_dpll_unipro; /* 4a0081d0 */ - u32 pad041[5]; /* 4a0081d4 */ - u32 cm_ssc_deltamstep_dpll_unipro; /* 4a0081e8 */ - u32 cm_ssc_modfreqdiv_dpll_unipro; /* 4a0081ec */ - - /* cm2.core */ - u32 pad0411[324]; /* 4a0081f0 */ - u32 cm_l3_1_clkstctrl; /* 4a008700 */ - u32 pad042[1]; /* 4a008704 */ - u32 cm_l3_1_dynamicdep; /* 4a008708 */ - u32 pad043[5]; /* 4a00870c */ - u32 cm_l3_1_l3_1_clkctrl; /* 4a008720 */ - u32 pad044[55]; /* 4a008724 */ - u32 cm_l3_2_clkstctrl; /* 4a008800 */ - u32 pad045[1]; /* 4a008804 */ - u32 cm_l3_2_dynamicdep; /* 4a008808 */ - u32 pad046[5]; /* 4a00880c */ - u32 cm_l3_2_l3_2_clkctrl; /* 4a008820 */ - u32 pad047[1]; /* 4a008824 */ - u32 cm_l3_2_gpmc_clkctrl; /* 4a008828 */ - u32 pad048[1]; /* 4a00882c */ - u32 cm_l3_2_ocmc_ram_clkctrl; /* 4a008830 */ - u32 pad049[51]; /* 4a008834 */ - u32 cm_mpu_m3_clkstctrl; /* 4a008900 */ - u32 cm_mpu_m3_staticdep; /* 4a008904 */ - u32 cm_mpu_m3_dynamicdep; /* 4a008908 */ - u32 pad050[5]; /* 4a00890c */ - u32 cm_mpu_m3_mpu_m3_clkctrl; /* 4a008920 */ - u32 pad051[55]; /* 4a008924 */ - u32 cm_sdma_clkstctrl; /* 4a008a00 */ - u32 cm_sdma_staticdep; /* 4a008a04 */ - u32 cm_sdma_dynamicdep; /* 4a008a08 */ - u32 pad052[5]; /* 4a008a0c */ - u32 cm_sdma_sdma_clkctrl; /* 4a008a20 */ - u32 pad053[55]; /* 4a008a24 */ - u32 cm_memif_clkstctrl; /* 4a008b00 */ - u32 pad054[7]; /* 4a008b04 */ - u32 cm_memif_dmm_clkctrl; /* 4a008b20 */ - u32 pad055[1]; /* 4a008b24 */ - u32 cm_memif_emif_fw_clkctrl; /* 4a008b28 */ - u32 pad056[1]; /* 4a008b2c */ - u32 cm_memif_emif_1_clkctrl; /* 4a008b30 */ - u32 pad057[1]; /* 4a008b34 */ - u32 cm_memif_emif_2_clkctrl; /* 4a008b38 */ - u32 pad058[1]; /* 4a008b3c */ - u32 cm_memif_dll_clkctrl; /* 4a008b40 */ - u32 pad059[3]; /* 4a008b44 */ - u32 cm_memif_emif_h1_clkctrl; /* 4a008b50 */ - u32 pad060[1]; /* 4a008b54 */ - u32 cm_memif_emif_h2_clkctrl; /* 4a008b58 */ - u32 pad061[1]; /* 4a008b5c */ - u32 cm_memif_dll_h_clkctrl; /* 4a008b60 */ - u32 pad062[39]; /* 4a008b64 */ - u32 cm_c2c_clkstctrl; /* 4a008c00 */ - u32 cm_c2c_staticdep; /* 4a008c04 */ - u32 cm_c2c_dynamicdep; /* 4a008c08 */ - u32 pad063[5]; /* 4a008c0c */ - u32 cm_c2c_sad2d_clkctrl; /* 4a008c20 */ - u32 pad064[1]; /* 4a008c24 */ - u32 cm_c2c_modem_icr_clkctrl; /* 4a008c28 */ - u32 pad065[1]; /* 4a008c2c */ - u32 cm_c2c_sad2d_fw_clkctrl; /* 4a008c30 */ - u32 pad066[51]; /* 4a008c34 */ - u32 cm_l4cfg_clkstctrl; /* 4a008d00 */ - u32 pad067[1]; /* 4a008d04 */ - u32 cm_l4cfg_dynamicdep; /* 4a008d08 */ - u32 pad068[5]; /* 4a008d0c */ - u32 cm_l4cfg_l4_cfg_clkctrl; /* 4a008d20 */ - u32 pad069[1]; /* 4a008d24 */ - u32 cm_l4cfg_hw_sem_clkctrl; /* 4a008d28 */ - u32 pad070[1]; /* 4a008d2c */ - u32 cm_l4cfg_mailbox_clkctrl; /* 4a008d30 */ - u32 pad071[1]; /* 4a008d34 */ - u32 cm_l4cfg_sar_rom_clkctrl; /* 4a008d38 */ - u32 pad072[49]; /* 4a008d3c */ - u32 cm_l3instr_clkstctrl; /* 4a008e00 */ - u32 pad073[7]; /* 4a008e04 */ - u32 cm_l3instr_l3_3_clkctrl; /* 4a008e20 */ - u32 pad074[1]; /* 4a008e24 */ - u32 cm_l3instr_l3_instr_clkctrl; /* 4a008e28 */ - u32 pad075[5]; /* 4a008e2c */ - u32 cm_l3instr_intrconn_wp1_clkctrl; /* 4a008e40 */ - - - /* cm2.ivahd */ - u32 pad076[47]; /* 4a008e44 */ - u32 cm_ivahd_clkstctrl; /* 4a008f00 */ - u32 pad077[7]; /* 4a008f04 */ - u32 cm_ivahd_ivahd_clkctrl; /* 4a008f20 */ - u32 pad078[1]; /* 4a008f24 */ - u32 cm_ivahd_sl2_clkctrl; /* 4a008f28 */ - - /* cm2.cam */ - u32 pad079[53]; /* 4a008f2c */ - u32 cm_cam_clkstctrl; /* 4a009000 */ - u32 pad080[7]; /* 4a009004 */ - u32 cm_cam_iss_clkctrl; /* 4a009020 */ - u32 pad081[1]; /* 4a009024 */ - u32 cm_cam_fdif_clkctrl; /* 4a009028 */ - - /* cm2.dss */ - u32 pad082[53]; /* 4a00902c */ - u32 cm_dss_clkstctrl; /* 4a009100 */ - u32 pad083[7]; /* 4a009104 */ - u32 cm_dss_dss_clkctrl; /* 4a009120 */ - - /* cm2.sgx */ - u32 pad084[55]; /* 4a009124 */ - u32 cm_sgx_clkstctrl; /* 4a009200 */ - u32 pad085[7]; /* 4a009204 */ - u32 cm_sgx_sgx_clkctrl; /* 4a009220 */ - - /* cm2.l3init */ - u32 pad086[55]; /* 4a009224 */ - u32 cm_l3init_clkstctrl; /* 4a009300 */ - - /* cm2.l3init */ - u32 pad087[9]; /* 4a009304 */ - u32 cm_l3init_hsmmc1_clkctrl; /* 4a009328 */ - u32 pad088[1]; /* 4a00932c */ - u32 cm_l3init_hsmmc2_clkctrl; /* 4a009330 */ - u32 pad089[1]; /* 4a009334 */ - u32 cm_l3init_hsi_clkctrl; /* 4a009338 */ - u32 pad090[7]; /* 4a00933c */ - u32 cm_l3init_hsusbhost_clkctrl; /* 4a009358 */ - u32 pad091[1]; /* 4a00935c */ - u32 cm_l3init_hsusbotg_clkctrl; /* 4a009360 */ - u32 pad092[1]; /* 4a009364 */ - u32 cm_l3init_hsusbtll_clkctrl; /* 4a009368 */ - u32 pad093[3]; /* 4a00936c */ - u32 cm_l3init_p1500_clkctrl; /* 4a009378 */ - u32 pad094[21]; /* 4a00937c */ - u32 cm_l3init_fsusb_clkctrl; /* 4a0093d0 */ - u32 pad095[3]; /* 4a0093d4 */ - u32 cm_l3init_ocp2scp1_clkctrl; - - /* cm2.l4per */ - u32 pad096[7]; /* 4a0093e4 */ - u32 cm_l4per_clkstctrl; /* 4a009400 */ - u32 pad097[1]; /* 4a009404 */ - u32 cm_l4per_dynamicdep; /* 4a009408 */ - u32 pad098[5]; /* 4a00940c */ - u32 cm_l4per_adc_clkctrl; /* 4a009420 */ - u32 pad100[1]; /* 4a009424 */ - u32 cm_l4per_gptimer10_clkctrl; /* 4a009428 */ - u32 pad101[1]; /* 4a00942c */ - u32 cm_l4per_gptimer11_clkctrl; /* 4a009430 */ - u32 pad102[1]; /* 4a009434 */ - u32 cm_l4per_gptimer2_clkctrl; /* 4a009438 */ - u32 pad103[1]; /* 4a00943c */ - u32 cm_l4per_gptimer3_clkctrl; /* 4a009440 */ - u32 pad104[1]; /* 4a009444 */ - u32 cm_l4per_gptimer4_clkctrl; /* 4a009448 */ - u32 pad105[1]; /* 4a00944c */ - u32 cm_l4per_gptimer9_clkctrl; /* 4a009450 */ - u32 pad106[1]; /* 4a009454 */ - u32 cm_l4per_elm_clkctrl; /* 4a009458 */ - u32 pad107[1]; /* 4a00945c */ - u32 cm_l4per_gpio2_clkctrl; /* 4a009460 */ - u32 pad108[1]; /* 4a009464 */ - u32 cm_l4per_gpio3_clkctrl; /* 4a009468 */ - u32 pad109[1]; /* 4a00946c */ - u32 cm_l4per_gpio4_clkctrl; /* 4a009470 */ - u32 pad110[1]; /* 4a009474 */ - u32 cm_l4per_gpio5_clkctrl; /* 4a009478 */ - u32 pad111[1]; /* 4a00947c */ - u32 cm_l4per_gpio6_clkctrl; /* 4a009480 */ - u32 pad112[1]; /* 4a009484 */ - u32 cm_l4per_hdq1w_clkctrl; /* 4a009488 */ - u32 pad113[1]; /* 4a00948c */ - u32 cm_l4per_hecc1_clkctrl; /* 4a009490 */ - u32 pad114[1]; /* 4a009494 */ - u32 cm_l4per_hecc2_clkctrl; /* 4a009498 */ - u32 pad115[1]; /* 4a00949c */ - u32 cm_l4per_i2c1_clkctrl; /* 4a0094a0 */ - u32 pad116[1]; /* 4a0094a4 */ - u32 cm_l4per_i2c2_clkctrl; /* 4a0094a8 */ - u32 pad117[1]; /* 4a0094ac */ - u32 cm_l4per_i2c3_clkctrl; /* 4a0094b0 */ - u32 pad118[1]; /* 4a0094b4 */ - u32 cm_l4per_i2c4_clkctrl; /* 4a0094b8 */ - u32 pad119[1]; /* 4a0094bc */ - u32 cm_l4per_l4per_clkctrl; /* 4a0094c0 */ - u32 pad1191[3]; /* 4a0094c4 */ - u32 cm_l4per_mcasp2_clkctrl; /* 4a0094d0 */ - u32 pad120[1]; /* 4a0094d4 */ - u32 cm_l4per_mcasp3_clkctrl; /* 4a0094d8 */ - u32 pad121[3]; /* 4a0094dc */ - u32 cm_l4per_mgate_clkctrl; /* 4a0094e8 */ - u32 pad123[1]; /* 4a0094ec */ - u32 cm_l4per_mcspi1_clkctrl; /* 4a0094f0 */ - u32 pad124[1]; /* 4a0094f4 */ - u32 cm_l4per_mcspi2_clkctrl; /* 4a0094f8 */ - u32 pad125[1]; /* 4a0094fc */ - u32 cm_l4per_mcspi3_clkctrl; /* 4a009500 */ - u32 pad126[1]; /* 4a009504 */ - u32 cm_l4per_mcspi4_clkctrl; /* 4a009508 */ - u32 pad127[1]; /* 4a00950c */ - u32 cm_l4per_gpio7_clkctrl; /* 4a009510 */ - u32 pad1271[1]; /* 4a009514 */ - u32 cm_l4per_gpio8_clkctrl; /* 4a009518 */ - u32 pad1272[1]; /* 4a00951c */ - u32 cm_l4per_mmcsd3_clkctrl; /* 4a009520 */ - u32 pad128[1]; /* 4a009524 */ - u32 cm_l4per_mmcsd4_clkctrl; /* 4a009528 */ - u32 pad129[1]; /* 4a00952c */ - u32 cm_l4per_msprohg_clkctrl; /* 4a009530 */ - u32 pad130[1]; /* 4a009534 */ - u32 cm_l4per_slimbus2_clkctrl; /* 4a009538 */ - u32 pad131[1]; /* 4a00953c */ - u32 cm_l4per_uart1_clkctrl; /* 4a009540 */ - u32 pad132[1]; /* 4a009544 */ - u32 cm_l4per_uart2_clkctrl; /* 4a009548 */ - u32 pad133[1]; /* 4a00954c */ - u32 cm_l4per_uart3_clkctrl; /* 4a009550 */ - u32 pad134[1]; /* 4a009554 */ - u32 cm_l4per_uart4_clkctrl; /* 4a009558 */ - u32 pad135[1]; /* 4a00955c */ - u32 cm_l4per_mmcsd5_clkctrl; /* 4a009560 */ - u32 pad136[1]; /* 4a009564 */ - u32 cm_l4per_i2c5_clkctrl; /* 4a009568 */ - u32 pad1371[1]; /* 4a00956c */ - u32 cm_l4per_uart5_clkctrl; /* 4a009570 */ - u32 pad1372[1]; /* 4a009574 */ - u32 cm_l4per_uart6_clkctrl; /* 4a009578 */ - u32 pad1374[1]; /* 4a00957c */ - u32 cm_l4sec_clkstctrl; /* 4a009580 */ - u32 cm_l4sec_staticdep; /* 4a009584 */ - u32 cm_l4sec_dynamicdep; /* 4a009588 */ - u32 pad138[5]; /* 4a00958c */ - u32 cm_l4sec_aes1_clkctrl; /* 4a0095a0 */ - u32 pad139[1]; /* 4a0095a4 */ - u32 cm_l4sec_aes2_clkctrl; /* 4a0095a8 */ - u32 pad140[1]; /* 4a0095ac */ - u32 cm_l4sec_des3des_clkctrl; /* 4a0095b0 */ - u32 pad141[1]; /* 4a0095b4 */ - u32 cm_l4sec_pkaeip29_clkctrl; /* 4a0095b8 */ - u32 pad142[1]; /* 4a0095bc */ - u32 cm_l4sec_rng_clkctrl; /* 4a0095c0 */ - u32 pad143[1]; /* 4a0095c4 */ - u32 cm_l4sec_sha2md51_clkctrl; /* 4a0095c8 */ - u32 pad144[3]; /* 4a0095cc */ - u32 cm_l4sec_cryptodma_clkctrl; /* 4a0095d8 */ - u32 pad145[3660425]; /* 4a0095dc */ - - /* l4 wkup regs */ - u32 pad201[6211]; /* 4ae00000 */ - u32 cm_abe_pll_ref_clksel; /* 4ae0610c */ - u32 cm_sys_clksel; /* 4ae06110 */ - u32 pad202[1467]; /* 4ae06114 */ - u32 cm_wkup_clkstctrl; /* 4ae07800 */ - u32 pad203[7]; /* 4ae07804 */ - u32 cm_wkup_l4wkup_clkctrl; /* 4ae07820 */ - u32 pad204; /* 4ae07824 */ - u32 cm_wkup_wdtimer1_clkctrl; /* 4ae07828 */ - u32 pad205; /* 4ae0782c */ - u32 cm_wkup_wdtimer2_clkctrl; /* 4ae07830 */ - u32 pad206; /* 4ae07834 */ - u32 cm_wkup_gpio1_clkctrl; /* 4ae07838 */ - u32 pad207; /* 4ae0783c */ - u32 cm_wkup_gptimer1_clkctrl; /* 4ae07840 */ - u32 pad208; /* 4ae07844 */ - u32 cm_wkup_gptimer12_clkctrl; /* 4ae07848 */ - u32 pad209; /* 4ae0784c */ - u32 cm_wkup_synctimer_clkctrl; /* 4ae07850 */ - u32 pad210; /* 4ae07854 */ - u32 cm_wkup_usim_clkctrl; /* 4ae07858 */ - u32 pad211; /* 4ae0785c */ - u32 cm_wkup_sarram_clkctrl; /* 4ae07860 */ - u32 pad212[5]; /* 4ae07864 */ - u32 cm_wkup_keyboard_clkctrl; /* 4ae07878 */ - u32 pad213; /* 4ae0787c */ - u32 cm_wkup_rtc_clkctrl; /* 4ae07880 */ - u32 pad214; /* 4ae07884 */ - u32 cm_wkup_bandgap_clkctrl; /* 4ae07888 */ - u32 pad215[1]; /* 4ae0788c */ - u32 cm_wkupaon_scrm_clkctrl; /* 4ae07890 */ - u32 pad216[195]; - u32 prm_vc_val_bypass; /* 4ae07ba0 */ - u32 pad217[4]; - u32 prm_vc_cfg_i2c_mode; /* 4ae07bb4 */ - u32 prm_vc_cfg_i2c_clk; /* 4ae07bb8 */ - u32 pad218[2]; - u32 prm_sldo_core_setup; /* 4ae07bc4 */ - u32 prm_sldo_core_ctrl; /* 4ae07bc8 */ - u32 prm_sldo_mpu_setup; /* 4ae07bcc */ - u32 prm_sldo_mpu_ctrl; /* 4ae07bd0 */ - u32 prm_sldo_mm_setup; /* 4ae07bd4 */ - u32 prm_sldo_mm_ctrl; /* 4ae07bd8 */ -}; - /* DPLL register offsets */ #define CM_CLKMODE_DPLL 0 #define CM_IDLEST_DPLL 0x4 @@ -715,7 +266,6 @@ struct dpll_params { s8 h23; };
-extern struct omap5_prcm_regs *const prcm; extern const u32 sys_clk_array[8];
void scale_vcores(void); @@ -723,14 +273,14 @@ void do_scale_tps62361(int gpio, u32 reg, u32 volt_mv); u32 get_offset_code(u32 offset); u32 omap_ddr_clk(void); void do_scale_vcore(u32 vcore_reg, u32 volt_mv); -void setup_post_dividers(u32 *const base, const struct dpll_params *params); +void setup_post_dividers(u32 const base, const struct dpll_params *params); u32 get_sys_clk_index(void); void enable_basic_clocks(void); void enable_non_essential_clocks(void); void enable_basic_uboot_clocks(void); -void do_enable_clocks(u32 *const *clk_domains, - u32 *const *clk_modules_hw_auto, - u32 *const *clk_modules_explicit_en, +void do_enable_clocks(u32 const *clk_domains, + u32 const *clk_modules_hw_auto, + u32 const *clk_modules_explicit_en, u8 wait_for_enable); const struct dpll_params *get_mpu_dpll_params(void); const struct dpll_params *get_core_dpll_params(void); diff --git a/arch/arm/include/asm/arch-omap5/omap.h b/arch/arm/include/asm/arch-omap5/omap.h index 9dce49a..50e055e 100644 --- a/arch/arm/include/asm/arch-omap5/omap.h +++ b/arch/arm/include/asm/arch-omap5/omap.h @@ -271,7 +271,8 @@ struct omap_sys_ctrl_regs { #define OMAP5_SRAM_SCRATCH_EMIF_SIZE (SRAM_SCRATCH_SPACE_ADDR + 0x4) #define OMAP5_SRAM_SCRATCH_EMIF_T_NUM (SRAM_SCRATCH_SPACE_ADDR + 0xC) #define OMAP5_SRAM_SCRATCH_EMIF_T_DEN (SRAM_SCRATCH_SPACE_ADDR + 0x10) -#define OMAP5_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x14) +#define OMAP_SRAM_SCRATCH_PRCM_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x14) +#define OMAP5_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x18)
/* Silicon revisions */ #define OMAP4430_SILICON_ID_INVALID 0xFFFFFFFF diff --git a/arch/arm/include/asm/arch-omap5/sys_proto.h b/arch/arm/include/asm/arch-omap5/sys_proto.h index 72e9df7..2b3a071 100644 --- a/arch/arm/include/asm/arch-omap5/sys_proto.h +++ b/arch/arm/include/asm/arch-omap5/sys_proto.h @@ -44,7 +44,7 @@ u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); void setup_clocks_for_console(void); void prcm_init(void); -void bypass_dpll(u32 *const base); +void bypass_dpll(u32 const base); void freq_update_core(void); u32 get_sys_clk_freq(void); u32 omap5_ddr_clk(void); diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 2a40b89..fcf9ce5 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -25,6 +25,310 @@ #ifndef _OMAP_COMMON_H_ #define _OMAP_COMMON_H_
+#include <common.h> + +struct prcm_regs { + /* cm1.ckgen */ + u32 cm_clksel_core; + u32 cm_clksel_abe; + u32 cm_dll_ctrl; + u32 cm_clkmode_dpll_core; + u32 cm_idlest_dpll_core; + u32 cm_autoidle_dpll_core; + u32 cm_clksel_dpll_core; + u32 cm_div_m2_dpll_core; + u32 cm_div_m3_dpll_core; + u32 cm_div_h11_dpll_core; + u32 cm_div_h12_dpll_core; + u32 cm_div_h13_dpll_core; + u32 cm_div_h14_dpll_core; + u32 cm_ssc_deltamstep_dpll_core; + u32 cm_ssc_modfreqdiv_dpll_core; + u32 cm_emu_override_dpll_core; + u32 cm_div_h22_dpllcore; + u32 cm_div_h23_dpll_core; + u32 cm_clkmode_dpll_mpu; + u32 cm_idlest_dpll_mpu; + u32 cm_autoidle_dpll_mpu; + u32 cm_clksel_dpll_mpu; + u32 cm_div_m2_dpll_mpu; + u32 cm_ssc_deltamstep_dpll_mpu; + u32 cm_ssc_modfreqdiv_dpll_mpu; + u32 cm_bypclk_dpll_mpu; + u32 cm_clkmode_dpll_iva; + u32 cm_idlest_dpll_iva; + u32 cm_autoidle_dpll_iva; + u32 cm_clksel_dpll_iva; + u32 cm_div_h11_dpll_iva; + u32 cm_div_h12_dpll_iva; + u32 cm_ssc_deltamstep_dpll_iva; + u32 cm_ssc_modfreqdiv_dpll_iva; + u32 cm_bypclk_dpll_iva; + u32 cm_clkmode_dpll_abe; + u32 cm_idlest_dpll_abe; + u32 cm_autoidle_dpll_abe; + u32 cm_clksel_dpll_abe; + u32 cm_div_m2_dpll_abe; + u32 cm_div_m3_dpll_abe; + u32 cm_ssc_deltamstep_dpll_abe; + u32 cm_ssc_modfreqdiv_dpll_abe; + u32 cm_clkmode_dpll_ddrphy; + u32 cm_idlest_dpll_ddrphy; + u32 cm_autoidle_dpll_ddrphy; + u32 cm_clksel_dpll_ddrphy; + u32 cm_div_m2_dpll_ddrphy; + u32 cm_div_h11_dpll_ddrphy; + u32 cm_div_h12_dpll_ddrphy; + u32 cm_div_h13_dpll_ddrphy; + u32 cm_ssc_deltamstep_dpll_ddrphy; + u32 cm_shadow_freq_config1; + u32 cm_mpu_mpu_clkctrl; + + /* cm1.dsp */ + u32 cm_dsp_clkstctrl; + u32 cm_dsp_dsp_clkctrl; + + /* cm1.abe */ + u32 cm1_abe_clkstctrl; + u32 cm1_abe_l4abe_clkctrl; + u32 cm1_abe_aess_clkctrl; + u32 cm1_abe_pdm_clkctrl; + u32 cm1_abe_dmic_clkctrl; + u32 cm1_abe_mcasp_clkctrl; + u32 cm1_abe_mcbsp1_clkctrl; + u32 cm1_abe_mcbsp2_clkctrl; + u32 cm1_abe_mcbsp3_clkctrl; + u32 cm1_abe_slimbus_clkctrl; + u32 cm1_abe_timer5_clkctrl; + u32 cm1_abe_timer6_clkctrl; + u32 cm1_abe_timer7_clkctrl; + u32 cm1_abe_timer8_clkctrl; + u32 cm1_abe_wdt3_clkctrl; + + /* cm2.ckgen */ + u32 cm_clksel_mpu_m3_iss_root; + u32 cm_clksel_usb_60mhz; + u32 cm_scale_fclk; + u32 cm_core_dvfs_perf1; + u32 cm_core_dvfs_perf2; + u32 cm_core_dvfs_perf3; + u32 cm_core_dvfs_perf4; + u32 cm_core_dvfs_current; + u32 cm_iva_dvfs_perf_tesla; + u32 cm_iva_dvfs_perf_ivahd; + u32 cm_iva_dvfs_perf_abe; + u32 cm_iva_dvfs_current; + u32 cm_clkmode_dpll_per; + u32 cm_idlest_dpll_per; + u32 cm_autoidle_dpll_per; + u32 cm_clksel_dpll_per; + u32 cm_div_m2_dpll_per; + u32 cm_div_m3_dpll_per; + u32 cm_div_h11_dpll_per; + u32 cm_div_h12_dpll_per; + u32 cm_div_h14_dpll_per; + u32 cm_ssc_deltamstep_dpll_per; + u32 cm_ssc_modfreqdiv_dpll_per; + u32 cm_emu_override_dpll_per; + u32 cm_clkmode_dpll_usb; + u32 cm_idlest_dpll_usb; + u32 cm_autoidle_dpll_usb; + u32 cm_clksel_dpll_usb; + u32 cm_div_m2_dpll_usb; + u32 cm_ssc_deltamstep_dpll_usb; + u32 cm_ssc_modfreqdiv_dpll_usb; + u32 cm_clkdcoldo_dpll_usb; + u32 cm_clkmode_dpll_unipro; + u32 cm_idlest_dpll_unipro; + u32 cm_autoidle_dpll_unipro; + u32 cm_clksel_dpll_unipro; + u32 cm_div_m2_dpll_unipro; + u32 cm_ssc_deltamstep_dpll_unipro; + u32 cm_ssc_modfreqdiv_dpll_unipro; + + /* cm2.core */ + u32 cm_coreaon_bandgap_clkctrl; + u32 cm_l3_1_clkstctrl; + u32 cm_l3_1_dynamicdep; + u32 cm_l3_1_l3_1_clkctrl; + u32 cm_l3_2_clkstctrl; + u32 cm_l3_2_dynamicdep; + u32 cm_l3_2_l3_2_clkctrl; + u32 cm_l3_2_gpmc_clkctrl; + u32 cm_l3_2_ocmc_ram_clkctrl; + u32 cm_mpu_m3_clkstctrl; + u32 cm_mpu_m3_staticdep; + u32 cm_mpu_m3_dynamicdep; + u32 cm_mpu_m3_mpu_m3_clkctrl; + u32 cm_sdma_clkstctrl; + u32 cm_sdma_staticdep; + u32 cm_sdma_dynamicdep; + u32 cm_sdma_sdma_clkctrl; + u32 cm_memif_clkstctrl; + u32 cm_memif_dmm_clkctrl; + u32 cm_memif_emif_fw_clkctrl; + u32 cm_memif_emif_1_clkctrl; + u32 cm_memif_emif_2_clkctrl; + u32 cm_memif_dll_clkctrl; + u32 cm_memif_emif_h1_clkctrl; + u32 cm_memif_emif_h2_clkctrl; + u32 cm_memif_dll_h_clkctrl; + u32 cm_c2c_clkstctrl; + u32 cm_c2c_staticdep; + u32 cm_c2c_dynamicdep; + u32 cm_c2c_sad2d_clkctrl; + u32 cm_c2c_modem_icr_clkctrl; + u32 cm_c2c_sad2d_fw_clkctrl; + u32 cm_l4cfg_clkstctrl; + u32 cm_l4cfg_dynamicdep; + u32 cm_l4cfg_l4_cfg_clkctrl; + u32 cm_l4cfg_hw_sem_clkctrl; + u32 cm_l4cfg_mailbox_clkctrl; + u32 cm_l4cfg_sar_rom_clkctrl; + u32 cm_l3instr_clkstctrl; + u32 cm_l3instr_l3_3_clkctrl; + u32 cm_l3instr_l3_instr_clkctrl; + u32 cm_l3instr_intrconn_wp1_clkctrl; + + /* cm2.ivahd */ + u32 cm_ivahd_clkstctrl; + u32 cm_ivahd_ivahd_clkctrl; + u32 cm_ivahd_sl2_clkctrl; + + /* cm2.cam */ + u32 cm_cam_clkstctrl; + u32 cm_cam_iss_clkctrl; + u32 cm_cam_fdif_clkctrl; + + /* cm2.dss */ + u32 cm_dss_clkstctrl; + u32 cm_dss_dss_clkctrl; + + /* cm2.sgx */ + u32 cm_sgx_clkstctrl; + u32 cm_sgx_sgx_clkctrl; + + /* cm2.l3init */ + u32 cm_l3init_clkstctrl; + + /* cm2.l3init */ + u32 cm_l3init_hsmmc1_clkctrl; + u32 cm_l3init_hsmmc2_clkctrl; + u32 cm_l3init_hsi_clkctrl; + u32 cm_l3init_hsusbhost_clkctrl; + u32 cm_l3init_hsusbotg_clkctrl; + u32 cm_l3init_hsusbtll_clkctrl; + u32 cm_l3init_p1500_clkctrl; + u32 cm_l3init_fsusb_clkctrl; + u32 cm_l3init_ocp2scp1_clkctrl; + + /* cm2.l4per */ + u32 cm_l4per_clkstctrl; + u32 cm_l4per_dynamicdep; + u32 cm_l4per_adc_clkctrl; + u32 cm_l4per_gptimer10_clkctrl; + u32 cm_l4per_gptimer11_clkctrl; + u32 cm_l4per_gptimer2_clkctrl; + u32 cm_l4per_gptimer3_clkctrl; + u32 cm_l4per_gptimer4_clkctrl; + u32 cm_l4per_gptimer9_clkctrl; + u32 cm_l4per_elm_clkctrl; + u32 cm_l4per_gpio2_clkctrl; + u32 cm_l4per_gpio3_clkctrl; + u32 cm_l4per_gpio4_clkctrl; + u32 cm_l4per_gpio5_clkctrl; + u32 cm_l4per_gpio6_clkctrl; + u32 cm_l4per_hdq1w_clkctrl; + u32 cm_l4per_hecc1_clkctrl; + u32 cm_l4per_hecc2_clkctrl; + u32 cm_l4per_i2c1_clkctrl; + u32 cm_l4per_i2c2_clkctrl; + u32 cm_l4per_i2c3_clkctrl; + u32 cm_l4per_i2c4_clkctrl; + u32 cm_l4per_l4per_clkctrl; + u32 cm_l4per_mcasp2_clkctrl; + u32 cm_l4per_mcasp3_clkctrl; + u32 cm_l4per_mgate_clkctrl; + u32 cm_l4per_mcspi1_clkctrl; + u32 cm_l4per_mcspi2_clkctrl; + u32 cm_l4per_mcspi3_clkctrl; + u32 cm_l4per_mcspi4_clkctrl; + u32 cm_l4per_gpio7_clkctrl; + u32 cm_l4per_gpio8_clkctrl; + u32 cm_l4per_mmcsd3_clkctrl; + u32 cm_l4per_mmcsd4_clkctrl; + u32 cm_l4per_msprohg_clkctrl; + u32 cm_l4per_slimbus2_clkctrl; + u32 cm_l4per_uart1_clkctrl; + u32 cm_l4per_uart2_clkctrl; + u32 cm_l4per_uart3_clkctrl; + u32 cm_l4per_uart4_clkctrl; + u32 cm_l4per_mmcsd5_clkctrl; + u32 cm_l4per_i2c5_clkctrl; + u32 cm_l4per_uart5_clkctrl; + u32 cm_l4per_uart6_clkctrl; + u32 cm_l4sec_clkstctrl; + u32 cm_l4sec_staticdep; + u32 cm_l4sec_dynamicdep; + u32 cm_l4sec_aes1_clkctrl; + u32 cm_l4sec_aes2_clkctrl; + u32 cm_l4sec_des3des_clkctrl; + u32 cm_l4sec_pkaeip29_clkctrl; + u32 cm_l4sec_rng_clkctrl; + u32 cm_l4sec_sha2md51_clkctrl; + u32 cm_l4sec_cryptodma_clkctrl; + + /* l4 wkup regs */ + u32 cm_abe_pll_ref_clksel; + u32 cm_sys_clksel; + u32 cm_wkup_clkstctrl; + u32 cm_wkup_l4wkup_clkctrl; + u32 cm_wkup_wdtimer1_clkctrl; + u32 cm_wkup_wdtimer2_clkctrl; + u32 cm_wkup_gpio1_clkctrl; + u32 cm_wkup_gptimer1_clkctrl; + u32 cm_wkup_gptimer12_clkctrl; + u32 cm_wkup_synctimer_clkctrl; + u32 cm_wkup_usim_clkctrl; + u32 cm_wkup_sarram_clkctrl; + u32 cm_wkup_keyboard_clkctrl; + u32 cm_wkup_rtc_clkctrl; + u32 cm_wkup_bandgap_clkctrl; + u32 cm_wkupaon_scrm_clkctrl; + u32 prm_vc_val_bypass; + u32 prm_vc_cfg_i2c_mode; + u32 prm_vc_cfg_i2c_clk; + u32 prm_sldo_core_setup; + u32 prm_sldo_core_ctrl; + u32 prm_sldo_mpu_setup; + u32 prm_sldo_mpu_ctrl; + u32 prm_sldo_mm_setup; + u32 prm_sldo_mm_ctrl; + + u32 cm_div_m4_dpll_core; + u32 cm_div_m5_dpll_core; + u32 cm_div_m6_dpll_core; + u32 cm_div_m7_dpll_core; + u32 cm_div_m4_dpll_iva; + u32 cm_div_m5_dpll_iva; + u32 cm_div_m4_dpll_ddrphy; + u32 cm_div_m5_dpll_ddrphy; + u32 cm_div_m6_dpll_ddrphy; + u32 cm_div_m4_dpll_per; + u32 cm_div_m5_dpll_per; + u32 cm_div_m6_dpll_per; + u32 cm_div_m7_dpll_per; + u32 cm_l3instr_intrconn_wp1_clkct; + u32 cm_l3init_usbphy_clkctrl; + u32 cm_l4per_mcbsp4_clkctrl; + u32 prm_vc_cfg_channel; +}; + +extern struct prcm_regs const **prcm; +extern struct prcm_regs const omap5_es1_prcm; +extern struct prcm_regs const omap4_prcm; + +void hw_data_init(void); /* Max value for DPLL multiplier M */ #define OMAP_DPLL_MAX_N 127
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
On 02/04/2013 09:22 AM, R Sricharan wrote:
The current PRCM structure prototype directly matches the hardware register layout. So there is a need to change this for every new silicon revision which has register space changes.
Avoiding this by making the prototye generic and populating the register addresses seperately for all Socs.
Signed-off-by: R Sricharan r.sricharan@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com
Reviewed-by: Tom Rini trini@ti.com
- -- Tom
Currently there is quite a lot of code which is duplicated in the clocks code for OMAP 4 and 5 Socs. Avoiding this here by moving the clocks data to a SOC specific place and the sharing the common code.
This helps in addition of a new Soc with minimal changes.
Signed-off-by: R Sricharan r.sricharan@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- [V2] Addressed Tom Rini's trini@ti.com comments
arch/arm/cpu/armv7/omap-common/clocks-common.c | 89 +++++- arch/arm/cpu/armv7/omap4/clocks.c | 393 ----------------------- arch/arm/cpu/armv7/omap4/hw_data.c | 367 +++++++++++++++++++++- arch/arm/cpu/armv7/omap5/clocks.c | 396 ------------------------ arch/arm/cpu/armv7/omap5/hw_data.c | 355 +++++++++++++++++++++ arch/arm/include/asm/arch-omap4/clocks.h | 45 --- arch/arm/include/asm/arch-omap4/omap.h | 3 +- arch/arm/include/asm/arch-omap5/clocks.h | 50 --- arch/arm/include/asm/arch-omap5/omap.h | 3 +- arch/arm/include/asm/omap_common.h | 63 ++++ 10 files changed, 869 insertions(+), 895 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/clocks-common.c b/arch/arm/cpu/armv7/omap-common/clocks-common.c index d36fccc..2becc4a 100644 --- a/arch/arm/cpu/armv7/omap-common/clocks-common.c +++ b/arch/arm/cpu/armv7/omap-common/clocks-common.c @@ -47,6 +47,16 @@ #define puts(s) #endif
+const u32 sys_clk_array[8] = { + 12000000, /* 12 MHz */ + 13000000, /* 13 MHz */ + 16800000, /* 16.8 MHz */ + 19200000, /* 19.2 MHz */ + 26000000, /* 26 MHz */ + 27000000, /* 27 MHz */ + 38400000, /* 38.4 MHz */ +}; + static inline u32 __get_sys_clk_index(void) { u32 ind; @@ -76,6 +86,29 @@ u32 get_sys_clk_freq(void) return sys_clk_array[index]; }
+void setup_post_dividers(u32 const base, const struct dpll_params *params) +{ + struct dpll_regs *const dpll_regs = (struct dpll_regs *)base; + + /* Setup post-dividers */ + if (params->m2 >= 0) + writel(params->m2, &dpll_regs->cm_div_m2_dpll); + if (params->m3 >= 0) + writel(params->m3, &dpll_regs->cm_div_m3_dpll); + if (params->m4_h11 >= 0) + writel(params->m4_h11, &dpll_regs->cm_div_m4_h11_dpll); + if (params->m5_h12 >= 0) + writel(params->m5_h12, &dpll_regs->cm_div_m5_h12_dpll); + if (params->m6_h13 >= 0) + writel(params->m6_h13, &dpll_regs->cm_div_m6_h13_dpll); + if (params->m7_h14 >= 0) + writel(params->m7_h14, &dpll_regs->cm_div_m7_h14_dpll); + if (params->h22 >= 0) + writel(params->h22, &dpll_regs->cm_div_h22_dpll); + if (params->h23 >= 0) + writel(params->h23, &dpll_regs->cm_div_h23_dpll); +} + static inline void do_bypass_dpll(u32 const base) { struct dpll_regs *dpll_regs = (struct dpll_regs *)base; @@ -124,6 +157,46 @@ inline u32 check_for_lock(u32 const base) return lock; }
+const struct dpll_params *get_mpu_dpll_params(struct dplls const *dpll_data) +{ + u32 sysclk_ind = get_sys_clk_index(); + return &dpll_data->mpu[sysclk_ind]; +} + +const struct dpll_params *get_core_dpll_params(struct dplls const *dpll_data) +{ + u32 sysclk_ind = get_sys_clk_index(); + return &dpll_data->core[sysclk_ind]; +} + +const struct dpll_params *get_per_dpll_params(struct dplls const *dpll_data) +{ + u32 sysclk_ind = get_sys_clk_index(); + return &dpll_data->per[sysclk_ind]; +} + +const struct dpll_params *get_iva_dpll_params(struct dplls const *dpll_data) +{ + u32 sysclk_ind = get_sys_clk_index(); + return &dpll_data->iva[sysclk_ind]; +} + +const struct dpll_params *get_usb_dpll_params(struct dplls const *dpll_data) +{ + u32 sysclk_ind = get_sys_clk_index(); + return &dpll_data->usb[sysclk_ind]; +} + +const struct dpll_params *get_abe_dpll_params(struct dplls const *dpll_data) +{ +#ifdef CONFIG_SYS_OMAP_ABE_SYSCK + u32 sysclk_ind = get_sys_clk_index(); + return &dpll_data->abe[sysclk_ind]; +#else + return dpll_data->abe; +#endif +} + static void do_setup_dpll(u32 const base, const struct dpll_params *params, u8 lock, char *dpll) { @@ -184,7 +257,7 @@ u32 omap_ddr_clk(void) omap_rev = omap_revision(); sys_clk_khz = get_sys_clk_freq() / 1000;
- core_dpll_params = get_core_dpll_params(); + core_dpll_params = get_core_dpll_params(*dplls_data);
debug("sys_clk %d\n ", sys_clk_khz * 1000);
@@ -251,7 +324,7 @@ void configure_mpu_dpll(void) setbits_le32((*prcm)->cm_mpu_mpu_clkctrl, MPU_CLKCTRL_CLKSEL_ABE_DIV_MODE_MASK);
- params = get_mpu_dpll_params(); + params = get_mpu_dpll_params(*dplls_data);
do_setup_dpll((*prcm)->cm_clkmode_dpll_mpu, params, DPLL_LOCK, "mpu"); debug("MPU DPLL locked\n"); @@ -272,7 +345,7 @@ static void setup_usb_dpll(void) * Use CLKINP in KHz and adjust the denominator accordingly so * that we have enough accuracy and at the same time no overflow */ - params = get_usb_dpll_params(); + params = get_usb_dpll_params(*dplls_data); num = params->m * sys_clk_khz; den = (params->n + 1) * 250 * 1000; num += den - 1; @@ -294,7 +367,7 @@ static void setup_dplls(void) debug("setup_dplls\n");
/* CORE dpll */ - params = get_core_dpll_params(); /* default - safest */ + params = get_core_dpll_params(*dplls_data); /* default - safest */ /* * Do not lock the core DPLL now. Just set it up. * Core DPLL will be locked after setting up EMIF @@ -314,7 +387,7 @@ static void setup_dplls(void) debug("Core DPLL configured\n");
/* lock PER dpll */ - params = get_per_dpll_params(); + params = get_per_dpll_params(*dplls_data); do_setup_dpll((*prcm)->cm_clkmode_dpll_per, params, DPLL_LOCK, "per"); debug("PER DPLL locked\n"); @@ -337,11 +410,11 @@ static void setup_non_essential_dplls(void) clrsetbits_le32((*prcm)->cm_bypclk_dpll_iva, CM_BYPCLK_DPLL_IVA_CLKSEL_MASK, DPLL_IVA_CLKSEL_CORE_X2_DIV_2);
- params = get_iva_dpll_params(); + params = get_iva_dpll_params(*dplls_data); do_setup_dpll((*prcm)->cm_clkmode_dpll_iva, params, DPLL_LOCK, "iva");
/* Configure ABE dpll */ - params = get_abe_dpll_params(); + params = get_abe_dpll_params(*dplls_data); #ifdef CONFIG_SYS_OMAP_ABE_SYSCK abe_ref_clk = CM_ABE_PLL_REF_CLKSEL_CLKSEL_SYSCLK; #else @@ -459,7 +532,7 @@ void freq_update_core(void) const struct dpll_params *core_dpll_params; u32 omap_rev = omap_revision();
- core_dpll_params = get_core_dpll_params(); + core_dpll_params = get_core_dpll_params(*dplls_data); /* Put EMIF clock domain in sw wakeup mode */ enable_clock_domain((*prcm)->cm_memif_clkstctrl, CD_CLKCTRL_CLKTRCTRL_SW_WKUP); diff --git a/arch/arm/cpu/armv7/omap4/clocks.c b/arch/arm/cpu/armv7/omap4/clocks.c index 9acceb0..4772743 100644 --- a/arch/arm/cpu/armv7/omap4/clocks.c +++ b/arch/arm/cpu/armv7/omap4/clocks.c @@ -46,221 +46,6 @@ #define puts(s) #endif /* !CONFIG_SPL_BUILD */
-const u32 sys_clk_array[8] = { - 12000000, /* 12 MHz */ - 13000000, /* 13 MHz */ - 16800000, /* 16.8 MHz */ - 19200000, /* 19.2 MHz */ - 26000000, /* 26 MHz */ - 27000000, /* 27 MHz */ - 38400000, /* 38.4 MHz */ -}; - -/* - * The M & N values in the following tables are created using the - * following tool: - * tools/omap/clocks_get_m_n.c - * Please use this tool for creating the table for any new frequency. - */ - -/* dpll locked at 1400 MHz MPU clk at 700 MHz(OPP100) - DCC OFF */ -static const struct dpll_params mpu_dpll_params_1400mhz[NUM_SYS_CLKS] = { - {175, 2, 1, -1, -1, -1, -1, -1}, /* 12 MHz */ - {700, 12, 1, -1, -1, -1, -1, -1}, /* 13 MHz */ - {125, 2, 1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ - {401, 10, 1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ - {350, 12, 1, -1, -1, -1, -1, -1}, /* 26 MHz */ - {700, 26, 1, -1, -1, -1, -1, -1}, /* 27 MHz */ - {638, 34, 1, -1, -1, -1, -1, -1} /* 38.4 MHz */ -}; - -/* dpll locked at 1584 MHz - MPU clk at 792 MHz(OPP Turbo 4430) */ -static const struct dpll_params mpu_dpll_params_1600mhz[NUM_SYS_CLKS] = { - {200, 2, 1, -1, -1, -1, -1, -1}, /* 12 MHz */ - {800, 12, 1, -1, -1, -1, -1, -1}, /* 13 MHz */ - {619, 12, 1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ - {125, 2, 1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ - {400, 12, 1, -1, -1, -1, -1, -1}, /* 26 MHz */ - {800, 26, 1, -1, -1, -1, -1, -1}, /* 27 MHz */ - {125, 5, 1, -1, -1, -1, -1, -1} /* 38.4 MHz */ -}; - -/* dpll locked at 1200 MHz - MPU clk at 600 MHz */ -static const struct dpll_params mpu_dpll_params_1200mhz[NUM_SYS_CLKS] = { - {50, 0, 1, -1, -1, -1, -1, -1}, /* 12 MHz */ - {600, 12, 1, -1, -1, -1, -1, -1}, /* 13 MHz */ - {250, 6, 1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ - {125, 3, 1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ - {300, 12, 1, -1, -1, -1, -1, -1}, /* 26 MHz */ - {200, 8, 1, -1, -1, -1, -1, -1}, /* 27 MHz */ - {125, 7, 1, -1, -1, -1, -1, -1} /* 38.4 MHz */ -}; - -static const struct dpll_params core_dpll_params_1600mhz[NUM_SYS_CLKS] = { - {200, 2, 1, 5, 8, 4, 6, 5}, /* 12 MHz */ - {800, 12, 1, 5, 8, 4, 6, 5}, /* 13 MHz */ - {619, 12, 1, 5, 8, 4, 6, 5}, /* 16.8 MHz */ - {125, 2, 1, 5, 8, 4, 6, 5}, /* 19.2 MHz */ - {400, 12, 1, 5, 8, 4, 6, 5}, /* 26 MHz */ - {800, 26, 1, 5, 8, 4, 6, 5}, /* 27 MHz */ - {125, 5, 1, 5, 8, 4, 6, 5} /* 38.4 MHz */ -}; - -static const struct dpll_params core_dpll_params_es1_1524mhz[NUM_SYS_CLKS] = { - {127, 1, 1, 5, 8, 4, 6, 5}, /* 12 MHz */ - {762, 12, 1, 5, 8, 4, 6, 5}, /* 13 MHz */ - {635, 13, 1, 5, 8, 4, 6, 5}, /* 16.8 MHz */ - {635, 15, 1, 5, 8, 4, 6, 5}, /* 19.2 MHz */ - {381, 12, 1, 5, 8, 4, 6, 5}, /* 26 MHz */ - {254, 8, 1, 5, 8, 4, 6, 5}, /* 27 MHz */ - {496, 24, 1, 5, 8, 4, 6, 5} /* 38.4 MHz */ -}; - -static const struct dpll_params - core_dpll_params_es2_1600mhz_ddr200mhz[NUM_SYS_CLKS] = { - {200, 2, 2, 5, 8, 4, 6, 5}, /* 12 MHz */ - {800, 12, 2, 5, 8, 4, 6, 5}, /* 13 MHz */ - {619, 12, 2, 5, 8, 4, 6, 5}, /* 16.8 MHz */ - {125, 2, 2, 5, 8, 4, 6, 5}, /* 19.2 MHz */ - {400, 12, 2, 5, 8, 4, 6, 5}, /* 26 MHz */ - {800, 26, 2, 5, 8, 4, 6, 5}, /* 27 MHz */ - {125, 5, 2, 5, 8, 4, 6, 5} /* 38.4 MHz */ -}; - -static const struct dpll_params per_dpll_params_1536mhz[NUM_SYS_CLKS] = { - {64, 0, 8, 6, 12, 9, 4, 5}, /* 12 MHz */ - {768, 12, 8, 6, 12, 9, 4, 5}, /* 13 MHz */ - {320, 6, 8, 6, 12, 9, 4, 5}, /* 16.8 MHz */ - {40, 0, 8, 6, 12, 9, 4, 5}, /* 19.2 MHz */ - {384, 12, 8, 6, 12, 9, 4, 5}, /* 26 MHz */ - {256, 8, 8, 6, 12, 9, 4, 5}, /* 27 MHz */ - {20, 0, 8, 6, 12, 9, 4, 5} /* 38.4 MHz */ -}; - -static const struct dpll_params iva_dpll_params_1862mhz[NUM_SYS_CLKS] = { - {931, 11, -1, -1, 4, 7, -1, -1}, /* 12 MHz */ - {931, 12, -1, -1, 4, 7, -1, -1}, /* 13 MHz */ - {665, 11, -1, -1, 4, 7, -1, -1}, /* 16.8 MHz */ - {727, 14, -1, -1, 4, 7, -1, -1}, /* 19.2 MHz */ - {931, 25, -1, -1, 4, 7, -1, -1}, /* 26 MHz */ - {931, 26, -1, -1, 4, 7, -1, -1}, /* 27 MHz */ - {291, 11, -1, -1, 4, 7, -1, -1} /* 38.4 MHz */ -}; - -/* ABE M & N values with sys_clk as source */ -static const struct dpll_params - abe_dpll_params_sysclk_196608khz[NUM_SYS_CLKS] = { - {49, 5, 1, 1, -1, -1, -1, -1}, /* 12 MHz */ - {68, 8, 1, 1, -1, -1, -1, -1}, /* 13 MHz */ - {35, 5, 1, 1, -1, -1, -1, -1}, /* 16.8 MHz */ - {46, 8, 1, 1, -1, -1, -1, -1}, /* 19.2 MHz */ - {34, 8, 1, 1, -1, -1, -1, -1}, /* 26 MHz */ - {29, 7, 1, 1, -1, -1, -1, -1}, /* 27 MHz */ - {64, 24, 1, 1, -1, -1, -1, -1} /* 38.4 MHz */ -}; - -/* ABE M & N values with 32K clock as source */ -static const struct dpll_params abe_dpll_params_32k_196608khz = { - 750, 0, 1, 1, -1, -1, -1, -1 -}; - -static const struct dpll_params usb_dpll_params_1920mhz[NUM_SYS_CLKS] = { - {80, 0, 2, -1, -1, -1, -1, -1}, /* 12 MHz */ - {960, 12, 2, -1, -1, -1, -1, -1}, /* 13 MHz */ - {400, 6, 2, -1, -1, -1, -1, -1}, /* 16.8 MHz */ - {50, 0, 2, -1, -1, -1, -1, -1}, /* 19.2 MHz */ - {480, 12, 2, -1, -1, -1, -1, -1}, /* 26 MHz */ - {320, 8, 2, -1, -1, -1, -1, -1}, /* 27 MHz */ - {25, 0, 2, -1, -1, -1, -1, -1} /* 38.4 MHz */ -}; - -void setup_post_dividers(u32 const base, const struct dpll_params *params) -{ - struct dpll_regs *const dpll_regs = (struct dpll_regs *)base; - - /* Setup post-dividers */ - if (params->m2 >= 0) - writel(params->m2, &dpll_regs->cm_div_m2_dpll); - if (params->m3 >= 0) - writel(params->m3, &dpll_regs->cm_div_m3_dpll); - if (params->m4 >= 0) - writel(params->m4, &dpll_regs->cm_div_m4_dpll); - if (params->m5 >= 0) - writel(params->m5, &dpll_regs->cm_div_m5_dpll); - if (params->m6 >= 0) - writel(params->m6, &dpll_regs->cm_div_m6_dpll); - if (params->m7 >= 0) - writel(params->m7, &dpll_regs->cm_div_m7_dpll); -} - -/* - * Lock MPU dpll - * - * Resulting MPU frequencies: - * 4430 ES1.0 : 600 MHz - * 4430 ES2.x : 792 MHz (OPP Turbo) - * 4460 : 920 MHz (OPP Turbo) - DCC disabled - */ -const struct dpll_params *get_mpu_dpll_params(void) -{ - u32 omap_rev, sysclk_ind; - - omap_rev = omap_revision(); - sysclk_ind = get_sys_clk_index(); - - if (omap_rev == OMAP4430_ES1_0) - return &mpu_dpll_params_1200mhz[sysclk_ind]; - else if (omap_rev < OMAP4460_ES1_0) - return &mpu_dpll_params_1600mhz[sysclk_ind]; - else - return &mpu_dpll_params_1400mhz[sysclk_ind]; -} - -const struct dpll_params *get_core_dpll_params(void) -{ - u32 sysclk_ind = get_sys_clk_index(); - - switch (omap_revision()) { - case OMAP4430_ES1_0: - return &core_dpll_params_es1_1524mhz[sysclk_ind]; - case OMAP4430_ES2_0: - case OMAP4430_SILICON_ID_INVALID: - /* safest */ - return &core_dpll_params_es2_1600mhz_ddr200mhz[sysclk_ind]; - default: - return &core_dpll_params_1600mhz[sysclk_ind]; - } -} - - -const struct dpll_params *get_per_dpll_params(void) -{ - u32 sysclk_ind = get_sys_clk_index(); - return &per_dpll_params_1536mhz[sysclk_ind]; -} - -const struct dpll_params *get_iva_dpll_params(void) -{ - u32 sysclk_ind = get_sys_clk_index(); - return &iva_dpll_params_1862mhz[sysclk_ind]; -} - -const struct dpll_params *get_usb_dpll_params(void) -{ - u32 sysclk_ind = get_sys_clk_index(); - return &usb_dpll_params_1920mhz[sysclk_ind]; -} - -const struct dpll_params *get_abe_dpll_params(void) -{ -#ifdef CONFIG_SYS_OMAP_ABE_SYSCK - u32 sysclk_ind = get_sys_clk_index(); - return &abe_dpll_params_sysclk_196608khz[sysclk_ind]; -#else - return &abe_dpll_params_32k_196608khz; -#endif -} - /* * Setup the voltages for vdd_mpu, vdd_core, and vdd_iva * We set the maximum voltages allowed here because Smart-Reflex is not @@ -336,181 +121,3 @@ u32 get_offset_code(u32 offset) /* The code starts at 1 not 0 */ return ++offset_code; } - -/* - * Enable essential clock domains, modules and - * do some additional special settings needed - */ -void enable_basic_clocks(void) -{ - u32 const clk_domains_essential[] = { - (*prcm)->cm_l4per_clkstctrl, - (*prcm)->cm_l3init_clkstctrl, - (*prcm)->cm_memif_clkstctrl, - (*prcm)->cm_l4cfg_clkstctrl, - 0 - }; - - u32 const clk_modules_hw_auto_essential[] = { - (*prcm)->cm_l3_2_gpmc_clkctrl, - (*prcm)->cm_memif_emif_1_clkctrl, - (*prcm)->cm_memif_emif_2_clkctrl, - (*prcm)->cm_l4cfg_l4_cfg_clkctrl, - (*prcm)->cm_wkup_gpio1_clkctrl, - (*prcm)->cm_l4per_gpio2_clkctrl, - (*prcm)->cm_l4per_gpio3_clkctrl, - (*prcm)->cm_l4per_gpio4_clkctrl, - (*prcm)->cm_l4per_gpio5_clkctrl, - (*prcm)->cm_l4per_gpio6_clkctrl, - 0 - }; - - u32 const clk_modules_explicit_en_essential[] = { - (*prcm)->cm_wkup_gptimer1_clkctrl, - (*prcm)->cm_l3init_hsmmc1_clkctrl, - (*prcm)->cm_l3init_hsmmc2_clkctrl, - (*prcm)->cm_l4per_gptimer2_clkctrl, - (*prcm)->cm_wkup_wdtimer2_clkctrl, - (*prcm)->cm_l4per_uart3_clkctrl, - 0 - }; - - /* Enable optional additional functional clock for GPIO4 */ - setbits_le32((*prcm)->cm_l4per_gpio4_clkctrl, - GPIO4_CLKCTRL_OPTFCLKEN_MASK); - - /* Enable 96 MHz clock for MMC1 & MMC2 */ - setbits_le32((*prcm)->cm_l3init_hsmmc1_clkctrl, - HSMMC_CLKCTRL_CLKSEL_MASK); - setbits_le32((*prcm)->cm_l3init_hsmmc2_clkctrl, - HSMMC_CLKCTRL_CLKSEL_MASK); - - /* Select 32KHz clock as the source of GPTIMER1 */ - setbits_le32((*prcm)->cm_wkup_gptimer1_clkctrl, - GPTIMER1_CLKCTRL_CLKSEL_MASK); - - /* Enable optional 48M functional clock for USB PHY */ - setbits_le32((*prcm)->cm_l3init_usbphy_clkctrl, - USBPHY_CLKCTRL_OPTFCLKEN_PHY_48M_MASK); - - do_enable_clocks(clk_domains_essential, - clk_modules_hw_auto_essential, - clk_modules_explicit_en_essential, - 1); -} - -void enable_basic_uboot_clocks(void) -{ - u32 const clk_domains_essential[] = { - 0 - }; - - u32 const clk_modules_hw_auto_essential[] = { - (*prcm)->cm_l3init_hsusbotg_clkctrl, - (*prcm)->cm_l3init_usbphy_clkctrl, - (*prcm)->cm_l3init_usbphy_clkctrl, - (*prcm)->cm_clksel_usb_60mhz, - (*prcm)->cm_l3init_hsusbtll_clkctrl, - 0 - }; - - u32 const clk_modules_explicit_en_essential[] = { - (*prcm)->cm_l4per_mcspi1_clkctrl, - (*prcm)->cm_l4per_i2c1_clkctrl, - (*prcm)->cm_l4per_i2c2_clkctrl, - (*prcm)->cm_l4per_i2c3_clkctrl, - (*prcm)->cm_l4per_i2c4_clkctrl, - (*prcm)->cm_l3init_hsusbhost_clkctrl, - 0 - }; - - do_enable_clocks(clk_domains_essential, - clk_modules_hw_auto_essential, - clk_modules_explicit_en_essential, - 1); -} - -/* - * Enable non-essential clock domains, modules and - * do some additional special settings needed - */ -void enable_non_essential_clocks(void) -{ - u32 const clk_domains_non_essential[] = { - (*prcm)->cm_mpu_m3_clkstctrl, - (*prcm)->cm_ivahd_clkstctrl, - (*prcm)->cm_dsp_clkstctrl, - (*prcm)->cm_dss_clkstctrl, - (*prcm)->cm_sgx_clkstctrl, - (*prcm)->cm1_abe_clkstctrl, - (*prcm)->cm_c2c_clkstctrl, - (*prcm)->cm_cam_clkstctrl, - (*prcm)->cm_dss_clkstctrl, - (*prcm)->cm_sdma_clkstctrl, - 0 - }; - - u32 const clk_modules_hw_auto_non_essential[] = { - (*prcm)->cm_l3instr_l3_3_clkctrl, - (*prcm)->cm_l3instr_l3_instr_clkctrl, - (*prcm)->cm_l3instr_intrconn_wp1_clkctrl, - (*prcm)->cm_l3init_hsi_clkctrl, - 0 - }; - - u32 const clk_modules_explicit_en_non_essential[] = { - (*prcm)->cm1_abe_aess_clkctrl, - (*prcm)->cm1_abe_pdm_clkctrl, - (*prcm)->cm1_abe_dmic_clkctrl, - (*prcm)->cm1_abe_mcasp_clkctrl, - (*prcm)->cm1_abe_mcbsp1_clkctrl, - (*prcm)->cm1_abe_mcbsp2_clkctrl, - (*prcm)->cm1_abe_mcbsp3_clkctrl, - (*prcm)->cm1_abe_slimbus_clkctrl, - (*prcm)->cm1_abe_timer5_clkctrl, - (*prcm)->cm1_abe_timer6_clkctrl, - (*prcm)->cm1_abe_timer7_clkctrl, - (*prcm)->cm1_abe_timer8_clkctrl, - (*prcm)->cm1_abe_wdt3_clkctrl, - (*prcm)->cm_l4per_gptimer9_clkctrl, - (*prcm)->cm_l4per_gptimer10_clkctrl, - (*prcm)->cm_l4per_gptimer11_clkctrl, - (*prcm)->cm_l4per_gptimer3_clkctrl, - (*prcm)->cm_l4per_gptimer4_clkctrl, - (*prcm)->cm_l4per_hdq1w_clkctrl, - (*prcm)->cm_l4per_mcbsp4_clkctrl, - (*prcm)->cm_l4per_mcspi2_clkctrl, - (*prcm)->cm_l4per_mcspi3_clkctrl, - (*prcm)->cm_l4per_mcspi4_clkctrl, - (*prcm)->cm_l4per_mmcsd3_clkctrl, - (*prcm)->cm_l4per_mmcsd4_clkctrl, - (*prcm)->cm_l4per_mmcsd5_clkctrl, - (*prcm)->cm_l4per_uart1_clkctrl, - (*prcm)->cm_l4per_uart2_clkctrl, - (*prcm)->cm_l4per_uart4_clkctrl, - (*prcm)->cm_wkup_keyboard_clkctrl, - (*prcm)->cm_wkup_wdtimer2_clkctrl, - (*prcm)->cm_cam_iss_clkctrl, - (*prcm)->cm_cam_fdif_clkctrl, - (*prcm)->cm_dss_dss_clkctrl, - (*prcm)->cm_sgx_sgx_clkctrl, - 0 - }; - - /* Enable optional functional clock for ISS */ - setbits_le32((*prcm)->cm_cam_iss_clkctrl, ISS_CLKCTRL_OPTFCLKEN_MASK); - - /* Enable all optional functional clocks of DSS */ - setbits_le32((*prcm)->cm_dss_dss_clkctrl, DSS_CLKCTRL_OPTFCLKEN_MASK); - - do_enable_clocks(clk_domains_non_essential, - clk_modules_hw_auto_non_essential, - clk_modules_explicit_en_non_essential, - 0); - - /* Put camera module in no sleep mode */ - clrsetbits_le32((*prcm)->cm_cam_clkstctrl, - MODULE_CLKCTRL_MODULEMODE_MASK, - CD_CLKCTRL_CLKTRCTRL_NO_SLEEP << - MODULE_CLKCTRL_MODULEMODE_SHIFT); -} diff --git a/arch/arm/cpu/armv7/omap4/hw_data.c b/arch/arm/cpu/armv7/omap4/hw_data.c index 3174cc3..6ae3986 100644 --- a/arch/arm/cpu/armv7/omap4/hw_data.c +++ b/arch/arm/cpu/armv7/omap4/hw_data.c @@ -27,12 +27,377 @@ */ #include <common.h> #include <asm/arch/omap.h> +#include <asm/arch/sys_proto.h> #include <asm/omap_common.h> +#include <asm/arch/clocks.h> +#include <asm/io.h>
struct prcm_regs const **prcm = (struct prcm_regs const **) OMAP_SRAM_SCRATCH_PRCM_PTR; +struct dplls const **dplls_data = + (struct dplls const **) OMAP_SRAM_SCRATCH_DPLLS_PTR; + +/* + * The M & N values in the following tables are created using the + * following tool: + * tools/omap/clocks_get_m_n.c + * Please use this tool for creating the table for any new frequency. + */ + +/* dpll locked at 1400 MHz MPU clk at 700 MHz(OPP100) - DCC OFF */ +static const struct dpll_params mpu_dpll_params_1400mhz[NUM_SYS_CLKS] = { + {175, 2, 1, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {700, 12, 1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {125, 2, 1, -1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {401, 10, 1, -1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {350, 12, 1, -1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {700, 26, 1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {638, 34, 1, -1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +/* dpll locked at 1584 MHz - MPU clk at 792 MHz(OPP Turbo 4430) */ +static const struct dpll_params mpu_dpll_params_1600mhz[NUM_SYS_CLKS] = { + {200, 2, 1, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {800, 12, 1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {619, 12, 1, -1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {125, 2, 1, -1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {400, 12, 1, -1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {800, 26, 1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {125, 5, 1, -1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +/* dpll locked at 1200 MHz - MPU clk at 600 MHz */ +static const struct dpll_params mpu_dpll_params_1200mhz[NUM_SYS_CLKS] = { + {50, 0, 1, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {600, 12, 1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {250, 6, 1, -1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {125, 3, 1, -1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {300, 12, 1, -1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {200, 8, 1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {125, 7, 1, -1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +static const struct dpll_params core_dpll_params_1600mhz[NUM_SYS_CLKS] = { + {200, 2, 1, 5, 8, 4, 6, 5, -1, -1}, /* 12 MHz */ + {800, 12, 1, 5, 8, 4, 6, 5, -1, -1}, /* 13 MHz */ + {619, 12, 1, 5, 8, 4, 6, 5, -1, -1}, /* 16.8 MHz */ + {125, 2, 1, 5, 8, 4, 6, 5, -1, -1}, /* 19.2 MHz */ + {400, 12, 1, 5, 8, 4, 6, 5, -1, -1}, /* 26 MHz */ + {800, 26, 1, 5, 8, 4, 6, 5, -1, -1}, /* 27 MHz */ + {125, 5, 1, 5, 8, 4, 6, 5, -1, -1} /* 38.4 MHz */ +}; + +static const struct dpll_params core_dpll_params_es1_1524mhz[NUM_SYS_CLKS] = { + {127, 1, 1, 5, 8, 4, 6, 5, -1, -1}, /* 12 MHz */ + {762, 12, 1, 5, 8, 4, 6, 5, -1, -1}, /* 13 MHz */ + {635, 13, 1, 5, 8, 4, 6, 5, -1, -1}, /* 16.8 MHz */ + {635, 15, 1, 5, 8, 4, 6, 5, -1, -1}, /* 19.2 MHz */ + {381, 12, 1, 5, 8, 4, 6, 5, -1, -1}, /* 26 MHz */ + {254, 8, 1, 5, 8, 4, 6, 5, -1, -1}, /* 27 MHz */ + {496, 24, 1, 5, 8, 4, 6, 5, -1, -1} /* 38.4 MHz */ +}; + +static const struct dpll_params + core_dpll_params_es2_1600mhz_ddr200mhz[NUM_SYS_CLKS] = { + {200, 2, 2, 5, 8, 4, 6, 5, -1, -1}, /* 12 MHz */ + {800, 12, 2, 5, 8, 4, 6, 5, -1, -1}, /* 13 MHz */ + {619, 12, 2, 5, 8, 4, 6, 5, -1, -1}, /* 16.8 MHz */ + {125, 2, 2, 5, 8, 4, 6, 5, -1, -1}, /* 19.2 MHz */ + {400, 12, 2, 5, 8, 4, 6, 5, -1, -1}, /* 26 MHz */ + {800, 26, 2, 5, 8, 4, 6, 5, -1, -1}, /* 27 MHz */ + {125, 5, 2, 5, 8, 4, 6, 5, -1, -1} /* 38.4 MHz */ +}; + +static const struct dpll_params per_dpll_params_1536mhz[NUM_SYS_CLKS] = { + {64, 0, 8, 6, 12, 9, 4, 5, -1, -1}, /* 12 MHz */ + {768, 12, 8, 6, 12, 9, 4, 5, -1, -1}, /* 13 MHz */ + {320, 6, 8, 6, 12, 9, 4, 5, -1, -1}, /* 16.8 MHz */ + {40, 0, 8, 6, 12, 9, 4, 5, -1, -1}, /* 19.2 MHz */ + {384, 12, 8, 6, 12, 9, 4, 5, -1, -1}, /* 26 MHz */ + {256, 8, 8, 6, 12, 9, 4, 5, -1, -1}, /* 27 MHz */ + {20, 0, 8, 6, 12, 9, 4, 5, -1, -1} /* 38.4 MHz */ +}; + +static const struct dpll_params iva_dpll_params_1862mhz[NUM_SYS_CLKS] = { + {931, 11, -1, -1, 4, 7, -1, -1, -1, -1}, /* 12 MHz */ + {931, 12, -1, -1, 4, 7, -1, -1, -1, -1}, /* 13 MHz */ + {665, 11, -1, -1, 4, 7, -1, -1, -1, -1}, /* 16.8 MHz */ + {727, 14, -1, -1, 4, 7, -1, -1, -1, -1}, /* 19.2 MHz */ + {931, 25, -1, -1, 4, 7, -1, -1, -1, -1}, /* 26 MHz */ + {931, 26, -1, -1, 4, 7, -1, -1, -1, -1}, /* 27 MHz */ + {291, 11, -1, -1, 4, 7, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +/* ABE M & N values with sys_clk as source */ +static const struct dpll_params + abe_dpll_params_sysclk_196608khz[NUM_SYS_CLKS] = { + {49, 5, 1, 1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {68, 8, 1, 1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {35, 5, 1, 1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {46, 8, 1, 1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {34, 8, 1, 1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {29, 7, 1, 1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {64, 24, 1, 1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +/* ABE M & N values with 32K clock as source */ +static const struct dpll_params abe_dpll_params_32k_196608khz = { + 750, 0, 1, 1, -1, -1, -1, -1, -1, -1 +}; + +static const struct dpll_params usb_dpll_params_1920mhz[NUM_SYS_CLKS] = { + {80, 0, 2, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {960, 12, 2, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {400, 6, 2, -1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {50, 0, 2, -1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {480, 12, 2, -1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {320, 8, 2, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {25, 0, 2, -1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +struct dplls omap4430_dplls_es1 = { + .mpu = mpu_dpll_params_1200mhz, + .core = core_dpll_params_es1_1524mhz, + .per = per_dpll_params_1536mhz, + .iva = iva_dpll_params_1862mhz, +#ifdef CONFIG_SYS_OMAP_ABE_SYSCK + .abe = abe_dpll_params_sysclk_196608khz, +#else + .abe = &abe_dpll_params_32k_196608khz, +#endif + .usb = usb_dpll_params_1920mhz +}; + +struct dplls omap4430_dplls = { + .mpu = mpu_dpll_params_1600mhz, + .core = core_dpll_params_es2_1600mhz_ddr200mhz, + .per = per_dpll_params_1536mhz, + .iva = iva_dpll_params_1862mhz, +#ifdef CONFIG_SYS_OMAP_ABE_SYSCK + .abe = abe_dpll_params_sysclk_196608khz, +#else + .abe = &abe_dpll_params_32k_196608khz, +#endif + .usb = usb_dpll_params_1920mhz +}; + +struct dplls omap4460_dplls = { + .mpu = mpu_dpll_params_1400mhz, + .core = core_dpll_params_1600mhz, + .per = per_dpll_params_1536mhz, + .iva = iva_dpll_params_1862mhz, +#ifdef CONFIG_SYS_OMAP_ABE_SYSCK + .abe = abe_dpll_params_sysclk_196608khz, +#else + .abe = &abe_dpll_params_32k_196608khz, +#endif + .usb = usb_dpll_params_1920mhz +}; + +/* + * Enable essential clock domains, modules and + * do some additional special settings needed + */ +void enable_basic_clocks(void) +{ + u32 const clk_domains_essential[] = { + (*prcm)->cm_l4per_clkstctrl, + (*prcm)->cm_l3init_clkstctrl, + (*prcm)->cm_memif_clkstctrl, + (*prcm)->cm_l4cfg_clkstctrl, + 0 + }; + + u32 const clk_modules_hw_auto_essential[] = { + (*prcm)->cm_l3_2_gpmc_clkctrl, + (*prcm)->cm_memif_emif_1_clkctrl, + (*prcm)->cm_memif_emif_2_clkctrl, + (*prcm)->cm_l4cfg_l4_cfg_clkctrl, + (*prcm)->cm_wkup_gpio1_clkctrl, + (*prcm)->cm_l4per_gpio2_clkctrl, + (*prcm)->cm_l4per_gpio3_clkctrl, + (*prcm)->cm_l4per_gpio4_clkctrl, + (*prcm)->cm_l4per_gpio5_clkctrl, + (*prcm)->cm_l4per_gpio6_clkctrl, + 0 + }; + + u32 const clk_modules_explicit_en_essential[] = { + (*prcm)->cm_wkup_gptimer1_clkctrl, + (*prcm)->cm_l3init_hsmmc1_clkctrl, + (*prcm)->cm_l3init_hsmmc2_clkctrl, + (*prcm)->cm_l4per_gptimer2_clkctrl, + (*prcm)->cm_wkup_wdtimer2_clkctrl, + (*prcm)->cm_l4per_uart3_clkctrl, + 0 + }; + + /* Enable optional additional functional clock for GPIO4 */ + setbits_le32((*prcm)->cm_l4per_gpio4_clkctrl, + GPIO4_CLKCTRL_OPTFCLKEN_MASK); + + /* Enable 96 MHz clock for MMC1 & MMC2 */ + setbits_le32((*prcm)->cm_l3init_hsmmc1_clkctrl, + HSMMC_CLKCTRL_CLKSEL_MASK); + setbits_le32((*prcm)->cm_l3init_hsmmc2_clkctrl, + HSMMC_CLKCTRL_CLKSEL_MASK); + + /* Select 32KHz clock as the source of GPTIMER1 */ + setbits_le32((*prcm)->cm_wkup_gptimer1_clkctrl, + GPTIMER1_CLKCTRL_CLKSEL_MASK); + + /* Enable optional 48M functional clock for USB PHY */ + setbits_le32((*prcm)->cm_l3init_usbphy_clkctrl, + USBPHY_CLKCTRL_OPTFCLKEN_PHY_48M_MASK); + + do_enable_clocks(clk_domains_essential, + clk_modules_hw_auto_essential, + clk_modules_explicit_en_essential, + 1); +} + +void enable_basic_uboot_clocks(void) +{ + u32 const clk_domains_essential[] = { + 0 + }; + + u32 const clk_modules_hw_auto_essential[] = { + (*prcm)->cm_l3init_hsusbotg_clkctrl, + (*prcm)->cm_l3init_usbphy_clkctrl, + (*prcm)->cm_l3init_usbphy_clkctrl, + (*prcm)->cm_clksel_usb_60mhz, + (*prcm)->cm_l3init_hsusbtll_clkctrl, + 0 + }; + + u32 const clk_modules_explicit_en_essential[] = { + (*prcm)->cm_l4per_mcspi1_clkctrl, + (*prcm)->cm_l4per_i2c1_clkctrl, + (*prcm)->cm_l4per_i2c2_clkctrl, + (*prcm)->cm_l4per_i2c3_clkctrl, + (*prcm)->cm_l4per_i2c4_clkctrl, + (*prcm)->cm_l3init_hsusbhost_clkctrl, + 0 + }; + + do_enable_clocks(clk_domains_essential, + clk_modules_hw_auto_essential, + clk_modules_explicit_en_essential, + 1); +} + +/* + * Enable non-essential clock domains, modules and + * do some additional special settings needed + */ +void enable_non_essential_clocks(void) +{ + u32 const clk_domains_non_essential[] = { + (*prcm)->cm_mpu_m3_clkstctrl, + (*prcm)->cm_ivahd_clkstctrl, + (*prcm)->cm_dsp_clkstctrl, + (*prcm)->cm_dss_clkstctrl, + (*prcm)->cm_sgx_clkstctrl, + (*prcm)->cm1_abe_clkstctrl, + (*prcm)->cm_c2c_clkstctrl, + (*prcm)->cm_cam_clkstctrl, + (*prcm)->cm_dss_clkstctrl, + (*prcm)->cm_sdma_clkstctrl, + 0 + }; + + u32 const clk_modules_hw_auto_non_essential[] = { + (*prcm)->cm_l3instr_l3_3_clkctrl, + (*prcm)->cm_l3instr_l3_instr_clkctrl, + (*prcm)->cm_l3instr_intrconn_wp1_clkctrl, + (*prcm)->cm_l3init_hsi_clkctrl, + 0 + }; + + u32 const clk_modules_explicit_en_non_essential[] = { + (*prcm)->cm1_abe_aess_clkctrl, + (*prcm)->cm1_abe_pdm_clkctrl, + (*prcm)->cm1_abe_dmic_clkctrl, + (*prcm)->cm1_abe_mcasp_clkctrl, + (*prcm)->cm1_abe_mcbsp1_clkctrl, + (*prcm)->cm1_abe_mcbsp2_clkctrl, + (*prcm)->cm1_abe_mcbsp3_clkctrl, + (*prcm)->cm1_abe_slimbus_clkctrl, + (*prcm)->cm1_abe_timer5_clkctrl, + (*prcm)->cm1_abe_timer6_clkctrl, + (*prcm)->cm1_abe_timer7_clkctrl, + (*prcm)->cm1_abe_timer8_clkctrl, + (*prcm)->cm1_abe_wdt3_clkctrl, + (*prcm)->cm_l4per_gptimer9_clkctrl, + (*prcm)->cm_l4per_gptimer10_clkctrl, + (*prcm)->cm_l4per_gptimer11_clkctrl, + (*prcm)->cm_l4per_gptimer3_clkctrl, + (*prcm)->cm_l4per_gptimer4_clkctrl, + (*prcm)->cm_l4per_hdq1w_clkctrl, + (*prcm)->cm_l4per_mcbsp4_clkctrl, + (*prcm)->cm_l4per_mcspi2_clkctrl, + (*prcm)->cm_l4per_mcspi3_clkctrl, + (*prcm)->cm_l4per_mcspi4_clkctrl, + (*prcm)->cm_l4per_mmcsd3_clkctrl, + (*prcm)->cm_l4per_mmcsd4_clkctrl, + (*prcm)->cm_l4per_mmcsd5_clkctrl, + (*prcm)->cm_l4per_uart1_clkctrl, + (*prcm)->cm_l4per_uart2_clkctrl, + (*prcm)->cm_l4per_uart4_clkctrl, + (*prcm)->cm_wkup_keyboard_clkctrl, + (*prcm)->cm_wkup_wdtimer2_clkctrl, + (*prcm)->cm_cam_iss_clkctrl, + (*prcm)->cm_cam_fdif_clkctrl, + (*prcm)->cm_dss_dss_clkctrl, + (*prcm)->cm_sgx_sgx_clkctrl, + 0 + }; + + /* Enable optional functional clock for ISS */ + setbits_le32((*prcm)->cm_cam_iss_clkctrl, ISS_CLKCTRL_OPTFCLKEN_MASK); + + /* Enable all optional functional clocks of DSS */ + setbits_le32((*prcm)->cm_dss_dss_clkctrl, DSS_CLKCTRL_OPTFCLKEN_MASK); + + do_enable_clocks(clk_domains_non_essential, + clk_modules_hw_auto_non_essential, + clk_modules_explicit_en_non_essential, + 0); + + /* Put camera module in no sleep mode */ + clrsetbits_le32((*prcm)->cm_cam_clkstctrl, + MODULE_CLKCTRL_MODULEMODE_MASK, + CD_CLKCTRL_CLKTRCTRL_NO_SLEEP << + MODULE_CLKCTRL_MODULEMODE_SHIFT); +}
void hw_data_init(void) { - *prcm = &omap4_prcm; + u32 omap_rev = omap_revision(); + + (*prcm) = &omap4_prcm; + + switch (omap_rev) { + + case OMAP4430_ES1_0: + *dplls_data = &omap4430_dplls_es1; + break; + + case OMAP4430_ES2_0: + case OMAP4430_ES2_1: + case OMAP4430_ES2_2: + case OMAP4430_ES2_3: + *dplls_data = &omap4430_dplls; + break; + + case OMAP4460_ES1_0: + case OMAP4460_ES1_1: + *dplls_data = &omap4460_dplls; + break; + + default: + printf("\n INVALID OMAP REVISION "); + } + } diff --git a/arch/arm/cpu/armv7/omap5/clocks.c b/arch/arm/cpu/armv7/omap5/clocks.c index a90f922..da5b3ac 100644 --- a/arch/arm/cpu/armv7/omap5/clocks.c +++ b/arch/arm/cpu/armv7/omap5/clocks.c @@ -47,210 +47,6 @@ #define puts(s) #endif
-const u32 sys_clk_array[8] = { - 12000000, /* 12 MHz */ - 0, /* NA */ - 16800000, /* 16.8 MHz */ - 19200000, /* 19.2 MHz */ - 26000000, /* 26 MHz */ - 0, /* NA */ - 38400000, /* 38.4 MHz */ -}; - -static const struct dpll_params mpu_dpll_params_1_5ghz[NUM_SYS_CLKS] = { - {125, 0, 1, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ - {625, 6, 1, -1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ - {625, 7, 1, -1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ - {750, 12, 1, -1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ - {625, 15, 1, -1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ -}; - -static const struct dpll_params mpu_dpll_params_2ghz[NUM_SYS_CLKS] = { - {500, 2, 1, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ - {2024, 16, 1, -1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ - {625, 5, 1, -1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ - {1000, 12, 1, -1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ - {625, 11, 1, -1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ -}; - -static const struct dpll_params mpu_dpll_params_1100mhz[NUM_SYS_CLKS] = { - {275, 2, 1, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ - {1375, 20, 1, -1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ - {1375, 23, 1, -1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ - {550, 12, 1, -1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ - {1375, 47, 1, -1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ -}; - -static const struct dpll_params mpu_dpll_params_800mhz[NUM_SYS_CLKS] = { - {200, 2, 1, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ - {1000, 20, 1, -1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ - {375, 8, 1, -1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ - {400, 12, 1, -1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ - {375, 17, 1, -1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ -}; - -static const struct dpll_params mpu_dpll_params_400mhz[NUM_SYS_CLKS] = { - {200, 2, 2, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ - {1000, 20, 2, -1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ - {375, 8, 2, -1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ - {400, 12, 2, -1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ - {375, 17, 2, -1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ -}; - -static const struct dpll_params mpu_dpll_params_550mhz[NUM_SYS_CLKS] = { - {275, 2, 2, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ - {1375, 20, 2, -1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ - {1375, 23, 2, -1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ - {550, 12, 2, -1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ - {1375, 47, 2, -1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ -}; - -static const struct dpll_params - core_dpll_params_2128mhz_ddr532[NUM_SYS_CLKS] = { - {266, 2, 2, 5, 8, 4, 62, 5, 5, 7}, /* 12 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ - {570, 8, 2, 5, 8, 4, 62, 5, 5, 7}, /* 16.8 MHz */ - {665, 11, 2, 5, 8, 4, 62, 5, 5, 7}, /* 19.2 MHz */ - {532, 12, 2, 5, 8, 4, 62, 5, 5, 7}, /* 26 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ - {665, 23, 2, 5, 8, 4, 62, 5, 5, 7} /* 38.4 MHz */ -}; - -static const struct dpll_params - core_dpll_params_2128mhz_ddr266[NUM_SYS_CLKS] = { - {266, 2, 4, 5, 8, 8, 62, 10, 10, 14}, /* 12 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ - {570, 8, 4, 5, 8, 8, 62, 10, 10, 14}, /* 16.8 MHz */ - {665, 11, 4, 5, 8, 8, 62, 10, 10, 14}, /* 19.2 MHz */ - {532, 12, 4, 8, 8, 8, 62, 10, 10, 14}, /* 26 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ - {665, 23, 4, 8, 8, 8, 62, 10, 10, 14} /* 38.4 MHz */ -}; - -static const struct dpll_params per_dpll_params_768mhz[NUM_SYS_CLKS] = { - {32, 0, 4, 3, 6, 4, -1, 2, -1, -1}, /* 12 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ - {160, 6, 4, 3, 6, 4, -1, 2, -1, -1}, /* 16.8 MHz */ - {20, 0, 4, 3, 6, 4, -1, 2, -1, -1}, /* 19.2 MHz */ - {192, 12, 4, 3, 6, 4, -1, 2, -1, -1}, /* 26 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ - {10, 0, 4, 3, 6, 4, -1, 2, -1, -1} /* 38.4 MHz */ -}; - -static const struct dpll_params iva_dpll_params_2330mhz[NUM_SYS_CLKS] = { - {1165, 11, -1, -1, 5, 6, -1, -1, -1, -1}, /* 12 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ - {2011, 28, -1, -1, 5, 6, -1, -1, -1, -1}, /* 16.8 MHz */ - {1881, 30, -1, -1, 5, 6, -1, -1, -1, -1}, /* 19.2 MHz */ - {1165, 25, -1, -1, 5, 6, -1, -1, -1, -1}, /* 26 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ - {1972, 64, -1, -1, 5, 6, -1, -1, -1, -1} /* 38.4 MHz */ -}; - -/* ABE M & N values with sys_clk as source */ -static const struct dpll_params - abe_dpll_params_sysclk_196608khz[NUM_SYS_CLKS] = { - {49, 5, 1, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ - {35, 5, 1, 1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ - {46, 8, 1, 1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ - {34, 8, 1, 1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ - {64, 24, 1, 1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ -}; - -/* ABE M & N values with 32K clock as source */ -static const struct dpll_params abe_dpll_params_32k_196608khz = { - 750, 0, 1, 1, -1, -1, -1, -1, -1, -1 -}; - -static const struct dpll_params usb_dpll_params_1920mhz[NUM_SYS_CLKS] = { - {400, 4, 2, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ - {400, 6, 2, -1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ - {400, 7, 2, -1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ - {480, 12, 2, -1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ - {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ - {400, 15, 2, -1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ -}; - -void setup_post_dividers(u32 const base, const struct dpll_params *params) -{ - struct dpll_regs *const dpll_regs = (struct dpll_regs *)base; - - /* Setup post-dividers */ - if (params->m2 >= 0) - writel(params->m2, &dpll_regs->cm_div_m2_dpll); - if (params->m3 >= 0) - writel(params->m3, &dpll_regs->cm_div_m3_dpll); - if (params->h11 >= 0) - writel(params->h11, &dpll_regs->cm_div_h11_dpll); - if (params->h12 >= 0) - writel(params->h12, &dpll_regs->cm_div_h12_dpll); - if (params->h13 >= 0) - writel(params->h13, &dpll_regs->cm_div_h13_dpll); - if (params->h14 >= 0) - writel(params->h14, &dpll_regs->cm_div_h14_dpll); - if (params->h22 >= 0) - writel(params->h22, &dpll_regs->cm_div_h22_dpll); - if (params->h23 >= 0) - writel(params->h23, &dpll_regs->cm_div_h23_dpll); -} - -const struct dpll_params *get_mpu_dpll_params(void) -{ - u32 sysclk_ind = get_sys_clk_index(); - return &mpu_dpll_params_800mhz[sysclk_ind]; -} - -const struct dpll_params *get_core_dpll_params(void) -{ - u32 sysclk_ind = get_sys_clk_index(); - - /* Configuring the DDR to be at 532mhz */ - return &core_dpll_params_2128mhz_ddr532[sysclk_ind]; -} - -const struct dpll_params *get_per_dpll_params(void) -{ - u32 sysclk_ind = get_sys_clk_index(); - return &per_dpll_params_768mhz[sysclk_ind]; -} - -const struct dpll_params *get_iva_dpll_params(void) -{ - u32 sysclk_ind = get_sys_clk_index(); - return &iva_dpll_params_2330mhz[sysclk_ind]; -} - -const struct dpll_params *get_usb_dpll_params(void) -{ - u32 sysclk_ind = get_sys_clk_index(); - return &usb_dpll_params_1920mhz[sysclk_ind]; -} - -const struct dpll_params *get_abe_dpll_params(void) -{ -#ifdef CONFIG_SYS_OMAP_ABE_SYSCK - u32 sysclk_ind = get_sys_clk_index(); - return &abe_dpll_params_sysclk_196608khz[sysclk_ind]; -#else - return &abe_dpll_params_32k_196608khz; -#endif -} - /* * Setup the voltages for vdd_mpu, vdd_core, and vdd_iva * We set the maximum voltages allowed here because Smart-Reflex is not @@ -300,195 +96,3 @@ u32 get_offset_code(u32 volt_offset) */ return offset_code + 6; } - -/* - * Enable essential clock domains, modules and - * do some additional special settings needed - */ -void enable_basic_clocks(void) -{ - u32 const clk_domains_essential[] = { - (*prcm)->cm_l4per_clkstctrl, - (*prcm)->cm_l3init_clkstctrl, - (*prcm)->cm_memif_clkstctrl, - (*prcm)->cm_l4cfg_clkstctrl, - 0 - }; - - u32 const clk_modules_hw_auto_essential[] = { - (*prcm)->cm_l3_2_gpmc_clkctrl, - (*prcm)->cm_memif_emif_1_clkctrl, - (*prcm)->cm_memif_emif_2_clkctrl, - (*prcm)->cm_l4cfg_l4_cfg_clkctrl, - (*prcm)->cm_wkup_gpio1_clkctrl, - (*prcm)->cm_l4per_gpio2_clkctrl, - (*prcm)->cm_l4per_gpio3_clkctrl, - (*prcm)->cm_l4per_gpio4_clkctrl, - (*prcm)->cm_l4per_gpio5_clkctrl, - (*prcm)->cm_l4per_gpio6_clkctrl, - 0 - }; - - u32 const clk_modules_explicit_en_essential[] = { - (*prcm)->cm_wkup_gptimer1_clkctrl, - (*prcm)->cm_l3init_hsmmc1_clkctrl, - (*prcm)->cm_l3init_hsmmc2_clkctrl, - (*prcm)->cm_l4per_gptimer2_clkctrl, - (*prcm)->cm_wkup_wdtimer2_clkctrl, - (*prcm)->cm_l4per_uart3_clkctrl, - (*prcm)->cm_l4per_i2c1_clkctrl, - 0 - }; - - /* Enable optional additional functional clock for GPIO4 */ - setbits_le32((*prcm)->cm_l4per_gpio4_clkctrl, - GPIO4_CLKCTRL_OPTFCLKEN_MASK); - - /* Enable 96 MHz clock for MMC1 & MMC2 */ - setbits_le32((*prcm)->cm_l3init_hsmmc1_clkctrl, - HSMMC_CLKCTRL_CLKSEL_MASK); - setbits_le32((*prcm)->cm_l3init_hsmmc2_clkctrl, - HSMMC_CLKCTRL_CLKSEL_MASK); - - /* Set the correct clock dividers for mmc */ - setbits_le32((*prcm)->cm_l3init_hsmmc1_clkctrl, - HSMMC_CLKCTRL_CLKSEL_DIV_MASK); - setbits_le32((*prcm)->cm_l3init_hsmmc2_clkctrl, - HSMMC_CLKCTRL_CLKSEL_DIV_MASK); - - /* Select 32KHz clock as the source of GPTIMER1 */ - setbits_le32((*prcm)->cm_wkup_gptimer1_clkctrl, - GPTIMER1_CLKCTRL_CLKSEL_MASK); - - do_enable_clocks(clk_domains_essential, - clk_modules_hw_auto_essential, - clk_modules_explicit_en_essential, - 1); - - /* Select 384Mhz for GPU as its the POR for ES1.0 */ - setbits_le32((*prcm)->cm_sgx_sgx_clkctrl, - CLKSEL_GPU_HYD_GCLK_MASK); - setbits_le32((*prcm)->cm_sgx_sgx_clkctrl, - CLKSEL_GPU_CORE_GCLK_MASK); - - /* Enable SCRM OPT clocks for PER and CORE dpll */ - setbits_le32((*prcm)->cm_wkupaon_scrm_clkctrl, - OPTFCLKEN_SCRM_PER_MASK); - setbits_le32((*prcm)->cm_wkupaon_scrm_clkctrl, - OPTFCLKEN_SCRM_CORE_MASK); -} - -void enable_basic_uboot_clocks(void) -{ - u32 const clk_domains_essential[] = { - 0 - }; - - u32 const clk_modules_hw_auto_essential[] = { - 0 - }; - - u32 const clk_modules_explicit_en_essential[] = { - (*prcm)->cm_l4per_mcspi1_clkctrl, - (*prcm)->cm_l4per_i2c2_clkctrl, - (*prcm)->cm_l4per_i2c3_clkctrl, - (*prcm)->cm_l4per_i2c4_clkctrl, - (*prcm)->cm_l3init_hsusbtll_clkctrl, - (*prcm)->cm_l3init_hsusbhost_clkctrl, - (*prcm)->cm_l3init_fsusb_clkctrl, - 0 - }; - - do_enable_clocks(clk_domains_essential, - clk_modules_hw_auto_essential, - clk_modules_explicit_en_essential, - 1); -} - -/* - * Enable non-essential clock domains, modules and - * do some additional special settings needed - */ -void enable_non_essential_clocks(void) -{ - u32 const clk_domains_non_essential[] = { - (*prcm)->cm_mpu_m3_clkstctrl, - (*prcm)->cm_ivahd_clkstctrl, - (*prcm)->cm_dsp_clkstctrl, - (*prcm)->cm_dss_clkstctrl, - (*prcm)->cm_sgx_clkstctrl, - (*prcm)->cm1_abe_clkstctrl, - (*prcm)->cm_c2c_clkstctrl, - (*prcm)->cm_cam_clkstctrl, - (*prcm)->cm_dss_clkstctrl, - (*prcm)->cm_sdma_clkstctrl, - 0 - }; - - u32 const clk_modules_hw_auto_non_essential[] = { - (*prcm)->cm_mpu_m3_mpu_m3_clkctrl, - (*prcm)->cm_ivahd_ivahd_clkctrl, - (*prcm)->cm_ivahd_sl2_clkctrl, - (*prcm)->cm_dsp_dsp_clkctrl, - (*prcm)->cm_l3instr_l3_3_clkctrl, - (*prcm)->cm_l3instr_l3_instr_clkctrl, - (*prcm)->cm_l3instr_intrconn_wp1_clkctrl, - (*prcm)->cm_l3init_hsi_clkctrl, - (*prcm)->cm_l4per_hdq1w_clkctrl, - 0 - }; - - u32 const clk_modules_explicit_en_non_essential[] = { - (*prcm)->cm1_abe_aess_clkctrl, - (*prcm)->cm1_abe_pdm_clkctrl, - (*prcm)->cm1_abe_dmic_clkctrl, - (*prcm)->cm1_abe_mcasp_clkctrl, - (*prcm)->cm1_abe_mcbsp1_clkctrl, - (*prcm)->cm1_abe_mcbsp2_clkctrl, - (*prcm)->cm1_abe_mcbsp3_clkctrl, - (*prcm)->cm1_abe_slimbus_clkctrl, - (*prcm)->cm1_abe_timer5_clkctrl, - (*prcm)->cm1_abe_timer6_clkctrl, - (*prcm)->cm1_abe_timer7_clkctrl, - (*prcm)->cm1_abe_timer8_clkctrl, - (*prcm)->cm1_abe_wdt3_clkctrl, - (*prcm)->cm_l4per_gptimer9_clkctrl, - (*prcm)->cm_l4per_gptimer10_clkctrl, - (*prcm)->cm_l4per_gptimer11_clkctrl, - (*prcm)->cm_l4per_gptimer3_clkctrl, - (*prcm)->cm_l4per_gptimer4_clkctrl, - (*prcm)->cm_l4per_mcspi2_clkctrl, - (*prcm)->cm_l4per_mcspi3_clkctrl, - (*prcm)->cm_l4per_mcspi4_clkctrl, - (*prcm)->cm_l4per_mmcsd3_clkctrl, - (*prcm)->cm_l4per_mmcsd4_clkctrl, - (*prcm)->cm_l4per_mmcsd5_clkctrl, - (*prcm)->cm_l4per_uart1_clkctrl, - (*prcm)->cm_l4per_uart2_clkctrl, - (*prcm)->cm_l4per_uart4_clkctrl, - (*prcm)->cm_wkup_keyboard_clkctrl, - (*prcm)->cm_wkup_wdtimer2_clkctrl, - (*prcm)->cm_cam_iss_clkctrl, - (*prcm)->cm_cam_fdif_clkctrl, - (*prcm)->cm_dss_dss_clkctrl, - (*prcm)->cm_sgx_sgx_clkctrl, - 0 - }; - - /* Enable optional functional clock for ISS */ - setbits_le32((*prcm)->cm_cam_iss_clkctrl, ISS_CLKCTRL_OPTFCLKEN_MASK); - - /* Enable all optional functional clocks of DSS */ - setbits_le32((*prcm)->cm_dss_dss_clkctrl, DSS_CLKCTRL_OPTFCLKEN_MASK); - - do_enable_clocks(clk_domains_non_essential, - clk_modules_hw_auto_non_essential, - clk_modules_explicit_en_non_essential, - 0); - - /* Put camera module in no sleep mode */ - clrsetbits_le32((*prcm)->cm_cam_clkstctrl, - MODULE_CLKCTRL_MODULEMODE_MASK, - CD_CLKCTRL_CLKTRCTRL_NO_SLEEP << - MODULE_CLKCTRL_MODULEMODE_SHIFT); -} diff --git a/arch/arm/cpu/armv7/omap5/hw_data.c b/arch/arm/cpu/armv7/omap5/hw_data.c index 0f1234c..df375f9 100644 --- a/arch/arm/cpu/armv7/omap5/hw_data.c +++ b/arch/arm/cpu/armv7/omap5/hw_data.c @@ -27,12 +27,367 @@ */ #include <common.h> #include <asm/arch/omap.h> +#include <asm/arch/sys_proto.h> #include <asm/omap_common.h> +#include <asm/arch/clocks.h> +#include <asm/io.h>
struct prcm_regs const **prcm = (struct prcm_regs const **) OMAP_SRAM_SCRATCH_PRCM_PTR; +struct dplls const **dplls_data = + (struct dplls const **) OMAP_SRAM_SCRATCH_DPLLS_PTR; + +static const struct dpll_params mpu_dpll_params_1_5ghz[NUM_SYS_CLKS] = { + {125, 0, 1, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {625, 6, 1, -1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {625, 7, 1, -1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {750, 12, 1, -1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {625, 15, 1, -1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +static const struct dpll_params mpu_dpll_params_2ghz[NUM_SYS_CLKS] = { + {500, 2, 1, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {2024, 16, 1, -1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {625, 5, 1, -1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {1000, 12, 1, -1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {625, 11, 1, -1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +static const struct dpll_params mpu_dpll_params_1100mhz[NUM_SYS_CLKS] = { + {275, 2, 1, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {1375, 20, 1, -1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {1375, 23, 1, -1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {550, 12, 1, -1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {1375, 47, 1, -1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +static const struct dpll_params mpu_dpll_params_800mhz[NUM_SYS_CLKS] = { + {200, 2, 1, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {1000, 20, 1, -1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {375, 8, 1, -1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {400, 12, 1, -1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {375, 17, 1, -1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +static const struct dpll_params mpu_dpll_params_400mhz[NUM_SYS_CLKS] = { + {200, 2, 2, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {1000, 20, 2, -1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {375, 8, 2, -1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {400, 12, 2, -1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {375, 17, 2, -1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +static const struct dpll_params mpu_dpll_params_550mhz[NUM_SYS_CLKS] = { + {275, 2, 2, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {1375, 20, 2, -1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {1375, 23, 2, -1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {550, 12, 2, -1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {1375, 47, 2, -1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +static const struct dpll_params + core_dpll_params_2128mhz_ddr532[NUM_SYS_CLKS] = { + {266, 2, 2, 5, 8, 4, 62, 5, 5, 7}, /* 12 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {570, 8, 2, 5, 8, 4, 62, 5, 5, 7}, /* 16.8 MHz */ + {665, 11, 2, 5, 8, 4, 62, 5, 5, 7}, /* 19.2 MHz */ + {532, 12, 2, 5, 8, 4, 62, 5, 5, 7}, /* 26 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {665, 23, 2, 5, 8, 4, 62, 5, 5, 7} /* 38.4 MHz */ +}; + +static const struct dpll_params + core_dpll_params_2128mhz_ddr266[NUM_SYS_CLKS] = { + {266, 2, 4, 5, 8, 8, 62, 10, 10, 14}, /* 12 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {570, 8, 4, 5, 8, 8, 62, 10, 10, 14}, /* 16.8 MHz */ + {665, 11, 4, 5, 8, 8, 62, 10, 10, 14}, /* 19.2 MHz */ + {532, 12, 4, 8, 8, 8, 62, 10, 10, 14}, /* 26 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {665, 23, 4, 8, 8, 8, 62, 10, 10, 14} /* 38.4 MHz */ +}; + +static const struct dpll_params per_dpll_params_768mhz[NUM_SYS_CLKS] = { + {32, 0, 4, 3, 6, 4, -1, 2, -1, -1}, /* 12 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {160, 6, 4, 3, 6, 4, -1, 2, -1, -1}, /* 16.8 MHz */ + {20, 0, 4, 3, 6, 4, -1, 2, -1, -1}, /* 19.2 MHz */ + {192, 12, 4, 3, 6, 4, -1, 2, -1, -1}, /* 26 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {10, 0, 4, 3, 6, 4, -1, 2, -1, -1} /* 38.4 MHz */ +}; + +static const struct dpll_params iva_dpll_params_2330mhz[NUM_SYS_CLKS] = { + {1165, 11, -1, -1, 5, 6, -1, -1, -1, -1}, /* 12 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {2011, 28, -1, -1, 5, 6, -1, -1, -1, -1}, /* 16.8 MHz */ + {1881, 30, -1, -1, 5, 6, -1, -1, -1, -1}, /* 19.2 MHz */ + {1165, 25, -1, -1, 5, 6, -1, -1, -1, -1}, /* 26 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {1972, 64, -1, -1, 5, 6, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +/* ABE M & N values with sys_clk as source */ +static const struct dpll_params + abe_dpll_params_sysclk_196608khz[NUM_SYS_CLKS] = { + {49, 5, 1, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {35, 5, 1, 1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {46, 8, 1, 1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {34, 8, 1, 1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {64, 24, 1, 1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +/* ABE M & N values with 32K clock as source */ +static const struct dpll_params abe_dpll_params_32k_196608khz = { + 750, 0, 1, 1, -1, -1, -1, -1, -1, -1 +}; + +static const struct dpll_params usb_dpll_params_1920mhz[NUM_SYS_CLKS] = { + {400, 4, 2, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {400, 6, 2, -1, -1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {400, 7, 2, -1, -1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {480, 12, 2, -1, -1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {-1, -1, -1, -1, -1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {400, 15, 2, -1, -1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +struct dplls omap5_dplls_es1 = { + .mpu = mpu_dpll_params_800mhz, + .core = core_dpll_params_2128mhz_ddr532, + .per = per_dpll_params_768mhz, + .iva = iva_dpll_params_2330mhz, +#ifdef CONFIG_SYS_OMAP_ABE_SYSCK + .abe = abe_dpll_params_sysclk_196608khz, +#else + .abe = &abe_dpll_params_32k_196608khz, +#endif + .usb = usb_dpll_params_1920mhz +}; + +/* + * Enable essential clock domains, modules and + * do some additional special settings needed + */ +void enable_basic_clocks(void) +{ + u32 const clk_domains_essential[] = { + (*prcm)->cm_l4per_clkstctrl, + (*prcm)->cm_l3init_clkstctrl, + (*prcm)->cm_memif_clkstctrl, + (*prcm)->cm_l4cfg_clkstctrl, + 0 + }; + + u32 const clk_modules_hw_auto_essential[] = { + (*prcm)->cm_l3_2_gpmc_clkctrl, + (*prcm)->cm_memif_emif_1_clkctrl, + (*prcm)->cm_memif_emif_2_clkctrl, + (*prcm)->cm_l4cfg_l4_cfg_clkctrl, + (*prcm)->cm_wkup_gpio1_clkctrl, + (*prcm)->cm_l4per_gpio2_clkctrl, + (*prcm)->cm_l4per_gpio3_clkctrl, + (*prcm)->cm_l4per_gpio4_clkctrl, + (*prcm)->cm_l4per_gpio5_clkctrl, + (*prcm)->cm_l4per_gpio6_clkctrl, + 0 + }; + + u32 const clk_modules_explicit_en_essential[] = { + (*prcm)->cm_wkup_gptimer1_clkctrl, + (*prcm)->cm_l3init_hsmmc1_clkctrl, + (*prcm)->cm_l3init_hsmmc2_clkctrl, + (*prcm)->cm_l4per_gptimer2_clkctrl, + (*prcm)->cm_wkup_wdtimer2_clkctrl, + (*prcm)->cm_l4per_uart3_clkctrl, + (*prcm)->cm_l4per_i2c1_clkctrl, + 0 + }; + + /* Enable optional additional functional clock for GPIO4 */ + setbits_le32((*prcm)->cm_l4per_gpio4_clkctrl, + GPIO4_CLKCTRL_OPTFCLKEN_MASK); + + /* Enable 96 MHz clock for MMC1 & MMC2 */ + setbits_le32((*prcm)->cm_l3init_hsmmc1_clkctrl, + HSMMC_CLKCTRL_CLKSEL_MASK); + setbits_le32((*prcm)->cm_l3init_hsmmc2_clkctrl, + HSMMC_CLKCTRL_CLKSEL_MASK); + + /* Set the correct clock dividers for mmc */ + setbits_le32((*prcm)->cm_l3init_hsmmc1_clkctrl, + HSMMC_CLKCTRL_CLKSEL_DIV_MASK); + setbits_le32((*prcm)->cm_l3init_hsmmc2_clkctrl, + HSMMC_CLKCTRL_CLKSEL_DIV_MASK); + + /* Select 32KHz clock as the source of GPTIMER1 */ + setbits_le32((*prcm)->cm_wkup_gptimer1_clkctrl, + GPTIMER1_CLKCTRL_CLKSEL_MASK); + + do_enable_clocks(clk_domains_essential, + clk_modules_hw_auto_essential, + clk_modules_explicit_en_essential, + 1); + + /* Select 384Mhz for GPU as its the POR for ES1.0 */ + setbits_le32((*prcm)->cm_sgx_sgx_clkctrl, + CLKSEL_GPU_HYD_GCLK_MASK); + setbits_le32((*prcm)->cm_sgx_sgx_clkctrl, + CLKSEL_GPU_CORE_GCLK_MASK); + + /* Enable SCRM OPT clocks for PER and CORE dpll */ + setbits_le32((*prcm)->cm_wkupaon_scrm_clkctrl, + OPTFCLKEN_SCRM_PER_MASK); + setbits_le32((*prcm)->cm_wkupaon_scrm_clkctrl, + OPTFCLKEN_SCRM_CORE_MASK); +} + +void enable_basic_uboot_clocks(void) +{ + u32 const clk_domains_essential[] = { + 0 + }; + + u32 const clk_modules_hw_auto_essential[] = { + 0 + }; + + u32 const clk_modules_explicit_en_essential[] = { + (*prcm)->cm_l4per_mcspi1_clkctrl, + (*prcm)->cm_l4per_i2c2_clkctrl, + (*prcm)->cm_l4per_i2c3_clkctrl, + (*prcm)->cm_l4per_i2c4_clkctrl, + (*prcm)->cm_l3init_hsusbtll_clkctrl, + (*prcm)->cm_l3init_hsusbhost_clkctrl, + (*prcm)->cm_l3init_fsusb_clkctrl, + 0 + }; + + do_enable_clocks(clk_domains_essential, + clk_modules_hw_auto_essential, + clk_modules_explicit_en_essential, + 1); +} + +/* + * Enable non-essential clock domains, modules and + * do some additional special settings needed + */ +void enable_non_essential_clocks(void) +{ + u32 const clk_domains_non_essential[] = { + (*prcm)->cm_mpu_m3_clkstctrl, + (*prcm)->cm_ivahd_clkstctrl, + (*prcm)->cm_dsp_clkstctrl, + (*prcm)->cm_dss_clkstctrl, + (*prcm)->cm_sgx_clkstctrl, + (*prcm)->cm1_abe_clkstctrl, + (*prcm)->cm_c2c_clkstctrl, + (*prcm)->cm_cam_clkstctrl, + (*prcm)->cm_dss_clkstctrl, + (*prcm)->cm_sdma_clkstctrl, + 0 + }; + + u32 const clk_modules_hw_auto_non_essential[] = { + (*prcm)->cm_mpu_m3_mpu_m3_clkctrl, + (*prcm)->cm_ivahd_ivahd_clkctrl, + (*prcm)->cm_ivahd_sl2_clkctrl, + (*prcm)->cm_dsp_dsp_clkctrl, + (*prcm)->cm_l3instr_l3_3_clkctrl, + (*prcm)->cm_l3instr_l3_instr_clkctrl, + (*prcm)->cm_l3instr_intrconn_wp1_clkctrl, + (*prcm)->cm_l3init_hsi_clkctrl, + (*prcm)->cm_l4per_hdq1w_clkctrl, + 0 + }; + + u32 const clk_modules_explicit_en_non_essential[] = { + (*prcm)->cm1_abe_aess_clkctrl, + (*prcm)->cm1_abe_pdm_clkctrl, + (*prcm)->cm1_abe_dmic_clkctrl, + (*prcm)->cm1_abe_mcasp_clkctrl, + (*prcm)->cm1_abe_mcbsp1_clkctrl, + (*prcm)->cm1_abe_mcbsp2_clkctrl, + (*prcm)->cm1_abe_mcbsp3_clkctrl, + (*prcm)->cm1_abe_slimbus_clkctrl, + (*prcm)->cm1_abe_timer5_clkctrl, + (*prcm)->cm1_abe_timer6_clkctrl, + (*prcm)->cm1_abe_timer7_clkctrl, + (*prcm)->cm1_abe_timer8_clkctrl, + (*prcm)->cm1_abe_wdt3_clkctrl, + (*prcm)->cm_l4per_gptimer9_clkctrl, + (*prcm)->cm_l4per_gptimer10_clkctrl, + (*prcm)->cm_l4per_gptimer11_clkctrl, + (*prcm)->cm_l4per_gptimer3_clkctrl, + (*prcm)->cm_l4per_gptimer4_clkctrl, + (*prcm)->cm_l4per_mcspi2_clkctrl, + (*prcm)->cm_l4per_mcspi3_clkctrl, + (*prcm)->cm_l4per_mcspi4_clkctrl, + (*prcm)->cm_l4per_mmcsd3_clkctrl, + (*prcm)->cm_l4per_mmcsd4_clkctrl, + (*prcm)->cm_l4per_mmcsd5_clkctrl, + (*prcm)->cm_l4per_uart1_clkctrl, + (*prcm)->cm_l4per_uart2_clkctrl, + (*prcm)->cm_l4per_uart4_clkctrl, + (*prcm)->cm_wkup_keyboard_clkctrl, + (*prcm)->cm_wkup_wdtimer2_clkctrl, + (*prcm)->cm_cam_iss_clkctrl, + (*prcm)->cm_cam_fdif_clkctrl, + (*prcm)->cm_dss_dss_clkctrl, + (*prcm)->cm_sgx_sgx_clkctrl, + 0 + }; + + /* Enable optional functional clock for ISS */ + setbits_le32((*prcm)->cm_cam_iss_clkctrl, ISS_CLKCTRL_OPTFCLKEN_MASK); + + /* Enable all optional functional clocks of DSS */ + setbits_le32((*prcm)->cm_dss_dss_clkctrl, DSS_CLKCTRL_OPTFCLKEN_MASK); + + do_enable_clocks(clk_domains_non_essential, + clk_modules_hw_auto_non_essential, + clk_modules_explicit_en_non_essential, + 0); + + /* Put camera module in no sleep mode */ + clrsetbits_le32((*prcm)->cm_cam_clkstctrl, + MODULE_CLKCTRL_MODULEMODE_MASK, + CD_CLKCTRL_CLKTRCTRL_NO_SLEEP << + MODULE_CLKCTRL_MODULEMODE_SHIFT); +}
void hw_data_init(void) { + u32 omap_rev = omap_revision(); + + switch (omap_rev) { + + case OMAP5430_ES1_0: *prcm = &omap5_es1_prcm; + *dplls_data = &omap5_dplls_es1; + break; + + case OMAP5432_ES1_0: + *prcm = &omap5_es1_prcm; + *dplls_data = &omap5_dplls_es1; + break; + + default: + printf("\n INVALID OMAP REVISION "); + } } diff --git a/arch/arm/include/asm/arch-omap4/clocks.h b/arch/arm/include/asm/arch-omap4/clocks.h index 4710d88..ceb3367 100644 --- a/arch/arm/include/asm/arch-omap4/clocks.h +++ b/arch/arm/include/asm/arch-omap4/clocks.h @@ -242,55 +242,10 @@ #define DPLL_NO_LOCK 0 #define DPLL_LOCK 1
-#define NUM_SYS_CLKS 7 - -struct dpll_regs { - u32 cm_clkmode_dpll; - u32 cm_idlest_dpll; - u32 cm_autoidle_dpll; - u32 cm_clksel_dpll; - u32 cm_div_m2_dpll; - u32 cm_div_m3_dpll; - u32 cm_div_m4_dpll; - u32 cm_div_m5_dpll; - u32 cm_div_m6_dpll; - u32 cm_div_m7_dpll; -}; - -/* DPLL parameter table */ -struct dpll_params { - u32 m; - u32 n; - s8 m2; - s8 m3; - s8 m4; - s8 m5; - s8 m6; - s8 m7; -}; - -extern const u32 sys_clk_array[8]; - void scale_vcores(void); void do_scale_tps62361(int gpio, u32 reg, u32 volt_mv); u32 get_offset_code(u32 offset); -u32 omap_ddr_clk(void); void do_scale_vcore(u32 vcore_reg, u32 volt_mv); -void setup_post_dividers(u32 const base, const struct dpll_params *params); -u32 get_sys_clk_index(void); -void enable_basic_clocks(void); -void enable_basic_uboot_clocks(void); -void enable_non_essential_clocks(void); -void do_enable_clocks(u32 const *clk_domains, - u32 const *clk_modules_hw_auto, - u32 const *clk_modules_explicit_en, - u8 wait_for_enable); -const struct dpll_params *get_mpu_dpll_params(void); -const struct dpll_params *get_core_dpll_params(void); -const struct dpll_params *get_per_dpll_params(void); -const struct dpll_params *get_iva_dpll_params(void); -const struct dpll_params *get_usb_dpll_params(void); -const struct dpll_params *get_abe_dpll_params(void);
struct omap4_scrm_regs { u32 revision; /* 0x0000 */ diff --git a/arch/arm/include/asm/arch-omap4/omap.h b/arch/arm/include/asm/arch-omap4/omap.h index 86ba335..1c0ce9b 100644 --- a/arch/arm/include/asm/arch-omap4/omap.h +++ b/arch/arm/include/asm/arch-omap4/omap.h @@ -179,7 +179,8 @@ struct control_lpddr2io_regs { #define OMAP4_SRAM_SCRATCH_EMIF_T_NUM (SRAM_SCRATCH_SPACE_ADDR + 0xC) #define OMAP4_SRAM_SCRATCH_EMIF_T_DEN (SRAM_SCRATCH_SPACE_ADDR + 0x10) #define OMAP_SRAM_SCRATCH_PRCM_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x14) -#define OMAP4_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x18) +#define OMAP_SRAM_SCRATCH_DPLLS_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x18) +#define OMAP4_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x1C)
/* ROM code defines */ /* Boot device */ diff --git a/arch/arm/include/asm/arch-omap5/clocks.h b/arch/arm/include/asm/arch-omap5/clocks.h index 67e74ca..063347f 100644 --- a/arch/arm/include/asm/arch-omap5/clocks.h +++ b/arch/arm/include/asm/arch-omap5/clocks.h @@ -234,58 +234,8 @@ #define DPLL_NO_LOCK 0 #define DPLL_LOCK 1
-#define NUM_SYS_CLKS 7 - -struct dpll_regs { - u32 cm_clkmode_dpll; - u32 cm_idlest_dpll; - u32 cm_autoidle_dpll; - u32 cm_clksel_dpll; - u32 cm_div_m2_dpll; - u32 cm_div_m3_dpll; - u32 cm_div_h11_dpll; - u32 cm_div_h12_dpll; - u32 cm_div_h13_dpll; - u32 cm_div_h14_dpll; - u32 reserved[3]; - u32 cm_div_h22_dpll; - u32 cm_div_h23_dpll; -}; - -/* DPLL parameter table */ -struct dpll_params { - u32 m; - u32 n; - s8 m2; - s8 m3; - s8 h11; - s8 h12; - s8 h13; - s8 h14; - s8 h22; - s8 h23; -}; - -extern const u32 sys_clk_array[8]; - void scale_vcores(void); void do_scale_tps62361(int gpio, u32 reg, u32 volt_mv); u32 get_offset_code(u32 offset); -u32 omap_ddr_clk(void); void do_scale_vcore(u32 vcore_reg, u32 volt_mv); -void setup_post_dividers(u32 const base, const struct dpll_params *params); -u32 get_sys_clk_index(void); -void enable_basic_clocks(void); -void enable_non_essential_clocks(void); -void enable_basic_uboot_clocks(void); -void do_enable_clocks(u32 const *clk_domains, - u32 const *clk_modules_hw_auto, - u32 const *clk_modules_explicit_en, - u8 wait_for_enable); -const struct dpll_params *get_mpu_dpll_params(void); -const struct dpll_params *get_core_dpll_params(void); -const struct dpll_params *get_per_dpll_params(void); -const struct dpll_params *get_iva_dpll_params(void); -const struct dpll_params *get_usb_dpll_params(void); -const struct dpll_params *get_abe_dpll_params(void); #endif /* _CLOCKS_OMAP5_H_ */ diff --git a/arch/arm/include/asm/arch-omap5/omap.h b/arch/arm/include/asm/arch-omap5/omap.h index 50e055e..7123694 100644 --- a/arch/arm/include/asm/arch-omap5/omap.h +++ b/arch/arm/include/asm/arch-omap5/omap.h @@ -272,7 +272,8 @@ struct omap_sys_ctrl_regs { #define OMAP5_SRAM_SCRATCH_EMIF_T_NUM (SRAM_SCRATCH_SPACE_ADDR + 0xC) #define OMAP5_SRAM_SCRATCH_EMIF_T_DEN (SRAM_SCRATCH_SPACE_ADDR + 0x10) #define OMAP_SRAM_SCRATCH_PRCM_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x14) -#define OMAP5_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x18) +#define OMAP_SRAM_SCRATCH_DPLLS_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x18) +#define OMAP5_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x1C)
/* Silicon revisions */ #define OMAP4430_SILICON_ID_INVALID 0xFFFFFFFF diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index fcf9ce5..c2d8388 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -27,6 +27,8 @@
#include <common.h>
+#define NUM_SYS_CLKS 7 + struct prcm_regs { /* cm1.ckgen */ u32 cm_clksel_core; @@ -324,11 +326,72 @@ struct prcm_regs { u32 prm_vc_cfg_channel; };
+struct dpll_params { + u32 m; + u32 n; + s8 m2; + s8 m3; + s8 m4_h11; + s8 m5_h12; + s8 m6_h13; + s8 m7_h14; + s8 h22; + s8 h23; +}; + +struct dpll_regs { + u32 cm_clkmode_dpll; + u32 cm_idlest_dpll; + u32 cm_autoidle_dpll; + u32 cm_clksel_dpll; + u32 cm_div_m2_dpll; + u32 cm_div_m3_dpll; + u32 cm_div_m4_h11_dpll; + u32 cm_div_m5_h12_dpll; + u32 cm_div_m6_h13_dpll; + u32 cm_div_m7_h14_dpll; + u32 reserved[3]; + u32 cm_div_h22_dpll; + u32 cm_div_h23_dpll; +}; + +struct dplls { + const struct dpll_params *mpu; + const struct dpll_params *core; + const struct dpll_params *per; + const struct dpll_params *abe; + const struct dpll_params *iva; + const struct dpll_params *usb; +}; + extern struct prcm_regs const **prcm; extern struct prcm_regs const omap5_es1_prcm; extern struct prcm_regs const omap4_prcm; +extern struct dplls const **dplls_data; +extern const u32 sys_clk_array[8];
void hw_data_init(void); + +const struct dpll_params *get_mpu_dpll_params(struct dplls const *); +const struct dpll_params *get_core_dpll_params(struct dplls const *); +const struct dpll_params *get_per_dpll_params(struct dplls const *); +const struct dpll_params *get_iva_dpll_params(struct dplls const *); +const struct dpll_params *get_usb_dpll_params(struct dplls const *); +const struct dpll_params *get_abe_dpll_params(struct dplls const *); + +void do_enable_clocks(u32 const *clk_domains, + u32 const *clk_modules_hw_auto, + u32 const *clk_modules_explicit_en, + u8 wait_for_enable); + +void setup_post_dividers(u32 const base, + const struct dpll_params *params); +u32 omap_ddr_clk(void); +u32 get_sys_clk_index(void); +void enable_basic_clocks(void); +void enable_basic_uboot_clocks(void); +void enable_non_essential_clocks(void); + /* Max value for DPLL multiplier M */ #define OMAP_DPLL_MAX_N 127
On Mon, Feb 04, 2013 at 07:52:01PM +0530, R Sricharan wrote:
Currently there is quite a lot of code which is duplicated in the clocks code for OMAP 4 and 5 Socs. Avoiding this here by moving the clocks data to a SOC specific place and the sharing the common code.
This helps in addition of a new Soc with minimal changes.
Signed-off-by: R Sricharan r.sricharan@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com
Reviewed-by: Tom Rini trini@ti.com
The pmic code is duplicated for OMAP 4 and 5. Instead move the data to Soc specific place and share the code.
Signed-off-by: R Sricharan r.sricharan@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- [V2] Addressed Tom Rini's trini@ti.com comments
arch/arm/cpu/armv7/omap-common/clocks-common.c | 83 +++++++++++----- arch/arm/cpu/armv7/omap4/Makefile | 1 - arch/arm/cpu/armv7/omap4/clocks.c | 123 ------------------------ arch/arm/cpu/armv7/omap4/hw_data.c | 70 ++++++++++++++ arch/arm/cpu/armv7/omap5/Makefile | 1 - arch/arm/cpu/armv7/omap5/clocks.c | 98 ------------------- arch/arm/cpu/armv7/omap5/hw_data.c | 43 +++++++++ arch/arm/include/asm/arch-omap4/clocks.h | 5 - arch/arm/include/asm/arch-omap4/omap.h | 3 +- arch/arm/include/asm/arch-omap5/clocks.h | 4 - arch/arm/include/asm/arch-omap5/omap.h | 3 +- arch/arm/include/asm/omap_common.h | 24 +++++ include/configs/omap5_evm.h | 1 + 13 files changed, 199 insertions(+), 260 deletions(-) delete mode 100644 arch/arm/cpu/armv7/omap4/clocks.c delete mode 100644 arch/arm/cpu/armv7/omap5/clocks.c
diff --git a/arch/arm/cpu/armv7/omap-common/clocks-common.c b/arch/arm/cpu/armv7/omap-common/clocks-common.c index 2becc4a..88e5336 100644 --- a/arch/arm/cpu/armv7/omap-common/clocks-common.c +++ b/arch/arm/cpu/armv7/omap-common/clocks-common.c @@ -443,44 +443,45 @@ static void setup_non_essential_dplls(void) } #endif
-void do_scale_tps62361(int gpio, u32 reg, u32 volt_mv) +u32 get_offset_code(u32 volt_offset, struct pmic_data *pmic) { - u32 step; - int ret = 0; - - /* See if we can first get the GPIO if needed */ - if (gpio >= 0) - ret = gpio_request(gpio, "TPS62361_VSEL0_GPIO"); - if (ret < 0) { - printf("%s: gpio %d request failed %d\n", __func__, gpio, ret); - gpio = -1; - } - - /* Pull the GPIO low to select SET0 register, while we program SET1 */ - if (gpio >= 0) - gpio_direction_output(gpio, 0); + u32 offset_code;
- step = volt_mv - TPS62361_BASE_VOLT_MV; - step /= 10; + volt_offset -= pmic->base_offset;
- debug("do_scale_tps62361: volt - %d step - 0x%x\n", volt_mv, step); - if (omap_vc_bypass_send_value(TPS62361_I2C_SLAVE_ADDR, reg, step)) - puts("Scaling voltage failed for vdd_mpu from TPS\n"); + offset_code = (volt_offset + pmic->step - 1) / pmic->step;
- /* Pull the GPIO high to select SET1 register */ - if (gpio >= 0) - gpio_direction_output(gpio, 1); + /* + * Offset codes 1-6 all give the base voltage in Palmas + * Offset code 0 switches OFF the SMPS + */ + return offset_code + pmic->start_code; }
-void do_scale_vcore(u32 vcore_reg, u32 volt_mv) +void do_scale_vcore(u32 vcore_reg, u32 volt_mv, struct pmic_data *pmic) { u32 offset_code; u32 offset = volt_mv; + int ret = 0; + + /* See if we can first get the GPIO if needed */ + if (pmic->gpio_en) + ret = gpio_request(pmic->gpio, "PMIC_GPIO"); + + if (ret < 0) { + printf("%s: gpio %d request failed %d\n", __func__, + pmic->gpio, ret); + return; + } + + /* Pull the GPIO low to select SET0 register, while we program SET1 */ + if (pmic->gpio_en) + gpio_direction_output(pmic->gpio, 0);
/* convert to uV for better accuracy in the calculations */ offset *= 1000;
- offset_code = get_offset_code(offset); + offset_code = get_offset_code(offset, pmic);
debug("do_scale_vcore: volt - %d offset_code - 0x%x\n", volt_mv, offset_code); @@ -488,6 +489,36 @@ void do_scale_vcore(u32 vcore_reg, u32 volt_mv) if (omap_vc_bypass_send_value(SMPS_I2C_SLAVE_ADDR, vcore_reg, offset_code)) printf("Scaling voltage failed for 0x%x\n", vcore_reg); + + if (pmic->gpio_en) + gpio_direction_output(pmic->gpio, 1); +} + +/* + * Setup the voltages for vdd_mpu, vdd_core, and vdd_iva + * We set the maximum voltages allowed here because Smart-Reflex is not + * enabled in bootloader. Voltage initialization in the kernel will set + * these to the nominal values after enabling Smart-Reflex + */ +void scale_vcores(struct vcores_data const *vcores) +{ + omap_vc_init(PRM_VC_I2C_CHANNEL_FREQ_KHZ); + + do_scale_vcore(vcores->core.addr, vcores->core.value, + vcores->core.pmic); + + do_scale_vcore(vcores->mpu.addr, vcores->mpu.value, + vcores->mpu.pmic); + + do_scale_vcore(vcores->mm.addr, vcores->mm.value, + vcores->mm.pmic); + + if (emif_sdram_type() == EMIF_SDRAM_TYPE_DDR3) { + /* Configure LDO SRAM "magic" bits */ + writel(2, (*prcm)->prm_sldo_core_setup); + writel(2, (*prcm)->prm_sldo_mpu_setup); + writel(2, (*prcm)->prm_sldo_mm_setup); + } }
static inline void enable_clock_domain(u32 const clkctrl_reg, u32 enable_mode) @@ -656,7 +687,7 @@ void prcm_init(void) case OMAP_INIT_CONTEXT_UBOOT_FROM_NOR: case OMAP_INIT_CONTEXT_UBOOT_AFTER_CH: enable_basic_clocks(); - scale_vcores(); + scale_vcores(*omap_vcores); setup_dplls(); #ifdef CONFIG_SYS_CLOCKS_ENABLE_ALL setup_non_essential_dplls(); diff --git a/arch/arm/cpu/armv7/omap4/Makefile b/arch/arm/cpu/armv7/omap4/Makefile index 0365148..40808d1 100644 --- a/arch/arm/cpu/armv7/omap4/Makefile +++ b/arch/arm/cpu/armv7/omap4/Makefile @@ -27,7 +27,6 @@ LIB = $(obj)lib$(SOC).o
COBJS += sdram_elpida.o COBJS += hwinit.o -COBJS += clocks.o COBJS += emif.o COBJS += prcm-regs.o COBJS += hw_data.o diff --git a/arch/arm/cpu/armv7/omap4/clocks.c b/arch/arm/cpu/armv7/omap4/clocks.c deleted file mode 100644 index 4772743..0000000 --- a/arch/arm/cpu/armv7/omap4/clocks.c +++ /dev/null @@ -1,123 +0,0 @@ -/* - * - * Clock initialization for OMAP4 - * - * (C) Copyright 2010 - * Texas Instruments, <www.ti.com> - * - * Aneesh V aneesh@ti.com - * - * Based on previous work by: - * Santosh Shilimkar santosh.shilimkar@ti.com - * Rajendra Nayak rnayak@ti.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ -#include <common.h> -#include <asm/omap_common.h> -#include <asm/gpio.h> -#include <asm/arch/clocks.h> -#include <asm/arch/sys_proto.h> -#include <asm/utils.h> -#include <asm/omap_gpio.h> - -#ifndef CONFIG_SPL_BUILD -/* - * printing to console doesn't work unless - * this code is executed from SPL - */ -#define printf(fmt, args...) -#define puts(s) -#endif /* !CONFIG_SPL_BUILD */ - -/* - * Setup the voltages for vdd_mpu, vdd_core, and vdd_iva - * We set the maximum voltages allowed here because Smart-Reflex is not - * enabled in bootloader. Voltage initialization in the kernel will set - * these to the nominal values after enabling Smart-Reflex - */ -void scale_vcores(void) -{ - u32 volt, omap_rev; - - omap_vc_init(PRM_VC_I2C_CHANNEL_FREQ_KHZ); - - omap_rev = omap_revision(); - - /* - * Scale Voltage rails: - * 1. VDD_CORE - * 3. VDD_MPU - * 3. VDD_IVA - */ - if (omap_rev < OMAP4460_ES1_0) { - /* - * OMAP4430: - * VDD_CORE = TWL6030 VCORE3 - * VDD_MPU = TWL6030 VCORE1 - * VDD_IVA = TWL6030 VCORE2 - */ - volt = 1200; - do_scale_vcore(SMPS_REG_ADDR_VCORE3, volt); - - /* - * note on VDD_MPU: - * Setting a high voltage for Nitro mode as smart reflex is not - * enabled. We use the maximum possible value in the AVS range - * because the next higher voltage in the discrete range - * (code >= 0b111010) is way too high. - */ - volt = 1325; - do_scale_vcore(SMPS_REG_ADDR_VCORE1, volt); - volt = 1200; - do_scale_vcore(SMPS_REG_ADDR_VCORE2, volt); - - } else { - /* - * OMAP4460: - * VDD_CORE = TWL6030 VCORE1 - * VDD_MPU = TPS62361 - * VDD_IVA = TWL6030 VCORE2 - */ - volt = 1200; - do_scale_vcore(SMPS_REG_ADDR_VCORE1, volt); - /* TPS62361 */ - volt = 1203; - do_scale_tps62361(TPS62361_VSEL0_GPIO, - TPS62361_REG_ADDR_SET1, volt); - /* VCORE 2 - supplies vdd_iva */ - volt = 1200; - do_scale_vcore(SMPS_REG_ADDR_VCORE2, volt); - } -} - -u32 get_offset_code(u32 offset) -{ - u32 offset_code, step = 12660; /* 12.66 mV represented in uV */ - - if (omap_revision() == OMAP4430_ES1_0) - offset -= PHOENIX_SMPS_BASE_VOLT_STD_MODE_UV; - else - offset -= PHOENIX_SMPS_BASE_VOLT_STD_MODE_WITH_OFFSET_UV; - - offset_code = (offset + step - 1) / step; - - /* The code starts at 1 not 0 */ - return ++offset_code; -} diff --git a/arch/arm/cpu/armv7/omap4/hw_data.c b/arch/arm/cpu/armv7/omap4/hw_data.c index 6ae3986..18efa6c 100644 --- a/arch/arm/cpu/armv7/omap4/hw_data.c +++ b/arch/arm/cpu/armv7/omap4/hw_data.c @@ -30,12 +30,15 @@ #include <asm/arch/sys_proto.h> #include <asm/omap_common.h> #include <asm/arch/clocks.h> +#include <asm/omap_gpio.h> #include <asm/io.h>
struct prcm_regs const **prcm = (struct prcm_regs const **) OMAP_SRAM_SCRATCH_PRCM_PTR; struct dplls const **dplls_data = (struct dplls const **) OMAP_SRAM_SCRATCH_DPLLS_PTR; +struct vcores_data const **omap_vcores = + (struct vcores_data const **) OMAP_SRAM_SCRATCH_VCORES_PTR;
/* * The M & N values in the following tables are created using the @@ -194,6 +197,70 @@ struct dplls omap4460_dplls = { .usb = usb_dpll_params_1920mhz };
+struct pmic_data twl6030_4430es1 = { + .base_offset = PHOENIX_SMPS_BASE_VOLT_STD_MODE_UV, + .step = 12660, /* 10 mV represented in uV */ + /* The code starts at 1 not 0 */ + .start_code = 1, +}; + +struct pmic_data twl6030 = { + .base_offset = PHOENIX_SMPS_BASE_VOLT_STD_MODE_WITH_OFFSET_UV, + .step = 12660, /* 10 mV represented in uV */ + /* The code starts at 1 not 0 */ + .start_code = 1, +}; + +struct pmic_data tps62361 = { + .base_offset = TPS62361_BASE_VOLT_MV, + .step = 10000, /* 10 mV represented in uV */ + .start_code = 0, + .gpio = TPS62361_VSEL0_GPIO, + .gpio_en = 1 +}; + +struct vcores_data omap4430_volts_es1 = { + .mpu.value = 1325, + .mpu.addr = SMPS_REG_ADDR_VCORE1, + .mpu.pmic = &twl6030_4430es1, + + .core.value = 1200, + .core.addr = SMPS_REG_ADDR_VCORE3, + .core.pmic = &twl6030_4430es1, + + .mm.value = 1200, + .mm.addr = SMPS_REG_ADDR_VCORE2, + .mm.pmic = &twl6030_4430es1, +}; + +struct vcores_data omap4430_volts = { + .mpu.value = 1325, + .mpu.addr = SMPS_REG_ADDR_VCORE1, + .mpu.pmic = &twl6030, + + .core.value = 1200, + .core.addr = SMPS_REG_ADDR_VCORE3, + .core.pmic = &twl6030, + + .mm.value = 1200, + .mm.addr = SMPS_REG_ADDR_VCORE2, + .mm.pmic = &twl6030, +}; + +struct vcores_data omap4460_volts = { + .mpu.value = 1203, + .mpu.addr = TPS62361_REG_ADDR_SET1, + .mpu.pmic = &tps62361, + + .core.value = 1200, + .core.addr = SMPS_REG_ADDR_VCORE1, + .core.pmic = &tps62361, + + .mm.value = 1200, + .mm.addr = SMPS_REG_ADDR_VCORE2, + .mm.pmic = &tps62361, +}; + /* * Enable essential clock domains, modules and * do some additional special settings needed @@ -382,6 +449,7 @@ void hw_data_init(void)
case OMAP4430_ES1_0: *dplls_data = &omap4430_dplls_es1; + *omap_vcores = &omap4430_volts_es1; break;
case OMAP4430_ES2_0: @@ -389,11 +457,13 @@ void hw_data_init(void) case OMAP4430_ES2_2: case OMAP4430_ES2_3: *dplls_data = &omap4430_dplls; + *omap_vcores = &omap4430_volts; break;
case OMAP4460_ES1_0: case OMAP4460_ES1_1: *dplls_data = &omap4460_dplls; + *omap_vcores = &omap4460_volts; break;
default: diff --git a/arch/arm/cpu/armv7/omap5/Makefile b/arch/arm/cpu/armv7/omap5/Makefile index 81625f6..ce00e2c 100644 --- a/arch/arm/cpu/armv7/omap5/Makefile +++ b/arch/arm/cpu/armv7/omap5/Makefile @@ -26,7 +26,6 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(SOC).o
COBJS += hwinit.o -COBJS += clocks.o COBJS += emif.o COBJS += sdram.o COBJS += prcm-regs.o diff --git a/arch/arm/cpu/armv7/omap5/clocks.c b/arch/arm/cpu/armv7/omap5/clocks.c deleted file mode 100644 index da5b3ac..0000000 --- a/arch/arm/cpu/armv7/omap5/clocks.c +++ /dev/null @@ -1,98 +0,0 @@ -/* - * - * Clock initialization for OMAP5 - * - * (C) Copyright 2010 - * Texas Instruments, <www.ti.com> - * - * Aneesh V aneesh@ti.com - * Sricharan R r.sricharan@ti.com - * - * Based on previous work by: - * Santosh Shilimkar santosh.shilimkar@ti.com - * Rajendra Nayak rnayak@ti.com - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ -#include <common.h> -#include <asm/omap_common.h> -#include <asm/arch/clocks.h> -#include <asm/arch/sys_proto.h> -#include <asm/utils.h> -#include <asm/omap_gpio.h> -#include <asm/emif.h> - -#ifndef CONFIG_SPL_BUILD -/* - * printing to console doesn't work unless - * this code is executed from SPL - */ -#define printf(fmt, args...) -#define puts(s) -#endif - -/* - * Setup the voltages for vdd_mpu, vdd_core, and vdd_iva - * We set the maximum voltages allowed here because Smart-Reflex is not - * enabled in bootloader. Voltage initialization in the kernel will set - * these to the nominal values after enabling Smart-Reflex - */ -void scale_vcores(void) -{ - u32 volt_core, volt_mpu, volt_mm; - - omap_vc_init(PRM_VC_I2C_CHANNEL_FREQ_KHZ); - - /* Palmas settings */ - if (omap_revision() != OMAP5432_ES1_0) { - volt_core = VDD_CORE; - volt_mpu = VDD_MPU; - volt_mm = VDD_MM; - } else { - volt_core = VDD_CORE_5432; - volt_mpu = VDD_MPU_5432; - volt_mm = VDD_MM_5432; - } - - do_scale_vcore(SMPS_REG_ADDR_8_CORE, volt_core); - do_scale_vcore(SMPS_REG_ADDR_12_MPU, volt_mpu); - do_scale_vcore(SMPS_REG_ADDR_45_IVA, volt_mm); - - if (emif_sdram_type() == EMIF_SDRAM_TYPE_DDR3) { - /* Configure LDO SRAM "magic" bits */ - writel(2, (*prcm)->prm_sldo_core_setup); - writel(2, (*prcm)->prm_sldo_mpu_setup); - writel(2, (*prcm)->prm_sldo_mm_setup); - } -} - -u32 get_offset_code(u32 volt_offset) -{ - u32 offset_code, step = 10000; /* 10 mV represented in uV */ - - volt_offset -= PALMAS_SMPS_BASE_VOLT_UV; - - offset_code = (volt_offset + step - 1) / step; - - /* - * Offset codes 1-6 all give the base voltage in Palmas - * Offset code 0 switches OFF the SMPS - */ - return offset_code + 6; -} diff --git a/arch/arm/cpu/armv7/omap5/hw_data.c b/arch/arm/cpu/armv7/omap5/hw_data.c index df375f9..44fadbf 100644 --- a/arch/arm/cpu/armv7/omap5/hw_data.c +++ b/arch/arm/cpu/armv7/omap5/hw_data.c @@ -30,12 +30,15 @@ #include <asm/arch/sys_proto.h> #include <asm/omap_common.h> #include <asm/arch/clocks.h> +#include <asm/omap_gpio.h> #include <asm/io.h>
static const struct dpll_params mpu_dpll_params_1_5ghz[NUM_SYS_CLKS] = { {125, 0, 1, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ @@ -179,6 +182,44 @@ struct dplls omap5_dplls_es1 = { .usb = usb_dpll_params_1920mhz };
+struct pmic_data palmas = { + .base_offset = PALMAS_SMPS_BASE_VOLT_UV, + .step = 10000, /* 10 mV represented in uV */ + /* + * Offset codes 1-6 all give the base voltage in Palmas + * Offset code 0 switches OFF the SMPS + */ + .start_code = 6, +}; + +struct vcores_data omap5430_volts = { + .mpu.value = VDD_MPU, + .mpu.addr = SMPS_REG_ADDR_12_MPU, + .mpu.pmic = &palmas, + + .core.value = VDD_CORE, + .core.addr = SMPS_REG_ADDR_8_CORE, + .core.pmic = &palmas, + + .mm.value = VDD_MM, + .mm.addr = SMPS_REG_ADDR_45_IVA, + .mm.pmic = &palmas, +}; + +struct vcores_data omap5432_volts = { + .mpu.value = VDD_MPU_5432, + .mpu.addr = SMPS_REG_ADDR_12_MPU, + .mpu.pmic = &palmas, + + .core.value = VDD_CORE_5432, + .core.addr = SMPS_REG_ADDR_8_CORE, + .core.pmic = &palmas, + + .mm.value = VDD_MM_5432, + .mm.addr = SMPS_REG_ADDR_45_IVA, + .mm.pmic = &palmas, +}; + /* * Enable essential clock domains, modules and * do some additional special settings needed @@ -380,11 +421,13 @@ void hw_data_init(void) case OMAP5430_ES1_0: *prcm = &omap5_es1_prcm; *dplls_data = &omap5_dplls_es1; + *omap_vcores = &omap5430_volts; break;
case OMAP5432_ES1_0: *prcm = &omap5_es1_prcm; *dplls_data = &omap5_dplls_es1; + *omap_vcores = &omap5432_volts; break;
default: diff --git a/arch/arm/include/asm/arch-omap4/clocks.h b/arch/arm/include/asm/arch-omap4/clocks.h index ceb3367..ed7a1c8 100644 --- a/arch/arm/include/asm/arch-omap4/clocks.h +++ b/arch/arm/include/asm/arch-omap4/clocks.h @@ -242,11 +242,6 @@ #define DPLL_NO_LOCK 0 #define DPLL_LOCK 1
-void scale_vcores(void); -void do_scale_tps62361(int gpio, u32 reg, u32 volt_mv); -u32 get_offset_code(u32 offset); -void do_scale_vcore(u32 vcore_reg, u32 volt_mv); - struct omap4_scrm_regs { u32 revision; /* 0x0000 */ u32 pad00[63]; diff --git a/arch/arm/include/asm/arch-omap4/omap.h b/arch/arm/include/asm/arch-omap4/omap.h index 1c0ce9b..73edd9d 100644 --- a/arch/arm/include/asm/arch-omap4/omap.h +++ b/arch/arm/include/asm/arch-omap4/omap.h @@ -180,7 +180,8 @@ struct control_lpddr2io_regs { #define OMAP4_SRAM_SCRATCH_EMIF_T_DEN (SRAM_SCRATCH_SPACE_ADDR + 0x10) #define OMAP_SRAM_SCRATCH_PRCM_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x14) #define OMAP_SRAM_SCRATCH_DPLLS_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x18) -#define OMAP4_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x1C) +#define OMAP_SRAM_SCRATCH_VCORES_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x1C) +#define OMAP4_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x20)
/* ROM code defines */ /* Boot device */ diff --git a/arch/arm/include/asm/arch-omap5/clocks.h b/arch/arm/include/asm/arch-omap5/clocks.h index 063347f..15362ae 100644 --- a/arch/arm/include/asm/arch-omap5/clocks.h +++ b/arch/arm/include/asm/arch-omap5/clocks.h @@ -234,8 +234,4 @@ #define DPLL_NO_LOCK 0 #define DPLL_LOCK 1
-void scale_vcores(void); -void do_scale_tps62361(int gpio, u32 reg, u32 volt_mv); -u32 get_offset_code(u32 offset); -void do_scale_vcore(u32 vcore_reg, u32 volt_mv); #endif /* _CLOCKS_OMAP5_H_ */ diff --git a/arch/arm/include/asm/arch-omap5/omap.h b/arch/arm/include/asm/arch-omap5/omap.h index 7123694..4bf555a 100644 --- a/arch/arm/include/asm/arch-omap5/omap.h +++ b/arch/arm/include/asm/arch-omap5/omap.h @@ -273,7 +273,8 @@ struct omap_sys_ctrl_regs { #define OMAP5_SRAM_SCRATCH_EMIF_T_DEN (SRAM_SCRATCH_SPACE_ADDR + 0x10) #define OMAP_SRAM_SCRATCH_PRCM_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x14) #define OMAP_SRAM_SCRATCH_DPLLS_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x18) -#define OMAP5_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x1C) +#define OMAP_SRAM_SCRATCH_VCORES_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x1C) +#define OMAP5_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x20)
/* Silicon revisions */ #define OMAP4430_SILICON_ID_INVALID 0xFFFFFFFF diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index c2d8388..eee6893 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -364,10 +364,31 @@ struct dplls { const struct dpll_params *usb; };
+struct pmic_data { + u32 base_offset; + u32 step; + u32 start_code; + unsigned gpio; + int gpio_en; +}; + +struct volts { + u32 value; + u32 addr; + struct pmic_data *pmic; +}; + +struct vcores_data { + struct volts mpu; + struct volts core; + struct volts mm; +}; + extern struct prcm_regs const **prcm; extern struct prcm_regs const omap5_es1_prcm; extern struct prcm_regs const omap4_prcm; extern struct dplls const **dplls_data; +extern struct vcores_data const **omap_vcores; extern const u32 sys_clk_array[8];
void hw_data_init(void); @@ -391,6 +412,9 @@ u32 get_sys_clk_index(void); void enable_basic_clocks(void); void enable_basic_uboot_clocks(void); void enable_non_essential_clocks(void); +void scale_vcores(struct vcores_data const *); +u32 get_offset_code(u32 volt_offset, struct pmic_data *pmic); +void do_scale_vcore(u32 vcore_reg, u32 volt_mv, struct pmic_data *pmic);
/* Max value for DPLL multiplier M */ #define OMAP_DPLL_MAX_N 127 diff --git a/include/configs/omap5_evm.h b/include/configs/omap5_evm.h index 623da77..1d3ac2b 100644 --- a/include/configs/omap5_evm.h +++ b/include/configs/omap5_evm.h @@ -264,5 +264,6 @@ #define CONFIG_SPL_BSS_MAX_SIZE 0x100000 /* 1 MB */ #define CONFIG_SYS_SPL_MALLOC_START 0x84100000 #define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 /* 1 MB */ +#define CONFIG_SPL_GPIO_SUPPORT
#endif /* __CONFIG_H */
Removing the duplicated code in ddr3 initialization. Also creating structure for lpddr2 mode registers to avoid unnessecary revision checks.
These change reduces code addition for future Socs.
Signed-off-by: R Sricharan r.sricharan@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/cpu/armv7/omap-common/emif-common.c | 46 ++-------- arch/arm/cpu/armv7/omap4/sdram_elpida.c | 16 +++- arch/arm/cpu/armv7/omap5/sdram.c | 119 +++++++++++++++++--------- arch/arm/include/asm/emif.h | 12 ++- 4 files changed, 108 insertions(+), 85 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/emif-common.c b/arch/arm/cpu/armv7/omap-common/emif-common.c index bb37cf3..0683b9f 100644 --- a/arch/arm/cpu/armv7/omap-common/emif-common.c +++ b/arch/arm/cpu/armv7/omap-common/emif-common.c @@ -123,11 +123,13 @@ void emif_reset_phy(u32 base) static void do_lpddr2_init(u32 base, u32 cs) { u32 mr_addr; + const struct lpddr2_mr_regs *mr_regs;
+ get_lpddr2_mr_regs(&mr_regs); /* Wait till device auto initialization is complete */ while (get_mr(base, cs, LPDDR2_MR0) & LPDDR2_MR0_DAI_MASK) ; - set_mr(base, cs, LPDDR2_MR10, MR10_ZQ_ZQINIT); + set_mr(base, cs, LPDDR2_MR10, mr_regs->mr10); /* * tZQINIT = 1 us * Enough loops assuming a maximum of 2GHz @@ -135,22 +137,18 @@ static void do_lpddr2_init(u32 base, u32 cs)
sdelay(2000);
- if (omap_revision() >= OMAP5430_ES1_0) - set_mr(base, cs, LPDDR2_MR1, MR1_BL_8_BT_SEQ_WRAP_EN_NWR_8); - else - set_mr(base, cs, LPDDR2_MR1, MR1_BL_8_BT_SEQ_WRAP_EN_NWR_3); - - set_mr(base, cs, LPDDR2_MR16, MR16_REF_FULL_ARRAY); + set_mr(base, cs, LPDDR2_MR1, mr_regs->mr1); + set_mr(base, cs, LPDDR2_MR16, mr_regs->mr16);
/* * Enable refresh along with writing MR2 * Encoding of RL in MR2 is (RL - 2) */ mr_addr = LPDDR2_MR2 | EMIF_REG_REFRESH_EN_MASK; - set_mr(base, cs, mr_addr, RL_FINAL - 2); + set_mr(base, cs, mr_addr, mr_regs->mr2);
- if (omap_revision() >= OMAP5430_ES1_0) - set_mr(base, cs, LPDDR2_MR3, 0x1); + if (mr_regs->mr3 > 0) + set_mr(base, cs, LPDDR2_MR3, mr_regs->mr3); }
static void lpddr2_init(u32 base, const struct emif_regs *regs) @@ -268,9 +266,6 @@ static void ddr3_leveling(u32 base, const struct emif_regs *regs) static void ddr3_init(u32 base, const struct emif_regs *regs) { struct emif_reg_struct *emif = (struct emif_reg_struct *)base; - u32 *ext_phy_ctrl_base = 0; - u32 *emif_ext_phy_ctrl_base = 0; - u32 i = 0;
/* * Set SDRAM_CONFIG and PHY control registers to locked frequency @@ -290,27 +285,7 @@ static void ddr3_init(u32 base, const struct emif_regs *regs) writel(regs->ref_ctrl, &emif->emif_sdram_ref_ctrl); writel(regs->read_idle_ctrl, &emif->emif_read_idlectrl);
- ext_phy_ctrl_base = (u32 *) &(regs->emif_ddr_ext_phy_ctrl_1); - emif_ext_phy_ctrl_base = (u32 *) &(emif->emif_ddr_ext_phy_ctrl_1); - - /* Configure external phy control timing registers */ - for (i = 0; i < EMIF_EXT_PHY_CTRL_TIMING_REG; i++) { - writel(*ext_phy_ctrl_base, emif_ext_phy_ctrl_base++); - /* Update shadow registers */ - writel(*ext_phy_ctrl_base++, emif_ext_phy_ctrl_base++); - } - - /* - * external phy 6-24 registers do not change with - * ddr frequency - */ - for (i = 0; i < EMIF_EXT_PHY_CTRL_CONST_REG; i++) { - writel(ddr3_ext_phy_ctrl_const_base[i], - emif_ext_phy_ctrl_base++); - /* Update shadow registers */ - writel(ddr3_ext_phy_ctrl_const_base[i], - emif_ext_phy_ctrl_base++); - } + do_ext_phy_settings(base, regs);
/* enable leveling */ writel(regs->emif_rd_wr_lvl_rmp_ctl, &emif->emif_rd_wr_lvl_rmp_ctl); @@ -1109,9 +1084,6 @@ void emif_post_init_config(u32 base) struct emif_reg_struct *emif = (struct emif_reg_struct *)base; u32 omap_rev = omap_revision();
- if (omap_rev == OMAP5430_ES1_0) - return; - /* reset phy on ES2.0 */ if (omap_rev == OMAP4430_ES2_0) emif_reset_phy(base); diff --git a/arch/arm/cpu/armv7/omap4/sdram_elpida.c b/arch/arm/cpu/armv7/omap4/sdram_elpida.c index b9128fa..01da790 100644 --- a/arch/arm/cpu/armv7/omap4/sdram_elpida.c +++ b/arch/arm/cpu/armv7/omap4/sdram_elpida.c @@ -90,9 +90,6 @@ const struct emif_regs emif_regs_elpida_400_mhz_2cs = { .emif_ddr_phy_ctlr_1 = 0x049ff418 };
-/* Dummy registers for OMAP44xx */ -const u32 ddr3_ext_phy_ctrl_const_base[EMIF_EXT_PHY_CTRL_CONST_REG]; - const struct dmm_lisa_map_regs lisa_map_2G_x_1_x_2 = { .dmm_lisa_map_0 = 0xFF020100, .dmm_lisa_map_1 = 0, @@ -284,3 +281,16 @@ void emif_get_device_timings(u32 emif_nr, __attribute__((weak, alias("emif_get_device_timings_sdp")));
#endif /* CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS */ + +const struct lpddr2_mr_regs mr_regs = { + .mr1 = MR1_BL_8_BT_SEQ_WRAP_EN_NWR_3, + .mr2 = 0x4, + .mr3 = -1, + .mr10 = MR10_ZQ_ZQINIT, + .mr16 = MR16_REF_FULL_ARRAY +}; + +void get_lpddr2_mr_regs(const struct lpddr2_mr_regs **regs) +{ + *regs = &mr_regs; +} diff --git a/arch/arm/cpu/armv7/omap5/sdram.c b/arch/arm/cpu/armv7/omap5/sdram.c index 6ebdf5f..687800f 100644 --- a/arch/arm/cpu/armv7/omap5/sdram.c +++ b/arch/arm/cpu/armv7/omap5/sdram.c @@ -116,6 +116,56 @@ const struct dmm_lisa_map_regs lisa_map_4G_x_2_x_2 = { .dmm_lisa_map_3 = 0xFF020100 };
+static void emif_get_reg_dump_sdp(u32 emif_nr, const struct emif_regs **regs) +{ + switch (omap_revision()) { + case OMAP5430_ES1_0: + *regs = &emif_regs_532_mhz_2cs; + break; + case OMAP5432_ES1_0: + *regs = &emif_regs_ddr3_532_mhz_1cs; + break; + default: + *regs = &emif_regs_ddr3_532_mhz_1cs; + } +} + +void emif_get_reg_dump(u32 emif_nr, const struct emif_regs **regs) + __attribute__((weak, alias("emif_get_reg_dump_sdp"))); + +static void emif_get_dmm_regs_sdp(const struct dmm_lisa_map_regs + **dmm_lisa_regs) +{ + *dmm_lisa_regs = &lisa_map_4G_x_2_x_2; +} + +void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs) + __attribute__((weak, alias("emif_get_dmm_regs_sdp"))); +#else + +static const struct lpddr2_device_details dev_4G_S4_details = { + .type = LPDDR2_TYPE_S4, + .density = LPDDR2_DENSITY_4Gb, + .io_width = LPDDR2_IO_WIDTH_32, + .manufacturer = LPDDR2_MANUFACTURER_SAMSUNG +}; + +static void emif_get_device_details_sdp(u32 emif_nr, + struct lpddr2_device_details *cs0_device_details, + struct lpddr2_device_details *cs1_device_details) +{ + /* EMIF1 & EMIF2 have identical configuration */ + *cs0_device_details = dev_4G_S4_details; + *cs1_device_details = dev_4G_S4_details; +} + +void emif_get_device_details(u32 emif_nr, + struct lpddr2_device_details *cs0_device_details, + struct lpddr2_device_details *cs1_device_details) + __attribute__((weak, alias("emif_get_device_details_sdp"))); + +#endif /* CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS */ + const u32 ext_phy_ctrl_const_base[EMIF_EXT_PHY_CTRL_CONST_REG] = { 0x01004010, 0x00001004, @@ -138,7 +188,7 @@ const u32 ext_phy_ctrl_const_base[EMIF_EXT_PHY_CTRL_CONST_REG] = { 0x00000077 };
-const u32 ddr3_ext_phy_ctrl_const_base[EMIF_EXT_PHY_CTRL_CONST_REG] = { +const u32 ddr3_ext_phy_ctrl_const_base_es1[EMIF_EXT_PHY_CTRL_CONST_REG] = { 0x01004010, 0x00001004, 0x04010040, @@ -160,54 +210,38 @@ const u32 ddr3_ext_phy_ctrl_const_base[EMIF_EXT_PHY_CTRL_CONST_REG] = { 0x00000057 };
-static void emif_get_reg_dump_sdp(u32 emif_nr, const struct emif_regs **regs) -{ - if (omap_revision() == OMAP5432_ES1_0) - *regs = &emif_regs_ddr3_532_mhz_1cs; - else - *regs = &emif_regs_532_mhz_2cs; -} -void emif_get_reg_dump(u32 emif_nr, const struct emif_regs **regs) - __attribute__((weak, alias("emif_get_reg_dump_sdp"))); +const struct lpddr2_mr_regs mr_regs = { + .mr1 = MR1_BL_8_BT_SEQ_WRAP_EN_NWR_8, + .mr2 = 0x6, + .mr3 = 0x1, + .mr10 = MR10_ZQ_ZQINIT, + .mr16 = MR16_REF_FULL_ARRAY +};
-static void emif_get_dmm_regs_sdp(const struct dmm_lisa_map_regs - **dmm_lisa_regs) +static void emif_get_ext_phy_ctrl_const_regs(const u32 **regs) { - *dmm_lisa_regs = &lisa_map_4G_x_2_x_2; + switch (omap_revision()) { + case OMAP5430_ES1_0: + *regs = ext_phy_ctrl_const_base; + break; + case OMAP5432_ES1_0: + *regs = ddr3_ext_phy_ctrl_const_base_es1; + break; + default: + *regs = ddr3_ext_phy_ctrl_const_base_es1; + } }
-void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs) - __attribute__((weak, alias("emif_get_dmm_regs_sdp"))); - -#else - -static const struct lpddr2_device_details dev_4G_S4_details = { - .type = LPDDR2_TYPE_S4, - .density = LPDDR2_DENSITY_4Gb, - .io_width = LPDDR2_IO_WIDTH_32, - .manufacturer = LPDDR2_MANUFACTURER_SAMSUNG -}; - -static void emif_get_device_details_sdp(u32 emif_nr, - struct lpddr2_device_details *cs0_device_details, - struct lpddr2_device_details *cs1_device_details) +void get_lpddr2_mr_regs(const struct lpddr2_mr_regs **regs) { - /* EMIF1 & EMIF2 have identical configuration */ - *cs0_device_details = dev_4G_S4_details; - *cs1_device_details = dev_4G_S4_details; + *regs = &mr_regs; }
-void emif_get_device_details(u32 emif_nr, - struct lpddr2_device_details *cs0_device_details, - struct lpddr2_device_details *cs1_device_details) - __attribute__((weak, alias("emif_get_device_details_sdp"))); - -#endif /* CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS */ - void do_ext_phy_settings(u32 base, const struct emif_regs *regs) { u32 *ext_phy_ctrl_base = 0; u32 *emif_ext_phy_ctrl_base = 0; + const u32 *ext_phy_ctrl_const_regs; u32 i = 0;
struct emif_reg_struct *emif = (struct emif_reg_struct *)base; @@ -226,12 +260,13 @@ void do_ext_phy_settings(u32 base, const struct emif_regs *regs) * external phy 6-24 registers do not change with * ddr frequency */ + emif_get_ext_phy_ctrl_const_regs(&ext_phy_ctrl_const_regs); for (i = 0; i < EMIF_EXT_PHY_CTRL_CONST_REG; i++) { - writel(ext_phy_ctrl_const_base[i], - emif_ext_phy_ctrl_base++); + writel(ext_phy_ctrl_const_regs[i], + emif_ext_phy_ctrl_base++); /* Update shadow registers */ - writel(ext_phy_ctrl_const_base[i], - emif_ext_phy_ctrl_base++); + writel(ext_phy_ctrl_const_regs[i], + emif_ext_phy_ctrl_base++); } }
diff --git a/arch/arm/include/asm/emif.h b/arch/arm/include/asm/emif.h index 0824a80..fd530bb 100644 --- a/arch/arm/include/asm/emif.h +++ b/arch/arm/include/asm/emif.h @@ -698,9 +698,6 @@ struct dmm_lisa_map_regs { u32 dmm_lisa_map_3; };
-extern const u32 ext_phy_ctrl_const_base[EMIF_EXT_PHY_CTRL_CONST_REG]; -extern const u32 ddr3_ext_phy_ctrl_const_base[EMIF_EXT_PHY_CTRL_CONST_REG]; - #define CS0 0 #define CS1 1 /* The maximum frequency at which the LPDDR2 interface can operate in Hz*/ @@ -1134,6 +1131,14 @@ struct emif_regs { u32 emif_rd_wr_exec_thresh; };
+struct lpddr2_mr_regs { + s8 mr1; + s8 mr2; + s8 mr3; + s8 mr10; + s8 mr16; +}; + /* assert macros */ #if defined(DEBUG) #define emif_assert(c) ({ if (!(c)) for (;;); }) @@ -1153,6 +1158,7 @@ void emif_get_device_timings(u32 emif_nr, #endif
void do_ext_phy_settings(u32 base, const struct emif_regs *regs); +void get_lpddr2_mr_regs(const struct lpddr2_mr_regs **regs);
#ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS extern u32 *const T_num;
A seperate omap_sys_ctrl_regs structure is defined for omap4 & 5. If there is any change in control module for any of the ES versions, a new structure needs to be created. In order to remove this dependency, making the register structure generic for all the omap4+ boards.
Signed-off-by: R Sricharan r.sricharan@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/cpu/armv7/omap-common/hwinit-common.c | 5 +- arch/arm/cpu/armv7/omap4/hw_data.c | 3 + arch/arm/cpu/armv7/omap4/hwinit.c | 36 ++++----- arch/arm/cpu/armv7/omap4/prcm-regs.c | 20 +++++ arch/arm/cpu/armv7/omap5/hw_data.c | 4 + arch/arm/cpu/armv7/omap5/hwinit.c | 102 +++++++++++------------- arch/arm/cpu/armv7/omap5/prcm-regs.c | 74 +++++++++++++++++ arch/arm/include/asm/arch-omap4/omap.h | 31 +------ arch/arm/include/asm/arch-omap5/omap.h | 84 +------------------ arch/arm/include/asm/omap_common.h | 91 +++++++++++++++++++++ drivers/mmc/omap_hsmmc.c | 25 +++--- 11 files changed, 269 insertions(+), 206 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/hwinit-common.c b/arch/arm/cpu/armv7/omap-common/hwinit-common.c index 4faf120..2aec2ea 100644 --- a/arch/arm/cpu/armv7/omap-common/hwinit-common.c +++ b/arch/arm/cpu/armv7/omap-common/hwinit-common.c @@ -244,10 +244,7 @@ int checkboard(void) */ u32 get_device_type(void) { - struct omap_sys_ctrl_regs *ctrl = - (struct omap_sys_ctrl_regs *) SYSCTRL_GENERAL_CORE_BASE; - - return (readl(&ctrl->control_status) & + return (readl((*ctrl)->control_status) & (DEVICE_TYPE_MASK)) >> DEVICE_TYPE_SHIFT; }
diff --git a/arch/arm/cpu/armv7/omap4/hw_data.c b/arch/arm/cpu/armv7/omap4/hw_data.c index 18efa6c..892d016 100644 --- a/arch/arm/cpu/armv7/omap4/hw_data.c +++ b/arch/arm/cpu/armv7/omap4/hw_data.c @@ -39,6 +39,8 @@ struct dplls const **dplls_data = (struct dplls const **) OMAP_SRAM_SCRATCH_DPLLS_PTR; struct vcores_data const **omap_vcores = (struct vcores_data const **) OMAP_SRAM_SCRATCH_VCORES_PTR; +struct omap_sys_ctrl_regs const **ctrl = + (struct omap_sys_ctrl_regs const **)OMAP4_SRAM_SCRATCH_SYS_CTRL;
/* * The M & N values in the following tables are created using the @@ -470,4 +472,5 @@ void hw_data_init(void) printf("\n INVALID OMAP REVISION "); }
+ *ctrl = &omap4_ctrl; } diff --git a/arch/arm/cpu/armv7/omap4/hwinit.c b/arch/arm/cpu/armv7/omap4/hwinit.c index f4123aa..2db517b 100644 --- a/arch/arm/cpu/armv7/omap4/hwinit.c +++ b/arch/arm/cpu/armv7/omap4/hwinit.c @@ -57,10 +57,6 @@ const struct gpio_bank *const omap_gpio_bank = gpio_bank_44xx; void do_io_settings(void) { u32 lpddr2io; - struct control_lpddr2io_regs *lpddr2io_regs = - (struct control_lpddr2io_regs *)LPDDR2_IO_REGS_BASE; - struct omap_sys_ctrl_regs *const ctrl = - (struct omap_sys_ctrl_regs *)SYSCTRL_GENERAL_CORE_BASE;
u32 omap4_rev = omap_revision();
@@ -72,20 +68,20 @@ void do_io_settings(void) lpddr2io = CONTROL_LPDDR2IO_SLEW_315PS_DRV12_PULL_DOWN;
/* EMIF1 */ - writel(lpddr2io, &lpddr2io_regs->control_lpddr2io1_0); - writel(lpddr2io, &lpddr2io_regs->control_lpddr2io1_1); + writel(lpddr2io, (*ctrl)->control_lpddr2io1_0); + writel(lpddr2io, (*ctrl)->control_lpddr2io1_1); /* No pull for GR10 as per hw team's recommendation */ writel(lpddr2io & ~LPDDR2IO_GR10_WD_MASK, - &lpddr2io_regs->control_lpddr2io1_2); - writel(CONTROL_LPDDR2IO_3_VAL, &lpddr2io_regs->control_lpddr2io1_3); + (*ctrl)->control_lpddr2io1_2); + writel(CONTROL_LPDDR2IO_3_VAL, (*ctrl)->control_lpddr2io1_3);
/* EMIF2 */ - writel(lpddr2io, &lpddr2io_regs->control_lpddr2io2_0); - writel(lpddr2io, &lpddr2io_regs->control_lpddr2io2_1); + writel(lpddr2io, (*ctrl)->control_lpddr2io2_0); + writel(lpddr2io, (*ctrl)->control_lpddr2io2_1); /* No pull for GR10 as per hw team's recommendation */ writel(lpddr2io & ~LPDDR2IO_GR10_WD_MASK, - &lpddr2io_regs->control_lpddr2io2_2); - writel(CONTROL_LPDDR2IO_3_VAL, &lpddr2io_regs->control_lpddr2io2_3); + (*ctrl)->control_lpddr2io2_2); + writel(CONTROL_LPDDR2IO_3_VAL, (*ctrl)->control_lpddr2io2_3);
/* * Some of these settings (TRIM values) come from eFuse and are @@ -93,16 +89,16 @@ void do_io_settings(void) * calibration of the device. Do the software over-ride only if * the device is not correctly trimmed */ - if (!(readl(&ctrl->control_std_fuse_opp_bgap) & 0xFFFF)) { + if (!(readl((*ctrl)->control_std_fuse_opp_bgap) & 0xFFFF)) {
writel(LDOSRAM_VOLT_CTRL_OVERRIDE, - &ctrl->control_ldosram_iva_voltage_ctrl); + (*ctrl)->control_ldosram_iva_voltage_ctrl);
writel(LDOSRAM_VOLT_CTRL_OVERRIDE, - &ctrl->control_ldosram_mpu_voltage_ctrl); + (*ctrl)->control_ldosram_mpu_voltage_ctrl);
writel(LDOSRAM_VOLT_CTRL_OVERRIDE, - &ctrl->control_ldosram_core_voltage_ctrl); + (*ctrl)->control_ldosram_core_voltage_ctrl); }
/* @@ -110,11 +106,11 @@ void do_io_settings(void) * i. unconditionally for all 4430 * ii. only if un-trimmed for 4460 */ - if (!readl(&ctrl->control_efuse_1)) - writel(CONTROL_EFUSE_1_OVERRIDE, &ctrl->control_efuse_1); + if (!readl((*ctrl)->control_efuse_1)) + writel(CONTROL_EFUSE_1_OVERRIDE, (*ctrl)->control_efuse_1);
- if ((omap4_rev < OMAP4460_ES1_0) || !readl(&ctrl->control_efuse_2)) - writel(CONTROL_EFUSE_2_OVERRIDE, &ctrl->control_efuse_2); + if ((omap4_rev < OMAP4460_ES1_0) || !readl((*ctrl)->control_efuse_2)) + writel(CONTROL_EFUSE_2_OVERRIDE, (*ctrl)->control_efuse_2); } #endif /* CONFIG_SPL_BUILD */
diff --git a/arch/arm/cpu/armv7/omap4/prcm-regs.c b/arch/arm/cpu/armv7/omap4/prcm-regs.c index 815b9d2..c58ce8d 100644 --- a/arch/arm/cpu/armv7/omap4/prcm-regs.c +++ b/arch/arm/cpu/armv7/omap4/prcm-regs.c @@ -293,3 +293,23 @@ struct prcm_regs const omap4_prcm = { .prm_vc_cfg_i2c_mode = 0x4a307ba8, .prm_vc_cfg_i2c_clk = 0x4a307bac, }; + +struct omap_sys_ctrl_regs const omap4_ctrl = { + .control_id_code = 0x4A002204, + .control_std_fuse_opp_bgap = 0x4a002260, + .control_status = 0x4a0022c4, + .control_ldosram_iva_voltage_ctrl = 0x4A002320, + .control_ldosram_mpu_voltage_ctrl = 0x4A002324, + .control_ldosram_core_voltage_ctrl = 0x4A002328, + .control_pbiaslite = 0x4A100600, + .control_lpddr2io1_0 = 0x4A100638, + .control_lpddr2io1_1 = 0x4A10063C, + .control_lpddr2io1_2 = 0x4A100640, + .control_lpddr2io1_3 = 0x4A100644, + .control_lpddr2io2_0 = 0x4A100648, + .control_lpddr2io2_1 = 0x4A10064C, + .control_lpddr2io2_2 = 0x4A100650, + .control_lpddr2io2_3 = 0x4A100654, + .control_efuse_1 = 0x4A100700, + .control_efuse_2 = 0x4A100704, +}; diff --git a/arch/arm/cpu/armv7/omap5/hw_data.c b/arch/arm/cpu/armv7/omap5/hw_data.c index 44fadbf..59c2283 100644 --- a/arch/arm/cpu/armv7/omap5/hw_data.c +++ b/arch/arm/cpu/armv7/omap5/hw_data.c @@ -39,6 +39,8 @@ struct dplls const **dplls_data = (struct dplls const **) OMAP_SRAM_SCRATCH_DPLLS_PTR; struct vcores_data const **omap_vcores = (struct vcores_data const **) OMAP_SRAM_SCRATCH_VCORES_PTR; +struct omap_sys_ctrl_regs const **ctrl = + (struct omap_sys_ctrl_regs const **)OMAP5_SRAM_SCRATCH_SYS_CTRL;
static const struct dpll_params mpu_dpll_params_1_5ghz[NUM_SYS_CLKS] = { {125, 0, 1, -1, -1, -1, -1, -1, -1, -1}, /* 12 MHz */ @@ -433,4 +435,6 @@ void hw_data_init(void) default: printf("\n INVALID OMAP REVISION "); } + + *ctrl = &omap5_ctrl; } diff --git a/arch/arm/cpu/armv7/omap5/hwinit.c b/arch/arm/cpu/armv7/omap5/hwinit.c index 4def422..1863c69 100644 --- a/arch/arm/cpu/armv7/omap5/hwinit.c +++ b/arch/arm/cpu/armv7/omap5/hwinit.c @@ -56,76 +56,71 @@ const struct gpio_bank *const omap_gpio_bank = gpio_bank_54xx; /* LPDDR2 specific IO settings */ static void io_settings_lpddr2(void) { - struct omap_sys_ctrl_regs *ioregs_base = - (struct omap_sys_ctrl_regs *) SYSCTRL_GENERAL_CORE_BASE; - writel(DDR_IO_I_34OHM_SR_FASTEST_WD_DQ_NO_PULL_DQS_PULL_DOWN, - &(ioregs_base->control_ddrch1_0)); + (*ctrl)->control_ddrch1_0); writel(DDR_IO_I_34OHM_SR_FASTEST_WD_DQ_NO_PULL_DQS_PULL_DOWN, - &(ioregs_base->control_ddrch1_1)); + (*ctrl)->control_ddrch1_1); writel(DDR_IO_I_34OHM_SR_FASTEST_WD_DQ_NO_PULL_DQS_PULL_DOWN, - &(ioregs_base->control_ddrch2_0)); + (*ctrl)->control_ddrch2_0); writel(DDR_IO_I_34OHM_SR_FASTEST_WD_DQ_NO_PULL_DQS_PULL_DOWN, - &(ioregs_base->control_ddrch2_1)); + (*ctrl)->control_ddrch2_1); writel(DDR_IO_I_34OHM_SR_FASTEST_WD_CK_CKE_NCS_CA_PULL_DOWN, - &(ioregs_base->control_lpddr2ch1_0)); + (*ctrl)->control_lpddr2ch1_0); writel(DDR_IO_I_34OHM_SR_FASTEST_WD_CK_CKE_NCS_CA_PULL_DOWN, - &(ioregs_base->control_lpddr2ch1_1)); + (*ctrl)->control_lpddr2ch1_1); writel(DDR_IO_0_DDR2_DQ_INT_EN_ALL_DDR3_CA_DIS_ALL, - &(ioregs_base->control_ddrio_0)); + (*ctrl)->control_ddrio_0); writel(DDR_IO_1_DQ_OUT_EN_ALL_DQ_INT_EN_ALL, - &(ioregs_base->control_ddrio_1)); + (*ctrl)->control_ddrio_1); writel(DDR_IO_2_CA_OUT_EN_ALL_CA_INT_EN_ALL, - &(ioregs_base->control_ddrio_2)); + (*ctrl)->control_ddrio_2); }
/* DDR3 specific IO settings */ static void io_settings_ddr3(void) { u32 io_settings = 0; - struct omap_sys_ctrl_regs *ioregs_base = - (struct omap_sys_ctrl_regs *) SYSCTRL_GENERAL_CORE_BASE;
writel(DDR_IO_I_40OHM_SR_SLOWEST_WD_DQ_NO_PULL_DQS_NO_PULL, - &(ioregs_base->control_ddr3ch1_0)); + (*ctrl)->control_ddr3ch1_0); writel(DDR_IO_I_40OHM_SR_FAST_WD_DQ_NO_PULL_DQS_NO_PULL, - &(ioregs_base->control_ddrch1_0)); + (*ctrl)->control_ddrch1_0); writel(DDR_IO_I_40OHM_SR_FAST_WD_DQ_NO_PULL_DQS_NO_PULL, - &(ioregs_base->control_ddrch1_1)); + (*ctrl)->control_ddrch1_1);
writel(DDR_IO_I_40OHM_SR_SLOWEST_WD_DQ_NO_PULL_DQS_NO_PULL, - &(ioregs_base->control_ddr3ch2_0)); + (*ctrl)->control_ddr3ch2_0); writel(DDR_IO_I_40OHM_SR_FAST_WD_DQ_NO_PULL_DQS_NO_PULL, - &(ioregs_base->control_ddrch2_0)); + (*ctrl)->control_ddrch2_0); writel(DDR_IO_I_40OHM_SR_FAST_WD_DQ_NO_PULL_DQS_NO_PULL, - &(ioregs_base->control_ddrch2_1)); + (*ctrl)->control_ddrch2_1);
writel(DDR_IO_0_VREF_CELLS_DDR3_VALUE, - &(ioregs_base->control_ddrio_0)); + (*ctrl)->control_ddrio_0); writel(DDR_IO_1_VREF_CELLS_DDR3_VALUE, - &(ioregs_base->control_ddrio_1)); + (*ctrl)->control_ddrio_1); writel(DDR_IO_2_VREF_CELLS_DDR3_VALUE, - &(ioregs_base->control_ddrio_2)); + (*ctrl)->control_ddrio_2);
/* omap5432 does not use lpddr2 */ - writel(0x0, &(ioregs_base->control_lpddr2ch1_0)); - writel(0x0, &(ioregs_base->control_lpddr2ch1_1)); + writel(0x0, (*ctrl)->control_lpddr2ch1_0); + writel(0x0, (*ctrl)->control_lpddr2ch1_1);
writel(SDRAM_CONFIG_EXT_RD_LVL_11_SAMPLES, - &(ioregs_base->control_emif1_sdram_config_ext)); + (*ctrl)->control_emif1_sdram_config_ext); writel(SDRAM_CONFIG_EXT_RD_LVL_11_SAMPLES, - &(ioregs_base->control_emif2_sdram_config_ext)); + (*ctrl)->control_emif2_sdram_config_ext);
/* Disable DLL select */ - io_settings = (readl(&(ioregs_base->control_port_emif1_sdram_config)) + io_settings = (readl((*ctrl)->control_port_emif1_sdram_config) & 0xFFEFFFFF); writel(io_settings, - &(ioregs_base->control_port_emif1_sdram_config)); + (*ctrl)->control_port_emif1_sdram_config);
- io_settings = (readl(&(ioregs_base->control_port_emif2_sdram_config)) + io_settings = (readl((*ctrl)->control_port_emif2_sdram_config) & 0xFFEFFFFF); writel(io_settings, - &(ioregs_base->control_port_emif2_sdram_config)); + (*ctrl)->control_port_emif2_sdram_config); }
/* @@ -134,62 +129,60 @@ static void io_settings_ddr3(void) void do_io_settings(void) { u32 io_settings = 0, mask = 0; - struct omap_sys_ctrl_regs *ioregs_base = - (struct omap_sys_ctrl_regs *) SYSCTRL_GENERAL_CORE_BASE;
/* Impedance settings EMMC, C2C 1,2, hsi2 */ mask = (ds_mask << 2) | (ds_mask << 8) | (ds_mask << 16) | (ds_mask << 18); - io_settings = readl(&(ioregs_base->control_smart1io_padconf_0)) & + io_settings = readl((*ctrl)->control_smart1io_padconf_0) & (~mask); io_settings |= (ds_60_ohm << 8) | (ds_45_ohm << 16) | (ds_45_ohm << 18) | (ds_60_ohm << 2); - writel(io_settings, &(ioregs_base->control_smart1io_padconf_0)); + writel(io_settings, (*ctrl)->control_smart1io_padconf_0);
/* Impedance settings Mcspi2 */ mask = (ds_mask << 30); - io_settings = readl(&(ioregs_base->control_smart1io_padconf_1)) & + io_settings = readl((*ctrl)->control_smart1io_padconf_1) & (~mask); io_settings |= (ds_60_ohm << 30); - writel(io_settings, &(ioregs_base->control_smart1io_padconf_1)); + writel(io_settings, (*ctrl)->control_smart1io_padconf_1);
/* Impedance settings C2C 3,4 */ mask = (ds_mask << 14) | (ds_mask << 16); - io_settings = readl(&(ioregs_base->control_smart1io_padconf_2)) & + io_settings = readl((*ctrl)->control_smart1io_padconf_2) & (~mask); io_settings |= (ds_45_ohm << 14) | (ds_45_ohm << 16); - writel(io_settings, &(ioregs_base->control_smart1io_padconf_2)); + writel(io_settings, (*ctrl)->control_smart1io_padconf_2);
/* Slew rate settings EMMC, C2C 1,2 */ mask = (sc_mask << 8) | (sc_mask << 16) | (sc_mask << 18); - io_settings = readl(&(ioregs_base->control_smart2io_padconf_0)) & + io_settings = readl((*ctrl)->control_smart2io_padconf_0) & (~mask); io_settings |= (sc_fast << 8) | (sc_na << 16) | (sc_na << 18); - writel(io_settings, &(ioregs_base->control_smart2io_padconf_0)); + writel(io_settings, (*ctrl)->control_smart2io_padconf_0);
/* Slew rate settings hsi2, Mcspi2 */ mask = (sc_mask << 24) | (sc_mask << 28); - io_settings = readl(&(ioregs_base->control_smart2io_padconf_1)) & + io_settings = readl((*ctrl)->control_smart2io_padconf_1) & (~mask); io_settings |= (sc_fast << 28) | (sc_fast << 24); - writel(io_settings, &(ioregs_base->control_smart2io_padconf_1)); + writel(io_settings, (*ctrl)->control_smart2io_padconf_1);
/* Slew rate settings C2C 3,4 */ mask = (sc_mask << 16) | (sc_mask << 18); - io_settings = readl(&(ioregs_base->control_smart2io_padconf_2)) & + io_settings = readl((*ctrl)->control_smart2io_padconf_2) & (~mask); io_settings |= (sc_na << 16) | (sc_na << 18); - writel(io_settings, &(ioregs_base->control_smart2io_padconf_2)); + writel(io_settings, (*ctrl)->control_smart2io_padconf_2);
/* impedance and slew rate settings for usb */ mask = (usb_i_mask << 29) | (usb_i_mask << 26) | (usb_i_mask << 23) | (usb_i_mask << 20) | (usb_i_mask << 17) | (usb_i_mask << 14); - io_settings = readl(&(ioregs_base->control_smart3io_padconf_1)) & + io_settings = readl((*ctrl)->control_smart3io_padconf_1) & (~mask); io_settings |= (ds_60_ohm << 29) | (ds_60_ohm << 26) | (ds_60_ohm << 23) | (sc_fast << 20) | (sc_fast << 17) | (sc_fast << 14); - writel(io_settings, &(ioregs_base->control_smart3io_padconf_1)); + writel(io_settings, (*ctrl)->control_smart3io_padconf_1);
if (emif_sdram_type() == EMIF_SDRAM_TYPE_LPDDR2) io_settings_lpddr2(); @@ -197,25 +190,22 @@ void do_io_settings(void) io_settings_ddr3();
/* Efuse settings */ - writel(EFUSE_1, &(ioregs_base->control_efuse_1)); - writel(EFUSE_2, &(ioregs_base->control_efuse_2)); - writel(EFUSE_3, &(ioregs_base->control_efuse_3)); - writel(EFUSE_4, &(ioregs_base->control_efuse_4)); + writel(EFUSE_1, (*ctrl)->control_efuse_1); + writel(EFUSE_2, (*ctrl)->control_efuse_2); + writel(EFUSE_3, (*ctrl)->control_efuse_3); + writel(EFUSE_4, (*ctrl)->control_efuse_4); } #endif
void config_data_eye_leveling_samples(u32 emif_base) { - struct omap_sys_ctrl_regs *ioregs_base = - (struct omap_sys_ctrl_regs *) SYSCTRL_GENERAL_CORE_BASE; - /*EMIF_SDRAM_CONFIG_EXT-Read data eye leveling no of samples =4*/ if (emif_base == EMIF1_BASE) writel(SDRAM_CONFIG_EXT_RD_LVL_4_SAMPLES, - &(ioregs_base->control_emif1_sdram_config_ext)); + (*ctrl)->control_emif1_sdram_config_ext); else if (emif_base == EMIF2_BASE) writel(SDRAM_CONFIG_EXT_RD_LVL_4_SAMPLES, - &(ioregs_base->control_emif2_sdram_config_ext)); + (*ctrl)->control_emif2_sdram_config_ext); }
void init_omap_revision(void) diff --git a/arch/arm/cpu/armv7/omap5/prcm-regs.c b/arch/arm/cpu/armv7/omap5/prcm-regs.c index cdc4864..0f58b2f 100644 --- a/arch/arm/cpu/armv7/omap5/prcm-regs.c +++ b/arch/arm/cpu/armv7/omap5/prcm-regs.c @@ -304,3 +304,77 @@ struct prcm_regs const omap5_es1_prcm = { .prm_sldo_mm_setup = 0x4ae07bd4, .prm_sldo_mm_ctrl = 0x4ae07bd8, }; + +struct omap_sys_ctrl_regs const omap5_ctrl = { + .control_status = 0x4A002134, + .control_paconf_global = 0x4A002DA0, + .control_paconf_mode = 0x4A002DA4, + .control_smart1io_padconf_0 = 0x4A002DA8, + .control_smart1io_padconf_1 = 0x4A002DAC, + .control_smart1io_padconf_2 = 0x4A002DB0, + .control_smart2io_padconf_0 = 0x4A002DB4, + .control_smart2io_padconf_1 = 0x4A002DB8, + .control_smart2io_padconf_2 = 0x4A002DBC, + .control_smart3io_padconf_0 = 0x4A002DC0, + .control_smart3io_padconf_1 = 0x4A002DC4, + .control_pbias = 0x4A002E00, + .control_i2c_0 = 0x4A002E04, + .control_camera_rx = 0x4A002E08, + .control_hdmi_tx_phy = 0x4A002E0C, + .control_uniportm = 0x4A002E10, + .control_dsiphy = 0x4A002E14, + .control_mcbsplp = 0x4A002E18, + .control_usb2phycore = 0x4A002E1C, + .control_hdmi_1 = 0x4A002E20, + .control_hsi = 0x4A002E24, + .control_ddr3ch1_0 = 0x4A002E30, + .control_ddr3ch2_0 = 0x4A002E34, + .control_ddrch1_0 = 0x4A002E38, + .control_ddrch1_1 = 0x4A002E3C, + .control_ddrch2_0 = 0x4A002E40, + .control_ddrch2_1 = 0x4A002E44, + .control_lpddr2ch1_0 = 0x4A002E48, + .control_lpddr2ch1_1 = 0x4A002E4C, + .control_ddrio_0 = 0x4A002E50, + .control_ddrio_1 = 0x4A002E54, + .control_ddrio_2 = 0x4A002E58, + .control_hyst_1 = 0x4A002E5C, + .control_usbb_hsic_control = 0x4A002E60, + .control_c2c = 0x4A002E64, + .control_core_control_spare_rw = 0x4A002E68, + .control_core_control_spare_r = 0x4A002E6C, + .control_core_control_spare_r_c0 = 0x4A002E70, + .control_srcomp_north_side = 0x4A002E74, + .control_srcomp_south_side = 0x4A002E78, + .control_srcomp_east_side = 0x4A002E7C, + .control_srcomp_west_side = 0x4A002E80, + .control_srcomp_code_latch = 0x4A002E84, + .control_port_emif1_sdram_config = 0x4AE0C110, + .control_port_emif1_lpddr2_nvm_config = 0x4AE0C114, + .control_port_emif2_sdram_config = 0x4AE0C118, + .control_emif1_sdram_config_ext = 0x4AE0C144, + .control_emif2_sdram_config_ext = 0x4AE0C148, + .control_smart1nopmio_padconf_0 = 0x4AE0CDA0, + .control_smart1nopmio_padconf_1 = 0x4AE0CDA4, + .control_padconf_mode = 0x4AE0CDA8, + .control_xtal_oscillator = 0x4AE0CDAC, + .control_i2c_2 = 0x4AE0CDB0, + .control_ckobuffer = 0x4AE0CDB4, + .control_wkup_control_spare_rw = 0x4AE0CDB8, + .control_wkup_control_spare_r = 0x4AE0CDBC, + .control_wkup_control_spare_r_c0 = 0x4AE0CDC0, + .control_srcomp_east_side_wkup = 0x4AE0CDC4, + .control_efuse_1 = 0x4AE0CDC8, + .control_efuse_2 = 0x4AE0CDCC, + .control_efuse_3 = 0x4AE0CDD0, + .control_efuse_4 = 0x4AE0CDD4, + .control_efuse_5 = 0x4AE0CDD8, + .control_efuse_6 = 0x4AE0CDDC, + .control_efuse_7 = 0x4AE0CDE0, + .control_efuse_8 = 0x4AE0CDE4, + .control_efuse_9 = 0x4AE0CDE8, + .control_efuse_10 = 0x4AE0CDEC, + .control_efuse_11 = 0x4AE0CDF0, + .control_efuse_12 = 0x4AE0CDF4, + .control_efuse_13 = 0x4AE0CDF8, +}; diff --git a/arch/arm/include/asm/arch-omap4/omap.h b/arch/arm/include/asm/arch-omap4/omap.h index 73edd9d..5f321fe 100644 --- a/arch/arm/include/asm/arch-omap4/omap.h +++ b/arch/arm/include/asm/arch-omap4/omap.h @@ -132,34 +132,6 @@ struct s32ktimer { #define DEVICE_TYPE_MASK (0x7 << DEVICE_TYPE_SHIFT) #define DEVICE_GP 0x3
-struct omap_sys_ctrl_regs { - unsigned int pad1[129]; - unsigned int control_id_code; /* 0x4A002204 */ - unsigned int pad11[22]; - unsigned int control_std_fuse_opp_bgap; /* 0x4a002260 */ - unsigned int pad2[24]; /* 0x4a002264 */ - unsigned int control_status; /* 0x4a0022c4 */ - unsigned int pad3[22]; /* 0x4a0022c8 */ - unsigned int control_ldosram_iva_voltage_ctrl; /* 0x4A002320 */ - unsigned int control_ldosram_mpu_voltage_ctrl; /* 0x4A002324 */ - unsigned int control_ldosram_core_voltage_ctrl; /* 0x4A002328 */ - unsigned int pad4[260277]; - unsigned int control_pbiaslite; /* 0x4A100600 */ - unsigned int pad5[63]; - unsigned int control_efuse_1; /* 0x4A100700 */ - unsigned int control_efuse_2; /* 0x4A100704 */ -}; - -struct control_lpddr2io_regs { - unsigned int control_lpddr2io1_0; - unsigned int control_lpddr2io1_1; - unsigned int control_lpddr2io1_2; - unsigned int control_lpddr2io1_3; - unsigned int control_lpddr2io2_0; - unsigned int control_lpddr2io2_1; - unsigned int control_lpddr2io2_2; - unsigned int control_lpddr2io2_3; -}; #endif /* __ASSEMBLY__ */
/* @@ -181,7 +153,8 @@ struct control_lpddr2io_regs { #define OMAP_SRAM_SCRATCH_PRCM_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x14) #define OMAP_SRAM_SCRATCH_DPLLS_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x18) #define OMAP_SRAM_SCRATCH_VCORES_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x1C) -#define OMAP4_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x20) +#define OMAP4_SRAM_SCRATCH_SYS_CTRL (SRAM_SCRATCH_SPACE_ADDR + 0x20) +#define OMAP4_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x24)
/* ROM code defines */ /* Boot device */ diff --git a/arch/arm/include/asm/arch-omap5/omap.h b/arch/arm/include/asm/arch-omap5/omap.h index 4bf555a..a91da7d 100644 --- a/arch/arm/include/asm/arch-omap5/omap.h +++ b/arch/arm/include/asm/arch-omap5/omap.h @@ -131,87 +131,6 @@ struct s32ktimer { #define DEVICE_TYPE_MASK (0x7 << DEVICE_TYPE_SHIFT) #define DEVICE_GP 0x3
-struct omap_sys_ctrl_regs { - u32 pad0[77]; /* 0x4A002000 */ - u32 control_status; /* 0x4A002134 */ - u32 pad1[794]; /* 0x4A002138 */ - u32 control_paconf_global; /* 0x4A002DA0 */ - u32 control_paconf_mode; /* 0x4A002DA4 */ - u32 control_smart1io_padconf_0; /* 0x4A002DA8 */ - u32 control_smart1io_padconf_1; /* 0x4A002DAC */ - u32 control_smart1io_padconf_2; /* 0x4A002DB0 */ - u32 control_smart2io_padconf_0; /* 0x4A002DB4 */ - u32 control_smart2io_padconf_1; /* 0x4A002DB8 */ - u32 control_smart2io_padconf_2; /* 0x4A002DBC */ - u32 control_smart3io_padconf_0; /* 0x4A002DC0 */ - u32 control_smart3io_padconf_1; /* 0x4A002DC4 */ - u32 pad2[14]; - u32 control_pbias; /* 0x4A002E00 */ - u32 control_i2c_0; /* 0x4A002E04 */ - u32 control_camera_rx; /* 0x4A002E08 */ - u32 control_hdmi_tx_phy; /* 0x4A002E0C */ - u32 control_uniportm; /* 0x4A002E10 */ - u32 control_dsiphy; /* 0x4A002E14 */ - u32 control_mcbsplp; /* 0x4A002E18 */ - u32 control_usb2phycore; /* 0x4A002E1C */ - u32 control_hdmi_1; /*0x4A002E20*/ - u32 control_hsi; /*0x4A002E24*/ - u32 pad3[2]; - u32 control_ddr3ch1_0; /*0x4A002E30*/ - u32 control_ddr3ch2_0; /*0x4A002E34*/ - u32 control_ddrch1_0; /*0x4A002E38*/ - u32 control_ddrch1_1; /*0x4A002E3C*/ - u32 control_ddrch2_0; /*0x4A002E40*/ - u32 control_ddrch2_1; /*0x4A002E44*/ - u32 control_lpddr2ch1_0; /*0x4A002E48*/ - u32 control_lpddr2ch1_1; /*0x4A002E4C*/ - u32 control_ddrio_0; /*0x4A002E50*/ - u32 control_ddrio_1; /*0x4A002E54*/ - u32 control_ddrio_2; /*0x4A002E58*/ - u32 control_hyst_1; /*0x4A002E5C*/ - u32 control_usbb_hsic_control; /*0x4A002E60*/ - u32 control_c2c; /*0x4A002E64*/ - u32 control_core_control_spare_rw; /*0x4A002E68*/ - u32 control_core_control_spare_r; /*0x4A002E6C*/ - u32 control_core_control_spare_r_c0; /*0x4A002E70*/ - u32 control_srcomp_north_side; /*0x4A002E74*/ - u32 control_srcomp_south_side; /*0x4A002E78*/ - u32 control_srcomp_east_side; /*0x4A002E7C*/ - u32 control_srcomp_west_side; /*0x4A002E80*/ - u32 control_srcomp_code_latch; /*0x4A002E84*/ - u32 pad4[3679394]; - u32 control_port_emif1_sdram_config; /*0x4AE0C110*/ - u32 control_port_emif1_lpddr2_nvm_config; /*0x4AE0C114*/ - u32 control_port_emif2_sdram_config; /*0x4AE0C118*/ - u32 pad5[10]; - u32 control_emif1_sdram_config_ext; /* 0x4AE0C144 */ - u32 control_emif2_sdram_config_ext; /* 0x4AE0C148 */ - u32 pad6[789]; - u32 control_smart1nopmio_padconf_0; /* 0x4AE0CDA0 */ - u32 control_smart1nopmio_padconf_1; /* 0x4AE0CDA4 */ - u32 control_padconf_mode; /* 0x4AE0CDA8 */ - u32 control_xtal_oscillator; /* 0x4AE0CDAC */ - u32 control_i2c_2; /* 0x4AE0CDB0 */ - u32 control_ckobuffer; /* 0x4AE0CDB4 */ - u32 control_wkup_control_spare_rw; /* 0x4AE0CDB8 */ - u32 control_wkup_control_spare_r; /* 0x4AE0CDBC */ - u32 control_wkup_control_spare_r_c0; /* 0x4AE0CDC0 */ - u32 control_srcomp_east_side_wkup; /* 0x4AE0CDC4 */ - u32 control_efuse_1; /* 0x4AE0CDC8 */ - u32 control_efuse_2; /* 0x4AE0CDCC */ - u32 control_efuse_3; /* 0x4AE0CDD0 */ - u32 control_efuse_4; /* 0x4AE0CDD4 */ - u32 control_efuse_5; /* 0x4AE0CDD8 */ - u32 control_efuse_6; /* 0x4AE0CDDC */ - u32 control_efuse_7; /* 0x4AE0CDE0 */ - u32 control_efuse_8; /* 0x4AE0CDE4 */ - u32 control_efuse_9; /* 0x4AE0CDE8 */ - u32 control_efuse_10; /* 0x4AE0CDEC */ - u32 control_efuse_11; /* 0x4AE0CDF0 */ - u32 control_efuse_12; /* 0x4AE0CDF4 */ - u32 control_efuse_13; /* 0x4AE0CDF8 */ -}; - /* Output impedance control */ #define ds_120_ohm 0x0 #define ds_60_ohm 0x1 @@ -274,7 +193,8 @@ struct omap_sys_ctrl_regs { #define OMAP_SRAM_SCRATCH_PRCM_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x14) #define OMAP_SRAM_SCRATCH_DPLLS_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x18) #define OMAP_SRAM_SCRATCH_VCORES_PTR (SRAM_SCRATCH_SPACE_ADDR + 0x1C) -#define OMAP5_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x20) +#define OMAP5_SRAM_SCRATCH_SYS_CTRL (SRAM_SCRATCH_SPACE_ADDR + 0x20) +#define OMAP5_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x24)
/* Silicon revisions */ #define OMAP4430_SILICON_ID_INVALID 0xFFFFFFFF diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index eee6893..2115687 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -326,6 +326,94 @@ struct prcm_regs { u32 prm_vc_cfg_channel; };
+struct omap_sys_ctrl_regs { + u32 control_status; + u32 control_id_code; + u32 control_std_fuse_opp_bgap; + u32 control_ldosram_iva_voltage_ctrl; + u32 control_ldosram_mpu_voltage_ctrl; + u32 control_ldosram_core_voltage_ctrl; + u32 control_paconf_global; + u32 control_paconf_mode; + u32 control_smart1io_padconf_0; + u32 control_smart1io_padconf_1; + u32 control_smart1io_padconf_2; + u32 control_smart2io_padconf_0; + u32 control_smart2io_padconf_1; + u32 control_smart2io_padconf_2; + u32 control_smart3io_padconf_0; + u32 control_smart3io_padconf_1; + u32 control_pbias; + u32 control_i2c_0; + u32 control_camera_rx; + u32 control_hdmi_tx_phy; + u32 control_uniportm; + u32 control_dsiphy; + u32 control_mcbsplp; + u32 control_usb2phycore; + u32 control_hdmi_1; + u32 control_hsi; + u32 control_ddr3ch1_0; + u32 control_ddr3ch2_0; + u32 control_ddrch1_0; + u32 control_ddrch1_1; + u32 control_ddrch2_0; + u32 control_ddrch2_1; + u32 control_lpddr2ch1_0; + u32 control_lpddr2ch1_1; + u32 control_ddrio_0; + u32 control_ddrio_1; + u32 control_ddrio_2; + u32 control_lpddr2io1_0; + u32 control_lpddr2io1_1; + u32 control_lpddr2io1_2; + u32 control_lpddr2io1_3; + u32 control_lpddr2io2_0; + u32 control_lpddr2io2_1; + u32 control_lpddr2io2_2; + u32 control_lpddr2io2_3; + u32 control_hyst_1; + u32 control_usbb_hsic_control; + u32 control_c2c; + u32 control_core_control_spare_rw; + u32 control_core_control_spare_r; + u32 control_core_control_spare_r_c0; + u32 control_srcomp_north_side; + u32 control_srcomp_south_side; + u32 control_srcomp_east_side; + u32 control_srcomp_west_side; + u32 control_srcomp_code_latch; + u32 control_pbiaslite; + u32 control_port_emif1_sdram_config; + u32 control_port_emif1_lpddr2_nvm_config; + u32 control_port_emif2_sdram_config; + u32 control_emif1_sdram_config_ext; + u32 control_emif2_sdram_config_ext; + u32 control_smart1nopmio_padconf_0; + u32 control_smart1nopmio_padconf_1; + u32 control_padconf_mode; + u32 control_xtal_oscillator; + u32 control_i2c_2; + u32 control_ckobuffer; + u32 control_wkup_control_spare_rw; + u32 control_wkup_control_spare_r; + u32 control_wkup_control_spare_r_c0; + u32 control_srcomp_east_side_wkup; + u32 control_efuse_1; + u32 control_efuse_2; + u32 control_efuse_3; + u32 control_efuse_4; + u32 control_efuse_5; + u32 control_efuse_6; + u32 control_efuse_7; + u32 control_efuse_8; + u32 control_efuse_9; + u32 control_efuse_10; + u32 control_efuse_11; + u32 control_efuse_12; + u32 control_efuse_13; +}; + struct dpll_params { u32 m; u32 n; @@ -390,6 +478,9 @@ extern struct prcm_regs const omap4_prcm; extern struct dplls const **dplls_data; extern struct vcores_data const **omap_vcores; extern const u32 sys_clk_array[8]; +extern struct omap_sys_ctrl_regs const **ctrl; +extern struct omap_sys_ctrl_regs const omap4_ctrl; +extern struct omap_sys_ctrl_regs const omap5_ctrl;
diff --git a/drivers/mmc/omap_hsmmc.c b/drivers/mmc/omap_hsmmc.c index afd9b30..f34214b 100644 --- a/drivers/mmc/omap_hsmmc.c +++ b/drivers/mmc/omap_hsmmc.c @@ -50,18 +50,15 @@ static struct mmc hsmmc_dev[2]; static void omap4_vmmc_pbias_config(struct mmc *mmc) { u32 value = 0; - struct omap_sys_ctrl_regs *const ctrl = - (struct omap_sys_ctrl_regs *) SYSCTRL_GENERAL_CORE_BASE;
- - value = readl(&ctrl->control_pbiaslite); + value = readl((*ctrl)->control_pbiaslite); value &= ~(MMC1_PBIASLITE_PWRDNZ | MMC1_PWRDNZ); - writel(value, &ctrl->control_pbiaslite); + writel(value, (*ctrl)->control_pbiaslite); /* set VMMC to 3V */ twl6030_power_mmc_init(); - value = readl(&ctrl->control_pbiaslite); + value = readl((*ctrl)->control_pbiaslite); value |= MMC1_PBIASLITE_VMODE | MMC1_PBIASLITE_PWRDNZ | MMC1_PWRDNZ; - writel(value, &ctrl->control_pbiaslite); + writel(value, (*ctrl)->control_pbiaslite); } #endif
@@ -69,26 +66,24 @@ static void omap4_vmmc_pbias_config(struct mmc *mmc) static void omap5_pbias_config(struct mmc *mmc) { u32 value = 0; - struct omap_sys_ctrl_regs *const ctrl = - (struct omap_sys_ctrl_regs *) SYSCTRL_GENERAL_CORE_BASE;
- value = readl(&ctrl->control_pbias); + value = readl((*ctrl)->control_pbias); value &= ~(SDCARD_PWRDNZ | SDCARD_BIAS_PWRDNZ); value |= SDCARD_BIAS_HIZ_MODE; - writel(value, &ctrl->control_pbias); + writel(value, (*ctrl)->control_pbias);
twl6035_mmc1_poweron_ldo();
- value = readl(&ctrl->control_pbias); + value = readl((*ctrl)->control_pbias); value &= ~SDCARD_BIAS_HIZ_MODE; value |= SDCARD_PBIASLITE_VMODE | SDCARD_PWRDNZ | SDCARD_BIAS_PWRDNZ; - writel(value, &ctrl->control_pbias); + writel(value, (*ctrl)->control_pbias);
- value = readl(&ctrl->control_pbias); + value = readl((*ctrl)->control_pbias); if (value & (1 << 23)) { value &= ~(SDCARD_PWRDNZ | SDCARD_BIAS_PWRDNZ); value |= SDCARD_BIAS_HIZ_MODE; - writel(value, &ctrl->control_pbias); + writel(value, (*ctrl)->control_pbias); } } #endif
Reviewed-by: Tom Rini trini@ti.com
There is some code duplication in the ddr io settings code. This is avoided by moving the data to a Soc specific place and letting the code generic.
This avoids unnessecary code addition for future socs.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/cpu/armv7/omap5/hw_data.c | 36 +++++++++++++ arch/arm/cpu/armv7/omap5/hwinit.c | 75 +++++++++++---------------- arch/arm/include/asm/arch-omap5/omap.h | 10 ++++ arch/arm/include/asm/arch-omap5/sys_proto.h | 1 + 4 files changed, 78 insertions(+), 44 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap5/hw_data.c b/arch/arm/cpu/armv7/omap5/hw_data.c index 59c2283..6b039f5 100644 --- a/arch/arm/cpu/armv7/omap5/hw_data.c +++ b/arch/arm/cpu/armv7/omap5/hw_data.c @@ -32,6 +32,7 @@ #include <asm/arch/clocks.h> #include <asm/omap_gpio.h> #include <asm/io.h> +#include <asm/emif.h>
struct prcm_regs const **prcm = (struct prcm_regs const **) OMAP_SRAM_SCRATCH_PRCM_PTR; @@ -414,6 +415,24 @@ void enable_non_essential_clocks(void) MODULE_CLKCTRL_MODULEMODE_SHIFT); }
+const struct ctrl_ioregs ioregs_omap5430 = { + .ctrl_ddrch = DDR_IO_I_34OHM_SR_FASTEST_WD_DQ_NO_PULL_DQS_PULL_DOWN, + .ctrl_lpddr2ch = DDR_IO_I_34OHM_SR_FASTEST_WD_CK_CKE_NCS_CA_PULL_DOWN, + .ctrl_ddrio_0 = DDR_IO_0_DDR2_DQ_INT_EN_ALL_DDR3_CA_DIS_ALL, + .ctrl_ddrio_1 = DDR_IO_1_DQ_OUT_EN_ALL_DQ_INT_EN_ALL, + .ctrl_ddrio_2 = DDR_IO_2_CA_OUT_EN_ALL_CA_INT_EN_ALL, +}; + +const struct ctrl_ioregs ioregs_omap5432_es1 = { + .ctrl_ddrch = DDR_IO_I_40OHM_SR_FAST_WD_DQ_NO_PULL_DQS_NO_PULL, + .ctrl_lpddr2ch = 0x0, + .ctrl_ddr3ch = DDR_IO_I_40OHM_SR_SLOWEST_WD_DQ_NO_PULL_DQS_NO_PULL, + .ctrl_ddrio_0 = DDR_IO_0_VREF_CELLS_DDR3_VALUE, + .ctrl_ddrio_1 = DDR_IO_1_VREF_CELLS_DDR3_VALUE, + .ctrl_ddrio_2 = DDR_IO_2_VREF_CELLS_DDR3_VALUE, + .ctrl_emif_sdram_config_ext = SDRAM_CONFIG_EXT_RD_LVL_11_SAMPLES, +}; + void hw_data_init(void) { u32 omap_rev = omap_revision(); @@ -438,3 +457,20 @@ void hw_data_init(void)
*ctrl = &omap5_ctrl; } + +void get_ioregs(const struct ctrl_ioregs **regs) +{ + u32 omap_rev = omap_revision(); + + switch (omap_rev) { + case OMAP5430_ES1_0: + *regs = &ioregs_omap5430; + break; + case OMAP5432_ES1_0: + *regs = &ioregs_omap5432_es1; + break; + + default: + printf("\n INVALID OMAP REVISION "); + } +} diff --git a/arch/arm/cpu/armv7/omap5/hwinit.c b/arch/arm/cpu/armv7/omap5/hwinit.c index 1863c69..dfc0e44 100644 --- a/arch/arm/cpu/armv7/omap5/hwinit.c +++ b/arch/arm/cpu/armv7/omap5/hwinit.c @@ -56,60 +56,47 @@ const struct gpio_bank *const omap_gpio_bank = gpio_bank_54xx; /* LPDDR2 specific IO settings */ static void io_settings_lpddr2(void) { - writel(DDR_IO_I_34OHM_SR_FASTEST_WD_DQ_NO_PULL_DQS_PULL_DOWN, - (*ctrl)->control_ddrch1_0); - writel(DDR_IO_I_34OHM_SR_FASTEST_WD_DQ_NO_PULL_DQS_PULL_DOWN, - (*ctrl)->control_ddrch1_1); - writel(DDR_IO_I_34OHM_SR_FASTEST_WD_DQ_NO_PULL_DQS_PULL_DOWN, - (*ctrl)->control_ddrch2_0); - writel(DDR_IO_I_34OHM_SR_FASTEST_WD_DQ_NO_PULL_DQS_PULL_DOWN, - (*ctrl)->control_ddrch2_1); - writel(DDR_IO_I_34OHM_SR_FASTEST_WD_CK_CKE_NCS_CA_PULL_DOWN, - (*ctrl)->control_lpddr2ch1_0); - writel(DDR_IO_I_34OHM_SR_FASTEST_WD_CK_CKE_NCS_CA_PULL_DOWN, - (*ctrl)->control_lpddr2ch1_1); - writel(DDR_IO_0_DDR2_DQ_INT_EN_ALL_DDR3_CA_DIS_ALL, - (*ctrl)->control_ddrio_0); - writel(DDR_IO_1_DQ_OUT_EN_ALL_DQ_INT_EN_ALL, - (*ctrl)->control_ddrio_1); - writel(DDR_IO_2_CA_OUT_EN_ALL_CA_INT_EN_ALL, - (*ctrl)->control_ddrio_2); + const struct ctrl_ioregs *ioregs; + + get_ioregs(&ioregs); + writel(ioregs->ctrl_ddrch, (*ctrl)->control_ddrch1_0); + writel(ioregs->ctrl_ddrch, (*ctrl)->control_ddrch1_1); + writel(ioregs->ctrl_ddrch, (*ctrl)->control_ddrch2_0); + writel(ioregs->ctrl_ddrch, (*ctrl)->control_ddrch2_1); + writel(ioregs->ctrl_lpddr2ch, (*ctrl)->control_lpddr2ch1_0); + writel(ioregs->ctrl_lpddr2ch, (*ctrl)->control_lpddr2ch1_1); + writel(ioregs->ctrl_ddrio_0, (*ctrl)->control_ddrio_0); + writel(ioregs->ctrl_ddrio_1, (*ctrl)->control_ddrio_1); + writel(ioregs->ctrl_ddrio_2, (*ctrl)->control_ddrio_2); }
/* DDR3 specific IO settings */ static void io_settings_ddr3(void) { u32 io_settings = 0; + const struct ctrl_ioregs *ioregs;
- writel(DDR_IO_I_40OHM_SR_SLOWEST_WD_DQ_NO_PULL_DQS_NO_PULL, - (*ctrl)->control_ddr3ch1_0); - writel(DDR_IO_I_40OHM_SR_FAST_WD_DQ_NO_PULL_DQS_NO_PULL, - (*ctrl)->control_ddrch1_0); - writel(DDR_IO_I_40OHM_SR_FAST_WD_DQ_NO_PULL_DQS_NO_PULL, - (*ctrl)->control_ddrch1_1); - - writel(DDR_IO_I_40OHM_SR_SLOWEST_WD_DQ_NO_PULL_DQS_NO_PULL, - (*ctrl)->control_ddr3ch2_0); - writel(DDR_IO_I_40OHM_SR_FAST_WD_DQ_NO_PULL_DQS_NO_PULL, - (*ctrl)->control_ddrch2_0); - writel(DDR_IO_I_40OHM_SR_FAST_WD_DQ_NO_PULL_DQS_NO_PULL, - (*ctrl)->control_ddrch2_1); - - writel(DDR_IO_0_VREF_CELLS_DDR3_VALUE, - (*ctrl)->control_ddrio_0); - writel(DDR_IO_1_VREF_CELLS_DDR3_VALUE, - (*ctrl)->control_ddrio_1); - writel(DDR_IO_2_VREF_CELLS_DDR3_VALUE, - (*ctrl)->control_ddrio_2); + get_ioregs(&ioregs); + writel(ioregs->ctrl_ddr3ch, (*ctrl)->control_ddr3ch1_0); + writel(ioregs->ctrl_ddrch, (*ctrl)->control_ddrch1_0); + writel(ioregs->ctrl_ddrch, (*ctrl)->control_ddrch1_1); + + writel(ioregs->ctrl_ddr3ch, (*ctrl)->control_ddr3ch2_0); + writel(ioregs->ctrl_ddrch, (*ctrl)->control_ddrch2_0); + writel(ioregs->ctrl_ddrch, (*ctrl)->control_ddrch2_1); + + writel(ioregs->ctrl_ddrio_0, (*ctrl)->control_ddrio_0); + writel(ioregs->ctrl_ddrio_1, (*ctrl)->control_ddrio_1); + writel(ioregs->ctrl_ddrio_2, (*ctrl)->control_ddrio_2);
/* omap5432 does not use lpddr2 */ - writel(0x0, (*ctrl)->control_lpddr2ch1_0); - writel(0x0, (*ctrl)->control_lpddr2ch1_1); + writel(ioregs->ctrl_lpddr2ch, (*ctrl)->control_lpddr2ch1_0); + writel(ioregs->ctrl_lpddr2ch, (*ctrl)->control_lpddr2ch1_1);
- writel(SDRAM_CONFIG_EXT_RD_LVL_11_SAMPLES, - (*ctrl)->control_emif1_sdram_config_ext); - writel(SDRAM_CONFIG_EXT_RD_LVL_11_SAMPLES, - (*ctrl)->control_emif2_sdram_config_ext); + writel(ioregs->ctrl_emif_sdram_config_ext, + (*ctrl)->control_emif1_sdram_config_ext); + writel(ioregs->ctrl_emif_sdram_config_ext, + (*ctrl)->control_emif2_sdram_config_ext);
/* Disable DLL select */ io_settings = (readl((*ctrl)->control_port_emif1_sdram_config) diff --git a/arch/arm/include/asm/arch-omap5/omap.h b/arch/arm/include/asm/arch-omap5/omap.h index a91da7d..873ccd7 100644 --- a/arch/arm/include/asm/arch-omap5/omap.h +++ b/arch/arm/include/asm/arch-omap5/omap.h @@ -229,5 +229,15 @@ struct omap_boot_parameters { unsigned char reset_reason; unsigned char ch_flags; }; + +struct ctrl_ioregs { + u32 ctrl_ddrch; + u32 ctrl_lpddr2ch; + u32 ctrl_ddr3ch; + u32 ctrl_ddrio_0; + u32 ctrl_ddrio_1; + u32 ctrl_ddrio_2; + u32 ctrl_emif_sdram_config_ext; +}; #endif /* __ASSEMBLY__ */ #endif diff --git a/arch/arm/include/asm/arch-omap5/sys_proto.h b/arch/arm/include/asm/arch-omap5/sys_proto.h index 2b3a071..201ed6f 100644 --- a/arch/arm/include/asm/arch-omap5/sys_proto.h +++ b/arch/arm/include/asm/arch-omap5/sys_proto.h @@ -58,6 +58,7 @@ void omap_vc_init(u16 speed_khz); int omap_vc_bypass_send_value(u8 sa, u8 reg_addr, u8 reg_data); u32 warm_reset(void); void force_emif_self_refresh(void); +void get_ioregs(const struct ctrl_ioregs **regs);
/* * This is used to verify if the configuration header
On Mon, Feb 04, 2013 at 07:51:58PM +0530, R Sricharan wrote:
This series is intended to cleanup code which is duplicated across soc specific files. This is accomplished by moving soc specifc data to one place and having the code common. This helps in avoiding un necessary cpu checks and minimal code addition for future socs.
Tested this on OMAP5 ES1.0, OMAP4460 Panda boards and verified MAKEALL for all armv7 boards.
Lokesh Vutla (4): ARM: OMAP4+: emif: Detect SDRAM from SDRAM config register ARM: OMAP4+: Cleanup emif specific files ARM: OMAP4+: Make control module register structure generic ARM: OMAP5: Clean up iosettings code
R Sricharan (3): ARM: OMAP4+: Change the PRCM structure prototype common for all Socs ARM: OMAP4+: Cleanup the clocks layer ARM: OMAP4+: Clean up the pmic code
Patch 2 of 7 didn't hit the mailing list yet.
R Sricharan
